commit 56ef6718a1d8d77745033c5291e025ce18504159 upstream.
It may happen that secondary CPUs are still alive and resetting
hv_context.tsc_page will cause a consequent crash in read_hv_clock_tsc()
as we don't check for it being not NULL there. It is safe as we're not
freeing this page anyways.
Signed-off-by: Vitaly Kuznetsov <vkuznets@redhat.com>
Signed-off-by: K. Y. Srinivasan <kys@microsoft.com>
Signed-off-by: Sumit Semwal <sumit.semwal@linaro.org>
commit cb7a5724c7e1bfb5766ad1c3beba14cc715991cf upstream.
I'm observing the following hot add requests from the WS2012 host:
hot_add_req: start_pfn = 0x108200 count = 330752
hot_add_req: start_pfn = 0x158e00 count = 193536
hot_add_req: start_pfn = 0x188400 count = 239616
As the host doesn't specify hot add regions we're trying to create
128Mb-aligned region covering the first request, we create the 0x108000 -
0x160000 region and we add 0x108000 - 0x158e00 memory. The second request
passes the pfn_covered() check, we enlarge the region to 0x108000 -
0x190000 and add 0x158e00 - 0x188200 memory. The problem emerges with the
third request as it starts at 0x188400 so there is a 0x200 gap which is
not covered. As the end of our region is 0x190000 now it again passes the
pfn_covered() check were we just adjust the covered_end_pfn and make it
0x188400 instead of 0x188200 which means that we'll try to online
0x188200-0x188400 pages but these pages were never assigned to us and we
crash.
We can't react to such requests by creating new hot add regions as it may
happen that the whole suggested range falls into the previously identified
128Mb-aligned area so we'll end up adding nothing or create intersecting
regions and our current logic doesn't allow that. Instead, create a list of
such 'gaps' and check for them in the page online callback.
commit 7cf3b79ec85ee1a5bbaaf936bb1d050dc652983b upstream.
Windows 2012 (non-R2) does not specify hot add region in hot add requests
and the logic in hot_add_req() is trying to find a 128Mb-aligned region
covering the request. It may also happen that host's requests are not 128Mb
aligned and the created ha_region will start before the first specified
PFN. We can't online these non-present pages but we don't remember the real
start of the region.
This is a regression introduced by the commit 5abbbb75d733 ("Drivers: hv:
hv_balloon: don't lose memory when onlining order is not natural"). While
the idea of keeping the 'moving window' was wrong (as there is no guarantee
that hot add requests come ordered) we should still keep track of
covered_start_pfn. This is not a revert, the logic is different.
commit 9cd9a21ce070be8a918ffd3381468315a7a76ba6 upstream.
In commit 6afaf8a484cb ("UBI: flush wl before clearing update marker") I
managed to trigger and fix a similar bug. Now here is another version of
which I assumed it wouldn't matter back then but it turns out UBI has a
check for it and will error out like this:
|ubi0 warning: validate_vid_hdr: inconsistent used_ebs
|ubi0 error: validate_vid_hdr: inconsistent VID header at PEB 592
All you need to trigger this is? "ubiupdatevol /dev/ubi0_0 file" + a
powercut in the middle of the operation.
ubi_start_update() sets the update-marker and puts all EBs on the erase
list. After that userland can proceed to write new data while the old EB
aren't erased completely. A powercut at this point is usually not that
much of a tragedy. UBI won't give read access to the static volume
because it has the update marker. It will most likely set the corrupted
flag because it misses some EBs.
So we are all good. Unless the size of the image that has been written
differs from the old image in the magnitude of at least one EB. In that
case UBI will find two different values for `used_ebs' and refuse to
attach the image with the error message mentioned above.
So in order not to get in the situation, the patch will ensure that we
wait until everything is removed before it tries to write any data.
The alternative would be to detect such a case and remove all EBs at the
attached time after we processed the volume-table and see the
update-marker set. The patch looks bigger and I doubt it is worth it
since usually the write() will wait from time to time for a new EB since
usually there not that many spare EB that can be used.
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Signed-off-by: Richard Weinberger <richard@nod.at>
commit 9f327845358d3dd0d8a5a7a5436b0aa5c432e757 upstream.
Currently for DDR50 card, it need tuning in default. We meet tuning fail
issue for DDR50 card and some data CRC error when DDR50 sd card works.
This is because the default pad I/O drive strength can't make sure DDR50
card work stable. So increase the pad I/O drive strength for DDR50 card,
and use pins_100mhz.
This fixes DDR50 card support for IMX since DDR50 tuning was enabled from
commit 9faac7b95ea4 ("mmc: sdhci: enable tuning for DDR50")
Tested-and-reported-by: Tim Harvey <tharvey@gateworks.com>
Signed-off-by: Haibo Chen <haibo.chen@nxp.com>
Acked-by: Dong Aisheng <aisheng.dong@nxp.com>
Acked-by: Adrian Hunter <adrian.hunter@intel.com>
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
commit fe8c470ab87d90e4b5115902dd94eced7e3305c3 upstream.
gcc -O2 cannot always prove that the loop in acpi_power_get_inferred_state()
is enterered at least once, so it assumes that cur_state might not get
initialized:
drivers/acpi/power.c: In function 'acpi_power_get_inferred_state':
drivers/acpi/power.c:222:9: error: 'cur_state' may be used uninitialized in this function [-Werror=maybe-uninitialized]
This sets the variable to zero at the start of the loop, to ensure that
there is well-defined behavior even for an empty list. This gets rid of
the warning.
The warning first showed up when the -Os flag got removed in a bug fix
patch in linux-4.11-rc5.
I would suggest merging this addon patch on top of that bug fix to avoid
introducing a new warning in the stable kernels.
Fixes: 61b79e16c68d (ACPI: Fix incompatibility with mcount-based function graph tracing)
commit 704de489e0e3640a2ee2d0daf173e9f7375582ba upstream.
Temporary got a Lifebook E547 into my hands and noticed the touchpad
only works after running:
echo "1" > /sys/devices/platform/i8042/serio2/crc_enabled
Add it to the list of machines that need this workaround.
Signed-off-by: Thorsten Leemhuis <linux@leemhuis.info>
Reviewed-by: Ulrik De Bie <ulrik.debie-os@e2big.org>
commit 8de0d7e951826d7592e0ba1da655b175c4aa0923 upstream.
The current delay between retries is unnecessarily high and is negatively
affecting the time it takes to boot the system.
commit 396e287fa2ff46e83ae016cdcb300c3faa3b02f6 upstream.
vmbus_teardown_gpadl() can result in infinite wait when it is called on 5
second timeout in vmbus_open(). The issue is caused by the fact that gpadl
teardown operation won't ever succeed for an opened channel and the timeout
isn't always enough. As a guest, we can always trust the host to respond to
our request (and there is nothing we can do if it doesn't).
commit 7cc80c98070ccc7940fc28811c92cca0a681015d upstream.
In some cases create_gpadl_header() allocates submessages but we never
free them.
[sumits] Note for stable:
Upstream commit 4d63763296ab7865a98bc29cc7d77145815ef89f:
(Drivers: hv: get rid of redundant messagecount in create_gpadl_header())
changes the list usage to initialize list header in all cases; that patch
isn't added to stable, so the current patch is modified a little bit from
the upstream commit to check if the list is valid or not.
commit b389f173aaa1204d6dc1f299082a162eb0491545 upstream.
When using RS485 in half duplex, RX should be enabled when TX is
finished, and stopped when TX starts.
Before commit 0058f0871efe7b01c6 ("tty/serial: atmel: fix RS485 half
duplex with DMA"), RX was not disabled in atmel_start_tx() if the DMA
was used. So, collisions could happened.
But disabling RX in atmel_start_tx() uncovered another bug:
RX was enabled again in the wrong place (in atmel_tx_dma) instead of
being enabled when TX is finished (in atmel_complete_tx_dma), so the
transmission simply stopped.
This bug was not triggered before commit 0058f0871efe7b01c6
("tty/serial: atmel: fix RS485 half duplex with DMA") because RX was
never disabled before.
Moving atmel_start_rx() in atmel_complete_tx_dma() corrects the problem.
Reported-by: Gil Weber <webergil@gmail.com>
Fixes: 0058f0871efe7b01c6
Tested-by: Gil Weber <webergil@gmail.com>
Signed-off-by: Richard Genoud <richard.genoud@gmail.com>
Acked-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Tested-by: Bryan Evenson <bevenson@melinkcorp.com>
commit 94acf164dc8f1184e8d0737be7125134c2701dbe upstream.
Include calculations to compute the number of segments
that comprise an aggregated large packet.
Signed-off-by: Thomas Falcon <tlfalcon@linux.vnet.ibm.com>
Reviewed-by: Marcelo Ricardo Leitner <marcelo.leitner@gmail.com>
Reviewed-by: Jonathan Maxwell <jmaxwell37@gmail.com>
commit 2d6a0e9de03ee658a9adc3bfb2f0ca55dff1e478 upstream.
Allocating USB buffers on the stack is not portable, and no longer
works on x86_64 (with VMAP_STACK enabled as per default).
Fixes: 1da177e4c3f4 ("Linux-2.6.12-rc2")
Cc: Brad Spengler <spender@grsecurity.net>
commit d41149145f98fe26dcd0bfd1d6cc095e6e041418 upstream.
commit 7926aff5c57b577ab0f43364ff0c59d968f6a414 upstream.
commit 5593523f968bc86d42a035c6df47d5e0979b5ace upstream.
References: https://bugs.debian.org/852556
Reported-by: Lisandro Damián Nicanor Pérez Meyer <lisandro@debian.org>
Tested-by: Lisandro Damián Nicanor Pérez Meyer <lisandro@debian.org>
commit c4baad50297d84bde1a7ad45e50c73adae4a2192 upstream.
put_chars() stuffs the buffer it gets into an sg, but that buffer may be
on the stack. This breaks with CONFIG_VMAP_STACK=y (for me, it
manifested as printks getting turned into NUL bytes).
Signed-off-by: Omar Sandoval <osandov@fb.com>
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
Reviewed-by: Amit Shah <amit.shah@redhat.com>
Cc: Ben Hutchings <ben@decadent.org.uk>
commit 67b0503db9c29b04eadfeede6bebbfe5ddad94ef upstream.
The buffer allocation for the firmware data was changed in
commit 43fab9793c1f ("[media] dvb-usb: don't use stack for firmware load")
but the same applies for the reset value.
Fixes: 43fab9793c1f ("[media] dvb-usb: don't use stack for firmware load")
Signed-off-by: Stefan Brüns <stefan.bruens@rwth-aachen.de>
Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
commit 43fab9793c1f44e665b4f98035a14942edf03ddc upstream.
As reported by Marc Duponcheel <marc@offline.be>, firmware load on
dvb-usb is using the stack, with is not allowed anymore on default
Kernel configurations:
[ 1025.958836] dvb-usb: found a 'WideView WT-220U PenType Receiver (based on ZL353)' in cold state, will try to load a firmware
[ 1025.958853] dvb-usb: downloading firmware from file 'dvb-usb-wt220u-zl0353-01.fw'
[ 1025.958855] dvb-usb: could not stop the USB controller CPU.
[ 1025.958856] dvb-usb: error while transferring firmware (transferred size: -11, block size: 3)
[ 1025.958856] dvb-usb: firmware download failed at 8 with -22
[ 1025.958867] usbcore: registered new interface driver dvb_usb_dtt200u
[ 2.789902] dvb-usb: downloading firmware from file 'dvb-usb-wt220u-zl0353-01.fw'
[ 2.789905] ------------[ cut here ]------------
[ 2.789911] WARNING: CPU: 3 PID: 2196 at drivers/usb/core/hcd.c:1584 usb_hcd_map_urb_for_dma+0x430/0x560 [usbcore]
[ 2.789912] transfer buffer not dma capable
[ 2.789912] Modules linked in: btusb dvb_usb_dtt200u(+) dvb_usb_af9035(+) btrtl btbcm dvb_usb dvb_usb_v2 btintel dvb_core bluetooth rc_core rfkill x86_pkg_temp_thermal intel_powerclamp coretemp crc32_pclmul aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd drm_kms_helper syscopyarea sysfillrect pcspkr i2c_i801 sysimgblt fb_sys_fops drm i2c_smbus i2c_core r8169 lpc_ich mfd_core mii thermal fan rtc_cmos video button acpi_cpufreq processor snd_hda_codec_realtek snd_hda_codec_generic snd_hda_intel snd_hda_codec snd_hwdep snd_hda_core snd_pcm snd_timer snd crc32c_intel ahci libahci libata xhci_pci ehci_pci xhci_hcd ehci_hcd usbcore usb_common dm_mirror dm_region_hash dm_log dm_mod
[ 2.789936] CPU: 3 PID: 2196 Comm: systemd-udevd Not tainted 4.9.0-gentoo #1
[ 2.789937] Hardware name: ASUS All Series/H81I-PLUS, BIOS 0401 07/23/2013
[ 2.789938] ffffc9000339b690 ffffffff812bd397 ffffc9000339b6e0 0000000000000000
[ 2.789939] ffffc9000339b6d0 ffffffff81055c86 000006300339b6a0 ffff880116c0c000
[ 2.789941] 0000000000000000 0000000000000000 0000000000000001 ffff880116c08000
[ 2.789942] Call Trace:
[ 2.789945] [<ffffffff812bd397>] dump_stack+0x4d/0x66
[ 2.789947] [<ffffffff81055c86>] __warn+0xc6/0xe0
[ 2.789948] [<ffffffff81055cea>] warn_slowpath_fmt+0x4a/0x50
[ 2.789952] [<ffffffffa006d460>] usb_hcd_map_urb_for_dma+0x430/0x560 [usbcore]
[ 2.789954] [<ffffffff814ed5a8>] ? io_schedule_timeout+0xd8/0x110
[ 2.789956] [<ffffffffa006e09c>] usb_hcd_submit_urb+0x9c/0x980 [usbcore]
[ 2.789958] [<ffffffff812d0ebf>] ? copy_page_to_iter+0x14f/0x2b0
[ 2.789960] [<ffffffff81126818>] ? pagecache_get_page+0x28/0x240
[ 2.789962] [<ffffffff8118c2a0>] ? touch_atime+0x20/0xa0
[ 2.789964] [<ffffffffa006f7c4>] usb_submit_urb+0x2c4/0x520 [usbcore]
[ 2.789967] [<ffffffffa006feca>] usb_start_wait_urb+0x5a/0xe0 [usbcore]
[ 2.789969] [<ffffffffa007000c>] usb_control_msg+0xbc/0xf0 [usbcore]
[ 2.789970] [<ffffffffa067903d>] usb_cypress_writemem+0x3d/0x40 [dvb_usb]
[ 2.789972] [<ffffffffa06791cf>] usb_cypress_load_firmware+0x4f/0x130 [dvb_usb]
[ 2.789973] [<ffffffff8109dbbe>] ? console_unlock+0x2fe/0x5d0
[ 2.789974] [<ffffffff8109e10c>] ? vprintk_emit+0x27c/0x410
[ 2.789975] [<ffffffff8109e40a>] ? vprintk_default+0x1a/0x20
[ 2.789976] [<ffffffff81124d76>] ? printk+0x43/0x4b
[ 2.789977] [<ffffffffa0679310>] dvb_usb_download_firmware+0x60/0xd0 [dvb_usb]
[ 2.789979] [<ffffffffa0679898>] dvb_usb_device_init+0x3d8/0x610 [dvb_usb]
[ 2.789981] [<ffffffffa069e302>] dtt200u_usb_probe+0x92/0xd0 [dvb_usb_dtt200u]
[ 2.789984] [<ffffffffa007420c>] usb_probe_interface+0xfc/0x270 [usbcore]
[ 2.789985] [<ffffffff8138bf95>] driver_probe_device+0x215/0x2d0
[ 2.789986] [<ffffffff8138c0e6>] __driver_attach+0x96/0xa0
[ 2.789987] [<ffffffff8138c050>] ? driver_probe_device+0x2d0/0x2d0
[ 2.789988] [<ffffffff81389ffb>] bus_for_each_dev+0x5b/0x90
[ 2.789989] [<ffffffff8138b7b9>] driver_attach+0x19/0x20
[ 2.789990] [<ffffffff8138b33c>] bus_add_driver+0x11c/0x220
[ 2.789991] [<ffffffff8138c91b>] driver_register+0x5b/0xd0
[ 2.789994] [<ffffffffa0072f6c>] usb_register_driver+0x7c/0x130 [usbcore]
[ 2.789994] [<ffffffffa06a5000>] ? 0xffffffffa06a5000
[ 2.789996] [<ffffffffa06a501e>] dtt200u_usb_driver_init+0x1e/0x20 [dvb_usb_dtt200u]
[ 2.789997] [<ffffffff81000408>] do_one_initcall+0x38/0x140
[ 2.789998] [<ffffffff8116001c>] ? __vunmap+0x7c/0xc0
[ 2.789999] [<ffffffff81124fb0>] ? do_init_module+0x22/0x1d2
[ 2.790000] [<ffffffff81124fe8>] do_init_module+0x5a/0x1d2
[ 2.790002] [<ffffffff810c96b1>] load_module+0x1e11/0x2580
[ 2.790003] [<ffffffff810c68b0>] ? show_taint+0x30/0x30
[ 2.790004] [<ffffffff81177250>] ? kernel_read_file+0x100/0x190
[ 2.790005] [<ffffffff810c9ffa>] SyS_finit_module+0xba/0xc0
[ 2.790007] [<ffffffff814f13e0>] entry_SYSCALL_64_fastpath+0x13/0x94
[ 2.790008] ---[ end trace c78a74e78baec6fc ]---
So, allocate the structure dynamically.
[bwh: Backported to 4.9: adjust context]
commit a4866aa812518ed1a37d8ea0c881dc946409de94 upstream.
Under CONFIG_STRICT_DEVMEM, reading System RAM through /dev/mem is
disallowed. However, on x86, the first 1MB was always allowed for BIOS
and similar things, regardless of it actually being System RAM. It was
possible for heap to end up getting allocated in low 1MB RAM, and then
read by things like x86info or dd, which would trip hardened usercopy:
usercopy: kernel memory exposure attempt detected from ffff880000090000 (dma-kmalloc-256) (4096 bytes)
This changes the x86 exception for the low 1MB by reading back zeros for
System RAM areas instead of blindly allowing them. More work is needed to
extend this to mmap, but currently mmap doesn't go through usercopy, so
hardened usercopy won't Oops the kernel.
Reported-by: Tommi Rantala <tommi.t.rantala@nokia.com>
Tested-by: Tommi Rantala <tommi.t.rantala@nokia.com>
commit 5fa4086987506b2ab8c92f8f99f2295db9918856 upstream.
Accessing the registers of the RTC block on Tegra requires the module
clock to be enabled. This only works because the RTC module clock will
be enabled by default during early boot. However, because the clock is
unused, the CCF will disable it at late_init time. This causes the RTC
to become unusable afterwards. This can easily be reproduced by trying
to use the RTC:
$ hwclock --rtc /dev/rtc1
This will hang the system. I ran into this by following up on a report
by Martin Michlmayr that reboot wasn't working on Tegra210 systems. It
turns out that the rtc-tegra driver's ->shutdown() implementation will
hang the CPU, because of the disabled clock, before the system can be
rebooted.
What confused me for a while is that the same driver is used on prior
Tegra generations where the hang can not be observed. However, as Peter
De Schrijver pointed out, this is because on 32-bit Tegra chips the RTC
clock is enabled by the tegra20_timer.c clocksource driver, which uses
the RTC to provide a persistent clock. This code is never enabled on
64-bit Tegra because the persistent clock infrastructure does not exist
on 64-bit ARM.
The proper fix for this is to add proper clock handling to the RTC
driver in order to ensure that the clock is enabled when the driver
requires it. All device trees contain the clock already, therefore
no additional changes are required.
Reported-by: Martin Michlmayr <tbm@cyrius.com>
Acked-By Peter De Schrijver <pdeschrijver@nvidia.com>
Signed-off-by: Thierry Reding <treding@nvidia.com>
notify event
commit 98d610c3739ac354319a6590b915f4624d9151e6 upstream.
The accelerometer event relies on the ACERWMID_EVENT_GUID notify.
So, this patch changes the codes to setup accelerometer input device
when detected ACERWMID_EVENT_GUID. It avoids that the accel input
device created on every Acer machines.
In addition, patch adds a clearly parsing logic of accelerometer hid
to acer_wmi_get_handle_cb callback function. It is positive matching
the "SENR" name with "BST0001" device to avoid non-supported hardware.
Reported-by: Bjørn Mork <bjorn@mork.no>
Cc: Darren Hart <dvhart@infradead.org>
Signed-off-by: Lee, Chun-Yi <jlee@suse.com>
[andy: slightly massage commit message]
commit 005145378c9ad7575a01b6ce1ba118fb427f583a upstream.
I ran into a stack frame size warning because of the on-stack copy of
the USB device structure:
drivers/media/usb/dvb-usb-v2/dvb_usb_core.c: In function 'dvb_usbv2_disconnect':
drivers/media/usb/dvb-usb-v2/dvb_usb_core.c:1029:1: error: the frame size of 1104 bytes is larger than 1024 bytes [-Werror=frame-larger-than=]
Copying a device structure like this is wrong for a number of other reasons
too aside from the possible stack overflow. One of them is that the
dev_info() call will print the name of the device later, but AFAICT
we have only copied a pointer to the name earlier and the actual name
has been freed by the time it gets printed.
This removes the on-stack copy of the device and instead copies the
device name using kstrdup(). I'm ignoring the possible failure here
as both printk() and kfree() are able to deal with NULL pointers.
commit 40bea976c72b9ee60f8d097852deb53ccbeaffbe upstream.
relay_open() may return NULL, check the return value to avoid the crash.
BUG: unable to handle kernel NULL pointer dereference at 0000000000000040
IP: [<ffffffffa01a95c5>] ath_cmn_process_fft+0xd5/0x700 [ath9k_common]
PGD 41cf28067 PUD 41be92067 PMD 0
Oops: 0000 [#1] SMP
CPU: 0 PID: 0 Comm: swapper/0 Not tainted 4.8.6+ #35
Hardware name: Hewlett-Packard h8-1080t/2A86, BIOS 6.15 07/04/2011
task: ffffffff81e0c4c0 task.stack: ffffffff81e00000
RIP: 0010:[<ffffffffa01a95c5>] [<ffffffffa01a95c5>] ath_cmn_process_fft+0xd5/0x700 [ath9k_common]
RSP: 0018:ffff88041f203ca0 EFLAGS: 00010293
RAX: 0000000000000000 RBX: 000000000000059f RCX: 0000000000000000
RDX: 0000000000000000 RSI: 0000000000000040 RDI: ffffffff81f0ca98
RBP: ffff88041f203dc8 R08: ffffffffffffffff R09: 00000000000000ff
R10: 0000000000000000 R11: 0000000000000000 R12: 0000000000000000
R13: ffffffff81f0ca98 R14: 0000000000000000 R15: 0000000000000000
FS: 0000000000000000(0000) GS:ffff88041f200000(0000) knlGS:0000000000000000
CR2: 0000000000000040 CR3: 000000041b6ec000 CR4: 00000000000006f0
Stack:
0000000000000363 00000000000003f3 00000000000003f3 00000000000001f9
000000000000049a 0000000001252c04 ffff88041f203e44 ffff880417b4bfd0
0000000000000008 ffff88041785b9c0 0000000000000002 ffff88041613dc60
Call Trace:
<IRQ>
[<ffffffffa01b6441>] ath9k_tasklet+0x1b1/0x220 [ath9k]
[<ffffffff8105d8dd>] tasklet_action+0x4d/0xf0
[<ffffffff8105dde2>] __do_softirq+0x92/0x2a0
Reported-by: Devin Tuchsen <devin.tuchsen@gmail.com>
Tested-by: Devin Tuchsen <devin.tuchsen@gmail.com>
Signed-off-by: Miaoqing Pan <miaoqing@codeaurora.org>
Signed-off-by: Kalle Valo <kvalo@qca.qualcomm.com>
commit d72e9a7a93e4f8e9e52491921d99e0c8aa89eb4e upstream.
The copy_page is optimized memcpy for page-alinged address. If it is
used with non-page aligned address, it can corrupt memory which means
system corruption. With zram, it can happen with
1. 64K architecture
2. partial IO
3. slub debug
Partial IO need to allocate a page and zram allocates it via kmalloc.
With slub debug, kmalloc(PAGE_SIZE) doesn't return page-size aligned
address. And finally, copy_page(mem, cmem) corrupts memory.
So, this patch changes it to memcpy.
Actuaully, we don't need to change zram_bvec_write part because zsmalloc
returns page-aligned address in case of PAGE_SIZE class but it's not
good to rely on the internal of zsmalloc.
Note:
When this patch is merged to stable, clear_page should be fixed, too.
Unfortunately, recent zram removes it by "same page merge" feature so
it's hard to backport this patch to -stable tree.
I will handle it when I receive the mail from stable tree maintainer to
merge this patch to backport.
Fixes: 42e99bd ("zram: optimize memory operations with clear_page()/copy_page()")
Link: http://lkml.kernel.org/r/1492042622-12074-2-git-send-email-minchan@kernel.org
Signed-off-by: Minchan Kim <minchan@kernel.org>
Cc: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
commit f2cfa58b136e4b06a9b9db7af5ef62fbb5992f62 upstream.
Without a bool string present, using "# CONFIG_DEVPORT is not set" in
defconfig files would not actually unset devport. This esnured that
/dev/port was always on, but there are reasons a user may wish to
disable it (smaller kernel, attack surface reduction) if it's not being
used. Adding a message here in order to make this user visible.
Signed-off-by: Max Bires <jbires@google.com>
commit 309124e2648d668a0c23539c5078815660a4a850 upstream.
According to full-history-linux commit d3794f4fa7c3edc3 ("[PATCH] M68k
update (part 25)"), port operations are allowed on m68k if CONFIG_ISA is
defined.
However, commit 153dcc54df826d2f ("[PATCH] mem driver: fix conditional
on isa i/o support") accidentally changed an "||" into an "&&",
disabling it completely on m68k. This logic was retained when
introducing the DEVPORT symbol in commit 4f911d64e04a44c4 ("Make
/dev/port conditional on config symbol").
Drop the bogus dependency on !M68K to fix this.
Fixes: 153dcc54df826d2f ("[PATCH] mem driver: fix conditional on isa i/o support")
Tested-by: Al Stone <ahs3@redhat.com>
commit 75eb5e1e7b4edbc8e8f930de59004d21cb46961f upstream.
The raw_spinlock in the IMX GPCV2 interupt chip is not initialized before
usage. That results in a lockdep splat:
INFO: trying to register non-static key.
the code is fine but needs lockdep annotation.
turning off the locking correctness validator.
Add the missing raw_spin_lock_init() to the setup code.
Fixes: e324c4dc4a59 ("irqchip/imx-gpcv2: IMX GPCv2 driver for wakeup sources")
Signed-off-by: Tyler Baker <tyler.baker@linaro.org>
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
Cc: jason@lakedaemon.net
Cc: marc.zyngier@arm.com
Cc: shawnguo@kernel.org
Cc: andrew.smirnov@gmail.com
Link: http://lkml.kernel.org/r/20170413222731.5917-1-tyler.baker@linaro.org
commit 0beb2012a1722633515c8aaa263c73449636c893 upstream.
Holding the reconfig_mutex over a potential userspace fault sets up a
lockdep dependency chain between filesystem-DAX and the libnvdimm ioctl
path. Move the user access outside of the lock.
[ INFO: possible circular locking dependency detected ]
4.11.0-rc3+ #13 Tainted: G W O
fallocate/16656 is trying to acquire lock:
(&nvdimm_bus->reconfig_mutex){+.+.+.}, at: [<ffffffffa00080b1>] nvdimm_bus_lock+0x21/0x30 [libnvdimm]
but task is already holding lock:
(jbd2_handle){++++..}, at: [<ffffffff813b4944>] start_this_handle+0x104/0x460
which lock already depends on the new lock.
the existing dependency chain (in reverse order) is:
-> #2 (jbd2_handle){++++..}:
lock_acquire+0xbd/0x200
start_this_handle+0x16a/0x460
jbd2__journal_start+0xe9/0x2d0
__ext4_journal_start_sb+0x89/0x1c0
ext4_dirty_inode+0x32/0x70
__mark_inode_dirty+0x235/0x670
generic_update_time+0x87/0xd0
touch_atime+0xa9/0xd0
ext4_file_mmap+0x90/0xb0
mmap_region+0x370/0x5b0
do_mmap+0x415/0x4f0
vm_mmap_pgoff+0xd7/0x120
SyS_mmap_pgoff+0x1c5/0x290
SyS_mmap+0x22/0x30
entry_SYSCALL_64_fastpath+0x1f/0xc2
-> #1 (&mm->mmap_sem){++++++}:
__might_fault+0x70/0xa0
__nd_ioctl+0x683/0x720 [libnvdimm]
nvdimm_ioctl+0x8b/0xe0 [libnvdimm]
do_vfs_ioctl+0xa8/0x740
SyS_ioctl+0x79/0x90
do_syscall_64+0x6c/0x200
return_from_SYSCALL_64+0x0/0x7a
-> #0 (&nvdimm_bus->reconfig_mutex){+.+.+.}:
__lock_acquire+0x16b6/0x1730
__mutex_lock+0x88/0x9b0
mutex_lock_nested+0x1b/0x20
nvdimm_forget_poison+0x25/0x50 [libnvdimm]
nvdimm_clear_poison+0x106/0x140 [libnvdimm]
pmem_do_bvec+0x1c2/0x2b0 [nd_pmem]
pmem_make_request+0xf9/0x270 [nd_pmem]
generic_make_request+0x118/0x3b0
submit_bio+0x75/0x150
Fixes: 62232e45f4a2 ("libnvdimm: control (ioctl) messages for nvdimm_bus and nvdimm devices")
Cc: Dave Jiang <dave.jiang@intel.com>
Reported-by: Vishal Verma <vishal.l.verma@intel.com>
commit 9121b15b5628b38b4695282dc18c553440e0f79b upstream.
Connecting to the backend isn't working reliably in xen-fbfront: in
case XenbusStateInitWait of the backend has been missed the backend
transition to XenbusStateConnected will trigger the connected state
only without doing the actions required when the backend has
connected.
Signed-off-by: Juergen Gross <jgross@suse.com>
Reviewed-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
commit 7c856152cb92f8eee2df29ef325a1b1f43161aff upstream.
We previously made sure that the reported disk capacity was less than
0xffffffff blocks when the kernel was not compiled with large sector_t
support (CONFIG_LBDAF). However, this check assumed that the capacity
was reported in units of 512 bytes.
Add a sanity check function to ensure that we only enable disks if the
entire reported capacity can be expressed in terms of sector_t.
Reported-by: Steve Magnani <steve.magnani@digidescorp.com>
Cc: Bart Van Assche <Bart.VanAssche@sandisk.com>
Reviewed-by: Bart Van Assche <Bart.VanAssche@sandisk.com>
commit 6780414519f91c2a84da9baa963a940ac916f803 upstream.
If device reports a small max_xfer_blocks and a zero opt_xfer_blocks, we
end up using BLK_DEF_MAX_SECTORS, which is wrong and r/w of that size
may get error.
[mkp: tweaked to avoid setting rw_max twice and added typecast]
Fixes: ca369d51b3e ("block/sd: Fix device-imposed transfer length limits")
Signed-off-by: Fam Zheng <famz@redhat.com>
commit a00a7862513089f17209b732f230922f1942e0b9 upstream.
Kefeng Wang discovered that old versions of the QEMU CD driver would
return mangled mode data causing us to walk off the end of the buffer in
an attempt to parse it. Sanity check the returned mode sense data.
Reported-by: Kefeng Wang <wangkefeng.wang@huawei.com>
Tested-by: Kefeng Wang <wangkefeng.wang@huawei.com>
commit 1c99de981f30b3e7868b8d20ce5479fa1c0fea46 upstream.
Once upon a time back in 2009, a work-around was added to support
the GlobalSAN iSCSI initiator v3.3 for MacOSX, which during login
did not propose nor respond to MaxBurstLength, FirstBurstLength,
DefaultTime2Wait and DefaultTime2Retain keys.
The work-around in iscsi_check_proposer_for_optional_reply()
allowed the missing keys to be proposed, but did not require
waiting for a response before moving to full feature phase
operation. This allowed GlobalSAN v3.3 to work out-of-the
box, and for many years we didn't run into login interopt
issues with any other initiators..
Until recently, when Martin tried a QLogic 57840S iSCSI Offload
HBA on Windows 2016 which completed login, but subsequently
failed with:
Got unknown iSCSI OpCode: 0x43
The issue was QLogic MSFT side did not propose DefaultTime2Wait +
DefaultTime2Retain, so LIO proposes them itself, and immediately
transitions to full feature phase because of the GlobalSAN hack.
However, the QLogic MSFT side still attempts to respond to
DefaultTime2Retain + DefaultTime2Wait, even though LIO has set
ISCSI_FLAG_LOGIN_NEXT_STAGE3 + ISCSI_FLAG_LOGIN_TRANSIT
in last login response.
So while the QLogic MSFT side should have been proposing these
two keys to start, it was doing the correct thing per RFC-3720
attempting to respond to proposed keys before transitioning to
full feature phase.
All that said, recent versions of GlobalSAN iSCSI (v5.3.0.541)
does correctly propose the four keys during login, making the
original work-around moot.
So in order to allow QLogic MSFT to run unmodified as-is, go
ahead and drop this long standing work-around.
Reported-by: Martin Svec <martin.svec@zoner.cz>
Cc: Martin Svec <martin.svec@zoner.cz>
Cc: Himanshu Madhani <Himanshu.Madhani@cavium.com>
Cc: Arun Easi <arun.easi@cavium.com>
commit efb2ea770bb3b0f40007530bc8b0c22f36e1c5eb upstream.
This patch fixes a iscsi-target specific TMR reference leak
during session shutdown, that could occur when a TMR was
quiesced before the hand-off back to iscsi-target code
via transport_cmd_check_stop_to_fabric().
The reference leak happens because iscsit_free_cmd() was
incorrectly skipping the final target_put_sess_cmd() for
TMRs when transport_generic_free_cmd() returned zero because
the se_cmd->cmd_kref did not reach zero, due to the missing
se_cmd assignment in original code.
The result was iscsi_cmd and it's associated se_cmd memory
would be freed once se_sess->sess_cmd_map where released,
but the associated se_tmr_req was leaked and remained part
of se_device->dev_tmr_list.
This bug would manfiest itself as kernel paging request
OOPsen in core_tmr_lun_reset(), when a left-over se_tmr_req
attempted to dereference it's se_cmd pointer that had
already been released during normal session shutdown.
To address this bug, go ahead and treat ISCSI_OP_SCSI_CMD
and ISCSI_OP_SCSI_TMFUNC the same when there is an extra
se_cmd->cmd_kref to drop in iscsit_free_cmd(), and use
op_scsi to signal __iscsit_free_cmd() when the former
needs to clear any further iscsi related I/O state.
Reported-by: Rob Millner <rlm@daterainc.com>
Cc: Rob Millner <rlm@daterainc.com>
Reported-by: Chu Yuan Lin <cyl@datera.io>
Cc: Chu Yuan Lin <cyl@datera.io>
Tested-by: Chu Yuan Lin <cyl@datera.io>
commit b03b99a329a14b7302f37c3ea6da3848db41c8c5 upstream.
While reviewing the -stable patch for commit 86ef58a4e35e "nfit,
libnvdimm: fix interleave set cookie calculation" Ben noted:
"This is returning an int, thus it's effectively doing a 32-bit
comparison and not the 64-bit comparison you say is needed."
Update the compare operation to be immune to this integer demotion problem.
Cc: Nicholas Moulin <nicholas.w.moulin@linux.intel.com>
Fixes: 86ef58a4e35e ("nfit, libnvdimm: fix interleave set cookie calculation")
Reported-by: Ben Hutchings <ben@decadent.org.uk>
commit 5376366886251e2f8f248704adb620a4bc4c0937 upstream.
Signed-off-by: Cameron Gutman <aicommander@gmail.com>
commit f94773b9f5ecd1df7c88c2e921924dd41d2020cc upstream.
The NV4A (aka NV44A) is an oddity in the family. It only comes in AGP
and PCI varieties, rather than a core PCIE chip with a bridge for
AGP/PCI as necessary. As a result, it appears that the MMU is also
non-functional. For AGP cards, the vast majority of the NV4A lineup,
this worked out since we force AGP cards to use the nv04 mmu. However
for PCI variants, this did not work.
Switching to the NV04 MMU makes it work like a charm. Thanks to mwk for
the suggestion. This should be a no-op for NV4A AGP boards, as they were
using it already.
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=70388
Signed-off-by: Ilia Mirkin <imirkin@alum.mit.edu>
Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
commit 83bce9c2baa51e439480a713119a73d3c8b61083 upstream.
Fixes: 590801c1a3 ("drm/nouveau/mpeg: remove dependence on namedb/engctx lookup")
commit 7b5967389f5a8dfb9d32843830f5e2717e20995d upstream.
This patch is based on an earlier one submitted
by Jon Maxwell with the following commit message:
"We recently encountered a bug where a few customers using ibmveth on the
same LPAR hit an issue where a TCP session hung when large receive was
enabled. Closer analysis revealed that the session was stuck because the
one side was advertising a zero window repeatedly.
We narrowed this down to the fact the ibmveth driver did not set gso_size
which is translated by TCP into the MSS later up the stack. The MSS is
used to calculate the TCP window size and as that was abnormally large,
it was calculating a zero window, even although the sockets receive buffer
was completely empty."
We rely on the Virtual I/O Server partition in a pseries
environment to provide the MSS through the TCP header checksum
field. The stipulation is that users should not disable checksum
offloading if rx packet aggregation is enabled through VIOS.
Some firmware offerings provide the MSS in the RX buffer.
This is signalled by a bit in the RX queue descriptor.
Reviewed-by: Brian King <brking@linux.vnet.ibm.com>
Reviewed-by: Pradeep Satyanarayana <pradeeps@linux.vnet.ibm.com>
Reviewed-by: David Dai <zdai@us.ibm.com>
transitions
commit 7c3945bc2073554bb2ecf983e073dee686679c53 upstream.
Save the qp context flags byte containing the flag disabling vlan stripping
in the RESET to INIT qp transition, rather than in the INIT to RTR
transition. Per the firmware spec, the flags in this byte are active
in the RESET to INIT transition.
As a result of saving the flags in the incorrect qp transition, when
switching dynamically from VGT to VST and back to VGT, the vlan
remained stripped (as is required for VST) and did not return to
not-stripped (as is required for VGT).
Fixes: f0f829bf42cd ("net/mlx4_core: Add immediate activate for VGT->VST->VGT")
Signed-off-by: Jack Morgenstein <jackm@dev.mellanox.co.il>
Signed-off-by: Tariq Toukan <tariqt@mellanox.com>
commit 291c566a28910614ce42d0ffe82196eddd6346f4 upstream.
In function mlx4_cq_completion() and mlx4_cq_event(), the
radix_tree_lookup requires a rcu_read_lock.
This is mandatory: if another core frees the CQ, it could
run the radix_tree_node_rcu_free() call_rcu() callback while
its being used by the radix tree lookup function.
Additionally, in function mlx4_cq_event(), since we are adding
the rcu lock around the radix-tree lookup, we no longer need to take
the spinlock. Also, the synchronize_irq() call for the async event
eliminates the need for incrementing the cq reference count in
mlx4_cq_event().
Other changes:
1. In function mlx4_cq_free(), replace spin_lock_irq with spin_lock:
we no longer take this spinlock in the interrupt context.
The spinlock here, therefore, simply protects against different
threads simultaneously invoking mlx4_cq_free() for different cq's.
2. In function mlx4_cq_free(), we move the radix tree delete to before
the synchronize_irq() calls. This guarantees that we will not
access this cq during any subsequent interrupts, and therefore can
safely free the CQ after the synchronize_irq calls. The rcu_read_lock
in the interrupt handlers only needs to protect against corrupting the
radix tree; the interrupt handlers may access the cq outside the
rcu_read_lock due to the synchronize_irq calls which protect against
premature freeing of the cq.
3. In function mlx4_cq_event(), we change the mlx_warn message to mlx4_dbg.
4. We leave the cq reference count mechanism in place, because it is
still needed for the cq completion tasklet mechanism.
Fixes: 6d90aa5cf17b ("net/mlx4_core: Make sure there are no pending async events when freeing CQ")
Fixes: 225c7b1feef1 ("IB/mlx4: Add a driver Mellanox ConnectX InfiniBand adapters")
Signed-off-by: Matan Barak <matanb@mellanox.com>
commit 6496bbf0ec481966ef9ffe5b6660d8d1b55c60cc upstream.
Single send WQE in RX buffer should be stamped with software
ownership in order to prevent the flow of QP in error in FW
once UPDATE_QP is called.
Fixes: 9f519f68cfff ('mlx4_en: Not using Shared Receive Queues')
Signed-off-by: Eugenia Emantayev <eugenia@mellanox.com>
commit 22547c4cc4fe20698a6a85a55b8788859134b8e4 upstream.
On a system with a defective USB device connected to an USB hub,
an endless sequence of port connect events was observed. The sequence
of events as observed is as follows:
- Port reports connected event (port status=USB_PORT_STAT_CONNECTION).
- Event handler debounces port and resets it by calling hub_port_reset().
- hub_port_reset() calls hub_port_wait_reset() to wait for the reset
to complete.
- The reset completes, but USB_PORT_STAT_CONNECTION is not immediately
set in the port status register.
- hub_port_wait_reset() returns -ENOTCONN.
- Port initialization sequence is aborted.
- A few milliseconds later, the port again reports a connected event,
and the sequence repeats.
This continues either forever or, randomly, stops if the connection
is already re-established when the port status is read. It results in
a high rate of udev events. This in turn destabilizes userspace since
the above sequence holds the device mutex pretty much continuously
and prevents userspace from actually reading the device status.
To prevent the problem from happening, let's wait for the connection
to be re-established after a port reset. If the device was actually
disconnected, the code will still return an error, but it will do so
only after the long reset timeout.
Cc: Douglas Anderson <dianders@chromium.org>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
commit 40c98cb57cdbc377456116ad4582c89e329721b0 upstream.
RNG instantiation was previously fixed by
commit 62743a4145bb9 ("crypto: caam - fix RNG init descriptor ret. code checking")
while deinstantiation was not addressed.
Since the descriptors used are similar, in the sense that they both end
with a JUMP HALT command, checking for errors should be similar too,
i.e. status code 7000_0000h should be considered successful.
Fixes: 1005bccd7a4a6 ("crypto: caam - enable instantiation of all RNG4 state handles")
Signed-off-by: Horia Geantă <horia.geanta@nxp.com>
commit bd5d21310133921021d78995ad6346f908483124 upstream.
After parsing TRX we should skip to the first block placed behind it.
Our code was working only with TRX with length not aligned to the
blocksize. In other cases (length aligned) it was missing the block
places right after TRX.
This fixes calculation and simplifies the comment.
Signed-off-by: Rafał Miłecki <rafal@milecki.pl>
Signed-off-by: Brian Norris <computersforpeace@gmail.com>
Signed-off-by: Amit Pundir <amit.pundir@linaro.org>
commit de288e36fe33f7e06fa272bc8e2f85aa386d99aa upstream.
In the case of bounced ep0 requests, we must delay DMA operation until
after ->complete() otherwise we might overwrite contents of req->buf.
This caused problems with RNDIS gadget.
Signed-off-by: Janusz Dziedzic <januszx.dziedzic@intel.com>
Signed-off-by: Felipe Balbi <felipe.balbi@linux.intel.com>
commit 8f68d591d4765b2e1ce9d916ac7bc5583285c4ad upstream.
On Baytrail, we manually calculate busyness over the evaluation interval
to avoid issues with miscaluations with RC6 enabled. However, it turns
out that the DOWN_EI interrupt generator is completely bust - it
operates in two modes, continuous or never. Neither of which are
conducive to good behaviour. Stop unmask the DOWN_EI interrupt and just
compute everything from the UP_EI which does seem to correspond to the
desired interval.
v2: Fixup gen6_rps_pm_mask() as well
v3: Inline vlv_c0_above() to combine the now identical elapsed
calculation for up/down and simplify the threshold testing
Fixes: 43cf3bf084ba ("drm/i915: Improved w/a for rps on Baytrail")
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
Cc: Mika Kuoppala <mika.kuoppala@linux.intel.com>
Link: http://patchwork.freedesktop.org/patch/msgid/20170309211232.28878-1-chris@chris-wilson.co.uk
Reviewed-by: Mika Kuoppala <mika.kuoppala@linux.intel.com>
Link: http://patchwork.freedesktop.org/patch/msgid/20170313170617.31564-1-chris@chris-wilson.co.uk
(cherry picked from commit e0e8c7cb6eb68e9256de2d8cbeb481d3701c05ac)
Signed-off-by: Jani Nikula <jani.nikula@intel.com>
commit 34dc8993eef63681b062871413a9484008a2a78f upstream.
Certain Baytrails, namely the 4 cpu core variants, have been
plaqued by spurious system hangs, mostly occurring with light loads.
Multiple bisects by various people point to a commit which changes the
reclocking strategy for Baytrail to follow its bigger brethen:
commit 8fb55197e64d ("drm/i915: Agressive downclocking on Baytrail")
There is also a review comment attached to this commit from Deepak S
on avoiding punit access on Cherryview and thus it was excluded on
common reclocking path. By taking the same approach and omitting
the punit access by not tweaking the thresholds when the hardware
has been asked to move into different frequency, considerable gains
in stability have been observed.
With J1900 box, light render/video load would end up in system hang
in usually less than 12 hours. With this patch applied, the cumulative
uptime has now been 34 days without issues. To provoke system hang,
light loads on both render and bsd engines in parallel have been used:
glxgears >/dev/null 2>/dev/null &
mpv --vo=vaapi --hwdec=vaapi --loop=inf vid.mp4
So far, author has not witnessed system hang with above load
and this patch applied. Reports from the tenacious people at
kernel bugzilla are also promising.
Considering that the punit access frequency with this patch is
considerably less, there is a possibility that this will push
the, still unknown, root cause past the triggering point on most loads.
But as we now can reliably reproduce the hang independently,
we can reduce the pain that users are having and use a
static thresholds until a root cause is found.
v3: don't break debugfs and simplification (Chris Wilson)
References: https://bugzilla.kernel.org/show_bug.cgi?id=109051
Cc: Chris Wilson <chris@chris-wilson.co.uk>
Cc: Ville Syrjälä <ville.syrjala@linux.intel.com>
Cc: Len Brown <len.brown@intel.com>
Cc: Daniel Vetter <daniel.vetter@ffwll.ch>
Cc: Jani Nikula <jani.nikula@intel.com>
Cc: fritsch@xbmc.org
Cc: miku@iki.fi
Cc: Ezequiel Garcia <ezequiel@vanguardiasur.com.ar>
CC: Michal Feix <michal@feix.cz>
Cc: Hans de Goede <hdegoede@redhat.com>
Cc: Deepak S <deepak.s@linux.intel.com>
Cc: Jarkko Nikula <jarkko.nikula@linux.intel.com>
Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Acked-by: Chris Wilson <chris@chris-wilson.co.uk>
Signed-off-by: Mika Kuoppala <mika.kuoppala@intel.com>
Link: http://patchwork.freedesktop.org/patch/msgid/1487166779-26945-1-git-send-email-mika.kuoppala@intel.com
(cherry picked from commit 6067a27d1f0184596d51decbac1c1fdc4acb012f)
commit 4bdc9029685ac03be50b320b29691766d2326c2b upstream.
The gyroscope chip might need to be reset to be used.
Without the chip being reset, the driver stopped at the first
regmap_read (to get the CHIP_ID) and failed to probe.
The datasheet of the gyroscope says that a minimum wait of 30ms after
the reset has to be done.
This patch has been checked on a BMX055 and the datasheet of the BMG160
and the BMI055 give the same reset register and bits.
Signed-off-by: Quentin Schulz <quentin.schulz@free-electrons.com>
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
