path: root/drivers
2012-02-13drm/radeon/kms: add support for streamout v7Marek Olšák
v2: agd5f: add strmout CS checking, copy_dw register checking v3: agd5f: don't use cs_check_reg() for copy_dw checking as it will incorrectly patch the command stream for certain regs. v4: agd5f: add warning if safe reg check fails for copy_dw v5: agd5f: add stricter checking for 6xx/7xx v6: agd5f: add range checking for copy_dw on eg+, add sx_surface_sync to safe reg list for 7xx. v7: agd5f: add stricter checking for eg+ Signed-off-by: Marek Olšák <maraeo@gmail.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-02-13drm: Fix kcalloc parameters swappedAxel Lin
The first parameter should be "number of elements" and the second parameter should be "element size". Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-02-13drm/vmwgfx: Bump driver minorThomas Hellstrom
Bump driver minor to signal availability of the page-flip ioctl. Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-02-13vmwgfx: Move function declaration to correct headerThomas Hellstrom
Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com> Reviewed-by: Jakob Bornecrantz <jakob@vmware.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-02-13drm/vmwgfx: Treat out-of-range initial width and height as host errorsThomas Hellstrom
And assign the initial width and height to the minimum in that case. Strange values (-1) from these registers have been reported by users. Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com> Reviewed-by: Jakob Bornecrantz <jakob@vmware.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-02-13vmwgfx: Pick up the initial size from the width and height regsJakob Bornecrantz
Signed-off-by: Jakob Bornecrantz <jakob@vmware.com> Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-02-13vmwgfx: Add page flip supportJakob Bornecrantz
Signed-off-by: Jakob Bornecrantz <jakob@vmware.com> Reviewed-by: Thomas Hellstrom <thellstrom@vmware.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-02-13vmwgfx: Pipe fence out of screen object dirty functionsJakob Bornecrantz
2012-02-13vmwgfx: Make it possible to get fence from execbufJakob Bornecrantz
2012-02-13vmwgfx: Clean up pending event references to struct drm_file objects on closeThomas Hellstrom
Pending events may have stale pointer references to struct drm_file objects after a file has been closed, but before the event is supposed to be attached to the drm file. Remove such events on file close. Tested with "modetest". Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com> Reviewed-by: Jakob Bornecrantz <jakob@vmware.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-02-13vmwgfx: Rework fence event actionJakob Bornecrantz
2012-02-13drm/modes: do not enforce an odd vtotal for interlaced modesDaniel Vetter
CEA actually specifies an interlaced mode with even vtotal and supplies a diagram showing how this is supposed to work. Note that interlaced modes with an even vtotal seem to be a fairly recent invention. All modelines lore I could dig up with googling says that vtotal for interlaced modes _needs_ to be odd. But the even modelines in CEA are not a spec-bug, there's a figure in CEA-861-E called "Figure 5 Special Interlaced Video Format Timing (Even Vtotal)" that explains how it's supposed to work. Furthermore intel Bspec explicitly mentions that both odd and even interlaced vtotal are supported (VTOTAL register in the south display engine of PCH split chips). Acked-by: Adam Jackson <ajax@redhat.com> Signed-Off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-02-09drm: do not set fb_info->pixmap fieldsSascha Hauer
The drm drivers set the fb_info->pixmap fields without setting fb_info->pixmap.addr. If this is not set the fb core will overwrite these all fb_info->pixmap fields anyway, so there is not much point in setting them in the first place. [airlied: dropped nvidiafb piece - not mine] Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-02-09drm: add convenience function to create an range propertySascha Hauer
Creating a range property is a common pattern, so create a convenience function for this and use it where appropriate. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-02-09drm: add convenience function to create an enum propertySascha Hauer
Creating an enum property is a common pattern, so create a convenience function for this and use it where appropriate. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-02-07Merge branch 'for-airlied' of git://people.freedesktop.org/~danvet/drm-intel ↵Dave Airlie
into drm-core-next * 'for-airlied' of git://people.freedesktop.org/~danvet/drm-intel: drm/i915: add a LLC feature flag in device description drm/i915: kill i915_mem.c drm/i915: Use kcalloc instead of kzalloc to allocate array drm/i915/dp: Check for AUXCH error before checking for success drm/i915/dp: Use auxch precharge value of 5 everywhere drm/i915/dp: Tweak auxch clock divider for PCH drm/i915: Remove a comment about PCH from the non-PCH path drm/i915: Fix assert_pch_hdmi_disabled to mention HDMI (not DP) drm/i915: Implement plane-disabled assertion for PCH too drivers: i915: Fix BLC PWM register setup drm/i915: Check that plane/pipe is disabled before removing the fb drm/i915: fix typo in function name drm/i915: split out pll divider code drm/i915: split 9xx refclk & sdvo tv code out agp/intel: Add pci id for hostbridge from has/qemu drm/i915: there is no pipe CxSR on ironlake drm/i915: Only look for matching clocks for LVDS downclock drm/i915: Silence _DSM errors
2012-02-03drm exynos: use drm_fb_helper_set_par directlySascha Hauer
info->fix.visual already is correctly set from drm_fb_helper_fill_fix. info->fix.line_length is also set from drm_fb_helper_fill_fix, so drm_fb_helper_set_par directly instead of a custom exynos_drm_fbdev_set_par. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Tested-by: Inki Dae <inki.dae@samsung.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-02-03drm crtc_helper: use list_for_each_entrySascha Hauer
list_for_each_entry_safe is for walking a list safe against removal of entries. Here, no entries are removed, so use list_for_each_entry. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-02-03drm crtc: Fix locking commentsSascha Hauer
Several comments above functions say that the caller must hold the mode_config lock, but the functions take the lock themselves. Fix the comments. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-02-03drm fb helper: remove unused variable crtc_idSascha Hauer
crtc_id is set but never used, so remove it from struct drm_fb_helper_crtc. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-02-03drm fb helper: remove unused variable conn_limitSascha Hauer
conn_limit is set but never used. Remove it from struct drm_fb_helper. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-02-03drm fb helper: use drm_helper_connector_dpms to do dpmsSascha Hauer
drm_fb_helper_on|off currently manually searches for encoders to turn on/off. Make this simpler by using the helper function. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-02-03drm: add proper return value for drm_mode_crtc_set_gamma_sizeSascha Hauer
drm_mode_crtc_set_gamma_size returns boolean true for success and false for failure. This is not very kernel conform, so change it to return 0 for success and a propert error code otherwise. Noone checks the return value, so no users have to be fixed. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-02-03drm drm_fb_helper: destroy modesSascha Hauer
drm_setup_crtcs allocated modes using drm_mode_duplicate. Free them in drm_fb_helper_crtc_free. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-02-03drm crtc: use drm_mode_destroy instead of kfree in drm_mode_removeSascha Hauer
Modes are created using drm_mode_create which does a drm_mode_object_get, so use drm_mode_destroy in drm_mode_remove which does a drm_mode_object_put. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-02-03drm/edid: drm modes have to be free with drm_mode_destroySascha Hauer
to add the missing drm_mode_object_put for that mode. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-02-03drm crtc: add forgotten idr cleanup functionsSascha Hauer
drm_mode_config_init initializes the idr with idr_init, so add the missing counterparts in drm_mode_config_cleanup. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-02-03drm/radeon/kms: add r1xx/r2xx CS support for tiled texturesAlex Deucher
Not likely this will be implemented anytime soon, but for completeness... Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-02-03drm/radeon/kms: add r1xx/r2xx support for CS_KEEP_TILING_FLAGSAlex Deucher
Previous patch only updates r3xx+. It's not likely anyone will use this on r1xx/r2xx, but add it for consistency. Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-02-03drm: give up on edid retries when i2c bus is not respondingEugeni Dodonov
This allows to avoid talking to a non-responding bus repeatedly until we finally timeout after 15 attempts. We can do this by catching the -ENXIO error, provided by i2c_algo_bit:bit_doAddress call. Within the bit_doAddress we already try 3 times to get the edid data, so if the routine tells us that bus is not responding, it is mostly pointless to keep re-trying those attempts over and over again until we reach final number of retries. This change should fix https://bugs.freedesktop.org/show_bug.cgi?id=41059 and improve overall edid detection timing by 10-30% in most cases, and by a much larger margin in case of phantom outputs (up to 30x in one worst case). Timing results for i915-powered machines for 'time xrandr' command: Machine 1: from 0.840s to 0.290s Machine 2: from 0.315s to 0.280s Machine 3: from +/- 4s to 0.184s Timing results for HD5770 with 'time xrandr' command: Machine 4: from 3.210s to 1.060s Reviewed-by: Chris Wilson <chris@hchris-wilson.co.uk> Reviewed-by: Keith Packard <keithp@keithp.com> Tested-by: Sean Finney <seanius@seanius.net> Tested-by: Soren Hansen <soren@linux2go.dk> Tested-by: Hernando Torque <sirius@sonnenkinder.org> Tested-by: Mike Lothian <mike@fireburn.co.uk> Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=41059 Signed-off-by: Eugeni Dodonov <eugeni.dodonov@intel.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-02-03drm/radeon/kms/dce3+: add support for hw i2c using atomAlex Deucher
Starting with DCE3 hardware, atom contains a general purpose ProcessI2cChannelTransaction similar to ProcessAuxChannelTransaction. Add an implementation using the atom tables for DCE3+ hardware. This should be a little less CPU intensive than bit banging and may work better in certain cases. Enable it by setting the radeon hw_i2c module parameter to 1. E.g., radeon.hw_i2c=1 on the kernel command line in grub. Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-02-03drm/radeon/kms: Use the standard VESA timeout for DDC channelsJean Delvare
The VESA specification suggests a 2.2 ms timeout on DDC channels. Use exactly that (as the i915 driver does) instead of hard-coding a jiffy count. Signed-off-by: Jean Delvare <jdelvare@suse.de> Reviewed-by: Keith Packard <keithp@keithp.com> Reviewed-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-02-03drm/kms: Make i2c buses fasterJean Delvare
A udelay value of 20 leads to an I2C bus running at only 25 kbps. I2C devices can typically operate faster than this, 50 kbps should be fine for all devices (and compliant devices can always stretch the clock if needed.) FWIW, the vast majority of framebuffer drivers set udelay to 10 already. So set it to 10 in DRM drivers too, this will make EDID block reads faster. We might even lower the udelay value later if no problem is reported. Signed-off-by: Jean Delvare <jdelvare@suse.de> Acked-by: Eugeni Dodonov <eugeni.dodonov@intel.com> Cc: Keith Packard <keithp@keithp.com> Reviewed-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-02-03drm/radeon/kms: remove benchmarks shorter than one pageIlija Hadzic
copy_blit operation works only on integral number of pages so benchmarks shorter than one page size (4K) do not make sense v2: use RADEON_GPU_PAGE_SIZE instead of "magic" 1024 number and sweep sizes between 1 * <page_size> to 16K * <page_size> doubling the size in each iteration; we get the same coverage, as in the original benchmark, but guarantee integer multiples of page size v3: add whitespace between '*' operator per review received from zajec5@gmail.com Signed-off-by: Ilija Hadzic <ihadzic@research.bell-labs.com> Reviewed-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-02-03drm/radeon/kms: common definitions for blit copy codeIlija Hadzic
R600/700 and Evergreen/NI blit code have a few redundant definitions in respective .c file. Move common definitions into a separate (new) .h file. Signed-off-by: Ilija Hadzic <ihadzic@research.bell-labs.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-02-03drm: remove master fd restriction on mode setting gettersMandeep Singh Baines
Its useful to be able to call the mode setting getter ioctls. Not requiring master fd, enables writing a simple program which can query the state of the video system. Since these ioctls are only "getters" there is no security or synchronization issues which would require master fd. Opening an new fd is already protected by the file permissions on the device file. Signed-off-by: Mandeep Singh Baines <msb@chromium.org> Cc: Dave Airlie <airlied@redhat.com> Cc: Daniel Vetter <daniel.vetter@ffwll.ch> Cc: Ilija Hadzic <ihadzic@research.bell-labs.com> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Cc: Stephane Marchesin <marcheu@chromium.org> Cc: dri-devel@lists.freedesktop.org Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-02-02Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: rbd: fix safety of rbd_put_client() rbd: fix a memory leak in rbd_get_client() ceph: create a new session lock to avoid lock inversion ceph: fix length validation in parse_reply_info() ceph: initialize client debugfs outside of monc->mutex ceph: change "ceph.layout" xattr to be "ceph.file.layout"
2012-02-02rbd: fix safety of rbd_put_client()Alex Elder
The rbd_client structure uses a kref to arrange for cleaning up and freeing an instance when its last reference is dropped. The cleanup routine is rbd_client_release(), and one of the things it does is delete the rbd_client from rbd_client_list. It acquires node_lock to do so, but the way it is done is still not safe. The problem is that when attempting to reuse an existing rbd_client, the structure found might already be in the process of getting destroyed and cleaned up. Here's the scenario, with "CLIENT" representing an existing rbd_client that's involved in the race: Thread on CPU A | Thread on CPU B --------------- | --------------- rbd_put_client(CLIENT) | rbd_get_client() kref_put() | (acquires node_lock) kref->refcount becomes 0 | __rbd_client_find() returns CLIENT calls rbd_client_release() | kref_get(&CLIENT->kref); | (releases node_lock) (acquires node_lock) | deletes CLIENT from list | ...and starts using CLIENT... (releases node_lock) | and frees CLIENT | <-- but CLIENT gets freed here Fix this by having rbd_put_client() acquire node_lock. The result could still be improved, but at least it avoids this problem. Signed-off-by: Alex Elder <elder@dreamhost.com> Signed-off-by: Sage Weil <sage@newdream.net>
2012-02-02rbd: fix a memory leak in rbd_get_client()Alex Elder
If an existing rbd client is found to be suitable for use in rbd_get_client(), the rbd_options structure is not being freed as it should. Fix that. Signed-off-by: Alex Elder <elder@dreamhost.com> Signed-off-by: Sage Weil <sage@newdream.net>
2012-02-02Merge branch 'drm-fixes' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
* 'drm-fixes' of git://people.freedesktop.org/~airlied/linux: drm/radeon/kms/blit: fix blit copy for very large buffers drm/radeon/kms: fix TRAVIS panel setup drm/radeon: fix use after free in ATRM bios reading code. drm/radeon/kms: Fix device tree linkage of DP i2c buses too drm/radeon: Set DESKTOP_HEIGHT register to the framebuffer (not mode) height. drm/radeon/kms: disable output polling when suspended drm/nv50/pm: signedness bug in nv50_pm_clocks_pre() drm/nouveau/gem: fix fence_sync race / oops drm/nouveau: fix typo on mxmdcb option drm/nouveau/mxm: pretend to succeed, even if we can't shadow the MXM-SIS drm/nouveau/disp: check that panel power gpio is enabled at init time
2012-02-02drm/radeon/kms/blit: fix blit copy for very large buffersIlija Hadzic
Evergreen and NI blit copy was broken if the buffer maps to a rectangle whose one dimension is 16384 (max dimension allowed by these chips). In the mainline kernel, the problem is exposed only when buffers are very large (1G), but it's still a problem. The problem could be exposed for smaller buffers if anyone modifies the algorithm for rectangle construction in r600_blit_create_rect() (the reason why someone would modify that algorithm is to tune the performance of buffer moves). The root cause was in i2f() function which only operated on range between 0 and 16383. Fix this by extending the range of i2f() function to 0 to 32767. While at it improve the function so that the range can be easily extended in the future (if it becomes necessary), cleanup lines over 80 characters, and replace in-line comments with one strategic comment that explains the crux of the function. Credits to michel@daenzer.net for pointing out the root cause of the bug. v2: Fix I2F_MAX_INPUT constant definition goof and warn only once if input argument is out of range. Edit the comment a little bit to avoid some linguistic confusion and make it look better in general. Signed-off-by: Ilija Hadzic <ihadzic@research.bell-labs.com> Reviewed-by: Alex Deucher <alexander.deucher@amd.com> Reviewed-by: Michel Dänzer <michel@daenzer.net> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-02-02drm/radeon/kms: fix TRAVIS panel setupAlex Deucher
Different versions of the DP to LVDS bridge chip need different panel mode settings depending on the chip version used. Fixes: https://bugs.freedesktop.org/show_bug.cgi?id=41569 Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Cc: stable@vger.kernel.org Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-02-02drm/radeon: fix use after free in ATRM bios reading code.Dave Airlie
Fixes: https://bugs.freedesktop.org/show_bug.cgi?id=45503 Reported-and-Debugged-by: mlambda@gmail.com Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-02-01Merge tag 'firewire-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394 firewire fixes post v3.3-rc1 Add workarounds table entries for hardware bugs in - FireWire part of Sound Blaster Audigy cards, - Ricoh PCIe 1394 controllers. Without these, several protocols, e.g. AV/C, do not work on the Audigy, and the Ricoh PCIe controllers wouldn't work at all. This does not concern the older Ricoh PCI controllers. * tag 'firewire-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394: firewire: ohci: disable MSI on Ricoh controllers firewire: ohci: add reset packet quirk for SB Audigy
2012-02-01staging: fix go7007-usb licenseRandy Dunlap
Add MODULE_LICENSE() as per the license in the comment at the top of the file for this source module to fix build warning: WARNING: modpost: missing MODULE_LICENSE() in drivers/staging/media/go7007/go7007-usb.o see include/linux/module.h for more information Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Cc: Ross Cohen <rcohen@snurgle.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-02-01Merge tag 'rdma-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband InfiniBand/RDMA fixes for 3.3: - Fix a crash due to a regression (uninitialized refcnt) introduced in 3.2 with XRC support. - Close race in how ucma reports events when connect fails. - Process vendor-specific MADs in mlx4 so that eg FDR-10 data rate works. - Fix regression in qib caused by over-aggressive PCIe tuning. - Other small fixes for hardware drivers (ipath, nes, qib). * tag 'rdma-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: RDMA/nes: Copyright update IB/mlx4: pass SMP vendor-specific attribute MADs to firmware RDMA/nes: Fix fast memory registration opcode RDMA/nes: Fix fast memory registration length RDMA/ucma: Discard all events for new connections until accepted IB/qib: Roll back PCIe tuning change IB/qib: Use GFP_ATOMIC when locks are held RDMA/nes: Add missing rcu_read_unlock() in nes_addr_resolve_neigh() RDMA/nes: Fix for sending MPA reject frame IB/ipath: Calling PTR_ERR() on right variable in create_file() RDMA/core: Fix kernel panic by always initializing qp->usecnt
2012-02-01drm/radeon/kms: Fix device tree linkage of DP i2c buses tooJean Delvare
Properly set the parent device of DP i2c buses before registering them too. Signed-off-by: Jean Delvare <jdelvare@suse.de> Reviewed-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-02-01drm/radeon: Set DESKTOP_HEIGHT register to the framebuffer (not mode) height.Michel Dänzer
The value of this register is transferred to the V_COUNTER register at the beginning of vertical blank. V_COUNTER is the reference for VLINE waits and goes from VIEWPORT_Y_START to VIEWPORT_Y_START+VIEWPORT_HEIGHT during scanout, so if VIEWPORT_Y_START is not 0, V_COUNTER actually went backwards at the beginning of vertical blank, and VLINE waits excluding the whole scanout area could never finish (possibly only if VIEWPORT_Y_START is larger than the length of vertical blank in scanlines). Setting DESKTOP_HEIGHT to the framebuffer height should prevent this for any kind of VLINE wait. Fixes https://bugs.freedesktop.org/show_bug.cgi?id=45329 . CC: stable@vger.kernel.org Signed-off-by: Michel Dänzer <michel.daenzer@amd.com> Reviewed-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-02-01drm/radeon/kms: disable output polling when suspendedSeth Forshee
Polling the outputs when the device is suspended can result in erroneous status updates. Disable output polling during suspend to prevent this from happening. Signed-off-by: Seth Forshee <seth.forshee@canonical.com> Reviewed-by: Alex Deucher <alexander.deucher@amd.com> Cc: stable@vger.kernel.org Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-02-01drm/nv50/pm: signedness bug in nv50_pm_clocks_pre()Dan Carpenter
calc_mclk() returns zero on success and negative on failure but clk is a u32. v2: Martin Peres: - clk should be an int, not a u32 Signed-off-by: Martin Peres <martin.peres@labri.fr> Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
