commit f974008f07a62171a9dede08250c9a35c2b2b986 upstream.
Add keyboard input assist controls usages from approved
hid usage table request HUTTR42:
http://www.usb.org/developers/hidpage/HUTRR42c.pdf
Signed-off-by: Olivier Gay <ogay@logitech.com>
Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
commit a87fa1d81a9fb5e9adca9820e16008c40ad09f33 upstream.
The string property read helpers will run off the end of the buffer if
it is handed a malformed string property. Rework the parsers to make
sure that doesn't happen. At the same time add new test cases to make
sure the functions behave themselves.
The original implementations of of_property_read_string_index() and
of_property_count_strings() both open-coded the same block of parsing
code, each with it's own subtly different bugs. The fix here merges
functions into a single helper and makes the original functions static
inline wrappers around the helper.
One non-bugfix aspect of this patch is the addition of a new wrapper,
of_property_read_string_array(). The new wrapper is needed by the
device_properties feature that Rafael is working on and planning to
merge for v3.19. The implementation is identical both with and without
the new static inline wrapper, so it just got left in to reduce the
churn on the header file.
Signed-off-by: Grant Likely <grant.likely@linaro.org>
Cc: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
Cc: Mika Westerberg <mika.westerberg@linux.intel.com>
Cc: Rob Herring <robh+dt@kernel.org>
Cc: Darren Hart <darren.hart@intel.com>
commit e4a60d139060975eb956717e4f63ae348d4d8cc5 upstream.
There is a race condition when removing glue directory.
It can be reproduced in following test:
path 1: Add first child device
device_add()
get_device_parent()
/*find parent from glue_dirs.list*/
list_for_each_entry(k, &dev->class->p->glue_dirs.list, entry)
if (k->parent == parent_kobj) {
kobj = kobject_get(k);
break;
class_dir_create_and_add()
path2: Remove last child device under glue dir
device_del()
cleanup_device_parent()
cleanup_glue_dir()
kobject_put(glue_dir);
If path2 has been called cleanup_glue_dir(), but not
call kobject_put(glue_dir), the glue dir is still
in parent's kset list. Meanwhile, path1 find the glue
dir from the glue_dirs.list. Path2 may release glue dir
before path1 call kobject_get(). So kernel will report
the warning and bug_on.
This is a "classic" problem we have of a kref in a list
that can be found while the last instance could be removed
at the same time.
This patch reuse gdp_mutex to fix this race condition.
The following calltrace is captured in kernel 3.4, but
the latest kernel still has this bug.
<4>[ 3965.441471] WARNING: at ...include/linux/kref.h:41 kobject_get+0x33/0x40()
<4>[ 3965.441474] Hardware name: Romley
<4>[ 3965.441475] Modules linked in: isd_iop(O) isd_xda(O)...
<4>[ 3965.441605] Call Trace:
<4>[ 3965.441611] [<ffffffff8103717a>] warn_slowpath_common+0x7a/0xb0
<4>[ 3965.441615] [<ffffffff810371c5>] warn_slowpath_null+0x15/0x20
<4>[ 3965.441618] [<ffffffff81215963>] kobject_get+0x33/0x40
<4>[ 3965.441624] [<ffffffff812d1e45>] get_device_parent.isra.11+0x135/0x1f0
<4>[ 3965.441627] [<ffffffff812d22d4>] device_add+0xd4/0x6d0
<4>[ 3965.441631] [<ffffffff812d0dbc>] ? dev_set_name+0x3c/0x40
<2>[ 3965.441912] kernel BUG at ..../fs/sysfs/group.c:65!
<4>[ 3965.441915] invalid opcode: 0000 [#1] SMP
<4>[ 3965.686743] [<ffffffff811a677e>] sysfs_create_group+0xe/0x10
<4>[ 3965.686748] [<ffffffff810cfb04>] blk_trace_init_sysfs+0x14/0x20
<4>[ 3965.686753] [<ffffffff811fcabb>] blk_register_queue+0x3b/0x120
<4>[ 3965.686756] [<ffffffff812030bc>] add_disk+0x1cc/0x490
Signed-off-by: Yijing Wang <wangyijing@huawei.com>
Signed-off-by: Weng Meiling <wengmeiling.weng@huawei.com>
commit 11cfbfb098b22d3e57f1f2be217cad20e2d48463 upstream.
iowait is for blkio [1]. I2C shouldn't use it.
[1] https://lkml.org/lkml/2014/11/3/317
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
Acked-by: Ludovic Desroches <ludovic.desroches@atmel.com>
commit 758e8366754d3fa57da978fef9d2c652f7b55c02 upstream.
In both Armada-375 and Armada-38x MPIC interrupts should be identified by
reading cause register multiplied by the interrupt mask.
A lack of above mentioned multiplication resulted in a bug, caused by the
fact that in Armada-375 and Armada-38x some of the interrupts
(e.g. network interrupts) can be handled either as a GIC or MPIC interrupts.
Therefore during MPIC interrupts handling, cause register shows hits from
interrupts even if they are masked for MPIC but unmasked for a GIC.
This resulted in 'bad IRQ' error, because masked MPIC interrupt without
registered interrupt handler, was trying to be handled during interrupt
handling procedure of some other unmasked MPIC interrupt (e.g. local timer
irq).
This commit fixes that by ensuring that during MPIC interrupt handling only
interrupts that are unmasked for MPIC are processed.
Signed-off-by: Grzegorz Jaszczyk <jaz@semihalf.com>
Reviewed-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
Fixes: bc69b8adfe22 ("irqchip: armada-370-xp: Setup a chained handler for the MPIC")
Acked-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com>
Link: https://lkml.kernel.org/r/1411643839-64925-3-git-send-email-jaz@semihalf.com
Signed-off-by: Jason Cooper <jason@lakedaemon.net>
commit 298dcb2dd0267d51e4f7c94a628cd0765a50ad75 upstream.
The MSI interrupts use the 16 high doorbells, which are notified by using IRQ1
of the main interrupt controller.
The MSI interrupts were handled correctly for Armada-XP and Armada-370 but not
for Armada-375 and Armada-38x, which use chained handler for the MPIC.
This commit fixes that by checking proper interrupt number in chained handler
for the MPIC.
Link: https://lkml.kernel.org/r/1411643839-64925-2-git-send-email-jaz@semihalf.com
commit ca0c37a0b489bb14bf3e1549e7a8d0c9a17f4919 upstream.
Driver allocated on stack struct regulator_config but didn't initialize
it fully. Few fields (driver_data, ena_gpio) were left untouched. This
lead to using random ena_gpio values as GPIOs for max77693 regulators.
On occasion these values could match real GPIO numbers leading to
interfering with other drivers and to unsuccessful enable/disable of
regulator.
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Fixes: 80b022e29bfd ("regulator: max77693: Add max77693 regualtor driver.")
Signed-off-by: Mark Brown <broonie@kernel.org>
commit d90c33818967c5e5371961604ad98b4dea4fa3f4 upstream.
Even if a gpio pin is set to output, we still need to set INPUT_EN
functionality (by clearing INPUT_EN bit) to be able to read the pin's
level.
E.g. without this change, we'll always read low level state from sysfs.
Cc: Mathias Nyman <mathias.nyman@linux.intel.com>
Signed-off-by: David Cohen <david.a.cohen@linux.intel.com>
Reviewed-by: Felipe Balbi <balbi@ti.com>
commit 5a1426c99f9b7aa11d60c4e6b7a3211bb5321696 upstream.
The acpi-video backlight interface on the NC210 does not work, blacklist it
and use the samsung-laptop interface instead.
BugLink: https://bugzilla.redhat.com/show_bug.cgi?id=861573
Signed-off-by: Darren Hart <dvhart@linux.intel.com>
commit 183fd8fcd7f8afb7ac5ec68f83194872f9fecc84 upstream.
The acpi-video backlight interface on the Acer KAV80 is broken, and worse
it causes the entire machine to slow down significantly after a suspend/resume.
Blacklist it, and use the acer-wmi backlight interface instead. Note that
the KAV80 is somewhat unique in that it is the only Acer model where we
fall back to acer-wmi after blacklisting, rather then using the native
(e.g. intel) backlight driver. This is done because there is no native
backlight interface on this model.
BugLink: https://bugzilla.redhat.com/show_bug.cgi?id=1128309
commit a8d4205623ae965e36c68629db306ca0695a2771 upstream.
When we fail to allocate page vector in rbd_obj_read_sync() we just
basically ignore the problem and continue which will result in an oops
later. Fix the problem by returning proper error.
CC: Yehuda Sadeh <yehuda@inktank.com>
CC: Sage Weil <sage@inktank.com>
CC: ceph-devel@vger.kernel.org
Coverity-id: 1226882
Signed-off-by: Ilya Dryomov <idryomov@redhat.com>
commit b2a9601c587dbc5536546aa54009d1130adedd72 upstream.
commit c675949ec58ca50d5a3ae3c757892f1560f6e896
Author: Jani Nikula <jani.nikula@intel.com>
Date: Wed Apr 9 11:31:37 2014 +0300
drm/i915: do not setup backlight if not available according to VBT
prevents backlight setup on Macbook 2,1. Apply quirk to ignore the VBT
check so backlight is set up properly.
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=81438
Signed-off-by: Jens Stein Jørgensen <jens.s.stein@gmail.com>
Signed-off-by: Jani Nikula <jani.nikula@intel.com>
commit 6be1e3d3ea29354d7c834a3936e796e185d5c73b upstream.
vlv_cdclk_freq is in kHz but we need MHz for the GMBUSFREQ divider.
This is a regression from:
commit f8bf63fdcb1f82459dae7a3f22ee5ce92f3ea727
Author: Ville Syrjälä <ville.syrjala@linux.intel.com>
Date: Fri Jun 13 13:37:54 2014 +0300
drm/i915: Kill duplicated cdclk readout code from i2c
Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com>
commit f6a1906674005377b64ee5431c1418077c1b2425 upstream.
Sometimes we seem to get utter garbage from DPCD reads. The resulting
buffer is filled with the same byte, and the operation completed without
errors. My HP ZR24w monitor seems particularly susceptible to this
problem once it's gone into a sleep mode.
The issue seems to happen only for the first AUX message that wakes the
sink up. But as the first AUX read we often do is the DPCD receiver
cap it does wreak a bit of havoc with subsequent link training etc. when
the receiver cap bw/lane/etc. information is garbage.
A sufficient workaround seems to be to perform a single byte dummy read
before reading the actual data. I suppose that just wakes up the sink
sufficiently and we can just throw away the returned data in case it's
crap. DP_DPCD_REV seems like a sufficiently safe location to read here.
Reviewed-by: Todd Previte <tprevite@gmail.com>
commit 72b3f9183ed57e4a2f0601a1c25ae2fd39855952 upstream.
- bapm seems to cause CPU stuck messages so disable it.
- nb dpm seems to prevent GPU dpm from getting enabled, so
disable it.
bug:
https://bugs.freedesktop.org/show_bug.cgi?id=85107
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
commit e5a5fd4df21b9c4acb67e815ec949cce594860f8 upstream.
Should avoid kmalloc failures due to large number of array entries.
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=81991
Reviewed-by: Dave Airlie <airlied@redhat.com>
Reviewed-by: Christian König <christian.koenig@amd.com>
Signed-off-by: Michel Dänzer <michel.daenzer@amd.com>
commit 6fa455935ab956248b165f150ec6ae9106210077 upstream.
Causes problems on some boards.
bug:
https://bugs.freedesktop.org/show_bug.cgi?id=82889
commit 9a72384d86b26cb8a2b25106677e1197f606668f upstream.
When screen objects are enabled, the bpp is assumed to be 32, otherwise
it is set to 16.
v2:
* Use u32 instead of u64 for assumed_bpp.
* Fixed mechanism to check for screen objects
* Limit the back buffer size to VRAM.
Signed-off-by: Sinclair Yeh <syeh@vmware.com>
Reviewed-by: Thomas Hellstrom <thellstrom@vmware.com>
[ Upstream commit 52ec49a5e56a27c5b6f8217708783eff39f24c16 ]
During Halt Endpoint Test, our interrupt endpoint
will be disabled, which will clear out ep->desc
to NULL. Unless we call config_ep_by_speed() again,
we will not be able to enable this endpoint which
will make us fail that test.
Fixes: f9c56cd (usb: gadget: Clear usb_endpoint_descriptor
inside the struct usb_ep on disable)
Signed-off-by: Felipe Balbi <balbi@ti.com>
[ Upstream commit 7a60855972f0d3c014093046cb6f013a1ee5bb19 ]
According to our Gadget Framework API documentation,
->set_halt() *must* return -EAGAIN if we have pending
transfers (on either direction) or FIFO isn't empty (on
TX endpoints).
Fix this bug so that the mass storage gadget can be used
without stall=0 parameter.
This patch should be backported to all kernels since v3.2.
Suggested-by: Alan Stern <stern@rowland.harvard.edu>
Based on a5b7616c55e188fe3d6ef686bef402d4703ecb62, but backported so
that a bunch of dependencies are not needed.
m25p80's device ID table is now spi_nor_ids, defined in spi-nor. The
MODULE_DEVICE_TABLE() macro doesn't work with extern definitions, but
its use was also removed at the same time. Now if m25p80 is built as
a module it doesn't get the necessary aliases to be loaded
automatically.
A clean solution to this will involve defining the list of device
IDs in spi-nor.h and removing struct spi_device_id from the spi-nor
API, but this is quite a large change.
As a quick fix suitable for stable, copy the device IDs back into
m25p80.
Fixes: 03e296f613af ("mtd: m25p80: use the SPI nor framework")
[Brian: backport without the dependencies]
Signed-off-by: Brian Norris <computersforpeace@gmail.com>
commit 098bcd2335f0824e76dd835e4e2b7ae8e38fc281 upstream.
The PLAT_S5P Kconfig symbol was removed in commit d78c16ccde96
("ARM: SAMSUNG: Remove remaining legacy code"). However, there
are still some references to that symbol left, fix that by
substituting them with ARCH_S5PV210.
Fixes: d78c16ccde96 ("ARM: SAMSUNG: Remove remaining legacy code")
Reported-by: Paul Bolle <pebolle@tiscali.nl>
Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
commit 89cf38dd536a7301d6b5f5ddd73f42074c01bfaa upstream.
After '#echo mem > /sys/power/state' some devices can not be properly resumed
because apparently the MTD Partition Configuration Register has been reset
to default thus the rootfs cannot be mounted cleanly on resume.
An example of this can be found in the SA-1100 Developer's Manual at 9.5.3.3
where the second step of the Sleep Shutdown Sequence is described:
"An internal reset is applied to the SA-1100. All units are reset...".
As workaround we refresh the PCR value as done initially on chip setup.
This behavior and the fix are confirmed by our tests done on 2 different Zaurus
collie units with kernel 3.17.
Fixes: 812c5fa82bae: ("mtd: cfi_cmdset_0001.c: add support for Sharp LH28F640BF NOR")
Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com>
Signed-off-by: Andrea Adami <andrea.adami@gmail.com>
commit 238b5ad855924919e5b98d0c772d9dc78795639b upstream.
As a follow-up to commit 6cab7a37f5c04 ("staging: comedi: (regression)
channel list must be set for COMEDI_CMD ioctl"), Hartley Sweeten pointed
out another couple of bugs stemming from commit 6cab7a37f5c04 ("staging:
comedi: comedi_fops: introduce __comedi_get_user_chanlist()").
Firstly, `do_cmdtest_ioctl()` never frees the kernel copy of the user
chanlist allocated by `__comedi_get_user_chanlist()`, so that memory is
leaked. Fix it by freeing the allocated kernel memory pointed to by
`cmd.chanlist` before that pointer is overwritten with its original
pointer to user memory before `cmd` is copied back to user-space.
Secondly, if `__comedi_get_user_chanlist()` returns an error,
`cmd->chanlist` is left unchanged and in fact will be a pointer to user
memory. This causes `do_cmd_ioctl()` to `goto cleanup` and call
`do_become_nonbusy()` which would attempt to free the memory pointed to
by the user-space pointer. Fix it by setting `cmd->chanlist` to NULL at
the start of `__comedi_get_user_chanlist()`.
Fixes: c6cd0eefb27b ("staging: comedi: comedi_fops: introduce __comedi_get_user_chanlist()")
Reported-by: H Hartley Sweeten <hsweeten@visionengravers.com>
commit 6cab7a37f5c048bb2a768f24b0ec748b052fda09 upstream.
`do_cmd_ioctl()`, the handler for the `COMEDI_CMD` ioctl can incorrectly
call the Comedi subdevice's `do_cmd()` handler with a NULL channel list
pointer. This is a regression as the `do_cmd()` handler has never been
expected to deal with that, leading to a kernel OOPS when it tries to
dereference it.
A NULL channel list pointer is allowed for the `COMEDI_CMDTEST` ioctl,
handled by `do_cmdtest_ioctl()` and the subdevice's `do_cmdtest()`
handler, but not for the `COMEDI_CMD` ioctl and its handlers.
Both `do_cmd_ioctl()` and `do_cmdtest_ioctl()` call
`__comedi_get_user_chanlist()` to copy the channel list from user memory
into dynamically allocated kernel memory and check it for consistency.
That function currently returns 0 if the `user_chanlist` parameter
(pointing to the channel list in user memory) is NULL. That's fine for
`do_cmdtest_ioctl()`, but `do_cmd_ioctl()` incorrectly assumes the
kernel copy of the channel list has been set-up correctly.
Fix it by not allowing the `user_chanlist` parameter to be NULL in
`__comedi_get_user_chanlist()`, and only calling it from
`do_cmdtest_ioctl()` if the parameter is non-NULL.
Thanks to Bernd Porr for reporting the bug via an initial patch sent
privately.
Reported-by: Bernd Porr <mail@berndporr.me.uk>
Signed-off-by: Ian Abbott <abbotti@mev.co.uk>
Reviewed-by: H Hartley Sweeten <hsweeten@visionengravers.com>
Cc: Bernd Porr <mail@berndporr.me.uk>
commit 246ef766743618a7cab059d6c4993270075b173e upstream.
If an asynchronous suspend_late or freeze_late callback fails
during the SUSPEND, FREEZE or QUIESCE phases, we don't propagate the
corresponding error correctly, in effect ignoring the error and
continuing the suspend-to-ram/hibernation. During suspend-to-ram this
could leave some devices without a valid saved context, leading to a
failure to reinitialize them during resume. During hibernation this
could leave some devices active interfeering with the creation /
restoration of the hibernation image. Also this could leave the
corresponding devices without a valid saved context and failure to
Fixes: de377b397272 (PM / sleep: Asynchronous threads for suspend_late)
Signed-off-by: Imre Deak <imre.deak@intel.com>
commit 37b164578826406a173ca7c20d9ba7430134d23e upstream.
Kernel oops can cause the tty to be unreleaseable (for example, if
n_tty_read() crashes while on the read_wait queue). This will cause
tty_release() to endlessly loop without sleeping.
Use a killable sleep timeout which grows by 2n+1 jiffies over the interval
[0, 120 secs.) and then jumps to forever (but still killable).
NB: killable just allows for the task to be rewoken manually, not
to be terminated.
Signed-off-by: Peter Hurley <peter@hurleysoftware.com>
commit 9e326f78713a4421fe11afc2ddeac07698fac131 upstream.
We can call this function for a dummy console that doesn't support
setting the font mapping, which will result in a null ptr BUG. So check
for this case and return error for consoles w/o font mapping support.
Reference: https://bugzilla.kernel.org/show_bug.cgi?id=59321
commit d8e7d53a2fc14e0830ab728cb84ee19933d3ac8d upstream.
Back in commit 5136b2da770d ("PCI: convert bus code to use dev_groups"),
I misstyped the 'enable' sysfs filename as 'enabled', which broke the
userspace API. This patch fixes that issue by renaming the file back.
Fixes: 5136b2da770d ("PCI: convert bus code to use dev_groups")
Reported-by: Jeff Epler <jepler@unpythonic.net>
Tested-by: Jeff Epler <jepler@unpythonic.net> # on v3.14-rt
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
commit 1ffde699aae127e7abdb98dbdedc2cc6a973a1a1 upstream.
This reverts commit aa11bbf3df026d6b1c6b528bef634fd9de7c2619.
This commit was causing connection issues and is not needed
if IWL_MVM_RS_RSSI_BASED_INIT_RATE is set to false by default.
Regardless of the issues mentioned above, this patch added the
following WARNING:
WARNING: CPU: 0 PID: 3946 at drivers/net/wireless/iwlwifi/mvm/tx.c:190 iwl_mvm_set_tx_params+0x60a/0x6f0 [iwlmvm]()
Got an HT rate for a non data frame 0x8
CPU: 0 PID: 3946 Comm: wpa_supplicant Tainted: G O 3.17.0+ #6
Hardware name: LENOVO 20ANCTO1WW/20ANCTO1WW, BIOS GLET71WW (2.25 ) 07/02/2014
0000000000000009 ffffffff814fa911 ffff8804288db8f8 ffffffff81064f52
0000000000001808 ffff8804288db948 ffff88040add8660 ffff8804291b5600
0000000000000000 ffffffff81064fb7 ffffffffa07b73d0 0000000000000020
Call Trace:
[<ffffffff814fa911>] ? dump_stack+0x41/0x51
[<ffffffff81064f52>] ? warn_slowpath_common+0x72/0x90
[<ffffffff81064fb7>] ? warn_slowpath_fmt+0x47/0x50
[<ffffffffa07a39ea>] ? iwl_mvm_set_tx_params+0x60a/0x6f0 [iwlmvm]
[<ffffffffa07a3cf8>] ? iwl_mvm_tx_skb+0x48/0x3c0 [iwlmvm]
[<ffffffffa079cb9b>] ? iwl_mvm_mac_tx+0x7b/0x180 [iwlmvm]
[<ffffffffa0746ce9>] ? __ieee80211_tx+0x2b9/0x3c0 [mac80211]
[<ffffffffa07492f3>] ? ieee80211_tx+0xb3/0x100 [mac80211]
[<ffffffffa0749c49>] ? ieee80211_subif_start_xmit+0x459/0xca0 [mac80211]
[<ffffffff814116e7>] ? dev_hard_start_xmit+0x337/0x5f0
[<ffffffff81430d46>] ? sch_direct_xmit+0x96/0x1f0
[<ffffffff81411ba3>] ? __dev_queue_xmit+0x203/0x4f0
[<ffffffff8142f670>] ? ether_setup+0x70/0x70
[<ffffffff814e96a1>] ? packet_sendmsg+0xf81/0x1110
[<ffffffff8140625c>] ? skb_free_datagram+0xc/0x40
[<ffffffff813f7538>] ? sock_sendmsg+0x88/0xc0
[<ffffffff813f7274>] ? move_addr_to_kernel.part.20+0x14/0x60
[<ffffffff811c47c2>] ? __inode_wait_for_writeback+0x62/0xb0
[<ffffffff813f7a91>] ? SYSC_sendto+0xf1/0x180
[<ffffffff813f88f9>] ? __sys_recvmsg+0x39/0x70
[<ffffffff8150066d>] ? system_call_fastpath+0x1a/0x1f
---[ end trace cc19a150d311fc63 ]---
which was reported here: https://bugzilla.kernel.org/show_bug.cgi?id=85691
Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
commit a0855054e59b0c5b2b00237fdb5147f7bcc18efb upstream.
When mac80211 wants to ensure that a frame is sent, it calls
the flush() callback. Until now, iwldvm implemented this by
waiting that all the frames are sent (ACKed or timeout).
In case of weak signal, this can take a significant amount
of time, delaying the next connection (in case of roaming).
Many users have reported that the flush would take too long
leading to the following error messages to be printed:
iwlwifi 0000:03:00.0: fail to flush all tx fifo queues Q 2
iwlwifi 0000:03:00.0: Current SW read_ptr 161 write_ptr 201
iwl data: 00000000: 00 00 00 00 00 00 00 00 fe ff 01 00 00 00 00 00
[snip]
iwlwifi 0000:03:00.0: FH TRBs(0) = 0x00000000
[snip]
iwlwifi 0000:03:00.0: Q 0 is active and mapped to fifo 3 ra_tid 0x0000 [9,9]
[snip]
Instead of waiting for these packets, simply drop them. This
significantly improves the responsiveness of the network.
Note that all the queues are flushed, but the VO one. This
is not typically used by the applications and it likely
contains management frames that are useful for connection
or roaming.
This bug is tracked here:
https://bugzilla.kernel.org/show_bug.cgi?id=56581
But it is duplicated in distributions' trackers.
A simple search in Ubuntu's database led to these bugs:
https://bugs.launchpad.net/ubuntu/+source/linux-firmware/+bug/1270808
https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1305406
https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1356236
https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1360597
https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1361809
Depends-on: 77be2c54c5bd ("mac80211: add vif to flush call")
commit 9180ac50716a097a407c6d7e7e4589754a922260 upstream.
The LTR is the handshake between the device and the root
complex about the latency allowed when the bus exits power
save. This configuration was missing and this led to high
latency in the link power up. The end user could experience
high latency in the network because of this.
commit d14b28fd2c61af0bf310230472e342864d799c98 upstream.
Fixes: 2adc8949efab ("iwlwifi: mvm: BT Coex - fix boost register / LUT values")
commit fa19ac4b92bc2b5024af3e868f41f81fa738567a upstream.
Fix UE event being reported as HW_EVENT_ERR_CORRECTED.
Signed-off-by: Jason Baron <jbaron@akamai.com>
Link: http://lkml.kernel.org/r/8beb13803500076fef827eab33d523e355d83759.1413405053.git.jbaron@akamai.com
commit 8030122a9ccf939186f8db96c318dbb99b5463f6 upstream.
Fix CE event being reported as HW_EVENT_ERR_UNCORRECTED.
Link: http://lkml.kernel.org/r/e6dd616f2cd51583a7e77af6f639b86313c74144.1413405053.git.jbaron@akamai.com
commit 8a3f075d6c9b3612b4a5fb2af8db82b38b20caf0 upstream.
Link: http://lkml.kernel.org/r/d02465b4f30314b390c12c061502eda5e9d29c52.1413405053.git.jbaron@akamai.com
commit ab0543de6ff0877474f57a5aafbb51a61e88676f upstream.
Link: http://lkml.kernel.org/r/7aee8e244a32ff86b399a8f966c4aae70296aae0.1413405053.git.jbaron@akamai.com
commit b1dd2aac4cc0892b82ec60232ed37e3b0af776cc upstream.
To generate the right SPI tag messages we need to properly set
QUEUE_FLAG_QUEUED in the request_queue and mirror it to the
request.
Reviewed-by: Martin K. Petersen <martin.petersen@oracle.com>
Acked-by: Jens Axboe <axboe@kernel.dk>
Reported-by: Meelis Roos <mroos@linux.ee>
Tested-by: Meelis Roos <mroos@linux.ee>
commit 2391eacbd00b706ff4902db7dbee21e33b6f1850 upstream.
Streams seem to be broken on the Asmedia 1042. An uas capable Seagate disk
which is known to work fine with other controllers causes the system to freeze
when connected over usb-3 with this controller, where as it works fine with
uas in usb-2 ports, indicating a problem with streams.
This is a bit bigger hammer then I would like to use for this, but for now it
will have to make do. I've ordered a pci-e usb controller card with an Asmedia
1042, once that arrives I'll try to get streams to work (with a quirk flag if
necessary) and then we can re-enable them. For now this at least makes uas
capable disk enclosures work again by forcing fallback to the usb-storage
driver.
Reported-by: Bogdan Mihalcea <bogdan.mihalcea@infim.ro>
Cc: Bogdan Mihalcea <bogdan.mihalcea@infim.ro>
commit b45abacde3d551c6696c6738bef4a1805d0bf27a upstream.
The switch back is limited to ULT even on HP. The contrary
finding arose by bad luck in BIOS versions for testing.
This fixes spontaneous resume from S3 on some HP laptops.
Signed-off-by: Oliver Neukum <oneukum@suse.de>
commit cd6e245a2d061a8367e37aaece32cf3fc922de80 upstream.
("ARM: SAMSUNG: Remove remaining legacy code"). There are still
some references left, fix that by replacing them with ARCH_S5PV210.
Acked-by: Jingoo Han <jg1.han@samsung.com>
commit 191252837626fca0de694c18bb2aa64c118eda89 upstream.
Write may be called from interrupt context so make sure to use
GFP_ATOMIC for all allocations in write.
Fixes: 1da177e4c3f4 ("Linux-2.6.12-rc2")
Signed-off-by: Johan Hovold <johan@kernel.org>
commit 90a646c770c50cc206ceba0d7b50453c46c13c36 upstream.
This commit fixes the following oops:
[10238.622067] scsi host3: uas_eh_bus_reset_handler start
[10240.766164] usb 3-4: reset SuperSpeed USB device number 3 using xhci_hcd
[10245.779365] usb 3-4: device descriptor read/8, error -110
[10245.883331] usb 3-4: reset SuperSpeed USB device number 3 using xhci_hcd
[10250.897603] usb 3-4: device descriptor read/8, error -110
[10251.058200] BUG: unable to handle kernel NULL pointer dereference at 0000000000000040
[10251.058244] IP: [<ffffffff815ac6e1>] xhci_check_streams_endpoint+0x91/0x140
<snip>
[10251.059473] Call Trace:
[10251.059487] [<ffffffff815aca6c>] xhci_calculate_streams_and_bitmask+0xbc/0x130
[10251.059520] [<ffffffff815aeb5f>] xhci_alloc_streams+0x10f/0x5a0
[10251.059548] [<ffffffff810a4685>] ? check_preempt_curr+0x75/0xa0
[10251.059575] [<ffffffff810a46dc>] ? ttwu_do_wakeup+0x2c/0x100
[10251.059601] [<ffffffff810a49e6>] ? ttwu_do_activate.constprop.111+0x66/0x70
[10251.059635] [<ffffffff815779ab>] usb_alloc_streams+0xab/0xf0
[10251.059662] [<ffffffffc0616b48>] uas_configure_endpoints+0x128/0x150 [uas]
[10251.059694] [<ffffffffc0616bac>] uas_post_reset+0x3c/0xb0 [uas]
[10251.059722] [<ffffffff815727d9>] usb_reset_device+0x1b9/0x2a0
[10251.059749] [<ffffffffc0616f42>] uas_eh_bus_reset_handler+0xb2/0x190 [uas]
[10251.059781] [<ffffffff81514293>] scsi_try_bus_reset+0x53/0x110
[10251.059808] [<ffffffff815163b7>] scsi_eh_bus_reset+0xf7/0x270
<snip>
The problem is the following call sequence (simplified):
1) usb_reset_device
2) usb_reset_and_verify_device
2) hub_port_init
3) hub_port_finish_reset
3) xhci_discover_or_reset_device
This frees xhci->devs[slot_id]->eps[ep_index].ring for all eps but 0
4) usb_get_device_descriptor
This fails
5) hub_port_init fails
6) usb_reset_and_verify_device fails, does not restore device config
7) uas_post_reset
8) xhci_alloc_streams
NULL deref on the free-ed ring
This commit fixes this by not allowing usb_alloc_streams to continue if
the device is not configured.
Note that we do allow usb_free_streams to continue after a (logical)
disconnect, as it is necessary to explicitly free the streams at the xhci
controller level.
Acked-by: Alan Stern <stern@rowland.harvard.edu>
commit e681286de221af78fc85db9222b6a203148c005a upstream.
Fixes: 0d930e51cfe6 ("USB: opticon: Add Opticon OPN2001 write support")
commit 93c9bf4d1838d5851a18ca398b0ad66397f05056 upstream.
Sometimes mass-storage devices using the Bulk-only transport will
mistakenly skip the data phase of a command. Rather than sending the
data expected by the host or sending a zero-length packet, they go
directly to the status phase and send the CSW.
This causes problems for usb-storage, for obvious reasons. The driver
will interpret the CSW as a short data transfer and will wait to
receive a CSW. The device won't have anything left to send, so the
command eventually times out.
The SCSI layer doesn't retry commands after they time out (this is a
relatively recent change). Therefore we should do our best to detect
a skipped data phase and handle it promptly.
This patch adds code to do that. If usb-storage receives a short
13-byte data transfer from the device, and if the first four bytes of
the data match the CSW signature, the driver will set the residue to
the full transfer length and interpret the data as a CSW.
This fixes Bugzilla #86611.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
CC: Matthew Dharm <mdharm-usb@one-eyed-alien.net>
Tested-by: Paul Osmialowski <newchief@king.net.pl>
commit bfa6b18c680450c17512c741ed1d818695747621 upstream.
Currently, there's no guarantee that udc->driver
will be valid when using soft_connect sysfs
interface. In fact, we can very easily trigger
a NULL pointer dereference by trying to disconnect
when a gadget driver isn't loaded.
Fix this bug:
~# echo disconnect > soft_connect
[ 33.685743] Unable to handle kernel NULL pointer dereference at virtual address 00000014
[ 33.694221] pgd = ed0cc000
[ 33.697174] [00000014] *pgd=ae351831, *pte=00000000, *ppte=00000000
[ 33.703766] Internal error: Oops: 17 [#1] SMP ARM
[ 33.708697] Modules linked in: xhci_plat_hcd xhci_hcd snd_soc_davinci_mcasp snd_soc_tlv320aic3x snd_soc_edma snd_soc_omap snd_soc_evm snd_soc_core dwc3 snd_compress snd_pcm_dmaengine snd_pcm snd_timer snd lis3lv02d_i2c matrix_keypad lis3lv02d dwc3_omap input_polldev soundcore
[ 33.734372] CPU: 0 PID: 1457 Comm: bash Not tainted 3.17.0-09740-ga93416e-dirty #345
[ 33.742457] task: ee71ce00 ti: ee68a000 task.ti: ee68a000
[ 33.748116] PC is at usb_udc_softconn_store+0xa4/0xec
[ 33.753416] LR is at mark_held_locks+0x78/0x90
[ 33.758057] pc : [<c04df128>] lr : [<c00896a4>] psr: 20000013
[ 33.758057] sp : ee68bec8 ip : c0c00008 fp : ee68bee4
[ 33.770050] r10: ee6b394c r9 : ee68bf80 r8 : ee6062c0
[ 33.775508] r7 : 00000000 r6 : ee6062c0 r5 : 0000000b r4 : ee739408
[ 33.782346] r3 : 00000000 r2 : 00000000 r1 : ee71d390 r0 : ee664170
[ 33.789168] Flags: nzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 33.796636] Control: 10c5387d Table: ad0cc059 DAC: 00000015
[ 33.802638] Process bash (pid: 1457, stack limit = 0xee68a248)
[ 33.808740] Stack: (0xee68bec8 to 0xee68c000)
[ 33.813299] bec0: 0000000b c0411284 ee6062c0 00000000 ee68bef4 ee68bee8
[ 33.821862] bee0: c04112ac c04df090 ee68bf14 ee68bef8 c01c2868 c0411290 0000000b ee6b3940
[ 33.830419] bf00: 00000000 00000000 ee68bf4c ee68bf18 c01c1a24 c01c2818 00000000 00000000
[ 33.838990] bf20: ee61b940 ee2f47c0 0000000b 000ce408 ee68bf80 c000f304 ee68a000 00000000
[ 33.847544] bf40: ee68bf7c ee68bf50 c0152dd8 c01c1960 ee68bf7c c0170af8 ee68bf7c ee2f47c0
[ 33.856099] bf60: ee2f47c0 000ce408 0000000b c000f304 ee68bfa4 ee68bf80 c0153330 c0152d34
[ 33.864653] bf80: 00000000 00000000 0000000b 000ce408 b6e7fb50 00000004 00000000 ee68bfa8
[ 33.873204] bfa0: c000f080 c01532e8 0000000b 000ce408 00000001 000ce408 0000000b 00000000
[ 33.881763] bfc0: 0000000b 000ce408 b6e7fb50 00000004 0000000b 00000000 000c5758 00000000
[ 33.890319] bfe0: 00000000 bec2c924 b6de422d b6e1d226 40000030 00000001 75716d2f 00657565
[ 33.898890] [<c04df128>] (usb_udc_softconn_store) from [<c04112ac>] (dev_attr_store+0x28/0x34)
[ 33.907920] [<c04112ac>] (dev_attr_store) from [<c01c2868>] (sysfs_kf_write+0x5c/0x60)
[ 33.916200] [<c01c2868>] (sysfs_kf_write) from [<c01c1a24>] (kernfs_fop_write+0xd0/0x194)
[ 33.924773] [<c01c1a24>] (kernfs_fop_write) from [<c0152dd8>] (vfs_write+0xb0/0x1bc)
[ 33.932874] [<c0152dd8>] (vfs_write) from [<c0153330>] (SyS_write+0x54/0xb0)
[ 33.940247] [<c0153330>] (SyS_write) from [<c000f080>] (ret_fast_syscall+0x0/0x48)
[ 33.948160] Code: e1a01007 e12fff33 e5140004 e5143008 (e5933014)
[ 33.954625] ---[ end trace f849bead94eab7ea ]---
Fixes: 2ccea03 (usb: gadget: introduce UDC Class)
commit 1af39588f84c7c18f8c6d88342f36513a4ce383c upstream.
This device needs the quirk as well.
Tested-by: Kevin Fenzi <kevin@scrye.com>
Signed-off-by: Adel Gadllah <adel.gadllah@gmail.com>
commit 29d05c2ecf396161ef2938a0635707ef5685ef58 upstream.
commit 5235166fbc332c8b5dcf49e3a498a8b510a77449 upstream.
There is a second mouse sharing the same vendor strings but different IDs.
commit 4980f95755e2966b30ac70d1841f4db66d1a8a22 upstream.
This mouse keeps disconnecting in runlevel 3. It needs the ALWAYS_POLL quirk.
