path: root/drivers
2016-10-23Merge tag 'upstream-4.9-rc2' of git://git.infradead.org/linux-ubifsLinus Torvalds
Pull UBI[FS] fixes from Richard Weinberger: "This contains fixes for issues in both UBI and UBIFS: - Fallout from the merge window, refactoring UBI code introduced some issues. - Fixes for an UBIFS readdir bug which can cause getdents() to busy loop for ever and a bug in the UBIFS xattr code" * tag 'upstream-4.9-rc2' of git://git.infradead.org/linux-ubifs: ubifs: Abort readdir upon error UBI: Fix crash in try_recover_peb() ubi: fix swapped arguments to call to ubi_alloc_aeb ubifs: Fix xattr_names length in exit paths ubifs: Rename ubifs_rename2
2016-10-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pendingLinus Torvalds
Pull SCSI target fixes from Nicholas Bellinger: "Here are the outstanding target-pending fixes for v4.9-rc2. This includes: - Fix v4.1.y+ reference leak regression with concurrent TMR ABORT_TASK + session shutdown. (Vaibhav Tandon) - Enable tcm_fc w/ SCF_USE_CPUID to avoid host exchange timeouts (Hannes) - target/user error sense handling fixes. (Andy + MNC + HCH) - Fix iscsi-target NOP_OUT error path iscsi_cmd descriptor leak (Varun) - Two EXTENDED_COPY SCSI status fixes for ESX VAAI (Dinesh Israni + Nixon Vincent) - Revert a v4.8 residual overflow change, that breaks sg_inq with small allocation lengths. There are a number of folks stress testing the v4.1.y regression fix in their environments, and more folks doing iser-target I/O stress testing atop recent v4.x.y code. There is also one v4.2.y+ RCU conversion regression related to explicit NodeACL configfs changes, that is still being tracked down" * git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: target/tcm_fc: use CPU affinity for responses target/tcm_fc: Update debugging statements to match libfc usage target/tcm_fc: return detailed error in ft_sess_create() target/tcm_fc: print command pointer in debug message target: fix potential race window in target_sess_cmd_list_waiting() Revert "target: Fix residual overflow handling in target_complete_cmd_with_length" target: Don't override EXTENDED_COPY xcopy_pt_cmd SCSI status code target: Make EXTENDED_COPY 0xe4 failure return COPY TARGET DEVICE NOT REACHABLE target: Re-add missing SCF_ACK_KREF assignment in v4.1.y iscsi-target: fix iscsi cmd leak iscsi-target: fix spelling mistake "Unsolicitied" -> "Unsolicited" target/user: Fix comments to not refer to data ring target/user: Return an error if cmd data size is too large target/user: Use sense_reason_t in tcmu_queue_cmd_ring
2016-10-23Merge tag 'hwmon-for-linus-v4.9-rc2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging Pull hwmon fixes from Guenter Roeck: "Couple of hwmon fixes: Fix a potential ERR_PTR dereference in max31790 driver, and handle temperature readings below 0 in adm9240 driver" * tag 'hwmon-for-linus-v4.9-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging: hwmon: (max31790) potential ERR_PTR dereference hwmon: (adm9240) handle temperature readings below 0
2016-10-23Merge tag 'for-linus-4.9-2' of git://git.code.sf.net/p/openipmi/linux-ipmiLinus Torvalds
Pull IPMI updates from Corey Minyard: "A small bug fix and a new driver for acting as an IPMI device. I was on vacation during the merge window (a long vacation) but this is a bug fix that should go in and a new driver that shouldn't hurt anything. This has been in linux-next for a month or so" * tag 'for-linus-4.9-2' of git://git.code.sf.net/p/openipmi/linux-ipmi: ipmi: fix crash on reading version from proc after unregisted bmc ipmi/bt-bmc: remove redundant return value check of platform_get_resource() ipmi/bt-bmc: add a dependency on ARCH_ASPEED ipmi: Fix ioremap error handling in bt-bmc ipmi: add an Aspeed BT IPMI BMC driver
2016-10-22Merge branch 'timers-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer updates from Thomas Gleixner: "This updates contains: - A revert which addresses a boot failure on ARM Sun5i platforms - A new clocksource driver, which has been delayed beyond rc1 due to an interrupt driver issue which was unearthed by this driver. The debugging of that issue and the discussion about the proper solution made this driver miss the merge window. There is no point in delaying it for a full cycle as it completes the basic mainline support for the new JCore platform and does not create any risk outside of that platform" * 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: Revert "clocksource/drivers/timer_sun5i: Replace code by clocksource_mmio_init" clocksource: Add J-Core timer/clocksource driver of: Add J-Core timer bindings
2016-10-22Merge branch 'irq-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull irq fixes from Ingo Molnar: "Mostly irqchip driver fixes, plus a symbol export" * 'irq-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: kernel/irq: Export irq_set_parent() irqchip/gic: Add missing \n to CPU IF adjustment message irqchip/jcore: Don't show Kconfig menu item for driver irqchip/eznps: Drop pointless static qualifier in nps400_of_init() irqchip/gic-v3-its: Fix entry size mask for GITS_BASER irqchip/gic-v3-its: Fix 64bit GIC{R,ITS}_TYPER accesses
2016-10-22Merge branch 'efi-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull EFI fixes from Ingo Molnar: "Add Ard Biesheuvel as EFI co-maintainer, plus fix an ARM build bug with older toolchains" * 'efi-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: efi/arm: Fix absolute relocation detection for older toolchains MAINTAINERS: Add myself as EFI maintainer
2016-10-21Merge tag 'powerpc-4.9-3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux Pull powerpc fixes from Michael Ellerman: "Fixes marked for stable: - Prevent unlikely crash in copro_calculate_slb() (Frederic Barrat) - cxl: Prevent adapter reset if an active context exists (Vaibhav Jain) Fixes for code merged this cycle: - Fix boot on systems with uncompressed kernel image (Heiner Kallweit) - Drop dump_numa_memory_topology() (Michael Ellerman) - Fix numa topology console print (Aneesh Kumar K.V) - Ignore the pkey system calls for now (Stephen Rothwell)" * tag 'powerpc-4.9-3' of git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux: powerpc: Ignore the pkey system calls for now powerpc: Fix numa topology console print powerpc/mm: Drop dump_numa_memory_topology() cxl: Prevent adapter reset if an active context exists powerpc/boot: Fix boot on systems with uncompressed kernel image powerpc/mm: Prevent unlikely crash in copro_calculate_slb()
2016-10-21Merge tag 'acpi-4.9-rc2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull ACPI fixes from Rafael Wysocki: "These fix an issue related to system resume in the new WDAT-based watchdog driver and a return value of a stub function in the ACPI CPPC framework. Specifics: - Update the ACPI WDAT-based watchdog driver to ping the hardware during system resume to prevent a reset from occurring after the resume is complete (Mika Westerberg). - Fix the return value of the pcc_mbox_request_channel() stub for CONFIG_PCC unset (Hoan Tran)" * tag 'acpi-4.9-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: watchdog: wdat_wdt: Ping the watchdog on resume mailbox: PCC: Fix return value of pcc_mbox_request_channel()
2016-10-21Merge branches 'acpi-wdat' and 'acpi-cppc'Rafael J. Wysocki
* acpi-wdat: watchdog: wdat_wdt: Ping the watchdog on resume * acpi-cppc: mailbox: PCC: Fix return value of pcc_mbox_request_channel()
2016-10-21Merge tag 'gic-fixes-for-4.9-rc2' of ↵Thomas Gleixner
git://git.kernel.org/pub/scm/linux/kernel/git/maz/arm-platforms into irq/urgent Pull GIC updates from Marc Zyngier: - Fix for 32bit accesses that should be 64bit on 64bit machines - Fix for a field decoding macro - Beautify a warning message
2016-10-21Merge tag 'scsi-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi Pull SCSI fixes from James Bottomley: "Five small fixes. Some of these, like the nested spinlock overwriting saved flags and the Kasan use after free look serious, but they seem not to have been picked up in testing or seen in the field. The biggest user visible issue is probably the wrong device handler for Clariion, which means that alua doesn't bind to the array like it should" * tag 'scsi-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: scsi: ipr: Fix async error WARN_ON scsi: zfcp: spin_lock_irqsave() is not nestable scsi: Remove one useless stack variable scsi: Fix use-after-free scsi: Replace wrong device handler name for CLARiiON arrays
2016-10-21Merge branch 'for-linus' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block fixes from Jens Axboe: "A set of fixes that missed the merge window, mostly due to me being away around that time. Nothing major here, a mix of nvme cleanups and fixes, and one fix for the badblocks handling" * 'for-linus' of git://git.kernel.dk/linux-block: nvmet: use symbolic constants for CNS values nvme: use symbolic constants for CNS values nvme.h: add an enum for cns values nvme.h: don't use uuid_be nvme.h: resync with nvme-cli nvme: Add tertiary number to NVME_VS nvme : Add sysfs entry for NVMe CMBs when appropriate nvme: don't schedule multiple resets nvme: Delete created IO queues on reset nvme: Stop probing a removed device badblocks: fix overlapping check for clearing
2016-10-21Merge tag 'pci-v4.9-fixes-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci Pull PCI fixes from Bjorn Helgaas: "This includes: - Fix for a Layerscape driver issue that causes a use-before-set crash - Maintainer update for the Synopsis prototyping device driver" * tag 'pci-v4.9-fixes-1' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: PCI: designware-plat: Update author email address PCI: layerscape: Fix drvdata usage before assignment PCI: designware-plat: Change maintainer to Jose Abreu
2016-10-21PCI: designware-plat: Update author email addressJoao Pinto
Although I am leaving Synopsys, I would like to keep working with the linux kernel community and help in what you might find useful. For that I am sending this patch to change my contact e-mail. Signed-off-by: Joao Pinto <jpinto@synopsys.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2016-10-21target/tcm_fc: use CPU affinity for responsesHannes Reinecke
The libfc stack assigns exchange IDs based on the CPU the request was received on, so we need to send the responses via the same CPU. Otherwise the send logic gets confuses and responses will be delayed, causing exchange timeouts on the initiator side. Signed-off-by: Hannes Reinecke <hare@suse.com> Cc: stable@vger.kernel.org # 4.5+ Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2016-10-21target/tcm_fc: Update debugging statements to match libfc usageHannes Reinecke
Update the debug statements to match those from libfc. Signed-off-by: Hannes Reinecke <hare@suse.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2016-10-21target/tcm_fc: return detailed error in ft_sess_create()Hannes Reinecke
Not every failure is due to out-of-memory; the ACLs might not be set, too. So return a detailed error code in ft_sess_create() instead of just a NULL pointer. Signed-off-by: Hannes Reinecke <hare@suse.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2016-10-21target/tcm_fc: print command pointer in debug messageHannes Reinecke
When allocating a new command we should add the pointer to the debug statements; that allows us to match this with other debug statements for handling data. Signed-off-by: Hannes Reinecke <hare@suse.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2016-10-21target: fix potential race window in target_sess_cmd_list_waiting()Hannes Reinecke
target_sess_cmd_list_waiting() might hit on a condition where the kref for the command is already 0, but the destructor has not been called yet (or is stuck in waiting for a spin lock). Rather than leaving the command on the list we should explicitly remove it to avoid race issues later on. Signed-off-by: Hannes Reinecke <hare@suse.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2016-10-21Merge branch 'drm-etnaviv-fixes' of git://git.pengutronix.de/lst/linux into ↵Dave Airlie
drm-fixes 2 more patches to stabilize the new MMUv2 support. * 'drm-etnaviv-fixes' of git://git.pengutronix.de/lst/linux: drm/etnaviv: block 64K of address space behind each cmdstream drm/etnaviv: ensure write caches are flushed at end of user cmdstream
2016-10-21Merge branch 'drm-vmwgfx-fixes' of ↵Dave Airlie
ssh://people.freedesktop.org/~syeh/repos_linux into drm-fixes vmwgfx cleanups and fixes. * 'drm-vmwgfx-fixes' of ssh://people.freedesktop.org/~syeh/repos_linux: drm/vmwgfx: Adjust checks for null pointers in 13 functions drm/vmwgfx: Use memdup_user() rather than duplicating its implementation drm/vmwgfx: Use kmalloc_array() in vmw_surface_define_ioctl() drm/vmwgfx: Avoid validating views on view destruction drm/vmwgfx: Limit the user-space command buffer size drm/vmwgfx: Remove a leftover debug printout drm/vmwgfx: Allow resource relocations on byte boundaries drm/vmwgfx: Enable SVGA_3D_CMD_DX_TRANSFER_FROM_BUFFER command drm/vmwgfx: Remove call to reservation_object_test_signaled_rcu before wait drm/vmwgfx: Replace numeric parameter like 0444 with macro
2016-10-21Merge branch 'drm-armada-fixes' of git://git.armlinux.org.uk/~rmk/linux-arm ↵Dave Airlie
into drm-fixes One small fix for Armada, where the clock prepare/enable counts were going awry. * 'drm-armada-fixes' of git://git.armlinux.org.uk/~rmk/linux-arm: drm/armada: fix clock counts
2016-10-21Merge branch 'fixes-for-v4.9-rc2' of ↵Dave Airlie
http://git.agner.ch/git/linux-drm-fsl-dcu into drm-fixes This are some fixes which I hoped to still get into v4.9. I used to test them here since about 2 weeks and Meng came around to test it on the second platform making use of this IP too, so they are well tested now. * 'fixes-for-v4.9-rc2' of http://git.agner.ch/git/linux-drm-fsl-dcu: drm/fsl-dcu: enable pixel clock when enabling CRTC drm/fsl-dcu: do not transfer registers in mode_set_nofb drm/fsl-dcu: do not transfer registers on plane init drm/fsl-dcu: enable TCON bypass mode by default
2016-10-21watchdog: wdat_wdt: Ping the watchdog on resumeMika Westerberg
It turns out we need to ping the watchdog hardware on resume when we re-program it. Otherwise this causes inadvertent reset to trigger right after the resume is complete. Fixes: 058dfc767008 (ACPI / watchdog: Add support for WDAT hardware watchdog) Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Acked-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2016-10-20Revert "clocksource/drivers/timer_sun5i: Replace code by clocksource_mmio_init"Chen-Yu Tsai
struct clocksource is also used by the clk notifier callback, to unregister and re-register the clocksource with a different clock rate. clocksource_mmio_init does not pass back a pointer to the struct used, and the clk notifier callback assumes that the struct clocksource in struct sun5i_timer_clksrc is valid. This results in a kernel NULL pointer dereference when the hstimer clock is changed: Unable to handle kernel NULL pointer dereference at virtual address 00000004 [<c03a4678>] (clocksource_unbind) from [<c03a46d4>] (clocksource_unregister+0x2c/0x44) [<c03a46d4>] (clocksource_unregister) from [<c0a6f350>] (sun5i_rate_cb_clksrc+0x34/0x3c) [<c0a6f350>] (sun5i_rate_cb_clksrc) from [<c035ea50>] (notifier_call_chain+0x44/0x84) [<c035ea50>] (notifier_call_chain) from [<c035edc0>] (__srcu_notifier_call_chain+0x44/0x60) [<c035edc0>] (__srcu_notifier_call_chain) from [<c035edf4>] (srcu_notifier_call_chain+0x18/0x20) [<c035edf4>] (srcu_notifier_call_chain) from [<c0670174>] (__clk_notify+0x70/0x7c) [<c0670174>] (__clk_notify) from [<c06702c0>] (clk_propagate_rate_change+0xa4/0xc4) [<c06702c0>] (clk_propagate_rate_change) from [<c0670288>] (clk_propagate_rate_change+0x6c/0xc4) Revert the commit for now. clocksource_mmio_init can be made to pass back a pointer, but the code churn and usage of an inner struct might not be worth it. Fixes: 157dfadef832 ("clocksource/drivers/timer_sun5i: Replace code by clocksource_mmio_init") Reported-by: Maxime Ripard <maxime.ripard@free-electrons.com> Signed-off-by: Chen-Yu Tsai <wens@csie.org> Cc: linux-sunxi@googlegroups.com Cc: Daniel Lezcano <daniel.lezcano@linaro.org> Cc: linux-arm-kernel@lists.infradead.org Link: http://lkml.kernel.org/r/20161018054918.26855-1-wens@csie.org Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2016-10-20clocksource: Add J-Core timer/clocksource driverRich Felker
At the hardware level, the J-Core PIT is integrated with the interrupt controller, but it is represented as its own device and has an independent programming interface. It provides a 12-bit countdown timer, which is not presently used, and a periodic timer. The interval length for the latter is programmable via a 32-bit throttle register whose units are determined by a bus-period register. The periodic timer is used to implement both periodic and oneshot clock event modes; in oneshot mode the interrupt handler simply disables the timer as soon as it fires. Despite its device tree node representing an interrupt for the PIT, the actual irq generated is programmable, not hard-wired. The driver is responsible for programming the PIT to generate the hardware irq number that the DT assigns to it. On SMP configurations, J-Core provides cpu-local instances of the PIT; no broadcast timer is needed. This driver supports the creation of the necessary per-cpu clock_event_device instances. A nanosecond-resolution clocksource is provided using the J-Core "RTC" registers, which give a 64-bit seconds count and 32-bit nanoseconds that wrap every second. The driver converts these to a full-range 32-bit nanoseconds count. Signed-off-by: Rich Felker <dalias@libc.org> Cc: Mark Rutland <mark.rutland@arm.com> Cc: devicetree@vger.kernel.org Cc: linux-sh@vger.kernel.org Cc: Daniel Lezcano <daniel.lezcano@linaro.org> Cc: Rob Herring <robh+dt@kernel.org> Link: http://lkml.kernel.org/r/b591ff12cc5ebf63d1edc98da26046f95a233814.1476393790.git.dalias@libc.org Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2016-10-20Merge tag 'arm64-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux Pull arm64 fixes from Will Deacon: "Most of these are CC'd for stable, but there are a few fixing issues introduced during the recent merge window too. There's also a fix for the xgene PMU driver, but it seemed daft to send as a separate pull request, so I've included it here with the rest of the fixes. - Fix ACPI boot due to recent broken NUMA changes - Fix remote enabling of CPU features requiring PSTATE bit manipulation - Add address range check when emulating user cache maintenance - Fix LL/SC loops that allow compiler to introduce memory accesses - Fix recently added write_sysreg_s macro - Ensure MDCR_EL2 is initialised on qemu targets without a PMU - Avoid kaslr breakage due to MODVERSIONs and DYNAMIC_FTRACE - Correctly drive recent ld when building relocatable Image - Remove junk IS_ERR check from xgene PMU driver added during merge window - pr_cont fixes after core changes in the merge window" * tag 'arm64-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux: arm64: remove pr_cont abuse from mem_init arm64: fix show_regs fallout from KERN_CONT changes arm64: kernel: force ET_DYN ELF type for CONFIG_RELOCATABLE=y arm64: suspend: Reconfigure PSTATE after resume from idle arm64: mm: Set PSTATE.PAN from the cpu_enable_pan() call arm64: cpufeature: Schedule enable() calls instead of calling them via IPI arm64: Cortex-A53 errata workaround: check for kernel addresses arm64: percpu: rewrite ll/sc loops in assembly arm64: swp emulation: bound LL/SC retries before rescheduling arm64: sysreg: Fix use of XZR in write_sysreg_s arm64: kaslr: keep modules close to the kernel when DYNAMIC_FTRACE=y arm64: kernel: Init MDCR_EL2 even in the absence of a PMU perf: xgene: Remove bogus IS_ERR() check arm64: kernel: numa: fix ACPI boot cpu numa node mapping arm64: kaslr: fix breakage with CONFIG_MODVERSIONS=y
2016-10-20Merge tag 'ceph-for-4.9-rc2' of git://github.com/ceph/ceph-clientLinus Torvalds
Pull Ceph fixes from Ilya Dryomov: "An rbd exclusive-lock edge case fix and several filesystem fixups. Nikolay's error path patch is tagged for stable, everything else but readdir vs frags race was introduced in this merge window" * tag 'ceph-for-4.9-rc2' of git://github.com/ceph/ceph-client: ceph: fix non static symbol warning ceph: fix uninitialized dentry pointer in ceph_real_mount() ceph: fix readdir vs fragmentation race ceph: fix error handling in ceph_read_iter rbd: don't retry watch reregistration if header object is gone rbd: don't wait for the lock forever if blacklisted
2016-10-20Merge tag 'mmc-v4.9-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ulfh/mmc Pull MMC fixes from Ulf Hansson: "Here are some mmc fixes intended for v4.9 rc2. This time I have also included a few changes for a memstick driver which has a corresponding mmc driver. They use the same USB device as parent, hence both needs to play nice with runtime PM, which they didn't. MMC core: - Update MAINTAINERS as the mmc tree moved to kernel.org - A few fixes for HS400es mode - A few other minor fixes MMC host: - sdhci: Fix an issue when dealing with stop commands - sdhci-pci: Fix a bus power failure issue - sdhci-esdhc-imx: Correct two register accesses - sdhci-of-arasan: Fix the 1.8V I/O signal switch behaviour - rtsx_usb_sdmmc: Fix runtime PM issues Other: (Because of no maintainer) - memstick: rtsx_usb_ms: Fix runtime PM issues" * tag 'mmc-v4.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/ulfh/mmc: MAINTAINERS: mmc: Move the mmc tree to kernel.org memstick: rtsx_usb_ms: Manage runtime PM when accessing the device memstick: rtsx_usb_ms: Runtime resume the device when polling for cards mmc: rtsx_usb_sdmmc: Handle runtime PM while changing the led mmc: rtsx_usb_sdmmc: Avoid keeping the device runtime resumed when unused mmc: sdhci: cast unsigned int to unsigned long long to avoid unexpeted error mmc: sdhci-esdhc-imx: Correct two register accesses mmc: sdhci-pci: Fix bus power failing to enable for some Intel controllers mmc: sdhci-pci: Let devices define their own sdhci_ops mmc: sdhci: Rename sdhci_set_power() to sdhci_set_power_noreg() mmc: sdhci: Fix SDHCI_QUIRK2_STOP_WITH_TC mmc: core: Annotate cmd_hdr as __le32 mmc: sdhci-of-arasan: add sdhci_arasan_voltage_switch for arasan, 5.1 mmc: core: changes frequency to hs_max_dtr when selecting hs400es mmc: core: switch to 1V8 or 1V2 for hs400es mode mmc: block: add missing header dependencies mmc: sdhci-of-arasan: Fix non static symbol warning
2016-10-20irqchip/gic: Add missing \n to CPU IF adjustment messageMarc Zyngier
It really looks bad without a newline. Signed-off-by: Marc Zyngier <marc.zyngier@arm.com>
2016-10-20irqchip/jcore: Don't show Kconfig menu item for driverRich Felker
Core drivers for J-Core SoCs will be selected implicitly via CONFIG_SH_JCORE_SOC instead. Based on a corresponding change to the clocksource/timer driver requested by Daniel Lezcano. Signed-off-by: Rich Felker <dalias@libc.org> Cc: Marc Zyngier <marc.zyngier@arm.com> Cc: Jason Cooper <jason@lakedaemon.net> Cc: linux-sh@vger.kernel.org Link: http://lkml.kernel.org/r/883a3d17084003e3cf21bab73ec12828fe4ff6c6.1476899495.git.dalias@libc.org Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2016-10-19Revert "target: Fix residual overflow handling in ↵Nicholas Bellinger
target_complete_cmd_with_length" This reverts commit c1ccbfe0311e2380a6d2dcb0714b36904f5d586f. Reverting this patch, as it incorrectly assumes the additional length for INQUIRY in target_complete_cmd_with_length() is SCSI allocation length, which breaks existing user-space code when SCSI allocation length is smaller than additional length. root@scsi-mq:~# sg_inq --len=4 -vvvv /dev/sdb found bsg_major=253 open /dev/sdb with flags=0x800 inquiry cdb: 12 00 00 00 04 00 duration=0 ms inquiry: pass-through requested 4 bytes (data-in) but got -28 bytes inquiry: pass-through can't get negative bytes, say it got none inquiry: got too few bytes (0) INQUIRY resid (32) should never exceed requested len=4 inquiry: failed requesting 4 byte response: Malformed response to SCSI command [resid=32] AFAICT the original change was not to address a specific host issue, so go ahead and revert to original logic for now. Cc: Douglas Gilbert <dgilbert@interlog.com> Cc: Martin K. Petersen <martin.petersen@oracle.com> Cc: Sumit Rai <sumitrai96@gmail.com> Cc: stable@vger.kernel.org # 4.8+ Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2016-10-19target: Don't override EXTENDED_COPY xcopy_pt_cmd SCSI status codeDinesh Israni
This patch addresses a bug where a local EXTENDED_COPY WRITE or READ backend I/O request would always return SAM_STAT_CHECK_CONDITION, even if underlying xcopy_pt_cmd->se_cmd generated a different SCSI status code. ESX host environments expect to hit SAM_STAT_RESERVATION_CONFLICT for certain scenarios, and SAM_STAT_CHECK_CONDITION results in non-retriable status for these cases. Tested on v4.1.y with ESX v5.5u2+ with local IBLOCK backend copy. Reported-by: Nixon Vincent <nixon.vincent@calsoftinc.com> Tested-by: Nixon Vincent <nixon.vincent@calsoftinc.com> Cc: Nixon Vincent <nixon.vincent@calsoftinc.com> Tested-by: Dinesh Israni <ddi@datera.io> Signed-off-by: Dinesh Israni <ddi@datera.io> Cc: Dinesh Israni <ddi@datera.io> Cc: stable@vger.kernel.org # 3.14+ Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2016-10-19target: Make EXTENDED_COPY 0xe4 failure return COPY TARGET DEVICE NOT REACHABLENicholas Bellinger
This patch addresses a bug where EXTENDED_COPY across multiple LUNs results in a CHECK_CONDITION when the source + destination are not located on the same physical node. ESX Host environments expect sense COPY_ABORTED w/ COPY TARGET DEVICE NOT REACHABLE to be returned when this occurs, in order to signal fallback to local copy method. As described in section 6.3.3 of spc4r22: "If it is not possible to complete processing of a segment because the copy manager is unable to establish communications with a copy target device, because the copy target device does not respond to INQUIRY, or because the data returned in response to INQUIRY indicates an unsupported logical unit, then the EXTENDED COPY command shall be terminated with CHECK CONDITION status, with the sense key set to COPY ABORTED, and the additional sense code set to COPY TARGET DEVICE NOT REACHABLE." Tested on v4.1.y with ESX v5.5u2+ with BlockCopy across multiple nodes. Reported-by: Nixon Vincent <nixon.vincent@calsoftinc.com> Tested-by: Nixon Vincent <nixon.vincent@calsoftinc.com> Cc: Nixon Vincent <nixon.vincent@calsoftinc.com> Tested-by: Dinesh Israni <ddi@datera.io> Signed-off-by: Dinesh Israni <ddi@datera.io> Cc: Dinesh Israni <ddi@datera.io> Cc: stable@vger.kernel.org # 3.14+ Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2016-10-19target: Re-add missing SCF_ACK_KREF assignment in v4.1.yNicholas Bellinger
This patch fixes a regression in >= v4.1.y code where the original SCF_ACK_KREF assignment in target_get_sess_cmd() was dropped upstream in commit 054922bb, but the series for addressing TMR ABORT_TASK + LUN_RESET with fabric session reinstatement in commit febe562c20 still depends on this code in transport_cmd_finish_abort(). The regression manifests itself as a se_cmd->cmd_kref +1 leak, where ABORT_TASK + LUN_RESET can hang indefinately for a specific I_T session for drivers using SCF_ACK_KREF, resulting in hung kthreads. This patch has been verified with v4.1.y code. Reported-by: Vaibhav Tandon <vst@datera.io> Tested-by: Vaibhav Tandon <vst@datera.io> Cc: Vaibhav Tandon <vst@datera.io> Cc: stable@vger.kernel.org # 4.1+ Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2016-10-19iscsi-target: fix iscsi cmd leakVarun Prakash
If iscsi-target receives NOP OUT with ITT and TTT set to 0xffffffff it allocates iscsi_cmd but does not free the cmd, so free iscsi_cmd in this case. Signed-off-by: Varun Prakash <varun@chelsio.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2016-10-19iscsi-target: fix spelling mistake "Unsolicitied" -> "Unsolicited"Colin Ian King
Trivial fix to spelling mistakes in pr_debug message and comments Signed-off-by: Colin Ian King <colin.king@canonical.com> Reviewed-by: Bart Van Assche <bart.vanassche@sandisk.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2016-10-19target/user: Fix comments to not refer to data ringAndy Grover
We no longer use a ringbuffer for the data area, so this might cause confusion. Just call it the data area. Signed-off-by: Andy Grover <agrover@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Mike Christie <mchristi@redhat.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2016-10-19target/user: Return an error if cmd data size is too largeAndy Grover
Userspace should be implementing VPD B0 (Block Limits) to inform the initiator of max data size, but just in case we do get a too-large request, do what the spec says and return INVALID_CDB_FIELD. Make sure to unlock udev->cmdr_lock before returning. Signed-off-by: Andy Grover <agrover@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Mike Christie <mchristi@redhat.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2016-10-19target/user: Use sense_reason_t in tcmu_queue_cmd_ringAndy Grover
Instead of using -ERROR-style returns, use sense_reason_t. This lets us remove tcmu_pass_op(), and return more correct sense values. Signed-off-by: Andy Grover <agrover@redhat.com> Signed-off-by: Bryant G. Ly <bryantly@linux.vnet.ibm.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Mike Christie <mchristi@redhat.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2016-10-19drm/fsl-dcu: enable pixel clock when enabling CRTCStefan Agner
The pixel clock should not be on if the CRTC is not in use, hence move clock enable/disable calls into CRTC callbacks. Signed-off-by: Stefan Agner <stefan@agner.ch> Tested-By: Meng Yi <meng.yi@nxp.com>
2016-10-19drm/fsl-dcu: do not transfer registers in mode_set_nofbStefan Agner
Do not schedule a transfer of mode settings early. Modes should get applied on on CRTC enable where we also enable the pixel clock. Signed-off-by: Stefan Agner <stefan@agner.ch> Tested-By: Meng Yi <meng.yi@nxp.com>
2016-10-19drm/fsl-dcu: do not transfer registers on plane initStefan Agner
There is no need to explicitly initiate a register transfer and turn off the DCU after initializing the plane registers. In fact, this is harmful and leads to unnecessary flickers if the DCU has been left on by the bootloader. Signed-off-by: Stefan Agner <stefan@agner.ch> Tested-By: Meng Yi <meng.yi@nxp.com>
2016-10-19drm/fsl-dcu: enable TCON bypass mode by defaultStefan Agner
Do not use encoder disable/enable callbacks to control bypass mode as this seems to mess with the signals not liked by displays. This also makes more sense since the encoder is already defined to be parallel RGB/LVDS at creation time. Signed-off-by: Stefan Agner <stefan@agner.ch> Tested-By: Meng Yi <meng.yi@nxp.com>
2016-10-20UBI: Fix crash in try_recover_peb()Geert Uytterhoeven
drivers/mtd/ubi/eba.c: In function ‘try_recover_peb’: drivers/mtd/ubi/eba.c:744: warning: ‘vid_hdr’ is used uninitialized in this function The pointer vid_hdr is indeed not initialized, leading to a crash when it is dereferenced. Fix this by obtaining the pointer from the VID buffer, like is done everywhere else. Fixes: 3291b52f9ff0acc8 ("UBI: introduce the VID buffer concept") Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Reviewed-by: Boris Brezillon <boris.brezillon@free-electrons.com> Signed-off-by: Richard Weinberger <richard@nod.at>
2016-10-20ubi: fix swapped arguments to call to ubi_alloc_aebColin Ian King
Static analysis by CoverityScan detected the ec and pnum arguments are in the wrong order on a call to ubi_alloc_aeb. Swap the order to fix this. Fixes: 91f4285fe389a27 ("UBI: provide helpers to allocate and free aeb elements") Signed-off-by: Colin Ian King <colin.king@canonical.com> Reviewed-by: Boris Brezillon <boris.brezillon@free-electrons.com> Signed-off-by: Richard Weinberger <richard@nod.at>
2016-10-19Merge tag 'platform-drivers-x86-v4.9-2' of ↵Linus Torvalds
git://git.infradead.org/users/dvhart/linux-platform-drivers-x86 Pull x86 platform driver fixes from Darren Hart: "Fix a Kconfig issue leading potential link failure, and add a DMI match for an existing quirk. asus-wmi: - add SERIO_I8042 dependency ideapad-laptop: - Add Lenovo Yoga 910-13IKB to no_hw_rfkill dmi list" * tag 'platform-drivers-x86-v4.9-2' of git://git.infradead.org/users/dvhart/linux-platform-drivers-x86: platform/x86: asus-wmi: add SERIO_I8042 dependency platform/x86: ideapad-laptop: Add Lenovo Yoga 910-13IKB to no_hw_rfkill dmi list
2016-10-19nvmet: use symbolic constants for CNS valuesChristoph Hellwig
Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Gabriel Krisman Bertazi <krisman@linux.vnet.ibm.com> Reviewed-by: Jay Freyensee <james_p_freyensee@linux.intel.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-10-19nvme: use symbolic constants for CNS valuesChristoph Hellwig
Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Gabriel Krisman Bertazi <krisman@linux.vnet.ibm.com> Reviewed-by: Keith Busch <keith.busch@intel.com> Signed-off-by: Jens Axboe <axboe@fb.com>
