This change separates issp device configuration for p2454 and
p2560 boards.
This change also downgrades the JS firmware P2454 from v37 to
v30. Also, it creates a node for p2560 with v37.
Bug 1266521
Bug 1270341
Bug 1276644
Change-Id: Ibb4b59d48146b71a8dec83c2460716299f38a0fc
Signed-off-by: Anshul Jain <anshulj@nvidia.com>
Reviewed-on: http://git-master/r/222599
Reviewed-by: Simone Willett <swillett@nvidia.com>
issp is used to program roth on-board joystick micro controller.
This driver adds:
- issp platform device
- firmware for micro controller P2560_v0_34_not_readprotect_0280.hex
- add issp to tegra11_android_defconfig
Bug 1245803
Change-Id: Idaddbbe8e853744da7f09bb846f47374ebe841b9
Signed-off-by: Richard Zhao <rizhao@nvidia.com>
Reviewed-on: http://git-master/r/209785
This parameter blob and generator program have been moved to the
linux-firmware.git repository.
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
Support for the up to 2x4-port 6Gb/s SAS controllers embedded in the
chipset.
This is a snapshot of the first publicly available version of the driver,
commit 4c1db2d0 in the 'historical' branch.
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/isci.git historical
Signed-off-by: Maciej Trela <maciej.trela@intel.com>
Signed-off-by: Dave Jiang <dave.jiang@intel.com>
Signed-off-by: Edmund Nadolski <edmund.nadolski@intel.com>
To fix bugs when running offloaded FCoE/iSCSI traffic in multiple
Class of Service environments. In some scenarios, traffic could stop
on certain rings and eventually all traffic would stop.
Signed-off-by: Dmitry Kravkov <dmitry@broadcom.com>
Signed-off-by: Michael Chan <mchan@broadcom.com>
Update 5709 mips firmware to 6.2.1a to fix iSCSI performance
regression. There was an unnecessary context read in the fast path
affecting performance.
Update bnx2 to 2.1.6.
Update MIPS firmware to 6.2.1, with improved small packet performance
in RSS mode, and iSCSI CID allocation bug fix on 5708.
Update driver version to 2.0.21.
Includes FCoE releated fixes in FW flows
Signed-off-by: Eilon Greenstein <eilong@broadcom.com>
- Improved flow control and simplified interface
- Use hardware RSS indirection table instead of the slower firmware-
based table
- Lower latency interrupt on 5709
Reviewed-by: Benjamin Li <benli@broadcom.com>
57712 HW supported with same set of features as for 57710/57711
This is the new FW HSI blob and the relevant definitions without logic changes.
It also included code adaptation for new HSI. New features are not enabled.
New FW/HSI includes:
- Support for 57712 HW
- Future support for VF (not used)
- Improvements in FW interrupts scheme
- FW FCoE hooks (stubs for future usage)
It doesn't like pattern and explicit rules to be on the same line,
and it seems to be more picky when matching file (or really directory)
names with different numbers of trailing slashes.
Signed-off-by: Jan Beulich <jbeulich@novell.com>
Acked-by: Sam Ravnborg <sam@ravnborg.org>
Andrew Benton <b3nton@gmail.com>
Cc: <stable@kernel.org>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1443 commits)
phy/marvell: add 88ec048 support
igb: Program MDICNFG register prior to PHY init
e1000e: correct MAC-PHY interconnect register offset for 82579
hso: Add new product ID
can: Add driver for esd CAN-USB/2 device
l2tp: fix export of header file for userspace
can-raw: Fix skb_orphan_try handling
Revert "net: remove zap_completion_queue"
net: cleanup inclusion
phy/marvell: add 88e1121 interface mode support
u32: negative offset fix
net: Fix a typo from "dev" to "ndev"
igb: Use irq_synchronize per vector when using MSI-X
ixgbevf: fix null pointer dereference due to filter being set for VLAN 0
e1000e: Fix irq_synchronize in MSI-X case
e1000e: register pm_qos request on hardware activation
ip_fragment: fix subtracting PPPOE_SES_HLEN from mtu twice
net: Add getsockopt support for TCP thin-streams
cxgb4: update driver version
cxgb4: add new PCI IDs
Manually fix up conflicts in:
- drivers/net/e1000e/netdev.c: due to pm_qos registration
infrastructure changes
- drivers/net/phy/marvell.c: conflict between adding 88ec048 support
and cleaning up the IDs
- drivers/net/wireless/ipw2x00/ipw2100.c: trivial ipw2100_pm_qos_req
conflict (registration change vs marking it static)
Extract the microcode for the QLogic QLE7220 series IB HCA and use the
kernel microcode request facility to load the microcode. This
supports Debian Linux's requirements to separate microcode which
doesn't have open source code available from the device driver.
Signed-off-by: Roland Dreier <rolandd@cisco.com>
Update FW to 7.10
Signed-off-by: Divy Le Ray <divy@chelsio.com>
New firmware fixes a performance regression on small packets.
Switch to the new firmware version (5.2.13).
Signed-off-by: Vladislav Zolotarov <vladz@broadcom.com>
- Increase FTQ depth to 256 to ehnabce performance.
- Fix RV2P context corruption on 5709 when flow control is enabled.
pcnet_cs,serial_cs:
add cis of KTI PE520 pcmcia network card,
and serial card(Sierra Wireless AC860).
Signed-off-by: Ken Kawasaki <ken_kawasaki@spring.nifty.jp>
drivers/net/usb/cdc_ether.c
All CDC ethernet devices of type USB_CLASS_COMM need to use
'&mbm_info'.
pcnet_cs,serial_cs:
add cis of PreMax ethernet pcmcia card,
and some Sierra Wireless serial card(AC555, AC7xx, AC8xx).
use PROD_ID for AC7xx, because MANF_ID of AC7xx and AC8xx are the same.
Value of zero was used to disable the fairness mechanism. Though the code
(driver and FW) allowed changing the value at run time, it did not allow to do
that if the mechanism was disabled to begin with.
Fixed the FW to allow turning on and off the mechanism at run time. Fixed the
code to read the value from the chip at the right sequence.
Without this fix, if the initial value was set to zero, traffic could not run on
the interface.
pcnet_cs,serial_cs:
add cis of National Semicondoctor's lan&modem mulitifunction pcmcia card,
NE2K, tamarack ethernet card,
and some serial card(COMpad2, COMpad4).
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6
* 'drm-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: (133 commits)
drm/vgaarb: add VGA arbitration support to the drm and kms.
drm/radeon: some r420s have a CP race with the DMA engine.
drm/radeon/r600/kms: rv670 is not DCE3
drm/radeon/kms: r420 idle after programming GA_ENHANCE
drm/radeon/kms: more fixes to rv770 suspend/resume path.
drm/radeon/kms: more alignment for rv770.c with r600.c
drm/radeon/kms: rv770 blit init called too late.
drm/radeon/kms: move around new init path code to avoid posting at init
drm/radeon/r600: fix some issues with suspend/resume.
drm/radeon/kms: disable VGA rendering engine before taking over VRAM
drm/radeon/kms: Move radeon_get_clock_info() call out of radeon_clocks_init().
drm/radeon/kms: add initial connector properties
drm/radeon/kms: Use surfaces for scanout / cursor byte swapping on big endian.
drm/radeon/kms: don't fail if we fail to init GPU acceleration
drm/r600/kms: fixup number of loops per blit calculation.
drm/radeon/kms: reprogram format in set base.
drm/radeon: avivo chips have no separate int bit for display
drm/radeon/r600: don't do interrupts
drm: fix _DRM_GEM addmap error message
drm: update crtc x/y when only fb changes
Fixed up trivial conflicts in firmware/Makefile due to network driver
(cxgb3) and drm (mga/r128/radeon) firmware being listed next to each
other.
pcnet_cs,serial_cs:
add cis of Linksys lan&modem mulitifunction pcmcia card
and some modem card(MT5634ZLX, RS-COM-2P).
Loosely based on a patch by
Jaswinder Singh Rajput <jaswinderlinux@gmail.com>.
KMS support by Dave Airlie <airlied@redhat.com>.
For Radeon 100- to 500-series, firmware blobs look like:
struct {
__be32 datah;
__be32 datal;
} cp_ucode[256];
For Radeon 600-series, there are two separate firmware blobs:
__be32 me_ucode[PM4_UCODE_SIZE * 3];
__be32 pfp_ucode[PFP_UCODE_SIZE];
For Radeon 700-series, likewise:
__be32 me_ucode[R700_PM4_UCODE_SIZE];
__be32 pfp_ucode[R700_PFP_UCODE_SIZE];
- Better small packet receive performance.
- Better handling of Flow control on 5709.
- Fixed iSCSI TMP ABORT TASK problem.
- Added iSCSI TCP timestamp option.
Firmware blob looks like this:
__be32 datah
__be32 datal
Image format is IHEX, one record for each pipe in order (record
addresses are ignored).
The new FW improves the packets per second rate. It required a lot of change in
the FW which implies many changes in the driver to support it. It is now also
possible for the driver to use a separate MSI-X vector for Rx and Tx - this also
add some to the complicity of this change.
All things said - after this patch, practically all performance matrixes show
improvement.
Though Vladislav Zolotarov is not signed on this patch, he did most of the job
and deserves credit for that.
use request_firmware() to load the phy's EDC programmation
Update FW to 7.4.
Bump up driver revision.
3c589_cs,3c574_cs,serial_cs:
(1)add cis(firmware) of 3Com lan&modem mulitifunction pcmcia card.
(2)load correct configuration register for 3Com card
>From now on FW will be downloaded from the binary file using request_firmware.
There will be different files for every supported chip. Currently 57710 (e1) and
57711 (e1h).
File names have the following format: bnx2x-<chip version>-<FW version>.fw.
ihex versions of current FW files are submitted in the next patch.
Each binary file has a header in the following format:
struct bnx2x_fw_file_section {
__be32 len;
__be32 offset;
struct bnx2x_fw_file_hdr {
struct bnx2x_fw_file_section init_ops;
struct bnx2x_fw_file_section init_ops_offsets;
struct bnx2x_fw_file_section init_data;
struct bnx2x_fw_file_section tsem_int_table_data;
struct bnx2x_fw_file_section tsem_pram_data;
struct bnx2x_fw_file_section usem_int_table_data;
struct bnx2x_fw_file_section usem_pram_data;
struct bnx2x_fw_file_section csem_int_table_data;
struct bnx2x_fw_file_section csem_pram_data;
struct bnx2x_fw_file_section xsem_int_table_data;
struct bnx2x_fw_file_section xsem_pram_data;
struct bnx2x_fw_file_section fw_version;
Each bnx2x_fw_file_section contains the length and the offset of the appropriate
section in the binary file. Values are stored in the big endian format.
Data types of arrays:
init_data __be32
init_ops_offsets __be16
XXsem_pram_data u8
XXsem_int_table_data u8
init_ops struct raw_op {
u8 op;
__be24 offset;
__be32 data;
fw_version u8
>From now boundaries of a specific initialization stage are stored in
init_ops_offsets array instead of being defined by separate macroes. The index
in init_ops_offsets is calculated by BLOCK_OPS_IDX macro:
#define BLOCK_OPS_IDX(block, stage, end) \
(2*(((block)*STAGE_IDX_MAX) + (stage)) + (end))
Security:
In addition to sanity check of array boundaries bnx2x will check a FW version.
Additional checks might be added in the future.
pcnet_cs: add cis(firmware) of the Allied Telesis LA-PCM
* git://git.infradead.org/~dwmw2/firmware-2.6:
qla1280: Fix off-by-some error in firmware loading.
Add README.AddingFirmware file. Basically telling people not to.
firmware: Remove newly-added slicoss and sxg firmware images
firmware/WHENCE: Add missing origin information for Ambassador atmsar11.fw
ALSA: wavefront - Always use request_firmware()
Remove fdump tool for av7110 firmware
firmware: convert av7110 driver to request_firmware()
Partially revert "V4L/DVB (9533): cx88: Add support for TurboSight TBS8910 DVB-S PCI card"
Revert "fix modules_install via NFS"
Add-add conflicts in firmware/WHENCE fixed manually
These are available elsewhere (for example in the linux-firmware.git
repository); they have no business being added to the kernel source
tree.
We are only putting stuff in the firmware/ directory of the kernel
source when it's extracted from long-standing drivers which used to
include it directly.
We didn't intend to open the floodgates to including megabytes of new
firmware which was previously being distributed separately.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6:
b44: Use kernel DMA addresses for the kernel DMA API
forcedeth: Fix resume from hibernation regression.
xfrm: fix fragmentation on inter family tunnels
ibm_newemac: Fix dangerous struct assumption
gigaset: documentation update
gigaset: in file ops, check for device disconnect before anything else
bas_gigaset: use tasklet_hi_schedule for timing critical tasklets
net/802/fddi.c: add MODULE_LICENSE
smsc911x: remove unused #include <linux/version.h>
axnet_cs: fix phy_id detection for bogus Asix chip.
bnx2: Use request_firmware()
b44: Fix sizes passed to b44_sync_dma_desc_for_{device,cpu}()
socket: use percpu_add() while updating sockets_in_use
virtio_net: Set the mac config only when VIRITO_NET_F_MAC
myri_sbus: use request_firmware
e1000: fix loss of multicast packets
vxge: should include tcp.h
Conflict in firmware/WHENCE (SCSI vs net firmware)
Always use request_firmware() for loading yss225_registers image.
Signed-off-by: Jaswinder Singh <jaswinder@infradead.org>
DVB-S PCI card"
This reverts a hunk of commit 4b29631db33292d416dc395c56122ea865e7635c
which seems to have been an accident, and which re-introduced a
previously fixed bug.
This reverts commit 8b249b6856f16f09b0e5b79ce5f4d435e439b9d6.
This 'fix' is not necessary; we just need to undo the damage caused
accidentally by Igor/Mauro in 4b29631db33292d416dc395c56122ea865e7635c
("V4L/DVB (9533): cx88: Add support for TurboSight TBS8910 DVB-S PCI card")
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (74 commits)
[SCSI] sg: fix q->queue_lock on scsi_error_handler path
[SCSI] replace __inline with inline
[SCSI] a2091: make 2 functions static
[SCSI] a3000: make 2 functions static
[SCSI] ses: #if 0 the unused ses_match_host()
[SCSI] use kmem_cache_zalloc instead of kmem_cache_alloc/memset
[SCSI] sg: fix iovec bugs introduced by the block layer conversion
[SCSI] qlogicpti: use request_firmware
[SCSI] advansys: use request_firmware
[SCSI] qla1280: use request_firmware
[SCSI] libiscsi: fix iscsi pool error path
[SCSI] cxgb3i: call ddp release function directly
[SCSI] cxgb3i: merge cxgb3i_ddp into cxgb3i module
[SCSI] cxgb3i: close all tcp connections upon chip reset
[SCSI] cxgb3i: re-read ddp settings information after chip reset
[SCSI] cxgb3i: re-initialize ddp settings after chip reset
[SCSI] cxgb3i: subscribe to error notification from cxgb3 driver
[SCSI] aacraid driver update
[SCSI] mptsas: remove unneeded check
[SCSI] config: Make need for SCSI_CDROM clearer
Based on original patch by Ben Hutchings <ben@decadent.org.uk> and
Bastian Blank <waldi@debian.org>, with the following main changes:
Separated the mips firmware and rv2p firmware into different files
to make it easier to update them separately.
Added some code to fixup the rv2p code with run-time information
such as PAGE_SIZE.
Update version to 2.0.0.
Firmware blob looks like this...
__be16 lanai4_data_size
unsigned char lanai4_code[]
Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com>
Add support for downloading the firmware using kernel-builtin mechanism.
This will remove the need for the firmware files in the driver source code.
Signed-off-by: Christopher Harrer <charrer@alacritech.com>
Signed-off-by: Mithlesh Thukral <mithlesh@linsyssoft.com>
Adds the firmware to the firmware directory in ihex format so it can be
installed when doing make firmware_install.
Also update the firmware location in the driver code so it can locate
the files in the right place.
This should conclude the move to request_firmware().
Signed-off-by: Lior Dotan <liodot@gmail.com>
Cc: Christopher Harrer <charrer@alacritech.com>
Firmware blob is little endian
Thanks to Stephen Rothwell for fixing typos
Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
