path: root/drivers
2013-09-14macvtap: do not zerocopy if iov needs more pages than MAX_SKB_FRAGSJason Wang
commit ece793fcfc417b3925844be88a6a6dc82ae8f7c6 upstream. We try to linearize part of the skb when the number of iov is greater than MAX_SKB_FRAGS. This is not enough since each single vector may occupy more than one pages, so zerocopy_sg_fromiovec() may still fail and may break the guest network. Solve this problem by calculate the pages needed for iov before trying to do zerocopy and switch to use copy instead of zerocopy if it needs more than MAX_SKB_FRAGS. This is done through introducing a new helper to count the pages for iov, and call uarg->callback() manually when switching from zerocopy to copy to notify vhost. We can do further optimization on top. This bug were introduced from b92946e2919134ebe2a4083e4302236295ea2a73 (macvtap: zerocopy: validate vectors before building skb). Cc: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Jason Wang <jasowang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-14vhost: zerocopy: poll vq in zerocopy callbackJason Wang
commit c70aa540c7a9f67add11ad3161096fb95233aa2e upstream. We add used and signal guest in worker thread but did not poll the virtqueue during the zero copy callback. This may lead the missing of adding and signalling during zerocopy. Solve this by polling the virtqueue and let it wakeup the worker during callback. Signed-off-by: Jason Wang <jasowang@redhat.com> Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-14tun: signedness bug in tun_get_user()Dan Carpenter
[ Upstream commit 15718ea0d844e4816dbd95d57a8a0e3e264ba90e ] The recent fix d9bf5f1309 "tun: compare with 0 instead of total_len" is not totally correct. Because "len" and "sizeof()" are size_t type, that means they are never less than zero. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Acked-by: Michael S. Tsirkin <mst@redhat.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-148139cp: Fix skb leak in rx_status_loop failure path.Dave Jones
[ Upstream commit d06f5187469eee1b2932c02fd093d113cfc60d5e ] Introduced in cf3c4c03060b688cbc389ebc5065ebcce5653e96 ("8139cp: Add dma_mapping_error checking") Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-14bonding: modify only neigh_parms owned by usVeaceslav Falico
[ Upstream commit 9918d5bf329d0dc5bb2d9d293bcb772bdb626e65 ] Otherwise, on neighbour creation, bond_neigh_init() will be called with a foreign netdev. Signed-off-by: Veaceslav Falico <vfalico@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-07target: Fix trailing ASCII space usage in INQUIRY vendor+modelNicholas Bellinger
commit ee60bddba5a5f23e39598195d944aa0eb2d455e5 upstream. This patch fixes spc_emulate_inquiry_std() to add trailing ASCII spaces for INQUIRY vendor + model fields following SPC-4 text: "ASCII data fields described as being left-aligned shall have any unused bytes at the end of the field (i.e., highest offset) and the unused bytes shall be filled with ASCII space characters (20h)." This addresses a problem with Falconstor NSS multipathing. Reported-by: Tomas Molota <tomas.molota@lightstorm.sk> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-07ACPI / EC: Add ASUSTEK L4R to quirk list in order to validate ECDTLan Tianyu
commit 524f42fab787a9510be826ce3d736b56d454ac6d upstream. The ECDT of ASUSTEK L4R doesn't provide correct command and data I/O ports. The DSDT provides the correct information instead. For this reason, add this machine to quirk list for ECDT validation and use the EC information from the DSDT. [rjw: Changelog] References: https://bugzilla.kernel.org/show_bug.cgi?id=60765 Reported-and-tested-by: Daniele Esposti <expo@expobrain.net> Signed-off-by: Lan Tianyu <tianyu.lan@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-07iwl4965: fix rfkill set state regressionStanislaw Gruszka
commit b2fcc0aee58a3435566dd6d8501a0b355552f28b upstream. My current 3.11 fix: commit 788f7a56fce1bcb2067b62b851a086fca48a0056 Author: Stanislaw Gruszka <sgruszka@redhat.com> Date: Thu Aug 1 12:07:55 2013 +0200 iwl4965: reset firmware after rfkill off broke rfkill notification to user-space . I missed that bug, because I compiled without CONFIG_RFKILL, sorry about that. Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-07ath9k_htc: Restore skb headroom when returning skb to mac80211Helmut Schaa
commit d2e9fc141e2aa21f4b35ee27072d84e9aa6e2ba0 upstream. ath9k_htc adds padding between the 802.11 header and the payload during TX by moving the header. When handing the frame back to mac80211 for TX status handling the header is not moved back into its original position. This can result in a too small skb headroom when entering ath9k_htc again (due to a soft retransmission for example) causing an skb_under_panic oops. Fix this by moving the 802.11 header back into its original position before returning the frame to mac80211 as other drivers like rt2x00 or ath5k do. Reported-by: Marc Kleine-Budde <mkl@blackshift.org> Signed-off-by: Helmut Schaa <helmut.schaa@googlemail.com> Tested-by: Marc Kleine-Budde <mkl@blackshift.org> Signed-off-by: Marc Kleine-Budde <mkl@blackshift.org> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-07drm/i915: ivb: fix edp voltage swing reg valImre Deak
commit 77fa4cbd5fa389e28419bbe8ac491b5fdd54840d upstream. Fix the typo introduced in commit 1a2eb4604b85c5efb343da8a4dcf41288fcfca85 Author: Keith Packard <keithp@keithp.com> Date: Wed Nov 16 16:26:07 2011 -0800 drm/i915: Hook up Ivybridge eDP This fixes eDP link-training failures and cases where all voltage swing /pre-emphasis levels were tried and failed during clock recovery and - as a fallback - we go on to do channel equalization with the last voltage swing/pre-emphasis level which will succeed. Both issues can lead to a blank screen. v2: - improve commit message Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=64880 Tested-by: Jeremy Moles <cubicool@gmail.com> Signed-off-by: Imre Deak <imre.deak@intel.com> Reviewed-by: Paulo Zanoni <paulo.r.zanoni@intel.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-07drm/vmwgfx: Split GMR2_REMAP commands if they are to largeJakob Bornecrantz
commit 6e4dcff3adbf25acb87e74500a58e3c07bdec40f upstream. This fixes the piglit test texturing/max-texture-size causing the VM to die due to a too large SVGA command. Signed-off-by: Jakob Bornecrantz <jakob@vmware.com> Reviewed-by: Biran Paul <brianp@vmware.com> Reviewed-by: Zack Rusin <zackr@vmware.com> Signed-off-by: Dave Airlie <airlied@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-07drivers/base/memory.c: fix show_mem_removable() to handle missing sectionsRuss Anderson
commit 21ea9f5ace3a7317cc3ba1fbc749758021a83136 upstream. "cat /sys/devices/system/memory/memory*/removable" crashed the system. The problem is that show_mem_removable() is passing a bad pfn to is_mem_section_removable(), which causes if (!node_online(page_to_nid(page))) to blow up. Why is it passing in a bad pfn? The reason is that show_mem_removable() will loop sections_per_block times. sections_per_block is 16, but mem->section_count is 8, indicating holes in this memory block. Checking that the memory section is present before checking to see if the memory section is removable fixes the problem. harp5-sys:~ # cat /sys/devices/system/memory/memory*/removable 0 1 1 1 1 1 1 1 1 1 1 1 1 1 BUG: unable to handle kernel paging request at ffffea00c3200000 IP: [<ffffffff81117ed1>] is_pageblock_removable_nolock+0x1/0x90 PGD 83ffd4067 PUD 37bdfce067 PMD 0 Oops: 0000 [#1] SMP Modules linked in: autofs4 binfmt_misc rdma_ucm rdma_cm iw_cm ib_addr ib_srp scsi_transport_srp scsi_tgt ib_ipoib ib_cm ib_uverbs ib_umad iw_cxgb3 cxgb3 mdio mlx4_en mlx4_ib ib_sa mlx4_core ib_mthca ib_mad ib_core fuse nls_iso8859_1 nls_cp437 vfat fat joydev loop hid_generic usbhid hid hwperf(O) numatools(O) dm_mod iTCO_wdt ipv6 iTCO_vendor_support igb i2c_i801 ioatdma i2c_algo_bit ehci_pci pcspkr lpc_ich i2c_core ehci_hcd ptp sg mfd_core dca rtc_cmos pps_core mperf button xhci_hcd sd_mod crc_t10dif usbcore usb_common scsi_dh_emc scsi_dh_hp_sw scsi_dh_alua scsi_dh_rdac scsi_dh gru(O) xvma(O) xfs crc32c libcrc32c thermal sata_nv processor piix mptsas mptscsih scsi_transport_sas mptbase megaraid_sas fan thermal_sys hwmon ext3 jbd ata_piix ahci libahci libata scsi_mod CPU: 4 PID: 5991 Comm: cat Tainted: G O 3.11.0-rc5-rja-uv+ #10 Hardware name: SGI UV2000/ROMLEY, BIOS SGI UV 2000/3000 series BIOS 01/15/2013 task: ffff88081f034580 ti: ffff880820022000 task.ti: ffff880820022000 RIP: 0010:[<ffffffff81117ed1>] [<ffffffff81117ed1>] is_pageblock_removable_nolock+0x1/0x90 RSP: 0018:ffff880820023df8 EFLAGS: 00010287 RAX: 0000000000040000 RBX: ffffea00c3200000 RCX: 0000000000000004 RDX: ffffea00c30b0000 RSI: 00000000001c0000 RDI: ffffea00c3200000 RBP: ffff880820023e38 R08: 0000000000000000 R09: 0000000000000001 R10: 0000000000000000 R11: 0000000000000001 R12: ffffea00c33c0000 R13: 0000160000000000 R14: 6db6db6db6db6db7 R15: 0000000000000001 FS: 00007ffff7fb2700(0000) GS:ffff88083fc80000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: ffffea00c3200000 CR3: 000000081b954000 CR4: 00000000000407e0 Call Trace: show_mem_removable+0x41/0x70 dev_attr_show+0x2a/0x60 sysfs_read_file+0xf7/0x1c0 vfs_read+0xc8/0x130 SyS_read+0x5d/0xa0 system_call_fastpath+0x16/0x1b Signed-off-by: Russ Anderson <rja@sgi.com> Cc: "Rafael J. Wysocki" <rafael.j.wysocki@intel.com> Cc: Yinghai Lu <yinghai@kernel.org> Reviewed-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-07regmap: silence GCC warningPaul Bolle
commit a8f28cfad8cd44d7c34b166d0e5ace1125dbee1f upstream. Building regmap.o triggers this GCC warning: drivers/base/regmap/regmap.c: In function ‘regmap_raw_read’: drivers/base/regmap/regmap.c:1172:6: warning: ‘ret’ may be used uninitialized in this function [-Wmaybe-uninitialized] Long story short: Jakub Jelinek pointed out that there is a type mismatch between 'num' in regmap_volatile_range() and 'val_count' in regmap_raw_read(). And indeed, converting 'num' to the type of 'val_count' (ie, size_t) makes this warning go away. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-07powerpc/hvsi: Increase handshake timeout from 200ms to 400ms.Eugene Surovegin
commit d220980b701d838560a70de691b53be007e99e78 upstream. This solves a problem observed in kexec'ed kernel where 200ms timeout is too short and bootconsole fails to initialize. Console did eventually become workable but much later into the boot process. Observed timeout was around 260ms, but I decided to make it a little bigger for more reliability. This has been tested on Power7 machine with Petitboot as a primary bootloader and PowerNV firmware. Signed-off-by: Eugene Surovegin <surovegin@google.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-29SCSI: zfcp: fix schedule-inside-lock in scsi_device list loopsMartin Peschke
commit 924dd584b198a58aa7cb3efefd8a03326550ce8f upstream. BUG: sleeping function called from invalid context at kernel/workqueue.c:2752 in_atomic(): 1, irqs_disabled(): 1, pid: 360, name: zfcperp0.0.1700 CPU: 1 Not tainted 3.9.3+ #69 Process zfcperp0.0.1700 (pid: 360, task: 0000000075b7e080, ksp: 000000007476bc30) <snip> Call Trace: ([<00000000001165de>] show_trace+0x106/0x154) [<00000000001166a0>] show_stack+0x74/0xf4 [<00000000006ff646>] dump_stack+0xc6/0xd4 [<000000000017f3a0>] __might_sleep+0x128/0x148 [<000000000015ece8>] flush_work+0x54/0x1f8 [<00000000001630de>] __cancel_work_timer+0xc6/0x128 [<00000000005067ac>] scsi_device_dev_release_usercontext+0x164/0x23c [<0000000000161816>] execute_in_process_context+0x96/0xa8 [<00000000004d33d8>] device_release+0x60/0xc0 [<000000000048af48>] kobject_release+0xa8/0x1c4 [<00000000004f4bf2>] __scsi_iterate_devices+0xfa/0x130 [<000003ff801b307a>] zfcp_erp_strategy+0x4da/0x1014 [zfcp] [<000003ff801b3caa>] zfcp_erp_thread+0xf6/0x2b0 [zfcp] [<000000000016b75a>] kthread+0xf2/0xfc [<000000000070c9de>] kernel_thread_starter+0x6/0xc [<000000000070c9d8>] kernel_thread_starter+0x0/0xc Apparently, the ref_count for some scsi_device drops down to zero, triggering device removal through execute_in_process_context(), while the lldd error recovery thread iterates through a scsi device list. Unfortunately, execute_in_process_context() decides to immediately execute that device removal function, instead of scheduling asynchronous execution, since it detects process context and thinks it is safe to do so. But almost all calls to shost_for_each_device() in our lldd are inside spin_lock_irq, even in thread context. Obviously, schedule() inside spin_lock_irq sections is a bad idea. Change the lldd to use the proper iterator function, __shost_for_each_device(), in combination with required locking. Occurences that need to be changed include all calls in zfcp_erp.c, since those might be executed in zfcp error recovery thread context with a lock held. Other occurences of shost_for_each_device() in zfcp_fsf.c do not need to be changed (no process context, no surrounding locking). The problem was introduced in Linux 2.6.37 by commit b62a8d9b45b971a67a0f8413338c230e3117dff5 "[SCSI] zfcp: Use SCSI device data zfcp_scsi_dev instead of zfcp_unit". Reported-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Martin Peschke <mpeschke@linux.vnet.ibm.com> Signed-off-by: Steffen Maier <maier@linux.vnet.ibm.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-29SCSI: zfcp: fix lock imbalance by reworking request queue lockingMartin Peschke
commit d79ff142624e1be080ad8d09101f7004d79c36e1 upstream. This patch adds wait_event_interruptible_lock_irq_timeout(), which is a straight-forward descendant of wait_event_interruptible_timeout() and wait_event_interruptible_lock_irq(). The zfcp driver used to call wait_event_interruptible_timeout() in combination with some intricate and error-prone locking. Using wait_event_interruptible_lock_irq_timeout() as a replacement nicely cleans up that locking. This rework removes a situation that resulted in a locking imbalance in zfcp_qdio_sbal_get(): BUG: workqueue leaked lock or atomic: events/1/0xffffff00/10 last function: zfcp_fc_wka_port_offline+0x0/0xa0 [zfcp] It was introduced by commit c2af7545aaff3495d9bf9a7608c52f0af86fb194 "[SCSI] zfcp: Do not wait for SBALs on stopped queue", which had a new code path related to ZFCP_STATUS_ADAPTER_QDIOUP that took an early exit without a required lock being held. The problem occured when a special, non-SCSI I/O request was being submitted in process context, when the adapter's queues had been torn down. In this case the bug surfaced when the Fibre Channel port connection for a well-known address was closed during a concurrent adapter shut-down procedure, which is a rare constellation. This patch also fixes these warnings from the sparse tool (make C=1): drivers/s390/scsi/zfcp_qdio.c:224:12: warning: context imbalance in 'zfcp_qdio_sbal_check' - wrong count at exit drivers/s390/scsi/zfcp_qdio.c:244:5: warning: context imbalance in 'zfcp_qdio_sbal_get' - unexpected unlock Last but not least, we get rid of that crappy lock-unlock-lock sequence at the beginning of the critical section. It is okay to call zfcp_erp_adapter_reopen() with req_q_lock held. Reported-by: Mikulas Patocka <mpatocka@redhat.com> Reported-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Peschke <mpeschke@linux.vnet.ibm.com> Signed-off-by: Steffen Maier <maier@linux.vnet.ibm.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-29libata: apply behavioral quirks to sil3826 PMPTerry Suereth
commit 8ffff94d20b7eb446e848e0046107d51b17a20a8 upstream. Fixing support for the Silicon Image 3826 port multiplier, by applying to it the same quirks applied to the Silicon Image 3726. Specifically fixes the repeated timeout/reset process which previously afflicted the 3726, as described from line 290. Slightly based on notes from: https://bugzilla.redhat.com/show_bug.cgi?id=890237 Signed-off-by: Terry Suereth <terry.suereth@gmail.com> Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-29Hostap: copying wrong data prism2_ioctl_giwaplist()Dan Carpenter
commit 909bd5926d474e275599094acad986af79671ac9 upstream. We want the data stored in "addr" and "qual", but the extra ampersands mean we are copying stack data instead. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-29of: fdt: fix memory initialization for expanded DTWladislav Wiebe
commit 9e40127526e857fa3f29d51e83277204fbdfc6ba upstream. Already existing property flags are filled wrong for properties created from initial FDT. This could cause problems if this DYNAMIC device-tree functions are used later, i.e. properties are attached/detached/replaced. Simply dumping flags from the running system show, that some initial static (not allocated via kzmalloc()) nodes are marked as dynamic. I putted some debug extensions to property_proc_show(..) : .. + if (OF_IS_DYNAMIC(pp)) + pr_err("DEBUG: xxx : OF_IS_DYNAMIC\n"); + if (OF_IS_DETACHED(pp)) + pr_err("DEBUG: xxx : OF_IS_DETACHED\n"); when you operate on the nodes (e.g.: ~$ cat /proc/device-tree/*some_node*) you will see that those flags are filled wrong, basically in most cases it will dump a DYNAMIC or DETACHED status, which is in not true. (BTW. this OF_IS_DETACHED is a own define for debug purposes which which just make a test_bit(OF_DETACHED, &x->_flags) If nodes are dynamic kernel is allowed to kfree() them. But it will crash attempting to do so on the nodes from FDT -- they are not allocated via kzmalloc(). Signed-off-by: Wladislav Wiebe <wladislav.kw@gmail.com> Acked-by: Alexander Sverdlin <alexander.sverdlin@nsn.com> Signed-off-by: Rob Herring <rob.herring@calxeda.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-29drm/i915: Invalidate TLBs for the rings after a resetChris Wilson
commit 884020bf3d2a3787a1cc6df902e98e0eec60330b upstream. After any "soft gfx reset" we must manually invalidate the TLBs associated with each ring. Empirically, it seems that a suspend/resume or D3-D0 cycle count as a "soft reset". The symptom is that the hardware would fail to note the new address for its status page, and so it would continue to write the shadow registers and breadcrumbs into the old physical address (now used by something completely different, scary). Whereas the driver would read the new status page and never see any progress, it would appear that the GPU hung immediately upon resume. Based on a patch by naresh kumar kachhi <naresh.kumar.kacchi@intel.com> Reported-by: Thiago Macieira <thiago@kde.org> Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=64725 Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Tested-by: Thiago Macieira <thiago@kde.org> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-29xen/events: initialize local per-cpu mask for all possible eventsDavid Vrabel
commit 84ca7a8e45dafb49cd5ca90a343ba033e2885c17 upstream. The sizeof() argument in init_evtchn_cpu_bindings() is incorrect resulting in only the first 64 (or 32 in 32-bit guests) ports having their bindings being initialized to VCPU 0. In most cases this does not cause a problem as request_irq() will set the irq affinity which will set the correct local per-cpu mask. However, if the request_irq() is called on a VCPU other than 0, there is a window between the unmasking of the event and the affinity being set were an event may be lost because it is not locally unmasked on any VCPU. If request_irq() is called on VCPU 0 then local irqs are disabled during the window and the race does not occur. Fix this by initializing all NR_EVENT_CHANNEL bits in the local per-cpu masks. Signed-off-by: David Vrabel <david.vrabel@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-29zd1201: do not use stack as URB transfer_bufferJussi Kivilinna
commit 1206ff4ff9d2ef7468a355328bc58ac6ebf5be44 upstream. Patch fixes zd1201 not to use stack as URB transfer_buffer. URB buffers need to be DMA-able, which stack is not. Patch is only compile tested. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@iki.fi> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-20USB: mos7720: fix broken control requestsJohan Hovold
commit ef6c8c1d733e244f0499035be0dabe1f4ed98c6f upstream. The parallel-port code of the drivers used a stack allocated control-request buffer for asynchronous (and possibly deferred) control requests. This not only violates the no-DMA-from-stack requirement but could also lead to corrupt control requests being submitted. Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-20usb: add two quirky touchscreenOliver Neukum
commit 304ab4ab079a8ed03ce39f1d274964a532db036b upstream. These devices tend to become unresponsive after S3 Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-20can: pcan_usb: fix wrong memcpy() bytes lengthStephane Grosjean
commit 3c322a56b01695df15c70bfdc2d02e0ccd80654e upstream. Fix possibly wrong memcpy() bytes length since some CAN records received from PCAN-USB could define a DLC field in range [9..15]. In that case, the real DLC value MUST be used to move forward the record pointer but, only 8 bytes max. MUST be copied into the data field of the struct can_frame object of the skb given to the network core. Signed-off-by: Stephane Grosjean <s.grosjean@peak-system.com> Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-20iwl4965: reset firmware after rfkill offStanislaw Gruszka
commit 788f7a56fce1bcb2067b62b851a086fca48a0056 upstream. Using rfkill switch can make firmware unstable, what cause various Microcode errors and kernel warnings. Reseting firmware just after rfkill off (radio on) helped with that. Resolve: https://bugzilla.redhat.com/show_bug.cgi?id=977053 Reported-and-tested-by: Justin Pearce <whitefox@guardianfox.net> Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-20iwl4965: set power mode earlyStanislaw Gruszka
commit eca396d7a5bdcc1fd67b1b12f737c213ac78a6f4 upstream. If device was put into a sleep and system was restarted or module reloaded, we have to wake device up before sending other commands. Otherwise it will fail to start with Microcode error. Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-20md/raid1,raid10: use freeze_array in place of raise_barrier in various places.NeilBrown
commit e2d59925221cd562e07fee38ec8839f7209ae603 upstream. Various places in raid1 and raid10 are calling raise_barrier when they really should call freeze_array. The former is only intended to be called from "make_request". The later has extra checks for 'nr_queued' and makes a call to flush_pending_writes(), so it is safe to call it from within the management thread. Using raise_barrier will sometimes deadlock. Using freeze_array should not. As 'freeze_array' currently expects one request to be pending (in handle_read_error - the only previous caller), we need to pass it the number of pending requests (extra) to ignore. The deadlock was made particularly noticeable by commits 050b66152f87c7 (raid10) and 6b740b8d79252f13 (raid1) which appeared in 3.4, so the fix is appropriate for any -stable kernel since then. This patch probably won't apply directly to some early kernels and will need to be applied by hand. Cc: stable@vger.kernel.org Reported-by: Alexander Lyakas <alex.bolshoy@gmail.com> Signed-off-by: NeilBrown <neilb@suse.de> [adjust context to make it can be apply on top of 3.4 ] Signed-off-by: Jack Wang <jinpu.wang@profitbricks.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-20HID: microsoft: do not use compound literal - fix buildJiri Slaby
commit 6b90466cfec2a2fe027187d675d8d14217c12d82 upstream. In patch "HID: microsoft: fix invalid rdesc for 3k kbd" I fixed support for MS 3k keyboards. However the added check using memcmp and a compound statement breaks build on architectures where memcmp is a macro with parameters. hid-microsoft.c:51:18: error: macro "memcmp" passed 6 arguments, but takes just 3 On x86_64, memcmp is a function, so I did not see the error. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Reported-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Cc: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-20drm/i915/lvds: ditch ->prepare special caseDaniel Vetter
commit 520c41cf2fa029d1e8b923ac2026f96664f17c4b upstream. LVDS is the first output where dpms on/off and prepare/commit don't perfectly match. Now the idea behind this special case seems to be that for simple resolution changes on the LVDS we don't need to stop the pipe, because (at least on newer chips) we can adjust the panel fitter on the fly. There are a few problems with the current code though: - We still stop and restart the pipe unconditionally, because the crtc helper code isn't flexible enough. - We show some ugly flickering, especially when changing crtcs (this the crtc helper would actually take into account, but we don't implement the encoder->get_crtc callback required to make this work properly). So it doesn't even work as advertised. I agree that it would be nice to do resolution changes on LVDS (and also eDP) whithout blacking the screen where the panel fitter allows to do that. But imo we should implement this as a special case a few layers up in the mode set code, akin to how we already detect simple framebuffer changes (and only update the required registers with ->mode_set_base). Until this is all in place, make our lives easier and just rip it out. Also note that this seems to fix actual bugs with enabling the lvds output, see: http://lists.freedesktop.org/archives/intel-gfx/2012-July/018614.html Acked-by: Chris Wilson <chris@chris-wilson.co.uk> Cc: Takashi Iwai <tiwai@suse.de> Cc: Giacomo Comes <comes@naic.edu> Tested-by: Takashi Iwai <tiwai@suse.de> Signed-Off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Cc: Haitao Zhang <haitao.zhang@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-14SCSI: nsp32: use mdelay instead of large udelay constantsArnd Bergmann
commit b497ceb964a80ebada3b9b3cea4261409039e25a upstream. ARM cannot handle udelay for more than 2 miliseconds, so we should use mdelay instead for those. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: GOTO Masanori <gotom@debian.or.jp> Cc: YOKOTA Hiroshi <yokota@netlab.is.tsukuba.ac.jp> Cc: "James E.J. Bottomley" <JBottomley@parallels.com> Cc: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-14usb: core: don't try to reset_device() a port that got just disconnectedJulius Werner
commit 481f2d4f89f87a0baa26147f323380e31cfa7c44 upstream. The USB hub driver's event handler contains a check to catch SuperSpeed devices that transitioned into the SS.Inactive state and tries to fix them with a reset. It decides whether to do a plain hub port reset or call the usb_reset_device() function based on whether there was a device attached to the port. However, there are device/hub combinations (found with a JetFlash Transcend mass storage stick (8564:1000) on the root hub of an Intel LynxPoint PCH) which can transition to the SS.Inactive state on disconnect (and stay there long enough for the host to notice). In this case, above-mentioned reset check will call usb_reset_device() on the stale device data structure. The kernel will send pointless LPM control messages to the no longer connected device address and can even cause several 5 second khubd stalls on some (buggy?) host controllers, before finally accepting the device's fate amongst a flurry of error messages. This patch makes the choice of reset dependent on the port status that has just been read from the hub in addition to the existence of an in-kernel data structure for the device, and only proceeds with the more extensive reset if both are valid. Signed-off-by: Julius Werner <jwerner@chromium.org> Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-14virtio: console: return -ENODEV on all read operations after unplugAmit Shah
commit 96f97a83910cdb9d89d127c5ee523f8fc040a804 upstream. If a port gets unplugged while a user is blocked on read(), -ENODEV is returned. However, subsequent read()s returned 0, indicating there's no host-side connection (but not indicating the device went away). This also happened when a port was unplugged and the user didn't have any blocking operation pending. If the user didn't monitor the SIGIO signal, they won't have a chance to find out if the port went away. Fix by returning -ENODEV on all read()s after the port gets unplugged. write() already behaves this way. Signed-off-by: Amit Shah <amit.shah@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-14virtio: console: fix raising SIGIO after port unplugAmit Shah
commit 92d3453815fbe74d539c86b60dab39ecdf01bb99 upstream. SIGIO should be sent when a port gets unplugged. It should only be sent to prcesses that have the port opened, and have asked for SIGIO to be delivered. We were clearing out guest_connected before calling send_sigio_to_port(), resulting in a sigio not getting sent to processes. Fix by setting guest_connected to false after invoking the sigio function. Signed-off-by: Amit Shah <amit.shah@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-14virtio: console: clean up port data immediately at time of unplugAmit Shah
commit ea3768b4386a8d1790f4cc9a35de4f55b92d6442 upstream. We used to keep the port's char device structs and the /sys entries around till the last reference to the port was dropped. This is actually unnecessary, and resulted in buggy behaviour: 1. Open port in guest 2. Hot-unplug port 3. Hot-plug a port with the same 'name' property as the unplugged one This resulted in hot-plug being unsuccessful, as a port with the same name already exists (even though it was unplugged). This behaviour resulted in a warning message like this one: -------------------8<--------------------------------------- WARNING: at fs/sysfs/dir.c:512 sysfs_add_one+0xc9/0x130() (Not tainted) Hardware name: KVM sysfs: cannot create duplicate filename '/devices/pci0000:00/0000:00:04.0/virtio0/virtio-ports/vport0p1' Call Trace: [<ffffffff8106b607>] ? warn_slowpath_common+0x87/0xc0 [<ffffffff8106b6f6>] ? warn_slowpath_fmt+0x46/0x50 [<ffffffff811f2319>] ? sysfs_add_one+0xc9/0x130 [<ffffffff811f23e8>] ? create_dir+0x68/0xb0 [<ffffffff811f2469>] ? sysfs_create_dir+0x39/0x50 [<ffffffff81273129>] ? kobject_add_internal+0xb9/0x260 [<ffffffff812733d8>] ? kobject_add_varg+0x38/0x60 [<ffffffff812734b4>] ? kobject_add+0x44/0x70 [<ffffffff81349de4>] ? get_device_parent+0xf4/0x1d0 [<ffffffff8134b389>] ? device_add+0xc9/0x650 -------------------8<--------------------------------------- Instead of relying on guest applications to release all references to the ports, we should go ahead and unregister the port from all the core layers. Any open/read calls on the port will then just return errors, and an unplug/plug operation on the host will succeed as expected. This also caused buggy behaviour in case of the device removal (not just a port): when the device was removed (which means all ports on that device are removed automatically as well), the ports with active users would clean up only when the last references were dropped -- and it would be too late then to be referencing char device pointers, resulting in oopses: -------------------8<--------------------------------------- PID: 6162 TASK: ffff8801147ad500 CPU: 0 COMMAND: "cat" #0 [ffff88011b9d5a90] machine_kexec at ffffffff8103232b #1 [ffff88011b9d5af0] crash_kexec at ffffffff810b9322 #2 [ffff88011b9d5bc0] oops_end at ffffffff814f4a50 #3 [ffff88011b9d5bf0] die at ffffffff8100f26b #4 [ffff88011b9d5c20] do_general_protection at ffffffff814f45e2 #5 [ffff88011b9d5c50] general_protection at ffffffff814f3db5 [exception RIP: strlen+2] RIP: ffffffff81272ae2 RSP: ffff88011b9d5d00 RFLAGS: 00010246 RAX: 0000000000000000 RBX: ffff880118901c18 RCX: 0000000000000000 RDX: ffff88011799982c RSI: 00000000000000d0 RDI: 3a303030302f3030 RBP: ffff88011b9d5d38 R8: 0000000000000006 R9: ffffffffa0134500 R10: 0000000000001000 R11: 0000000000001000 R12: ffff880117a1cc10 R13: 00000000000000d0 R14: 0000000000000017 R15: ffffffff81aff700 ORIG_RAX: ffffffffffffffff CS: 0010 SS: 0018 #6 [ffff88011b9d5d00] kobject_get_path at ffffffff8126dc5d #7 [ffff88011b9d5d40] kobject_uevent_env at ffffffff8126e551 #8 [ffff88011b9d5dd0] kobject_uevent at ffffffff8126e9eb #9 [ffff88011b9d5de0] device_del at ffffffff813440c7 -------------------8<--------------------------------------- So clean up when we have all the context, and all that's left to do when the references to the port have dropped is to free up the port struct itself. Reported-by: chayang <chayang@redhat.com> Reported-by: YOGANANTH SUBRAMANIAN <anantyog@in.ibm.com> Reported-by: FuXiangChun <xfu@redhat.com> Reported-by: Qunfang Zhang <qzhang@redhat.com> Reported-by: Sibiao Luo <sluo@redhat.com> Signed-off-by: Amit Shah <amit.shah@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-14virtio: console: fix race in port_fops_open() and port unplugAmit Shah
commit 671bdea2b9f210566610603ecbb6584c8a201c8c upstream. Between open() being called and processed, the port can be unplugged. Check if this happened, and bail out. A simple test script to reproduce this is: while true; do for i in $(seq 1 100); do echo $i > /dev/vport0p3; done; done; This opens and closes the port a lot of times; unplugging the port while this is happening triggers the bug. Signed-off-by: Amit Shah <amit.shah@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-14virtio: console: fix race with port unplug and open/closeAmit Shah
commit 057b82be3ca3d066478e43b162fc082930a746c9 upstream. There's a window between find_port_by_devt() returning a port and us taking a kref on the port, where the port could get unplugged. Fix it by taking the reference in find_port_by_devt() itself. Problem reported and analyzed by Mateusz Guzik. Reported-by: Mateusz Guzik <mguzik@redhat.com> Signed-off-by: Amit Shah <amit.shah@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-14hwmon: (adt7470) Fix incorrect return code checkCurt Brune
commit 93d783bcca69bfacc8dc739d8a050498402587b5 upstream. In adt7470_write_word_data(), which writes two bytes using i2c_smbus_write_byte_data(), the return codes are incorrectly AND-ed together when they should be OR-ed together. The return code of i2c_smbus_write_byte_data() is zero for success. The upshot is only the first byte was ever written to the hardware. The 2nd byte was never written out. I noticed that trying to set the fan speed limits was not working correctly on my system. Setting the fan speed limits is the only code that uses adt7470_write_word_data(). After making the change the limit settings work and the alarms work also. Signed-off-by: Curt Brune <curt@cumulusnetworks.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-14SCSI: megaraid_sas: megaraid_sas driver init fails in kdump kernelSumit.Saxena@lsi.com
commit 6431f5d7c6025f8b007af06ea090de308f7e6881 upstream. Problem: When Hardware IOMMU is on, megaraid_sas driver initialization fails in kdump kernel with LSI MegaRAID controller(device id-0x73). Actually this issue needs fix in firmware, but for firmware running in field, this driver fix is proposed to resolve the issue. At firmware initialization time, if firmware does not come to ready state, driver will reset the adapter and retry for firmware transition to ready state unconditionally(not only executed for kdump kernel). Signed-off-by: Sumit Saxena <sumit.saxena@lsi.com> Signed-off-by: Kashyap Desai <kashyap.desai@lsi.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-14SCSI: Don't attempt to send extended INQUIRY command if skip_vpd_pages is setMartin K. Petersen
commit 7562523e84ddc742fe1f9db8bd76b01acca89f6b upstream. If a device has the skip_vpd_pages flag set we should simply fail the scsi_get_vpd_page() call. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Tested-by: Stuart Foster <smf.linux@ntlworld.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-118139cp: Add dma_mapping_error checkingNeil Horman
[ Upstream commit cf3c4c03060b688cbc389ebc5065ebcce5653e96 ] Self explanitory dma_mapping_error addition to the 8139 driver, based on this: https://bugzilla.redhat.com/show_bug.cgi?id=947250 It showed several backtraces arising for dma_map_* usage without checking the return code on the mapping. Add the check and abort the rx/tx operation if its failed. Untested as I have no hardware and the reporter has wandered off, but seems pretty straightforward. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> CC: "David S. Miller" <davem@davemloft.net> CC: Francois Romieu <romieu@fr.zoreil.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-11usbnet: do not pretend to support SG/TSOEric Dumazet
[ Upstream commit 20f0170377264e8449b6987041f0bcc4d746d3ed ] usbnet doesn't support yet SG, so drivers should not advertise SG or TSO capabilities, as they allow TCP stack to build large TSO packets that need to be linearized and might use order-5 pages. This adds an extra copy overhead and possible allocation failures. Current code ignore skb_linearize() return code so crashes are even possible. Best is to not pretend SG/TSO is supported, and add this again when/if usbnet really supports SG for devices who could get a performance gain. Based on a prior patch from Freddy Xin <freddy@asix.com.tw> Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-11arcnet: cleanup sizeof parameterDan Carpenter
[ Upstream commit 087d273caf4f7d3f2159256f255f1f432bc84a5b ] This patch doesn't change the compiled code because ARC_HDR_SIZE is 4 and sizeof(int) is 4, but the intent was to use the header size and not the sizeof the header size. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-11drm/i915: quirk no PCH_PWM_ENABLE for Dell XPS13 backlightKamal Mostafa
commit e85843bec6c2ea7c10ec61238396891cc2b753a9 upstream. BugLink: https://bugzilla.kernel.org/show_bug.cgi?id=47941 BugLink: https://bugs.launchpad.net/bugs/1163720 BugLink: https://bugs.launchpad.net/bugs/1162026 Some machines suffer from non-functional backlight controls if BLM_PCH_PWM_ENABLE is set, so provide a quirk to avoid doing so. Apply this quirk to Dell XPS 13 models. [ kamal: backport to 3.4 ] Tested-by: Eric Griffith <EGriffith92@gmail.com> Tested-by: Kent Baxley <kent.baxley@canonical.com> Signed-off-by: Kamal Mostafa <kamal@canonical.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-11ACPI / battery: Fix parsing _BIX return valueLan Tianyu
commit 016d5baad04269e8559332df05f89bd95b52d6ad upstream. The _BIX method returns extended battery info as a package. According the ACPI spec (ACPI 5, Section 10.2.2.2), the first member of that package should be "Revision". However, the current ACPI battery driver treats the first member as "Power Unit" which should be the second member. This causes the result of _BIX return data parsing to be incorrect. Fix this by adding a new member called 'revision' to struct acpi_battery and adding the offsetof() information on it to extended_info_offsets[] as the first row. [rjw: Changelog] Reported-and-tested-by: Jan Hoffmann <jan.christian.hoffmann@gmail.com> References: http://bugzilla.kernel.org/show_bug.cgi?id=60519 Signed-off-by: Lan Tianyu <tianyu.lan@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-11mwifiex: Add missing endian conversion.Tomasz Moń
commit 83e612f632c3897be29ef02e0472f6d63e258378 upstream. Both type and pkt_len variables are in host endian and these should be in Little Endian in the payload. Signed-off-by: Tomasz Moń <desowin@gmail.com> Acked-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-11rt2x00: fix stop queueStanislaw Gruszka
commit e2288b66fe7ff0288382b2af671b4da558b44472 upstream. Since we clear QUEUE_STARTED in rt2x00queue_stop_queue(), following call to rt2x00queue_pause_queue() reduce to noop, i.e we do not stop queue in mac80211. To fix that introduce rt2x00queue_pause_queue_nocheck() function, which will stop queue in mac80211 directly. Note that rt2x00_start_queue() explicitly set QUEUE_PAUSED bit. Note also that reordering operations i.e. first call to rt2x00queue_pause_queue() and then clear QUEUE_STARTED bit, will race with rt2x00queue_unpause_queue(), so calling ieee80211_stop_queue() directly is the only available solution to fix the problem without major rework. Signed-off-by: Stanislaw Gruszka <stf_xl@wp.pl> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-11ixgbe: Fix Tx Hang issue with lldpad on 82598EBJacob Keller
commit 1eb9ac14c34a948bf1538bfb9034e8ab29099a64 upstream. This patch fixes an issue with the 82598EB device, where lldpad is causing Tx Hangs on the card as soon as it attempts to configure DCB for the device. The adapter will continually Tx hang and reset in a loop. Signed-off-by: Jacob Keller <jacob.e.keller@intel.com> Tested-by: Phil Schmitt <phillip.j.schmitt@intel.com> Tested-by: Jack Morgan <jack.morgan@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-11ath9k_htc: do some initial hardware configurationOleksij Rempel
commit dc2a87f519a4d8cb376ab54f22b6b98a943b51ce upstream. Currently we configure harwdare and clock, only after interface start. In this case, if we reload module or reboot PC without configuring adapter, firmware will freeze. There is no software way to reset adpter. This patch add initial configuration and set it in disabled state, to avoid this freeze. Behaviour of this patch should be similar to: ifconfig wlan0 up; ifconfig wlan0 down. Bug: https://github.com/qca/open-ath9k-htc-firmware/issues/1 Tested-by: Bo Shi <cnshibo@gmail.com> Signed-off-by: Oleksij Rempel <linux@rempel-privat.de> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-11serial/mxs-auart: increase time to wait for transmitter to become idleUwe Kleine-König
commit 079a036f4283e2b0e5c26080b8c5112bc0cc1831 upstream. Without this patch the driver waits ~1 ms for the UART to become idle. At 115200n8 this time is (theoretically) enough to transfer 11.5 characters (= 115200 bits/s / (10 Bits/char) * 1ms). As the mxs-auart has a fifo size of 16 characters the clock is gated too early. The problem is worse for lower baud rates. This only happens to really shut down the transmitter in the middle of a transfer if /dev/ttyAPPx isn't opened in userspace (e.g. by a getty) but was at least once (because the bootloader doesn't disable the transmitter). So increase the timeout to 20 ms which should be enough for 9600n8, too. Moreover skip gating the clock if the timeout is elapsed. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
