path: root/fs/9p/vfs_file.c
2006-03-02[PATCH] v9fs: fix atomic create openLatchesar Ionkov
In order to assure atomic create+open v9fs stores the open fid produced by v9fs_vfs_create in the dentry, from where v9fs_file_open retrieves it and associates it with the open file. This patch modifies v9fs to use nameidata.intent.open values to do the atomic create+open. Signed-off-by: Latchesar Ionkov <lucho@ionkov.net> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-18[PATCH] v9fs: add readpage supportEric Van Hensbergen
v9fs mmap support was originally removed from v9fs at Al Viro's request, but recently there have been requests from folks who want readpage functionality (primarily to enable execution of files mounted via 9P). This patch adds readpage support (but not writepage which contained most of the objectionable code). It passes fsx-linux (and other regressions) so it should be relatively safe. Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] v9fs: zero copy implementationLatchesar Ionkov
Performance enhancement reducing the number of copies in the data and stat paths. Signed-off-by: Latchesar Ionkov <lucho@ionkov.net> Cc: Eric Van Hensbergen <ericvh@ericvh.myip.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] Fix and add EXPORT_SYMBOL(filemap_write_and_wait)OGAWA Hirofumi
This patch add EXPORT_SYMBOL(filemap_write_and_wait) and use it. See mm/filemap.c: And changes the filemap_write_and_wait() and filemap_write_and_wait_range(). Current filemap_write_and_wait() doesn't wait if filemap_fdatawrite() returns error. However, even if filemap_fdatawrite() returned an error, it may have submitted the partially data pages to the device. (e.g. in the case of -ENOSPC) <quotation> Andrew Morton writes, If filemap_fdatawrite() returns an error, this might be due to some I/O problem: dead disk, unplugged cable, etc. Given the generally crappy quality of the kernel's handling of such exceptions, there's a good chance that the filemap_fdatawait() will get stuck in D state forever. </quotation> So, this patch doesn't wait if filemap_fdatawrite() returns the -EIO. Trond, could you please review the nfs part? Especially I'm not sure, nfs must use the "filemap_fdatawrite(inode->i_mapping) == 0", or not. Acked-by: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] changing CONFIG_LOCALVERSION rebuilds too much, for no good reasonOlaf Hering
This patch removes almost all inclusions of linux/version.h. The 3 #defines are unused in most of the touched files. A few drivers use the simple KERNEL_VERSION(a,b,c) macro, which is unfortunatly in linux/version.h. There are also lots of #ifdef for long obsolete kernels, this was not touched. In a few places, the linux/version.h include was move to where the LINUX_VERSION_CODE was used. quilt vi `find * -type f -name "*.[ch]"|xargs grep -El '(UTS_RELEASE|LINUX_VERSION_CODE|KERNEL_VERSION|linux/version.h)'|grep -Ev '(/(boot|coda|drm)/|~$)'` search pattern: /UTS_RELEASE\|LINUX_VERSION_CODE\|KERNEL_VERSION\|linux\/\(utsname\|version\).h Signed-off-by: Olaf Hering <olh@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-11[PATCH] v9fs: remove additional buffer allocation from v9fs_file_read and ↵Latchesar Ionkov
v9fs_file_write v9fs_file_read and v9fs_file_write use kmalloc to allocate buffers as big as the data buffer received as parameter. kmalloc cannot be used to allocate buffers bigger than 128K, so reading/writing data in chunks bigger than 128k fails. This patch reorganizes v9fs_file_read and v9fs_file_write to allocate only buffers as big as the maximum data that can be sent in one 9P message. Signed-off-by: Latchesar Ionkov <lucho@ionkov.net> Cc: Eric Van Hensbergen <ericvh@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-28[PATCH] v9fs: fix races in fid allocationLatchesar Ionkov
Fid management cleanup. The patch attempts to fix the races in dentry's fid management. Dentries don't keep the opened fids anymore, they are moved to the file structs. Ideally there should be no more than one fid with fidcreate equal to zero in the dentry's list of fids. v9fs_fid_create initializes the important fields (fid, fidcreated) before v9fs_fid is added to the list. v9fs_fid_lookup returns only fids that are not created by v9fs_create. v9fs_fid_get_created returns the fid created by the same process by v9fs_create (if any) and removes it from dentry's list Signed-off-by: Latchesar Ionkov <lucho@ionkov.net> Cc: Eric Van Hensbergen <ericvh@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] v9fs: VFS file, dentry, and directory operationsEric Van Hensbergen
This part of the patch contains the VFS file, dentry & directory interfaces. Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
