path: root/fs/9p/vfs_super.c
2006-03-08[PATCH] v9fs: fix for access to unitialized variables or freed memoryLatchesar Ionkov
Miscellaneous fixes related to accessing uninitialized variables or memory that was already freed. Signed-off-by: Latchesar Ionkov <lucho@ionkov.net> Cc: Eric Van Hensbergen <ericvh@ericvh.myip.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-02[PATCH] v9fs: fix bug in atomic create open fixEric Van Hensbergen
Lucho's atomic create+open fix had a bug in the super block initialization causing all mounts to fail. He was freeing an fcall too early. This patch fixes that oversight. Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-02[PATCH] v9fs: fix atomic create openLatchesar Ionkov
In order to assure atomic create+open v9fs stores the open fid produced by v9fs_vfs_create in the dentry, from where v9fs_file_open retrieves it and associates it with the open file. This patch modifies v9fs to use nameidata.intent.open values to do the atomic create+open. Signed-off-by: Latchesar Ionkov <lucho@ionkov.net> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] 9p: remove superflous MS_NODIRATIME assignmentChristoph Hellwig
MS_NOATIME implies MS_NODIRATIME Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Eric Van Hensbergen <ericvh@ericvh.myip.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] v9fs: handle kthread_create failure, minor bugfixesLatchesar Ionkov
- remove unnecessary -ENOMEM assignments - return correct value when buf_check_size for second time in a buffer - handle failures when create_workqueue and kthread_create are called - use kzalloc instead of kmalloc/memset 0 - v9fs_str_copy and v9fs_str_compare were buggy, were used only in one place, correct the logic and move it to the place it is used. Signed-off-by: Latchesar Ionkov <lucho@ionkov.net> Cc: Eric Van Hensbergen <ericvh@ericvh.myip.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] v9fs: zero copy implementationLatchesar Ionkov
Performance enhancement reducing the number of copies in the data and stat paths. Signed-off-by: Latchesar Ionkov <lucho@ionkov.net> Cc: Eric Van Hensbergen <ericvh@ericvh.myip.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] v9fs: new multiplexer implementationLatchesar Ionkov
New multiplexer implementation. Decreases the number of kernel threads required. Better handling when the user process receives a signal. Signed-off-by: Latchesar Ionkov <lucho@ionkov.net> Cc: Eric Van Hensbergen <ericvh@ericvh.myip.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-30[PATCH] missing ERR_PTR in 9fsAl Viro
2005-09-28[PATCH] v9fs: fix races in fid allocationLatchesar Ionkov
Fid management cleanup. The patch attempts to fix the races in dentry's fid management. Dentries don't keep the opened fids anymore, they are moved to the file structs. Ideally there should be no more than one fid with fidcreate equal to zero in the dentry's list of fids. v9fs_fid_create initializes the important fields (fid, fidcreated) before v9fs_fid is added to the list. v9fs_fid_lookup returns only fids that are not created by v9fs_create. v9fs_fid_get_created returns the fid created by the same process by v9fs_create (if any) and removes it from dentry's list Signed-off-by: Latchesar Ionkov <lucho@ionkov.net> Cc: Eric Van Hensbergen <ericvh@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-22[PATCH] v9fs: don't free root dentry & inode if error occurs in v9fs_get_sbLatchesar Ionkov
If error occurs while in v9fs_get_sb after it calles sget, the dentry object of the root and its inode may be freed twice -- once while handling the error in v9fs_get_sb, and second time when v9fs_get_sb calles deactivate_super (which in turn calls v9fs_kill_super) The patch removes the unnecessary code that frees the root dentry and its inode. Signed-off-by: Latchesar Ionkov <lucho@ionkov.net> Cc: Eric Van Hensbergen <ericvh@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] v9fs: Support to force umountEric Van Hensbergen
Support for force umount Signed-off-by: Latchesar Ionkov <lucho@ionkov.net> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] v9fs: VFS superblock operations and glueEric Van Hensbergen
This part of the patch contains VFS superblock and mapping code. Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
