Value of zero was used to disable the fairness mechanism. Though the code
(driver and FW) allowed changing the value at run time, it did not allow to do
that if the mechanism was disabled to begin with.
Fixed the FW to allow turning on and off the mechanism at run time. Fixed the
code to read the value from the chip at the right sequence.
Without this fix, if the initial value was set to zero, traffic could not run on
the interface.
Signed-off-by: Eilon Greenstein <eilong@broadcom.com>
pcnet_cs,serial_cs:
add cis of National Semicondoctor's lan&modem mulitifunction pcmcia card,
NE2K, tamarack ethernet card,
and some serial card(COMpad2, COMpad4).
Signed-off-by: Ken Kawasaki <ken_kawasaki@spring.nifty.jp>
Fix up -Wmissing-prototypes in compileable userspace code, mainly under
Documentation/.
Signed-off-by: Ladinu Chandrasinghe <ladinu.pub@gmail.com>
Signed-off-by: Trevor Keith <tsrk@tsrk.net>
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6
* 'drm-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: (133 commits)
drm/vgaarb: add VGA arbitration support to the drm and kms.
drm/radeon: some r420s have a CP race with the DMA engine.
drm/radeon/r600/kms: rv670 is not DCE3
drm/radeon/kms: r420 idle after programming GA_ENHANCE
drm/radeon/kms: more fixes to rv770 suspend/resume path.
drm/radeon/kms: more alignment for rv770.c with r600.c
drm/radeon/kms: rv770 blit init called too late.
drm/radeon/kms: move around new init path code to avoid posting at init
drm/radeon/r600: fix some issues with suspend/resume.
drm/radeon/kms: disable VGA rendering engine before taking over VRAM
drm/radeon/kms: Move radeon_get_clock_info() call out of radeon_clocks_init().
drm/radeon/kms: add initial connector properties
drm/radeon/kms: Use surfaces for scanout / cursor byte swapping on big endian.
drm/radeon/kms: don't fail if we fail to init GPU acceleration
drm/r600/kms: fixup number of loops per blit calculation.
drm/radeon/kms: reprogram format in set base.
drm/radeon: avivo chips have no separate int bit for display
drm/radeon/r600: don't do interrupts
drm: fix _DRM_GEM addmap error message
drm: update crtc x/y when only fb changes
Fixed up trivial conflicts in firmware/Makefile due to network driver
(cxgb3) and drm (mga/r128/radeon) firmware being listed next to each
other.
pcnet_cs,serial_cs:
add cis of Linksys lan&modem mulitifunction pcmcia card
and some modem card(MT5634ZLX, RS-COM-2P).
Loosely based on a patch by
Jaswinder Singh Rajput <jaswinderlinux@gmail.com>.
KMS support by Dave Airlie <airlied@redhat.com>.
For Radeon 100- to 500-series, firmware blobs look like:
struct {
__be32 datah;
__be32 datal;
} cp_ucode[256];
For Radeon 600-series, there are two separate firmware blobs:
__be32 me_ucode[PM4_UCODE_SIZE * 3];
__be32 pfp_ucode[PFP_UCODE_SIZE];
For Radeon 700-series, likewise:
__be32 me_ucode[R700_PM4_UCODE_SIZE];
__be32 pfp_ucode[R700_PFP_UCODE_SIZE];
- Better small packet receive performance.
- Better handling of Flow control on 5709.
- Fixed iSCSI TMP ABORT TASK problem.
- Added iSCSI TCP timestamp option.
Signed-off-by: Michael Chan <mchan@broadcom.com>
Firmware blob looks like this:
__be32 datah
__be32 datal
Image format is IHEX, one record for each pipe in order (record
addresses are ignored).
The new FW improves the packets per second rate. It required a lot of change in
the FW which implies many changes in the driver to support it. It is now also
possible for the driver to use a separate MSI-X vector for Rx and Tx - this also
add some to the complicity of this change.
All things said - after this patch, practically all performance matrixes show
improvement.
Though Vladislav Zolotarov is not signed on this patch, he did most of the job
and deserves credit for that.
use request_firmware() to load the phy's EDC programmation
Signed-off-by: Divy Le Ray <divy@chelsio.com>
Update FW to 7.4.
Bump up driver revision.
drivers/net/forcedeth.c
Signed-off-by: Matt Kraai <kraai@ftbfs.org>
3c589_cs,3c574_cs,serial_cs:
(1)add cis(firmware) of 3Com lan&modem mulitifunction pcmcia card.
(2)load correct configuration register for 3Com card
>From now on FW will be downloaded from the binary file using request_firmware.
There will be different files for every supported chip. Currently 57710 (e1) and
57711 (e1h).
File names have the following format: bnx2x-<chip version>-<FW version>.fw.
ihex versions of current FW files are submitted in the next patch.
Each binary file has a header in the following format:
struct bnx2x_fw_file_section {
__be32 len;
__be32 offset;
struct bnx2x_fw_file_hdr {
struct bnx2x_fw_file_section init_ops;
struct bnx2x_fw_file_section init_ops_offsets;
struct bnx2x_fw_file_section init_data;
struct bnx2x_fw_file_section tsem_int_table_data;
struct bnx2x_fw_file_section tsem_pram_data;
struct bnx2x_fw_file_section usem_int_table_data;
struct bnx2x_fw_file_section usem_pram_data;
struct bnx2x_fw_file_section csem_int_table_data;
struct bnx2x_fw_file_section csem_pram_data;
struct bnx2x_fw_file_section xsem_int_table_data;
struct bnx2x_fw_file_section xsem_pram_data;
struct bnx2x_fw_file_section fw_version;
Each bnx2x_fw_file_section contains the length and the offset of the appropriate
section in the binary file. Values are stored in the big endian format.
Data types of arrays:
init_data __be32
init_ops_offsets __be16
XXsem_pram_data u8
XXsem_int_table_data u8
init_ops struct raw_op {
u8 op;
__be24 offset;
__be32 data;
fw_version u8
>From now boundaries of a specific initialization stage are stored in
init_ops_offsets array instead of being defined by separate macroes. The index
in init_ops_offsets is calculated by BLOCK_OPS_IDX macro:
#define BLOCK_OPS_IDX(block, stage, end) \
(2*(((block)*STAGE_IDX_MAX) + (stage)) + (end))
Security:
In addition to sanity check of array boundaries bnx2x will check a FW version.
Additional checks might be added in the future.
Signed-off-by: Vladislav Zolotarov <vladz@broadcom.com>
pcnet_cs: add cis(firmware) of the Allied Telesis LA-PCM
* git://git.infradead.org/~dwmw2/firmware-2.6:
qla1280: Fix off-by-some error in firmware loading.
Add README.AddingFirmware file. Basically telling people not to.
firmware: Remove newly-added slicoss and sxg firmware images
firmware/WHENCE: Add missing origin information for Ambassador atmsar11.fw
ALSA: wavefront - Always use request_firmware()
Remove fdump tool for av7110 firmware
firmware: convert av7110 driver to request_firmware()
Partially revert "V4L/DVB (9533): cx88: Add support for TurboSight TBS8910 DVB-S PCI card"
Revert "fix modules_install via NFS"
Add-add conflicts in firmware/WHENCE fixed manually
These are available elsewhere (for example in the linux-firmware.git
repository); they have no business being added to the kernel source
tree.
We are only putting stuff in the firmware/ directory of the kernel
source when it's extracted from long-standing drivers which used to
include it directly.
We didn't intend to open the floodgates to including megabytes of new
firmware which was previously being distributed separately.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6:
b44: Use kernel DMA addresses for the kernel DMA API
forcedeth: Fix resume from hibernation regression.
xfrm: fix fragmentation on inter family tunnels
ibm_newemac: Fix dangerous struct assumption
gigaset: documentation update
gigaset: in file ops, check for device disconnect before anything else
bas_gigaset: use tasklet_hi_schedule for timing critical tasklets
net/802/fddi.c: add MODULE_LICENSE
smsc911x: remove unused #include <linux/version.h>
axnet_cs: fix phy_id detection for bogus Asix chip.
bnx2: Use request_firmware()
b44: Fix sizes passed to b44_sync_dma_desc_for_{device,cpu}()
socket: use percpu_add() while updating sockets_in_use
virtio_net: Set the mac config only when VIRITO_NET_F_MAC
myri_sbus: use request_firmware
e1000: fix loss of multicast packets
vxge: should include tcp.h
Conflict in firmware/WHENCE (SCSI vs net firmware)
Looks like we forgot to update WHENCE when we converted this driver.
Always use request_firmware() for loading yss225_registers image.
Signed-off-by: Jaswinder Singh <jaswinder@infradead.org>
DVB-S PCI card"
This reverts a hunk of commit 4b29631db33292d416dc395c56122ea865e7635c
which seems to have been an accident, and which re-introduced a
previously fixed bug.
This reverts commit 8b249b6856f16f09b0e5b79ce5f4d435e439b9d6.
This 'fix' is not necessary; we just need to undo the damage caused
accidentally by Igor/Mauro in 4b29631db33292d416dc395c56122ea865e7635c
("V4L/DVB (9533): cx88: Add support for TurboSight TBS8910 DVB-S PCI card")
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (74 commits)
[SCSI] sg: fix q->queue_lock on scsi_error_handler path
[SCSI] replace __inline with inline
[SCSI] a2091: make 2 functions static
[SCSI] a3000: make 2 functions static
[SCSI] ses: #if 0 the unused ses_match_host()
[SCSI] use kmem_cache_zalloc instead of kmem_cache_alloc/memset
[SCSI] sg: fix iovec bugs introduced by the block layer conversion
[SCSI] qlogicpti: use request_firmware
[SCSI] advansys: use request_firmware
[SCSI] qla1280: use request_firmware
[SCSI] libiscsi: fix iscsi pool error path
[SCSI] cxgb3i: call ddp release function directly
[SCSI] cxgb3i: merge cxgb3i_ddp into cxgb3i module
[SCSI] cxgb3i: close all tcp connections upon chip reset
[SCSI] cxgb3i: re-read ddp settings information after chip reset
[SCSI] cxgb3i: re-initialize ddp settings after chip reset
[SCSI] cxgb3i: subscribe to error notification from cxgb3 driver
[SCSI] aacraid driver update
[SCSI] mptsas: remove unneeded check
[SCSI] config: Make need for SCSI_CDROM clearer
Based on original patch by Ben Hutchings <ben@decadent.org.uk> and
Bastian Blank <waldi@debian.org>, with the following main changes:
Separated the mips firmware and rv2p firmware into different files
to make it easier to update them separately.
Added some code to fixup the rv2p code with run-time information
such as PAGE_SIZE.
Update version to 2.0.0.
Firmware blob looks like this...
__be16 lanai4_data_size
unsigned char lanai4_code[]
Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com>
Specify a license for the Alacritech Sahara (10Gbe) and SLICOSS (1GBE)
firmware files.
Signed-off-by: Christopher Harrer <charrer@alacritech.com>
Signed-off-by: Mithlesh Thukral <mithlesh@linsyssoft.com>
Add support for downloading the firmware using kernel-builtin mechanism.
This will remove the need for the firmware files in the driver source code.
Adds the firmware to the firmware directory in ihex format so it can be
installed when doing make firmware_install.
Also update the firmware location in the driver code so it can locate
the files in the right place.
This should conclude the move to request_firmware().
Signed-off-by: Lior Dotan <liodot@gmail.com>
Cc: Christopher Harrer <charrer@alacritech.com>
Firmware blob is little endian
Thanks to Stephen Rothwell for fixing typos
Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
__le32 checksum
unsigned char data[]
Firmware blob is little endian looks like this...
unsigned char Version1
unsigned char Version2
unsigned char Version3
unsigned char Padding
unsigned short start_address
unsigned short data
Added osi_load_firmware() instead of copying same thing twice
Added predef variable in add_mcs() to support predefined mcs data
Update FW to 7.1
Based on a patch by Jaswinder Singh <jaswinder@infradead.org>.
Compile-tested only.
Firmware blob is little endian.
Add the Multi-Tech cellular modem firmware to the TI USB serial driver.
This firmware was extracted from:
ftp://ftp.multitech.com/wireless/wireless_linux.zip
Firmware licence: "all firmware components are redistributable in binary
form" per support@multitech.com
Copyright (C) 2005 Multi-Tech Systems, Inc.
Signed-off-by: Chris Adams <cmadams@hiwaay.net>
Signed-off-by: Alan Cox <alan@redhat.com>
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6
Thanks to David Woodhouse for help.
Rafael reported:
I get the following error from 'make modules_install' on my test boxes:
HOSTCC firmware/ihex2fw
/home/rafael/src/linux-2.6/firmware/ihex2fw.c:268: fatal error: opening dependency file firmware/.ihex2fw.d: Read-only file system
compilation terminated.
make[3]: *** [firmware/ihex2fw] Error 1
make[2]: *** [_modinst_post] Error 2
make[1]: *** [sub-make] Error 2
make: *** [all] Error 2
where the configuration is that the kernel is compiled on a build box
with 'make O=<destdir> -j5' and then <destdir> is mounted over NFS read-only by
each test box (full path to this directory is the same on the build box and on
the test boxes). Then, I cd into <destdir>, run 'make modules_install' and get
the error above.
The issue turns out to be that we when we install firmware pick
up the list of firmware blobs from firmware/Makefile.
And this triggers the Makefile rules to update ihex2fw.
There were two solutions for this issue:
1) Move the list of firmware blobs to a separate file
2) Avoid ihex2fw rebuild by moving it to scripts
As I seriously beleive that the list of firmware blobs should be
done in a fundamental different way solution 2) was selected.
Reported-and-tested-by: "Rafael J. Wysocki" <rjw@sisk.pl>
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
Make firmware/dsp56k/bootstrap.asm buildable on a56, the free Motorola
DSP56001 assembler (http://www.zdomain.com/a56.html).
Summary of changes:
- Remove '<' and '>' candy (they specify explicit addressing modes,
which a56 don't grok, but uses implicitly anyway).
- Replace 'move' with 'movem' when accessing program memory.
- Rename a few labels to avoid duplicates (which a56 can't handle).
Signed-off-by: Robert Millan <rmh@aybabtu.com>
Cc: Jaswinder Singh <jaswinder@infradead.org>
