path: root/firmware
2020-01-23Fix built-in early-load Intel microcode alignmentJari Ruusu
commit f5ae2ea6347a308cfe91f53b53682ce635497d0d upstream. Intel Software Developer's Manual, volume 3, chapter 9.11.6 says: "Note that the microcode update must be aligned on a 16-byte boundary and the size of the microcode update must be 1-KByte granular" When early-load Intel microcode is loaded from initramfs, userspace tool 'iucode_tool' has already 16-byte aligned those microcode bits in that initramfs image. Image that was created something like this: iucode_tool --write-earlyfw=FOO.cpio microcode-files... However, when early-load Intel microcode is loaded from built-in firmware BLOB using CONFIG_EXTRA_FIRMWARE= kernel config option, that 16-byte alignment is not guaranteed. Fix this by forcing all built-in firmware BLOBs to 16-byte alignment. [ If we end up having other firmware with much bigger alignment requirements, we might need to introduce some method for the firmware to specify it, this is the minimal "just increase the alignment a bit to account for this one special case" patch - Linus ] Signed-off-by: Jari Ruusu <jari.ruusu@gmail.com> Cc: Borislav Petkov <bp@alien8.de> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Luis Chamberlain <mcgrof@kernel.org> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-07firmware: Update information in linux.git about adding firmwareBen Hutchings
Kyle McMartin joined the linux-firmware maintainers, and we now have an alias <linux-firmware@kernel.org> which reaches all of us. Include that instead of the individual addresses. Add some further recommendations that were already included in the README in linux-firmware.git added by Xose Vazquez Perez <xose.vazquez@gmail.com>. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2015-04-17firmware/ihex2fw.c: restore missing default in switch statementNicolas Iooss
Commit 2473238eac95 ("ihex: add support for CS:IP/EIP records") removes the "default:" statement in the switch block, making the "return usage();" line dead code and ihex2fw silently ignoring unknown options. Restore this statement. This bug was found by building with HOSTCC=clang and adding -Wunreachable-code-return to HOSTCFLAGS. Fixes: 2473238eac95 ("ihex: add support for CS:IP/EIP records") Signed-off-by: Nicolas Iooss <nicolas.iooss_linux@m4x.org> Cc: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-02kbuild: remove obj-n and lib-n handlingMasahiro Yamada
Kconfig never defines CONFIG_* as 'n'. Now obj-n is only used in firmware/Makefile and it can be replaced with obj-. No makefile uses lib-n. Let's rip off obj-n and lib-n. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Peter Foley <pefoley2@pefoley.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2014-07-09firmware: Create directories for external firmwareMichal Marek
Commit 5180d5f4 ("firmware: Simplify directory creation") broke including firmware specified in CONFIG_EXTRA_FIRMWARE: MK_FW firmware/amd-ucode/microcode_amd.bin.gen.S /bin/sh: firmware/amd-ucode/microcode_amd.bin.gen.S: No such file or directory ... firmware/Makefile:185: recipe for target 'firmware/amd-ucode/microcode_amd.bin.gen.S' failed It works with O= builds, because the directory is created by Makefile.build. Create the directory in firmware/Makefile in non-O builds. Reported-and-tested-by: Ronald Uitermark <ronald645@gmail.com> Reported-and-tested-by: Torsten Kaiser <just.for.lkml@googlemail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2014-06-12Merge branch 'kbuild' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kbuild updates from Michal Marek: "Kbuild changes for v3.16-rc1: - cross-compilation fix so that cc-option is testing the right compiler - Fix for make defconfig all - Using relative paths to the object and source directory where possible, plus fixes for the fallout of the change - several cleanups in the Makefiles and scripts The powerpc fix is from today, because it was only discovered recently. The rest has been in linux-next for some time" * 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: powerpc: Avoid circular dependency with zImage.% kbuild: create include/config directory in scripts/kconfig/Makefile kbuild: do not create include/linux directory Makefile: Fix unrecognized cross-compiler command line options kbuild: do not add "selinux" to subdir- twice um: Fix for relative objtree when generating x86 headers kbuild: Use relative path when building in a subdir of the source tree kbuild: Use relative path when building in the source tree kbuild: Use relative path for $(objtree) firmware: Use $(quote) in the Makefile firmware: Simplify directory creation kbuild: trivial - fix comment block indent kbuild: trivial - remove trailing spaces kbuild: support simultaneous "make %config" and "make all" kbuild: move extra gcc checks to scripts/Makefile.extrawarn
2014-05-14firmware: Use $(quote) in the MakefileMichal Marek
The literal " confuses syntax highlighting in vim. Cc: David Woodhouse <dwmw2@infradead.org> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2014-05-14firmware: Simplify directory creationMichal Marek
When building the firmware blobs, use a simple loop to create directories in $(objtree), like in Makefile.build. This simplifies the rules and also makes it possible to set $(objtree) to '.' later. Before this change, a dependency on $(objtree)/<dir> would be satisfied by <dir> in $(srctree). When installing the firmware blobs, call mkdir like in Makefile.modinst. Cc: David Woodhouse <dwmw2@infradead.org> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2014-04-16Documentation/serial: Delete obsolete driver documentationJean Delvare
These serial drivers were removed in kernel v3.1, so we can drop their documentation files and references to their magic numbers and parameters. There are still references to these old drivers in Documentation/devices.txt but I'm afraid they can't be removed. Signed-off-by: Jean Delvare <jdelvare@suse.de> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Jiri Slaby <jslaby@suse.cz> Cc: Rob Landley <rob@landley.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-10USB: emi62: Provide the correct bitstream firmwareBen Hutchings
Commit b8e24bfabb03 ('emi62: use request_firmware()') made emi62/bitstream.HEX a copy of emi26/bitstream.HEX. Re-do the conversion from drivers/usb/misc/emi62_fw_{m,s}.h (these headers contained the same bitstream but different firmware). This produces an identical blob to the known working version in http://people.xiph.org/~xiphmont/emagic/emi-20131209.tgz Reported-by: Monty <xiphmont@xiph.org> Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-04-05firmware,IB/qib: revert firmware file moveMike Marciniszyn
Commit e2eed58b4fbf ("IB/qib: change QLogic to Intel") moved a firmware file potentially breaking the ABI. This patch reverts that aspect of the fix as well as reverting the firmware name as used in qib. Reported-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Mike Marciniszyn <mike.marciniszyn@intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-03-22IB/qib: change QLogic to IntelVinit Agnihotri
These changes modify the qib driver as part of acquiring the InfiniBand assets of QLogic. Reviewed-by: Mike Marciniszyn <mike.marciniszyn@intel.com> Reviewed-by: Dean Luick <dean.luick@intel.com> Signed-off-by: Vinit Agnihotri <vinit.abhay.agnihotri@intel.com> Signed-off-by: Roland Dreier <roland@purestorage.com>
2012-11-21firmware: remove last vestiges of dabusbTim Gardner
dabusb was removed with commit dae86ccbc3 ("[media] dabusb: remove obsolete driver"), so remove the last vestiges of firmware and documentation. Signed-off-by: Tim Gardner <tim.gardner@canonical.com> Cc: Rob Landley <rob@landley.net> Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-02Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking changes from David Miller: 1) GRE now works over ipv6, from Dmitry Kozlov. 2) Make SCTP more network namespace aware, from Eric Biederman. 3) TEAM driver now works with non-ethernet devices, from Jiri Pirko. 4) Make openvswitch network namespace aware, from Pravin B Shelar. 5) IPV6 NAT implementation, from Patrick McHardy. 6) Server side support for TCP Fast Open, from Jerry Chu and others. 7) Packet BPF filter supports MOD and XOR, from Eric Dumazet and Daniel Borkmann. 8) Increate the loopback default MTU to 64K, from Eric Dumazet. 9) Use a per-task rather than per-socket page fragment allocator for outgoing networking traffic. This benefits processes that have very many mostly idle sockets, which is quite common. From Eric Dumazet. 10) Use up to 32K for page fragment allocations, with fallbacks to smaller sizes when higher order page allocations fail. Benefits are a) less segments for driver to process b) less calls to page allocator c) less waste of space. From Eric Dumazet. 11) Allow GRO to be used on GRE tunnels, from Eric Dumazet. 12) VXLAN device driver, one way to handle VLAN issues such as the limitation of 4096 VLAN IDs yet still have some level of isolation. From Stephen Hemminger. 13) As usual there is a large boatload of driver changes, with the scale perhaps tilted towards the wireless side this time around. Fix up various fairly trivial conflicts, mostly caused by the user namespace changes. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1012 commits) hyperv: Add buffer for extended info after the RNDIS response message. hyperv: Report actual status in receive completion packet hyperv: Remove extra allocated space for recv_pkt_list elements hyperv: Fix page buffer handling in rndis_filter_send_request() hyperv: Fix the missing return value in rndis_filter_set_packet_filter() hyperv: Fix the max_xfer_size in RNDIS initialization vxlan: put UDP socket in correct namespace vxlan: Depend on CONFIG_INET sfc: Fix the reported priorities of different filter types sfc: Remove EFX_FILTER_FLAG_RX_OVERRIDE_IP sfc: Fix loopback self-test with separate_tx_channels=1 sfc: Fix MCDI structure field lookup sfc: Add parentheses around use of bitfield macro arguments sfc: Fix null function pointer in efx_sriov_channel_type vxlan: virtual extensible lan igmp: export symbol ip_mc_leave_group netlink: add attributes to fdb interface tg3: unconditionally select HWMON support when tg3 is enabled. Revert "net: ti cpsw ethernet: allow reading phy interface mode from DT" gre: fix sparse warning ...
2012-08-16firmware: remove computone driver firmware and documentationTim Gardner
The only Computone support left in the kernel is in drivers/tty/serial/8250/8250_pci.c. CONFIG_COMPUTONE is no longer a valid option. Therefore, remove firmware, documentation, and the last vestiges of this driver. Cc: Rob Landley <rob@landley.net> Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Ben Hutchings <ben@decadent.org.uk> Cc: James Bottomley <JBottomley@Parallels.com> Cc: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Tim Gardner <tim.gardner@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-02firmware: Remove obsolete Chelsio cxgb3 firmwareTim Gardner
The current firmware version used by the device driver is 7.12.0 Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Ben Hutchings <ben@decadent.org.uk> Cc: James Bottomley <JBottomley@Parallels.com> Cc: Dan Williams <dan.j.williams@intel.com> Cc: Divy Le Ray <divy@chelsio.com> Cc: netdev@vger.kernel.org Signed-off-by: Tim Gardner <tim.gardner@canonical.com>
2012-05-15tokenring: delete all remaining driver supportPaul Gortmaker
This represents the mass deletion of the of the tokenring support. It gets rid of: - the net/tr.c which the drivers depended on - the drivers/net component - the Kbuild infrastructure around it - any tokenring related CONFIG_ settings in any defconfigs - the tokenring headers in the include/linux dir - the firmware associated with the tokenring drivers. - any associated token ring documentation. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-01-16[SCSI] isci, firmware: Remove isci fallback parameter blob and generatorBen Hutchings
This parameter blob and generator program have been moved to the linux-firmware.git repository. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-12-20firmware: Refer to the co-maintained linux-firmware.git repositoryBen Hutchings
David and I are sharing maintenance of this repository. Patches should be sent to both of us. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-03isci: Added support for C0 to SCU DriverAdam Gruchala
C0 silicon updates the pci revision id and requires new AFE parameters for phy signal integrity. Support for previous silicon revisions is deprecated (it's also broken for the theoretical case of multiple controllers at different silicon revisions, all the more reason to get it removed as soon as possible) Signed-off-by: Adam Gruchala <adam.gruchala@intel.com> [fixed up deprecated silicon support] Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2011-07-03isci: fix oem parameter header definitionDan Williams
The element_length is 2 bytes. Reported-by: Yinghai Lu <yinghai.lu@oracle.com> Acked-by: Dave Jiang <dave.jiang@intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2011-07-03isci: fix apc mode definitionDan Williams
The original apc mode definition is the correct one, the fix from commit 4711ba10 "isci: fix oem parameter initialization and mode detection" was based on a typo from a specification update. Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2011-07-03isci: fix oem parameter initialization and mode detectionDan Williams
1/ Since commit 858d4aa7 "isci: Move firmware loading to per PCI device" we have been silently falling back to built-in defaults for the parameter settings by skipping the call to scic_oem_parameters_set(). 2/ The afe parameters from the firmware were not being honored 3/ The latest oem parameter definition flips the mode_type values which are now 0: for APC 1: for MPC. For APC we need to make sure all the phys default to the same address otherwise strict_wide_ports will cause duplicate domains. 4/ Fix up the driver announcement to indicate the source of the parameters. 5/ Fix up the sas addresses to be unique per controller (in the fallback case) Signed-off-by: Dave Jiang <dave.jiang@intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2011-07-03isci: add support for 2 more oem parmetersHenryk Dembkowski
1/ add OEM paramater support for mode_type (MPC vs APC) 2/ add OEM parameter support for max_number_concurrent_device_spin_up 3/ cleanup scic_sds_controller_start_next_phy todo: hook up the amp control afe parameters into the afe init code Signed-off-by: Henryk Dembkowski <henryk.dembkowski@intel.com> Signed-off-by: Jacek Danecki <Jacek.Danecki@intel.com> [cleaned up scic_sds_controller_start_next_phy] Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2011-07-03isci: Add support for probing OROM for OEM paramsDan Williams
We need to scan the OROM for signature and grab the OEM parameters. We also need to do the same for EFI. If all fails then we resort to user binary blob, and if that fails then we go to the defaults. Share the format with the create_fw utility so that all possible sources of the parameters are in-sync. Signed-off-by: Dave Jiang <dave.jiang@intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2011-07-02isci: Intel(R) C600 Series Chipset Storage Control Unit DriverDan Williams
Support for the up to 2x4-port 6Gb/s SAS controllers embedded in the chipset. This is a snapshot of the first publicly available version of the driver, commit 4c1db2d0 in the 'historical' branch. git://git.kernel.org/pub/scm/linux/kernel/git/djbw/isci.git historical Signed-off-by: Maciej Trela <maciej.trela@intel.com> Signed-off-by: Dave Jiang <dave.jiang@intel.com> Signed-off-by: Edmund Nadolski <edmund.nadolski@intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2011-03-31bnx2x: Update firmware to 6.2.9Dmitry Kravkov
To fix bugs when running offloaded FCoE/iSCSI traffic in multiple Class of Service environments. In some scenarios, traffic could stop on certain rings and eventually all traffic would stop. Signed-off-by: Dmitry Kravkov <dmitry@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-14bnx2: Update firmware and versionMichael Chan
Update 5709 mips firmware to 6.2.1a to fix iSCSI performance regression. There was an unnecessary context read in the fast path affecting performance. Update bnx2 to 2.1.6. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-13ihex: fix unused return value compiler warningChris Ruffin
Fix unusued return value compiler warnings due to unchecked write() calls. [akpm@linux-foundation.org: correctly handle short writes] Signed-off-by: Chris Ruffin <cmruffin@gmail.com> Cc: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-12-31bnx2: Update firmware and versionMichael Chan
Update MIPS firmware to 6.2.1, with improved small packet performance in RSS mode, and iSCSI CID allocation bug fix on 5708. Update driver version to 2.0.21. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-16bnx2x: remove old FW filesVladislav Zolotarov
Signed-off-by: Dmitry Kravkov <dmitry@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-16bnx2x: replace FW to 6.2.5Vladislav Zolotarov
Includes FCoE releated fixes in FW flows Signed-off-by: Dmitry Kravkov <dmitry@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-16bnx2x: add FW 6.2.5 filesVladislav Zolotarov
2010-10-26ihex: add support for CS:IP/EIP recordsMark Brown
ihex firmwares can include a jump address for starting execution. Add a -j option which will cause this to be written into the generated file as a record with address zero and data consisting of the address to jump to, allowing drivers to make use of this information. This format is chosen because it most closely follows the original ihex format, though it may make more sense to write a record with length zero and the address stored as the address. The records are not omitted by default since our ihex format does not include record type information and so including additional records may lead to confusion. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-24Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) Update broken web addresses in arch directory. Update broken web addresses in the kernel. Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget Revert "Fix typo: configuation => configuration" partially ida: document IDA_BITMAP_LONGS calculation ext2: fix a typo on comment in ext2/inode.c drivers/scsi: Remove unnecessary casts of private_data drivers/s390: Remove unnecessary casts of private_data net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data drivers/infiniband: Remove unnecessary casts of private_data drivers/gpu/drm: Remove unnecessary casts of private_data kernel/pm_qos_params.c: Remove unnecessary casts of private_data fs/ecryptfs: Remove unnecessary casts of private_data fs/seq_file.c: Remove unnecessary casts of private_data arm: uengine.c: remove C99 comments arm: scoop.c: remove C99 comments Fix typo configue => configure in comments Fix typo: configuation => configuration Fix typo interrest[ing|ed] => interest[ing|ed] Fix various typos of valid in comments ... Fix up trivial conflicts in: drivers/char/ipmi/ipmi_si_intf.c drivers/usb/gadget/rndis.c net/irda/irnet/irnet_ppp.c
2010-10-18Update broken web addresses in the kernel.Justin P. Mattock
The patch below updates broken web addresses in the kernel Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Cc: Maciej W. Rozycki <macro@linux-mips.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Finn Thain <fthain@telegraphics.com.au> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Matt Turner <mattst88@gmail.com> Cc: Dimitry Torokhov <dmitry.torokhov@gmail.com> Cc: Mike Frysinger <vapier.adi@gmail.com> Acked-by: Ben Pfaff <blp@cs.stanford.edu> Acked-by: Hans J. Koch <hjk@linutronix.de> Reviewed-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-10-11bnx2: Update firmware to 6.0.x.Michael Chan
- Improved flow control and simplified interface - Use hardware RSS indirection table instead of the slower firmware- based table - Lower latency interrupt on 5709 Signed-off-by: Michael Chan <mchan@broadcom.com> Reviewed-by: Benjamin Li <benli@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-06bnx2x: Add 57712 supportDmitry Kravkov
57712 HW supported with same set of features as for 57710/57711 Signed-off-by: Dmitry Kravkov <dmitry@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-06bnx2x: remove old FW filesDmitry Kravkov
2010-10-06bnx2x, cnic, bnx2i: use new FW/HSIDmitry Kravkov
This is the new FW HSI blob and the relevant definitions without logic changes. It also included code adaptation for new HSI. New features are not enabled. New FW/HSI includes: - Support for 57712 HW - Future support for VF (not used) - Improvements in FW interrupts scheme - FW FCoE hooks (stubs for future usage) Signed-off-by: Dmitry Kravkov <dmitry@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-06bnx2x: add 6.0.34 fw filesDmitry Kravkov
New firmware files for all bnx2x devices Signed-off-by: Dmitry Kravkov <dmitry@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-06bnx2x: create folder for bnx2x firmware filesDmitry Kravkov
2010-08-20Merge commit 'v2.6.36-rc1' into kbuild/rc-fixesMichal Marek
2010-08-17fixes for using make 3.82Jan Beulich
It doesn't like pattern and explicit rules to be on the same line, and it seems to be more picky when matching file (or really directory) names with different numbers of trailing slashes. Signed-off-by: Jan Beulich <jbeulich@novell.com> Acked-by: Sam Ravnborg <sam@ravnborg.org> Andrew Benton <b3nton@gmail.com> Cc: <stable@kernel.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-08-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1443 commits) phy/marvell: add 88ec048 support igb: Program MDICNFG register prior to PHY init e1000e: correct MAC-PHY interconnect register offset for 82579 hso: Add new product ID can: Add driver for esd CAN-USB/2 device l2tp: fix export of header file for userspace can-raw: Fix skb_orphan_try handling Revert "net: remove zap_completion_queue" net: cleanup inclusion phy/marvell: add 88e1121 interface mode support u32: negative offset fix net: Fix a typo from "dev" to "ndev" igb: Use irq_synchronize per vector when using MSI-X ixgbevf: fix null pointer dereference due to filter being set for VLAN 0 e1000e: Fix irq_synchronize in MSI-X case e1000e: register pm_qos request on hardware activation ip_fragment: fix subtracting PPPOE_SES_HLEN from mtu twice net: Add getsockopt support for TCP thin-streams cxgb4: update driver version cxgb4: add new PCI IDs ... Manually fix up conflicts in: - drivers/net/e1000e/netdev.c: due to pm_qos registration infrastructure changes - drivers/net/phy/marvell.c: conflict between adding 88ec048 support and cleaning up the IDs - drivers/net/wireless/ipw2x00/ipw2100.c: trivial ipw2100_pm_qos_req conflict (registration change vs marking it static)
2010-07-08IB/qib: Use request_firmware() to load SD7220 firmwareBen Hutchings
Extract the microcode for the QLogic QLE7220 series IB HCA and use the kernel microcode request facility to load the microcode. This supports Debian Linux's requirements to separate microcode which doesn't have open source code available from the device driver. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2010-06-25cxgb3: update FW to 7.10Divy Le Ray
Update FW to 7.10 Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-17bnx2: Update 5709 MIPS firmware and version to 2.0.15.Michael Chan
New firmware fixes a performance regression on small packets. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-03bnx2x: Removed FW 5.2.7Vladislav Zolotarov
Removed FW 5.2.7. Signed-off-by: Vladislav Zolotarov <vladz@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-17bnx2x: Use firmware 5.2.13Vladislav Zolotarov
Switch to the new firmware version (5.2.13). Signed-off-by: Vladislav Zolotarov <vladz@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
