[ Upstream commit fed03fe7e55b7dc16077f672bd9d7bbe92b3a691 ]
The Asus Z370-I contains a Realtek RTL8822BE device with an associated
BT chip using a USB ID of 0b05:185c. This device is added to the driver.
Signed-off-by: Hon Weng Chong <honwchong@gmail.com>
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
'of_regulator_match()'
[ Upstream commit 30966861a7a2051457be8c49466887d78cc47e97 ]
If an unlikely failure in 'of_get_regulator_init_data()' occurs, we must
release the reference on the current 'child' node before returning.
Signed-off-by: Christophe JAILLET <christophe.jaillet@wanadoo.fr>
Signed-off-by: Mark Brown <broonie@kernel.org>
[ Upstream commit 04673e38f56b30cd39b1fa0f386137d818b17781 ]
The driver controls when the hardware sends completions that communicate
consumption of elements from the WQ. This is done by setting a WQEC bit
on a WQE.
The current driver sets it on every Nth WQE posting. However, the driver
isn't clearing the bit if the WQE is reused. Thus, if the queue depth
isn't evenly divisible by N, with enough time, it can be set on every
element, creating a lot of overhead and risking CQ full conditions.
Correct by clearing the bit when not setting it on an Nth element.
Signed-off-by: Dick Kennedy <dick.kennedy@broadcom.com>
Signed-off-by: James Smart <james.smart@broadcom.com>
Reviewed-by: Hannes Reinecke <hare@suse.com>
[ Upstream commit 161df4f09987ae2e9f0f97f0b38eee298b4a39ff ]
During link bounce testing in a point-to-point topology, the host may
enter a soft lockup on the lpfc_worker thread:
Call Trace:
lpfc_work_done+0x1f3/0x1390 [lpfc]
lpfc_do_work+0x16f/0x180 [lpfc]
kthread+0xc7/0xe0
ret_from_fork+0x3f/0x70
The driver was simultaneously setting a combination of flags that caused
lpfc_do_work()to effectively spin between slow path work and new event
data, causing the lockup.
Ensure in the typical wq completions, that new event data flags are set
if the slow path flag is running. The slow path will eventually
reschedule the wq handling.
[ Upstream commit 2289e9598dde9705400559ca2606fb8c145c34f0 ]
The driver ignored checks on whether the link should be kept
administratively down after a link bounce. Correct the checks.
[ Upstream commit 57de50af162b67612da99207b061ade3239e57db ]
When mapping external DMA-bufs through the PRIME mmap call, we might be
given an offset which has to be respected. However for the internal DRM
GEM mmap path, we have to ignore the fake mmap offset used to identify
the buffer only. Currently the code always zeroes out vma->vm_pgoff,
which breaks the former.
This patch fixes the problem by moving the vm_pgoff assignment to a
function that is used only for GEM mmap path, so that the PRIME path
retains the original offset.
Cc: Daniel Kurtz <djkurtz@chromium.org>
Signed-off-by: Ørjan Eide <orjan.eide@arm.com>
Signed-off-by: Tomasz Figa <tfiga@chromium.org>
Signed-off-by: Sean Paul <seanpaul@chromium.org>
Signed-off-by: Thierry Escande <thierry.escande@collabora.com>
Tested-by: Heiko Stuebner <heiko@sntech.de>
Signed-off-by: Heiko Stuebner <heiko@sntech.de>
Link: https://patchwork.freedesktop.org/patch/msgid/20180130202913.28724-4-thierry.escande@collabora.com
[ Upstream commit 7c73cf4cc2ac16465f5102437dc0a12d66671bd6 ]
The MODULE_ALIAS is required to enable the sun4i-ss driver to load
automatically when built at a module. Tested on a Cubietruck.
Fixes: 6298e948215f ("crypto: sunxi-ss - Add Allwinner Security System crypto accelerator")
Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
[ Upstream commit a8321e7887410a2b2e80ab89d1ef7b30562658ea ]
Rates declared in PLL rate tables should match exactly rates calculated
from PLL coefficients. If that is not the case, rate of the PLL's child clock
might be set not as expected. For instance, if in the PLL rates table we have
a 393216000 Hz entry and the real value as returned by the PLL's recalc_rate
callback is 393216003, after setting PLL's clk rate to 393216000 clk_get_rate
will return 393216003. If we now attempt to set rate of a PLL's child divider
clock to 393216000/2 its rate will be 131072001, rather than 196608000.
That is, the divider will be set to 3 instead of 2, because 393216003/2 is
greater than 196608000.
To fix this issue declared rates are changed to exactly match rates generated
by the PLL, as calculated from the P, M, S, K coefficients.
In this patch an erroneous P value for 74176002 output frequency is also
corrected.
Signed-off-by: Andrzej Hajda <a.hajda@samsung.com>
Acked-by: Chanwoo Choi <cw00.choi@samsung.com>
Acked-by: Tomasz Figa <tomasz.figa@gmail.com>
Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
[ Upstream commit 2ac051eeabaa411ef89ae7cd5bb8e60cb41ad780 ]
[ Upstream commit ab0447845cffc0fd752df2ccd6b4e34006000ce4 ]
Rates declared in PLL rate tables should match exactly rates calculated from
the PLL coefficients. If that is not the case, rate of the PLL's child clock
[ Upstream commit cdb68fbd4e7962be742c4f29475220c5bf28d8a5 ]
[ Upstream commit 179db533c08431f509a3823077549773d519358b ]
[ Upstream commit 67300abdbe9f1717532aaf4e037222762716d0f6 ]
Currently an out of range dev->nr is detected by just reporting the
issue and later on an out-of-bounds read on array card occurs because
of this. Fix this by checking the upper range of dev->nr with the size
of array card (removes the hard coded size), move this check earlier
and also exit with the error -ENOSYS to avoid the later out-of-bounds
array read.
Detected by CoverityScan, CID#711191 ("Out-of-bounds-read")
Fixes: commit 02b20b0b4cde ("V4L/DVB (12730): Add conexant cx25821 driver")
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
[hans.verkuil@cisco.com: %ld -> %zd]
Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
[ Upstream commit 832e4e1f76b8a84991e9db56fdcef1ebce839b8b ]
Add Marvell 88SE9220 DMA quirk as found and tested on bug 42679.
Link: https://bugzilla.kernel.org/show_bug.cgi?id=42679
Signed-off-by: Thomas Vincent-Cross <me@tvc.id.au>
Signed-off-by: Bjorn Helgaas <helgaas@kernel.org>
[ Upstream commit f9f5786987e81d166c60833edcb7d1836aa16944 ]
The arc_uart_ports[] array is indexed using a value derived from the
"serialN" alias in DT, which may lead to an out-of-bounds access.
Fix this by adding a range check.
Note that the array size is defined by a Kconfig symbol
(CONFIG_SERIAL_ARC_NR_PORTS), so this can even be triggered using a
legitimate DTB.
Fixes: ea28fd56fcde69af ("serial/arc-uart: switch to devicetree based probing")
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
[ Upstream commit ffab87fdecc655cc676f8be8dd1a2c5e22bd6d47 ]
The lpuart_ports[] array is indexed using a value derived from the
Fixes: c9e2e946fb0ba5d2 ("tty: serial: add Freescale lpuart driver support")
[ Upstream commit 5673444821406dda5fc25e4b52aca419f8065a19 ]
The imx_ports[] array is indexed using a value derived from the
"serialN" alias in DT, or from platform data, which may lead to an
Fixes: ff05967a07225ab6 ("serial/imx: add of_alias_get_id() reference back")
Reviewed-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
[ Upstream commit dd345a31bfdec350d2593e6de5964e55c7f19c76 ]
The auart_port[] array is indexed using a value derived from the
Fixes: 1ea6607d4cdc9179 ("serial: mxs-auart: Allow device tree probing")
[ Upstream commit 49ee23b71877831ac087d6083f6f397dc19c9664 ]
The s3c24xx_serial_ports[] array is indexed using a value derived from
the "serialN" alias in DT, or from an incrementing probe index, which
(CONFIG_SERIAL_SAMSUNG_UARTS), so this can even be triggered using
a legitimate DTB or legitimate board code.
Fixes: 13a9f6c64fdc55eb ("serial: samsung: Consider DT alias when probing ports")
[ Upstream commit e7d75e18d0fc3f7193b65282b651f980c778d935 ]
The cdns_uart_port[] array is indexed using a value derived from the
Fixes: 928e9263492069ee ("tty: xuartps: Initialize ports according to aliases")
Reviewed-by: Michal Simek <michal.simek@xilinx.com>
[ Upstream commit 347876ad47b9923ce26e686173bbf46581802ffa ]
The shifting of buf[5] by 24 bits to the left will be promoted to
a 32 bit signed int and then sign-extended to an unsigned long. If
the top bit of buf[5] is set then all then all the upper bits sec
end up as also being set because of the sign-extension. Fix this by
casting buf[5] to an unsigned long before the shift.
Detected by CoverityScan, CID#1465292 ("Unintended sign extension")
Fixes: 0e1492330cd2 ("rtc: add rtc-tx4939 driver")
Signed-off-by: Alexandre Belloni <alexandre.belloni@bootlin.com>
[ Upstream commit e1a7418529e33bc4efc346324557251a16a3e79b ]
Currently the allocation of priv->oldaddr is not null checked which will
lead to subsequent errors when accessing priv->oldaddr. Fix this with
a null pointer check and a return of -ENOMEM on allocation failure.
Detected with Coccinelle:
drivers/staging/rtl8192u/r8192U_core.c:1708:2-15: alloc with no test,
possible model on line 1723
Fixes: 8fc8598e61f6 ("Staging: Added Realtek rtl8192u driver to staging")
[ Upstream commit 326ed382256475aa4b8b7eae8a2f60689fd25e78 ]
Avoid issue when probing the RNG without
reset if bad status has been detected previously
Signed-off-by: Lionel Debieve <lionel.debieve@st.com>
[ Upstream commit e8588e268509292550634d9a35f2723a207683b2 ]
rq should be enabled before posting the buffers to rq desc. If not hw sees
stale value and casuses DMAR errors.
Signed-off-by: Govindarajulu Varadarajan <gvaradar@cisco.com>
[ Upstream commit 4bf59902b50012b1dddeeaa23b217d9c4956cdda ]
The MMC sample and drv clock for rockchip platforms are derived from
the bus clock output to the MMC/SDIO card. So it should never happens
that the clk rate is zero given it should inherits the clock rate from
its parent. If something goes wrong and makes the clock rate to be zero,
the calculation would be wrong but may still make the mmc tuning process
work luckily. However it makes people harder to debug when the following
data transfer is unstable.
Signed-off-by: Shawn Lin <shawn.lin@rock-chips.com>
[ Upstream commit c7c7e8d7803406daa21e96d00c357de8b77b6764 ]
Hauppauge em28xx bulk devices exhibit continuity errors and corrupted
packets, when run in VMWare virtual machines. Unknown if other
manufacturers bulk models exhibit the same issue. KVM/Qemu is unaffected.
According to documentation the maximum packet multiplier for em28xx in bulk
transfer mode is 256 * 188 bytes. This changes the size of bulk transfers
to maximum supported value and have a bonus beneficial alignment.
Before:
After:
This sets up USB to expect just as many bytes as the em28xx is set to emit.
Successful usage under load afterwards natively and in both VMWare
and KVM/Qemu virtual machines.
Signed-off-by: Brad Love <brad@nextdimension.cc>
Reviewed-by: Michael Ira Krufky <mkrufky@linuxtv.org>
[ Upstream commit a3ca831249ca8c4c226e4ceafee04e280152e59d ]
When booting up with "threadirqs" in command line, all irq handlers of the DMA
controller pl330 will be threaded forcedly. These threads will race for the same
list, pl330->req_done.
Before the callback, the spinlock was released. And after it, the spinlock was
taken. This opened an race window where another threaded irq handler could steal
the spinlock and be permitted to delete entries of the list, pl330->req_done.
If the later deleted an entry that was still referred to by the former, there would
be a kernel panic when the former was scheduled and tried to get the next sibling
of the deleted entry.
The scenario could be depicted as below:
Thread: T1 pl330->req_done Thread: T2
| -A-B-C-D- |
Locked | |
| | Waiting
Del A | |
| -B-C-D- |
Unlocked | |
| | Locked
Waiting | |
| | Del B
| -C-D- Unlocked
Waiting | |
Locked
get C via B
- Kernel panic
The kernel panic looked like as below:
Unable to handle kernel paging request at virtual address dead000000000108
pgd = ffffff8008c9e000
[dead000000000108] *pgd=000000027fffe003, *pud=000000027fffe003, *pmd=0000000000000000
Internal error: Oops: 96000044 [#1] PREEMPT SMP
Modules linked in:
CPU: 0 PID: 85 Comm: irq/59-66330000 Not tainted 4.8.24-WR9.0.0.12_standard #2
Hardware name: Broadcom NS2 SVK (DT)
task: ffffffc1f5cc3c00 task.stack: ffffffc1f5ce0000
PC is at pl330_irq_handler+0x27c/0x390
LR is at pl330_irq_handler+0x2a8/0x390
pc : [<ffffff80084cb694>] lr : [<ffffff80084cb6c0>] pstate: 800001c5
sp : ffffffc1f5ce3d00
x29: ffffffc1f5ce3d00 x28: 0000000000000140
x27: ffffffc1f5c530b0 x26: dead000000000100
x25: dead000000000200 x24: 0000000000418958
x23: 0000000000000001 x22: ffffffc1f5ccd668
x21: ffffffc1f5ccd590 x20: ffffffc1f5ccd418
x19: dead000000000060 x18: 0000000000000001
x17: 0000000000000007 x16: 0000000000000001
x15: ffffffffffffffff x14: ffffffffffffffff
x13: ffffffffffffffff x12: 0000000000000000
x11: 0000000000000001 x10: 0000000000000840
x9 : ffffffc1f5ce0000 x8 : ffffffc1f5cc3338
x7 : ffffff8008ce2020 x6 : 0000000000000000
x5 : 0000000000000000 x4 : 0000000000000001
x3 : dead000000000200 x2 : dead000000000100
x1 : 0000000000000140 x0 : ffffffc1f5ccd590
Process irq/59-66330000 (pid: 85, stack limit = 0xffffffc1f5ce0020)
Stack: (0xffffffc1f5ce3d00 to 0xffffffc1f5ce4000)
3d00: ffffffc1f5ce3d80 ffffff80080f09d0 ffffffc1f5ca0c00 ffffffc1f6f7c600
3d20: ffffffc1f5ce0000 ffffffc1f6f7c600 ffffffc1f5ca0c00 ffffff80080f0998
3d40: ffffffc1f5ce0000 ffffff80080f0000 0000000000000000 0000000000000000
3d60: ffffff8008ce202c ffffff8008ce2020 ffffffc1f5ccd668 ffffffc1f5c530b0
3d80: ffffffc1f5ce3db0 ffffff80080f0d70 ffffffc1f5ca0c40 0000000000000001
3da0: ffffffc1f5ce0000 ffffff80080f0cfc ffffffc1f5ce3e20 ffffff80080bf4f8
3dc0: ffffffc1f5ca0c80 ffffff8008bf3798 ffffff8008955528 ffffffc1f5ca0c00
3de0: ffffff80080f0c30 0000000000000000 0000000000000000 0000000000000000
3e00: 0000000000000000 0000000000000000 0000000000000000 ffffff80080f0b68
3e20: 0000000000000000 ffffff8008083690 ffffff80080bf420 ffffffc1f5ca0c80
3e40: 0000000000000000 0000000000000000 0000000000000000 ffffff80080cb648
3e60: ffffff8008b1c780 0000000000000000 0000000000000000 ffffffc1f5ca0c00
3e80: ffffffc100000000 ffffff8000000000 ffffffc1f5ce3e90 ffffffc1f5ce3e90
3ea0: 0000000000000000 ffffff8000000000 ffffffc1f5ce3eb0 ffffffc1f5ce3eb0
3ec0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
3ee0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
3f00: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
3f20: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
3f40: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
3f60: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
3f80: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
3fa0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
3fc0: 0000000000000000 0000000000000005 0000000000000000 0000000000000000
3fe0: 0000000000000000 0000000000000000 0000000275ce3ff0 0000000275ce3ff8
Call trace:
Exception stack(0xffffffc1f5ce3b30 to 0xffffffc1f5ce3c60)
3b20: dead000000000060 0000008000000000
3b40: ffffffc1f5ce3d00 ffffff80084cb694 0000000000000008 0000000000000e88
3b60: ffffffc1f5ce3bb0 ffffff80080dac68 ffffffc1f5ce3b90 ffffff8008826fe4
3b80: 00000000000001c0 00000000000001c0 ffffffc1f5ce3bb0 ffffff800848dfcc
3ba0: 0000000000020000 ffffff8008b15ae4 ffffffc1f5ce3c00 ffffff800808f000
3bc0: 0000000000000010 ffffff80088377f0 ffffffc1f5ccd590 0000000000000140
3be0: dead000000000100 dead000000000200 0000000000000001 0000000000000000
3c00: 0000000000000000 ffffff8008ce2020 ffffffc1f5cc3338 ffffffc1f5ce0000
3c20: 0000000000000840 0000000000000001 0000000000000000 ffffffffffffffff
3c40: ffffffffffffffff ffffffffffffffff 0000000000000001 0000000000000007
[<ffffff80084cb694>] pl330_irq_handler+0x27c/0x390
[<ffffff80080f09d0>] irq_forced_thread_fn+0x38/0x88
[<ffffff80080f0d70>] irq_thread+0x140/0x200
[<ffffff80080bf4f8>] kthread+0xd8/0xf0
[<ffffff8008083690>] ret_from_fork+0x10/0x40
Code: f2a00838 f9405763 aa1c03e1 aa1503e0 (f9000443)
---[ end trace f50005726d31199c ]---
Kernel panic - not syncing: Fatal exception in interrupt
SMP: stopping secondary CPUs
SMP: failed to stop secondary CPUs 0-1
Kernel Offset: disabled
Memory Limit: none
---[ end Kernel panic - not syncing: Fatal exception in interrupt
To fix this, re-start with the list-head after dropping the lock then
re-takeing it.
Reviewed-by: Frank Mori Hess <fmh6jj@gmail.com>
Tested-by: Frank Mori Hess <fmh6jj@gmail.com>
Signed-off-by: Qi Hou <qi.hou@windriver.com>
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
[ Upstream commit a398e043637a4819a0e96467bfecaabf3224dd62 ]
While experimenting with older compiler versions, I ran
into a warning that no longer shows up on gcc-4.8 or newer:
drivers/media/platform/s3c-camif/camif-capture.c: In function '__camif_subdev_try_format':
drivers/media/platform/s3c-camif/camif-capture.c:1265:25: error: array subscript is below array bounds
This is an off-by-one bug, leading to an access before the start of the
array, while newer compilers silently assume this undefined behavior
cannot happen and leave the loop at index 0 if no other entry matches.
As Sylvester explains, we actually need to ensure that the
value is within the range, so this reworks the loop to be
easier to parse correctly, and an additional check to fall
back on the first format value for any unexpected input.
I found an existing gcc bug for it and added a reduced version
of the function there.
Link: https://gcc.gnu.org/bugzilla/show_bug.cgi?id=69249#c3
Fixes: babde1c243b2 ("[media] V4L: Add driver for S3C24XX/S3C64XX SoC series camera interface")
Reviewed-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Acked-by: Sakari Ailus <sakari.ailus@linux.intel.com>
[ Upstream commit 5ceade1d97fc6687e050c44c257382c192f56276 ]
Currently clk_freq is ignored entirely, because the cx235840 driver
configures the xtal at the chip defaults. This is an issue if a
board is produced with a non-default frequency crystal. If clk_freq
is not zero the cx25840 will attempt to use the setting provided,
or fall back to defaults otherwise.
[ Upstream commit 779c79d4b833ec646b0aed878da38edb45bbe156 ]
Hauppauge produced a revision of ImpactVCBe using an 888,
with a 25MHz crystal, instead of using the default third
overtone 50Mhz crystal. This overrides that frequency so
that the cx25840 is properly configured. Without the proper
crystal setup the cx25840 cannot load the firmware or
decode video.
[ Upstream commit 5d6ae4f0da8a64a185074dabb1b2f8c148efa741 ]
When handling an OS descriptor request, one of the first operations is
to zero out the request buffer using the wLength from the setup packet.
There is no bounds checking, so a wLength > 4096 would clobber memory
adjacent to the request buffer. Fix this by taking the min of wLength
and the request buffer length prior to the memset. While at it, define
the buffer length in a header file so that magic numbers don't appear
throughout the code.
When returning data to the host, the data length should be the min of
the wLength and the valid data we have to return. Currently we are
returning wLength, thus requests for a wLength greater than the amount
of data in the OS descriptor buffer would return invalid (albeit zero'd)
data following the valid descriptor data. Fix this by counting the
number of bytes when constructing the data and using this when
determining the length of the request.
Signed-off-by: Chris Dickens <christopher.a.dickens@gmail.com>
Signed-off-by: Felipe Balbi <felipe.balbi@linux.intel.com>
[ Upstream commit ac87e560f7c0f91b62012e9a159c0681a373b922 ]
Due to a typo, the mask was destroyed by a comparison instead of a bit
shift.
Reported-by: Geert Uytterhoeven <geert+renesas@glider.be>
Signed-off-by: Wolfram Sang <wsa+renesas@sang-engineering.com>
[ Upstream commit 2bbea6e117357d17842114c65e9a9cf2d13ae8a3 ]
when mounting an ISO filesystem sometimes (very rarely)
the system hangs because of a race condition between two tasks.
PID: 6766 TASK: ffff88007b2a6dd0 CPU: 0 COMMAND: "mount"
#0 [ffff880078447ae0] __schedule at ffffffff8168d605
#1 [ffff880078447b48] schedule_preempt_disabled at ffffffff8168ed49
#2 [ffff880078447b58] __mutex_lock_slowpath at ffffffff8168c995
#3 [ffff880078447bb8] mutex_lock at ffffffff8168bdef
#4 [ffff880078447bd0] sr_block_ioctl at ffffffffa00b6818 [sr_mod]
#5 [ffff880078447c10] blkdev_ioctl at ffffffff812fea50
#6 [ffff880078447c70] ioctl_by_bdev at ffffffff8123a8b3
#7 [ffff880078447c90] isofs_fill_super at ffffffffa04fb1e1 [isofs]
#8 [ffff880078447da8] mount_bdev at ffffffff81202570
#9 [ffff880078447e18] isofs_mount at ffffffffa04f9828 [isofs]
#10 [ffff880078447e28] mount_fs at ffffffff81202d09
#11 [ffff880078447e70] vfs_kern_mount at ffffffff8121ea8f
#12 [ffff880078447ea8] do_mount at ffffffff81220fee
#13 [ffff880078447f28] sys_mount at ffffffff812218d6
#14 [ffff880078447f80] system_call_fastpath at ffffffff81698c49
RIP: 00007fd9ea914e9a RSP: 00007ffd5d9bf648 RFLAGS: 00010246
RAX: 00000000000000a5 RBX: ffffffff81698c49 RCX: 0000000000000010
RDX: 00007fd9ec2bc210 RSI: 00007fd9ec2bc290 RDI: 00007fd9ec2bcf30
RBP: 0000000000000000 R8: 0000000000000000 R9: 0000000000000010
R10: 00000000c0ed0001 R11: 0000000000000206 R12: 00007fd9ec2bc040
R13: 00007fd9eb6b2380 R14: 00007fd9ec2bc210 R15: 00007fd9ec2bcf30
ORIG_RAX: 00000000000000a5 CS: 0033 SS: 002b
This task was trying to mount the cdrom. It allocated and configured a
super_block struct and owned the write-lock for the super_block->s_umount
rwsem. While exclusively owning the s_umount lock, it called
sr_block_ioctl and waited to acquire the global sr_mutex lock.
PID: 6785 TASK: ffff880078720fb0 CPU: 0 COMMAND: "systemd-udevd"
#0 [ffff880078417898] __schedule at ffffffff8168d605
#1 [ffff880078417900] schedule at ffffffff8168dc59
#2 [ffff880078417910] rwsem_down_read_failed at ffffffff8168f605
#3 [ffff880078417980] call_rwsem_down_read_failed at ffffffff81328838
#4 [ffff8800784179d0] down_read at ffffffff8168cde0
#5 [ffff8800784179e8] get_super at ffffffff81201cc7
#6 [ffff880078417a10] __invalidate_device at ffffffff8123a8de
#7 [ffff880078417a40] flush_disk at ffffffff8123a94b
#8 [ffff880078417a88] check_disk_change at ffffffff8123ab50
#9 [ffff880078417ab0] cdrom_open at ffffffffa00a29e1 [cdrom]
#10 [ffff880078417b68] sr_block_open at ffffffffa00b6f9b [sr_mod]
#11 [ffff880078417b98] __blkdev_get at ffffffff8123ba86
#12 [ffff880078417bf0] blkdev_get at ffffffff8123bd65
#13 [ffff880078417c78] blkdev_open at ffffffff8123bf9b
#14 [ffff880078417c90] do_dentry_open at ffffffff811fc7f7
#15 [ffff880078417cd8] vfs_open at ffffffff811fc9cf
#16 [ffff880078417d00] do_last at ffffffff8120d53d
#17 [ffff880078417db0] path_openat at ffffffff8120e6b2
#18 [ffff880078417e48] do_filp_open at ffffffff8121082b
#19 [ffff880078417f18] do_sys_open at ffffffff811fdd33
#20 [ffff880078417f70] sys_open at ffffffff811fde4e
#21 [ffff880078417f80] system_call_fastpath at ffffffff81698c49
RIP: 00007f29438b0c20 RSP: 00007ffc76624b78 RFLAGS: 00010246
RAX: 0000000000000002 RBX: ffffffff81698c49 RCX: 0000000000000000
RDX: 00007f2944a5fa70 RSI: 00000000000a0800 RDI: 00007f2944a5fa70
RBP: 00007f2944a5f540 R8: 0000000000000000 R9: 0000000000000020
R10: 00007f2943614c40 R11: 0000000000000246 R12: ffffffff811fde4e
R13: ffff880078417f78 R14: 000000000000000c R15: 00007f2944a4b010
ORIG_RAX: 0000000000000002 CS: 0033 SS: 002b
This task tried to open the cdrom device, the sr_block_open function
acquired the global sr_mutex lock. The call to check_disk_change()
then saw an event flag indicating a possible media change and tried
to flush any cached data for the device.
As part of the flush, it tried to acquire the super_block->s_umount
lock associated with the cdrom device.
This was the same super_block as created and locked by the previous task.
The first task acquires the s_umount lock and then the sr_mutex_lock;
the second task acquires the sr_mutex_lock and then the s_umount lock.
This patch fixes the issue by moving check_disk_change() out of
cdrom_open() and let the caller take care of it.
Signed-off-by: Maurizio Lombardi <mlombard@redhat.com>
[ Upstream commit ecb29abd4cb0670c616fb563a078f25d777ce530 ]
A negative page register value means that no page needs to be
selected. This is used by status register read operations and needs
to be accepted. The failure to do so so results in missed status
and limit registers.
Fixes: da8e48ab483e1 ("hwmon: (pmbus) Always call _pmbus_read_byte in core driver")
[ Upstream commit a46f8cd696624ef757be0311eb28f119c36778e8 ]
selected. This is used by status register evaluations and needs
to be accepted.
[ Upstream commit 4058ebf33cb0be88ca516f968eda24ab7b6b93e4 ]
When using a AIO read() operation on the function FS gadget driver a URB is
submitted asynchronously and on URB completion the received data is copied
to the userspace buffer associated with the read operation.
This is done from a kernel worker thread invoking copy_to_user() (through
copy_to_iter()). And while the user space process memory is made available
to the kernel thread using use_mm(), some architecture require in addition
to this that the operation runs with USER_DS set. Otherwise the userspace
memory access will fail.
For example on ARM64 with Privileged Access Never (PAN) and User Access
Override (UAO) enabled the following crash occurs.
Internal error: Accessing user space memory with fs=KERNEL_DS: 9600004f [#1] SMP
Modules linked in:
CPU: 2 PID: 1636 Comm: kworker/2:1 Not tainted 4.9.0-04081-g8ab2dfb-dirty #487
Hardware name: ZynqMP ZCU102 Rev1.0 (DT)
Workqueue: events ffs_user_copy_worker
task: ffffffc87afc8080 task.stack: ffffffc87a00c000
PC is at __arch_copy_to_user+0x190/0x220
LR is at copy_to_iter+0x78/0x3c8
[<ffffff800847b790>] __arch_copy_to_user+0x190/0x220
[<ffffff80086f25d8>] ffs_user_copy_worker+0x70/0x130
[<ffffff80080b8c64>] process_one_work+0x1dc/0x460
[<ffffff80080b8f38>] worker_thread+0x50/0x4b0
[<ffffff80080bf5a0>] kthread+0xd8/0xf0
[<ffffff8008083680>] ret_from_fork+0x10/0x50
Address this by placing a set_fs(USER_DS) before of the copy operation
and revert it again once the copy operation has finished.
This patch is analogous to commit d7ffde35e31a ("vhost: use USER_DS in
vhost_worker thread") which addresses the same underlying issue.
[ Upstream commit 946ef68ad4e45aa048a5fb41ce8823ed29da866a ]
Some UDC drivers (like the DWC3) expect that the response to a setup()
request is queued from within the setup function itself so that it is
available as soon as setup() has completed.
Upon receiving a setup request the function fs driver creates an event that
is made available to userspace. And only once userspace has acknowledged
that event the response to the setup request is queued.
So it violates the requirement of those UDC drivers and random failures can
be observed. This is basically a race condition and if userspace is able to
read the event and queue the response fast enough all is good. But if it is
not, for example because other processes are currently scheduled to run,
the USB host that sent the setup request will observe an error.
To avoid this the gadget framework provides the USB_GADGET_DELAYED_STATUS
return code. If a setup() callback returns this value the UDC driver is
aware that response is not yet available and can uses the appropriate
methods to handle this case.
Since in the case of function fs the response will never be available when
the setup() function returns make sure that this status code is used.
This fixed random occasional failures that were previously observed on a
DWC3 based system under high system load.
[ Upstream commit 12814a3f8f9b247531d7863170cc82b3fe4218fd ]
The maximum value that unsigned char can hold is 255, meanwhile
the maximum value of interval is 2^(bIntervalMax-1)=2^15.
Signed-off-by: Grigor Tovmasyan <tovmasya@synopsys.com>
[ Upstream commit f002612b9d86613bc6fde0a444e0095225f6053e ]
This happens when BMC doesn't return any data and the code is trying
to print the value of data[2].
Getting following crash:
[ 484.728410] Unable to handle kernel NULL pointer dereference at virtual address 00000002
[ 484.736496] pgd = ffff0000094a2000
[ 484.739885] [00000002] *pgd=00000047fcffe003, *pud=00000047fcffd003, *pmd=0000000000000000
[ 484.748158] Internal error: Oops: 96000005 [#1] SMP
[ 485.101451] Call trace:
[ 485.188473] [<ffff000000a46e68>] msg_done_handler+0x668/0x700 [ipmi_ssif]
[ 485.195249] [<ffff000000a456b8>] ipmi_ssif_thread+0x110/0x128 [ipmi_ssif]
[ 485.202038] [<ffff0000080f1430>] kthread+0x108/0x138
[ 485.206994] [<ffff0000080838e0>] ret_from_fork+0x10/0x30
[ 485.212294] Code: aa1903e1 aa1803e0 b900227f 95fef6a5 (39400aa3)
Adding a check to validate the data len before printing data[2] to fix this issue.
Signed-off-by: Kamlakant Patel <kamlakant.patel@cavium.com>
Signed-off-by: Corey Minyard <cminyard@mvista.com>
[ Upstream commit 5775b843a619b3c93f946e2b55a208d9f0f48b59 ]
We leave PCI devices not bound to a driver in D0 during runtime suspend.
But they may have a parent which is bound and can be transitioned to
D3cold at runtime. Once the parent goes to D3cold, the unbound child
may go to D3cold as well. When the child goes to D3cold, its internal
state, including configuration of BARs, MSI, ASPM, MPS, etc., is lost.
One example are recent hybrid graphics laptops which cut power to the
discrete GPU when the root port above it goes to ACPI power state D3.
Users may provoke this by unbinding the GPU driver and allowing runtime
PM on the GPU via sysfs: The PM core will then treat the GPU as
"suspended", which in turn allows the root port to runtime suspend,
causing the power resources listed in its _PR3 object to be powered off.
The GPU's BARs will be uninitialized when a driver later probes it.
Another example are hybrid graphics laptops where the GPU itself (rather
than the root port) is capable of runtime suspending to D3cold. If the
GPU's integrated HDA controller is not bound and the GPU's driver
decides to runtime suspend to D3cold, the HDA controller's BARs will be
Fix by saving and restoring config space over a runtime suspend cycle
even if the device is not bound.
Acked-by: Bjorn Helgaas <bhelgaas@google.com>
Tested-by: Peter Wu <peter@lekensteyn.nl> # Nvidia Optimus
Tested-by: Lukas Wunner <lukas@wunner.de> # MacBook Pro
[lukas: add commit message, bikeshed code comments for clarity]
Signed-off-by: Lukas Wunner <lukas@wunner.de>
Link: https://patchwork.freedesktop.org/patch/msgid/92fb6e6ae2730915eb733c08e2f76c6a313e3860.1520068884.git.lukas@wunner.de
[ Upstream commit a400efe455f7b61ac9a801ac8d0d01f8c8d82dd5 ]
set udev->slot_id to zero when disabling and freeing the xhci slot.
Prevents usb core from calling xhci with a stale slot id.
xHC controller may be reset during resume to recover from some error.
All slots are unusable as they are disabled and freed.
xhci driver starts slot enumeration again from 1 in the order they are
enabled. In the worst case a stale udev->slot_id for one device matches
a newly enabled slot_id for a different device, causing us to
perform a action on the wrong device.
Signed-off-by: Mathias Nyman <mathias.nyman@linux.intel.com>
[ Upstream commit 31184d8c6ea49ea0676d100cdd7e1f102ad025b5 ]
The errata FE-8471889 description has been updated. There is still a
timing violation for repeated start. But the errata now states that it
was only the case for the Standard mode (100 kHz), in Fast mode (400 kHz)
there is no issue.
This patch limit the errata fix to the Standard mode.
It has been tesed successfully on the clearfog (Aramda 388 based board).
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
[ Upstream commit 97f3c0a4b0579b646b6b10ae5a3d59f0441cc12c ]
I found an ACPI cache leak in ACPI early termination and boot continuing case.
When early termination occurs due to malicious ACPI table, Linux kernel
terminates ACPI function and continues to boot process. While kernel terminates
ACPI function, kmem_cache_destroy() reports Acpi-Operand cache leak.
Boot log of ACPI operand cache leak is as follows:
>[ 0.464168] ACPI: Added _OSI(Module Device)
>[ 0.467022] ACPI: Added _OSI(Processor Device)
>[ 0.469376] ACPI: Added _OSI(3.0 _SCP Extensions)
>[ 0.471647] ACPI: Added _OSI(Processor Aggregator Device)
>[ 0.477997] ACPI Error: Null stack entry at ffff880215c0aad8 (20170303/exresop-174)
>[ 0.482706] ACPI Exception: AE_AML_INTERNAL, While resolving operands for [opcode_name unavailable] (20170303/dswexec-461)
>[ 0.487503] ACPI Error: Method parse/execution failed [\DBG] (Node ffff88021710ab40), AE_AML_INTERNAL (20170303/psparse-543)
>[ 0.492136] ACPI Error: Method parse/execution failed [\_SB._INI] (Node ffff88021710a618), AE_AML_INTERNAL (20170303/psparse-543)
>[ 0.497683] ACPI: Interpreter enabled
>[ 0.499385] ACPI: (supports S0)
>[ 0.501151] ACPI: Using IOAPIC for interrupt routing
>[ 0.503342] ACPI Error: Null stack entry at ffff880215c0aad8 (20170303/exresop-174)
>[ 0.506522] ACPI Exception: AE_AML_INTERNAL, While resolving operands for [opcode_name unavailable] (20170303/dswexec-461)
>[ 0.510463] ACPI Error: Method parse/execution failed [\DBG] (Node ffff88021710ab40), AE_AML_INTERNAL (20170303/psparse-543)
>[ 0.514477] ACPI Error: Method parse/execution failed [\_PIC] (Node ffff88021710ab18), AE_AML_INTERNAL (20170303/psparse-543)
>[ 0.518867] ACPI Exception: AE_AML_INTERNAL, Evaluating _PIC (20170303/bus-991)
>[ 0.522384] kmem_cache_destroy Acpi-Operand: Slab cache still has objects
>[ 0.524597] CPU: 1 PID: 1 Comm: swapper/0 Not tainted 4.12.0-rc5 #26
>[ 0.526795] Hardware name: innotek gmb_h virtual_box/virtual_box, BIOS virtual_box 12/01/2006
>[ 0.529668] Call Trace:
>[ 0.530811] ? dump_stack+0x5c/0x81
>[ 0.532240] ? kmem_cache_destroy+0x1aa/0x1c0
>[ 0.533905] ? acpi_os_delete_cache+0xa/0x10
>[ 0.535497] ? acpi_ut_delete_caches+0x3f/0x7b
>[ 0.537237] ? acpi_terminate+0xa/0x14
>[ 0.538701] ? acpi_init+0x2af/0x34f
>[ 0.540008] ? acpi_sleep_proc_init+0x27/0x27
>[ 0.541593] ? do_one_initcall+0x4e/0x1a0
>[ 0.543008] ? kernel_init_freeable+0x19e/0x21f
>[ 0.546202] ? rest_init+0x80/0x80
>[ 0.547513] ? kernel_init+0xa/0x100
>[ 0.548817] ? ret_from_fork+0x25/0x30
>[ 0.550587] vgaarb: loaded
>[ 0.551716] EDAC MC: Ver: 3.0.0
>[ 0.553744] PCI: Probing PCI hardware
>[ 0.555038] PCI host bridge to bus 0000:00
> ... Continue to boot and log is omitted ...
I analyzed this memory leak in detail and found acpi_ns_evaluate() function
only removes Info->return_object in AE_CTRL_RETURN_VALUE case. But, when errors
occur, the status value is not AE_CTRL_RETURN_VALUE, and Info->return_object is
also not null. Therefore, this causes acpi operand memory leak.
This cache leak causes a security threat because an old kernel (<= 4.9) shows
memory locations of kernel functions in stack dump. Some malicious users
could use this information to neutralize kernel ASLR.
I made a patch to fix ACPI operand cache leak.
Signed-off-by: Seunghun Han <kkamagui@gmail.com>
Signed-off-by: Erik Schmauss <erik.schmauss@intel.com>
[ Upstream commit b4c0de312613ca676db5bd7e696a44b56795612a ]
This ensures that acpi_ev_fixed_event_detect() does not use fixed_status
and and fixed_enable as uninitialized variables.
[ Upstream commit fadd94e05c02afec7b70b0b14915624f1782f578 ]
In patch "bcache: fix cached_dev->count usage for bch_cache_set_error()",
cached_dev_get() is called when creating dc->writeback_thread, and
cached_dev_put() is called when exiting dc->writeback_thread. This
modification works well unless people detach the bcache device manually by
'echo 1 > /sys/block/bcache<N>/bcache/detach'
Because this sysfs interface only calls bch_cached_dev_detach() which wakes
up dc->writeback_thread but does not stop it. The reason is, before patch
"bcache: fix cached_dev->count usage for bch_cache_set_error()", inside
bch_writeback_thread(), if cache is not dirty after writeback,
cached_dev_put() will be called here. And in cached_dev_make_request() when
a new write request makes cache from clean to dirty, cached_dev_get() will
be called there. Since we don't operate dc->count in these locations,
refcount d->count cannot be dropped after cache becomes clean, and
cached_dev_detach_finish() won't be called to detach bcache device.
This patch fixes the issue by checking whether BCACHE_DEV_DETACHING is
set inside bch_writeback_thread(). If this bit is set and cache is clean
(no existing writeback_keys), break the while-loop, call cached_dev_put()
and quit the writeback thread.
Please note if cache is still dirty, even BCACHE_DEV_DETACHING is set the
writeback thread should continue to perform writeback, this is the original
design of manually detach.
It is safe to do the following check without locking, let me explain why,
+ if (!test_bit(BCACHE_DEV_DETACHING, &dc->disk.flags) &&
+ (!atomic_read(&dc->has_dirty) || !dc->writeback_running)) {
If the kenrel thread does not sleep and continue to run due to conditions
are not updated in time on the running CPU core, it just consumes more CPU
cycles and has no hurt. This should-sleep-but-run is safe here. We just
focus on the should-run-but-sleep condition, which means the writeback
thread goes to sleep in mistake while it should continue to run.
1, First of all, no matter the writeback thread is hung or not,
kthread_stop() from cached_dev_detach_finish() will wake up it and
terminate by making kthread_should_stop() return true. And in normal
run time, bit on index BCACHE_DEV_DETACHING is always cleared, the
condition
is always true and can be ignored as constant value.
2, If one of the following conditions is true, the writeback thread should
go to sleep,
"!atomic_read(&dc->has_dirty)" or "!dc->writeback_running)"
each of them independently controls the writeback thread should sleep or
not, let's analyse them one by one.
2.1 condition "!atomic_read(&dc->has_dirty)"
If dc->has_dirty is set from 0 to 1 on another CPU core, bcache will
call bch_writeback_queue() immediately or call bch_writeback_add() which
indirectly calls bch_writeback_queue() too. In bch_writeback_queue(),
wake_up_process(dc->writeback_thread) is called. It sets writeback
thread's task state to TASK_RUNNING and following an implicit memory
barrier, then tries to wake up the writeback thread.
In writeback thread, its task state is set to TASK_INTERRUPTIBLE before
doing the condition check. If other CPU core sets the TASK_RUNNING state
after writeback thread setting TASK_INTERRUPTIBLE, the writeback thread
will be scheduled to run very soon because its state is not
TASK_INTERRUPTIBLE. If other CPU core sets the TASK_RUNNING state before
writeback thread setting TASK_INTERRUPTIBLE, the implict memory barrier
of wake_up_process() will make sure modification of dc->has_dirty on
other CPU core is updated and observed on the CPU core of writeback
thread. Therefore the condition check will correctly be false, and
continue writeback code without sleeping.
2.2 condition "!dc->writeback_running)"
dc->writeback_running can be changed via sysfs file, every time it is
modified, a following bch_writeback_queue() is alwasy called. So the
change is always observed on the CPU core of writeback thread. If
dc->writeback_running is changed from 0 to 1 on other CPU core, this
condition check will observe the modification and allow writeback
thread to continue to run without sleeping.
Now we can see, even without a locking protection, multiple conditions
check is safe here, no deadlock or process hang up will happen.
I compose a separte patch because that patch "bcache: fix cached_dev->count
usage for bch_cache_set_error()" already gets a "Reviewed-by:" from Hannes
Reinecke. Also this fix is not trivial and good for a separate patch.
Signed-off-by: Coly Li <colyli@suse.de>
Reviewed-by: Michael Lyle <mlyle@lyle.org>
Cc: Hannes Reinecke <hare@suse.com>
Cc: Huijun Tang <tang.junhui@zte.com.cn>
[ Upstream commit 55496d3fe2acd1a365c43cbd613a20ecd4d74395 ]
The generic DMA API uses dev->dma_mask to check the DMA addressable
memory bitmask, and warns if no mask is set or even allocated.
Set z->dev.dma_coherent_mask on Zorro bus scan, and make z->dev.dma_mask
to point to z->dev.dma_coherent_mask so device drivers that need DMA have
everything set up to avoid warnings from dma_alloc_coherent(). Drivers can
still use dma_set_mask_and_coherent() to explicitly set their DMA bit mask.
Signed-off-by: Michael Schmitz <schmitzmic@gmail.com>
[geert: Handle Zorro II with 24-bit address space]
Acked-by: Christoph Hellwig <hch@lst.de>
[ Upstream commit 1f9c63e8de3d7b377c9d74e4a17524cfb60e6384 ]
It's found that the clock phase output from clk_summary is
wrong compared to the actual phase reading from the register.
cat /sys/kernel/debug/clk/clk_summary | grep sdio_sample
sdio_sample 0 1 0 50000000 0 -22
It exposes an issue that clk core, clk_core_get_phase, always
returns the cached core->phase which should be either updated
by calling clk_set_phase or directly from the first place the
clk was registered.
When registering the clk, the core->phase geting from ->get_phase()
may return negative value indicating error. This is quite common
since the clk's phase may be highly related to its parent chain,
but it was temporarily orphan when registered, since its parent
chains hadn't be ready at that time, so the clk drivers decide to
return error in this case. However, if no clk_set_phase is called or
maybe the ->set_phase() isn't even implemented, the core->phase would
never be updated. This is wrong, and we should try to update it when
all its parent chains are settled down, like the way of updating clock
rate for that. But it's not deserved to complicate the code now and
just update it anyway when calling clk_core_get_phase, which would be
much simple and enough.
Acked-by: Jerome Brunet <jbrunet@baylibre.com>
Signed-off-by: Stephen Boyd <sboyd@kernel.org>
[ Upstream commit 55b55abc17f238c61921360e61dde90dd9a326d1 ]
Kmemleak reported the below leak. When cppc_cpufreq_init went into
failure path, the cpu mask is not freed. After fix, this report is
gone. And to avaoid potential NULL pointer reference, check the cpu
value first.
unreferenced object 0xffff800fd5ea4880 (size 128):
comm "swapper/0", pid 1, jiffies 4294939510 (age 668.680s)
hex dump (first 32 bytes):
00 00 00 00 20 00 00 00 00 00 00 00 00 00 00 00 .... ...........
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
backtrace:
[<ffff0000082c4ae4>] __kmalloc_node+0x278/0x634
[<ffff0000088f4a74>] alloc_cpumask_var_node+0x28/0x60
[<ffff0000088f4af0>] zalloc_cpumask_var+0x14/0x1c
[<ffff000008d20254>] cppc_cpufreq_init+0xd0/0x19c
[<ffff000008083828>] do_one_initcall+0xec/0x15c
[<ffff000008cd1018>] kernel_init_freeable+0x1f4/0x2a4
[<ffff0000089099b0>] kernel_init+0x18/0x10c
[<ffff000008084d50>] ret_from_fork+0x10/0x18
[<ffffffffffffffff>] 0xffffffffffffffff
Signed-off-by: Chunyu Hu <chuhu@redhat.com>
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
[ Upstream commit 0cab8d26d6e5e053b2bed3356992aaa71dc93628 ]
Update two GTXFIFOSIZ bit fields for the DWC_usb31 controller. TXFDEP
is a 15-bit value instead of 16-bit value, and bit 15 is TXFRAMNUM.
The GTXFIFOSIZ register for DWC_usb31 is as follows:
| BITS | Name | Description |
| 31:16 | TXFSTADDR | Transmit FIFOn RAM Start Address |
| 15 | TXFRAMNUM | Asynchronous/Periodic TXFIFO |
| 14:0 | TXFDEP | TXFIFO Depth |
Signed-off-by: Thinh Nguyen <thinhn@synopsys.com>
[ Upstream commit bda7fab54828bbef2164bb23c0f6b1a7d05cc718 ]
The operstate update logic will leave an interface in the
default UNKNOWN operstate if the interface carrier state never changes
from the default carrier up state set at creation. This includes the
case of an explicit call to netif_carrier_on, as the carrier on to on
transition has no effect on operstate.
This affects virtio-net for the case that the virtio peer does
not support VIRTIO_NET_F_STATUS (the feature that provides carrier state
updates). Without this feature, the virtio specification states that
"the link should be assumed active," so, logically, the operstate should
be UP instead of UNKNOWN. This has impact on user space applications
that use the operstate to make availability decisions for the interface.
Resolve this by changing the virtio probe logic slightly to call
netif_carrier_off for both the "with" and "without" VIRTIO_NET_F_STATUS
cases, and then the existing call to netif_carrier_on for the "without"
case will cause an operstate transition.
Cc: "Michael S. Tsirkin" <mst@redhat.com>
Cc: Jason Wang <jasowang@redhat.com>
Cc: Ben Hutchings <ben@decadent.org.uk>
Signed-off-by: Jay Vosburgh <jay.vosburgh@canonical.com>
Acked-by: Michael S. Tsirkin <mst@redhat.com>
