Calculate height based on the slice bitfield rather than the size.
Same as Dave's CB fix.
Signed-off-by: Alex Deucher <alexdeucher@gmail.com>
There are cases when multiple texture units have to be enabled,
but not actually used to sample. This patch checks to see if
the lookup_disable bit is set and if so, skips the texture check.
Fixes:
https://bugs.freedesktop.org/show_bug.cgi?id=25544
Cc: stable@kernel.org
Use Ben's new range manager hooks to implement a manager for
GMRs that manages ids rather than ranges.
This means we can use the standard TTM code for binding, unbinding and
eviction.
Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com>
broken by:
drm/radeon/r600: fix tiling issues in CS checker.
v2: only apply it to 1D tiling case.
Needed for tiled surfaces.
macro tile heights are aligned to num channels, not num banks.
Noticed by Dave Airlie.
The hw stores a default clear state for registers in the context
range that can be initialized when the CP is set up. Set the
blit state as the default clear state and use the CLEAR_STATE
packet to load the blit state rather than loading it from an IB.
This reduces overhead when doing bo moves using the 3D engine.
This is slightly destructive, cpu intensive and can cause lockups.
Currently, there have no GMA500(Poulsbo) native video driver to support
intel opregion. So, use this stub driver to enable the acpi backlight
control sysfs entry files by requrest acpi_video_register.
[airlied: fix warnings]
Signed-off-by: Lee, Chun-Yi <jlee@novell.com>
The vram map in the radeon memory controller needs to be
>= the pci aperture size. Fixes:
https://bugs.freedesktop.org/show_bug.cgi?id=28402
The problematic cards in the above bug have 64 MB of vram,
but the pci aperture is 128 MB and the MC vram map was only
64 MB. This can lead to hangs.
Improper display watermarks can result in underflow to the display
controllers which can cause flickering or other artifacts.
This patch implements display watermark support and line buffer
allocation for evergreen asics.
These are needed for enabling dynamic GPR allocation in the shaders
in the userspace acceleration drivers.
v2: fix typo in reg name
The CS checker had some incorrect alignment requirements for 2D surfaces,
this made rendering to mipmap levels that were 2D broken.
Also the CB height was being worked out from the BO size, this doesn't work
at all when rendering mipmap levels, instead we work out what height userspace
wanted from slice max and use that to check it fits inside the BO, however
the DDX send the wrong slice max for an unaligned buffer so we have to workaround
for that even though its a userspace bug.
Reviewed-by: Alex Deucher <alexdeucher@gmail.com>
* 'intel/drm-intel-next' of ../drm-next: (63 commits)
drm/i915: Move gpu_write_list to per-ring
drm/i915: Invalidate the to-ring, flush the old-ring when updating domains
drm/i915/ringbuffer: Write the value passed in to the tail register
agp/intel: Restore valid PTE bit for Sandybridge after bdd3072
drm/i915: Fix flushing regression from 9af90d19f
drm/i915/sdvo: Remove unused encoding member
i915: enable AVI infoframe for intel_hdmi.c [v4]
drm/i915: Fix current fb blocking for page flip
drm/i915: IS_IRONLAKE is synonymous with gen == 5
drm/i915: Enable SandyBridge blitter ring
drm/i915/ringbuffer: Remove broken intel_fill_struct()
drm/i915/ringbuffer: Fix emit batch buffer regression from 8187a2b
drm/i915: Copy the updated reloc->presumed_offset back to the user
drm/i915: Track objects in global active list (as well as per-ring)
drm/i915: Simplify most HAS_BSD() checks
drm/i915: cache the last object lookup during pin_and_relocate()
drm/i915: Do interrupible mutex lock first to avoid locking for unreference
drivers: gpu: drm: i915: Fix a typo.
agp/intel: Also add B43.1 to list of supported devices
drm/i915: rearrange mutex acquisition for pread
... to prevent flush processing of an idle (or even absent) ring.
This fixes a regression during suspend from 87acb0a5.
Reported-and-tested-by: Alexey Fisher <bug-track@fisher-privat.net>
Tested-by: Peter Clifton <pcjc2@cam.ac.uk>
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
When the object has been written to by the gpu it remains on the ring
until its flush has been retired. However, when the object is moving to
the ring and the associated cache needs to be invalidated, we need to
perform the flush on the target ring, not the one it came from (which is
NULL in the reported case and so the flush was entirely absent).
Reported-by: Peter Clifton <pcjc2@cam.ac.uk>
This should fix the error along the reset path were we tried to clear the
tail register by setting it to 0, but were in fact setting it to the
current value and complaining when it did not reset to 0.
In cleaning up the mask functions in bdd3072, the setting of the PTE
valid bit was dropped for Sandybridge.
Whilst moving the code around in 9af90d19f, I dropped the or'ing in of
new write domains which would zero out the write domain for a render
target if later reused as a source later in the batch. This meant that
we might drop a required flush before reading from the render target.
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=31043
Reported-by: xunx.fang@intel.com
This block is only used when detecting whether the connector is HDMI and
never again, so scope the variable to the detection routine.
This patch enables the sending of AVI infoframes in
drivers/gpu/drm/i915/intel_hdmi.c.
My receiver currently loses sync when the HDMI output on my computer
(DG45FC motherboard) is switched from 800x600 (the BIOS resolution) to
1920x1080 as part of the boot. Fixable by switching inputs on the receiver
a couple of times.
With this patch, my receiver has not lost sync yet (> 40 tries).
Fourth version, now based on drm-intel-next from:
git://git.kernel.org/pub/scm/linux/kernel/git/ickle/drm-intel.git
Two questions still remain:
I'm assuming that the sdvo hardware also stores a header ECC byte in
the MSB of the first dword - is this correct?
Does the SDVOB and SDVOC handling in intel_hdmi_set_avi_infoframe()
look correct?
Signed-off-by: David Härdeman <david@hardeman.nu>
Block execbuffer for the fb to be flipped away, not the one that is to
be flipped in.
[ickle: rewritten for -next]
Signed-off-by: Chia-I Wu <olvaffe@gmail.com>
Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Acked-by: Kristian Høgsberg <krh@bitplanet.net>
So remove the redundant bit in the capabilities block and
s/IS_IRONLAKE/IS_GEN5/.
Based on an original patch by Zhenyu Wang, this initializes the BLT ring for
SandyBridge and enables support for user execbuffers.
Cc: Zhenyu Wang <zhenyuw@linux.intel.com>
... before someone tries to use it. The code both calls
intel_ring_begin/advance() and open-codes the bookkeeping performed by
those two functions.
In commit 8187a2b, the number of dwords used in the ringbuffer for
executing the batch buffer was erroneously changed from 2 to 4.
This commit replaces the ttm_bo_cleanup_ref function with two new functions.
One for the case where the bo is not yet on the delayed destroy list, and
one for the case where the bo was on the delayed destroy list, at least at
the time of call. This makes it possible to optimize the two cases somewhat.
It also enables the possibility to directly destroy buffers on the
delayed delete list when they are about to be evicted or swapped out.
Currently they were only evicted / swapped and destruction was left for the
delayed buffer destruction thread.
Release the lru spinlock early.
If the userspace driver is using a constant relocation array with a
static buffer, they will pass the same relocation array back to the
kernel. So we *do* need to update the presumed offset value in those
relocations to reflect the current object so that they remain correct
with future batchbuffers and we avoid the necessity of having to suspend
execution and perform redundant relocations.
Fixes the regression introduced by 12f889c for applications using
absolute addressing on trees of buffer (i.e. the current consumers of
libdrm_intel.so).
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=30996
Reported-by: Wang, Jinjin <jinjin.wang@intel.com>
To handle retirements, we need per-ring tracking of active objects.
To handle evictions, we need global tracking of active objects.
As we enable more rings, rebuilding the global list from the individual
per-ring lists quickly grows tiresome and overly complicated. Tracking the
active objects in two lists is the lesser of two evils.
... by always initialising the empty ringbuffer it is always then safe
to check whether it is active.
The most frequent relocation within a batchbuffer is a contiguous sequence
of vertex buffer relocations, for which we can virtually eliminate the
drm_gem_object_lookup() overhead by caching the last handle to object
translation.
In doing so we refactor the pin and relocate retry loop out of
do_execbuffer into its own helper function and so improve the error
paths.
One of the primarily consumers of the i915 driver is X, a large signal
driven application. Frequently when writing into the buffers, there is a
pending signal which causes us not to take the interruptible lock but
then we need to take that same lock around the object unreference. By
rearranging the code to do the interruptible lock as the first check, we
can avoid the frequent additional locking around the unreference.
"userpace" -> "userspace"
Signed-off-by: Andrea Gelmini <andrea.gelmini@gelma.net>
This was a missing piece from 41a5142 that dropped recognition of the
AGP module for the second B43 variant.
Reported-by: Stefan Bader <stefan.bader@canonical.com>
... to avoid the double acquisition along fast[er] paths.
... to avoid reacquiring it to drop the object reference count on
exit. Note we have to make sure we now drop (and reacquire) the lock
around acquiring the mm semaphore on the slow paths.
... in the hope that it makes the atomic fast paths more likely.
After allocation a handle for the fresh object, we know that we can
safely drop the refcnt without triggering a free so we do not need the
mutex. Strangely, this mutex acquisition is the one that appears on
driver profiles.
Avoid an early eviction of the batch buffer into the uncached GTT
domain, and so do the relocation fixup in cacheable memory.
... perform an access validation check up front instead and copy them in
on-demand, during i915_gem_object_pin_and_relocate(). As around 20% of
the CPU overhead may be spent inside vmalloc for the relocation entries
when submitting an execbuffer [for x11perf -aa10text], the savings are
considerable and result in around a 10% throughput increase [for glyphs].
Allow the user to override the detection of the sink's audio capabilities
from EDID. Not all sinks support the required EDID level to specify
whether they handle audio over the display connection, so allow the user
to enable it manually.
Rely on monitor's audio capability to turn on audio output for HDMI.
Tested-by: Wu Fengguang <fengguang.wu@intel.com>
Signed-off-by: Zhenyu Wang <zhenyuw@linux.intel.com>
This will turn on DP audio output by checking monitor's audio
capability.
[ickle: rebase onto recent changes and rearranged for clarity]
To help to determine if digital display port needs to enable
audio output or not. This one adds a helper to get monitor's
audio capability via EDID CEA extension block.
Reviewed-by: Adam Jackson <ajax@redhat.com>
The time between start of the pixel clock and backlight enable is a basic
panel timing constraint. If the Panel Power On/Off registers are found
to be 0, assume we are booting without VBIOS initialization and set these
registers to something reasonable.
Change-Id: Ibed6cc10d46bf52fd92e0beb25ae3525b5eef99d
Signed-off-by: Bryan Freed <bfreed@chromium.org>
[ickle: rearranged into a separate function to distinguish its role from
simply parsing the VBIOS tables.]
If userspace is submitting so many long running batches that the ring
becomes full, throttle by sleeping for a 1ms before checking for free
space. Simply yielding was causing excessive scheduler overhead whilst
making no progress.
In i2c GPIO fallback, index 6 is reserved for nothing.
