There is a bug in ssi sdma script cause dual fifo swap.Correct
it in sdma script.
Signed-off-by: Robin Gong <yibin.gong@nxp.com>
Fix two below bugs in script:
-- check error flag in FIFO data, thus dma will stop once the error happen
when real HW error triggered by switch boundrate, overun,etc. Actrually,
no need to check in script since UART driver will handle this.
-- clear other status bit in USR1.
Since ERR008517(TKT238285) fixed on i.mx6ul, we need change script to
compatible all i.mx6 chips.
Signed-off-by: Robin Gong <b38343@freescale.com>
(cherry picked from commit 6970e2b497621e3f2fc4005d06bb8ca76d234074)
add sdma firmware for i.mx6 and i.mx7d
While https was always supported on linuxtv.org, only in
Dec 3 2015 the website is using valid certificates.
As we're planning to drop pure http support on some
future, change the http://linuxtv.org references at firmware/WHENCE
file to point to https://linuxtv.org instead.
Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
Kyle McMartin joined the linux-firmware maintainers, and we now
have an alias <linux-firmware@kernel.org> which reaches all of us.
Include that instead of the individual addresses.
Add some further recommendations that were already included in the
README in linux-firmware.git added by Xose Vazquez Perez
<xose.vazquez@gmail.com>.
Signed-off-by: Jonathan Corbet <corbet@lwn.net>
Commit 2473238eac95 ("ihex: add support for CS:IP/EIP records") removes
the "default:" statement in the switch block, making the "return
usage();" line dead code and ihex2fw silently ignoring unknown options.
Restore this statement.
This bug was found by building with HOSTCC=clang and adding
-Wunreachable-code-return to HOSTCFLAGS.
Fixes: 2473238eac95 ("ihex: add support for CS:IP/EIP records")
Signed-off-by: Nicolas Iooss <nicolas.iooss_linux@m4x.org>
Cc: Mark Brown <broonie@opensource.wolfsonmicro.com>
Kconfig never defines CONFIG_* as 'n'.
Now obj-n is only used in firmware/Makefile and it can be
replaced with obj-. No makefile uses lib-n.
Let's rip off obj-n and lib-n.
Acked-by: Peter Foley <pefoley2@pefoley.com>
Commit 5180d5f4 ("firmware: Simplify directory creation") broke
including firmware specified in CONFIG_EXTRA_FIRMWARE:
MK_FW firmware/amd-ucode/microcode_amd.bin.gen.S
/bin/sh: firmware/amd-ucode/microcode_amd.bin.gen.S: No such file or directory
firmware/Makefile:185: recipe for target
'firmware/amd-ucode/microcode_amd.bin.gen.S' failed
It works with O= builds, because the directory is created by
Makefile.build. Create the directory in firmware/Makefile in non-O
builds.
Reported-and-tested-by: Ronald Uitermark <ronald645@gmail.com>
Reported-and-tested-by: Torsten Kaiser <just.for.lkml@googlemail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild
Pull kbuild updates from Michal Marek:
"Kbuild changes for v3.16-rc1:
- cross-compilation fix so that cc-option is testing the right
compiler
- Fix for make defconfig all
- Using relative paths to the object and source directory where
possible, plus fixes for the fallout of the change
- several cleanups in the Makefiles and scripts
The powerpc fix is from today, because it was only discovered
recently. The rest has been in linux-next for some time"
* 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild:
powerpc: Avoid circular dependency with zImage.%
kbuild: create include/config directory in scripts/kconfig/Makefile
kbuild: do not create include/linux directory
Makefile: Fix unrecognized cross-compiler command line options
kbuild: do not add "selinux" to subdir- twice
um: Fix for relative objtree when generating x86 headers
kbuild: Use relative path when building in a subdir of the source tree
kbuild: Use relative path when building in the source tree
kbuild: Use relative path for $(objtree)
firmware: Use $(quote) in the Makefile
kbuild: trivial - fix comment block indent
kbuild: trivial - remove trailing spaces
kbuild: support simultaneous "make %config" and "make all"
kbuild: move extra gcc checks to scripts/Makefile.extrawarn
The literal " confuses syntax highlighting in vim.
Acked-by: Sam Ravnborg <sam@ravnborg.org>
When building the firmware blobs, use a simple loop to create
directories in $(objtree), like in Makefile.build. This simplifies the
rules and also makes it possible to set $(objtree) to '.' later. Before
this change, a dependency on $(objtree)/<dir> would be satisfied by
<dir> in $(srctree).
When installing the firmware blobs, call mkdir like in Makefile.modinst.
These serial drivers were removed in kernel v3.1, so we can drop their
documentation files and references to their magic numbers and
parameters.
There are still references to these old drivers in
Documentation/devices.txt but I'm afraid they can't be removed.
Signed-off-by: Jean Delvare <jdelvare@suse.de>
Cc: Jiri Slaby <jslaby@suse.cz>
Cc: Rob Landley <rob@landley.net>
Commit b8e24bfabb03 ('emi62: use request_firmware()') made
emi62/bitstream.HEX a copy of emi26/bitstream.HEX. Re-do the
conversion from drivers/usb/misc/emi62_fw_{m,s}.h (these headers
contained the same bitstream but different firmware).
This produces an identical blob to the known working version in
http://people.xiph.org/~xiphmont/emagic/emi-20131209.tgz
Reported-by: Monty <xiphmont@xiph.org>
Commit e2eed58b4fbf ("IB/qib: change QLogic to Intel") moved a firmware
file potentially breaking the ABI.
This patch reverts that aspect of the fix as well as reverting the
firmware name as used in qib.
Reported-by: David Woodhouse <dwmw2@infradead.org>
Signed-off-by: Mike Marciniszyn <mike.marciniszyn@intel.com>
These changes modify the qib driver as part of acquiring
the InfiniBand assets of QLogic.
Reviewed-by: Mike Marciniszyn <mike.marciniszyn@intel.com>
Reviewed-by: Dean Luick <dean.luick@intel.com>
Signed-off-by: Vinit Agnihotri <vinit.abhay.agnihotri@intel.com>
Signed-off-by: Roland Dreier <roland@purestorage.com>
dabusb was removed with commit dae86ccbc3 ("[media] dabusb: remove
obsolete driver"), so remove the last vestiges of firmware and
documentation.
Signed-off-by: Tim Gardner <tim.gardner@canonical.com>
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
Cc: Ben Hutchings <ben@decadent.org.uk>
Pull networking changes from David Miller:
1) GRE now works over ipv6, from Dmitry Kozlov.
2) Make SCTP more network namespace aware, from Eric Biederman.
3) TEAM driver now works with non-ethernet devices, from Jiri Pirko.
4) Make openvswitch network namespace aware, from Pravin B Shelar.
5) IPV6 NAT implementation, from Patrick McHardy.
6) Server side support for TCP Fast Open, from Jerry Chu and others.
7) Packet BPF filter supports MOD and XOR, from Eric Dumazet and Daniel
Borkmann.
8) Increate the loopback default MTU to 64K, from Eric Dumazet.
9) Use a per-task rather than per-socket page fragment allocator for
outgoing networking traffic. This benefits processes that have very
many mostly idle sockets, which is quite common.
From Eric Dumazet.
10) Use up to 32K for page fragment allocations, with fallbacks to
smaller sizes when higher order page allocations fail. Benefits are
a) less segments for driver to process b) less calls to page
allocator c) less waste of space.
From Eric Dumazet.
11) Allow GRO to be used on GRE tunnels, from Eric Dumazet.
12) VXLAN device driver, one way to handle VLAN issues such as the
limitation of 4096 VLAN IDs yet still have some level of isolation.
From Stephen Hemminger.
13) As usual there is a large boatload of driver changes, with the scale
perhaps tilted towards the wireless side this time around.
Fix up various fairly trivial conflicts, mostly caused by the user
namespace changes.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1012 commits)
hyperv: Add buffer for extended info after the RNDIS response message.
hyperv: Report actual status in receive completion packet
hyperv: Remove extra allocated space for recv_pkt_list elements
hyperv: Fix page buffer handling in rndis_filter_send_request()
hyperv: Fix the missing return value in rndis_filter_set_packet_filter()
hyperv: Fix the max_xfer_size in RNDIS initialization
vxlan: put UDP socket in correct namespace
vxlan: Depend on CONFIG_INET
sfc: Fix the reported priorities of different filter types
sfc: Remove EFX_FILTER_FLAG_RX_OVERRIDE_IP
sfc: Fix loopback self-test with separate_tx_channels=1
sfc: Fix MCDI structure field lookup
sfc: Add parentheses around use of bitfield macro arguments
sfc: Fix null function pointer in efx_sriov_channel_type
vxlan: virtual extensible lan
igmp: export symbol ip_mc_leave_group
netlink: add attributes to fdb interface
tg3: unconditionally select HWMON support when tg3 is enabled.
Revert "net: ti cpsw ethernet: allow reading phy interface mode from DT"
gre: fix sparse warning
The only Computone support left in the kernel is in
drivers/tty/serial/8250/8250_pci.c. CONFIG_COMPUTONE is no longer a valid
option. Therefore, remove firmware, documentation, and the last vestiges
of this driver.
Cc: James Bottomley <JBottomley@Parallels.com>
Cc: Dan Williams <dan.j.williams@intel.com>
The current firmware version used by the device driver
is 7.12.0
Cc: Divy Le Ray <divy@chelsio.com>
Cc: netdev@vger.kernel.org
This represents the mass deletion of the of the tokenring support.
It gets rid of:
- the net/tr.c which the drivers depended on
- the drivers/net component
- the Kbuild infrastructure around it
- any tokenring related CONFIG_ settings in any defconfigs
- the tokenring headers in the include/linux dir
- the firmware associated with the tokenring drivers.
- any associated token ring documentation.
This parameter blob and generator program have been moved to the
linux-firmware.git repository.
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
David and I are sharing maintenance of this repository. Patches
should be sent to both of us.
C0 silicon updates the pci revision id and requires new AFE parameters
for phy signal integrity. Support for previous silicon revisions is
deprecated (it's also broken for the theoretical case of multiple
controllers at different silicon revisions, all the more reason to get
it removed as soon as possible)
Signed-off-by: Adam Gruchala <adam.gruchala@intel.com>
[fixed up deprecated silicon support]
The element_length is 2 bytes.
Reported-by: Yinghai Lu <yinghai.lu@oracle.com>
Acked-by: Dave Jiang <dave.jiang@intel.com>
The original apc mode definition is the correct one, the fix from commit
4711ba10 "isci: fix oem parameter initialization and mode detection" was based
on a typo from a specification update.
1/ Since commit 858d4aa7 "isci: Move firmware loading to per PCI device" we have
been silently falling back to built-in defaults for the parameter settings by
skipping the call to scic_oem_parameters_set().
2/ The afe parameters from the firmware were not being honored
3/ The latest oem parameter definition flips the mode_type values which are
now 0: for APC 1: for MPC. For APC we need to make sure all the phys
default to the same address otherwise strict_wide_ports will cause duplicate
domains.
4/ Fix up the driver announcement to indicate the source of the
parameters.
5/ Fix up the sas addresses to be unique per controller (in the fallback case)
Signed-off-by: Dave Jiang <dave.jiang@intel.com>
1/ add OEM paramater support for mode_type (MPC vs APC)
2/ add OEM parameter support for max_number_concurrent_device_spin_up
3/ cleanup scic_sds_controller_start_next_phy
todo: hook up the amp control afe parameters into the afe init code
Signed-off-by: Henryk Dembkowski <henryk.dembkowski@intel.com>
Signed-off-by: Jacek Danecki <Jacek.Danecki@intel.com>
[cleaned up scic_sds_controller_start_next_phy]
We need to scan the OROM for signature and grab the OEM parameters. We
also need to do the same for EFI. If all fails then we resort to user
binary blob, and if that fails then we go to the defaults.
Share the format with the create_fw utility so that all possible sources
of the parameters are in-sync.
Support for the up to 2x4-port 6Gb/s SAS controllers embedded in the
chipset.
This is a snapshot of the first publicly available version of the driver,
commit 4c1db2d0 in the 'historical' branch.
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/isci.git historical
Signed-off-by: Maciej Trela <maciej.trela@intel.com>
Signed-off-by: Edmund Nadolski <edmund.nadolski@intel.com>
To fix bugs when running offloaded FCoE/iSCSI traffic in multiple
Class of Service environments. In some scenarios, traffic could stop
on certain rings and eventually all traffic would stop.
Signed-off-by: Dmitry Kravkov <dmitry@broadcom.com>
Signed-off-by: Michael Chan <mchan@broadcom.com>
Update 5709 mips firmware to 6.2.1a to fix iSCSI performance
regression. There was an unnecessary context read in the fast path
affecting performance.
Update bnx2 to 2.1.6.
Fix unusued return value compiler warnings due to unchecked write() calls.
[akpm@linux-foundation.org: correctly handle short writes]
Signed-off-by: Chris Ruffin <cmruffin@gmail.com>
Update MIPS firmware to 6.2.1, with improved small packet performance
in RSS mode, and iSCSI CID allocation bug fix on 5708.
Update driver version to 2.0.21.
Signed-off-by: Eilon Greenstein <eilong@broadcom.com>
Includes FCoE releated fixes in FW flows
ihex firmwares can include a jump address for starting execution. Add a
-j option which will cause this to be written into the generated file as a
record with address zero and data consisting of the address to jump to,
allowing drivers to make use of this information.
This format is chosen because it most closely follows the original ihex
format, though it may make more sense to write a record with length zero
and the address stored as the address. The records are not omitted by
default since our ihex format does not include record type information and
so including additional records may lead to confusion.
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
Update broken web addresses in arch directory.
Update broken web addresses in the kernel.
Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget
Revert "Fix typo: configuation => configuration" partially
ida: document IDA_BITMAP_LONGS calculation
ext2: fix a typo on comment in ext2/inode.c
drivers/scsi: Remove unnecessary casts of private_data
drivers/s390: Remove unnecessary casts of private_data
net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data
drivers/infiniband: Remove unnecessary casts of private_data
drivers/gpu/drm: Remove unnecessary casts of private_data
kernel/pm_qos_params.c: Remove unnecessary casts of private_data
fs/ecryptfs: Remove unnecessary casts of private_data
fs/seq_file.c: Remove unnecessary casts of private_data
arm: uengine.c: remove C99 comments
arm: scoop.c: remove C99 comments
Fix typo configue => configure in comments
Fix typo interrest[ing|ed] => interest[ing|ed]
Fix various typos of valid in comments
Fix up trivial conflicts in:
drivers/char/ipmi/ipmi_si_intf.c
drivers/usb/gadget/rndis.c
net/irda/irnet/irnet_ppp.c
The patch below updates broken web addresses in the kernel
Cc: Maciej W. Rozycki <macro@linux-mips.org>
Cc: Finn Thain <fthain@telegraphics.com.au>
Cc: Randy Dunlap <rdunlap@xenotime.net>
Cc: Matt Turner <mattst88@gmail.com>
Cc: Dimitry Torokhov <dmitry.torokhov@gmail.com>
Cc: Mike Frysinger <vapier.adi@gmail.com>
Acked-by: Ben Pfaff <blp@cs.stanford.edu>
Acked-by: Hans J. Koch <hjk@linutronix.de>
Reviewed-by: Finn Thain <fthain@telegraphics.com.au>
- Improved flow control and simplified interface
- Use hardware RSS indirection table instead of the slower firmware-
based table
- Lower latency interrupt on 5709
Reviewed-by: Benjamin Li <benli@broadcom.com>
57712 HW supported with same set of features as for 57710/57711
This is the new FW HSI blob and the relevant definitions without logic changes.
It also included code adaptation for new HSI. New features are not enabled.
New FW/HSI includes:
- Support for 57712 HW
- Future support for VF (not used)
- Improvements in FW interrupts scheme
- FW FCoE hooks (stubs for future usage)
New firmware files for all bnx2x devices
It doesn't like pattern and explicit rules to be on the same line,
and it seems to be more picky when matching file (or really directory)
names with different numbers of trailing slashes.
Signed-off-by: Jan Beulich <jbeulich@novell.com>
Andrew Benton <b3nton@gmail.com>
Cc: <stable@kernel.org>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1443 commits)
phy/marvell: add 88ec048 support
igb: Program MDICNFG register prior to PHY init
e1000e: correct MAC-PHY interconnect register offset for 82579
hso: Add new product ID
can: Add driver for esd CAN-USB/2 device
l2tp: fix export of header file for userspace
can-raw: Fix skb_orphan_try handling
Revert "net: remove zap_completion_queue"
net: cleanup inclusion
phy/marvell: add 88e1121 interface mode support
u32: negative offset fix
net: Fix a typo from "dev" to "ndev"
igb: Use irq_synchronize per vector when using MSI-X
ixgbevf: fix null pointer dereference due to filter being set for VLAN 0
e1000e: Fix irq_synchronize in MSI-X case
e1000e: register pm_qos request on hardware activation
ip_fragment: fix subtracting PPPOE_SES_HLEN from mtu twice
net: Add getsockopt support for TCP thin-streams
cxgb4: update driver version
cxgb4: add new PCI IDs
Manually fix up conflicts in:
- drivers/net/e1000e/netdev.c: due to pm_qos registration
infrastructure changes
- drivers/net/phy/marvell.c: conflict between adding 88ec048 support
and cleaning up the IDs
- drivers/net/wireless/ipw2x00/ipw2100.c: trivial ipw2100_pm_qos_req
conflict (registration change vs marking it static)
Extract the microcode for the QLogic QLE7220 series IB HCA and use the
kernel microcode request facility to load the microcode. This
supports Debian Linux's requirements to separate microcode which
doesn't have open source code available from the device driver.
Signed-off-by: Roland Dreier <rolandd@cisco.com>
