path: root/drivers
2012-10-21tpm: Propagate error from tpm_transmit to fix a timeout hangPeter Huewe
commit abce9ac292e13da367bbd22c1f7669f988d931ac upstream. tpm_write calls tpm_transmit without checking the return value and assigns the return value unconditionally to chip->pending_data, even if it's an error value. This causes three bugs. So if we write to /dev/tpm0 with a tpm_param_size bigger than TPM_BUFSIZE=0x1000 (e.g. 0x100a) and a bufsize also bigger than TPM_BUFSIZE (e.g. 0x100a) tpm_transmit returns -E2BIG which is assigned to chip->pending_data as -7, but tpm_write returns that TPM_BUFSIZE bytes have been successfully been written to the TPM, altough this is not true (bug #1). As we did write more than than TPM_BUFSIZE bytes but tpm_write reports that only TPM_BUFSIZE bytes have been written the vfs tries to write the remaining bytes (in this case 10 bytes) to the tpm device driver via tpm_write which then blocks at /* cannot perform a write until the read has cleared either via tpm_read or a user_read_timer timeout */ while (atomic_read(&chip->data_pending) != 0) msleep(TPM_TIMEOUT); for 60 seconds, since data_pending is -7 and nobody is able to read it (since tpm_read luckily checks if data_pending is greater than 0) (#bug 2). After that the remaining bytes are written to the TPM which are interpreted by the tpm as a normal command. (bug #3) So if the last bytes of the command stream happen to be a e.g. tpm_force_clear this gets accidentally sent to the TPM. This patch fixes all three bugs, by propagating the error code of tpm_write and returning -E2BIG if the input buffer is too big, since the response from the tpm for a truncated value is bogus anyway. Moreover it returns -EBUSY to userspace if there is a response ready to be read. Signed-off-by: Peter Huewe <peter.huewe@infineon.com> Signed-off-by: Kent Yoder <key@linux.vnet.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-21drm/radeon: Don't destroy I2C Bus Rec in radeon_ext_tmds_enc_destroy().Egbert Eich
commit 082918471139b07964967cfe5f70230909c82ae1 upstream. radeon_i2c_fini() walks thru the list of I2C bus recs rdev->i2c_bus[] to destroy each of them. radeon_ext_tmds_enc_destroy() however also has code to destroy it's associated I2C bus rec which has been obtained by radeon_i2c_lookup() and is therefore also in the i2c_bus[] list. This causes a double free resulting in a kernel panic when unloading the radeon driver. Removing destroy code from radeon_ext_tmds_enc_destroy() fixes this problem. agd5f: fix compiler warning Signed-off-by: Egbert Eich <eich@suse.de> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-21Add CDC-ACM support for the CX93010-2x UCMxx USB ModemJean-Christian de Rivaz
commit e7d491a19d3e3aac544070293891a2542ae0c565 upstream. This USB V.92/V.32bis Controllered Modem have the USB vendor ID 0x0572 and device ID 0x1340. It need the NO_UNION_NORMAL quirk to be recognized. Reference: http://www.conexant.com/servlets/DownloadServlet/DSH-201723-005.pdf?docid=1725&revid=5 See idVendor and idProduct in table 6-1. Device Descriptors Signed-off-by: Jean-Christian de Rivaz <jc@eclis.ch> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-21tg3: Apply short DMA frag workaround to 5906Matt Carlson
commit b7abee6ef888117f92db370620ebf116a38e3f4d upstream. 5906 devices also need the short DMA fragment workaround. This patch makes the necessary change. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Tested-by: Christian Kujau <lists@nerdbynature.de> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Mike Pagano <mpagano@gentoo.org>
2012-10-21viafb: don't touch clock state on OLPC XO-1.5Daniel Drake
commit 012a1211845eab69a5488d59eb87d24cc518c627 upstream. As detailed in the thread titled "viafb PLL/clock tweaking causes XO-1.5 instability," enabling or disabling the IGA1/IGA2 clocks causes occasional stability problems during suspend/resume cycles on this platform. This is rather odd, as the documentation suggests that clocks have two states (on/off) and the default (stable) configuration is configured to enable the clock only when it is needed. However, explicitly enabling *or* disabling the clock triggers this system instability, suggesting that there is a 3rd state at play here. Leaving the clock enable/disable registers alone solves this problem. This fixes spurious reboots during suspend/resume behaviour introduced by commit b692a63a. Signed-off-by: Daniel Drake <dsd@laptop.org> Signed-off-by: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-21video/udlfb: fix line counting in fb_writeAlexander Holler
commit b8c4321f3d194469007f5f5f2b34ec278c264a04 upstream. Line 0 and 1 were both written to line 0 (on the display) and all subsequent lines had an offset of -1. The result was that the last line on the display was never overwritten by writes to /dev/fbN. Signed-off-by: Alexander Holler <holler@ahsoftware.de> Acked-by: Bernie Thompson <bernie@plugable.com> Signed-off-by: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-21firewire: cdev: fix user memory corruption (i386 userland on amd64 kernel)Stefan Richter
commit 790198f74c9d1b46b6a89504361b1a844670d050 upstream. Fix two bugs of the /dev/fw* character device concerning the FW_CDEV_IOC_GET_INFO ioctl with nonzero fw_cdev_get_info.bus_reset. (Practically all /dev/fw* clients issue this ioctl right after opening the device.) Both bugs are caused by sizeof(struct fw_cdev_event_bus_reset) being 36 without natural alignment and 40 with natural alignment. 1) Memory corruption, affecting i386 userland on amd64 kernel: Userland reserves a 36 bytes large buffer, kernel writes 40 bytes. This has been first found and reported against libraw1394 if compiled with gcc 4.7 which happens to order libraw1394's stack such that the bug became visible as data corruption. 2) Information leak, affecting all kernel architectures except i386: 4 bytes of random kernel stack data were leaked to userspace. Hence limit the respective copy_to_user() to the 32-bit aligned size of struct fw_cdev_event_bus_reset. Reported-by: Simon Kirby <sim@hostway.ca> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-21ACPI: EC: Add a quirk for CLEVO M720T/M730T laptopFeng Tang
commit 67bfa9b60bd689601554526d144b21d529f78a09 upstream. By enlarging the GPE storm threshold back to 20, that laptop's EC works fine with interrupt mode instead of polling mode. https://bugzilla.kernel.org/show_bug.cgi?id=45151 Reported-and-Tested-by: Francesco <trentini@dei.unipd.it> Signed-off-by: Feng Tang <feng.tang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-21ACPI: EC: Make the GPE storm threshold a module parameterFeng Tang
commit a520d52e99b14ba7db135e916348f12f2a6e09be upstream. The Linux EC driver includes a mechanism to detect GPE storms, and switch from interrupt-mode to polling mode. However, polling mode sometimes doesn't work, so the workaround is problematic. Also, different systems seem to need the threshold for detecting the GPE storm at different levels. ACPI_EC_STORM_THRESHOLD was initially 20 when it's created, and was changed to 8 in 2.6.28 commit 06cf7d3c7 "ACPI: EC: lower interrupt storm threshold" to fix kernel bug 11892 by forcing the laptop in that bug to work in polling mode. However in bug 45151, it works fine in interrupt mode if we lift the threshold back to 20. This patch makes the threshold a module parameter so that user has a flexible option to debug/workaround this issue. The default is unchanged. This is also a preparation patch to fix specific systems: https://bugzilla.kernel.org/show_bug.cgi?id=45151 Signed-off-by: Feng Tang <feng.tang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13mtd: omap2: fix module loadingAndreas Bießmann
commit 4d3d688da8e7016f15483e9319b41311e1db9515 upstream. Unloading the omap2 nand driver missed to release the memory region which will result in not being able to request it again if one want to load the driver later on. This patch fixes following error when loading omap2 module after unloading: ---8<--- ~ $ rmmod omap2 ~ $ modprobe omap2 [ 37.420928] omap2-nand: probe of omap2-nand.0 failed with error -16 ~ $ --->8--- This error was introduced in 67ce04bf2746f8a1f8c2a104b313d20c63f68378 which was the first commit of this driver. Signed-off-by: Andreas Bießmann <andreas@biessmann.de> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13mtd: omap2: fix omap_nand_remove segfaultAndreas Bießmann
commit 7d9b110269253b1d5858cfa57d68dfc7bf50dd77 upstream. Do not kfree() the mtd_info; it is handled in the mtd subsystem and already freed by nand_release(). Instead kfree() the struct omap_nand_info allocated in omap_nand_probe which was not freed before. This patch fixes following error when unloading the omap2 module: ---8<--- ~ $ rmmod omap2 ------------[ cut here ]------------ kernel BUG at mm/slab.c:3126! Internal error: Oops - BUG: 0 [#1] PREEMPT ARM Modules linked in: omap2(-) CPU: 0 Not tainted (3.6.0-rc3-00230-g155e36d-dirty #3) PC is at cache_free_debugcheck+0x2d4/0x36c LR is at kfree+0xc8/0x2ac pc : [<c01125a0>] lr : [<c0112efc>] psr: 200d0193 sp : c521fe08 ip : c0e8ef90 fp : c521fe5c r10: bf0001fc r9 : c521e000 r8 : c0d99c8c r7 : c661ebc0 r6 : c065d5a4 r5 : c65c4060 r4 : c78005c0 r3 : 00000000 r2 : 00001000 r1 : c65c4000 r0 : 00000001 Flags: nzCv IRQs off FIQs on Mode SVC_32 ISA ARM Segment user Control: 10c5387d Table: 86694019 DAC: 00000015 Process rmmod (pid: 549, stack limit = 0xc521e2f0) Stack: (0xc521fe08 to 0xc5220000) fe00: c008a874 c00bf44c c515c6d0 200d0193 c65c4860 c515c240 fe20: c521fe3c c521fe30 c008a9c0 c008a854 c521fe5c c65c4860 c78005c0 bf0001fc fe40: c780ff40 a00d0113 c521e000 00000000 c521fe84 c521fe60 c0112efc c01122d8 fe60: c65c4860 c0673778 c06737ac 00000000 00070013 00000000 c521fe9c c521fe88 fe80: bf0001fc c0112e40 c0673778 bf001ca8 c521feac c521fea0 c02ca11c bf0001ac fea0: c521fec4 c521feb0 c02c82c4 c02ca100 c0673778 bf001ca8 c521fee4 c521fec8 fec0: c02c8dd8 c02c8250 00000000 bf001ca8 bf001ca8 c0804ee0 c521ff04 c521fee8 fee0: c02c804c c02c8d20 bf001924 00000000 bf001ca8 c521e000 c521ff1c c521ff08 ff00: c02c950c c02c7fbc bf001d48 00000000 c521ff2c c521ff20 c02ca3a4 c02c94b8 ff20: c521ff3c c521ff30 bf001938 c02ca394 c521ffa4 c521ff40 c009beb4 bf001930 ff40: c521ff6c 70616d6f b6fe0032 c0014f84 70616d6f b6fe0032 00000081 60070010 ff60: c521ff84 c521ff70 c008e1f4 c00bf328 0001a004 70616d6f c521ff94 0021ff88 ff80: c008e368 0001a004 70616d6f b6fe0032 00000081 c0015028 00000000 c521ffa8 ffa0: c0014dc0 c009bcd0 0001a004 70616d6f bec2ab38 00000880 bec2ab38 00000880 ffc0: 0001a004 70616d6f b6fe0032 00000081 00000319 00000000 b6fe1000 00000000 ffe0: bec2ab30 bec2ab20 00019f00 b6f539c0 60070010 bec2ab38 aaaaaaaa aaaaaaaa Backtrace: [<c01122cc>] (cache_free_debugcheck+0x0/0x36c) from [<c0112efc>] (kfree+0xc8/0x2ac) [<c0112e34>] (kfree+0x0/0x2ac) from [<bf0001fc>] (omap_nand_remove+0x5c/0x64 [omap2]) [<bf0001a0>] (omap_nand_remove+0x0/0x64 [omap2]) from [<c02ca11c>] (platform_drv_remove+0x28/0x2c) r5:bf001ca8 r4:c0673778 [<c02ca0f4>] (platform_drv_remove+0x0/0x2c) from [<c02c82c4>] (__device_release_driver+0x80/0xdc) [<c02c8244>] (__device_release_driver+0x0/0xdc) from [<c02c8dd8>] (driver_detach+0xc4/0xc8) r5:bf001ca8 r4:c0673778 [<c02c8d14>] (driver_detach+0x0/0xc8) from [<c02c804c>] (bus_remove_driver+0x9c/0x104) r6:c0804ee0 r5:bf001ca8 r4:bf001ca8 r3:00000000 [<c02c7fb0>] (bus_remove_driver+0x0/0x104) from [<c02c950c>] (driver_unregister+0x60/0x80) r6:c521e000 r5:bf001ca8 r4:00000000 r3:bf001924 [<c02c94ac>] (driver_unregister+0x0/0x80) from [<c02ca3a4>] (platform_driver_unregister+0x1c/0x20) r5:00000000 r4:bf001d48 [<c02ca388>] (platform_driver_unregister+0x0/0x20) from [<bf001938>] (omap_nand_driver_exit+0x14/0x1c [omap2]) [<bf001924>] (omap_nand_driver_exit+0x0/0x1c [omap2]) from [<c009beb4>] (sys_delete_module+0x1f0/0x2ec) [<c009bcc4>] (sys_delete_module+0x0/0x2ec) from [<c0014dc0>] (ret_fast_syscall+0x0/0x48) r8:c0015028 r7:00000081 r6:b6fe0032 r5:70616d6f r4:0001a004 Code: e1a00005 eb0d9172 e7f001f2 e7f001f2 (e7f001f2) ---[ end trace 6a30b24d8c0cc2ee ]--- Segmentation fault --->8--- This error was introduced in 67ce04bf2746f8a1f8c2a104b313d20c63f68378 which was the first commit of this driver. Signed-off-by: Andreas Bießmann <andreas@biessmann.de> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13mtd: nand: Use the mirror BBT descriptor when reading its versionShmulik Ladkani
commit 7bb9c75436212813b38700c34df4bbb6eb82debe upstream. The code responsible for reading the version of the mirror bbt was incorrectly using the descriptor of the main bbt. Pass the mirror bbt descriptor to 'scan_read_raw' when reading the version of the mirror bbt. Signed-off-by: Shmulik Ladkani <shmulik.ladkani@gmail.com> Acked-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13mtd: nandsim: bugfix: fail if overridesize is too bigRichard Genoud
commit bb0a13a13411c4ce24c48c8ff3cdf7b48d237240 upstream. If override size is too big, the module was actually loaded instead of failing, because retval was not set. This lead to memory corruption with the use of the freed structs nandsim and nand_chip. Signed-off-by: Richard Genoud <richard.genoud@gmail.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13mtd: autcpu12-nvram: Fix compile breakageAlexander Shiyan
commit d1f55c680e5d021e7066f4461dd678d42af18898 upstream. Update driver autcpu12-nvram.c so it compiles; map_read32/map_write32 no longer exist in the kernel so the driver is totally broken. Additionally, map_info name passed to simple_map_init is incorrect. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13r8169: call netif_napi_del at errpaths and at driver unloadDevendra Naga
commit ad1be8d345416a794dea39761a374032aa471a76 upstream. When register_netdev fails, the init'ed NAPIs by netif_napi_add must be deleted with netif_napi_del, and also when driver unloads, it should delete the NAPI before unregistering netdevice using unregister_netdev. Signed-off-by: Devendra Naga <devendra.aaru@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13r8169: fix unsigned int wraparound with TSOJulien Ducourthial
commit 477206a018f902895bfcd069dd820bfe94c187b1 upstream. The r8169 may get stuck or show bad behaviour after activating TSO : the net_device is not stopped when it has no more TX descriptors. This problem comes from TX_BUFS_AVAIL which may reach -1 when all transmit descriptors are in use. The patch simply tries to keep positive values. Tested with 8111d(onboard) on a D510MO, and with 8111e(onboard) on a Zotac 890GXITX. Signed-off-by: Julien Ducourthial <jducourt@free.fr> Acked-by: Francois Romieu <romieu@fr.zoreil.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13r8169: 8168c and later require bit 0x20 to be set in Config2 for PME signaling.Francois Romieu
commit d387b427c973974dd619a33549c070ac5d0e089f upstream. The new 84xx stopped flying below the radars. Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Cc: Hayes Wang <hayeswang@realtek.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13r8169: Config1 is read-only on 8168c and later.Francois Romieu
commit 851e60221926a53344b4227879858bef841b0477 upstream. Suggested by Hayes. Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Cc: Hayes Wang <hayeswang@realtek.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13r8169: runtime resume before shutdown.françois romieu
commit 2a15cd2ff488a9fdb55e5e34060f499853b27c77 upstream. With runtime PM, if the ethernet cable is disconnected, the device is transitioned to D3 state to conserve energy. If the system is shutdown in this state, any register accesses in rtl_shutdown are dropped on the floor. As the device was programmed by .runtime_suspend() to wake on link changes, it is thus brought back up as soon as the link recovers. Resuming every suspended device through the driver core would slow things down and it is not clear how many devices really need it now. Original report and D0 transition patch by Sameer Nanda. Patch has been changed to comply with advices by Rafael J. Wysocki and the PM folks. Reported-by: Sameer Nanda <snanda@chromium.org> Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Cc: Rafael J. Wysocki <rjw@sisk.pl> Cc: Hayes Wang <hayeswang@realtek.com> Cc: Alan Stern <stern@rowland.harvard.edu> Acked-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13r8169: missing barriers.Francois Romieu
commit 1e874e041fc7c222cbd85b20c4406070be1f687a upstream. Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Cc: Hayes Wang <hayeswang@realtek.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13r8169: fix Config2 MSIEnable bit setting.françois romieu
commit 2ca6cf06d988fea21e812a86be79353352677c9c upstream. The MSIEnable bit is only available for the 8169. Avoid Config2 writes for the post-8169 8168 and 810x. Reported-by: Su Kang Yin <cantona@cantona.net> Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Cc: Hayes Wang <hayeswang@realtek.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13r8169: Rx FIFO overflow fixes.Francois Romieu
commit 811fd3010cf512f2e23e6c4c912aad54516dc706 upstream. Realtek has specified that the post 8168c gigabit chips and the post 8105e fast ethernet chips recover automatically from a Rx FIFO overflow. The driver does not need to clear the RxFIFOOver bit of IntrStatus and it should rather avoid messing it. The implementation deserves some explanation: 1. events outside of the intr_event bit mask are now ignored. It enforces a no-processing policy for the events that either should not be there or should be ignored. 2. RxFIFOOver was already ignored in rtl_cfg_infos[RTL_CFG_1] for the whole 8168 line of chips with two exceptions: - RTL_GIGA_MAC_VER_22 since b5ba6d12bdac21bc0620a5089e0f24e362645efd ("use RxFIFO overflow workaround for 8168c chipset."). This one should now be correctly handled. - RTL_GIGA_MAC_VER_11 (8168b) which requires a different Rx FIFO overflow processing. Though it does not conform to Realtek suggestion above, the updated driver includes no change for RTL_GIGA_MAC_VER_12 and RTL_GIGA_MAC_VER_17. Both are 8168b. RTL_GIGA_MAC_VER_12 is common and a bit old so I'd rather wait for experimental evidence that the change suggested by Realtek really helps or does not hurt in unexpected ways. Removed case statements in rtl8169_interrupt are only 8168 relevant. 3. RxFIFOOver is masked for post 8105e 810x chips, namely the sole 8105e (RTL_GIGA_MAC_VER_30) itself. Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Cc: hayeswang <hayeswang@realtek.com> Signed-off-by: David S. Miller <davem@davemloft.net> Reviewed-by: Jonathan Nieder <jrnieder@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13r8169: increase the delay parameter of pm_schedule_suspendhayeswang
commit 10953db8e1a278742ef7e64a3d1491802bcfa98b upstream The link down would occur when reseting PHY. And it would take about 2 ~ 5 seconds from link down to link up. If the delay of pm_schedule_suspend is not long enough, the device would enter runtime_suspend before link up. After link up, the device would wake up and reset PHY again. Then, you would find the driver keep in a loop of runtime_suspend and rumtime_resume. Signed-off-by: Hayes Wang <hayeswang@realtek.com> Acked-by: Francois Romieu <romieu@fr.zoreil.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13r8169: expand received packet length indication.Francois Romieu
commit deb9d93c89d311714a60809b28160e538e1cbb43 upstream. 8168d and above allow jumbo frames beyond 8k. Bump the received packet length check before enabling jumbo frames on these chipsets. Frame length indication covers bits 0..13 of the first Rx descriptor 32 bits for the 8169 and 8168. I only have authoritative documentation for the allowed use of the extra (13) bit with the 8169 and 8168c. Realtek's drivers use the same mask for the 816x and the fast ethernet only 810x. Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13r8169: jumbo fixes.Francois Romieu
commit d58d46b5d85139d18eb939aa7279c160bab70484 upstream. - fix features : jumbo frames and checksumming can not be used at the same time. - introduce hw_jumbo_{enable / disable} helpers. Their content has been creatively extracted from Realtek's own drivers. As an illustration, it would be nice to know how/if the MaxTxPacketSize register operates when the device can work with a 9k jumbo frame as its documentation (8168c) can not be applied beyond ~7k. - rtl_tx_performance_tweak is moved forward. No change. Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13r8169: remove erroneous processing of always set bit.Francois Romieu
commit e03f33af79f0772156e1a1a1e36bdddf8012b2e4 upstream. When set, RxFOVF (resp. RxBOVF) is always 1 (resp. 0). Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Cc: Hayes <hayeswang@realtek.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13r8169: don't enable rx when shutdown.Hayes Wang
commit aaa89c08d9ffa3739c93d65d98b73ec2aa2e93a5 upstream. Only 8111b needs to enable rx when shutdowning with WoL. Signed-off-by: Hayes Wang <hayeswang@realtek.com> Acked-by: Francois Romieu <romieu@fr.zoreil.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13r8169: fix wake on lan setting for non-8111E.Hayes Wang
commit d4ed95d796e5126bba51466dc07e287cebc8bd19 upstream. Only 8111E needs enable RxConfig bit 0 ~ 3 when suspending or shutdowning for wake on lan. Signed-off-by: Hayes Wang <hayeswang@realtek.com> Acked-by: Francois Romieu <romieu@fr.zoreil.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13drm/radeon: force MSIs on RS690 asicsAlex Deucher
commit fb6ca6d154cdcd53e7f27f8dbba513830372699b upstream. There are so many quirks, lets just try and force this for all RS690s. See: https://bugs.freedesktop.org/show_bug.cgi?id=37679 Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13drm/radeon: Add MSI quirk for gateway RS690Alex Deucher
commit 3a6d59df80897cc87812b6826d70085905bed013 upstream. Fixes another system on: https://bugs.freedesktop.org/show_bug.cgi?id=37679 Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13drm/radeon: only adjust default clocks on NI GPUsAlex Deucher
commit 2e3b3b105ab3bb5b6a37198da4f193cd13781d13 upstream. SI asics store voltage information differently so we don't have a way to deal with it properly yet. Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13PCI: Check P2P bridge for invalid secondary/subordinate rangeYinghai Lu
commit 1965f66e7db08d1ebccd24a59043eba826cc1ce8 upstream. For bridges with "secondary > subordinate", i.e., invalid bus number apertures, we don't enumerate anything behind the bridge unless the user specified "pci=assign-busses". This patch makes us automatically try to reassign the downstream bus numbers in this case (just for that bridge, not for all bridges as "pci=assign-busses" does). We don't discover all the devices on the Intel DP43BF motherboard without this change (or "pci=assign-busses") because its BIOS configures a bridge as: pci 0000:00:1e.0: PCI bridge to [bus 20-08] (subtractive decode) [bhelgaas: changelog, change message to dev_info] Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=18412 Bugzilla: https://bugzilla.redhat.com/show_bug.cgi?id=625754 Reported-by: Brian C. Huffman <bhuffman@graze.net> Reported-by: VL <vl.homutov@gmail.com> Tested-by: VL <vl.homutov@gmail.com> Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2012-10-13SCSI: zfcp: only access zfcp_scsi_dev for valid scsi_deviceMartin Peschke
commit d436de8ce25f53a8a880a931886821f632247943 upstream. __scsi_remove_device (e.g. due to dev_loss_tmo) calls zfcp_scsi_slave_destroy which in turn sends a close LUN FSF request to the adapter. After 30 seconds without response, zfcp_erp_timeout_handler kicks the ERP thread failing the close LUN ERP action. zfcp_erp_wait in zfcp_erp_lun_shutdown_wait and thus zfcp_scsi_slave_destroy returns and then scsi_device is no longer valid. Sometime later the response to the close LUN FSF request may finally come in. However, commit b62a8d9b45b971a67a0f8413338c230e3117dff5 "[SCSI] zfcp: Use SCSI device data zfcp_scsi_dev instead of zfcp_unit" introduced a number of attempts to unconditionally access struct zfcp_scsi_dev through struct scsi_device causing a use-after-free. This leads to an Oops due to kernel page fault in one of: zfcp_fsf_abort_fcp_command_handler, zfcp_fsf_open_lun_handler, zfcp_fsf_close_lun_handler, zfcp_fsf_req_trace, zfcp_fsf_fcp_handler_common. Move dereferencing of zfcp private data zfcp_scsi_dev allocated in scsi_device via scsi_transport_reserve_device after the check for potentially aborted FSF request and thus no longer valid scsi_device. Only then assign sdev_to_zfcp(sdev) to the local auto variable struct zfcp_scsi_dev *zfcp_sdev. Signed-off-by: Martin Peschke <mpeschke@linux.vnet.ibm.com> Signed-off-by: Steffen Maier <maier@linux.vnet.ibm.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13SCSI: zfcp: restore refcount check on port_removeSteffen Maier
commit d99b601b63386f3395dc26a699ae703a273d9982 upstream. Upstream commit f3450c7b917201bb49d67032e9f60d5125675d6a "[SCSI] zfcp: Replace local reference counting with common kref" accidentally dropped a reference count check before tearing down zfcp_ports that are potentially in use by zfcp_units. Even remote ports in use can be removed causing unreachable garbage objects zfcp_ports with zfcp_units. Thus units won't come back even after a manual port_rescan. The kref of zfcp_port->dev.kobj is already used by the driver core. We cannot re-use it to track the number of zfcp_units. Re-introduce our own counter for units per port and check on port_remove. Signed-off-by: Steffen Maier <maier@linux.vnet.ibm.com> Reviewed-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13SCSI: zfcp: remove invalid reference to list iterator variableJulia Lawall
commit ca579c9f136af4274ccfd1bcaee7f38a29a0e2e9 upstream. If list_for_each_entry, etc complete a traversal of the list, the iterator variable ends up pointing to an address at an offset from the list head, and not a meaningful structure. Thus this value should not be used after the end of the iterator. Replace port->adapter->scsi_host by adapter->scsi_host. This problem was found using Coccinelle (http://coccinelle.lip6.fr/). Oversight in upsteam commit of v2.6.37 a1ca48319a9aa1c5b57ce142f538e76050bb8972 "[SCSI] zfcp: Move ACL/CFDC code to zfcp_cfdc.c" which merged the content of zfcp_erp_port_access_changed(). Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Steffen Maier <maier@linux.vnet.ibm.com> Reviewed-by: Martin Peschke <mpeschke@linux.vnet.ibm.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13SCSI: zfcp: Do not wakeup while suspendedSteffen Maier
commit cb45214960bc989af8b911ebd77da541c797717d upstream. If the mapping of FCP device bus ID and corresponding subchannel is modified while the Linux image is suspended, the resume of FCP devices can fail. During resume, zfcp gets callbacks from cio regarding the modified subchannels but they can be arbitrarily mixed with the restore/resume callback. Since the cio callbacks would trigger adapter recovery, zfcp could wakeup before the resume callback. Therefore, ignore the cio callbacks regarding subchannels while being suspended. We can safely do so, since zfcp does not deal itself with subchannels. For problem determination purposes, we still trace the ignored callback events. The following kernel messages could be seen on resume: kernel: <WWPN>: parent <FCP device bus ID> should not be sleeping As part of adapter reopen recovery, zfcp performs auto port scanning which can erroneously try to register new remote ports with scsi_transport_fc and the device core code complains about the parent (adapter) still sleeping. kernel: zfcp.3dff9c: <FCP device bus ID>:\ Setting up the QDIO connection to the FCP adapter failed <last kernel message repeated 3 more times> kernel: zfcp.574d43: <FCP device bus ID>:\ ERP cannot recover an error on the FCP device In such cases, the adapter gave up recovery and remained blocked along with its child objects: remote ports and LUNs/scsi devices. Even the adapter shutdown as part of giving up recovery failed because the ccw device state remained disconnected. Later, the corresponding remote ports ran into dev_loss_tmo. As a result, the LUNs were erroneously not available again after resume. Even a manually triggered adapter recovery (e.g. sysfs attribute failed, or device offline/online via sysfs) could not recover the adapter due to the remaining disconnected state of the corresponding ccw device. Signed-off-by: Steffen Maier <maier@linux.vnet.ibm.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13SCSI: zfcp: Make trace record tags uniqueSteffen Maier
commit 0100998dbfe6dfcd90a6e912ca7ed6f255d48f25 upstream. Duplicate fssrh_2 from a54ca0f62f953898b05549391ac2a8a4dad6482b "[SCSI] zfcp: Redesign of the debug tracing for HBA records." complicates distinction of generic status read response from local link up. Duplicate fsscth1 from 2c55b750a884b86dea8b4cc5f15e1484cc47a25c "[SCSI] zfcp: Redesign of the debug tracing for SAN records." complicates distinction of good common transport response from invalid port handle. Signed-off-by: Steffen Maier <maier@linux.vnet.ibm.com> Reviewed-by: Martin Peschke <mpeschke@linux.vnet.ibm.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13tg3: Fix TSO CAP for 5704 devs w / ASF enabledMatt Carlson
[ Upstream commit cf9ecf4b631f649a964fa611f1a5e8874f2a76db ] On the earliest TSO capable devices, TSO was accomplished through firmware. The TSO cannot coexist with ASF management firmware though. The tg3 driver determines whether or not ASF is enabled by calling tg3_get_eeprom_hw_cfg(), which checks a particular bit of NIC memory. Commit dabc5c670d3f86d15ee4f42ab38ec5bd2682487d, entitled "tg3: Move TSO_CAPABLE assignment", accidentally moved the code that determines TSO capabilities earlier than the call to tg3_get_eeprom_hw_cfg(). As a consequence, the driver was attempting to determine TSO capabilities before it had all the data it needed to make the decision. This patch fixes the problem by revisiting and reevaluating the decision after tg3_get_eeprom_hw_cfg() is called. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13aoe: assert AoE packets marked as requiring no checksumEd Cashin
[ Upstream commit 8babe8cc6570ed896b7b596337eb8fe730c3ff45 ] In order for the network layer to see that AoE requires no checksumming in a generic way, the packets must be marked as requiring no checksum, so we make this requirement explicit with the assertion. Signed-off-by: Ed Cashin <ecashin@coraid.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13pppoe: drop PPPOX_ZOMBIEs in pppoe_releaseXiaodong Xu
[ Upstream commit 2b018d57ff18e5405823e5cb59651a5b4d946d7b ] When PPPOE is running over a virtual ethernet interface (e.g., a bonding interface) and the user tries to delete the interface in case the PPPOE state is ZOMBIE, the kernel will loop forever while unregistering net_device for the reference count is not decreased to zero which should have been done with dev_put(). Signed-off-by: Xiaodong Xu <stid.smth@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13sierra_net: Endianess bug fix.Lennart Sorensen
[ Upstream commit 2120c52da6fe741454a60644018ad2a6abd957ac ] I discovered I couldn't get sierra_net to work on a powerpc. Turns out the firmware attribute check assumes the system is little endian and hence fails because the attributes is a 16 bit value. Signed-off-by: Len Sorensen <lsorense@csclub.uwaterloo.ca> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13netxen: check for root bus in netxen_mask_aer_correctableNikolay Aleksandrov
[ Upstream commit e4d1aa40e363ed3e0486aeeeb0d173f7f822737e ] Add a check if pdev->bus->self == NULL (root bus). When attaching a netxen NIC to a VM it can be on the root bus and the guest would crash in netxen_mask_aer_correctable() because of a NULL pointer dereference if CONFIG_PCIEAER is present. Signed-off-by: Nikolay Aleksandrov <nikolay@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13ixp4xx_hss: fix build failure due to missing linux/module.h inclusionFlorian Fainelli
[ Upstream commit 0b836ddde177bdd5790ade83772860940bd481ea ] Commit 36a1211970193ce215de50ed1e4e1272bc814df1 (netprio_cgroup.h: dont include module.h from other includes) made the following build error on ixp4xx_hss pop up: CC [M] drivers/net/wan/ixp4xx_hss.o drivers/net/wan/ixp4xx_hss.c:1412:20: error: expected ';', ',' or ')' before string constant drivers/net/wan/ixp4xx_hss.c:1413:25: error: expected ';', ',' or ')' before string constant drivers/net/wan/ixp4xx_hss.c:1414:21: error: expected ';', ',' or ')' before string constant drivers/net/wan/ixp4xx_hss.c:1415:19: error: expected ';', ',' or ')' before string constant make[8]: *** [drivers/net/wan/ixp4xx_hss.o] Error 1 This was previously hidden because ixp4xx_hss includes linux/hdlc.h which includes linux/netdevice.h which includes linux/netprio_cgroup.h which used to include linux/module.h. The real issue was actually present since the initial commit that added this driver since it uses macros from linux/module.h without including this file. Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13net: ethernet: davinci_cpdma: decrease the desc count when cleaning up the ↵htbegin
remaining packets [ Upstream commit ffb5ba90017505a19e238e986e6d33f09e4df765 ] chan->count is used by rx channel. If the desc count is not updated by the clean up loop in cpdma_chan_stop, the value written to the rxfree register in cpdma_chan_start will be incorrect. Signed-off-by: Tao Hou <hotforest@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13drivers/scsi/atp870u.c: fix bad use of udelayMartin Michlmayr
commit 0f6d93aa9d96cc9022b51bd10d462b03296be146 upstream. The ACARD driver calls udelay() with a value > 2000, which leads to to the following compilation error on ARM: ERROR: "__bad_udelay" [drivers/scsi/atp870u.ko] undefined! make[1]: *** [__modpost] Error 1 This is because udelay is defined on ARM, roughly speaking, as #define udelay(n) ((n) > 2000 ? __bad_udelay() : \ __const_udelay((n) * ((2199023U*HZ)>>11))) The argument to __const_udelay is the number of jiffies to wait divided by 4, but this does not work unless the multiplication does not overflow, and that is what the build error is designed to prevent. The intended behavior can be achieved by using mdelay to call udelay multiple times in a loop. [jrnieder@gmail.com: adding context] Signed-off-by: Martin Michlmayr <tbm@cyrius.com> Signed-off-by: Jonathan Nieder <jrnieder@gmail.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13PCI: acpiphp: check whether _ADR evaluation succeededBjorn Helgaas
commit dfb117b3e50c52c7b3416db4a4569224b8db80bb upstream. Check whether we evaluated _ADR successfully. Previously we ignored failure, so we would have used garbage data from the stack as the device and function number. We return AE_OK so that we ignore only this slot and continue looking for other slots. Found by Coverity (CID 113981). Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> [bwh: Backported to 2.6.32/3.0: adjust context] Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13ACPI: run _OSC after ACPI_FULL_INITIALIZATIONLin Ming
commit fc54ab72959edbf229b65ac74b2f122d799ca002 upstream. The _OSC method may exist in module level code, so it must be called after ACPI_FULL_INITIALIZATION On some new platforms with Zero-Power-Optical-Disk-Drive (ZPODD) support, this fix is necessary to save power. Signed-off-by: Lin Ming <ming.m.lin@intel.com> Tested-by: Aaron Lu <aaron.lu@intel.com> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13media: rc: ite-cir: Initialise ite_dev::rdev earlierBen Hutchings
commit 4b961180ef275035b1538317ffd0e21e80e63e77 upstream. ite_dev::rdev is currently initialised in ite_probe() after rc_register_device() returns. If a newly registered device is opened quickly enough, we may enable interrupts and try to use ite_dev::rdev before it has been initialised. Move it up to the earliest point we can, right after calling rc_allocate_device(). Reported-and-tested-by: YunQiang Su <wzssyqa@gmail.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-07SCSI: scsi_dh_alua: Enable STPG for unavailable portsBart Van Assche
commit e47f8976d8e573928824a06748f7bc82c58d747f upstream. A quote from SPC-4: "While in the unavailable primary target port asymmetric access state, the device server shall support those of the following commands that it supports while in the active/optimized state: [ ... ] d) SET TARGET PORT GROUPS; [ ... ]". Hence enable sending STPG to a target port group that is in the unavailable state. Signed-off-by: Bart Van Assche <bvanassche@acm.org> Reviewed-by: Mike Christie <michaelc@cs.wisc.edu> Acked-by: Hannes Reinecke <hare@suse.de> Signed-off-by: James Bottomley <JBottomley@Parallels.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-07SCSI: scsi_remove_target: fix softlockup regression on hot removeDan Williams
commit bc3f02a795d3b4faa99d37390174be2a75d091bd upstream. John reports: BUG: soft lockup - CPU#2 stuck for 23s! [kworker/u:8:2202] [..] Call Trace: [<ffffffff8141782a>] scsi_remove_target+0xda/0x1f0 [<ffffffff81421de5>] sas_rphy_remove+0x55/0x60 [<ffffffff81421e01>] sas_rphy_delete+0x11/0x20 [<ffffffff81421e35>] sas_port_delete+0x25/0x160 [<ffffffff814549a3>] mptsas_del_end_device+0x183/0x270 ...introduced by commit 3b661a9 "[SCSI] fix hot unplug vs async scan race". Don't restart lookup of more stargets in the multi-target case, just arrange to traverse the list once, on the assumption that new targets are always added at the end. There is no guarantee that the target will change state in scsi_target_reap() so we can end up spinning if we restart. Acked-by: Jack Wang <jack_wang@usish.com> LKML-Reference: <CAEhu1-6wq1YsNiscGMwP4ud0Q+MrViRzv=kcWCQSBNc8c68N5Q@mail.gmail.com> Reported-by: John Drescher <drescherjm@gmail.com> Tested-by: John Drescher <drescherjm@gmail.com> Signed-off-by: Dan Williams <djbw@fb.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
