path: root/fs/9p
2005-11-28[PATCH] v9fs: fix memory leak in v9fs dentry codeLatchesar Ionkov
Assign the appropriate dentry operations to the dentry. Fixes memory leak. Signed-off-by: Latchesar Ionkov <lucho@ionkov.net> Cc: Eric Van Hensbergen <ericvh@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] changing CONFIG_LOCALVERSION rebuilds too much, for no good reasonOlaf Hering
This patch removes almost all inclusions of linux/version.h. The 3 #defines are unused in most of the touched files. A few drivers use the simple KERNEL_VERSION(a,b,c) macro, which is unfortunatly in linux/version.h. There are also lots of #ifdef for long obsolete kernels, this was not touched. In a few places, the linux/version.h include was move to where the LINUX_VERSION_CODE was used. quilt vi `find * -type f -name "*.[ch]"|xargs grep -El '(UTS_RELEASE|LINUX_VERSION_CODE|KERNEL_VERSION|linux/version.h)'|grep -Ev '(/(boot|coda|drm)/|~$)'` search pattern: /UTS_RELEASE\|LINUX_VERSION_CODE\|KERNEL_VERSION\|linux\/\(utsname\|version\).h Signed-off-by: Olaf Hering <olh@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] kfree cleanup: fsJesper Juhl
This is the fs/ part of the big kfree cleanup patch. Remove pointless checks for NULL prior to calling kfree() in fs/. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] fix remaining missing includesTim Schmielau
Fix more include file problems that surfaced since I submitted the previous fix-missing-includes.patch. This should now allow not to include sched.h from module.h, which is done by a followup patch. Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] V9FS: 'names_cache' memory leakDavi Arnaut
Data allocated with "__getname()" should always be free'd with "__putname()" because of the AUDITSYSCALL code. Signed-off-by: Davi Arnaut <davi.arnaut@gmail.com> Cc: <rminnich@lanl.gov> Cc: Eric Van Hensbergen <ericvh@ericvh.myip.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-11[PATCH] v9fs: remove additional buffer allocation from v9fs_file_read and ↵Latchesar Ionkov
v9fs_file_write v9fs_file_read and v9fs_file_write use kmalloc to allocate buffers as big as the data buffer received as parameter. kmalloc cannot be used to allocate buffers bigger than 128K, so reading/writing data in chunks bigger than 128k fails. This patch reorganizes v9fs_file_read and v9fs_file_write to allocate only buffers as big as the maximum data that can be sent in one 9P message. Signed-off-by: Latchesar Ionkov <lucho@ionkov.net> Cc: Eric Van Hensbergen <ericvh@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-30[PATCH] missing ERR_PTR in 9fsAl Viro
2005-09-28[PATCH] v9fs: fix races in fid allocationLatchesar Ionkov
Fid management cleanup. The patch attempts to fix the races in dentry's fid management. Dentries don't keep the opened fids anymore, they are moved to the file structs. Ideally there should be no more than one fid with fidcreate equal to zero in the dentry's list of fids. v9fs_fid_create initializes the important fields (fid, fidcreated) before v9fs_fid is added to the list. v9fs_fid_lookup returns only fids that are not created by v9fs_create. v9fs_fid_get_created returns the fid created by the same process by v9fs_create (if any) and removes it from dentry's list Signed-off-by: Latchesar Ionkov <lucho@ionkov.net> Cc: Eric Van Hensbergen <ericvh@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-22[PATCH] v9fs: don't free root dentry & inode if error occurs in v9fs_get_sbLatchesar Ionkov
If error occurs while in v9fs_get_sb after it calles sget, the dentry object of the root and its inode may be freed twice -- once while handling the error in v9fs_get_sb, and second time when v9fs_get_sb calles deactivate_super (which in turn calls v9fs_kill_super) The patch removes the unnecessary code that frees the root dentry and its inode. Signed-off-by: Latchesar Ionkov <lucho@ionkov.net> Cc: Eric Van Hensbergen <ericvh@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-22[PATCH] v9fs: replace strlen on newly allocated by __getname buffers to PATH_MAXLatchesar Ionkov
v9fs_vfs_readlink allocates space for the link using __getname and errorneously uses strlen on the newly allocated buffer to check if the buffer passed by the user is bigger than the one returned by __getname. The patch replaces the strlen usage to PATH_MAX, which is the actual size of the buffers returned by __getname. Signed-off-by: Latchesar Ionkov <lucho@ionkov.net> Cc: Eric Van Hensbergen <ericvh@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-22[PATCH] v9fs: make copy of the transport prototype instead of using it directlyLatchesar Ionkov
When a new session is created it uses a template object of the specified transport type to instantiate its own copy. The code for the making a copy of the template object was lost, and the object itself is attached to the v9fs session. This leads to many sessions using the same transport instead of having their own copy. The patch puts back the code that makes a copy of the template object. Signed-off-by: Latchesar Ionkov <lucho@ionkov.net> Cc: Eric Van Hensbergen <ericvh@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-22[PATCH] v9fs: allocate the Rwalk qid array from the right conv bufferLatchesar Ionkov
When v9fs_deserealize_fcall deserializes a Rwalk message, it incorrectly allocates space for the qid array in the source instead of the destination buffer. Signed-off-by: Latchesar Ionkov <lucho@ionkov.net> Cc: Eric Van Hensbergen <ericvh@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-22[PATCH] v9fs: make conv functions to check for conv buffer overflowLatchesar Ionkov
buf_check_size function checks if the conv buffer has enough space for the performed operation, but it doesn't return the result back to the calling function, only logs an error in the log. The report-back-error functionality was lost when buf_check_size was converted from macro to inline function. The return in the macro used to exit from the functions that include it, after the conversion it just exits from the inline function itself. The patch makes buf_check_size to return flag and all functions that use it check if they should perform the operation, or exit. Signed-off-by: Latchesar Ionkov <lucho@ionkov.net> Cc: Eric Van Hensbergen <ericvh@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] v9fs: fix handling of malformed 9P messagesEric Van Hensbergen
This patch attempts to do a better job of cleaning up after detecting errors on the transport. This should also improve error reporting on broken connections to servers. Signed-off-by: Latchesar Ionkov <lucho@ionkov.net> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] v9fs: readlink extended mode checkEric Van Hensbergen
LANL reported some issues with random crashes during mount of legacy protocol servers (9P2000 versus 9P2000.u) -- crash was always happening in readlink (which should never happen in legacy mode). Added some sanity conditionals to the get_inode code which should prevent the errors LANL was seeing. Code tested benign through regression. Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] v9fs: Fix support for special files (devices, named pipes, etc.)Eric Van Hensbergen
Fix v9fs special files (block, char devices) support. Signed-off-by: Latchesar Ionkov <lucho@ionkov.net> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] v9fs: Clean-up vfs_inode and setattr functionsEric Van Hensbergen
Cleanup code in v9fs vfs_inode as suggested by Alexey Dobriyan. Did some major revamping of the v9fs setattr code to remove unnecessary allocations and clean up some dead-code. Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] v9fs: Change error magic numbers to defined constantsEric Van Hensbergen
Change magic error numbers to system defined constants in v9fs error.h As suggested by Jan-Benedict Glaw. Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] v9fs: debug and support routinesEric Van Hensbergen
This part of the patch contains debug and other misc routines. Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] v9fs: Support to force umountEric Van Hensbergen
Support for force umount Signed-off-by: Latchesar Ionkov <lucho@ionkov.net> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] v9fs: transport modulesEric Van Hensbergen
This part of the patch contains transport routines. Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com> Signed-off-by: Latchesar Ionkov <lucho@ionkov.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] v9fs: 9P protocol implementationEric Van Hensbergen
This part of the patch contains the 9P protocol functions. Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] v9fs: VFS superblock operations and glueEric Van Hensbergen
This part of the patch contains VFS superblock and mapping code. Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] v9fs: VFS inode operationsEric Van Hensbergen
This part of the patch contains the VFS inode interfaces. Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] v9fs: VFS file, dentry, and directory operationsEric Van Hensbergen
This part of the patch contains the VFS file, dentry & directory interfaces. Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] v9fs: Documentation, Makefiles, ConfigurationEric Van Hensbergen
OVERVIEW V9FS is a distributed file system for Linux which provides an implementation of the Plan 9 resource sharing protocol 9P. It can be used to share all sorts of resources: static files, synthetic file servers (such as /proc or /sys), devices, and application file servers (such as FUSE). BACKGROUND Plan 9 (http://plan9.bell-labs.com/plan9) is a research operating system and associated applications suite developed by the Computing Science Research Center of AT&T Bell Laboratories (now a part of Lucent Technologies), the same group that developed UNIX , C, and C++. Plan 9 was initially released in 1993 to universities, and then made generally available in 1995. Its core operating systems code laid the foundation for the Inferno Operating System released as a product by Lucent Bell-Labs in 1997. The Inferno venture was the only commercial embodiment of Plan 9 and is currently maintained as a product by Vita Nuova (http://www.vitanuova.com). After updated releases in 2000 and 2002, Plan 9 was open-sourced under the OSI approved Lucent Public License in 2003. The Plan 9 project was started by Ken Thompson and Rob Pike in 1985. Their intent was to explore potential solutions to some of the shortcomings of UNIX in the face of the widespread use of high-speed networks to connect machines. In UNIX, networking was an afterthought and UNIX clusters became little more than a network of stand-alone systems. Plan 9 was designed from first principles as a seamless distributed system with integrated secure network resource sharing. Applications and services were architected in such a way as to allow for implicit distribution across a cluster of systems. Configuring an environment to use remote application components or services in place of their local equivalent could be achieved with a few simple command line instructions. For the most part, application implementations operated independent of the location of their actual resources. Commercial operating systems haven't changed much in the 20 years since Plan 9 was conceived. Network and distributed systems support is provided by a patchwork of middle-ware, with an endless number of packages supplying pieces of the puzzle. Matters are complicated by the use of different complicated protocols for individual services, and separate implementations for kernel and application resources. The V9FS project (http://v9fs.sourceforge.net) is an attempt to bring Plan 9's unified approach to resource sharing to Linux and other operating systems via support for the 9P2000 resource sharing protocol. V9FS HISTORY V9FS was originally developed by Ron Minnich and Maya Gokhale at Los Alamos National Labs (LANL) in 1997. In November of 2001, Greg Watson setup a SourceForge project as a public repository for the code which supported the Linux 2.4 kernel. About a year ago, I picked up the initial attempt Ron Minnich had made to provide 2.6 support and got the code integrated into a 2.6.5 kernel. I then went through a line-for-line re-write attempting to clean-up the code while more closely following the Linux Kernel style guidelines. I co-authored a paper with Ron Minnich on the V9FS Linux support including performance comparisons to NFSv3 using Bonnie and PostMark - this paper appeared at the USENIX/FREENIX 2005 conference in April 2005: ( http://www.usenix.org/events/usenix05/tech/freenix/hensbergen.html ). CALL FOR PARTICIPATION/REQUEST FOR COMMENTS Our 2.6 kernel support is stabilizing and we'd like to begin pursuing its integration into the official kernel tree. We would appreciate any review, comments, critiques, and additions from this community and are actively seeking people to join our project and help us produce something that would be acceptable and useful to the Linux community. STATUS The code is reasonably stable, although there are no doubt corner cases our regression tests haven't discovered yet. It is in regular use by several of the developers and has been tested on x86 and PowerPC (32-bit and 64-bit) in both small and large (LANL cluster) deployments. Our current regression tests include fsx, bonnie, and postmark. It was our intention to keep things as simple as possible for this release -- trying to focus on correctness within the core of the protocol support versus a rich set of features. For example: a more complete security model and cache layer are in the road map, but excluded from this release. Additionally, we have removed support for mmap operations at Al Viro's request. PERFORMANCE Detailed performance numbers and analysis are included in the FREENIX paper, but we show comparable performance to NFSv3 for large file operations based on the Bonnie benchmark, and superior performance for many small file operations based on the PostMark benchmark. Somewhat preliminary graphs (from the FREENIX paper) are available (http://v9fs.sourceforge.net/perf/index.html). RESOURCES The source code is available in a few different forms: tarballs: http://v9fs.sf.net CVSweb: http://cvs.sourceforge.net/viewcvs.py/v9fs/linux-9p/ CVS: :pserver:anonymous@cvs.sourceforge.net:/cvsroot/v9fs/linux-9p Git: rsync://v9fs.graverobber.org/v9fs (webgit: http://v9fs.graverobber.org) 9P: tcp!v9fs.graverobber.org!6564 The user-level server is available from either the Plan 9 distribution or from http://v9fs.sf.net Other support applications are still being developed, but preliminary version can be downloaded from sourceforge. Documentation on the protocol has historically been the Plan 9 Man pages (http://plan9.bell-labs.com/sys/man/5/INDEX.html), but there is an effort under way to write a more complete Internet-Draft style specification (http://v9fs.sf.net/rfc). There are a couple of mailing lists supporting v9fs, but the most used is v9fs-developer@lists.sourceforge.net -- please direct/cc your comments there so the other v9fs contibutors can participate in the conversation. There is also an IRC channel: irc://freenode.net/#v9fs This part of the patch contains Documentation, Makefiles, and configuration file changes. Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
