corner case"
This reverts commit 563931094bf096da2ce6f2cc40387f9e726b3342.
That patch causes wrong blitting and will block GA release
Date: Apr 04, 2014
Signed-off-by: Loren Huang <b02279@freescale.com>
Acked-by: Shawn Guo
During hdmi hotplug test, there's a possibility that X-server unblanks
the frame buffer while HDMI-audio just gets the signal to start playback.
Then audio would get an unblanked state right before the playback and
bypassed the DMA enabling code. So this issue is caused by the race
between unblank and set_cable_state().
This patch sets the hdmi cable state a bit earilier so as to let audio
play first. If unblank happens later, the hdmi core and hdmi audio would
be robust enough to handle that case as long as it's not racing with the
other parts.
Acked-by: Sandor Yu <R01008@freescale.com>
Signed-off-by: Nicolin Chen <Guangyu.Chen@freescale.com>
eLCDIF did not support stride buffer, check the xres_virtual
in function mxfb_check_var, return false
if the value larger than xres.
Signed-off-by: Sandor Yu <R01008@freescale.com>
CAAM depends on the clock used by WEIM interface. This patch supplied by
Haung Shijie corrects the issue by adding the clock as a resource for
the CAAM driver.
Signed-off-by: Dan Douglass <dan.douglass@freescale.com>
This issue happens when multiple thread is trying to idle GPU at the
same time, root cause is some wrong logic related with powerMutex which
cause cpu still access GPU AHB register after GPU is suspend(clock off),
that cause the bus lockup and make the whole system hang.
Signed-off-by: Richard Liu <r66033@freescale.com>
Acked-by: Jason Liu
(cherry picked from commit d48e52700c4177e94695cdbdb480cb38a88a5ddc)
Vivante patch name:
cl17466.17776.rls.lockup.2dhang(clear.blit)
-Updated the outstanding request limit to 12.
-Refined the 2D chip feature check.
-Refine the 2D cache flush operation
(avoid FE and PE access memory through the same port).
-Enable cache flush for filterblt.
-Dynamic enabling SPLIT_RECT by checking chip feature(disable for us)
-Use brush stretch blt for clear operation.
Date: Mar 26, 2014
Acked-by: Shawn Guo
2G above address will cause system reboot and fixed in original patch,
error check code is added based on the original logic.
Signed-off-by: Xianzhong <b07117@freescale.com>
Acked-by: Jason Liu
(cherry picked from commit 7d85c98bf781eb047c2000bd82ea7559c24a2446)
(cherry picked from commit 04911cf737a4a40e7914ad94fd58bf92dcfa4a92)
Set the correct permissions of the fsl_disp_property sysfs entry.
Acked-by: Liu Ying <Ying.Liu@freescale.com>
Signed-off-by: Julien Olivain <julien.olivain@freescale.com>
(cherry picked from commit 9db2d982c90b6edb3dfebe03a68f50f381bb99bb)
The optimal resize ratio should be used if the downscaler is not needed. This
will fix a vertical line in the center for some scaling ratios.
Signed-off-by: Oliver Brown <oliver.brown@freescale.com>
For HSIC operation at imx6sl, it needs host quirk too.
Signed-off-by: Peter Chen <peter.chen@freescale.com>
real meaning
This flag is not only used for mxs phy's bug, but also
for speical routine for other imx host operations.
ci_usb_phy_init"
This reverts commit 6cf1375d32049b7d852131d232ec97e76535a2e0
in order to avoid system hang access portsc without PHY clock.
See: http://marc.info/?l=linux-arm-kernel&m=139350618732108&w=2
The mipi csi2 code is ugly present in the capture pipeline setup/disable
routions with '#ifdef CONFIG_MXC_MIPI_CSI2/#endif' protected. Whenever
it finds mipi_csi2_info is not gotten correctly, it will return error to
callers. This breaks the normally routines in which mipi csi2 is not used
and mipi csi2 driver is disabled in its devicetree node(but with the
Kconfig CONFIG_MXC_MIPI_CSI2 defined). A real example is the capture
feature on the MX6 Sabreauto platforms. We have only parallel CSI input
on it and the mipi csi2 driver is disabled in its devicetree node but with
the Kconfig CONFIG_MXC_MIPI_CSI2 defined. So, a reasonable choice at present
is not to return error if mipi_csi2_info cannot be gotten, though we could
eventually re-organize the capture code for a better total solution in the
future.
Signed-off-by: Liu Ying <Ying.Liu@freescale.com>
(cherry picked from commit 8133b7fd26e8b068fa8ab9cd62eae090c76080be)
xserver will read default video mode in command line by sysfs node
/sys/class/graphics/fb0/mode, but the sysfs node is not initialized
when system bootup without hdmi cable plugin
or frame buffer register in blank state.
Fixed:
- Remove unused previous_mode
- Add default_mode, initialize in disp_init function.
- Initialize fbi->mode in disp_init function and hdmi_setup function.
commit f8e1a3bb62eecf93a31a51c4dbe08a0214fa1d57 introduced an
annoying kernel log by changing a pure debug info to error level.
This patch reverts that change.
drivers/media/video/mxc/capture/mxc_v4l2_capture.c
(cherry picked from commit b635fadfdff01d0f6112956ac903d80c62fd648b)
commit f8e1a3bb62eecf93a31a51c4dbe08a0214fa1d57 added a hard
coding for csi_parma.mclk setting to 27MHz. The comment added by
that commit is totally wrong by telling that csi_param.mclk
would be a kind of 'pixel clock' set in 'csi_data_dest' register.
This patch removes the unnecessary mclk setting for csi_param.mclk
variable, since it is only valid for CSI test mode.
(cherry picked from commit bb5afd554c50b639f1e1b94481b24f35ae8c4dc5)
This patch removes test mode clock setting in function
ipu_csi_init_interface(), since the setting is only
necessary for function _ipu_csi_set_test_generator().
This unnecessary setting is added wrongly by commit
f8e1a3bb62eecf93a31a51c4dbe08a0214fa1d57.
(cherry picked from commit 0f395a7aecfd2845df384c7a5a0045c86c3a2e20)
We reversed CCIR code1/2 setting before, which may brings
captured frame quality issue(jaggy edge can be seen). This
patch revert that change.
(cherry picked from commit a4c2228f5428af02b9be87114d096340f9b58083)
The following error was reported.
root@imx6qdlsolo:~# /unit_tests/mxc_v4l2_capture.out -d /dev/video1 1.yuv
in_width = 176, in_height = 144
out_width = 176, out_height = 144
top = 0, left = 0
mipi csi2 can not receive sensor clk!
sensor chip is ov5640_mipi_camera
sensor supported frame size:
640x480
320x240
720x480
720x576
1280x720
1920x1080
2592x1944
176x144
1024x768
sensor frame format: UYVY
mxc_v4l2_s_param: vidioc_int_s_parm returned an error -1
VIDIOC_S_PARM failed
get format failed
Root cause analysis:
It only happens when HDMI is not used/enabled. There is a clock named
video_27m which are needed by HDMI (as isfrclk's parent) and MIPI-CSI2 (as
cfg_clk's parent). MIPI-CSI2 driver is lack of enabling this clock before
start to work and only happen to work when HDMI driver enables this clock.
Signed-off-by: Robby Cai <R63905@freescale.com>
(cherry picked from commit a6bbc7d56f261ab84e04071487264c6a519df758)
After change the resolution, the blank state will be changed, the audio will
be triggered to start. which didn't care about the audio is running or not
before changing the resolution.
Add hdmi_abort_state for this special case.
Signed-off-by: Shengjiu Wang <b02247@freescale.com>
LDO2p5 cannot be disabled in low power idle mode when the USB driver
enables VBUS wakeup. To identify when LDO2p5 can be disabled add a dummy
regulator that the USB driver will enable when VBUS wakeup is required.
Signed-off-by: Ranjani Vaidyanathan <Ranjani.Vaidyanathan@freescale.com>
When dma zone memory used up, gckOS_AllocateNonPagedMemory() will try to
free non paged memory cache and allocate again. Such operation will cause
twice memory mutex request and cause gpu driver hang.
The solution is free the memory mutex at first before trying to free non
paged memory cache.
Date: Feb 27, 2014
Acked-by: Shawn Guo
(cherry picked from commit 79ed8edd23f990f6c1429154c2ee773c83bfd72e)
Add hwrng support for i.MX6SL.
1. Add RNG driver. This driver originated as fsl-rngc.c. It
has been modified to support device tree. The name has been
changed since it supports both b and c variants of RNG.
2. Added clock and compatible info to the device tree data.
3. Added the entry in the options in the Kconfig for hwrng.
When split mode deinterlacing is the ipu_calc_stripes_sizes() was failing due
to an unnecessary test. Added logic to use the maximal_stripe_width only if
the flag parameter has the bit 0 clear for not equal stripe sizes.
For i.MX6 ARD board, the board not support read EDID from TV,
so HDMI driver will create a default support mode list when system
bootup.
Because yocto xserver can not get video mode information from
framebuffer now, and xserver will set default video mode XGA
to framebuffer, but XGA mode is not support by hdmi.
Remove XGA and SXGA from default support list.
HDMI driver will find a nearest match video mode in support list.
It is VGA mode. HDMI support VGA mode well.
Issue is fixed.
This patch adds Hannstar CABC driver support. The CABC
function turns the backlight density of a display panel
automatically according to the content shown on the panel.
It is controlled(enabled/disabled) by a GPIO.
(cherry picked from commit 2dddbc55bd8ae9461067e1a9d047b2994510e6d8)
- add one imx pcie ep simple skeleton driver to demo
the msi trigger capability in imx6 pcie rc/ep validation
system
- in order to avoid the modification of common codes,
force the msi address to be 0x01ff8000
Test howto:
- Enable CONFIG_PCI_MSI=y, when rebuild the rc/ep images
- EP side(console command and kernel message):
root@sabresd_6dq:/ # memtool 0x1ff8000=0
Writing 32-bit value 0x0 to address 0x01FF8000
- RC side(console command and kernel message):
root@sabresd_6dq:/ # cat /proc/interrupts | grep MSI
384: 1 0 0 0 PCI-MSI
384: 2 0 0 0 PCI-MSI
Signed-off-by: Richard Zhu <r65037@freescale.com>
- setup one new outbound memory region at rc side, used
to let imx6 pcie rc can access the memory of imx6 pcie ep
in imx6 pcie rc ep validation system.
- set the default address of the ddr memory to be 0x4000_0000
NOTE:
- default address 0x4000_0000 of ep side would be
accessed in this demo.
Test howto:
step1:
EP side:
1.1:
echo 0x40000000 > /sys/devices/soc0/soc.1/1ffc000.pcie/ep_bar0_addr
1.2:
memtool -32 0x40000000 4
E
Reading 0x4 count starting at address 0x40000000
0x40000000: 6FE9E9F6 7583FBB9 39EAEFEA FBDCFD78
step2:
RC side:
memtool -32 0x01000000=58D454DA
memtool -32 0x01000004=7332095B
step3:
EP side:
E
0x40000000: 58D454DA 7332095B 39EAEFEA FBDCFD78
full-speed idle
If the high-speed device does not enter full-speed idle after
wakeup on disconnect logic has effected, there will be an
unexpected disconnect wakeup interrupt due to the bus is still SE0.
- add sata phy cr(offset:0x7f3f) reset in sata resume to
workaround imx6q sata kinds of suspend resume link
issues.
- add sata phy cr reset during imx6q sata initialization,
to initialize the sata phy to be an initialized state.
- add about 100us delay between mpll_clk enable and cr-rst,
make sure that the mpll_clk is stable.
- add about 100us delay between cr-rst and waiting for rx_pll
stable too, make sure that the cr-rst is finished.
- change the tx level setting from 1.025v to be the default
value 1.104v
- make sure the sata phy internal pll ref clk enable is
cleared before it is set, otherwise, the sata phy link
maybe failed when some devices are used.
When device boot into console, frame buffer failed to work after
suspend/resume.
That is caused by LCDIF IP lost all registers configuration
in suspend mode, and console didn't reconfiguration fb after resume.
Same issue didn't found with Yocto UI.
Reinitialize frame buffer driver after resume to fix the issue.
Kernel will dump when run deinterlace stress test.
It is caused by vditmpbuf being reallocated by another thread
when one thread accesses it.
Issue is fixed by putting these code in mutex.
Kernel dump log:
[Playing ][Vol=01][00:00:10/00:00:30][fps:32]Unable to handle kernel
paging request at virtual address 607d6085
pgd = 80004000
[607d6085] *pgd=00000000
Internal error: Oops: 5 [#1] SMP ARM
Modules linked in:
CPU: 0 PID: 50 Comm: ipu2_task Not tainted 3.10.17-02308-g3700819 #28
task: ac1dc700 ti: ac1ba000 task.ti: ac1ba000
PC is at __kmalloc+0x40/0x114
LR is at __kmalloc+0x14/0x114
pc : [<800bbd40>] lr : [<800bbd14>] psr: 200f0013
sp : ac1bbbc8 ip : 008cc000 fp : 00001e40
r10: ac772e00 r9 : 0057b255 r8 : 000000d0
r7 : 00000790 r6 : ac773800 r5 : 607d6085 r4 : ac001b00
r3 : 00000000 r2 : 814f92a0 r1 : 000000d0 r0 : 000398c9
Flags: nzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kernel
Control: 10c53c7d Table: 3c4c004a DAC: 00000015
Process ipu2_task (pid: 50, stack limit = 0xac1ba238)
Stack: (0xac1bbbc8 to 0xac1bc000)
__va function only can handle frame buffer from low memory.
Use page_address function to replace it, that can handle
frame buffer from both lower and high memory.
Use ioremap_nocache function to handle Frame buffer
from GPU reserve memory pool.
Correct vdi data save buffer size, save both luma and chroma part for
interleaved YUV format.
For non-interleaved and partial-interleaved YUV format,
save luma part data, chroma part is not covered in the patch.
gpio-leds driver common framework didn't take care of this case if use CONFIG_OF
, add property "retain-state-suspended" in dts and check it while gpio-leds
device created.
Signed-off-by: Robin Gong <b38343@freescale.com>
(cherry picked from commit 118c650de0bb518d377b0e6427b38fc101fe31aa)
We should set watchdog timer to be disabled in low power mode,
as there is no service running in background, otherwise, system
will reset unexpected.
Signed-off-by: Anson Huang <b20788@freescale.com>
The usdhc of i.MX6Q/DL can work well under low power mode without
request high bus freq. So we do not need request bus freq for i.MX6Q/DL.
It can save power for i.MX6D/DL due to it saves a lot busfreq switch
cost as well as the CPU time runing on high bus freq after switch
during low power mode.
A new flag ESDHC_FLAG_BUSFREQ is added to indicated this requirement.
Currently only i.MX6SL is using it.
Signed-off-by: Dong Aisheng <b29396@freescale.com>
(cherry picked from commit 075196777d00bf9507d68a76bf25f6c7e776102f)
-If _FlushMMU() return error, commitMutex and powerSemaphore will be
locked forever.
-Correct file attribute for gc_hal_base.h
Date: Jan 15, 2014
Acked-by: Shawn Guo
(cherry picked from commit 0279fa8984dac78c289d264450c76e1156b3ac79)
-Most vg memory must requires reserved memory, when reserved memory is
used up by 3d appliction. vg hardware can't be constructed successfully,
which cause whole context creation failure(including 3d context).
-Allow allocating vg memory from small block reserved memory can help such
multi context cases.
Date: Jan 15, 2014
Acked-by: Shawn Guo
(cherry picked from commit 5d7c8c1c695b79f7372de16504292a1241390a8b)
The regmap only needs to reallocate if the hw_read on the CAP register shows
lpm is used. Therefore the if() statement check the change.
Signed-off-by: Chris Ruehl <chris.ruehl@gtsys.com.hk>
(cherry picked from commit 57fadc36d11a1263b446ef6f5d474d529274faa8)
The ci_hdrc_imx's probe needs usbmisc_imx to be loadded beforehand,
so it is better we load usbmisc_imx first.
(cherry picked from commit 4ee606c17718706a2bf0f68c70124a343341b4f1)
Commit 40ed51a4b (usb: chipidea: host: add vbus regulator
control) introduced a smatch complaint because regulator_disable() is called
without checking whether ci->platdata->reg_vbus is not NULL.
Fix this by adding the check.
This patch is needed for 3.12 stable
Cc: stable <stable@vger.kernel.org>
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
(cherry picked from commit ae93fad5728e08f7cde89f628be2703ad249930d)
Add guard macro to driver/usb/chipidea/ci_hdrc_imx.h
Signed-off-by: Rahul Bedarkar <rahulbedarkar89@gmail.com>
(cherry picked from commit d27c16a1270c339e62ccc5816f3346d29f6b6c0d)
We have met a bug that the high bandwidth ISO-TX transfer has failed
at the last packet if it is less than 1024, the TD status shows it
is "Transaction Error".
The root cause of this problem is: the mult value at qh is not correct
for current TD's transfer length. We use TD list to queue un-transfer
TDs, and change mult for new adding TDs. If new adding TDs transfer length
less than 1024, but the queued un-transfer TDs transfer length is larger
than 1024, the transfer error will occur, and vice versa.
Usually, this problem occurs at the last packet, and the first packet for
new frame.
We fixed this problem by setting Mult at QH as the largest value (3), and
set MultO (Multiplier Override) at TD according to every transfer length.
It can cover both hardware version less than 2.3 (the real mult is MultO
if it is not 0) and 2.3+ (the real mult is min(qh.mult, td.multo)).
Since the MultO bits are only existed at TX TD, we keep the ISO-RX behavior
unchanged.
For stable tree: 3.11+.
Cc: Michael Grzeschik <m.grzeschik@pengutronix.de>
Reported-by: Matthieu Vanin <b47495@freescale.com>
Tested-by: Matthieu Vanin <b47495@freescale.com>
(cherry picked from commit 1c91f7e338e24fe86e5dba384337f19e49348430)
hw_phymode_configure configures the PORTSC registers and allow the
following phy_inits to operate on the right parameters. This fix a problem
where the UPLI (ISP1504) could not be detected, because the Viewport was not
available and read the viewport return 0's only.
(cherry picked from commit fda8a80b7e944ec29f4438d6e6f159f691ae41a6)
* init the sts flag to 0 (missed)
* fix write the real bit not sts value
* Set PORTCS_STS and DEVLC_STS only if sts = 1
[Peter Chen: This one and the next patch fix the problem occurred imx27
and imx31, and imx27 and imx31 usb support are enabled until 3.14, so
these two patches isn't needed for -stable]
(cherry picked from commit 4cf40dc3d21cd9a482d969d1468fd265ec9921dd)
Do not need to enable the controller card cd interrupt wakeup
if using GPIO as card detect since it's meaningless.
Enable wakeup for SDIO IRQ when the host is able to keep power
during suspend.
IMX boards can keep power for cards during suspend.
User can enable it from device tree.
Except SDHCI_QUIRK_BROKEN_CARD_DETECTION and MMC_CAP_NONREMOVABLE,
we also do not need to handle controller native card detect interrupt
for gpio as card detect case.
If we wrong enabled the card detect interrupt for gpio case,
it will cause a lot of unexpected card detect interrupts during data transfer
which should not happen.
There are two possible reasons to cause AXI bus error
1.Allocate Tile status buffer from virtual memory. It seems gc2000
and gc880 doesn't support tile status buffer from virtual memory.
2.Stream buffer using very beginning gpu mmu address. In this condition,
a faked non gpu mmu address maybe generated and fill into gpu which cause
AXI bus error.
[DATE]09-01-2014
Acked-by: Shawn Guo
