Pull ARM SoC fixes from Olof Johansson:
"A smallish set of fixes that we've been sitting on for a while now,
flushing the queue here so they go in. Summary:
A handful of fixes for OMAP, i.MX, Allwinner and Tegra:
- A clock rate and a PHY setup fix for i.MX6Q/DL
- A couple of fixes for the reduced serial bus (sunxi-rsb) on
Allwinner
- UART wakeirq fix for an OMAP4 board, timer config fixes for AM43XX.
- Suspend fix for Tegra124 Chromebooks
- Fix for missing implicit include that's different between
ARM/ARM64"
* tag 'armsoc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
ARM: tegra: Fix suspend hang on Tegra124 Chromebooks
bus: sunxi-rsb: Fix peripheral IC mapping runtime address
bus: sunxi-rsb: Fix primary PMIC mapping hardware address
ARM: dts: Fix UART wakeirq for omap4 duovero parlor
ARM: OMAP2+: AM43xx: select ARM TWD timer
ARM: OMAP2+: am43xx: enable GENERIC_CLOCKEVENTS_BROADCAST
fsl-ifc: add missing include on ARM64
ARM: dts: imx6: Fix Ethernet PHY mode on Ventana boards
ARM: dts: imx: Fix the assigned-clock mismatch issue on imx6q/dl
bus: sunxi-rsb: unlock on error in sunxi_rsb_read()
ARM: dts: sunxi: sun6i-a31s-primo81.dts: add touchscreen axis swapping property
Pull power management and ACPI fixes from Rafael Wysocki:
"These fix an ACPI processor driver regression introduced during the
4.3 cycle and a mistake in the recently added SCPI support in the
arm_big_little cpufreq driver.
Specifics:
- Fix a thermal management issue introduced by an ACPI processor
driver change made during the 4.3 development cycle that failed to
return 0 from a function on success which triggered an error
cleanup path every time it had been called that deleted useful data
structures created previously (Srinivas Pandruvada).
- Fix a variable data type issue in the arm_big_little cpufreq
driver's SCPI support code added recently that prevents error
handling in there from working correctly (Dan Carpenter)"
* tag 'pm+acpi-4.4-rc7' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
cpufreq: scpi-cpufreq: signedness bug in scpi_get_dvfs_info()
ACPI / processor: Fix thermal cooling device regression
Pull md bugfix from Neil Brown:
"One more md fix for 4.4-rc
Fix a regression which causes reshape to not start properly sometimes"
* tag 'md/4.4-rc6-fix' of git://neil.brown.name/md:
md: remove check for MD_RECOVERY_NEEDED in action_store.
Pull UBI bug fixes from Richard Weinberger:
"This contains four bug fixes for UBI"
* tag 'upstream-4.4-rc7' of git://git.infradead.org/linux-ubifs:
mtd: ubi: don't leak e if schedule_erase() fails
mtd: ubi: fixup error correction in do_sync_erase()
UBI: fix use of "VID" vs. "EC" in header self-check
UBI: fix return error code
* acpi-processor:
* pm-cpufreq:
Pull sparc fixes from David Miller:
1) Finally make perf stack backtraces stable on sparc, several problems
(mostly due to the context in which the user copies from the stack
are done) contributed to this.
From Rob Gardner.
2) Export ADI capability if the cpu supports it.
3) Hook up userfaultfd system call.
4) When faults happen during user copies we really have to clean up and
restore the FPU state fully. Also from Rob Gardner
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc:
tty/serial: Skip 'NULL' char after console break when sysrq enabled
sparc64: fix FP corruption in user copy functions
sparc64: Perf should save/restore fault info
sparc64: Ensure perf can access user stacks
sparc64: Don't set %pil in rtrap_nmi too early
sparc64: Add ADI capability to cpu capabilities
tty: serial: constify sunhv_ops structs
sparc: Hook up userfaultfd system call
When sysrq is triggered from console, serial driver for SUN hypervisor
console receives a console break and enables the sysrq. It expects a valid
sysrq char following with break. Meanwhile if driver receives 'NULL'
ASCII char then it disables sysrq and sysrq handler will never be invoked.
This fix skips calling uart sysrq handler when 'NULL' is received while
sysrq is enabled.
Signed-off-by: Vijay Kumar <vijay.ac.kumar@oracle.com>
Acked-by: Karl Volz <karl.volz@oracle.com>
Constifies sunhv_ops structures in tty's serial
driver since they are not modified after their
initialization.
Detected and found using Coccinelle.
Suggested-by: Julia Lawall <Julia.Lawall@lip6.fr>
Signed-off-by: Aya Mahfouz <mahfouz.saif.elyazal@gmail.com>
The "domain" variable needs to be signed for the error handling to work.
Fixes: 8def31034d03 (cpufreq: arm_big_little: add SCPI interface driver)
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Acked-by: Sudeep Holla <sudeep.holla@arm.com>
git://anongit.freedesktop.org/drm-intel
Pull i915 drm fixes from Jani Nikula:
"Here's a batch of i915 fixes all around. It may be slightly bigger
than one would hope for at this stage, but they've all been through
testing in our -next before being picked up for v4.4. Also, I missed
Dave's fixes pull earlier today just because I wanted an extra testing
round on this. So I'm fairly confident.
Wishing you all the things it is customary to wish this time of the
year"
* tag 'drm-intel-fixes-2015-12-23' of git://anongit.freedesktop.org/drm-intel:
drm/i915: Correct max delay for HDMI hotplug live status checking
drm/i915: mdelay(10) considered harmful
drm/i915: Kill intel_crtc->cursor_bo
drm/i915: Workaround CHV pipe C cursor fail
drm/i915: Only spin whilst waiting on the current request
drm/i915: Limit the busy wait on requests to 5us not 10ms!
drm/i915: Break busywaiting for requests on pending signals
drm/i915: Disable primary plane if we fail to reconstruct BIOS fb (v2)
drm/i915: Set the map-and-fenceable flag for preallocated objects
drm/i915: Drop the broken cursor base==0 special casing
Pull drm fixes from Dave Airlie:
"Not much happening, should have dequeued this lot earlier.
One amdgpu, one nouveau and one exynos fix"
* 'drm-fixes' of git://people.freedesktop.org/~airlied/linux:
drm/exynos: atomic check only enabled crtc states
drm/nouveau/bios/fan: hardcode the fan mode to linear
drm/amdgpu: fix user fence handling
Pull block layer fixes from Jens Axboe:
"Three small fixes for 4.4 final. Specifically:
- The segment issue fix from Junichi, where the old IO path does a
bio limit split before potentially bouncing the pages. We need to
do that in the right order, to ensure that limitations are met.
- A NVMe surprise removal IO hang fix from Keith.
- A use-after-free in null_blk, introduced by a previous patch in
this series. From Mike Krinkin"
* 'for-linus' of git://git.kernel.dk/linux-block:
null_blk: fix use-after-free error
block: ensure to split after potentially bouncing a bio
NVMe: IO ending fixes on surprise removal
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux
Pull s390 fixes from Martin Schwidefsky:
"Two late bug fixes for kernel 4.4.
Merry Christmas"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux:
s390/dis: Fix handling of format specifiers
s390/zcrypt: Fix AP queue handling if queue is full
Pull virtio fix from Michael Tsirkin:
"This includes a single fix for virtio ccw error handling"
* tag 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mst/vhost:
virtio/s390: handle error values in irb
0x4e is the runtime address normally associated with perihperal ICs.
0x45 is not a valid runtime address.
Signed-off-by: Chen-Yu Tsai <wens@csie.org>
The primary PMICs use 0x3a3 as their hardware address, not 0x3e3.
blk_end_request_all may free request, so we need to save
request_queue pointer before blk_end_request_all call.
The problem was introduced in commit cf8ecc5a8455266f8d51
("null_blk: guarantee device restart in all irq modes")
and causes general protection fault with slab poisoning
enabled.
Fixes: cf8ecc5a8455266f8d51 ("null_blk: guarantee device
Signed-off-by: Mike Krinkin <krinkin.m.u@gmail.com>
Reviewed-by: Ming Lei <tom.leiming@gmail.com>
Signed-off-by: Jens Axboe <axboe@fb.com>
This patch fixes a lost request discovered during IO + hot removal.
The driver's pci removal deletes gendisks prior to shutting down the
controller to allow dirty data to sync. Dirty data can not be synced on
a surprise removal, though, and would potentially block indefinitely.
The driver previously had marked the queue as dying in this scenario
to prevent new requests from attempting, however it will still block
for requests that already entered the queue. This patch fixes this by
quiescing IO first, then aborting the requeued requests before deleting
disks.
Reported-by: Sujith Pandel <sujith_pandel@dell.com>
Signed-off-by: Keith Busch <keith.busch@intel.com>
Tested-by: Sujith Pandel <sujith_pandel@dell.com>
The total delay of HDMI hotplug detecting with 30ms have already
been split into a resolution of 3 retries of 10ms each, for the worst
cases. But it still suffered from only waiting 10ms at most in
intel_hdmi_detect(). This patch corrects it by reading hotplug status
with 4 times at most for 30ms delay.
v2:
- straight up to loop execution for more clear in code readability
- mdelay will replace with msleep by Daniel's new patch
- suggest to re-evaluate try times for being compatible to old HDMI monitor
Reviewed-by: Cooper Chiou <cooper.chiou@intel.com>
Tested-by: Gary Wang <gary.c.wang@intel.com>
Cc: Jani Nikula <jani.nikula@linux.intel.com>
Cc: Daniel Vetter <daniel@ffwll.ch>
Cc: Gavin Hindman <gavin.hindman@intel.com>
Cc: Sonika Jindal <sonika.jindal@intel.com>
Cc: Shashank Sharma <shashank.sharma@intel.com>
Signed-off-by: Gary Wang <gary.c.wang@intel.com>
[danvet: fixup conflict with s/mdelay/msleep/ patch.]
Cc: drm-intel-fixes@lists.freedesktop.org
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
(cherry picked from commit 61fb3980dd396880ffba48523b1e27579868b82b)
Signed-off-by: Jani Nikula <jani.nikula@intel.com>
I missed this myself when reviewing
commit 237ed86c693d8a8e4db476976aeb30df4deac74b
Author: Sonika Jindal <sonika.jindal@intel.com>
Date: Tue Sep 15 09:44:20 2015 +0530
drm/i915: Check live status before reading edid
Long sleeps like this really shouldn't waste cpu cycles spinning.
Cc: "Wang, Gary C" <gary.c.wang@intel.com>
Link: http://patchwork.freedesktop.org/patch/msgid/1449859455-32609-1-git-send-email-daniel.vetter@ffwll.ch
Reviewed-by: Sonika Jindal <sonika.jindal@intel.com>
(cherry picked from commit 71a199bacb398ee54eeac001699257dda083a455)
The vma may have been rebound between the last time the cursor was
enabled and now, so skipping the cursor gtt offset deduction is not
safe unless we would also reset cursor_bo to NULL when disabling the
cursor. Just thow cursor_bo to the bin instead since it's lost all
other uses thanks to universal plane support.
Chris pointed out that cursor updates are currently too slow
via universal planes that micro optimizations like these wouldn't
even help.
v2: Add a note about futility of micro optimizations (Chris)
References: http://lists.freedesktop.org/archives/intel-gfx/2015-December/082976.html
Cc: Chris Wilson <chris@chris-wilson.co.uk>
Cc: Takashi Iwai <tiwai@suse.de>
Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com>
Link: http://patchwork.freedesktop.org/patch/msgid/1450107302-17171-1-git-send-email-ville.syrjala@linux.intel.com
Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk>
(cherry picked from commit 1264859d648c4bdc9f0a098efbff90cbf462a075)
Turns out CHV pipe C was glued on somewhat poorly, and there's something
wrong with the cursor. If the cursor straddles the left screen edge,
and is then moved away from the edge or disabled, the pipe will often
underrun. If enough underruns are triggered quickly enough the pipe
will fall over and die (it just scans out a solid color and reports
a constant underrun). We need to turn the disp2d power well off and
on again to recover the pipe.
None of that is very nice for the user, so let's just refuse to place
the cursor in the compromised position. The ddx appears to fall back
to swcursor when the ioctl returns an error, so theoretically there's
no loss of functionality for the user (discounting swcursor bugs).
I suppose most cursors images actually have the hotspot not exactly
at 0,0 so under typical conditions the fallback will in fact kick in
as soon as the cursor touches the left edge of the screen.
Any atomic compositor should anyway be prepared to fall back to
GPU composition when things don't work out, so there should be no
problem with those.
Other things that I tried to solve this include flipping all
display related clock gating knobs I could find, increasing the
minimum gtt alignment all the way up to 512k. I also tried to see
if there are more specific screen coordinates that hit the bug, but
the findings were somewhat inconclusive. Sometimes the failures
happen almost across the whole left edge, sometimes more at the very
top and around the bottom half. I wasn't able to find any real pattern
to these variations, so it seems our only choice is to just refuse
to straddle the left screen edge at all.
Cc: stable@vger.kernel.org
Cc: Jason Plum <max@warheads.net>
Testcase: igt/kms_chv_cursor_fail
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=92826
Link: http://patchwork.freedesktop.org/patch/msgid/1450459479-16286-1-git-send-email-ville.syrjala@linux.intel.com
(cherry picked from commit b29ec92c4f5e6d45d8bae8194e664427a01c6687)
Limit busywaiting only to the request currently being processed by the
GPU. If the request is not currently being processed by the GPU, there
is a very low likelihood of it being completed within the 2 microsecond
spin timeout and so we will just be wasting CPU cycles.
v2: Check for logical inversion when rebasing - we were incorrectly
checking for this request being active, and instead busywaiting for
when the GPU was not yet processing the request of interest.
v3: Try another colour for the seqno names.
v4: Another colour for the function names.
v5: Remove the forced coherency when checking for the active request. On
reflection and plenty of recent experimentation, the issue is not a
cache coherency problem - but an irq/seqno ordering problem (timing issue).
Here, we do not need the w/a to force ordering of the read with an
interrupt.
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
Reviewed-by: Tvrtko Ursulin <tvrtko.ursulin@linux.intel.com>
Cc: "Rogozhkin, Dmitry V" <dmitry.v.rogozhkin@intel.com>
Cc: Daniel Vetter <daniel.vetter@ffwll.ch>
Cc: Tvrtko Ursulin <tvrtko.ursulin@linux.intel.com>
Cc: Eero Tamminen <eero.t.tamminen@intel.com>
Cc: "Rantala, Valtteri" <valtteri.rantala@intel.com>
Link: http://patchwork.freedesktop.org/patch/msgid/1449833608-22125-4-git-send-email-chris@chris-wilson.co.uk
(cherry picked from commit 821485dc2ad665f136c57ee589bf7a8210160fe2)
When waiting for high frequency requests, the finite amount of time
required to set up the irq and wait upon it limits the response rate. By
busywaiting on the request completion for a short while we can service
the high frequency waits as quick as possible. However, if it is a slow
request, we want to sleep as quickly as possible. The tradeoff between
waiting and sleeping is roughly the time it takes to sleep on a request,
on the order of a microsecond. Based on measurements of synchronous
workloads from across big core and little atom, I have set the limit for
busywaiting as 10 microseconds. In most of the synchronous cases, we can
reduce the limit down to as little as 2 miscroseconds, but that leaves
quite a few test cases regressing by factors of 3 and more.
The code currently uses the jiffie clock, but that is far too coarse (on
the order of 10 milliseconds) and results in poor interactivity as the
CPU ends up being hogged by slow requests. To get microsecond resolution
we need to use a high resolution timer. The cheapest of which is polling
local_clock(), but that is only valid on the same CPU. If we switch CPUs
because the task was preempted, we can also use that as an indicator that
the system is too busy to waste cycles on spinning and we should sleep
instead.
__i915_spin_request was introduced in
commit 2def4ad99befa25775dd2f714fdd4d92faec6e34 [v4.2]
Author: Chris Wilson <chris@chris-wilson.co.uk>
Date: Tue Apr 7 16:20:41 2015 +0100
drm/i915: Optimistically spin for the request completion
v2: Drop full u64 for unsigned long - the timer is 32bit wraparound safe,
so we can use native register sizes on smaller architectures. Mention
the approximate microseconds units for elapsed time and add some extra
comments describing the reason for busywaiting.
v3: Raise the limit to 10us
v4: Now 5us.
Reported-by: Jens Axboe <axboe@kernel.dk>
Link: https://lkml.org/lkml/2015/11/12/621
Link: http://patchwork.freedesktop.org/patch/msgid/1449833608-22125-3-git-send-email-chris@chris-wilson.co.uk
(cherry picked from commit ca5b721e238226af1d767103ac852aeb8e4c0764)
The busywait in __i915_spin_request() does not respect pending signals
and so may consume the entire timeslice for the task instead of
returning to userspace to handle the signal.
In the worst case this could cause a delay in signal processing of 20ms,
which would be a noticeable jitter in cursor tracking. If a higher
resolution signal was being used, for example to provide fairness of a
server timeslices between clients, we could expect to detect some
unfairness between clients (i.e. some windows not updating as fast as
others). This issue was noticed when inspecting a report of poor
interactivity resulting from excessively high __i915_spin_request usage.
Fixes regression from
v2: Try to assess the impact of the bug
Cc; "Rogozhkin, Dmitry V" <dmitry.v.rogozhkin@intel.com>
Link: http://patchwork.freedesktop.org/patch/msgid/1449833608-22125-2-git-send-email-chris@chris-wilson.co.uk
(cherry picked from commit 91b0c352ace9afec1fb51590c7b8bd60e0eb9fbd)
If we fail to reconstruct the BIOS fb (e.g., because the FB is too
large), we'll be left with plane state that indicates the primary plane
is visible yet has a NULL fb. This mismatch causes problems later on
(e.g., for the watermark code). Since we've failed to reconstruct the
BIOS FB, the best solution is to just disable the primary plane and
pretend the BIOS never had it enabled.
v2: Add intel_pre_disable_primary() call (Maarten)
Cc: Ville Syrjälä <ville.syrjala@intel.com>
Cc: Maarten Lankhorst <maarten.lankhorst@linux.intel.com>
Signed-off-by: Matt Roper <matthew.d.roper@intel.com>
Reviewed-by: Maarten Lankhorst <maarten.lankhorst@linux.intel.com>
Link: http://patchwork.freedesktop.org/patch/msgid/1449171462-30763-2-git-send-email-matthew.d.roper@intel.com
(cherry picked from commit 200757f5d7c6f7f7032a0a07bbb8c02a840bbf7d)
As we mark the preallocated objects as bound, we should also flag them
correctly as being map-and-fenceable (if appropriate!) so that later
users do not get confused and try and rebind the pinned vma in order to
get a map-and-fenceable binding.
Cc: "Goel, Akash" <akash.goel@intel.com>
Cc: Jesse Barnes <jbarnes@virtuousgeek.org>
Link: http://patchwork.freedesktop.org/patch/msgid/1448029000-10616-1-git-send-email-chris@chris-wilson.co.uk
Reviewed-by: Jesse Barnes <jbarnes@virtuousgeek.org>
(cherry picked from commit d0710abbcd88b1ff17760e97d74a673e67b49ea1)
The cursor code tries to treat base==0 to mean disabled. That fails
when the cursor bo gets bound at ggtt offset 0, and the user is left
looking at an invisible cursor.
We lose the disabled->disabled optimization, but that seems like
something better handled at a slightly higher level.
Link: http://patchwork.freedesktop.org/patch/msgid/1450091808-32607-3-git-send-email-ville.syrjala@linux.intel.com
(cherry picked from commit 663f3122d00c0b412d429f105dca129aa8f4f094)
The processor cooling device is no longer present for passive thermal
control.
Commit 239708a3af44 ("ACPI: Split out ACPI PSS from ACPI Processor driver")
moved the processing to a new function acpi_pss_perf_init(), but
missed "return 0" after successful creation. This causes the error
handling functions to be called, which will delete the previously
created processor cooling device.
Fixes: 239708a3af44 (ACPI: Split out ACPI PSS from ACPI Processor driver)
Signed-off-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com>
Cc: 4.3+ <stable@vger.kernel.org> # 4.3+
md currently doesn't allow a 'sync_action' such as 'reshape' to be set
while MD_RECOVERY_NEEDED is set.
This s a problem, particularly since commit 738a273806ee as that can
cause ->check_shape to call mddev_resume() which sets
MD_RECOVERY_NEEDED. So by the time we come to start 'reshape' it is
very likely that MD_RECOVERY_NEEDED is still set.
Testing for this flag is not really needed and is in any case very
racy as it can be set at any moment - asynchronously. Any race
between setting a sync_action and setting MD_RECOVERY_NEEDED must
already be handled properly in some locked code, probably
md_check_recovery(), so remove the test here.
The test on MD_RECOVERY_RUNNING is also racy in the 'reshape' case
so we should test it again after getting mddev_lock().
As this fixes a race and a regression which can cause 'reshape' to
fail, it is suitable for -stable kernels since 4.1
Reported-by: Xiao Ni <xni@redhat.com>
Fixes: 738a273806ee ("md/raid5: fix allocation of 'scribble' array.")
Cc: stable@vger.kernel.org (v4.1+)
Signed-off-by: NeilBrown <neilb@suse.com>
git://git.kernel.org/pub/scm/linux/kernel/git/abelloni/linux
Pull RTC fixes from Alexandre Belloni:
"Late fixes for the RTC subsystem for 4.4:
A fix for a nasty hardware bug in rk808 and an initialization
reordering in da9063 to fix a possible crash"
* tag 'rtc-4.4-3' of git://git.kernel.org/pub/scm/linux/kernel/git/abelloni/linux:
rtc: da9063: fix access ordering error during RTC interrupt at system power on
rtc: rk808: Compensate for Rockchip calendar deviation on November 31st
This fix alters the ordering of the IRQ and device registrations in the RTC
driver probe function. This change will apply to the RTC driver that supports
both DA9063 and DA9062 PMICs.
A problem could occur with the existing RTC driver if:
A system is started from a cold boot using the PMIC RTC IRQ to initiate a
power on operation. For instance, if an RTC alarm is used to start a
platform from power off.
The existing driver IRQ is requested before the device has been properly
registered.
i.e.
ret = devm_request_threaded_irq()
comes before
rtc->rtc_dev = devm_rtc_device_register();
In this case, the interrupt can be called before the device has been
registered and the handler can be called immediately. The IRQ handler
da9063_alarm_event() contains the function call
rtc_update_irq(rtc->rtc_dev, 1, RTC_IRQF | RTC_AF);
which in turn tries to access the unavailable rtc->rtc_dev.
The fix is to reorder the functions inside the RTC probe. The IRQ is
requested after the RTC device resource has been registered so that
get_irq_byname is the last thing to happen.
Signed-off-by: Steve Twiss <stwiss.opensource@diasemi.com>
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
In A.D. 1582 Pope Gregory XIII found that the existing Julian calendar
insufficiently represented reality, and changed the rules about
calculating leap years to account for this. Similarly, in A.D. 2013
Rockchip hardware engineers found that the new Gregorian calendar still
contained flaws, and that the month of November should be counted up to
31 days instead. Unfortunately it takes a long time for calendar changes
to gain widespread adoption, and just like more than 300 years went by
before the last Protestant nation implemented Greg's proposal, we will
have to wait a while until all religions and operating system kernels
acknowledge the inherent advantages of the Rockchip system. Until then
we need to translate dates read from (and written to) Rockchip hardware
back to the Gregorian format.
This patch works by defining Jan 1st, 2016 as the arbitrary anchor date
on which Rockchip and Gregorian calendars are in sync. From that we can
translate arbitrary later dates back and forth by counting the number
of November/December transitons since the anchor date to determine the
offset between the calendars. We choose this method (rather than trying
to regularly "correct" the date stored in hardware) since it's the only
way to ensure perfect time-keeping even if the system may be shut down
for an unknown number of years. The drawback is that other software
reading the same hardware (e.g. mainboard firmware) must use the same
translation convention (including the same anchor date) to be able to
read and write correct timestamps from/to the RTC.
Signed-off-by: Julius Werner <jwerner@chromium.org>
Reviewed-by: Douglas Anderson <dianders@chromium.org>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty
Pull tty/serial fixes from Greg KH:
"Here are some tty/serial driver fixes for 4.4-rc6 that resolve some
reported problems. All of these have been in linux-next. The details
are in the shortlog"
* tag 'tty-4.4-rc6' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty:
tty: Fix GPF in flush_to_ldisc()
serial: earlycon: Add missing spinlock initialization
serial: sh-sci: Fix length of scatterlist
n_tty: Fix poll() after buffer-limited eof push read
serial: 8250_uniphier: fix dl_read and dl_write functions
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull USB fixes from Greg KH:
"Here are some USB and PHY fixes for 4.4-rc6. All of them resolve some
reported problems. Full details in the shortlog"
* tag 'usb-4.4-rc6' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb:
USB: fix invalid memory access in hub_activate()
USB: ipaq.c: fix a timeout loop
phy: core: Get a refcount to phy in devm_of_phy_get_by_index()
phy: cygnus: pcie: add missing of_node_put
phy: miphy365x: add missing of_node_put
phy: miphy28lp: add missing of_node_put
phy: rockchip-usb: add missing of_node_put
phy: berlin-sata: add missing of_node_put
phy: mt65xx-usb3: add missing of_node_put
phy: brcmstb-sata: add missing of_node_put
phy: sun9i-usb: add USB dependency
Pull md fixes from Neil Brown:
"Four fixes for md:
- two recently introduced regressions fixed.
- one older bug in RAID10 - tagged for -stable since 4.2
- one minor sysfs api improvement"
* tag 'md/4.4-rc5-fixes' of git://neil.brown.name/md:
Fix remove_and_add_spares removes drive added as spare in slot_store
md: fix bug due to nested suspend
MD: change journal disk role to disk 0
md/raid10: fix data corruption and crash during resync
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi
Pull spi fixes from Mark Brown:
"A couple of reference counting bugs here, one in spidev and one with
holding an extra reference in the core that we never freed if we
removed a device, plus a driver specific fix. Both of the refcounting
bugs are very old but they've only been found by observation so
hopefully their impact has been low"
* tag 'spi-fix-v4.4-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi:
spi: fix parent-device reference leak
spi: spidev: Hold spi_lock over all defererences of spi in release()
spi-fsl-dspi: Fix CTAR Register access
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio
Pull GPIO fixes from Linus Walleij:
"Some GPIO fixes for the v4.4 series. Most prominent: I revert the
error propagation from the .get() function until we can fix up all the
drivers properly for v4.5.
- Revert the error number propagation from the .get() vtable entry
temporarily, until we make the proper fixes to all drivers.
- Fix the clamping behaviour in the generic GPIO driver.
- Driver fix for the ath79 driver"
* tag 'gpio-v4.4-3' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio:
gpio: revert get() to non-errorprogating behaviour
gpio: generic: clamp values from bgpio_get_set()
gpio: ath79: Fix the logic to clear offset bit of AR71XX_GPIO_REG_OE register
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl
Pull pin control fixes from Linus Walleij:
- Driver fixes for Freescale i.MX7D, Intel, Broadcom 2835
- One MAINTAINERS entry
* tag 'pinctrl-v4.4-3' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl:
MAINTAINERS: pinctrl: Add maintainers for pinctrl-single
pinctrl: bcm2835: Fix initial value for direction_output
pinctrl: intel: fix offset calculation issue of register PAD_OWN
pinctrl: intel: fix bug of register offset calculation
pinctrl: freescale: add ZERO_OFFSET_VALID flag for vf610 pinctrl
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux
Pull i2c fixes from Wolfram Sang:
"A set of 'usual' driver bugfixes for the I2C subsystem"
* 'i2c/for-current' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux:
i2c: rcar: disable runtime PM correctly in slave mode
i2c: designware: Keep pm_runtime_enable/_disable calls in sync
i2c: designware: fix IO timeout issue for AMD controller
i2c: imx: init bus recovery info before adding i2c adapter
i2c: do not use 0x in front of %pa
i2c: davinci: Increase module clock frequency
i2c: mv64xxx: The n clockdiv factor is 0 based on sunxi SoCs
i2c: rk3x: populate correct variable for sda_falling_time
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
Pull input fixes from Dmitry Torokhov:
"Just a few assorted driver fixes"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input:
Input: elants_i2c - fix wake-on-touch
Input: elan_i2c - set input device's vendor and product IDs
Input: sun4i-lradc-keys - fix typo in binding documentation
Input: atmel_mxt_ts - add maxtouch to I2C table for module autoload
Input: arizona-haptic - fix disabling of haptics device
Input: aiptek - fix crash on detecting device without endpoints
Input: atmel_mxt_ts - add generic platform data for Chromebooks
Input: parkbd - clear unused function pointers
Input: walkera0701 - clear unused function pointers
Input: turbografx - clear unused function pointers
Input: gamecon - clear unused function pointers
Input: db9 - clear unused function pointers
Since atomic check is called also for disabled crtcs it should skip
mode checking as it can be uninitialized. The patch fixes it.
Signed-off-by: Andrzej Hajda <a.hajda@samsung.com>
Suggested-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Tested-by: Javier Martinez Canillas <javier@osg.samsung.com>
Signed-off-by: Inki Dae <inki.dae@samsung.com>
When we also are I2C slave, we need to disable runtime PM because the
address detection mechanism needs to be active all the time. However, we
can reenable runtime PM once the slave instance was unregistered. So,
use pm_runtime_get_sync/put to achieve this, since it has proper
refcounting. pm_runtime_allow/forbid is like a global knob controllable
from userspace which is unsuitable here.
Signed-off-by: Wolfram Sang <wsa+renesas@sang-engineering.com>
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
Cc: stable@kernel.org
Pull power management fixes from Rafael Wysocki:
"These fix a potential regression introduced during the 4.3 cycle
(generic power domains framework), a nasty bug that has been present
forever (power capping RAPL driver), a build issue (Tegra cpufreq
driver) and a minor ugliness introduced recently (intel_pstate).
Specifics:
- Fix a potential regression in the generic power domains framework
introduced during the 4.3 development cycle that may lead to
spurious failures of system suspend in certain situations (Ulf
Hansson).
- Fix a problem in the power capping RAPL (Running Average Power
Limits) driver that causes it to initialize successfully on some
systems where it is not supposed to do that which is due to an
incorrect check in an initialization routine (Prarit Bhargava).
- Fix a build problem in the cpufreq Tegra driver that depends on the
regulator framework, but that dependency is not reflected in
Kconfig (Arnd Bergmann).
- Fix a recent mistake in the intel_pstate driver where a numeric
constant is used directly instead of a symbol defined specifically
for the case in question (Prarit Bhargava)"
* tag 'pm+acpi-4.4-rc6' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
powercap / RAPL: fix BIOS lock check
cpufreq: intel_pstate: Minor cleanup for FRAC_BITS
cpufreq: tegra: add regulator dependency for T124
PM / Domains: Allow runtime PM callbacks to be re-used during system PM
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi
Pull SCSI fixes from James Bottomley:
"Three fixes this time, two in SES picked up by KASAN for various types
of buffer overrun. The first is a USB array which returns page 8
whatever is asked for and causes us to overrun with incorrect data
format assumptions and the second is an invalid iteration of page 10
(the additional information page).
The final fix is a reversion of a NULL deref fix which caused
suspend/resume not to be called in pairs leading to incorrect device
operation (Jens has queued a more proper fix for the problem in
block)"
* tag 'scsi-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi:
ses: fix additional element traversal bug
Revert "SCSI: Fix NULL pointer dereference in runtime PM"
ses: Fix problems with simple enclosures
single nouveau fix.
* 'linux-4.4' of git://github.com/skeggsb/linux:
into drm-fixes
Just one important fix for amdgpu to avoid possible memory corruption.
* 'drm-fixes-4.4' of git://people.freedesktop.org/~agd5f/linux:
When sending "SLEEP" command to the controller it ceases scanning
completely and is unable to wake the system up from sleep, so if it is
configured as a wakeup source we should simply configure interrupt for
wakeup and rely on idle logic within the controller to reduce power
consumption while it is not used.
Signed-off-by: James Chen <james.chen@emc.com.tw>
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media
Pull media fixes from Mauro Carvalho Chehab.
* tag 'media/v4.4-3' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media:
[media] airspy: increase USB control message buffer size
[media] hackrf: move RF gain ctrl enable behind module parameter
[media] hackrf: fix possible null ptr on debug printing
[media] Revert "[media] ivtv: avoid going past input/audio array"
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging
Pull hwmon fixes from Guenter Roeck:
- Select CONFIG_BITREVERSE for sht15 driver to avoid build failure if
it is not configured.
- Force wait for conversion time for the first valid data in tmp102
driver to avoid reporting erroneous data to the thermal subsystem.
* tag 'hwmon-for-linus-v4.4-rc6' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging:
hwmon: (sht15) Select CONFIG_BITREVERSE
hwmon: (tmp102) Force wait for conversion time for the first valid data
