commit 72bb99cfe9c57d2044445fb34bbc95b4c0bae6f2 upstream.
In the situation that a writer fails to copy data from userspace it will reset
the write offset to the value it had before it went to sleep. This discarding
any messages written while aquiring the mutex.
Therefore the reset offset needs to be retrieved after acquiring the mutex.
Cc: Android Kernel Team <kernel-team@android.com>
Signed-off-by: Bjorn Andersson <bjorn.andersson@sonymobile.com>
commit 69acbaac303e8cb948801a9ddd0ac24e86cc4a1b upstream.
Comedi devices can do blocking read() or write() (or poll()) if an
asynchronous command has been set up, blocking for data (for read()) or
buffer space (for write()). Various events associated with the
asynchronous command will wake up the blocked reader or writer (or
poller). It is also possible to force the asynchronous command to
terminate by issuing a `COMEDI_CANCEL` ioctl. That shuts down the
asynchronous command, but does not currently wake up the blocked reader
or writer (or poller). If the blocked task could be woken up, it would
see that the command is no longer active and return. The caller of the
`COMEDI_CANCEL` ioctl could attempt to wake up the blocked task by
sending a signal, but that's a nasty workaround.
Change `do_cancel_ioctl()` to wake up the wait queue after it returns
from `do_cancel()`. `do_cancel()` can propagate an error return value
from the low-level comedi driver's cancel routine, but it always shuts
the command down regardless, so `do_cancel_ioctl()` can wake up he wait
queue regardless of the return value from `do_cancel()`.
Signed-off-by: Ian Abbott <abbotti@mev.co.uk>
commit 4b18f08be01a7b3c7b6df497137b6e3cb28adaa3 upstream.
`do_cmd_ioctl()` is called with the comedi device's mutex locked to
process the `COMEDI_CMD` ioctl to set up comedi's asynchronous command
handling on a comedi subdevice. `comedi_read()` and `comedi_write()`
are the `read` and `write` handlers for the comedi device, but do not
lock the mutex (for performance reasons, as some things can hold the
mutex for quite a long time).
There is a race condition if `comedi_read()` or `comedi_write()` is
running at the same time and for the same file object and comedi
subdevice as `do_cmd_ioctl()`. `do_cmd_ioctl()` sets the subdevice's
`busy` pointer to the file object way before it sets the `SRF_RUNNING` flag
in the subdevice's `runflags` member. `comedi_read() and
`comedi_write()` check the subdevice's `busy` pointer is pointing to the
current file object, then if the `SRF_RUNNING` flag is not set, will call
`do_become_nonbusy()` to shut down the asyncronous command. Bad things
can happen if the asynchronous command is being shutdown and set up at
the same time.
To prevent the race, don't set the `busy` pointer until
after the `SRF_RUNNING` flag has been set. Also, make sure the mutex is
held in `comedi_read()` and `comedi_write()` while calling
`do_become_nonbusy()` in order to avoid moving the race condition to a
point within that function.
Change some error handling `goto cleanup` statements in `do_cmd_ioctl()`
to simple `return -ERRFOO` statements as a result of changing when the
`busy` pointer is set.
commit e583d9db9960cf40e0bc8afee4946baa9d71596e upstream.
The hub driver was recently changed to use "global" suspend for system
suspend transitions on non-SuperSpeed buses. This means that we don't
suspend devices individually by setting the suspend feature on the
upstream hub port; instead devices all go into suspend automatically
when the root hub stops transmitting packets. The idea was to save
time and to avoid certain kinds of wakeup races.
Now it turns out that many hubs are buggy; they don't relay wakeup
requests from a downstream port to their upstream port if the
downstream port's suspend feature is not set (depending on the speed
of the downstream port, whether or not the hub is enabled for remote
wakeup, and possibly other factors).
We can't have hubs dropping wakeup requests. Therefore this patch
goes partway back to the old policy: It sets the suspend feature for a
port if the device attached to that port or any of its descendants is
enabled for wakeup. People will still be able to benefit from the
time savings if they don't care about wakeup and leave it disabled on
all their devices.
In order to accomplish this, the patch adds a new field to the usb_hub
structure: wakeup_enabled_descendants is a count of how many devices
below a suspended hub are enabled for remote wakeup. A corresponding
new subroutine determines the number of wakeup-enabled devices at or
below an arbitrary suspended USB device.
This should be applied to the 3.10 stable kernel.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Reported-and-tested-by: Toralf Förster <toralf.foerster@gmx.de>
commit 2c7b871b9102c497ba8f972aa5d38532f05b654d upstream.
Control transfers have both IN and OUT (or SETUP) packets, so when
clearing TT buffers for a control transfer it's necessary to send
two HUB_CLEAR_TT_BUFFER requests to the hub.
Signed-off-by: William Gulland <wgulland@google.com>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
commit 58fc90db8261b571c026bb8bf23aad48a7233118 upstream.
Signed-off-by: Jóhann B. Guðmundsson <johannbg@fedoraproject.org>
commit 1fad56424f5ad3ce4973505a357212b2e2282b3f upstream.
The driver failed to take the dynamic ids into account when determining
the device type and therefore all devices were detected as 2-port
devices when using the dynamic-id interface.
Match on the usb-serial-driver field instead of doing redundant id-table
searches.
Reported-by: Anders Hammarquist <iko@iko.pp.se>
Signed-off-by: Johan Hovold <jhovold@gmail.com>
commit cdcedd6981194e511cc206887db661d016069d68 upstream.
In case we fail our ->udc_start() callback, we
should be ready to accept another modprobe following
the failed one.
We had forgotten to clear dwc->gadget_driver back
to NULL and, because of that, we were preventing
gadget driver modprobe from being retried.
Signed-off-by: Felipe Balbi <balbi@ti.com>
commit 1974d494dea05ea227cb42f5e918828801e237aa upstream.
Per dwc3 2.50a spec, the is_devspec bit is used to distinguish the
Device Endpoint-Specific Event or Device-Specific Event (DEVT). If the
bit is 1, the event is represented Device-Specific Event, then use
[7:1] bits as Device Specific Event to marked the type. It has 7 bits,
and we can see the reserved8_31 variable name which means from 8 to 31
bits marked reserved, actually there are 24 bits not 25 bits between
that. And 1 + 7 + 24 = 32, the event size is 4 byes.
So in dwc3_event_type, the bit mask should be:
is_devspec [0] 1 bit
type [7:1] 7 bits
reserved8_31 [31:8] 24 bits
This patch should be backported to kernels as old as 3.2, that contain
the commit 72246da40f3719af3bfd104a2365b32537c27d83 "usb: Introduce
DesignWare USB3 DRD Driver".
Signed-off-by: Huang Rui <ray.huang@amd.com>
commit 315955d707b50c8aad20a32ec0dd4c9fe243cabe upstream.
When there is an error with the usb3_phy probe or absence, the error returned
is erroneously for usb2_phy.
Signed-off-by: Ruchika Kharwar <ruchika@ti.com>
commit 5f8a2e68b679b41cc8e9b642f2f5aa45dd678641 upstream.
Allocated urbs and buffers were never freed on errors in open.
commit 47a64a13d54f6c669b00542848d5550be3d3310e upstream.
Set the ehci->resuming flag for the port we receive a remote
wakeup on so that resume signalling can be completed.
Without this, the root hub timer will not fire again to check
if the resume was completed and there will be a never-ending wait on
on the port.
This effect is only observed if the HUB IRQ IN does not come after we
have initiated the port resume.
Signed-off-by: Roger Quadros <rogerq@ti.com>
commit 203a86613fb3bf2767335659513fa98563a3eb71 upstream.
When the host controller fails to respond to an Enable Slot command, and
the host fails to respond to the register write to abort the command
ring, the xHCI driver will assume the host is dead, and call
usb_hc_died().
The USB device's slot_id is still set to zero, and the pointer stored at
xhci->devs[0] will always be NULL. The call to xhci_check_args in
xhci_free_dev should have caught the NULL virt_dev pointer.
However, xhci_free_dev is designed to free the xhci_virt_device
structures, even if the host is dead, so that we don't leak kernel
memory. xhci_free_dev checks the return value from the generic
xhci_check_args function. If the return value is -ENODEV, it carries on
trying to free the virtual device.
The issue is that xhci_check_args looks at the host controller state
before it looks at the xhci_virt_device pointer. It will return -ENIVAL
because the host is dead, and xhci_free_dev will ignore the return
value, and happily dereference the NULL xhci_virt_device pointer.
The fix is to make sure that xhci_check_args checks the xhci_virt_device
pointer before it checks the host state.
See https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1203453 for
further details. This patch doesn't solve the underlying issue, but
will ensure we don't see any more NULL pointer dereferences because of
the issue.
This patch should be backported to kernels as old as 3.1, that
contain the commit 7bd89b4017f46a9b92853940fd9771319acb578a "xhci: Don't
submit commands or URBs to halted hosts."
Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
Reported-by: Vincent Thiele <vincentthiele@gmail.com>
commit d66eaf9f89502971fddcb0de550b01fa6f409d83 upstream.
in some cases where device is attched to xhci port and do not responding,
for example ath9k_htc with stalled firmware, kernel will
crash on ring_doorbell_for_active_rings.
This patch check if pointer exist before it is used.
This patch should be backported to kernels as old as 2.6.35, that
contain the commit e9df17eb1408cfafa3d1844bfc7f22c7237b31b8 "USB: xhci:
Correct assumptions about number of rings per endpoint"
Signed-off-by: Oleksij Rempel <linux@rempel-privat.de>
commit 07f3cb7c28bf3f4dd80bfb136cf45810c46ac474 upstream.
Xhci controllers with hci_version > 0.96 gives spurious success
events on short packet completion. During webcam capture the
"ERROR Transfer event TRB DMA ptr not part of current TD" was observed.
The same application works fine with synopsis controllers hci_version 0.96.
The same issue is seen with Intel Pantherpoint xhci controller. So enabling
this quirk in xhci_gen_setup if controller verion is greater than 0.96.
For xhci-pci move the quirk to much generic place xhci_gen_setup.
Note from Sarah:
The xHCI 1.0 spec changed how hardware handles short packets. The HW
will notify SW of the TRB where the short packet occurred, and it will
also give a successful status for the last TRB in a TD (the one with the
IOC flag set). On the second successful status, that warning will be
triggered in the driver.
Software is now supposed to not assume the TD is not completed until it
gets that last successful status. That means we have a slight race
condition, although it should have little practical impact. This patch
papers over that issue.
It's on my long-term to-do list to fix this race condition, but it is a
much more involved patch that will probably be too big for stable. This
patch is needed for stable to avoid serious log spam.
This patch should be backported to kernels as old as 3.0, that
contain the commit ad808333d8201d53075a11bc8dd83b81f3d68f0b "Intel xhci:
Ignore spurious successful event."
The patch will have to be modified for kernels older than 3.2, since
that kernel added the xhci_gen_setup function for xhci platform devices.
The correct conflict resolution for kernels older than 3.2 is to set
XHCI_SPURIOUS_SUCCESS in xhci_pci_quirks for all xHCI 1.0 hosts.
Signed-off-by: George Cherian <george.cherian@ti.com>
commit c3ccb1d7cf4c4549151876dd37c0944a682fd9e1 upstream.
This fixes a regression where Xyratex controllers and disks were lost by the
driver:
https://bugzilla.kernel.org/show_bug.cgi?id=59601
Reported-by: Jack Hill <jackhill@jackhill.us>
Signed-off-by: Saurav Kashyap <saurav.kashyap@qlogic.com>
Signed-off-by: Giridhar Malavali <giridhar.malavali@qlogic.com>
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
commit 085b513f97d8d799d28491239be4b451bcd8c2c5 upstream.
sd_prep_fn will allocate a larger CDB for the command via mempool_alloc
for devices using DIF type 2 protection. This CDB was being freed
in sd_done, which results in a kernel crash if the command is retried
due to a UNIT ATTENTION. This change moves the code to free the larger
CDB into sd_unprep_fn instead, which is invoked after the request is
complete.
It is no longer necessary to call scsi_print_command separately for
this case as the ->cmnd will no longer be NULL in the normal code path.
Also removed conditional test for DIF type 2 when freeing the larger
CDB because the protection_type could have been changed via sysfs while
the command was executing.
Signed-off-by: Ewan D. Milne <emilne@redhat.com>
Acked-by: Martin K. Petersen <martin.petersen@oracle.com>
commit 96f15f29038e58e1b0a96483e2b369ff446becf1 upstream.
This commit fixes a race condition in the isci driver abort task and SSP
device task management path. The race is caused when an I/O termination
in the SCU hardware is necessary because of an SSP target timeout condition,
and the check of the I/O end state races against the HW-termination-driven
end state. The failure of the race meant that no TMF was sent to the device
to clean-up the pending I/O.
Signed-off-by: Jeff Skirvin <jeffrey.d.skirvin@intel.com>
Reviewed-by: Lukasz Dorau <lukasz.dorau@intel.com>
commit 0699a73af3811b66b1ab5650575acee5eea841ab upstream.
Commit 18d627113b83 (firewire: prevent dropping of completed iso packet
header data) was intended to be an obvious bug fix, but libdc1394 and
FlyCap2 depend on the old behaviour by ignoring all returned information
and thus not noticing that not all packets have been received yet. The
result was that the video frame buffers would be saved before they
contained the correct data.
Reintroduce the old behaviour for old clients.
Tested-by: Stepan Salenikovich <stepan.salenikovich@gmail.com>
Tested-by: Josep Bosch <jep250@gmail.com>
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
commit e7a6121f4929c17215f0cdca3726f4bf3e4e9529 upstream.
The device report an error capacity when read_capacity_16().
Using read_capacity_10() can get the correct capacity.
Signed-off-by: Ren Bigcren <bigcren.ren@sonymobile.com>
Cc: Matthew Dharm <mdharm-usb@one-eyed-alien.net>
Signed-off-by: Oskar Andero <oskar.andero@sonymobile.com>
commit 186a9647019587b3784694894c4d136fd00cfd7b upstream.
This patch adds target_get_sess_cmd reference counting for
iscsit_handle_task_mgt_cmd(), and adds a target_put_sess_cmd()
for the failure case.
It also fixes a bug where ISCSI_OP_SCSI_TMFUNC type commands
where leaking iscsi_cmd->i_conn_node and eventually triggering
an OOPs during struct isert_conn shutdown.
commit b2cb96494d83b894a43ba8b9023eead8ff50684b upstream.
This patch addresses a bug where RDMA_CM_EVENT_DISCONNECTED may occur
before the connection shutdown has been completed by rx/tx threads,
that causes isert_free_conn() to wait indefinately on ->conn_wait.
This patch allows isert_disconnect_work code to invoke rdma_disconnect
when isert_disconnect_work() process context is started by client
session reset before isert_free_conn() code has been reached.
It also adds isert_conn->conn_mutex protection for ->state within
isert_disconnect_work(), isert_cq_comp_err() and isert_free_conn()
code, along with isert_check_state() for wait_event usage.
(v2: Add explicit iscsit_cause_connection_reinstatement call
during isert_disconnect_work() to force conn reset)
Cc: Or Gerlitz <ogerlitz@mellanox.com>
commit 0fbfc46fb0b2f543a8b539e94c6c293ebc0b05a6 upstream.
This patch fixes a potential buffer overflow while processing
iscsi_node_auth input for configfs attributes within NodeACL
tfc_tpg_nacl_auth_cit context.
Signed-off-by: Joern Engel <joern@logfs.org>
commit 3df8f68aaf7ebe3d136a22262b41b350b0a1858b upstream.
This patch adds the missing isert_put_reject() logic to post
a outgoing payload buffer to hold the 48 bytes of original PDU
header request payload for the rejected cmd.
It also fixes ISTATE_SEND_REJECT handling in isert_response_completion()
-> isert_do_control_comp() code, and drops incorrect iscsi_cmd_t->reject_comp
usage.
Cc: Mike Christie <michaelc@cs.wisc.edu>
commit 414abbd2cd4c2618895f02ed3a76ec6647281436 upstream.
In dvb_ringbuffer lock-less synchronizationof reader and writer threads is done
with separateread and write pointers. Sincedvb_ringbuffer_flush() modifies the
read pointer, this function must not be called from the writer thread.
This patch removes the dvb_ringbuffer_flush() calls in the dmxdev ringbuffer
write functions, this fixes Oopses "Unable to handle kernel paging request"
I could observe for the call chaindvb_demux_read ->dvb_dmxdev_buffer_read ->
dvb_ringbuffer_read_user -> __copy_to_user (the reader side of the ringbuffer).
The flush calls at the write side are not necessary anyway since ringbuffer_flush
is also called in dvb_dmxdev_buffer_read() when an error condition is set in the
ringbuffer.
This patch should also be applied to stable kernels.
Signed-off-by: Soeren Moch <smoch@web.de>
Reviewed-by: Sakari Ailus <sakari.ailus@iki.fi>
commit e6355ad7b1c6f70e2f48ae159f5658b441ccff95 upstream.
snd_pcm_stop() must be called in the PCM substream lock context.
commit b579fa52f6be0b4157ca9cc5e94d44a2c89a7e95 upstream.
This patch adds support for the Schweitzer Engineering Laboratories
C662 USB cable based off the CP210x driver.
Signed-off-by: Barry Grussling <barry@grussling.com>
commit 7681156982026ebf7eafd7301eb0374d7648d068 upstream.
Added support for MMB Networks and Planet Innovation Ingeni ZigBee USB
devices using customized Silicon Labs' CP210x.c USB to UART bridge
drivers with PIDs: 88A4, 88A5.
Signed-off-by: Sami Rahman <sami.rahman@mmbresearch.com>
Tested-by: Sami Rahman <sami.rahman@mmbresearch.com>
commit 90625070c4253377025878c4e82feed8b35c7116 upstream.
This adds NetGear Managed Switch M4100 series, M5300 series, M7100 series
USB ID (0846:0110) to the cp210x driver. Without this, the serial
adapter is not recognized in Linux. Description was obtained from
an Netgear Eng.
Signed-off-by: Luiz Angelo Daros de Luca <luizluca@gmail.com>
commit 63b5df963f52ccbab6fabedf05b7ac6b465789a4 upstream.
This patch adds support for the ONYX 3G device (version 1) from ALFA
NETWORK.
Signed-off-by: Enrico Mioso <mrkiko.rs@gmail.com>
commit ca24763588844b14f019ffc45c7df6d9e8f932c5 upstream.
Adding support for D-Link DWM-152/C1 and DWM-156/C1 devices.
DWM-152/C1:
T: Bus=01 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 6 Spd=480 MxCh= 0
D: Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=07d1 ProdID=3e01 Rev= 0.00
S: Product=USB Configuration
S: SerialNumber=1234567890ABCDEF
C:* #Ifs= 5 Cfg#= 1 Atr=e0 MxPwr=500mA
I:* If#= 0 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=ff Prot=ff Driver=option
E: Ad=81(I) Atr=03(Int.) MxPS= 64 Ivl=2ms
E: Ad=82(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=01(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms
I:* If#= 1 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=option
E: Ad=83(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=02(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms
I:* If#= 2 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=option
E: Ad=84(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=03(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms
I:* If#= 3 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=option
E: Ad=85(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=04(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms
I:* If#= 4 Alt= 0 #EPs= 2 Cls=08(stor.) Sub=06 Prot=50 Driver=usb-storage
E: Ad=05(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=86(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
DWM-156/C1:
T: Bus=01 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 8 Spd=480 MxCh= 0
P: Vendor=07d1 ProdID=3e02 Rev= 0.00
S: Product=DataCard Device
Signed-off-by: Alexandr Ivanov <alexandr.sky@gmail.com>
commit c38e83b6cc2adf80e3f091fd92cfbeacc9748347 upstream.
This patch was tested on 3.10.1 kernel.
Same models of Petatel NP10T modems have different device IDs.
Unfortunately they have no additional revision information on a board
which may treat them as different devices. Currently I've seen only
two NP10T devices with various IDs. Possibly Petatel NP10T list will
be appended upon devices with new IDs will appear.
Signed-off-by: Daniil Bolsun <dan.bolsun@gmail.com>
commit 878c69aae986ae97084458c0183a8c0a059865b1 upstream.
Some (very few) early devices like mine, where not exposting a proper CDC
descriptor. This was fixed with an immediate firmware update from the vendor,
and pre-installed on newer devices.
So actual devices can be driven by cdc_acm.c + cdc_ether.c.
commit 4cf76df06ecc852633ed927d91e01c83c33bc331 upstream.
Speaks AT on interfaces 5 (command & PPP) and 3 (secondary), other
interface protocols are unknown.
Signed-off-by: Dan Williams <dcbw@redhat.com>
commit 94190301ffa059c2d127b3a67ec5d161d5c62681 upstream.
Signed-off-by: Bjørn Mork <bjorn@mork.no>
commit 3d1a69e726406ab662ab88fa30a3a05ed404334d upstream.
Prevent the option driver from binding itself to the QMI/WWAN interface, making
it unusable by the proper driver.
Signed-off-by: enrico Mioso <mrkiko.rs@gmail.com>
commit 7a6a731bd00ca90d0e250867c3b9c05b5ff0fa49 upstream.
commit 98cb7e44 ([SCSI] megaraid_sas: Sanity check user
supplied length before passing it to dma_alloc_coherent())
introduced a memory leak. Memory allocated for entries
following zero length SGL entries will not be freed.
Reference: http://bugs.debian.org/688198
Acked-by: Adam Radford <aradford@gmail.com>
non LUN 0 configured expander
commit b65cfedf4560af65305bd7b3b9f26c02c6fb3660 upstream.
With some enclosures when LUN 0 is not created but LUN 1 or LUN X is created
then SCSI scan procedure calls target_alloc, slave_alloc call back functions
for LUN 0 and slave_destory() for same LUN 0.
In these kind of cases within slave_destroy, pointer to scsi_target in
_sas_device structure is set to NULL, following which when slave_alloc for LUN
1 is called then starget would not be set properly for this LUN. So,
scsi_target pointer pointing to NULL value would lead to a crash later in the
discovery procedure.
To solve this issue set the sas_device's scsi_target pointer to scsi_device's
scsi_target if it is NULL earlier in slave_alloc callback function.
Signed-off-by: Sreekanth Reddy <Sreekanth.Reddy@lsi.com>
MPI2_IOCSTATUS_CONFIG_INVALID_PAGE is not returned
commit 14be49ac965ebd3f8561d57e01ddb22f93f9b454 upstream.
Infinite loop can occur if IOCStatus is not equal to
MPI2_IOCSTATUS_CONFIG_INVALID_PAGE value in the while loops in functions
_scsih_search_responding_sas_devices,
_scsih_search_responding_raid_devices and
_scsih_search_responding_expanders
So, Instead of checking for MPI2_IOCSTATUS_CONFIG_INVALID_PAGE value,
in this patch code is modified to check for IOCStatus not equals to
MPI2_IOCSTATUS_SUCCESS to break the while loop.
commit 88d84ac97378c2f1d5fec9af1e8b7d9a662d6b00 upstream.
Fix the following:
BUG: key ffff88043bdd0330 not in .data!
WARNING: at kernel/lockdep.c:2987 lockdep_init_map+0x565/0x5a0()
DEBUG_LOCKS_WARN_ON(1)
Modules linked in: glue_helper sb_edac(+) edac_core snd acpi_cpufreq lrw gf128mul ablk_helper iTCO_wdt evdev i2c_i801 dcdbas button cryptd pcspkr iTCO_vendor_support usb_common lpc_ich mfd_core soundcore mperf processor microcode
CPU: 2 PID: 599 Comm: modprobe Not tainted 3.10.0 #1
Hardware name: Dell Inc. Precision T3600/0PTTT9, BIOS A08 01/24/2013
0000000000000009 ffff880439a1d920 ffffffff8160a9a9 ffff880439a1d958
ffffffff8103d9e0 ffff88043af4a510 ffffffff81a16e11 0000000000000000
ffff88043bdd0330 0000000000000000 ffff880439a1d9b8 ffffffff8103dacc
Call Trace:
dump_stack
warn_slowpath_common
warn_slowpath_fmt
lockdep_init_map
? trace_hardirqs_on_caller
? trace_hardirqs_on
debug_mutex_init
__mutex_init
bus_register
edac_create_sysfs_mci_device
edac_mc_add_mc
sbridge_probe
pci_device_probe
driver_probe_device
__driver_attach
? driver_probe_device
bus_for_each_dev
driver_attach
bus_add_driver
driver_register
__pci_register_driver
? 0xffffffffa0010fff
sbridge_init
do_one_initcall
load_module
? unset_module_init_ro_nx
SyS_init_module
tracesys
---[ end trace d24a70b0d3ddf733 ]---
EDAC MC0: Giving out device to 'sbridge_edac.c' 'Sandy Bridge Socket#0': DEV 0000:3f:0e.0
EDAC sbridge: Driver loaded.
What happens is that bus_register needs a statically allocated lock_key
because the last is handed in to lockdep. However, struct mem_ctl_info
embeds struct bus_type (the whole struct, not a pointer to it) and the
whole thing gets dynamically allocated.
Fix this by using a statically allocated struct bus_type for the MC bus.
Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org>
Cc: Markus Trippelsdorf <markus@trippelsdorf.de>
Signed-off-by: Tony Luck <tony.luck@intel.com>
commit faa5673617656ee58369a3cfe4a312cfcdc59c81 upstream.
The journal replay code starts by finding something that looks like a
valid journal entry, then it does a binary search over the unchecked
region of the journal for the journal entries with the highest sequence
numbers.
Trouble is, the logic was wrong - journal_read_bucket() returns true if
it found journal entries we need, but if the range of journal entries
we're looking for loops around the end of the journal - in that case
journal_read_bucket() could return true when it hadn't found the highest
sequence number we'd seen yet, and in that case the binary search did
the wrong thing. Whoops.
Signed-off-by: Kent Overstreet <kmo@daterainc.com>
commit 29ebf465b9050f241c4433a796a32e6c896a9dcd upstream.
Part of the job of garbage collection is to add up however many sectors
of live data it finds in each bucket, but that doesn't work very well if
it doesn't reset GC_SECTORS_USED() when it starts. Whoops.
This wouldn't have broken anything horribly, but allocation tries to
preferentially reclaim buckets that are mostly empty and that's not
gonna work with an incorrect GC_SECTORS_USED() value.
commit c9502ea4424b31728703d113fc6b30bfead14633 upstream.
If we stopped a bcache device when we were already detaching (or
something like that), bcache_device_unlink() would try to remove a
symlink from sysfs that was already gone because the bcache dev kobject
had already been removed from sysfs.
So keep track of whether we've removed stuff from sysfs.
commit 5caa52afc5abd1396e4af720469abb5843a71eb8 upstream.
Stopping a cache set is supposed to make it stop attached backing
devices, but somewhere along the way that code got lost. Fixing this
mainly has the effect of fixing our reboot notifier.
commit 54d12f2b4fd0f218590d1490b41a18d0e2328a9a upstream.
Whoops - bcache's flush/FUA was mostly correct, but flushes get filtered
out unless we say we support them...
commit 6aa8f1a6ca41c49721d2de4e048d3da8d06411f9 upstream.
In the far-too-complicated closure code - closures can have destructors,
for probably dubious reasons; they get run after the closure is no
longer waiting on anything but before dropping the parent ref, intended
just for freeing whatever memory the closure is embedded in.
Trouble is, when remaining goes to 0 and we've got nothing more to run -
we also have to unlock the closure, setting remaining to -1. If there's
a destructor, that unlock isn't doing anything - nobody could be trying
to lock it if we're about to free it - but if the unlock _is needed...
that check for a destructor was racy. Argh.
commit 27f62b9f294b7e2019c94c385abda43a0af6bb8b upstream.
CC drivers/rapidio/switches/idt_gen2.o
drivers/rapidio/switches/idt_gen2.c: In function ‘idtg2_show_errlog’:
drivers/rapidio/switches/idt_gen2.c:379:30: error: ‘PAGE_SIZE’ undeclared (first use in this function)
drivers/rapidio/switches/idt_gen2.c:379:30: note: each undeclared identifier is reported only once for each function it appears in
Acked-by: Alexandre Bounine <alexandre.bounine@idt.com>
[ Upstream commit ece793fcfc417b3925844be88a6a6dc82ae8f7c6 ]
We try to linearize part of the skb when the number of iov is greater than
MAX_SKB_FRAGS. This is not enough since each single vector may occupy more than
one pages, so zerocopy_sg_fromiovec() may still fail and may break the guest
network.
Solve this problem by calculate the pages needed for iov before trying to do
zerocopy and switch to use copy instead of zerocopy if it needs more than
MAX_SKB_FRAGS.
This is done through introducing a new helper to count the pages for iov, and
call uarg->callback() manually when switching from zerocopy to copy to notify
vhost.
We can do further optimization on top.
This bug were introduced from b92946e2919134ebe2a4083e4302236295ea2a73
(macvtap: zerocopy: validate vectors before building skb).
Cc: Michael S. Tsirkin <mst@redhat.com>
Signed-off-by: Jason Wang <jasowang@redhat.com>
[ Upstream commit 885291761dba2bfe04df4c0f7bb75e4c920ab82e ]
network.
MAX_SKB_FRAGS.
vhost.
The bug were introduced from commit 0690899b4d4501b3505be069b9a687e68ccbe15b
(tun: experimental zero copy tx support)
[ Upstream commit f45708209dc445bac0844f6ce86e315a2ffe8a29 ]
SG mode is not currently supported by netvsc, so remove this flag for now.
Otherwise, it will be unconditionally enabled by commit ec5f0615642
"Kill link between CSUM and SG features"
Previously, the SG feature is disabled because CSUM is not set here.
Signed-off-by: Haiyang Zhang <haiyangz@microsoft.com>
Reviewed-by: K. Y. Srinivasan <kys@microsoft.com>
