path: root/drivers
2005-08-23Merge head 'upstream-fixes' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/libata-dev
2005-08-23[PATCH] usbnet oops fixlepton
There's a "return the wrong SKB" error in the GL620A cable minidriver (for "usbnet") which can oops. This would not appear when talking Linux-to-Linux, only Linux-to-Windows (for recent Linuxes). Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-23[PATCH] s390 __CHECKER__ ifdefsAl Viro
remove the bogus games with explicit ifdefs on __CHECKER__ Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-23[PATCH] Kconfig fix (non-modular SCSI drivers)Al Viro
non-modular scsi drivers depend on built-in scsi Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-23[PATCH] typo fix in qdio.cAl Viro
dumb typo: u32 volatile * mistyped as u32 * volatile Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-23[PATCH] emac netpoll fixAl Viro
netpoll is void(struct net_device *), not int(struct net_device *) Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-23[PATCH] m32r_sio gcc4 fixesAl Viro
extern declaration followed by static in drivers/serial/m32r_sio.c Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-23[PATCH] missing include in pcmcia_resource.cAl Viro
missing include of asm/irq.h Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-23[PATCH] Kconfig fix (sparc32 drivers/char dependencies)Al Viro
since sparc32 Kconfig includes drivers/char/Kconfig (instead of duplicating its parts) we need several new dependencies there to exclude the stuff broken on sparc32 and not excluded by existing dependencies. Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-23[PATCH] Kconfig fix (emac dependencient)Al Viro
emac doesn't build modular; ibm_emac_debug doesn't build at all (missing headers). Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-23[PATCH] Kconfig fix (VGA console on arm/versatile)Al Viro
VGA console doesn't exist (or build) on arm/versatile; dependency fixed. Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-23[PATCH] Kconfig fix (amba on arm/versatile)Al Viro
AMBA_PL010 is broken on arm/versatile; marked as such Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-23[PATCH] Kconfig fix (acornscsi)Al Viro
acornscsi had been broken for a long time; marked as such Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-23[PATCH] Kconfig fix (M32R_PLDSIO dependecies)Al Viro
M32R_PLDSIO depends on subarchitecture providing PLD_ESIO0CR and friends. Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-23[PATCH] Kconfig fix (parport_pc on m32r)Al Viro
parport_pc shouldn't be picked on m32r (no asm/parport.h, for starters) Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-23[PATCH] Kconfig fix (airo_cs on m32r)Al Viro
airo_cs is broken on m32r; marked as such. [Proper fix would involve separating PCI-dependent parts and making sure they don't get in the way _and_ arranging for asm/scatterlist.h getting picked on m32r] Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-23[PATCH] Kconfig fix (tms380tr and ISA_DMA_API)Al Viro
ISA parts of tms380tr are using ISA DMA helpers and should depend on ISA_DMA_API. Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-23[PATCH] Kconfig fix (arv)Al Viro
arv uses constants provided only by include/asm-m32r/m32700ut/m32700ut_lan.h It won't build for any subarchitecture other than M32700UT; marked as such. Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-23[PATCH] Kconfig fix (infiniband and PCI)Al Viro
infiniband uses PCI helpers all over the place (including the core parts) and won't build without PCI. Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-23[PATCH] Kconfig fix (PMAC_BACKLIGHT on ppc64)Al Viro
PMAC_BACKLIGHT is broken on ppc64; marked as such Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-23[PATCH] Kconfig fix (HISAX_FRITZPCI on ppc64)Al Viro
HISAX_FRITZPCI is broken on ppc64; marked as such Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-23[PATCH] Kconfig fix (m32r genrtc)Al Viro
genrtc is not for m32r; marked as such. Probably ought to put that into arch/* - list of "don't build it on <platform>" is getting too long. Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-23[PATCH] Kconfig fix (epca on 64bit)Al Viro
epca is broken on 64bit; marked as such Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-23[PATCH] zd1201 kmalloc size fixAlexey Dobriyan
Noticed by Coverity checker. (akpm: I stole this from Greg's tree and used the (IMO) tidier sizeof(*p) construct). Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-23[PATCH] md: make sure resync gets started when array starts.NeilBrown
We weren't actually waking up the md thread after setting MD_RECOVERY_NEEDED when assembling an array, so it is possible to lose a race and not actually start resync. So add a call to md_wakeup_thread, and while we are at it, remove all the "if (mddev->thread)" guards as md_wake_thread does its own checking. Signed-off-by: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-23libata: release prep (bump versions, etc.)Jeff Garzik
- bump versions where necessary - remove two duplicated+outdated doc comments - add MODULE_VERSION() to AHCI driver
2005-08-19[TG3]: Update driver version and reldate.David S. Miller
2005-08-19[TG3]: Fix SerDes detectionMichael Chan
A problem was reported by Grant Grundler on an HP rx8620 using IOX Core LAN partno(A7109-6) 5701 copper NIC. The tg3 driver mistakenly detects this NIC as having a SerDes PHY and link does not come up as a result. The problem was caused by an incorrectly programmed eeprom that set the NIC_SRAM_DATA_CFG_PHY_TYPE_FIBER bit in the NIC_SRAM_DATA_CFG location. This patch will override the NIC_SRAM_DATA_CFG_PHY_TYPE_FIBER bit if a valid PHY ID is read from the MII registers on older 570x chips where the MII interface is not used on SerDes chips. On newer chips such as the 5780 that use MII for both copper and SerDes, SerDes detection must rely on the eeprom. This patch will make the SerDes detection identical to versions 3.25 and older. Signed-off-by: Michael Chan <mchan@broadcom.com> Acked-by: Grant Grundler <iod00d@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-18Merge master.kernel.org:/pub/scm/linux/kernel/git/bart/ide-2.6Linus Torvalds
2005-08-18Merge head 'upstream-fixes' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6
2005-08-18[NET]: Fix comment in loopback driver.Ralf Baechle
Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-18[PATCH] DM9000 - incorrect ioctl() handlingBen Dooks
The DM9000 driver is responding to ioctl() calls it should not be. This can cause problems with the wireless tools incorrectly indentifying the device as wireless capable, and crashing under certain operations. This patch also moves the version printk() to the init call, so that you only get it once for multiple devices, and to show it is loaded if there are no defined dm9000s Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-08-18[PATCH] DM9000 - spinlock fixesBen Dooks
Fix DM9000 driver usage of spinlocks, which mainly came to light when running a kernel with spinlock debugging. These come down to: 1) Un-initialised spin lock 2) Several cases of using spin_xxx(lock) and not spin_xxx(&lock) 3) move the locking around the phy reg for read/write to only keep the lock when actually reading or writing to the phy. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-08-18[PATCH] 8139cp - redetect link after suspendPierre Ossman
After suspend the driver needs to retest link status in case the cable has been inserted or removed during the suspend. Signed-off-by: Pierre Ossman <drzeus@drzeus.cx> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-08-18[PATCH] IOC3 fixesRalf Baechle
- Using the right register clearly improves chances of getting the MII code and thus the driver working at all. - On startup check the media type before setting up duplex or we might spend the first 1.2s with a wrong duplex setting. - Get rid of whitespace lines. Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-08-18[PATCH] serverworks: add support for new southbridge IDENarendra Sankar
BCM5785 (HT1000) is a Opteron Southbridge from Serverworks/Broadcom that incorporates a single channel ATA100 IDE controller that is functionally identical to the Serverworks CSB6 IDE controller. This patch adds support for the new PCI device ID and also the support for this controller. Signed-off-by: Narendra Sankar <nsankar@broadcom.com> Acked-by: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@elka.pw.edu.pl>
2005-08-18[PATCH] ide: add support for Netcell Revolution to pci-ide generic driverMatt Gillette
Adds support for Netcell Revolution to pci-ide generic driver by including it in the list of devices matched. Includes the Revolution in the list of simplex devices forced into DMA mode. Signed-off-by: Matt Gillette <matt.gillette@netcell.com> Cc: Bartlomiej Zolnierkiewicz <B.Zolnierkiewicz@elka.pw.edu.pl> Cc: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@elka.pw.edu.pl>
2005-08-18[PATCH] ide: fix PCI_DEVIEC_ID_APPLE_UNI_N_ATA spellingGrant Coady
Signed-off-by: Grant Coady <gcoady@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@elka.pw.edu.pl>
2005-08-18[PATCH] ide: fix the BLK_DEV_IDEDMA_PCI dependency for drivers/ide/ppc/pmac.cJuha-Matti Tapio
drivers/ide/ppc/pmac.c uses symbols ide_build_sglist, __ide_dma_off_quietly, __ide_dma_on and __ide_dma_timeout when CONFIG_BLK_DEV_IDEDMA_PMAC is defined. The declarations for these symbols (in ide.h) depend on CONFIG_BLK_DEV_IDEDMA_PCI. There is a missing dependency for this in drivers/ide/Kconfig which causes drivers/ide/ppc/pmac.c to fail to build if CONFIG_BLK_DEV_IDEDMA_PMAC is selected but CONFIG_BLK_DEV_IDEDMA_PCI is not. Signed-off-by: Juha-Matti Tapio <jmtapio@verkkotelakka.net> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@elka.pw.edu.pl>
2005-08-18[PATCH] ide-floppy: fix IDEFLOPPY_TICKS_DELAYBartlomiej Zolnierkiewicz
* IDEFLOPPY_TICKS_DELAY assumed HZ == 100, fix it * increase the delay to 50ms (to match comment in the code) Thanks to Manfred Scherer <manfred.scherer.mhm@t-online.de> for reporting the problem and testing the patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@elka.pw.edu.pl>
2005-08-18[PATCH] disable debug info in radeonfb old driverMichael Iatrou
This driver spams the user. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-18[PATCH] md: make sure mddev->bitmap_offset gets cleared between array ↵NeilBrown
instantiations. ... otherwise we might try to load a bitmap from an array which hasn't one. The bug is that if you create an array with an internal bitmap, shut it down, and then create an array with the same md device, the md drive will assume it should have a bitmap too. As the array can be created with a different md device, it is mostly an inconvenience. I'm pretty sure there is no risk of data corruption. Signed-off-by: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-18[PATCH] broken error path in drivers/pnp/card.cJaroslav Kysela
The error path in pnp_request_card_device() is broken (one variable is left initialized and the semaphore is not unlocked). This fixes it (and has been tested). Signed-off-by: Jaroslav Kysela <perex@suse.cz> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-17[PATCH] Fix manual binding infinite loopGreg KH
Fix for manual binding of drivers to devices. Problem is if you pass in a valid device id, but the driver refuses to bind. Infinite loop as write() tries to resubmit the data it just sent. Thanks to Michal Ostrowski <mostrows@watson.ibm.com> for pointing the problem out. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-17Merge head 'release' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/aegl/linux-2.6
2005-08-16[PATCH] USB: usbmon: Copyrights and a typoPete Zaitcev
Add copyright statements and fix a typo. Signed-off-by: Pete Zaitcev <zaitcev@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-16[PATCH] USB: fix usb wacom tablet driver bugPing Cheng
This patch fixes bug 4905 and a Cintiq 21UX bug. Signed-off-by: Ping Cheng <pingc@wacom.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-16[PATCH] PCI Hotplug: new contact infoKristen Accardi
Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-16[PATCH] PCI: fix quirk-6700-fix.patchAndrew Morton
drivers/built-in.o(.text+0x32c3): In function `quirk_pcie_pxh': /usr/src/25/drivers/pci/quirks.c:1312: undefined reference to `disable_msi_mode' Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-16[PATCH] PCI: 6700/6702PXH quirkKristen Accardi
On the 6700/6702 PXH part, a MSI may get corrupted if an ACPI hotplug driver and SHPC driver in MSI mode are used together. This patch will prevent MSI from being enabled for the SHPC as part of an early pci quirk, as well as on any pci device which sets the no_msi bit. Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
