path: root/firmware
2010-08-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1443 commits) phy/marvell: add 88ec048 support igb: Program MDICNFG register prior to PHY init e1000e: correct MAC-PHY interconnect register offset for 82579 hso: Add new product ID can: Add driver for esd CAN-USB/2 device l2tp: fix export of header file for userspace can-raw: Fix skb_orphan_try handling Revert "net: remove zap_completion_queue" net: cleanup inclusion phy/marvell: add 88e1121 interface mode support u32: negative offset fix net: Fix a typo from "dev" to "ndev" igb: Use irq_synchronize per vector when using MSI-X ixgbevf: fix null pointer dereference due to filter being set for VLAN 0 e1000e: Fix irq_synchronize in MSI-X case e1000e: register pm_qos request on hardware activation ip_fragment: fix subtracting PPPOE_SES_HLEN from mtu twice net: Add getsockopt support for TCP thin-streams cxgb4: update driver version cxgb4: add new PCI IDs ... Manually fix up conflicts in: - drivers/net/e1000e/netdev.c: due to pm_qos registration infrastructure changes - drivers/net/phy/marvell.c: conflict between adding 88ec048 support and cleaning up the IDs - drivers/net/wireless/ipw2x00/ipw2100.c: trivial ipw2100_pm_qos_req conflict (registration change vs marking it static)
2010-07-08IB/qib: Use request_firmware() to load SD7220 firmwareBen Hutchings
Extract the microcode for the QLogic QLE7220 series IB HCA and use the kernel microcode request facility to load the microcode. This supports Debian Linux's requirements to separate microcode which doesn't have open source code available from the device driver. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2010-06-25cxgb3: update FW to 7.10Divy Le Ray
Update FW to 7.10 Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-17bnx2: Update 5709 MIPS firmware and version to 2.0.15.Michael Chan
New firmware fixes a performance regression on small packets. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-03bnx2x: Removed FW 5.2.7Vladislav Zolotarov
Removed FW 5.2.7. Signed-off-by: Vladislav Zolotarov <vladz@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-17bnx2x: Use firmware 5.2.13Vladislav Zolotarov
Switch to the new firmware version (5.2.13). Signed-off-by: Vladislav Zolotarov <vladz@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-17bnx2x: FW 5.2.13Vladislav Zolotarov
New firmware version (5.2.13). Signed-off-by: Vladislav Zolotarov <vladz@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-16bnx2: Update firmwares and update version to 2.0.8.Michael Chan
- Increase FTQ depth to 256 to ehnabce performance. - Fix RV2P context corruption on 5709 when flow control is enabled. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-06pcnet_cs: add cis of KTI PE520 pcmcia network cardKen Kawasaki
pcnet_cs,serial_cs: add cis of KTI PE520 pcmcia network card, and serial card(Sierra Wireless AC860). Signed-off-by: Ken Kawasaki <ken_kawasaki@spring.nifty.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-06Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/usb/cdc_ether.c All CDC ethernet devices of type USB_CLASS_COMM need to use '&mbm_info'. Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-29pcnet_cs: add cis of PreMax PE-200 ethernet pcmcia cardKen Kawasaki
pcnet_cs,serial_cs: add cis of PreMax ethernet pcmcia card, and some Sierra Wireless serial card(AC555, AC7xx, AC8xx). use PROD_ID for AC7xx, because MANF_ID of AC7xx and AC8xx are the same. Signed-off-by: Ken Kawasaki <ken_kawasaki@spring.nifty.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-15bnx2x: Remove old FW filesEilon Greenstein
2009-10-15bnx2x: Allowing 0 as initial fairness valueEilon Greenstein
Value of zero was used to disable the fairness mechanism. Though the code (driver and FW) allowed changing the value at run time, it did not allow to do that if the mechanism was disabled to begin with. Fixed the FW to allow turning on and off the mechanism at run time. Fixed the code to read the value from the chip at the right sequence. Without this fix, if the initial value was set to zero, traffic could not run on the interface. Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-15bnx2x: Add FW 5.2.7Eilon Greenstein
2009-10-05pcnet_cs: add cis of National Semicondoctor's multifunction pcmcia cardKen Kawasaki
pcnet_cs,serial_cs: add cis of National Semicondoctor's lan&modem mulitifunction pcmcia card, NE2K, tamarack ethernet card, and some serial card(COMpad2, COMpad4). Signed-off-by: Ken Kawasaki <ken_kawasaki@spring.nifty.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-23Documentation/: fix warnings from -Wmissing-prototypes in HOSTCFLAGSLadinu Chandrasinghe
Fix up -Wmissing-prototypes in compileable userspace code, mainly under Documentation/. Signed-off-by: Ladinu Chandrasinghe <ladinu.pub@gmail.com> Signed-off-by: Trevor Keith <tsrk@tsrk.net> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-21Merge branch 'drm-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6 * 'drm-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: (133 commits) drm/vgaarb: add VGA arbitration support to the drm and kms. drm/radeon: some r420s have a CP race with the DMA engine. drm/radeon/r600/kms: rv670 is not DCE3 drm/radeon/kms: r420 idle after programming GA_ENHANCE drm/radeon/kms: more fixes to rv770 suspend/resume path. drm/radeon/kms: more alignment for rv770.c with r600.c drm/radeon/kms: rv770 blit init called too late. drm/radeon/kms: move around new init path code to avoid posting at init drm/radeon/r600: fix some issues with suspend/resume. drm/radeon/kms: disable VGA rendering engine before taking over VRAM drm/radeon/kms: Move radeon_get_clock_info() call out of radeon_clocks_init(). drm/radeon/kms: add initial connector properties drm/radeon/kms: Use surfaces for scanout / cursor byte swapping on big endian. drm/radeon/kms: don't fail if we fail to init GPU acceleration drm/r600/kms: fixup number of loops per blit calculation. drm/radeon/kms: reprogram format in set base. drm/radeon: avivo chips have no separate int bit for display drm/radeon/r600: don't do interrupts drm: fix _DRM_GEM addmap error message drm: update crtc x/y when only fb changes ... Fixed up trivial conflicts in firmware/Makefile due to network driver (cxgb3) and drm (mga/r128/radeon) firmware being listed next to each other.
2009-09-15pcnet_cs: add cis of Linksys multifunction pcmcia cardKen Kawasaki
pcnet_cs,serial_cs: add cis of Linksys lan&modem mulitifunction pcmcia card and some modem card(MT5634ZLX, RS-COM-2P). Signed-off-by: Ken Kawasaki <ken_kawasaki@spring.nifty.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-31radeon: Use request_firmware()Ben Hutchings
Loosely based on a patch by Jaswinder Singh Rajput <jaswinderlinux@gmail.com>. KMS support by Dave Airlie <airlied@redhat.com>. For Radeon 100- to 500-series, firmware blobs look like: struct { __be32 datah; __be32 datal; } cp_ucode[256]; For Radeon 600-series, there are two separate firmware blobs: __be32 me_ucode[PM4_UCODE_SIZE * 3]; __be32 pfp_ucode[PFP_UCODE_SIZE]; For Radeon 700-series, likewise: __be32 me_ucode[R700_PM4_UCODE_SIZE]; __be32 pfp_ucode[R700_PFP_UCODE_SIZE]; Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-08-29bnx2: Update firmware to 5.0.0.j3.Michael Chan
- Better small packet receive performance. - Better handling of Flow control on 5709. - Fixed iSCSI TMP ABORT TASK problem. - Added iSCSI TCP timestamp option. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-27drm/r128: Use request_firmware() to load CCE microcodeBen Hutchings
Firmware blob looks like this: __be32 datah __be32 datal Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-08-27drm/mga: Use request_firmware() to load microcodeBen Hutchings
Image format is IHEX, one record for each pipe in order (record addresses are ignored). Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-08-12bnx2x: Removing old FW filesEilon Greenstein
2009-08-12bnx2x: Using the new FWEilon Greenstein
The new FW improves the packets per second rate. It required a lot of change in the FW which implies many changes in the driver to support it. It is now also possible for the driver to use a separate MSI-X vector for Rx and Tx - this also add some to the complicity of this change. All things said - after this patch, practically all performance matrixes show improvement. Though Vladislav Zolotarov is not signed on this patch, he did most of the job and deserves credit for that. Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-12bnx2x: New FW filesEilon Greenstein
2009-07-08cxgb3: use request_firmware() for the EDC registers setupDivy Le Ray
use request_firmware() to load the phy's EDC programmation Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-03cxgb3: Update FW to 7.4.0Divy Le Ray
Update FW to 7.4. Bump up driver revision. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-03Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/forcedeth.c
2009-05-29net/firmare: Ignore .cis filesMatt Kraai
Signed-off-by: Matt Kraai <kraai@ftbfs.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-013c589_cs: add cis(firmware) of 3Com multifunction pcmcia cardKen Kawasaki
3c589_cs,3c574_cs,serial_cs: (1)add cis(firmware) of 3Com lan&modem mulitifunction pcmcia card. (2)load correct configuration register for 3Com card Signed-off-by: Ken Kawasaki <ken_kawasaki@spring.nifty.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-27bnx2x: Separated FW from the source.Vladislav Zolotarov
>From now on FW will be downloaded from the binary file using request_firmware. There will be different files for every supported chip. Currently 57710 (e1) and 57711 (e1h). File names have the following format: bnx2x-<chip version>-<FW version>.fw. ihex versions of current FW files are submitted in the next patch. Each binary file has a header in the following format: struct bnx2x_fw_file_section { __be32 len; __be32 offset; } struct bnx2x_fw_file_hdr { struct bnx2x_fw_file_section init_ops; struct bnx2x_fw_file_section init_ops_offsets; struct bnx2x_fw_file_section init_data; struct bnx2x_fw_file_section tsem_int_table_data; struct bnx2x_fw_file_section tsem_pram_data; struct bnx2x_fw_file_section usem_int_table_data; struct bnx2x_fw_file_section usem_pram_data; struct bnx2x_fw_file_section csem_int_table_data; struct bnx2x_fw_file_section csem_pram_data; struct bnx2x_fw_file_section xsem_int_table_data; struct bnx2x_fw_file_section xsem_pram_data; struct bnx2x_fw_file_section fw_version; } Each bnx2x_fw_file_section contains the length and the offset of the appropriate section in the binary file. Values are stored in the big endian format. Data types of arrays: init_data __be32 init_ops_offsets __be16 XXsem_pram_data u8 XXsem_int_table_data u8 init_ops struct raw_op { u8 op; __be24 offset; __be32 data; } fw_version u8 >From now boundaries of a specific initialization stage are stored in init_ops_offsets array instead of being defined by separate macroes. The index in init_ops_offsets is calculated by BLOCK_OPS_IDX macro: #define BLOCK_OPS_IDX(block, stage, end) \ (2*(((block)*STAGE_IDX_MAX) + (stage)) + (end)) Security: In addition to sanity check of array boundaries bnx2x will check a FW version. Additional checks might be added in the future. Signed-off-by: Vladislav Zolotarov <vladz@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-27bnx2x: FW 4.8.53.0Vladislav Zolotarov
2009-04-21pcnet_cs: add cis(firmware) of the Allied Telesis LA-PCMKen Kawasaki
pcnet_cs: add cis(firmware) of the Allied Telesis LA-PCM Signed-off-by: Ken Kawasaki <ken_kawasaki@spring.nifty.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-10Merge git://git.infradead.org/~dwmw2/firmware-2.6Linus Torvalds
* git://git.infradead.org/~dwmw2/firmware-2.6: qla1280: Fix off-by-some error in firmware loading. Add README.AddingFirmware file. Basically telling people not to. firmware: Remove newly-added slicoss and sxg firmware images firmware/WHENCE: Add missing origin information for Ambassador atmsar11.fw ALSA: wavefront - Always use request_firmware() Remove fdump tool for av7110 firmware firmware: convert av7110 driver to request_firmware() Partially revert "V4L/DVB (9533): cx88: Add support for TurboSight TBS8910 DVB-S PCI card" Revert "fix modules_install via NFS" Add-add conflicts in firmware/WHENCE fixed manually
2009-04-06Add README.AddingFirmware file. Basically telling people not to.David Woodhouse
2009-04-06firmware: Remove newly-added slicoss and sxg firmware imagesDavid Woodhouse
These are available elsewhere (for example in the linux-firmware.git repository); they have no business being added to the kernel source tree. We are only putting stuff in the firmware/ directory of the kernel source when it's extracted from long-standing drivers which used to include it directly. We didn't intend to open the floodgates to including megabytes of new firmware which was previously being distributed separately. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-04-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: b44: Use kernel DMA addresses for the kernel DMA API forcedeth: Fix resume from hibernation regression. xfrm: fix fragmentation on inter family tunnels ibm_newemac: Fix dangerous struct assumption gigaset: documentation update gigaset: in file ops, check for device disconnect before anything else bas_gigaset: use tasklet_hi_schedule for timing critical tasklets net/802/fddi.c: add MODULE_LICENSE smsc911x: remove unused #include <linux/version.h> axnet_cs: fix phy_id detection for bogus Asix chip. bnx2: Use request_firmware() b44: Fix sizes passed to b44_sync_dma_desc_for_{device,cpu}() socket: use percpu_add() while updating sockets_in_use virtio_net: Set the mac config only when VIRITO_NET_F_MAC myri_sbus: use request_firmware e1000: fix loss of multicast packets vxge: should include tcp.h Conflict in firmware/WHENCE (SCSI vs net firmware)
2009-04-06firmware/WHENCE: Add missing origin information for Ambassador atmsar11.fwDavid Woodhouse
Looks like we forgot to update WHENCE when we converted this driver. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-04-06ALSA: wavefront - Always use request_firmware()Takashi Iwai
Always use request_firmware() for loading yss225_registers image. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-04-06firmware: convert av7110 driver to request_firmware()Jaswinder Singh
Signed-off-by: Jaswinder Singh <jaswinder@infradead.org> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-04-06Partially revert "V4L/DVB (9533): cx88: Add support for TurboSight TBS8910 ↵David Woodhouse
DVB-S PCI card" This reverts a hunk of commit 4b29631db33292d416dc395c56122ea865e7635c which seems to have been an accident, and which re-introduced a previously fixed bug. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-04-06Revert "fix modules_install via NFS"David Woodhouse
This reverts commit 8b249b6856f16f09b0e5b79ce5f4d435e439b9d6. This 'fix' is not necessary; we just need to undo the damage caused accidentally by Igor/Mauro in 4b29631db33292d416dc395c56122ea865e7635c ("V4L/DVB (9533): cx88: Add support for TurboSight TBS8910 DVB-S PCI card") Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-04-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (74 commits) [SCSI] sg: fix q->queue_lock on scsi_error_handler path [SCSI] replace __inline with inline [SCSI] a2091: make 2 functions static [SCSI] a3000: make 2 functions static [SCSI] ses: #if 0 the unused ses_match_host() [SCSI] use kmem_cache_zalloc instead of kmem_cache_alloc/memset [SCSI] sg: fix iovec bugs introduced by the block layer conversion [SCSI] qlogicpti: use request_firmware [SCSI] advansys: use request_firmware [SCSI] qla1280: use request_firmware [SCSI] libiscsi: fix iscsi pool error path [SCSI] cxgb3i: call ddp release function directly [SCSI] cxgb3i: merge cxgb3i_ddp into cxgb3i module [SCSI] cxgb3i: close all tcp connections upon chip reset [SCSI] cxgb3i: re-read ddp settings information after chip reset [SCSI] cxgb3i: re-initialize ddp settings after chip reset [SCSI] cxgb3i: subscribe to error notification from cxgb3 driver [SCSI] aacraid driver update [SCSI] mptsas: remove unneeded check [SCSI] config: Make need for SCSI_CDROM clearer ...
2009-04-04bnx2: Use request_firmware()Michael Chan
Based on original patch by Ben Hutchings <ben@decadent.org.uk> and Bastian Blank <waldi@debian.org>, with the following main changes: Separated the mips firmware and rv2p firmware into different files to make it easier to update them separately. Added some code to fixup the rv2p code with run-time information such as PAGE_SIZE. Update version to 2.0.0. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-04myri_sbus: use request_firmwareJaswinder Singh Rajput
Firmware blob looks like this... __be16 lanai4_data_size unsigned char lanai4_code[] Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-03Staging: sxg: slicoss: Specify the license for Sahara SXG and Slicoss driversMithlesh Thukral
Specify a license for the Alacritech Sahara (10Gbe) and SLICOSS (1GBE) firmware files. Signed-off-by: Christopher Harrer <charrer@alacritech.com> Signed-off-by: Mithlesh Thukral <mithlesh@linsyssoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-04-03Staging: sxg: Add support to download the firmware using request_firmware()Mithlesh Thukral
Add support for downloading the firmware using kernel-builtin mechanism. This will remove the need for the firmware files in the driver source code. Signed-off-by: Christopher Harrer <charrer@alacritech.com> Signed-off-by: Mithlesh Thukral <mithlesh@linsyssoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-04-03Staging: slicoss: add binary firmware to firmware directoryLior Dotan
Adds the firmware to the firmware directory in ihex format so it can be installed when doing make firmware_install. Also update the firmware location in the driver code so it can locate the files in the right place. This should conclude the move to request_firmware(). Signed-off-by: Lior Dotan <liodot@gmail.com> Cc: Christopher Harrer <charrer@alacritech.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-04-03[SCSI] qlogicpti: use request_firmwareJaswinder Singh Rajput
Firmware blob is little endian Thanks to Stephen Rothwell for fixing typos Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-04-03[SCSI] advansys: use request_firmwareJaswinder Singh Rajput
Firmware blob looks like this... __le32 checksum unsigned char data[] Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
