commit eaa496ffaaf19591fe471a36cef366146eeb9153 upstream.
ep->mult is supposed to be set to Isochronous and
Interrupt Endapoint's multiplier value. This value
is computed from different places depending on the
link speed.
If we're dealing with HighSpeed, then it's part of
bits [12:11] of wMaxPacketSize. This case wasn't
taken into consideration before.
While at that, also make sure the ep->mult defaults
to one so drivers can use it unconditionally and
assume they'll never multiply ep->maxpacket to zero.
Signed-off-by: Felipe Balbi <felipe.balbi@linux.intel.com>
This reverts commit c53af76d5de1af844a71e673ae4a02f1786c1b9c which is
commit eaa496ffaaf19591fe471a36cef366146eeb9153 upstream as it was
incorrect.
Reported-by: Bin Liu <b-liu@ti.com>
Cc: Felipe Balbi <balbi@kernel.org>
commit 4349bd775cc8fd75cb648e3a2036a690f497de5c upstream.
We were storing viewport relative coordinates for AVIVO/DCE display
engines. However, radeon_crtc_cursor_set2 and radeon_cursor_reset pass
radeon_crtc->cursor_x/y as the x/y parameters of
radeon_cursor_move_locked, which would break if the CRTC isn't located
at (0, 0).
Cc: stable@vger.kernel.org
Signed-off-by: Michel Dänzer <michel.daenzer@amd.com>
Reviewed-by: Alex Deucher <alexander.deucher@amd.com>
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
commit f0b0faff78c2c2e8efe843de55405a1f0470b8c4 upstream.
Smatch complains about where the au8293_data is placed:
drivers/media/pci/cx23885/cx23885-dvb.c:2174 dvb_register() info: 'a8293_pdata' is not actually initialized (unreached code).
It is not actually expected to have such initialization at
switch {
foo = bar;
case:
Not really sure how gcc does that, but this is something that I would
expect that different compilers would do different things.
David Howells checked with the compiler people: it's not really expected to
initialise as expected.
So, move the initialization outside the switch(), making smatch to
shut up one warning.
Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
commit 57e7c8cef224af166b8ec932b5e383641418c005 upstream.
When CONFIG_PCI_MSI is disabled, we get warnings about unused functions
in the vxge driver:
drivers/net/ethernet/neterion/vxge/vxge-main.c:2121:13: warning: 'adaptive_coalesce_tx_interrupts' defined but not used [-Wunused-function]
drivers/net/ethernet/neterion/vxge/vxge-main.c:2149:13: warning: 'adaptive_coalesce_rx_interrupts' defined but not used [-Wunused-function]
We could add another #ifdef here, but it's nicer to avoid those warnings
for good by converting the existing #ifdef to if(IS_ENABLED()), which has
the same effect but provides better compile-time coverage in general,
and lets the compiler understand better when the function is intentionally
unused.
commit 2f5281ba2a8feaf6f0aee93356f350855bb530fc upstream.
cpmac_start_xmit() used the max() macro on skb->len (an unsigned int)
and ETH_ZLEN (a signed int literal). This led to the following compiler
warning:
In file included from include/linux/list.h:8:0,
from include/linux/module.h:9,
from drivers/net/ethernet/ti/cpmac.c:19:
drivers/net/ethernet/ti/cpmac.c: In function 'cpmac_start_xmit':
include/linux/kernel.h:748:17: warning: comparison of distinct pointer
types lacks a cast
(void) (&_max1 == &_max2); \
drivers/net/ethernet/ti/cpmac.c:560:8: note: in expansion of macro 'max'
len = max(skb->len, ETH_ZLEN);
On top of this, it assigned the result of the max() macro to a signed
integer whilst all further uses of it result in it being cast to varying
widths of unsigned integer.
Fix this up by using max_t to ensure the comparison is performed as
unsigned integers, and for consistency change the type of the len
variable to unsigned int.
Signed-off-by: Paul Burton <paul.burton@imgtec.com>
commit f6b1160eb27f990cc1c48b67a5f83cb63115284e upstream.
Arnd Bergmann pointed out that gcc-6 warns about passing negative signed
integer into swab16() due to the macro expansion of 'outw'.
It appears that the register map constants are causing the warnings.
Actually, it might just be the (1 << 15) ones...
Convert all the constants as suggested by checkpatch.pl:
CHECK: Prefer using the BIT macro
The BIT() macro will make all the constants explicitly 'unsigned', which
helps to avoid the warning.
Fix the, unsused, DT2821_CHANCSR_PRESLA() macro. The "Present List
Address" (PRESLA) bits in the CHANCSR register are read only. This
define was meant to extract the bits from the read value.
Reviewed-by: Ian Abbott <abbotti@mev.co.uk>
Tested-by: Arnd Bergmann <arnd@arndb.de>
commit 99e5cde5eae78bef95bfe7c16ccda87fb070149b upstream.
Make sure to drop any device reference taken by vio_find_node() when
adding and removing virtual I/O slots.
Fixes: 5eeb8c63a38f ("[PATCH] PCI Hotplug: rpaphp: Move VIO registration")
Signed-off-by: Johan Hovold <johan@kernel.org>
commit 82a301cb0ea2df8a5c88213094a01660067c7fb4 upstream.
Fixes: 90f5f7ad4f38("md: Wait for md_check_recovery before attempting device
removal.")
Reviewed-by: NeilBrown <neilb@suse.com>
Signed-off-by: Shaohua Li <shli@fb.com>
commit 16652a936e96f5dae53c3fbd38a570497baadaa8 upstream.
We never set "ret" to RESULT_OK.
Fixes: 9f9c4180f88d ("mmc: mmc_test: add test for non-blocking transfers")
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
commit bed570307ed78f21b77cb04a1df781dee4a8f05a upstream.
I noticed some wakeirq flakeyness with consumer drivers not using
autosuspend. For drivers not using autosuspend, the wakeirq may never
get unmasked in rpm_suspend() because of irq desc->depth.
We are configuring dedicated wakeirqs to start with IRQ_NOAUTOEN as we
naturally don't want them running until rpm_suspend() is called.
However, when a consumer driver initially calls pm_runtime_get(), we
now wrongly start with disable_irq_nosync() call on the dedicated
wakeirq that is disabled to start with.
This causes desc->depth to toggle between 1 and 2 instead of the usual
0 and 1. This can prevent enable_irq() from unmasking the wakeirq as
that only happens at desc->depth 1.
This does not necessarily show up with drivers using autosuspend as
there is time for disable_irq_nosync() before rpm_suspend() gets called
after the autosuspend timeout.
Let's fix the issue by adding wirq->status that lazily gets set on
the first rpm_suspend(). We also need PM runtime core private functions
for dev_pm_enable_wake_irq_check() and dev_pm_disable_wake_irq_check()
so we can enable the dedicated wakeirq on the first rpm_suspend().
While at it, let's also fix the comments for dev_pm_enable_wake_irq()
and dev_pm_disable_wake_irq(). Those can still be used by the consumer
drivers as needed because the IRQ core manages the interrupt usecount
for us.
Fixes: 4990d4fe327b (PM / Wakeirq: Add automated device wake IRQ handling)
commit 34c535793bcbf9263cf22f8a52101f796cdfab8e upstream.
We did not implement an irq_cpu_offline callback for our irqchip, yet we
support setting a given IRQ's affinity. This resulted in interrupts
whose affinity mask included CPUs being taken offline not to work
correctly once the CPU had been put offline.
Fixes: 5f7f0317ed28 ("IRQCHIP: Add new driver for BCM7038-style level 1 interrupt controllers")
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
Cc: linux-mips@linux-mips.org
Cc: jason@lakedaemon.net
Cc: marc.zyngier@arm.com
Cc: cernekee@gmail.com
Cc: jaedon.shin@gmail.com
Cc: ralf@linux-mips.org
Cc: justinpopo6@gmail.com
Link: http://lkml.kernel.org/r/1477948656-12966-2-git-send-email-f.fainelli@gmail.com
commit a91918cd3ea11f91c68e08e1e8ce1b560447a80e upstream.
This iscsit_tpg_add_portal_group() function is only called from
lio_target_tiqn_addtpg(). Both functions free the "tpg" pointer on
error so it's a double free bug. The memory is allocated in the caller
so it should be freed in the caller and not here.
Fixes: e48354ce078c ("iscsi-target: Add iSCSI fabric support for target v4.1")
Reviewed-by: David Disseldorp <ddiss@suse.de>
[ bvanassche: Added "Fix" at start of patch title ]
Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com>
commit af15769ffab13d777e55fdef09d0762bf0c249c4 upstream.
gcc-7 notices that the condition in mvs_94xx_command_active looks
suspicious:
drivers/scsi/mvsas/mv_94xx.c: In function 'mvs_94xx_command_active':
drivers/scsi/mvsas/mv_94xx.c:671:15: error: '<<' in boolean context, did you mean '<' ? [-Werror=int-in-bool-context]
This was introduced when the mv_printk() statement got added, and leads
to the condition being ignored. This is probably harmless.
Changing '&&' to '&' makes the code look reasonable, as we check the
command bit before setting and printing it.
Fixes: a4632aae8b66 ("[SCSI] mvsas: Add new macros and functions")
Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de>
commit aec0e86172a79eb5e44aff1055bb953fe4d47c59 upstream.
We met the DMAR fault both on hpsa P420i and P421 SmartArray controllers
under kdump, it can be steadily reproduced on several different machines,
the dmesg log is like:
HP HPSA Driver (v 3.4.16-0)
hpsa 0000:02:00.0: using doorbell to reset controller
hpsa 0000:02:00.0: board ready after hard reset.
hpsa 0000:02:00.0: Waiting for controller to respond to no-op
DMAR: Setting identity map for device 0000:02:00.0 [0xe8000 - 0xe8fff]
DMAR: Setting identity map for device 0000:02:00.0 [0xf4000 - 0xf4fff]
DMAR: Setting identity map for device 0000:02:00.0 [0xbdf6e000 - 0xbdf6efff]
DMAR: Setting identity map for device 0000:02:00.0 [0xbdf6f000 - 0xbdf7efff]
DMAR: Setting identity map for device 0000:02:00.0 [0xbdf7f000 - 0xbdf82fff]
DMAR: Setting identity map for device 0000:02:00.0 [0xbdf83000 - 0xbdf84fff]
DMAR: DRHD: handling fault status reg 2
DMAR: [DMA Read] Request device [02:00.0] fault addr fffff000 [fault reason 06] PTE Read access is not set
hpsa 0000:02:00.0: controller message 03:00 timed out
hpsa 0000:02:00.0: no-op failed; re-trying
After some debugging, we found that the fault addr is from DMA initiated at
the driver probe stage after reset(not in-flight DMA), and the corresponding
pte entry value is correct, the fault is likely due to the old iommu caches
of the in-flight DMA before it.
Thus we need to flush the old cache after context mapping is setup for the
device, where the device is supposed to finish reset at its driver probe
stage and no in-flight DMA exists hereafter.
I'm not sure if the hardware is responsible for invalidating all the related
caches allocated in the iommu hardware before, but seems not the case for hpsa,
actually many device drivers have problems in properly resetting the hardware.
Anyway flushing (again) by software in kdump kernel when the device gets context
mapped which is a quite infrequent operation does little harm.
With this patch, the problematic machine can survive the kdump tests.
CC: Myron Stowe <myron.stowe@gmail.com>
CC: Joseph Szczypek <jszczype@redhat.com>
CC: Don Brace <don.brace@microsemi.com>
CC: Baoquan He <bhe@redhat.com>
CC: Dave Young <dyoung@redhat.com>
Fixes: 091d42e43d21 ("iommu/vt-d: Copy translation tables from old kernel")
Fixes: dbcd861f252d ("iommu/vt-d: Do not re-use domain-ids from the old kernel")
Fixes: cf484d0e6939 ("iommu/vt-d: Mark copied context entries")
Signed-off-by: Xunlei Pang <xlpang@redhat.com>
Tested-by: Don Brace <don.brace@microsemi.com>
Signed-off-by: Joerg Roedel <jroedel@suse.de>
commit 65ca7f5f7d1cdde6c25172fe6107cd16902f826f upstream.
Different encodings are used to represent supported PASID bits
and number of PASID table entries.
The current code assigns ecap_pss directly to extended context
table entry PTS which is wrong and could result in writing
non-zero bits to the reserved fields. IOMMU fault reason
11 will be reported when reserved bits are nonzero.
This patch converts ecap_pss to extend context entry pts encoding
based on VT-d spec. Chapter 9.4 as follows:
- number of PASID bits = ecap_pss + 1
- number of PASID table entries = 2^(pts + 5)
Software assigned limit of pasid_max value is also respected to
match the allocation limitation of PASID table.
cc: Mika Kuoppala <mika.kuoppala@linux.intel.com>
cc: Ashok Raj <ashok.raj@intel.com>
Signed-off-by: Jacob Pan <jacob.jun.pan@linux.intel.com>
Tested-by: Mika Kuoppala <mika.kuoppala@intel.com>
Fixes: 2f26e0a9c9860 ('iommu/vt-d: Add basic SVM PASID support')
commit 432abf68a79332282329286d190e21fe3ac02a31 upstream.
The generic command buffer entry is 128 bits (16 bytes), so the offset
of tail and head pointer should be 16 bytes aligned and increased with
0x10 per command.
When cmd buf is full, head = (tail + 0x10) % CMD_BUFFER_SIZE.
So when left space of cmd buf should be able to store only two
command, we should be issued one COMPLETE_WAIT additionally to wait
all older commands completed. Then the left space should be increased
after IOMMU fetching from cmd buf.
So left check value should be left <= 0x20 (two commands).
Signed-off-by: Huang Rui <ray.huang@amd.com>
Fixes: ac0ea6e92b222 ('x86/amd-iommu: Improve handling of full command buffer')
commit 24c790fbf5d8f54c8c82979db11edea8855b74bf upstream.
We should set "ret" to -EINVAL if iommu_group_get() fails.
Fixes: 55c99a4dc50f ("iommu/amd: Use iommu_attach_group()")
commit bae203d58b7dce89664071b3fafe20cedaa3e4f6 upstream.
Function mx31_clocks_init() is called during clock intialization on
legacy boards with reference clock frequency passed as its input
argument, this can be verified by examination of the function
declaration found in arch/arm/mach-imx/common.h and actual function
users which include that header file.
Inside CCF driver the function ignores its input argument, by chance
the used value in the function body is the same as input arguments on
side of all callers.
Fixes: d9388c843237 ("clk: imx31: Do not call mxc_timer_init twice when booting with DT")
Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
Reviewed-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
Acked-by: Stephen Boyd <sboyd@codeaurora.org>
commit 20979202ee6e4c68dab7bcf408787225a656d18e upstream.
Fix bug https://bugzilla.kernel.org/show_bug.cgi?id=188561. Function
wm831x_clkout_is_prepared() returns "true" when it fails to read
CLOCK_CONTROL_1. "true" means the device is already prepared. So
return "true" on the read failure seems improper.
Signed-off-by: Pan Bian <bianpan2016@163.com>
Acked-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com>
Fixes: f05259a6ffa4 ("clk: wm831x: Add initial WM831x clock driver")
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
commit 4fccd4a1e8944033bcd7693ea4e8fb478cd2059a upstream.
Fix overflows seen when writing into fan speed limit attributes.
Also fix crash due to division by zero, seen when certain very
large values (such as 2147483648, or 0x80000000) are written
Fixes: 594fbe713bf60 ("Add support for GMT G762/G763 PWM fan controllers")
Cc: Arnaud Ebalard <arno@natisbad.org>
Reviewed-by: Jean Delvare <jdelvare@suse.de>
commit c0d04e9112ad59d73f23f3b0f6726c5e798dfcbf upstream.
Fix overflows seen when writing voltage and temperature limit attributes.
The value passed to DIV_ROUND_CLOSEST() needs to be clamped, and the
value parameter passed to nct7802_write_fan_min() is an unsigned long.
Also, writing values larger than 2700000 into a fan limit attribute results
in writing 0 into the chip's limit registers. The exact behavior when
writing this value is unspecified. For consistency, report a limit of
1350000 if the chip register reads 0. This may be wrong, and the chip
behavior should be verified with the actual chip, but it is better than
reporting a value of 0 (which, when written, results in writing a value
of 0x1fff into the chip register).
Fixes: 3434f3783580 ("hwmon: Driver for Nuvoton NCT7802Y")
commit e36ce99ee0815d7919a7b589bfb66f3de50b6bc7 upstream.
Module test reports:
temp1_max: Suspected overflow: [160000 vs. 0]
temp1_min: Suspected overflow: [160000 vs. 0]
This is seen because the values passed when writing temperature limits
are unbound.
Fixes: 6099469805c2 ("hwmon: Support for Dallas Semiconductor DS620")
commit 4538bfbf2d9f1fc48c07ac0cc0ee58716fe7fe96 upstream.
Converts the unsigned temperature values from the i2c read
to be sign extended as defined in the datasheet so that
negative temperatures are properly read.
Fixes: 28e6274d8fa67 ("hwmon: (amc6821) Avoid forward declaration")
Signed-off-by: Jared Bents <jared.bents@rockwellcollins.com>
Signed-off-by: Matt Weber <matthew.weber@rockwellcollins.com>
[groeck: Dropped unnecessary continuation line]
commit 13edb767aa609b6efb7c0c2b57fbd72a6ded0eed upstream.
If the driver is built as a module, autoload won't work because the module
alias information is not filled. So user-space can't match the registered
device with the corresponding module.
Export the module alias information using the MODULE_DEVICE_TABLE() macro.
Before this patch:
$ modinfo drivers/hwmon/scpi-hwmon.ko | grep alias
After this patch:
alias: of:N*T*Carm,scpi-sensorsC*
Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com>
Fixes: ea98b29a05e9c ("hwmon: Support sensors exported via ARM SCP interface")
commit 31b239824ece321c09bdb8e61e1d14814eaba38b upstream.
The word "background" contains 10 characters so the third argument of
strncmp() need to be 10 in order to match this prefix correctly.
Signed-off-by: Nicolas Iooss <nicolas.iooss_linux@m4x.org>
Fixes: 855aed1220d2 ("ath10k: add spectral scan feature")
Signed-off-by: Kalle Valo <kvalo@qca.qualcomm.com>
commit 19ec31230eb3084431bc2e565fd085f79f564274 upstream.
Let's call dwc3_ep0_prepare_one_trb() explicitly
because there are occasions where we will need more
than one TRB to handle an EP0 transfer.
A follow-up patch will fix one bug related to
multiple-TRB Data Phases when it comes to
mapping/unmapping requests for DMA.
Reported-by: Janusz Dziedzic <januszx.dziedzic@linux.intel.com>
commit 7931ec86c1b738e4e90e58c6d95e5f720d45ee56 upstream.
For now this is just a cleanup patch, no functional
changes. We will be using the new function to fix a
bug introduced long ago by commit 0416e494ce7d
("usb: dwc3: ep0: correct cache sync issue in case
of ep0_bounced") and further worsened by commit
c0bd5456a470 ("usb: dwc3: ep0: handle non maxpacket
aligned transfers > 512")
commit d62145929992f331fdde924d5963ab49588ccc7d upstream.
commit 0416e494ce7d ("usb: dwc3: ep0: correct cache
sync issue in case of ep0_bounced") introduced a bug
where we would leak DMA resources which would cause
us to starve the system of them resulting in failing
DMA transfers.
Fix the bug by making sure that we always unmap EP0
requests since those are *always* mapped.
Fixes: 0416e494ce7d ("usb: dwc3: ep0: correct cache
Cc: <stable@vger.kernel.org>
Tested-by: Tomasz Medrek <tomaszx.medrek@intel.com>
commit b321a38d2407c7e425c54bc09be909a34e49f740 upstream.
The oversampling ratio is controlled using the oversampling pins,
OS [2:0] with OS2 being the MSB control bit, and OS0 the LSB control
bit.
The gpio connected to the OS2 pin is not being set correctly, only OS0
and OS1 pins are being set. Fix the typo to allow proper control of the
oversampling pins.
Signed-off-by: Eva Rachel Retuya <eraretuya@gmail.com>
Fixes: b9618c0 ("staging: IIO: ADC: New driver for AD7606/AD7606-6/AD7606-4")
Acked-by: Lars-Peter Clausen <lars@metafoo.de>
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
commit 5026c9cb0744a9cd40242743ca91a5d712f468c6 upstream.
Adjust function name in KDoc.
Fixes: d49dc5e76fc9 (mei: bus: use mei_cldev_ prefix for the API functions)
Signed-off-by: Alexander Usyskin <alexander.usyskin@intel.com>
Signed-off-by: Tomas Winkler <tomas.winkler@intel.com>
commit e35d6d7c4e6532a89732cf4bace0e910ee684c88 upstream.
Bind to the interface, but do not register any ports, after having
downloaded the firmware. The device will still disconnect and
re-enumerate, but this way we avoid an error messages from being logged
as part of the process:
io_ti: probe of 1-1.3:1.0 failed with error -5
commit 015105b12183556771e111e93f5266851e7c5582 upstream.
Make sure to drop the references taken by of_parse_phandle() and
bus_find_device() before returning from am335x_get_phy_control().
Note that there is no guarantee that the devres-managed struct
phy_control will be valid for the lifetime of the sibling phy device
regardless of this change.
Fixes: 3bb869c8b3f1 ("usb: phy: Add AM335x PHY driver")
Acked-by: Bin Liu <b-liu@ti.com>
commit 3c3dd1e058cb01e835dcade4b54a6f13ffaeaf7c upstream.
Function klsi_105_open() calls usb_control_msg() (to "enable read") and
checks its return value. When the return value is unexpected, it only
assigns the error code to the return variable retval, but does not
terminate the exception path. This patch fixes the bug by inserting
"goto err_generic_close;" when the call to usb_control_msg() fails.
Fixes: 1da177e4c3f4 ("Linux-2.6.12-rc2")
[johan: rebase on prerequisite fix and amend commit message]
commit 5563bb5743cb09bde0d0f4660a5e5b19c26903bf upstream.
The function bfin_fifo_offset is defined but not used:
drivers/usb/musb/blackfin.c:36:12: warning: ‘bfin_fifo_offset’ defined
static u32 bfin_fifo_offset(u8 epnum)
Adding bfin_fifo_offset to bfin_ops fixes this warning and allows musb
core to call this function instead of default_fifo_offset.
Fixes: cc92f6818f6e ("usb: musb: Populate new IO functions for blackfin")
Signed-off-by: Jérémy Lefaure <jeremy.lefaure@lse.epita.fr>
Signed-off-by: Bin Liu <b-liu@ti.com>
commit 3bc02bce908c7250781376052248f5cd60a4e3d4 upstream.
If CONFIG_PM=n:
drivers/usb/core/hub.c:107: warning: ‘hub_usb3_port_prepare_disable’ declared inline after being called
drivers/usb/core/hub.c:107: warning: previous declaration of ‘hub_usb3_port_prepare_disable’ was here
To fix this, move hub_port_disable() after
hub_usb3_port_prepare_disable(), and adjust forward declarations.
Fixes: 37be66767e3cae4f ("usb: hub: Fix auto-remount of safely removed or ejected USB-3 devices")
commit 8c300fe282fa254ea730c92cb0983e2642dc1fff upstream.
When unloading omap2430, we can get the following splat:
WARNING: CPU: 1 PID: 295 at kernel/irq/manage.c:1478 __free_irq+0xa8/0x2c8
Trying to free already-free IRQ 4
[<c01a8b78>] (free_irq) from [<bf0aea84>]
(musbhs_dma_controller_destroy+0x28/0xb0 [musb_hdrc])
[<bf0aea84>] (musbhs_dma_controller_destroy [musb_hdrc]) from
[<bf09f88c>] (musb_remove+0xf0/0x12c [musb_hdrc])
[<bf09f88c>] (musb_remove [musb_hdrc]) from [<c056a384>]
(platform_drv_remove+0x24/0x3c)
This is because the irq number in use is 260 nowadays, and the dma
controller is using u8 instead of int.
Fixes: 6995eb68aab7 ("USB: musb: enable low level DMA operation for Blackfin")
[b-liu@ti.com: added Fixes tag]
commit 8f8983a5683623b62b339d159573f95a1fce44f3 upstream.
Intel Gemini Lake SoC has the same DWC3 than Broxton. Add
the new ID to the supported Devices.
Signed-off-by: Heikki Krogerus <heikki.krogerus@linux.intel.com>
commit 1c111b6c3844a142e03bcfc2fa17bfbdea08e9dc upstream.
Current abort operation has race.
xhci_handle_command_timeout()
xhci_abort_cmd_ring()
xhci_write_64(CMD_RING_ABORT)
xhci_handshake(5s)
do {
check CMD_RING_RUNNING
udelay(1)
COMP_CMD_ABORT event
COMP_CMD_STOP event
xhci_handle_stopped_cmd_ring()
restart cmd_ring
CMD_RING_RUNNING become 1 again
} while ()
return -ETIMEDOUT
/* can abort random command */
To do abort operation correctly, we have to wait both of COMP_CMD_STOP
event and negation of CMD_RING_RUNNING.
But like above, while timeout handler is waiting negation of
CMD_RING_RUNNING, event handler can restart cmd_ring. So timeout
handler never be notice negation of CMD_RING_RUNNING, and retry of
CMD_RING_ABORT can abort random command (BTW, I guess retry of
CMD_RING_ABORT was workaround of this race).
To fix this race, this moves xhci_handle_stopped_cmd_ring() to
xhci_abort_cmd_ring(). And timeout handler waits COMP_CMD_STOP event.
At this point, timeout handler is owner of cmd_ring, and safely
restart cmd_ring by using xhci_handle_stopped_cmd_ring().
[FWIW, as bonus, this way would be easily extend to add CMD_RING_PAUSE
operation]
[locks edited as patch is rebased on other locking fixes -Mathias]
Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
Signed-off-by: Mathias Nyman <mathias.nyman@linux.intel.com>
commit cb4d5ce588c5ff68e0fdd30370a0e6bc2c0a736b upstream.
This is preparation to fix abort operation race (See "xhci: Fix race
related to abort operation"). To make timeout sleepable, use
delayed_work instead of timer.
[change a newly added pending timer fix to pending work -Mathias]
commit c95a9f83711bf53faeb4ed9bbb63a3f065613dfb upstream.
We normally use the passed in gfp flags for allocations, it's just these
two which were missed.
Fixes: 22d45f01a836 ("usb/xhci: replace pci_*_consistent() with dma_*_coherent()")
Cc: Mathias Nyman <mathias.nyman@intel.com>
Acked-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
commit fde1faf872ed86d88e245191bc15a8e57368cd1c upstream.
A static usb-serial-driver structure that is used to initialise the
interrupt URB was modified during probe depending on the currently
probed device type, something which could break a parallel probe of a
device of a different type.
Fix this up by overriding the default completion callback for MCS7715
devices in attach() instead. We may want to use two usb-serial driver
instances for the two types later.
Fixes: fb088e335d78 ("USB: serial: add support for serial port on the moschip 7715")
commit 75dd211e773afcbc264677b0749d1cf7d937ab2d upstream.
Do not submit the interrupt URB until after the parport has been
successfully registered to avoid another use-after-free in the
completion handler when accessing the freed parport private data in case
of a racing completion.
Fixes: b69578df7e98 ("USB: usbserial: mos7720: add support for parallel port on moschip 7715")
commit 91a1ff4d53c5184d383d0baeeaeab6f9736f2ff3 upstream.
The interrupt URB was submitted on probe but never stopped on probe
errors. This can lead to use-after-free issues in the completion
handler when accessing the freed usb-serial struct:
Unable to handle kernel paging request at virtual address 6b6b6be7
[<bf052e70>] (mos7715_interrupt_callback [mos7720]) from [<c052a894>] (__usb_hcd_giveback_urb+0x80/0x140)
[<c052a894>] (__usb_hcd_giveback_urb) from [<c052a9a4>] (usb_hcd_giveback_urb+0x50/0x138)
[<c052a9a4>] (usb_hcd_giveback_urb) from [<c0550684>] (musb_giveback+0xc8/0x1cc)
commit b05aebc25fdc5aeeac3ee29f0dc9f58dd07c13cc upstream.
Fix NULL-pointer dereference at port open if a device lacks the expected
bulk in and out endpoints.
Unable to handle kernel NULL pointer dereference at virtual address 00000030
[<bf071c20>] (mos7720_open [mos7720]) from [<bf0490e0>] (serial_port_activate+0x68/0x98 [usbserial])
[<bf0490e0>] (serial_port_activate [usbserial]) from [<c0470ca4>] (tty_port_open+0x9c/0xe8)
[<c0470ca4>] (tty_port_open) from [<bf049d98>] (serial_open+0x48/0x6c [usbserial])
[<bf049d98>] (serial_open [usbserial]) from [<c0469178>] (tty_open+0xcc/0x5cc)
Fixes: 0f64478cbc7a ("USB: add USB serial mos7720 driver")
commit 5c75633ef751dd4cd8f443dc35152c1ae563162e upstream.
Fix NULL-pointer dereference in open() should the device lack the
expected endpoints:
PC is at mos7840_open+0x88/0x8dc [mos7840]
Note that we continue to treat the interrupt-in endpoint as optional for
now.
Fixes: 3f5429746d91 ("USB: Moschip 7840 USB-Serial Driver")
commit 21ce57840243c7b70fbc1ebd3dceeb70bb6e9e09 upstream.
Fix NULL-pointer dereference in write() should the device lack the
expected interrupt-out endpoint:
Unable to handle kernel NULL pointer dereference at virtual address 00000054
PC is at kobil_write+0x144/0x2a0 [kobil_sct]
commit 3dca01114dcecb1cf324534cd8d75fd1306a516b upstream.
Fix NULL-pointer dereference when clearing halt at open should the device
lack a bulk-out endpoint.
PC is at cyberjack_open+0x40/0x9c [cyberjack]
commit 5afeef2366db14587b65558bbfd5a067542e07fb upstream.
expected endpoints:
PC is at oti6858_open+0x30/0x1d0 [oti6858]
Note that a missing interrupt-in endpoint would have caused open() to
fail.
Fixes: 49cdee0ed0fc ("USB: oti6858 usb-serial driver (in Nokia CA-42
cable)")
commit 0dd408425eb21ddf26a692b3c8044c9e7d1a7948 upstream.
Fix NULL-pointer dereference when initialising URBs at open should a
non-EPIC device lack a bulk-in or interrupt-in endpoint.
Unable to handle kernel NULL pointer dereference at virtual address 00000028
PC is at edge_open+0x24c/0x3e8 [io_edgeport]
Note that the EPIC-device probe path has the required sanity checks so
this makes those checks partially redundant.
