path: root/fs/9p/fid.c
2010-04-05Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs: 9p: saving negative to unsigned char 9p: return on mutex_lock_interruptible() 9p: Creating files with names too long should fail with ENAMETOOLONG. 9p: Make sure we are able to clunk the cached fid on umount 9p: drop nlink remove fs/9p: Clunk the fid resulting from partial walk of the name 9p: documentation update 9p: Fix setting of protocol flags in v9fs_session_info structure.
2010-04-05fs/9p: Clunk the fid resulting from partial walk of the nameAneesh Kumar K.V
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-059P2010.L handshake: Add VFS flagsSripathi Kodi
Add 9P2000.u and 9P2010.L protocol flags to V9FS VFS This patch adds 9P2000.u and 9P2010.L protocol flags into V9FS VFS side code and removes the single flag used for 'extended'. Signed-off-by: Sripathi Kodi <sripathik@in.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2008-12-25Merge branch 'next' into for-linusJames Morris
2008-12-199p: convert d_iname references to d_name.nameWu Fengguang
d_iname is rubbish for long file names. Use d_name.name in printks instead. Signed-off-by: Wu Fengguang <wfg@linux.intel.com> Acked-by: Eric Van Hensbergen <ericvh@gmail.com>
2008-11-14CRED: Wrap task credential accesses in 9P2000 filesystemDavid Howells
Wrap access to task credentials so that they can be separated more easily from the task_struct during the introduction of COW creds. Change most current->(|e|s|fs)[ug]id to current_(|e|s|fs)[ug]id(). Change some task->e?[ug]id to task_e?[ug]id(). In some places it makes more sense to use RCU directly rather than a convenient wrapper; these will be addressed by later patches. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Reviewed-by: Eric Van Hensbergen <ericvh@gmail.com> Cc: Ron Minnich <rminnich@sandia.gov> Cc: Latchesar Ionkov <lucho@ionkov.net> Cc: v9fs-developer@lists.sourceforge.net Signed-off-by: James Morris <jmorris@namei.org>
2008-04-18fs: Remove unnecessary inclusions of asm/semaphore.hMatthew Wilcox
None of these files use any of the functionality promised by asm/semaphore.h. Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
2008-02-069p: fix bug in attach-per-userEric Van Hensbergen
When a new user attached at a directory other than the root, he would end up in the parent directory of the cwd. This was due to a logic error in the code which attaches the user at the mount point and walks back to the cwd. This patch fixes that. Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2007-10-179p: attach-per-userLatchesar Ionkov
The 9P2000 protocol requires the authentication and permission checks to be done in the file server. For that reason every user that accesses the file server tree has to authenticate and attach to the server separately. Multiple users can share the same connection to the server. Currently v9fs does a single attach and executes all I/O operations as a single user. This makes using v9fs in multiuser environment unsafe as it depends on the client doing the permission checking. This patch improves the 9P2000 support by allowing every user to attach separately. The patch defines three modes of access (new mount option 'access'): - attach-per-user (access=user) (default mode for 9P2000.u) If a user tries to access a file served by v9fs for the first time, v9fs sends an attach command to the server (Tattach) specifying the user. If the attach succeeds, the user can access the v9fs tree. As there is no uname->uid (string->integer) mapping yet, this mode works only with the 9P2000.u dialect. - allow only one user to access the tree (access=<uid>) Only the user with uid can access the v9fs tree. Other users that attempt to access it will get EPERM error. - do all operations as a single user (access=any) (default for 9P2000) V9fs does a single attach and all operations are done as a single user. If this mode is selected, the v9fs behavior is identical with the current one. Signed-off-by: Latchesar Ionkov <lucho@ionkov.net> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2007-08-239p: remove deprecated v9fs_fid_lookup_remove()Eric Van Hensbergen
This patch removes the v9fs_fid_lookup_remove which is no longer used. Based on original patch from Adrian Bunk <bunk@stusta.de> which used #if 0 to isolate the code. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2007-07-149p: Reorganization of 9p file system codeLatchesar Ionkov
This patchset moves non-filesystem interfaces of v9fs from fs/9p to net/9p. It moves the transport, packet marshalling and connection layers to net/9p leaving only the VFS related files in fs/9p. This work is being done in preparation for in-kernel 9p servers as well as alternate 9p clients (other than VFS). Signed-off-by: Latchesar Ionkov <lucho@ionkov.net> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2007-02-189p: implement optional loose read cacheEric Van Hensbergen
While cacheing is generally frowned upon in the 9p world, it has its place -- particularly in situations where the remote file system is exclusive and/or read-only. The vacfs views of venti content addressable store are a real-world instance of such a situation. To facilitate higher performance for these workloads (and eventually use the fscache patches), we have enabled a "loose" cache mode which does not attempt to maintain any form of consistency on the page-cache or dcache. This results in over two orders of magnitude performance improvement for cacheable block reads in the Bonnie benchmark. The more aggressive use of the dcache also seems to improve metadata operational performance. Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2007-01-26[PATCH] 9p: fix segfault caused by race condition in meta-data operationsEric Van Hensbergen
Running dbench multithreaded exposed a race condition where fid structures were removed while in use. This patch adds semaphores to meta-data operations to protect the fid structure. Some cleanup of error-case handling in the inode operations is also included. Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-04[PATCH] severing fs.h, radix-tree.h -> sched.hAl Viro
2006-03-25[PATCH] v9fs: update license boilerplateEric Van Hensbergen
Update license boilerplate to specify GPLv2 and remove the (at your option clause). This change was agreed to by all the copyright holders (approvals can be found on v9fs-developer mailing list). Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-02[PATCH] v9fs: simplify fid mappingEric Van Hensbergen
v9fs has been plagued by an over-complicated approach trying to map Linux dentry semantics to Plan 9 fid semantics. Our previous approach called for aggressive flushing of the dcache resulting in several problems (including wierd cwd behavior when running /bin/pwd). This patch dramatically simplifies our handling of this fid management. Fids will not be clunked as promptly, but the new approach is more functionally correct. We now clunk un-open fids only when their dentry ref_count reaches 0 (and d_delete is called). Another simplification is we no longer seek to match fids to the process-id or uid of the action initiator. The uid-matching will need to be revisited when we fix the security model. Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-02[PATCH] v9fs: fix atomic create openLatchesar Ionkov
In order to assure atomic create+open v9fs stores the open fid produced by v9fs_vfs_create in the dentry, from where v9fs_file_open retrieves it and associates it with the open file. This patch modifies v9fs to use nameidata.intent.open values to do the atomic create+open. Signed-off-by: Latchesar Ionkov <lucho@ionkov.net> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] v9fs: zero copy implementationLatchesar Ionkov
Performance enhancement reducing the number of copies in the data and stat paths. Signed-off-by: Latchesar Ionkov <lucho@ionkov.net> Cc: Eric Van Hensbergen <ericvh@ericvh.myip.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] v9fs: new multiplexer implementationLatchesar Ionkov
New multiplexer implementation. Decreases the number of kernel threads required. Better handling when the user process receives a signal. Signed-off-by: Latchesar Ionkov <lucho@ionkov.net> Cc: Eric Van Hensbergen <ericvh@ericvh.myip.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-28[PATCH] v9fs: fix races in fid allocationLatchesar Ionkov
Fid management cleanup. The patch attempts to fix the races in dentry's fid management. Dentries don't keep the opened fids anymore, they are moved to the file structs. Ideally there should be no more than one fid with fidcreate equal to zero in the dentry's list of fids. v9fs_fid_create initializes the important fields (fid, fidcreated) before v9fs_fid is added to the list. v9fs_fid_lookup returns only fids that are not created by v9fs_create. v9fs_fid_get_created returns the fid created by the same process by v9fs_create (if any) and removes it from dentry's list Signed-off-by: Latchesar Ionkov <lucho@ionkov.net> Cc: Eric Van Hensbergen <ericvh@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] v9fs: debug and support routinesEric Van Hensbergen
This part of the patch contains debug and other misc routines. Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
