This is a port of commit
91ed19f5f66a7fe544f0ec385e981f43491d1d5a
for 2.6.29.
Without this after scanning your device will set
the association ID to something bogus and what is
being reported is multicast/broadcast frame are not
being received. For details see this bug report:
https://bugzilla.redhat.com/show_bug.cgi?id=498502
>From the original commit:
So that a new created IBSS network
doesn't break on the first scan.
It seems to Sujith and me that this
stupid code unnecessary, too.
So remove it...
Reported-by: David Woodhouse <dwmw2@infradead.org>
Tested-by: David Woodhouse <dwmw2@infradead.org>
Signed-off-by: Alina Friedrichsen <x-alina@gmx.net>
Signed-off-by: Jouni Malinen <Jouni.Malinen@atheros.com>
Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com>
commit e805e4d0b53506dff4255a2792483f094e7fcd2c upstream.
rndis_wext_link_change() might be called from rndis_command() at
initialization stage and priv->workqueue/priv->work have not been
initialized yet. This causes invalid opcode at rndis_wext_bind on
some brands of bcm4320.
Fix by initializing workqueue/workers in rndis_wext_bind() before
rndis_command is used.
This bug has existed since 2.6.25, reported at:
http://bugzilla.kernel.org/show_bug.cgi?id=12794
Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi>
(cherry picked from commit e523b38e2f568af58baa13120a994cbf24e6dee0)
If the BIOS does something obviously stupid, like claiming that the
registers for the IOMMU are at physical address zero, then print a nasty
message and abort, rather than trying to set up the IOMMU and then later
panicking.
It's becoming more and more obvious that trusting this stuff to the BIOS
was a mistake.
(cherry picked from commit 4958c5dc7bcb2e42d985cd26aeafd8a7eca9ab1e)
It's possible for a device in the drhd->devices[] array to be NULL if
it wasn't found at boot time, which means we have to check for that
case.
(cherry picked from commit 924b6231edfaf1e764ffb4f97ea382bf4facff58)
When the DMAR table identifies that a PCI-PCI bridge belongs to a given
IOMMU, that means that the bridge and all devices behind it should be
associated with the IOMMU. Not just the bridge itself.
This fixes the device_to_iommu() function accordingly.
(It's broken if you have the same PCI bus numbers in multiple domains,
but this function was always broken in that way; I'll be dealing with
that later).
commit 15da90b516e9da92cc1d90001e640fd6707d0e27 upstream.
The driver somehow got merged with the initializer for the dma_sff_read_status()
method missing which caused kernel panic on bootup.
This should fix the kernel.org bug #13026...
Reported-by: Arnd Hannemann <hannemann@nets.rwth-aachen.de>
Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
commit b7fcb5c4a4c27da2f6d86cb03d18687e537442cf upstream.
char bname[5] is too small for the string "X GHz" when the null
terminator is taken into account. Thus, turning on rate debugging
can crash unless we have lucky stack alignment.
Cc: stable@kernel.org
Reported-by: Paride Legovini <legovini@spiro.fisica.unipd.it>
Signed-off-by: Bob Copeland <me@bobcopeland.com>
commit 1319ebadf185933e6b7ff95211d3cef9004e9754 upstream.
Currently, when OOM occurs during rx ring refill, mv643xx_eth will get
into an infinite loop, due to the refill function setting the OOM bit
but not clearing the 'rx refill needed' bit for this queue, while the
calling function (the NAPI poll handler) will call the refill function
in a loop until the 'rx refill needed' bit goes off, without checking
the OOM bit.
This patch fixes this by checking the OOM bit in the NAPI poll handler
before attempting to do rx refill. This means that once OOM occurs,
we won't try to do any memory allocations again until the next invocation
of the poll handler.
While we're at it, change the OOM flag to be a single bit instead of
one bit per receive queue since OOM is a system state rather than a
per-queue state, and cancel the OOM timer on entry to the NAPI poll
handler if it's running to prevent it from firing when we've already
come out of OOM.
Signed-off-by: Lennert Buytenhek <buytenh@marvell.com>
commit 93af7aca44f0e82e67bda10a0fb73d383edcc8bd upstream.
On several mv643xx_eth hardware versions, the two 64bit mib counters
for 'good octets received' and 'good octets sent' are actually 32bit
counters, and reading from the upper half of the register has the same
effect as reading from the lower half of the register: an atomic
read-and-clear of the entire 32bit counter value. This can under heavy
traffic occasionally lead to small numbers being added to the upper
half of the 64bit mib counter even though no 32bit wrap has occured.
Since we poll the mib counters at least every 30 seconds anyway, we
might as well just skip the reads of the upper halves of the hardware
counters without breaking the stats, which this patch does.
upstream 82babbb3887e234c995626e4121d411ea9070ca5
backported to 2.6.29.2
2f894ef9c8b36a35d80709bedca276d2fc691941
in Linux-2.6.21 worked around BIOS with mangled _PRT entries:
http://bugzilla.kernel.org/show_bug.cgi?id=6859
d0e184abc5983281ef189db2c759d65d56eb1b80
worked around the same issue via ACPICA, and shipped in 2.6.27.
Unfortunately the two workarounds conflict:
http://bugzilla.kernel.org/show_bug.cgi?id=12270
So revert the Linux specific one.
Signed-off-by: Zhang Rui <rui.zhang@intel.com>
Signed-off-by: Len Brown <len.brown@intel.com>
This is commit 2d93148ab6988cad872e65d694c95e8944e1b626 back-ported to
2.6.29.
This patch (as1229-3) fixes a few lifetime and locking problems in the
usb-serial driver. The main symptom is that an invalid kevent is
created when the serial device is unplugged while a connection is
active.
Ports should be unregistered when device is disconnected,
not when the parent usb_serial structure is deallocated.
Each open file should hold a reference to the corresponding
port structure, and the reference should be released when
the file is closed.
serial->disc_mutex should be acquired in serial_open(), to
resolve the classic race between open and disconnect.
serial_close() doesn't need to hold both serial->disc_mutex
and port->mutex at the same time.
Release the subdriver's module reference only after releasing
all the other references, in case one of the release routines
needs to invoke some code in the subdriver module.
Replace a call to flush_scheduled_work() (which is prone to
deadlocks) with cancel_work_sync(). Also, add a call to
cancel_work_sync() in the disconnect routine.
Reduce the scope of serial->disc_mutex in serial_disconnect().
The only place it really needs to protect is where the
"disconnected" flag is set.
Call the shutdown method from within serial_disconnect()
instead of destroy_serial(), because some subdrivers expect
the port data structures still to be in existence when
their shutdown method runs.
This fixes the bug reported in
http://bugs.freedesktop.org/show_bug.cgi?id=20703
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
commit f544847fbaf099278343f875987a983f2b913134 upstream.
This patch corrects a pretty big oversight in the KMS code for 965+
chips. The current code is missing tiled surface register programming,
so userland can allocate a tiled surface and use it for mode setting,
resulting in corruption. This patch fixes that, allowing for tiled
front buffers on 965+.
Tested-by: Arkadiusz Miskiewicz <arekm@maven.pl>
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Signed-off-by: Eric Anholt <eric@anholt.net>
commit 162dedd39dcc6eca3fc0d29cf19658c6c13b840e upstream.
Without this patch, Broadcom BCM5906 Ethernet controllers set up via MSI
cause the machine to hang. Tejun agreed that the best is to blacklist
the whole chipset and after adding it, seeing the other VIA quirks
disabling MSI, this very much looks like the right way.
Cc: <stable@kernel.org>
Signed-off-by: Thomas Renninger <trenn@suse.de>
commit 72021788678523047161e97b3dfed695e802a5fd upstream.
This had been delayed for some time due to failure to work on the one piece
of G41 hardware we had, and lack of success reports from anybody else.
Current hardware appears to be OK.
Signed-off-by: Zhenyu Wang <zhenyu.z.wang@intel.com>
[anholt: hand-applied due to conflicts with IGD patches]
commit 0d44dc59b2b434b29aafeae581d06f81efac7c83 upstream.
- keep dma functions away from chained scatterlists.
Use the existing scatterlist iteration inside the driver
to call dma_map_single() for each chunk and avoid dma_map_sg().
Signed-off-by: Christian Hohnstaedt <chohnstaedt@innominate.com>
Tested-By: Karl Hiramoto <karl@hiramoto.org>
commit 37efa239901493694a48f1d6f59f8de17c2c4509 upstream.
We must not use the device DMA addresses for the kernel DMA API, because
device DMA addresses have an additional offset added for the SSB translation.
Use the original dma_addr_t for the sync operation.
Signed-off-by: Michael Buesch <mb@bu3sch.de>
upstream commit: e5b89542ea18020961882228c26db3ba87f6e608
The virtio-rng drivers checks for spurious callbacks. Since
callbacks can be implemented via shared interrupts (e.g. PCI) this
could lead to guest kernel oopses with lots of virtio devices.
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
upstream commit: 46c6e93faa85d1362e1d127dc28cf9d0b304a6f1
Reported by Alessio Treglia on
https://bugs.launchpad.net/ubuntu/+source/linux/+bug/125250
User was getting the following errors in dmesg:
[ 2158.139386] sd 5:0:0:1: ioctl_internal_command return code = 8000002
[ 2158.139390] : Current: sense key: No Sense
[ 2158.139393] Additional sense: No additional sense information
Adds unusual device support.
modified: drivers/usb/storage/unusual_devs.h
Signed-off-by: Chuck Short <zulcss@ubuntu.com>
Signed-off-by: Tim Gardner <tim.gardner@canonical.com>
Signed-off-by: Stefan Bader <stefan.bader@canonical.com>
Cc: stable <stable@kernel.org>
upstream commit: 75bd3bf2ade9d548be0d2bde60b5ee0fdce0b127
The set_blink hook code in the LED subdriver would never manage to get
a LED to blink, and instead it would just turn it on. The consequence
of this is that the "timer" trigger would not cause the LED to blink
if given default parameters.
This problem exists since 2.6.26-rc1.
To fix it, switch the deferred LED work handling to use the
thinkpad-acpi-specific LED status (off/on/blink) directly.
This also makes the code easier to read, and to extend later.
Signed-off-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br>
upstream commit: cf68636a9773aa97915497fe54fa4a51e3f08f3a
The RX buffer poison needs to be refreshed, if we recycle an RX buffer,
because it might be (partially) overwritten by some DMA operations.
Cc: Francesco Gringoli <francesco.gringoli@ing.unibs.it>
upstream commit: ec9a1d8c13e36440eda0f3c79b8149080e3ab5ba
This patch adds poisoning and sanity checking to the RX DMA buffers.
This is used for protection against buggy hardware/firmware that raises
RX interrupts without doing an actual DMA transfer.
This mechanism protects against rare "bad packets" (due to uninitialized skb data)
and rare kernel crashes due to uninitialized RX headers.
The poison is selected to not match on valid frames and to be cheap for checking.
The poison check mechanism _might_ trigger incorrectly, if we are voluntarily
receiving frames with bad PLCP headers. However, this is nonfatal, because the
chance of such a match is basically zero and in case it happens it just results
in dropping the packet.
Bad-PLCP RX defaults to off, and you should leave it off unless you want to listen
to the latest news broadcasted by your microwave oven.
This patch also moves the initialization of the RX-header "length" field in front of
the mapping of the DMA buffer. The CPU should not touch the buffer after we mapped it.
Reported-by: Francesco Gringoli <francesco.gringoli@ing.unibs.it>
upstream commit: 35a7433c789ba6df6d96b70fa745ae9e6cac0038
Reset phy state on resume, fixing a regression caused by powering down
the phy on hibernate.
Signed-off-by: Ed Swierk <eswierk@aristanetworks.com>
Cc: Tvrtko Ursulin <tvrtko.ursulin@sophos.com>
upstream commit: 5a31bec014449dc9ca994e4c1dbf2802b7ca458a
Fix a zero address hole bug in the bonding arp_ip_target list
that was causing the bond to ignore ARP replies (bugz 13006).
Instead of just setting the array entry to zero, we now
copy any additional entries down one slot, putting the
zero entry at the end. With this change we can now have
all the loops that walk the array stop when they hit a zero
since there will be no addresses after it.
Changes are based in part on code fragment provided in kernel:
bugzilla 13006:
http://bugzilla.kernel.org/show_bug.cgi?id=13006
by Steve Howard <steve@astutenetworks.com>
Signed-off-by: Brian Haley <brian.haley@hp.com>
Signed-off-by: Jay Vosburgh <fubar@us.ibm.com>
upstream commit: d119b3927994e3d620d6adb0dd1ea6bf24427875
The BUG_ON(skge->tx_ring.to_use != skge->tx_ring.to_clean) in skge_up()
was sometimes observed when setting MTU.
skge_down() disables the TX queue, but then reenables it by mistake via
skge_tx_clean().
Fix it by moving the waking of the queue from skge_tx_clean() to the
other caller. And to make sure start_xmit is not in progress on another
CPU, skge_down() should call netif_tx_disable().
The bug was reported to me by Jiri Jilek whose Debian system sometimes
failed to boot. He tested the patch and the bug did not happen anymore.
Signed-off-by: Michal Schmidt <mschmidt@redhat.com>
Acked-by: Stephen Hemminger <shemminger@vyatta.com>
upstream commit: b298cecb3deddf76d60022473a57f1cb776cbdcd
Addresses http://bugzilla.kernel.org/show_bug.cgi?id=13133
ODEBUG: object is on stack, but not annotated
WARNING: at lib/debugobjects.c:253 __debug_object_init+0x1f3/0x276()
Hardware name: VMware Virtual Platform
Modules linked in: mptspi(+) mptscsih mptbase scsi_transport_spi ext3 jbd mbcache
Pid: 540, comm: insmod Not tainted 2.6.28-mm1 #2
Call Trace:
[<c042c51c>] warn_slowpath+0x74/0x8a
[<c0469600>] ? start_critical_timing+0x96/0xb7
[<c060c8ea>] ? _spin_unlock_irqrestore+0x2f/0x3c
[<c0446fad>] ? trace_hardirqs_off_caller+0x18/0xaf
[<c044704f>] ? trace_hardirqs_off+0xb/0xd
[<c042cb84>] ? release_console_sem+0x1a5/0x1ad
[<c05013e6>] __debug_object_init+0x1f3/0x276
[<c0501494>] debug_object_init+0x13/0x17
[<c0433c56>] init_timer+0x10/0x1a
[<e08e5b54>] mpt_config+0x1c1/0x2b7 [mptbase]
[<e08e3b82>] ? kmalloc+0x8/0xa [mptbase]
[<e08e6fa2>] mpt_do_ioc_recovery+0x950/0x1212 [mptbase]
[<c04496c2>] ? __lock_acquire+0xa69/0xacc
[<c060c8f1>] ? _spin_unlock_irqrestore+0x36/0x3c
[<c060c3af>] ? _spin_unlock_irq+0x22/0x26
[<c04f2d8b>] ? string+0x2b/0x76
[<c04f310e>] ? vsnprintf+0x338/0x7b3
[<c044897d>] ? debug_check_no_locks_freed+0xeb/0x105
[<c04488bc>] ? debug_check_no_locks_freed+0x2a/0x105
[<c0446b8c>] ? lock_release_holdtime+0x43/0x48
[<c043f742>] ? up_read+0x16/0x29
[<c05076f8>] ? pci_get_slot+0x66/0x72
[<e08e89ca>] mpt_attach+0x881/0x9b1 [mptbase]
[<e091c8e5>] mptspi_probe+0x11/0x354 [mptspi]
Noticing that every caller of mpt_config has its CONFIGPARMS struct
declared on the stack and thus the &pCfg->timer is always on the stack I
changed init_timer() to init_timer_on_stack() and it seems to have shut
up.....
Cc: "Moore, Eric Dean" <Eric.Moore@lsil.com>
Cc: James Bottomley <James.Bottomley@HansenPartnership.com>
Acked-by: "Desai, Kashyap" <Kashyap.Desai@lsi.com>
Cc: <stable@kernel.org> [2.6.29.x]
upstream commit: 59de2bebabc5027f93df999d59cc65df591c3e6e
CVE-2009-1192
AGP pages might be mapped into userspace finally, so the pages should be
set to zero before userspace can use it. Otherwise there is potential
information leakage.
Signed-off-by: Shaohua Li <shaohua.li@intel.com>
upstream commit: 84a139a985300901dfad99bd93c7345d180af860
Break out of wait_event_interruptible() if freezing has been requested,
in the vballoon thread. Without this change vballoon refuses to stop and
the system can't suspend.
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
upstream commit: c0b7988200a82290287c6f4cd49585007f73175a
This reverts commit 1c55f18717304100a5f624c923f7cb6511b4116d.
Ingo Brueckl was assuming that reverting to 1:1 mapping for chars >= 128
was not useful, but it happens to be: due to the limitations of the
Linux console, when a blind user wants to read BIG5 on it, he has no
other way than loading a font without SFM and let the 1:1 mapping permit
the screen reader to get the BIG5 encoding.
Signed-off-by: Samuel Thibault <samuel.thibault@ens-lyon.org>
upstream commit: 4ced8e7cb990a2c3bbf0ac7f27b35c890e7ce895
The commit 6902c0bead4ce266226fc0c5b3828b850bdc884a that moved
driver registration out of kgameportd thread was incomplete and
did not add the code necessary to actually attach driver to
already registered devices, rectify that.
upstream commit: e4813eec8d47c8299d968bd5349dc881fa481c26
This patch (as1227) adds the MAX_SECTORS_64 flag to the unusual_devs
entry for the Simple Tech/Datafab controller. This fixes Bugzilla
#12882.
Reported-and-tested-by: binbin <binbinsh@gmail.com>
upstream commit: e13c594f3a1fc2c78e7a20d1a07974f71e4b448f
cdc-wdm needs to ignore extremely malformed descriptors.
Signed-off-by: Oliver Neukum <oliver@neukum.org>
upstream commit: ae27d84351f1f3568118318a8c40ff3a154bd629
Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk>
upstream commit: 237e75bf1e558f7330f8deb167fa3116405bef2c
The g_ether USB gadget driver currently decides whether or not there's a
link to report back for eth_get_link based on if the USB link speed is
set. The USB gadget speed is however often set even before the device is
enumerated. It seems more sensible to only report a "link" if we're
actually connected to a host that wants to talk to us. The patch below
does this for me - tested with the PXA27x UDC driver.
Signed-off-by: Jonathan McDowell <noodles@earth.li>
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
upstream commit: 015640edb1f346e0b2eda703587c4cd1c310ec1d
sg_rq_end_io() is called via rq->end_io. In some rare cases,
sg_rq_end_io calls blk_put_request/blk_rq_unmap_user (when a program
issuing a command has gone before the command completion; e.g. by
interrupting a program issuing a command before the command
completes).
We can't call blk_put_request/blk_rq_unmap_user in interrupt so the
commit c96952ed7031e7c576ecf90cf95b8ec099d5295a uses
execute_in_process_context().
The problem is that scsi_error_handler() calls rq->end_io too. We
can't call blk_put_request/blk_rq_unmap_user too in this path (we hold
q->queue_lock).
To avoid the above problem, in these rare cases, this patch always
uses schedule_work() instead of execute_in_process_context().
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Acked-by: Douglas Gilbert <dgilbert@interlog.com>
Cc: Stable Tree <stable@kernel.org>
Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
upstream commit: c96952ed7031e7c576ecf90cf95b8ec099d5295a
This fixes the following oops:
http://marc.info/?l=linux-kernel&m=123316111415677&w=2
You can reproduce this bug by interrupting a program before a sg
response completes. This leads to the special sg state (the orphan
state), then sg calls blk_put_request in interrupt (rq->end_io).
The above bug report shows the recursive lock problem because sg calls
blk_put_request in interrupt. We could call __blk_put_request here
instead however we also need to handle blk_rq_unmap_user here, which
can't be called in interrupt too.
In the orphan state, we don't need to care about the data transfer
(the program revoked the command) so adding 'just free the resource'
mode to blk_rq_unmap_user is a possible option.
I prefer to avoid complicating the blk mapping API when possible. I
change the orphan state to call sg_finish_rem_req via
execute_in_process_context. We hold sg_fd->kref so sg_fd doesn't go
away until keventd_wq finishes our work. copy_from_user/to_user fails
so blk_rq_unmap_user just frees the resource without the data
transfer.
upstream commit: a2dd3b4cea335713b58996bb07b3abcde1175f47
sg_io_owned needs to be set before the command is sent to the midlevel;
otherwise, a quickly-completing command may cause a different CPU
to see "srp->done == 1 && !srp->sg_io_owned", which would lead to
incorrect behavior.
Check srp->done and set srp->orphan while holding rq_list_lock to
prevent races with sg_rq_end_io().
There is no need to check sfp->closed from read/write/ioctl/poll/etc.
since the kernel guarantees that this won't happen.
The usefulness of sg_srp_done() was questionable before; now it is
definitely not needed.
Signed-off-by: Tony Battersby <tonyb@cybernetics.com>
upstream commit: c6517b7942fad663cc1cf3235cbe4207cf769332
sg has the following problems related to device removal:
* opening a sg fd races with removing a device
* closing a sg fd races with removing a device
* /proc/scsi/sg/* access races with removing a device
* command completion races with removing a device
* command completion races with closing a sg fd
* can rmmod sg with active commands
These problems can cause kernel oopses, memory-use-after-free, or
double-free errors. This patch fixes these problems by using krefs
to manage the lifetime of sg_device and sg_fd.
Each command submitted to the midlevel holds a reference to sg_fd
until the completion callback. This ensures that sg_fd doesn't go
away if the fd is closed with commands still outstanding.
sg_fd gets the reference of sg_device (with scsi_device) and also
makes sure that the sg module doesn't go away.
/proc/scsi/sg/* functions don't play nicely with krefs because they
give information about sg_fds which have been closed but not yet
freed due to still having outstanding commands and sg_devices which
have been removed but not yet freed due to still being referenced
by one or more sg_fds. To deal with this safely without removing
functionality, /proc functions now access sg_device and sg_fd while
holding a lock instead of using kref_get()/kref_put().
[chrisw: big for -stable, helps fix real bug, and made it through rc2 upstream]
upstream commit: 265b7215aed36941620b65ecfff516200fb190c1
The libata driver has copied the code from the IDE driver which caused a post
2.4.18 regression on many HPT370[A] chips -- DMA stopped to work completely,
only causing timeouts. Now remove hpt370_bmdma_start() for good...
upstream commit: c018f1ee5cf81e58b93d9e93a2ee39cad13dc1ac
The big driver change in 2.4.19-rc1 introduced a regression for many HPT370[A]
chips -- DMA stopped to work completely, only causing endless timeouts...
The culprit has been identified (at last!): it turned to be the code resetting
the DMA state machine before each transfer. Stop doing it now as this counter-
measure has clearly caused more harm than good.
This should fix the kernel.org bug #7703.
upstream commit: 718cff1eec595ce6ab0635b8160a51ee37d9268d
sfc could call netif_napi_add() multiple times for the same
napi_struct, corrupting the list of napi_structs for the associated
device and leading to a busy-loop on device removal. Move the call to
netif_napi_add() and add a call to netif_napi_del() in the obvious
places.
[bhutchings: backport to 2.6.29]
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
upstream commit: cf5450930db0ae308584e5361f3345e0ff73e643
If the ti-usb adapter returns an zero data length frame (which happens)
then we leak a kref. Found by Christoph Mair <christoph.mair@gmail.com>
who proposed a patch. The patch here is different as Christoph's patch
didn't work for the case where tty = NULL and data arrived but Christoph
did all the hard work chasing it down.
Signed-off-by: Alan Cox <alan@linux.intel.com>
upstream commit: bdff549ebeff92b1a6952e5501caf16a6f8898c8
The "simplify spi_write_then_read()" patch included two regressions from
the 2.6.27 behaviors:
- The data it wrote out during the (full duplex) read side
of the transfer was not zeroed.
- It fails completely on half duplex hardware, such as
Microwire and most "3-wire" SPI variants.
So, revert that patch. A revised version should be submitted at some
point, which can get the speedup on standard hardware (full duplex)
without breaking on less-capable half-duplex stuff.
Cc: <stable@kernel.org> [2.6.28.x, 2.6.29.x]
upstream commit: 340cd44451fb0bfa542365e6b4b565bbd44836e2
If the thread calling dm_kcopyd_copy is delayed due to scheduling inside
split_job/segment_complete and the subjobs complete before the loop in
split_job completes, the kcopyd callback could be invoked from the
thread that called dm_kcopyd_copy instead of the kcopyd workqueue.
dm_kcopyd_copy -> split_job -> segment_complete -> job->fn()
Snapshots depend on the fact that callbacks are called from the singlethreaded
kcopyd workqueue and expect that there is no racing between individual
callbacks. The racing between callbacks can lead to corruption of exception
store and it can also mean that exception store callbacks are called twice
for the same exception - a likely reason for crashes reported inside
pending_complete() / remove_exception().
This patch fixes two problems:
1. job->fn being called from the thread that submitted the job (see above).
- Fix: hand over the completion callback to the kcopyd thread.
2. job->fn(read_err, write_err, job->context); in segment_complete
reports the error of the last subjob, not the union of all errors.
- Fix: pass job->write_err to the callback to report all error bits
(it is done already in run_complete_job)
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
Signed-off-by: Alasdair G Kergon <agk@redhat.com>
upstream commit: 73830857bca6f6c9dbd48e906daea50bea42d676
Use a variable in segment_complete() to point to the dm_kcopyd_client
struct and only release job->pages in run_complete_job() if any are
defined. These changes are needed by the next patch.
upstream commit: fd6e1c14b73dbab89cb76af895d5612e4a8b5522
Le lundi 30 mars 2009, Chris Wright a écrit :
> q->queue could be ERR_PTR(-ENOMEM) which will break unwinding
> on error. Make iscsi_pool_free more defensive.
Making the freeing of q->queue dependent on q->pool being set looks
really weird (although it is correct at the moment. But this seems
to be fixable in a much simpler way.
With the benefit that only the error case is slowed down. In both
cases we have a problem if q->queue contains an error value but it's
not -ENOMEM. Apparently this can't happen today, but it doesn't feel
right to assume this will always be true. Maybe it's the right time
to fix this as well.
Signed-off-by: Mike Christie <michaelc@cs.wisc.edu>
[chrisw: this is a fixlet to f474a37b, also in -stable]
upstream commit: f474a37bc48667595b5653a983b635c95ed82a3b
Memory freeing in iscsi_pool_free() looks wrong to me. Either q->pool
can be NULL and this should be tested before dereferencing it, or it
can't be NULL and it shouldn't be tested at all. As far as I can see,
the only case where q->pool is NULL is on early error in
iscsi_pool_init(). One possible way to fix the bug is thus to not
call iscsi_pool_free() in this case (nothing needs to be freed anyway)
and then we can get rid of the q->pool check.
Signed-off-by: Jean Delvare <jdelvare@suse.de>
upstream commit: a74dd5fdabcd34c93e17e9c7024eeb503c92b048
The Aspire One's ACPI-WMI interface is a placeholder that does nothing,
and the invalid results that we get from it are now causing userspace
problems as acer-wmi always returns that the rfkill is enabled (i.e. the
radio is off, when it isn't). As it's hardware controlled, acer-wmi
isn't needed on the Aspire One either.
Thanks to Andy Whitcroft at Canonical for tracking down Ubuntu's userspace
issues to this.
Signed-off-by: Carlos Corbacho <carlos@strangeworlds.co.uk>
Reported-by: Andy Whitcroft <apw@canonical.com>
upstream commit: 570b9d968bf9b16974252ef7cbce73fa6dac34f3
upgrade_mode() sets bdev to NULL temporarily, and does not have any
locking to exclude anything from seeing that NULL.
In dm_table_any_congested() bdev_get_queue() can dereference that NULL and
cause a reported oops.
Fix this by not changing that field during the mode upgrade.
Cc: Neil Brown <neilb@suse.de>
upstream commit: aea9058801c0acfa2831af1714da412dfb0018c2
Fix refcount corruption in dm-path-selector
Refcounting with non-atomic ops under shared lock will corrupt the counter
in multi-processor system and may trigger BUG_ON().
Use module refcount.
# same approach as dm-target-use-module-refcount-directly.patch here
# https://www.redhat.com/archives/dm-devel/2008-December/msg00075.html
Typical oops:
kernel BUG at linux-2.6.29-rc3/drivers/md/dm-path-selector.c:90!
Pid: 11148, comm: dmsetup Not tainted 2.6.29-rc3-nm #1
dm_put_path_selector+0x4d/0x61 [dm_multipath]
Call Trace:
[<ffffffffa031d3f9>] free_priority_group+0x33/0xb3 [dm_multipath]
[<ffffffffa031d4aa>] free_multipath+0x31/0x67 [dm_multipath]
[<ffffffffa031d50d>] multipath_dtr+0x2d/0x32 [dm_multipath]
[<ffffffffa015d6c2>] dm_table_destroy+0x64/0xd8 [dm_mod]
[<ffffffffa015b73a>] __unbind+0x46/0x4b [dm_mod]
[<ffffffffa015b79f>] dm_swap_table+0x60/0x14d [dm_mod]
[<ffffffffa015f963>] dev_suspend+0xfd/0x177 [dm_mod]
[<ffffffffa0160250>] dm_ctl_ioctl+0x24c/0x29c [dm_mod]
[<ffffffff80288cd3>] ? get_page_from_freelist+0x49c/0x61d
[<ffffffffa015f866>] ? dev_suspend+0x0/0x177 [dm_mod]
[<ffffffff802bf05c>] vfs_ioctl+0x2a/0x77
[<ffffffff802bf4f1>] do_vfs_ioctl+0x448/0x4a0
[<ffffffff802bf5a0>] sys_ioctl+0x57/0x7a
[<ffffffff8020c05b>] system_call_fastpath+0x16/0x1b
Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com>
upstream commit: 5642b8a61a15436231adf27b2b1bd96901b623dd
The tt_internal's 'use' field is superfluous: the module's refcount can do
the work properly. An acceptable side-effect is that this increases the
reference counts reported by 'lsmod'.
Remove the superfluous test when removing a target module.
[Crash possible without this on SMP - agk]
Signed-off-by: Cheng Renquan <crquan@gmail.com>
Reviewed-by: Alasdair G Kergon <agk@redhat.com>
Reviewed-by: Jonathan Brassow <jbrassow@redhat.com>
