commit 75646e758a0ecbed5024454507d5be5b9ea9dcbf upstream.
Some machines (eg. Lenovo Z480) ECs are not stable during boot up
and causes battery driver fails to be loaded due to failure of getting
battery information from EC sometimes. After several retries, the
operation will work. This patch is to retry to get battery information 5
times if the first try fails.
[ backport to 3.14.5: removed second parameter in acpi_battery_update(),
introduced by the commit 9e50bc14a7f58b5d8a55973b2d69355852ae2dae (ACPI /
battery: Accelerate battery resume callback)]
[naszar <naszar@ya.ru>: backport to 3.14.5]
Link: https://bugzilla.kernel.org/show_bug.cgi?id=75581
Reported-and-tested-by: naszar <naszar@ya.ru>
Cc: All applicable <stable@vger.kernel.org>
Signed-off-by: Lan Tianyu <tianyu.lan@intel.com>
commit 0986c1a55ca64b44ee126a2f719a6e9f28cbe0ed upstream.
When we set the valid bit on invalid GART entries they are
loaded into the TLB when an adjacent entry is loaded. This
poisons the TLB with invalid entries which are sometimes
not correctly removed on TLB flush.
For stable inclusion the patch probably needs to be modified a bit.
Signed-off-by: Christian König <christian.koenig@amd.com>
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
commit 1035a9e3e9c76b64a860a774f5b867d28d34acc2 upstream.
Writing to fanX_div does not clear the cache. As a result, reading
from fanX_div may return the old value for up to two seconds
after writing a new value.
This patch ensures the fan_div cache is updated in set_fan_div().
Reported-by: Guenter Roeck <linux@roeck-us.net>
Signed-off-by: Axel Lin <axel.lin@ingics.com>
commit df86754b746e9a0ff6f863f690b1c01d408e3cdc upstream.
temp2_input should not be writable, fix it.
commit 5a7fbe7e9ea0b1b9d7ffdba64db1faa3a259164c upstream.
This patch adds PID 0x0003 to the VID 0x128d (Testo). At least the
Testo 435-4 uses this, likely other gear as well.
Signed-off-by: Bert Vermeulen <bert@biot.com>
Cc: Johan Hovold <johan@kernel.org>
commit b9326057a3d8447f5d2e74a7b521ccf21add2ec0 upstream.
Corsair USB Dongles are shipped with Corsair AXi series PSUs.
These are cp210x serial usb devices, so make driver detect these.
I have a program, that can get information from these PSUs.
Tested with 2 different dongles shipped with Corsair AX860i and
AX1200i units.
Signed-off-by: Andras Kovacs <andras@sth.sze.hu>
Signed-off-by: Johan Hovold <johan@kernel.org>
commit 3d28bd840b2d3981cd28caf5fe1df38f1344dd60 upstream.
Add ID of the Telewell 4G v2 hardware to option driver to get legacy
serial interface working
Signed-off-by: Bernd Wachter <bernd.wachter@jolla.com>
commit 771d09b3c4c45d4d534a83a68e6331b97fd82e15 upstream.
On a HP Pavilion dm4 laptop the BIOS sets minimum backlight on boot,
completely dimming the screen. Ignore this initial value for this
machine.
Signed-off-by: Gustavo Maciel Dias Vieira <gustavo@sagui.org>
[wyj: Backported to 3.4: adjust context]
Signed-off-by: Yijing Wang <wangyijing@huawei.com>
commit 4f29ef050848245f7c180b95ccf67dfcd76b1fd8 upstream.
This patch adds two new products and modifies
the device id table to include them. In addition,
product of 0xbccd - BCM_USB_PRODUCT_ID_SM250 is
removed because Beceem, ZTE, Sprint use this id
for block devices.
Reported-by: Muhammad Minhazul Haque <mdminhazulhaque@gmail.com>
Signed-off-by: Kevin McKinney <klmckinney1@gmail.com>
[bwh: Backported to 3.2: adjust context]
Cc: Yijing Wang <wangyijing@huawei.com>
commit e66fc1fba248738d32f3b64508f9ef1176d9e767 upstream.
This patch create and initalizes a new device
id of 0x172 as reported by Rinat Camalov
<richman1000000d@gmail.com>. In addition, a
comment is added to the potential invalid
existing device id.
Reported-by: Rinat Camalov <richman1000000d@gmail.com>
commit b5e2f339865fb443107e5b10603e53bbc92dc054 upstream.
We need to check the length parameter before doing the memcpy(). I've
actually changed it to strlcpy() as well so that it's NUL terminated.
You need CAP_NET_ADMIN to trigger these so it's not the end of the
world.
Reported-by: Nico Golde <nico@ngolde.de>
Reported-by: Fabian Yamaguchi <fabs@goesec.de>
commit 4b18f08be01a7b3c7b6df497137b6e3cb28adaa3 upstream.
`do_cmd_ioctl()` is called with the comedi device's mutex locked to
process the `COMEDI_CMD` ioctl to set up comedi's asynchronous command
handling on a comedi subdevice. `comedi_read()` and `comedi_write()`
are the `read` and `write` handlers for the comedi device, but do not
lock the mutex (for performance reasons, as some things can hold the
mutex for quite a long time).
There is a race condition if `comedi_read()` or `comedi_write()` is
running at the same time and for the same file object and comedi
subdevice as `do_cmd_ioctl()`. `do_cmd_ioctl()` sets the subdevice's
`busy` pointer to the file object way before it sets the `SRF_RUNNING` flag
in the subdevice's `runflags` member. `comedi_read() and
`comedi_write()` check the subdevice's `busy` pointer is pointing to the
current file object, then if the `SRF_RUNNING` flag is not set, will call
`do_become_nonbusy()` to shut down the asyncronous command. Bad things
can happen if the asynchronous command is being shutdown and set up at
the same time.
To prevent the race, don't set the `busy` pointer until
after the `SRF_RUNNING` flag has been set. Also, make sure the mutex is
held in `comedi_read()` and `comedi_write()` while calling
`do_become_nonbusy()` in order to avoid moving the race condition to a
point within that function.
Change some error handling `goto cleanup` statements in `do_cmd_ioctl()`
to simple `return -ERRFOO` statements as a result of changing when the
`busy` pointer is set.
Signed-off-by: Ian Abbott <abbotti@mev.co.uk>
commit e6391a182865efc896cb2a8d79e07b7ac2f45b48 upstream.
The element of `das08_boards[]` for the 'das08jr-16-ao' board has the
`ai_encoding` member set to `das08_encode12`. It should be set to
`das08_encode16` same as the 'das08jr/16' board. After all, this board
has 16-bit AI resolution.
The description of the A/D LSB register at offset 0 seems incorrect in
the user manual "cio-das08jr-16-ao.pdf" as it implies that the AI
resolution is only 12 bits. The diagrams of the A/D LSB and MSB
registers show 15 data bits and a sign bit, which matches what the
software expects for the `das08_encode16` AI encoding method.
[bwh: Backported to 3.2: adjust indentation]
commit 4ef366c583d6180b1c951147869ee5a3038834f2 upstream.
On HP 1000 lapops, BIOS reports minimum backlight on boot and
causes backlight to dim completely. This ignores the initial backlight
values and set to max brightness.
References:: https://bugs.launchpad.net/bugs/1167760
Signed-off-by: Alex Hung <alex.hung@canonical.com>
commit c8f6d8351ba8c89d5cd4c562552ec7ec29274e31 upstream.
Like on UL30VT, the ACPI video driver can't control backlight correctly on
Asus UL30A. Vendor driver (asus-laptop) can work. This patch is to
add "Asus UL30A" to ACPI video detect blacklist in order to use
asus-laptop for video control on the "Asus UL30A" rather than ACPI
video driver.
Signed-off-by: Bastian Triller <bastian.triller@gmail.com>
commit d0c2ce16bec0afa6013b4c5220ca4c9c67210215 upstream.
The ACPI video driver can't control backlight correctly on
Asus UL30VT. Vendor driver (asus-laptop) can work. This patch is to
add "Asus UL30VT" to ACPI video detect blacklist in order to use
asus-laptop for video control on the "Asus UL30VT" rather than ACPI
video driver.
References: https://bugzilla.kernel.org/show_bug.cgi?id=32592
Reported-by: Alex Williamson <alex.williamson@redhat.com>
commit 084940d5b101e9ca91a689eb5048151b14076839 upstream.
On Samsung X360, the BIOS will set a flag (VDRV) if the generic
ACPI backlight device is used. This flag will definitively break
the backlight interface (even the vendor interface) untill next
reboot. It's why we should prevent video.ko from being used here
and we can't rely on a later call to acpi_video_unregister().
Signed-off-by: Corentin Chary <corentin.chary@gmail.com>
commit fd1232b214af43a973443aec6a2808f16ee5bf70 upstream.
This patch fixes I/O errors with the sym53c8xx_2 driver when the disk
returns QUEUE FULL status.
When the controller encounters an error (including QUEUE FULL or BUSY
status), it aborts all not yet submitted requests in the function
sym_dequeue_from_squeue.
This function aborts them with DID_SOFT_ERROR.
If the disk has full tag queue, the request that caused the overflow is
aborted with QUEUE FULL status (and the scsi midlayer properly retries
it until it is accepted by the disk), but the sym53c8xx_2 driver aborts
the following requests with DID_SOFT_ERROR --- for them, the midlayer
does just a few retries and then signals the error up to sd.
The result is that disk returning QUEUE FULL causes request failures.
The error was reproduced on 53c895 with COMPAQ BD03685A24 disk
(rebranded ST336607LC) with command queue 48 or 64 tags. The disk has
64 tags, but under some access patterns it return QUEUE FULL when there
are less than 64 pending tags. The SCSI specification allows returning
QUEUE FULL anytime and it is up to the host to retry.
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
Cc: Matthew Wilcox <matthew@wil.cx>
Cc: James Bottomley <JBottomley@Parallels.com>
commit 133d4527eab8d199a62eee6bd433f0776842df2e upstream.
When we write to a degraded array which has a bitmap, we
make sure the relevant bit in the bitmap remains set when
the write completes (so a 're-add' can quickly rebuilt a
temporarily-missing device).
If, immediately after such a write starts, we incorporate a spare,
commence recovery, and skip over the region where the write is
happening (because the 'needs recovery' flag isn't set yet),
then that write will not get to the new device.
Once the recovery finishes the new device will be trusted, but will
have incorrect data, leading to possible corruption.
We cannot set the 'needs recovery' flag when we start the write as we
do not know easily if the write will be "degraded" or not. That
depends on details of the particular raid level and particular write
request.
This patch fixes a corruption issue of long standing and so it
suitable for any -stable kernel. It applied correctly to 3.0 at
least and will minor editing to earlier kernels.
Reported-by: Bill <billstuff2001@sbcglobal.net>
Tested-by: Bill <billstuff2001@sbcglobal.net>
Link: http://lkml.kernel.org/r/53A518BB.60709@sbcglobal.net
Signed-off-by: NeilBrown <neilb@suse.de>
commit 2fc68eb122c7ea6cd5be1fe7d6650c0beb2f4f40 upstream.
Support for firmware rev 508+ was added years ago, but we never noticed
it reports channel in a different way for G-PHY devices. Instead of
offset from 2400 MHz it simply passes channel id (AKA hw_value).
So far it was (most probably) affecting monitor mode users only, but
the following recent commit made it noticeable for quite everybody:
commit 3afc2167f60a327a2c1e1e2600ef209a3c2b75b7
Author: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
Date: Tue Mar 4 16:50:13 2014 +0200
cfg80211/mac80211: ignore signal if the frame was heard on wrong channel
Reported-by: Aaro Koskinen <aaro.koskinen@iki.fi>
Signed-off-by: Rafał Miłecki <zajec5@gmail.com>
Tested-by: Aaro Koskinen <aaro.koskinen@iki.fi>
commit 4e578080ed3262ed2c3985868539bc66218d25c0 upstream.
Commit "drm/vmwgfx: correct fb_fix_screeninfo.line_length", while fixing a
vmwgfx fbdev bug, also writes the pitch to a supposedly read-only register:
SVGA_REG_BYTES_PER_LINE, while it should be (and also in fact is) written to
SVGA_REG_PITCHLOCK.
This patch is Cc'd stable because of the unknown effects writing to this
register might have, particularly on older device versions.
v2: Updated log message.
Cc: Christopher Friedt <chrisfriedt@gmail.com>
Tested-by: Christopher Friedt <chrisfriedt@gmail.com>
Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com>
Reviewed-by: Jakob Bornecrantz <jakob@vmware.com>
commit 642528355c694f5ed68f6bff9ff520326a249f99 upstream.
We need to specify the encoder mode as LVDS for eDP
when using the Crtc_Source atom table in order to properly
set up the FMT hardware.
bug:
https://bugs.freedesktop.org/show_bug.cgi?id=73911
commit af5d36539dfe043f1cf0f8b7334d6bb12cd14e75 upstream.
We were checking the ext clock rather than the display clock.
Noticed by ArtForz on IRC.
commit 7d5ab3009a8ca777174f6f469277b3922d56fd4b upstream.
May fix display issues with non-HDMI displays.
commit b7e460624f0f3c31150f3b09e75b0d009e22ba5f upstream.
The pxa3xx_nand driver currently uses __raw_writel() and __raw_readl()
to access I/O registers. However, those functions do not do any
endianness swapping, which means that they won't work when the CPU
runs in big-endian but the I/O registers are little endian, which is
the common situation for ARM systems running big endian.
Since __raw_writel() and __raw_readl() do not include any memory
barriers and the pxa3xx_nand driver can only be compiled for ARM
platforms, the closest I/o accessors functions that do endianess
swapping are writel_relaxed() and readl_relaxed().
This patch has been verified to work on Armada XP GP: without the
patch, the NAND is not detected when the kernel runs big endian while
it is properly detected when the kernel runs little endian. With the
patch applied, the NAND is properly detected in both situations
(little and big endian).
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Signed-off-by: Brian Norris <computersforpeace@gmail.com>
commit 616a8394b5df8c88f4dd416f4527439a4e365034 upstream.
As reported by Niels, starting rfkill polling during device probe
(commit e2bc7c5, generally sane change) broke rfkill on rt2500pci
device. I considered that bug as some initalization issue, which
should be fixed on rt2500pci specific code. But after several
attempts (see bug report for details) we fail to find working solution.
Hence I decided to revert to old behaviour on rt2500pci to fix
regression.
Additionally patch also unregister rfkill on device remove instead
of ifconfig down, what was another issue introduced by bad commit.
Bug report:
https://bugzilla.kernel.org/show_bug.cgi?id=73821
Fixes: e2bc7c5f3cb8 ("rt2x00: Fix rfkill_polling register function.")
Bisected-by: Niels <nille0386@googlemail.com>
Reported-and-tested-by: Niels <nille0386@googlemail.com>
Signed-off-by: Stanislaw Gruszka <stf_xl@wp.pl>
commit 8edcb0ba0d56f5914eef11eda6db8bfe74eb9ca8 upstream.
On USB we can not get atomically TKIP key. We have to disable support
for TKIP acceleration on USB hardware to avoid bug as showed bellow.
[ 860.827243] BUG: scheduling while atomic: hostapd/3397/0x00000002
<snip>
[ 860.827280] Call Trace:
[ 860.827282] [<ffffffff81682ea6>] dump_stack+0x4d/0x66
[ 860.827284] [<ffffffff8167eb9b>] __schedule_bug+0x47/0x55
[ 860.827285] [<ffffffff81685bb3>] __schedule+0x733/0x7b0
[ 860.827287] [<ffffffff81685c59>] schedule+0x29/0x70
[ 860.827289] [<ffffffff81684f8a>] schedule_timeout+0x15a/0x2b0
[ 860.827291] [<ffffffff8105ac50>] ? ftrace_raw_event_tick_stop+0xc0/0xc0
[ 860.827294] [<ffffffff810c13c2>] ? __module_text_address+0x12/0x70
[ 860.827296] [<ffffffff81686823>] wait_for_completion_timeout+0xb3/0x140
[ 860.827298] [<ffffffff81080fc0>] ? wake_up_state+0x20/0x20
[ 860.827301] [<ffffffff814d5b3d>] usb_start_wait_urb+0x7d/0x150
[ 860.827303] [<ffffffff814d5cd5>] usb_control_msg+0xc5/0x110
[ 860.827305] [<ffffffffa02fb0c6>] rt2x00usb_vendor_request+0xc6/0x160 [rt2x00usb]
[ 860.827307] [<ffffffffa02fb215>] rt2x00usb_vendor_req_buff_lock+0x75/0x150 [rt2x00usb]
[ 860.827309] [<ffffffffa02fb393>] rt2x00usb_vendor_request_buff+0xa3/0xe0 [rt2x00usb]
[ 860.827311] [<ffffffffa023d1a3>] rt2x00usb_register_multiread+0x33/0x40 [rt2800usb]
[ 860.827314] [<ffffffffa05805f9>] rt2800_get_tkip_seq+0x39/0x50 [rt2800lib]
[ 860.827321] [<ffffffffa0480f88>] ieee80211_get_key+0x218/0x2a0 [mac80211]
[ 860.827322] [<ffffffff815cc68c>] ? __nlmsg_put+0x6c/0x80
[ 860.827329] [<ffffffffa051b02e>] nl80211_get_key+0x22e/0x360 [cfg80211]
Reported-and-tested-by: Peter Wu <lekensteyn@gmail.com>
Reported-and-tested-by: Pontus Fuchs <pontus.fuchs@gmail.com>
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
commit f0688c8b81d2ea239c3fb0b848f623b579238d99 upstream.
If the descriptors do not need any strings and user space sends empty
set of strings, the ffs->stringtabs field remains NULL. Thus
*ffs->stringtabs in functionfs_bind leads to a NULL pointer
dereferenece.
The bug was introduced by commit [fd7c9a007f: “use usb_string_ids_n()”].
While at it, remove double initialisation of lang local variable in
that function.
ffs->strings_count does not need to be checked in any way since in
the above scenario it will remain zero and usb_string_ids_n() is
a no-operation when colled with 0 argument.
Signed-off-by: Michal Nazarewicz <mina86@mina86.com>
Signed-off-by: Felipe Balbi <balbi@ti.com>
commit aea1ae8760314e072bf1b773521e9de5d5dda10d upstream.
Fix NULL-pointer dereference when probing an interface with no
endpoints.
These devices have two bulk endpoints per interface, but this avoids
crashing the kernel if a user forces a non-FTDI device to be probed.
Note that the iterator variable was made unsigned in order to avoid
a maybe-uninitialized compiler warning for ep_desc after the loop.
Fixes: 895f28badce9 ("USB: ftdi_sio: fix hi-speed device packet size
calculation")
Reported-by: Mike Remski <mremski@mutualink.net>
Tested-by: Mike Remski <mremski@mutualink.net>
commit b0ebef36e93703e59003ad6a1a20227e47714417 upstream.
Adding a couple of Olivetti modems and blacklisting the net
function on a couple which are already supported.
Reported-by: Lars Melin <larsm17@gmail.com>
Signed-off-by: Bjørn Mork <bjorn@mork.no>
commit 1cab4c68e339086cdaff7535848e878e8f261fca upstream.
Reported by Alif Mubarak Ahmad:
This device vendor and product id is 1c9e:9800
It is working as serial interface with generic usbserial driver.
I thought it is more suitable to use usbserial option driver, which has
better capability distinguishing between modem serial interface and
micro sd storage interface.
[ johan: style changes ]
Signed-off-by: Oliver Neukum <oneukum@suse.de>
Tested-by: Alif Mubarak Ahmad <alive4ever@live.com>
commit d6236f6d1d885aa19d1cd7317346fe795227a3cc upstream.
The system suspend flow as following:
1, Freeze all user processes and kenrel threads.
2, Try to suspend all devices.
2.1, If pci device is in RPM suspended state, then pci driver will try
to resume it to RPM active state in the prepare stage.
2.2, xhci_resume function calls usb_hcd_resume_root_hub to queue two
workqueue items to resume usb2&usb3 roothub devices.
2.3, Call suspend callbacks of devices.
2.3.1, All suspend callbacks of all hcd's children, including
roothub devices are called.
2.3.2, Finally, hcd_pci_suspend callback is called.
Due to workqueue threads were already frozen in step 1, the workqueue
items can't be scheduled, and the roothub devices can't be resumed in
this flow. The HCD_FLAG_WAKEUP_PENDING flag which is set in
usb_hcd_resume_root_hub won't be cleared. Finally,
hcd_pci_suspend will return -EBUSY, and system suspend fails.
The reason why this issue doesn't show up very often is due to that
choose_wakeup will be called in step 2.3.1. In step 2.3.1, if
udev->do_remote_wakeup is not equal to device_may_wakeup(&udev->dev), then
udev will resume to RPM active for changing the wakeup settings. This
has been a lucky hit which hides this issue.
For some special xHCI controllers which have no USB2 port, then roothub
will not match hub driver due to probe failed. Then its
do_remote_wakeup will be set to zero, and we won't be as lucky.
xhci driver doesn't need to resume roothub devices everytime like in
the above case. It's only needed when there are pending event TRBs.
This patch should be back-ported to kernels as old as 3.2, that
contains the commit f69e3120df82391a0ee8118e0a156239a06b2afb
"USB: XHCI: resume root hubs when the controller resumes"
Signed-off-by: Wang, Yu <yu.y.wang@intel.com>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
[use readl() instead of removed xhci_readl(), reword commit message -Mathias]
Signed-off-by: Mathias Nyman <mathias.nyman@linux.intel.com>
commit 3213b151387df0b95f4eada104f68eb1c1409cb3 upstream.
The transfer burst count (TBC) field in xhci 1.0 hosts should be set
to the number of bursts needed to transfer all packets in a isoc TD.
Supported values are 0-2 (1 to 3 bursts per service interval).
Formula for TBC calculation is given in xhci spec section 4.11.2.3:
TBC = roundup( Transfer Descriptor Packet Count / Max Burst Size +1 ) - 1
This patch should be applied to stable kernels since 3.0 that contain
the commit 5cd43e33b9519143f06f507dd7cbee6b7a621885
"xhci 1.0: Set transfer burst count field."
Suggested-by: ShiChun Ma <masc2008@qq.com>
commit 9ee755974bea2f9880e517ec985dc9dede1b3a36 upstream.
If a CRQ reset is triggered for some reason while in the middle
of performing VSCSI adapter initialization, we don't want to
call the done function for the initialization MAD commands as
this will only result in two threads attempting initialization
at the same time, resulting in failures.
Signed-off-by: Brian King <brking@linux.vnet.ibm.com>
Acked-by: Nathan Fontenot <nfont@linux.vnet.ibm.com>
commit 60e1751cb52cc6d1ae04b6bd3c2b96e770b5823f upstream.
Avoid that closing /dev/infiniband/umad<n> or /dev/infiniband/issm<n>
triggers a use-after-free. __fput() invokes f_op->release() before it
invokes cdev_put(). Make sure that the ib_umad_device structure is
freed by the cdev_put() call instead of f_op->release(). This avoids
that changing the port mode from IB into Ethernet and back to IB
followed by restarting opensmd triggers the following kernel oops:
general protection fault: 0000 [#1] PREEMPT SMP
RIP: 0010:[<ffffffff810cc65c>] [<ffffffff810cc65c>] module_put+0x2c/0x170
Call Trace:
[<ffffffff81190f20>] cdev_put+0x20/0x30
[<ffffffff8118e2ce>] __fput+0x1ae/0x1f0
[<ffffffff8118e35e>] ____fput+0xe/0x10
[<ffffffff810723bc>] task_work_run+0xac/0xe0
[<ffffffff81002a9f>] do_notify_resume+0x9f/0xc0
[<ffffffff814b8398>] int_signal+0x12/0x17
Reference: https://bugzilla.kernel.org/show_bug.cgi?id=75051
Signed-off-by: Bart Van Assche <bvanassche@acm.org>
Reviewed-by: Yann Droneaud <ydroneaud@opteya.com>
Signed-off-by: Roland Dreier <roland@purestorage.com>
commit 8ec0a0e6b58218bdc1db91dd70ebfcd6ad8dd6cd upstream.
Avoid leaking a kref count in ib_umad_open() if port->ib_dev == NULL
or if nonseekable_open() fails.
Avoid leaking a kref count, that sm_sem is kept down and also that the
IB_PORT_SM capability mask is not cleared in ib_umad_sm_open() if
Since container_of() never returns NULL, remove the code that tests
whether container_of() returns NULL.
Moving the kref_get() call from the start of ib_umad_*open() to the
end is safe since it is the responsibility of the caller of these
functions to ensure that the cdev pointer remains valid until at least
when these functions return.
[ydroneaud@opteya.com: rework a bit to reduce the amount of code changed]
Signed-off-by: Yann Droneaud <ydroneaud@opteya.com>
[ nonseekable_open() can't actually fail, but.... - Roland ]
commit 024ca90151f5e4296d30f72c13ff9a075e23c9ec upstream.
Avoid that the loops that iterate over the request ring can encounter
a pointer to a SCSI command in req->scmnd that is no longer associated
with that request. If the function srp_unmap_data() is invoked twice
for a SCSI command that is not in flight then that would cause
ib_fmr_pool_unmap() to be invoked with an invalid pointer as argument,
resulting in a kernel oops.
Reported-by: Sagi Grimberg <sagig@mellanox.com>
Reference: http://thread.gmane.org/gmane.linux.drivers.rdma/19068/focus=19069
Reviewed-by: Sagi Grimberg <sagig@mellanox.com>
commit 7e6d3e5c70f13874fb06e6b67696ed90ce79bd48 upstream.
This patch addresses an issue where the legacy diagpacket is sent in
from the user, but the driver operates on only the extended
diagpkt. This patch specifically initializes the extended diagpkt
based on the legacy packet.
Reported-by: Rickard Strandqvist <rickard_strandqvist@spectrumdigital.se>
Reviewed-by: Mike Marciniszyn <mike.marciniszyn@intel.com>
Signed-off-by: Dennis Dalessandro <dennis.dalessandro@intel.com>
commit 911eccd284d13d78c92ec4f1f1092c03457d732a upstream.
The code used a literal 1 in dispatching an IB_EVENT_PKEY_CHANGE.
As of the dual port qib QDR card, this is not necessarily correct.
Change to use the port as specified in the call.
Reported-by: Alex Estrin <alex.estrin@intel.com>
Reviewed-by: Dennis Dalessandro <dennis.dalessandro@intel.com>
Signed-off-by: Mike Marciniszyn <mike.marciniszyn@intel.com>
commit 938626d96a3ffb9eb54552bb0d3a4f2b30ffdeb0 upstream.
Implementation of ->set_timeout() is supposed to set 'timeout' field of 'struct
watchdog_device' passed to it. sp805 was rather setting this in a local
variable. Fix it.
Reported-by: Arun Ramamurthy <arun.ramamurthy@broadcom.com>
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
Reviewed-by: Guenter Roeck <linux@roeck-us.net>
Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
commit 67ebd8140dc8923c65451fa0f6a8eee003c4dcd3 upstream.
3448a19da479 "vgaarb: use bridges to control VGA routing where possible"
added the "flags & PCI_VGA_STATE_CHANGE_DECODES" condition to an existing
WARN_ON(), but used bitwise AND (&) instead of logical AND (&&), so the
condition is never true. Replace with logical AND.
Found by Coverity (CID 142811).
Fixes: 3448a19da479 "vgaarb: use bridges to control VGA routing where possible"
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Acked-by: Yinghai Lu <yinghai@kernel.org>
Acked-by: David Airlie <airlied@redhat.com>
commit 7c82126a94e69bbbac586f0249e7ef11e681246c upstream.
After a CPU upgrade while keeping the same mainboard, we faced "spurious
interrupt" problems again.
It turned out that the new CPU also featured a new GPU with a different PCI
ID.
Add this PCI ID to the quirk table. Probably all other Intel GPU PCI IDs
are affected, too, but I don't want to add them without a test system.
See f67fd55fa96f ("PCI: Add quirk for still enabled interrupts on Intel
Sandy Bridge GPUs") for some history.
[bhelgaas: add f67fd55fa96f reference, stable tag]
Signed-off-by: Thomas Jarosch <thomas.jarosch@intra2net.com>
commit cd9e83e2754465856097f31c7ab933ce74c473f8 upstream.
At least the Dell Vostro 5470 elantech *clickpad* reports right button
clicks when clicked in the right bottom area:
https://bugzilla.redhat.com/show_bug.cgi?id=1103528
This is different from how (elantech) clickpads normally operate, normally
no matter where the user clicks on the pad the pad always reports a left
button event, since there is only 1 hardware button beneath the path.
It looks like Dell has put 2 buttons under the pad, one under each bottom
corner, causing this.
Since this however still clearly is a real clickpad hardware-wise, we still
want to report it as such to userspace, so that things like finger movement
in the bottom area can be properly ignored as it should be on clickpads.
So deal with this weirdness by simply mapping a right click to a left click
on elantech clickpads. As an added advantage this is something which we can
simply do on all elantech clickpads, so no need to add special quirks for
this weird model.
Reported-and-tested-by: Elder Marco <eldermarco@gmail.com>
commit e5e4746510d140261918aecce2e5e3aa4456f7e9 upstream.
Without a timetout some tests e.g. test_halt() can remain stuck forever.
Signed-off-by: Roger Quadros <rogerq@ti.com>
Reviewed-by: Felipe Balbi <balbi@ti.com>
[Note that a different patch to address the same issue went in during
v3.15-rc1 (commit 4442dc8a), but includes a bunch of other changes that
don't strictly apply to fixing the bug]
This patch changes rd_allocate_sgl_table() to explicitly clear
ramdisk_mcp backend memory pages by passing __GFP_ZERO into
alloc_pages().
This addresses a potential security issue where reading from a
ramdisk_mcp could return sensitive information, and follows what
>= v3.15 does to explicitly clear ramdisk_mcp memory at backend
device initialization time.
Reported-by: Jorge Daniel Sequeira Matias <jdsm@tecnico.ulisboa.pt>
Cc: Jorge Daniel Sequeira Matias <jdsm@tecnico.ulisboa.pt>
commit 73577d1df8e1f31f6b1a5eebcdbc334eb0330e47 upstream.
This patch fixes the following issue:
If DSDT is customized, no local DSDT copy is needed.
References: https://bugzilla.kernel.org/show_bug.cgi?id=69711
Signed-off-by: Enrico Etxe Arte <goitizena.generoa@gmail.com>
Signed-off-by: Lv Zheng <lv.zheng@intel.com>
[rjw: Subject]
commit 80cc0fcbdaeaf10d04ba27779a2d7ceb73d2717a upstream.
Make sure that needs_remote_wake up is always set when there are open
ports.
Currently close() would unconditionally set needs_remote_wakeup to 0
even though there might still be open ports. This could lead to blocked
input and possibly dropped data on devices that do not support remote
wakeup (and which must therefore not be runtime suspended while open).
Add an open_ports counter (protected by the susp_lock) and only clear
needs_remote_wakeup when the last port is closed.
Fixes: e6929a9020ac ("USB: support for autosuspend in sierra while
online")
Signed-off-by: Johan Hovold <jhovold@gmail.com>
commit 014333f77c0b71123d6ef7d31a9724e0699c9548 upstream.
The delayed-write queue was never emptied on disconnect, something which
would lead to leaked urbs and transfer buffers if the device is
disconnected before being runtime resumed due to a write.
online")
commit 7fdd26a01eb7b6cb6855ff8f69ef4a720720dfcb upstream.
Neither the transfer buffer or the urb itself were released in the
resume error path for delayed writes. Also on errors, the remainder of
the queue was not even processed, which leads to further urb and buffer
leaks.
The same error path also failed to balance the outstanding-urb counter,
something which results in degraded throughput or completely blocked
writes.
Fix this by releasing urb and buffer and balancing counters on errors,
and by always processing the whole queue even when submission of one urb
fails.
online")
commit 8452727de70f6ad850cd6d0aaa18b5d9050aa63b upstream.
Fix use after free or NULL-pointer dereference during suspend and
resume.
The port data may never have been allocated (port probe failed)
or may already have been released by port_remove (e.g. driver is
unloaded) when suspend and resume are called.
online")
