commit 8aac7f34369726d1a158788ae8aff3002d5eb528 upstream.
fbcon can deal with vc_hi_font_mask (the upper 256 chars) and adjust
the vc attrs dynamically when vc_hi_font_mask is changed at
fbcon_init(). When the vc_hi_font_mask is set, it remaps the attrs in
the existing console buffer with one bit shift up (for 9 bits), while
it remaps with one bit shift down (for 8 bits) when the value is
cleared. It works fine as long as the font gets updated after fbcon
was initialized.
However, we hit a bizarre problem when the console is switched to
another fb driver (typically from vesafb or efifb to drmfb). At
switching to the new fb driver, we temporarily rebind the console to
the dummy console, then rebind to the new driver. During the
switching, we leave the modified attrs as is. Thus, the new fbcon
takes over the old buffer as if it were to contain 8 bits chars
(although the attrs are still shifted for 9 bits), and effectively
this results in the yellow color texts instead of the original white
color, as found in the bugzilla entry below.
An easy fix for this is to re-adjust the attrs before leaving the
fbcon at con_deinit callback. Since the code to adjust the attrs is
already present in the current fbcon code, in this patch, we simply
factor out the relevant code, and call it from fbcon_deinit().
Bugzilla: https://bugzilla.suse.com/show_bug.cgi?id=1000619
Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
From: Gabriel Krisman Bertazi <krisman@linux.vnet.ibm.com>
[ Upstream commit f209fa03fc9d131b3108c2e4936181eabab87416 ]
During a PCI error recovery, like the ones provoked by EEH in the ppc64
platform, all IO to the device must be blocked while the recovery is
completed. Current 8250_pci implementation only suspends the port
instead of detaching it, which doesn't prevent incoming accesses like
TIOCMGET and TIOCMSET calls from reaching the device. Those end up
racing with the EEH recovery, crashing it. Similar races were also
observed when opening the device and when shutting it down during
recovery.
This patch implements a more robust IO blockage for the 8250_pci
recovery by unregistering the port at the beginning of the procedure and
re-adding it afterwards. Since the port is detached from the uart
layer, we can be sure that no request will make through to the device
during recovery. This is similar to the solution used by the JSM serial
driver.
I thank Peter Hurley <peter@hurleysoftware.com> for valuable input on
this one over one year ago.
Signed-off-by: Gabriel Krisman Bertazi <krisman@linux.vnet.ibm.com>
Signed-off-by: Sumit Semwal <sumit.semwal@linaro.org>
[ Upstream commit 708f5dcc21ae9b35f395865fc154b0105baf4de4 ]
The Dell Latitude 3350's ethernet card attempts to use a reserved
IRQ (18), resulting in ACPI being unable to enable the ethernet.
Adding it to acpi_rev_dmi_table[] helps to work around this problem.
Signed-off-by: Michael Pobega <mpobega@neverware.com>
[ rjw: Changelog ]
[ Upstream commit 9523b9bf6dceef6b0215e90b2348cd646597f796 ]
Precision 5520 and 3520 either hang at login and during suspend or reboot.
It turns out that that adding them to acpi_rev_dmi_table[] helps to work
around those issues.
Signed-off-by: Alex Hung <alex.hung@canonical.com>
[ rjw: Changelog ]
[ Upstream commit e950267ab802c8558f1100eafd4087fd039ad634 ]
Some devices have invalid baSourceID references, causing uvc_scan_chain()
to fail, but if we just take the entities we can find and put them
together in the most sensible chain we can think of, turns out they do
work anyway. Note: This heuristic assumes there is a single chain.
At the time of writing, devices known to have such a broken chain are
- Acer Integrated Camera (5986:055a)
- Realtek rtl157a7 (0bda:57a7)
Signed-off-by: Henrik Ingo <henrik.ingo@avoinelama.fi>
Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
From: Harald Freudenberger <freude@linux.vnet.ibm.com>
[ Upstream commit b3e8652bcbfa04807e44708d4d0c8cdad39c9215 ]
Signed-off-by: Harald Freudenberger <freude@linux.vnet.ibm.com>
[ Upstream commit 39701e56f5f16ea0cf8fc9e8472e645f8de91d23 ]
The iommu_table struct manages a hardware TCE table and a vmalloc'd
table with corresponding userspace addresses. Both are allocated when
the default DMA window is created and this happens when the very first
group is attached to a container.
As we are going to allow the userspace to configure container in one
memory context and pas container fd to another, we have to postpones
such allocations till a container fd is passed to the destination
user process so we would account locked memory limit against the actual
container user constrainsts.
This postpones the it_userspace array allocation till it is used first
time for mapping. The unmapping patch already checks if the array is
allocated.
Signed-off-by: Alexey Kardashevskiy <aik@ozlabs.ru>
Reviewed-by: David Gibson <david@gibson.dropbear.id.au>
Acked-by: Alex Williamson <alex.williamson@redhat.com>
[ Upstream commit f40ec3c748c6912f6266c56a7f7992de61b255ed ]
Previously we enabled VFs and enable their memory space before calling
pcibios_sriov_enable(). But pcibios_sriov_enable() may update the VF BARs:
for example, on PPC PowerNV we may change them to manage the association of
VFs to PEs.
Because 64-bit BARs cannot be updated atomically, it's unsafe to update
them while they're enabled. The half-updated state may conflict with other
devices in the system.
Call pcibios_sriov_enable() before enabling the VFs so any BAR updates
happen while the VF BARs are disabled.
[bhelgaas: changelog]
Tested-by: Carol Soto <clsoto@us.ibm.com>
Signed-off-by: Gavin Shan <gwshan@linux.vnet.ibm.com>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
[ Upstream commit 63880b230a4af502c56dde3d4588634c70c66006 ]
VF BARs are read-only zero, so updating VF BARs will not have any effect.
See the SR-IOV spec r1.1, sec 3.4.1.11.
We already ignore these updates because of 70675e0b6a1a ("PCI: Don't try to
restore VF BARs"); this merely restructures it slightly to make it easier
to split updates for standard and SR-IOV BARs.
Reviewed-by: Gavin Shan <gwshan@linux.vnet.ibm.com>
[ Upstream commit 45d004f4afefdd8d79916ee6d97a9ecd94bb1ffe ]
The BAR property bits (0-3 for memory BARs, 0-1 for I/O BARs) are supposed
to be read-only, but we do save them in res->flags and include them when
updating the BAR.
Mask the I/O property bits with ~PCI_BASE_ADDRESS_IO_MASK (0x3) instead of
PCI_REGION_FLAG_MASK (0xf) to make it obvious that we can't corrupt bits
2-3 of I/O addresses.
Use PCI_ROM_ADDRESS_MASK for ROM BARs. This means we'll only check the top
21 bits (instead of the 28 bits we used to check) of a ROM BAR to see if
the update was successful.
[ Upstream commit 546ba9f8f22f71b0202b6ba8967be5cc6dae4e21 ]
If we update a VF BAR while it's enabled, there are two potential problems:
1) Any driver that's using the VF has a cached BAR value that is stale
after the update, and
2) We can't update 64-bit BARs atomically, so the intermediate state
(new lower dword with old upper dword) may conflict with another
device, and an access by a driver unrelated to the VF may cause a bus
error.
Warn about attempts to update VF BARs while they are enabled. This is a
programming error, so use dev_WARN() to get a backtrace.
[ Upstream commit 7a6d312b50e63f598f5b5914c4fd21878ac2b595 ]
Remove the assumption that IORESOURCE_ROM_ENABLE == PCI_ROM_ADDRESS_ENABLE.
PCI_ROM_ADDRESS_ENABLE is the ROM enable bit defined by the PCI spec, so if
we're reading or writing a BAR register value, that's what we should use.
IORESOURCE_ROM_ENABLE is a corresponding bit in struct resource flags.
[ Upstream commit 0b457dde3cf8b7c76a60f8e960f21bbd4abdc416 ]
pci_update_resource() updates a hardware BAR so its address matches the
kernel's struct resource UNLESS it's a disabled ROM BAR. We only update
those when we enable the ROM.
It's not obvious from the code why ROM BARs should be handled specially.
Apparently there are Matrox devices with defective ROM BARs that read as
zero when disabled. That means that if pci_enable_rom() reads the disabled
BAR, sets PCI_ROM_ADDRESS_ENABLE (without re-inserting the address), and
writes it back, it would enable the ROM at address zero.
Add comments and references to explain why we can't make the code look more
rational.
The code changes are from 755528c860b0 ("Ignore disabled ROM resources at
setup") and 8085ce084c0f ("[PATCH] Fix PCI ROM mapping").
Link: https://lkml.org/lkml/2005/8/30/138
[sumits: minor fixup in rom.c for 4.4.y]
[ Upstream commit 286c2378aaccc7343ebf17ec6cd86567659caf70 ]
pci_std_update_resource() only deals with standard BARs, so we don't have
to worry about the complications of VF BARs in an SR-IOV capability.
Compute the BAR address inline and remove pci_resource_bar(). That makes
pci_iov_resource_bar() unused, so remove that as well.
[ Upstream commit 6ffa2489c51da77564a0881a73765ea2169f955d ]
Previously pci_update_resource() used the same code path for updating
standard BARs and VF BARs in SR-IOV capabilities.
Split the VF BAR update into a new pci_iov_update_resource() internal
interface, which makes it simpler to compute the BAR address (we can get
rid of pci_resource_bar() and pci_iov_resource_bar()).
This patch:
- Renames pci_update_resource() to pci_std_update_resource(),
- Adds pci_iov_update_resource(),
- Makes pci_update_resource() a wrapper that calls the appropriate one,
No functional change intended.
[ Upstream commit 5bc8c230e2a993b49244f9457499f17283da9ec7 ]
i210 and i211 share the same PHY but have different PCI IDs. Don't
forget i211 for any i210 workarounds.
Signed-off-by: Todd Fujinaka <todd.fujinaka@intel.com>
Tested-by: Aaron Brown <aaron.f.brown@intel.com>
[ Upstream commit 4e684f59d760a2c7c716bb60190783546e2d08a1 ]
Sometimes firmware may not properly initialize I347AT4_PAGE_SELECT causing
the probe of an igb i210 NIC to fail. This patch adds an addition zeroing
of this register during igb_get_phy_id to workaround this issue.
Thanks for Jochen Henneberg for the idea and original patch.
Signed-off-by: Chris J Arges <christopherarges@gmail.com>
commit 687e0687f71ec00e0132a21fef802dee88c2f1ad upstream.
USBTMC devices are required to have a bulk-in and a bulk-out endpoint,
but the driver failed to verify this, something which could lead to the
endpoint addresses being taken from uninitialised memory.
Make sure to zero all private data as part of allocation, and add the
missing endpoint sanity check.
Note that this also addresses a more recently introduced issue, where
the interrupt-in-presence flag would also be uninitialised whenever the
optional interrupt-in endpoint is not present. This in turn could lead
to an interrupt urb being allocated, initialised and submitted based on
uninitialised values.
Fixes: dbf3e7f654c0 ("Implement an ioctl to support the USMTMC-USB488 READ_STATUS_BYTE operation.")
Fixes: 5b775f672cc9 ("USB: add USB test and measurement class driver")
Signed-off-by: Johan Hovold <johan@kernel.org>
[ johan: backport to v4.4 ]
commit 9b622e2bbcf049c82e2550d35fb54ac205965f50 upstream.
md pending write counter must be incremented after bio is split,
otherwise it gets decremented too many times in end bio callback and
becomes negative.
Signed-off-by: Tomasz Majchrzak <tomasz.majchrzak@intel.com>
Reviewed-by: Artur Paszkiewicz <artur.paszkiewicz@intel.com>
Signed-off-by: Shaohua Li <shli@fb.com>
commit ff010472fb75670cb5c08671e820eeea3af59c87 upstream.
On CPU online the cpufreq core restores the previous governor (or
the previous "policy" setting for ->setpolicy drivers), but it does
not restore the min/max limits at the same time, which is confusing,
inconsistent and real pain for users who set the limits and then
suspend/resume the system (using full suspend), in which case the
limits are reset on all CPUs except for the boot one.
Fix this by making cpufreq_online() restore the limits when an inactive
policy is brought online.
The commit log and patch are inspired from Rafael's earlier work.
Reported-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
commit 5003ae1e735e6bfe4679d9bed6846274f322e77e upstream.
The function device_to_iommu() in the Intel VT-d driver
lacks a NULL-ptr check, resulting in this oops at boot on
some platforms:
BUG: unable to handle kernel NULL pointer dereference at 00000000000007ab
IP: [<ffffffff8132234a>] device_to_iommu+0x11a/0x1a0
PGD 0
Call Trace:
? find_or_alloc_domain.constprop.29+0x1a/0x300
? dw_dma_probe+0x561/0x580 [dw_dmac_core]
? __get_valid_domain_for_dev+0x39/0x120
? __intel_map_single+0x138/0x180
? intel_alloc_coherent+0xb6/0x120
? sst_hsw_dsp_init+0x173/0x420 [snd_soc_sst_haswell_pcm]
? mutex_lock+0x9/0x30
? kernfs_add_one+0xdb/0x130
? devres_add+0x19/0x60
? hsw_pcm_dev_probe+0x46/0xd0 [snd_soc_sst_haswell_pcm]
? platform_drv_probe+0x30/0x90
? driver_probe_device+0x1ed/0x2b0
? __driver_attach+0x8f/0xa0
? driver_probe_device+0x2b0/0x2b0
? bus_for_each_dev+0x55/0x90
? bus_add_driver+0x110/0x210
? 0xffffffffa11ea000
? driver_register+0x52/0xc0
? do_one_initcall+0x32/0x130
? free_vmap_area_noflush+0x37/0x70
? kmem_cache_alloc+0x88/0xd0
? do_init_module+0x51/0x1c4
? load_module+0x1ee9/0x2430
? show_taint+0x20/0x20
? kernel_read_file+0xfd/0x190
? SyS_finit_module+0xa3/0xb0
? do_syscall_64+0x4a/0xb0
? entry_SYSCALL64_slow_path+0x25/0x25
Code: 78 ff ff ff 4d 85 c0 74 ee 49 8b 5a 10 0f b6 9b e0 00 00 00 41 38 98 e0 00 00 00 77 da 0f b6 eb 49 39 a8 88 00 00 00 72 ce eb 8f <41> f6 82 ab 07 00 00 04 0f 85 76 ff ff ff 0f b6 4d 08 88 0e 49
RIP [<ffffffff8132234a>] device_to_iommu+0x11a/0x1a0
RSP <ffffc90001457a78>
CR2: 00000000000007ab
---[ end trace 16f974b6d58d0aad ]---
Add the missing pointer check.
Fixes: 1c387188c60f53b338c20eee32db055dfe022a9b ("iommu/vt-d: Fix IOMMU lookup for SR-IOV Virtual Functions")
Signed-off-by: Koos Vriezen <koos.vriezen@gmail.com>
Signed-off-by: Joerg Roedel <jroedel@suse.de>
commit 1914f0cd203c941bba72f9452c8290324f1ef3dc upstream.
This was broken in commit cd979883b9ed ("xen/acpi-processor:
fix enabling interrupts on syscore_resume"). do_suspend (from
xen/manage.c) and thus xen_resume_notifier never get called on
the initial-domain at resume (it is if running as guest.)
The rationale for the breaking change was that upload_pm_data()
potentially does blocking work in syscore_resume(). This patch
addresses the original issue by scheduling upload_pm_data() to
execute in workqueue context.
Cc: Stanislaw Gruszka <sgruszka@redhat.com>
Based-on-patch-by: Konrad Wilk <konrad.wilk@oracle.com>
Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Reviewed-by: Stanislaw Gruszka <sgruszka@redhat.com>
Signed-off-by: Ankur Arora <ankur.a.arora@oracle.com>
Signed-off-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
commit e2ebfb2142acefecc2496e71360f50d25726040b upstream.
Disabling interrupts for even a millisecond can cause problems for some
devices. That can happen when sdhci changes clock frequency because it
waits for the clock to become stable under a spin lock.
The spin lock is not necessary here. Anything that is racing with changes
to the I/O state is already broken. The mmc core already provides
synchronization via "claiming" the host.
Although the spin lock probably should be removed from the code paths that
lead to this point, such a patch would touch too much code to be suitable
for stable trees. Consequently, for this patch, just drop the spin lock
while waiting.
Signed-off-by: Adrian Hunter <adrian.hunter@intel.com>
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
Tested-by: Ludovic Desroches <ludovic.desroches@microchip.com>
commit 03270c6ac6207fc55bbf9d20d195029dca210c79 upstream.
Usually every parallel port will have a single pardev registered with
it. But ppdev driver is an exception. This userspace parallel port
driver allows to create multiple parrallel port devices for a single
parallel port. And as a result we were having a nice warning like:
"sysctl table check failed:
/dev/parport/parport0/devices/ppdev0/timeslice Sysctl already exists"
Use the same logic as used in parport_register_device() and register
the proc files only once for each parallel port.
Fixes: 6fa45a226897 ("parport: add device-model to parport subsystem")
Bugzilla: https://bugzilla.redhat.com/show_bug.cgi?id=1414656
Bugzilla: https://bugs.archlinux.org/task/52322
Tested-by: James Feeney <james@nurealm.net>
Signed-off-by: Sudip Mukherjee <sudip.mukherjee@codethink.co.uk>
sensor properties losing after resume from S3
commit 3bec247474469f769af41e8c80d3a100dd97dd76 upstream.
In function _hid_sensor_power_state(), when hid_sensor_read_poll_value()
is called, sensor's all properties will be updated by the value from
sensor hardware/firmware.
In some implementation, sensor hardware/firmware will do a power cycle
during S3. In this case, after resume, once hid_sensor_read_poll_value()
is called, sensor's all properties which are kept by driver during S3
will be changed to default value.
But instead, if a set feature function is called first, sensor
hardware/firmware will be recovered to the last status. So change the
sensor_hub_set_feature() calling order to behind of set feature function
to avoid sensor properties lose.
Signed-off-by: Song Hongyan <hongyan.song@intel.com>
Acked-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com>
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
commit e83bb3e6f3efa21f4a9d883a25d0ecd9dfb431e1 upstream.
The tiadc_irq_h(int irq, void *private) function is handling FIFO
overruns by clearing flags, disabling and enabling the ADC to
recover.
If the ADC is running in continuous mode a FIFO overrun happens
regularly. If the disabling of the ADC happens concurrently with
a new conversion. It might happen that the enabling of the ADC
is ignored by the hardware. This stops the ADC permanently. No
more interrupts are triggered.
According to the AM335x Reference Manual (SPRUH73H October 2011 -
Revised April 2013 - Chapter 12.4 and 12.5) it is necessary to
check the ADC FSM bits in REG_ADCFSM before enabling the ADC
again. Because the disabling of the ADC is done right after the
current conversion has been finished.
To trigger this bug it is necessary to run the ADC in continuous
mode. The ADC values of all channels need to be read in an endless
loop. The bug appears within the first 6 hours (~5.4 million
handled FIFO overruns). The user space application will hang on
reading new values from the character device.
Fixes: ca9a563805f7a ("iio: ti_am335x_adc: Add continuous sampling support")
Signed-off-by: Michael Engl <michael.engl@wjw-solutions.com>
commit 181302dc7239add8ab1449c23ecab193f52ee6ab upstream.
Make sure to check the number of endpoints to avoid dereferencing a
NULL-pointer should a malicious device lack endpoints.
Fixes: 53f3a9e26ed5 ("mmc: USB SD Host Controller (USHC) driver")
Cc: David Vrabel <david.vrabel@csr.com>
commit daf229b15907fbfdb6ee183aac8ca428cb57e361 upstream.
Note that the dereference happens in the start callback which is called
during probe.
Fixes: de520b8bd552 ("uwb: add HWA radio controller driver")
Cc: Inaky Perez-Gonzalez <inaky.perez-gonzalez@intel.com>
commit 4ce362711d78a4999011add3115b8f4b0bc25e8c upstream.
Note that the dereference happens in the cmd and wait_init_done
callbacks which are called during probe.
Fixes: 1ba47da52712 ("uwb: add the i1480 DFU driver")
commit 7b2db29fbb4e766fcd02207eb2e2087170bd6ebc upstream.
If usb_get_bos_descriptor() returns an error, usb->bos will be NULL.
Nevertheless, it is dereferenced unconditionally in
hub_set_initial_usb2_lpm_policy() if usb2_hw_lpm_capable is set.
This results in a crash.
usb 5-1: unable to get BOS descriptor
Unable to handle kernel NULL pointer dereference at virtual address 00000008
pgd = ffffffc00165f000
[00000008] *pgd=000000000174f003, *pud=000000000174f003,
*pmd=0000000001750003, *pte=00e8000001751713
Internal error: Oops: 96000005 [#1] PREEMPT SMP
Modules linked in: uinput uvcvideo videobuf2_vmalloc cmac [ ... ]
CPU: 5 PID: 3353 Comm: kworker/5:3 Tainted: G B 4.4.52 #480
Hardware name: Google Kevin (DT)
Workqueue: events driver_set_config_work
task: ffffffc0c3690000 ti: ffffffc0ae9a8000 task.ti: ffffffc0ae9a8000
PC is at hub_port_init+0xc3c/0xd10
LR is at hub_port_init+0xc3c/0xd10
Call trace:
[<ffffffc0007fbbfc>] hub_port_init+0xc3c/0xd10
[<ffffffc0007fbe2c>] usb_reset_and_verify_device+0x15c/0x82c
[<ffffffc0007fc5e0>] usb_reset_device+0xe4/0x298
[<ffffffbffc0e3fcc>] rtl8152_probe+0x84/0x9b0 [r8152]
[<ffffffc00080ca8c>] usb_probe_interface+0x244/0x2f8
[<ffffffc000774a24>] driver_probe_device+0x180/0x3b4
[<ffffffc000774e48>] __device_attach_driver+0xb4/0xe0
[<ffffffc000772168>] bus_for_each_drv+0xb4/0xe4
[<ffffffc0007747ec>] __device_attach+0xd0/0x158
[<ffffffc000775080>] device_initial_probe+0x24/0x30
[<ffffffc0007739d4>] bus_probe_device+0x50/0xe4
[<ffffffc000770bd0>] device_add+0x414/0x738
[<ffffffc000809fe8>] usb_set_configuration+0x89c/0x914
[<ffffffc00080a120>] driver_set_config_work+0xc0/0xf0
[<ffffffc000249bb8>] process_one_work+0x390/0x6b8
[<ffffffc00024abcc>] worker_thread+0x480/0x610
[<ffffffc000251a80>] kthread+0x164/0x178
[<ffffffc0002045d0>] ret_from_fork+0x10/0x40
Since we don't know anything about LPM capabilities without BOS descriptor,
don't attempt to enable LPM if it is not available.
Fixes: 890dae886721 ("xhci: Enable LPM support only for hardwired ...")
Cc: Mathias Nyman <mathias.nyman@linux.intel.com>
Acked-by: Mathias Nyman <mathias.nyman@linux.intel.com>
commit 0090114d336a9604aa2d90bc83f20f7cd121b76c upstream.
The CPPI 4.1 driver polls register to workaround the premature TX
interrupt issue, but it causes audio playback underrun when triggered in
Isoch transfers.
Isoch doesn't do back-to-back transfers, the TX should be done by the
time the next transfer is scheduled. So skip this polling workaround for
Isoch transfer.
Fixes: a655f481d83d6 ("usb: musb: musb_cppi41: handle pre-mature TX complete interrupt")
Reported-by: Alexandre Bailon <abailon@baylibre.com>
Acked-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Tested-by: Alexandre Bailon <abailon@baylibre.com>
Signed-off-by: Bin Liu <b-liu@ti.com>
commit 03ace948a4eb89d1cf51c06afdfc41ebca5fdb27 upstream.
NULL-pointer or accessing memory beyond the endpoint array should a
malicious device lack the expected endpoints.
This specifically fixes the NULL-pointer dereference when probing HWA HC
devices.
Fixes: df3654236e31 ("wusb: add the Wire Adapter (WA) core")
commit b0addd3fa6bcd119be9428996d5d4522479ab240 upstream.
Fixes: 1da177e4c3f4 ("Linux-2.6.12-rc2")
commit 1dc56c52d2484be09c7398a5207d6b11a4256be9 upstream.
NULL-pointer should the probed device lack endpoints.
Note that this driver does not bind to any devices by default.
Fixes: ce21bfe603b3 ("USB: Add LVS Test device driver")
Cc: Pratyush Anand <pratyush.anand@gmail.com>
commit f259ca3eed6e4b79ac3d5c5c9fb259fb46e86217 upstream.
Note that the endpoint access that causes the NULL-deref is currently
only used for debugging purposes during probe so the oops only happens
when dynamic debugging is enabled. This means the driver could be
rewritten to continue to accept device with only two endpoints, should
such devices exist.
commit 3243367b209faed5c320a4e5f9a565ee2a2ba958 upstream.
Some USB 2.0 devices erroneously report millisecond values in
bInterval. The generic config code manages to catch most of them,
but in some cases it's not completely enough.
The case at stake here is a USB 2.0 braille device, which wants to
announce 10ms and thus sets bInterval to 10, but with the USB 2.0
computation that yields to 64ms. It happens that one can type fast
enough to reach this interval and get the device buffers overflown,
leading to problematic latencies. The generic config code does not
catch this case because the 64ms is considered a sane enough value.
This change thus adds a USB_QUIRK_LINEAR_FRAME_INTR_BINTERVAL quirk
to mark devices which actually report milliseconds in bInterval,
and marks Vario Ultra devices as needing it.
Signed-off-by: Samuel Thibault <samuel.thibault@ens-lyon.org>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
commit 09424c50b7dff40cb30011c09114404a4656e023 upstream.
The streaming_maxburst module parameter is 0 offset (0..15)
so we must add 1 while using it for wBytesPerInterval
calculation for the SuperSpeed companion descriptor.
Without this host uvcvideo driver will always see the wrong
wBytesPerInterval for SuperSpeed uvc gadget and may not find
a suitable video interface endpoint.
e.g. for streaming_maxburst = 0 case it will always
fail as wBytePerInterval was evaluating to 0.
Reviewed-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Signed-off-by: Roger Quadros <rogerq@ti.com>
Signed-off-by: Felipe Balbi <felipe.balbi@linux.intel.com>
commit cdd7928df0d2efaa3270d711963773a08a4cc8ab upstream.
The gadget code exports the bitfield for serial status changes
over the wire in its internal endianness. The fix is to convert
to little endian before sending it over the wire.
Signed-off-by: Oliver Neukum <oneukum@suse.com>
Tested-by: 家瑋 <momo1208@gmail.com>
commit 436ecf5519d892397af133a79ccd38a17c25fa51 upstream.
This is a Dell branded Sierra Wireless EM7455.
Signed-off-by: Bjørn Mork <bjorn@mork.no>
commit 6e9f44eaaef0df7b846e9316fa9ca72a02025d44 upstream.
Add Quectel UC15, UC20, EC21, and EC25. The EC20 is handled by
qcserial due to a USB VID/PID conflict with an existing Acer
device.
Signed-off-by: Dan Williams <dcbw@redhat.com>
commit 92461f5d723037530c1f36cce93640770037812c upstream.
NULL-pointer or accessing memory that lie beyond the end of the endpoint
array should a malicious device lack the expected endpoints.
Fixes: bdb5c57f209c ("Input: add sur40 driver for Samsung SUR40... ")
commit cb1b494663e037253337623bf1ef2df727883cb7 upstream.
commit ac2ee9ba953afe88f7a673e1c0c839227b1d7891 upstream.
Fixes: c04148f915e5 ("Input: add driver for USB VoIP phones with CM109...")
commit 5cc4a1a9f5c179795c8a1f2b0f4361829d6a070e upstream.
Fixes: aca951a22a1d ("[PATCH] input-driver-yealink-P1K-usb-phone")
commit ba340d7b83703768ce566f53f857543359aa1b98 upstream.
Fixes: bba5394ad3bd ("Input: add support for Hanwang tablets")
commit 1916d319271664241b7aa0cd2b05e32bdb310ce9 upstream.
NULL-pointer should a malicious device lack control-interface endpoints.
Fixes: 628329d52474 ("Input: add IMS Passenger Control Unit driver")
commit 59cf8bed44a79ec42303151dd014fdb6434254bb upstream.
commit 45838660e34d90db8d4f7cbc8fd66e8aff79f4fe upstream.
The aux port does not get detected without noloop quirk, so external PS/2
mouse cannot work as result.
The PS/2 mouse can work with this quirk.
BugLink: https://bugs.launchpad.net/bugs/1591053
Signed-off-by: Kai-Heng Feng <kai.heng.feng@canonical.com>
Reviewed-by: Marcos Paulo de Souza <marcos.souza.org@gmail.com>
commit 92ef6f97a66e580189a41a132d0f8a9f78d6ddce upstream.
EeeBook X205TA is yet another ASUS device with a special touchpad
firmware that needs to be accounted for during initialization, or
else the touchpad will go into an invalid state upon suspend/resume.
Adding the appropriate ic_type and product_id check fixes the problem.
Signed-off-by: Matjaz Hegedic <matjaz.hegedic@gmail.com>
Acked-by: KT Liao <kt.liao@emc.com.tw>
[ Upstream commit 31739eae738ccbe8b9d627c3f2251017ca03f4d2 ]
Commit 6ac3ce8295e6 ("net: bcmgenet: Remove excessive PHY reset")
removed the bcmgenet_mii_reset() function from bcmgenet_power_up() and
bcmgenet_internal_phy_setup() functions. In so doing it broke the reset
of the internal PHY devices used by the GENETv1-GENETv3 which required
this reset before the UniMAC was enabled. It also broke the internal
GPHY devices used by the GENETv4 because the config_init that installed
the AFE workaround was no longer occurring after the reset of the GPHY
performed by bcmgenet_phy_power_set() in bcmgenet_internal_phy_setup().
In addition the code in bcmgenet_internal_phy_setup() related to the
"enable APD" comment goes with the bcmgenet_mii_reset() so it should
have also been removed.
Commit bd4060a6108b ("net: bcmgenet: Power on integrated GPHY in
bcmgenet_power_up()") moved the bcmgenet_phy_power_set() call to the
bcmgenet_power_up() function, but failed to remove it from the
bcmgenet_internal_phy_setup() function. Had it done so, the
bcmgenet_internal_phy_setup() function would have been empty and could
have been removed at that time.
Commit 5dbebbb44a6a ("net: bcmgenet: Software reset EPHY after power on")
was submitted to correct the functional problems introduced by
commit 6ac3ce8295e6 ("net: bcmgenet: Remove excessive PHY reset"). It
was included in v4.4 and made available on 4.3-stable. Unfortunately,
it didn't fully revert the commit because this bcmgenet_mii_reset()
doesn't apply the soft reset to the internal GPHY used by GENETv4 like
the previous one did. This prevents the restoration of the AFE work-
arounds for internal GPHY devices after the bcmgenet_phy_power_set() in
This commit takes the alternate approach of removing the unnecessary
bcmgenet_internal_phy_setup() function which shouldn't have been in v4.3
so that when bcmgenet_mii_reset() was restored it should have only gone
into bcmgenet_power_up(). This will avoid the problems while also
removing the redundancy (and hopefully some of the confusion).
Fixes: 6ac3ce8295e6 ("net: bcmgenet: Remove excessive PHY reset")
Signed-off-by: Doug Berger <opendmb@gmail.com>
Reviewed-by: Florian Fainelli <f.fainelli@gmail.com>
