path: root/fs/9p
2010-10-29convert v9fsAl Viro
2010-10-289p: Add datasync to client side TFSYNC/RFSYNC for dotlVenkateswararao Jujjuri (JV)
SYNOPSIS size[4] Tfsync tag[2] fid[4] datasync[4] size[4] Rfsync tag[2] DESCRIPTION The Tfsync transaction transfers ("flushes") all modified in-core data of file identified by fid to the disk device (or other permanent storage device) where that file resides. If datasync flag is specified data will be fleshed but does not flush modified metadata unless that metadata is needed in order to allow a subsequent data retrieval to be correctly handled. Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-10-28fs/9p: Use generic_file_open with lookup_instantiate_filpAneesh Kumar K.V
We need to do O_LARGEFILE check even in case of 9p. Use the generic_file_open helper Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-10-28fs/9p: Add missing iput in v9fs_vfs_lookupAneesh Kumar K.V
Make sure we drop inode reference in the error path Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-10-28fs/9p: Use mknod 9p operation on create without open requestAneesh Kumar K.V
A create without LOOKUP_OPEN flag set is due to mknod of regular files. Use mknod 9P operation for the same Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-10-289p: Implement TREADLINK operation for 9p2000.LM. Mohan Kumar
Synopsis size[4] TReadlink tag[2] fid[4] size[4] RReadlink tag[2] target[s] Description Readlink is used to return the contents of the symoblic link referred by fid. Contents of symboic link is returned as a response. target[s] - Contents of the symbolic link referred by fid. Signed-off-by: M. Mohan Kumar <mohan@in.ibm.com> Reviewed-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-10-289p: Use V9FS_MAGIC in statfsM. Mohan Kumar
Use V9FS_MAGIC as the file system type while filling kernel statfs strucutre instead of using host file system magic number. Also move the definition of V9FS_MAGIC from v9fs.h to standard magic.h file. Signed-off-by: M. Mohan Kumar <mohan@in.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-10-289p: Implement TGETLOCKM. Mohan Kumar
Synopsis size[4] TGetlock tag[2] fid[4] getlock[n] size[4] RGetlock tag[2] getlock[n] Description TGetlock is used to test for the existence of byte range posix locks on a file identified by given fid. The reply contains getlock structure. If the lock could be placed it returns F_UNLCK in type field of getlock structure. Otherwise it returns the details of the conflicting locks in the getlock structure getlock structure: type[1] - Type of lock: F_RDLCK, F_WRLCK start[8] - Starting offset for lock length[8] - Number of bytes to check for the lock If length is 0, check for lock in all bytes starting at the location 'start' through to the end of file pid[4] - PID of the process that wants to take lock/owns the task in case of reply client[4] - Client id of the system that owns the process which has the conflicting lock Signed-off-by: M. Mohan Kumar <mohan@in.ibm.com> Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-10-289p: Implement TLOCKM. Mohan Kumar
Synopsis size[4] TLock tag[2] fid[4] flock[n] size[4] RLock tag[2] status[1] Description Tlock is used to acquire/release byte range posix locks on a file identified by given fid. The reply contains status of the lock request flock structure: type[1] - Type of lock: F_RDLCK, F_WRLCK, F_UNLCK flags[4] - Flags could be either of P9_LOCK_FLAGS_BLOCK - Blocked lock request, if there is a conflicting lock exists, wait for that lock to be released. P9_LOCK_FLAGS_RECLAIM - Reclaim lock request, used when client is trying to reclaim a lock after a server restrart (due to crash) start[8] - Starting offset for lock length[8] - Number of bytes to lock If length is 0, lock all bytes starting at the location 'start' through to the end of file pid[4] - PID of the process that wants to take lock client_id[4] - Unique client id status[1] - Status of the lock request, can be P9_LOCK_SUCCESS(0), P9_LOCK_BLOCKED(1), P9_LOCK_ERROR(2) or P9_LOCK_GRACE(3) P9_LOCK_SUCCESS - Request was successful P9_LOCK_BLOCKED - A conflicting lock is held by another process P9_LOCK_ERROR - Error while processing the lock request P9_LOCK_GRACE - Server is in grace period, it can't accept new lock requests in this period (except locks with P9_LOCK_FLAGS_RECLAIM flag set) Signed-off-by: M. Mohan Kumar <mohan@in.ibm.com> Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-10-28[9p] Introduce client side TFSYNC/RFSYNC for dotl.Venkateswararao Jujjuri (JV)
SYNOPSIS size[4] Tfsync tag[2] fid[4] size[4] Rfsync tag[2] DESCRIPTION The Tfsync transaction transfers ("flushes") all modified in-core data of file identified by fid to the disk device (or other permanent storage device) where that file resides. Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-10-28[fs/9p] Add file_operations for cached mode in dotl protocol.Venkateswararao Jujjuri (JV)
2010-10-28fs/9p: Add access = client option to opt in acl evaluation.Aneesh Kumar K.V
2010-10-28fs/9p: Implement create time inheritanceAneesh Kumar K.V
Inherit default ACL on create Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-10-28fs/9p: Update ACL on chmodAneesh Kumar K.V
We need update the acl value on chmod Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-10-28fs/9p: Implement setting posix aclAneesh Kumar K.V
This patch also update mode bits, as a normal file system. I am not sure wether we should do that, considering that a setxattr on the server will again update the ACL/mode value Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-10-28fs/9p: Add xattr callbacks for POSIX ACLAneesh Kumar K.V
This patch implement fetching POSIX ACL from the server Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-10-28fs/9p: Implement POSIX ACL permission checking functionAneesh Kumar K.V
The ACL value is fetched as a part of inode initialization from the server and the permission checking function use the cached value of the ACL Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-10-28fs/9p: Remove the redundant rsize calculation in v9fs_file_write()jvrao
the same calculation is done in p9_client_write Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-10-289p: Add a Direct IO support for non-cached operations.jvrao
The presence of v9fs_direct_IO() in the address space ops vector allowes open() O_DIRECT flags which would have failed otherwise. In the non-cached mode, we shunt off direct read and write requests before the VFS gets them, so this method should never be called. Direct IO is not 'yet' supported in the cached mode. Hence when this routine is called through generic_file_aio_read(), the read/write fails with an error. Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-10-28fs/9p: mkdir fix for setting S_ISGID bit as per parent directoryHarsh Prateek Bora
The current implementation of 9p client mkdir function does not set the S_ISGID mode bit for the directory being created if the parent directory has this bit set. This patch fixes this problem so that the newly created directory inherits the gid from parent directory and not from the process creating this directory, when the S_ISGID bit is set in parent directory. Signed-off-by: Harsh Prateek Bora <harsh@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-10-289p: Pass the correct end of buffer to p9dirent_readSripathi Kodi
A patch was accepted recently for sending correct buffer size to p9stat_read. We need a similar patch in v9fs_dir_readdir_dotl to send correct end of buffer to p9dirent_read. Signed-off-by: Sripathi Kodi <sripathik@in.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-10-28fs/9p: setrlimit fix for 9p writeHarsh Prateek Bora
Current 9p client file write code does not check for RLIMIT_FSIZE resource. This bug was found by running LTP test case for setrlimit. This bug is fixed by calling generic_write_checks before sending the write request to the server. Without this patch: the write function is allowed to write above the RLIMIT_FSIZE set by user. With this patch: the write function checks for RLIMIT_SIZE and writes upto the size limit. Signed-off-by: Harsh Prateek Bora <harsh@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-10-289p: remove unneeded checksDan Carpenter
git_t is unsigned an can never be less than zero. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-10-25new helper: ihold()Al Viro
Clones an existing reference to inode; caller must already hold one. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-09-13fs/9p: Don't use dotl version of mknod for dotu inode operationsAneesh Kumar K.V
We should not use dotlversion for the dotu inode operations Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-09-13fs/9p: Use the correct dentry operationsAneesh Kumar K.V
We should use the cached dentry operation only if caching mode is enabled Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-09-139p: Check for NULL fid in v9fs_dir_release()jvrao
NULL fid should be handled in cases where we endup calling v9fs_dir_release() before even we instantiate the fid in filp. Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-09-13fs/9p: Fix error handling in v9fs_get_sbAneesh Kumar K.V
This was introduced by 7cadb63d58a932041afa3f957d5cbb6ce69dcee5 Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-09-13fs/9p, net/9p: memory leak fixesLatchesar Ionkov
Four memory leak fixes in the 9P code. Signed-off-by: Latchesar Ionkov <lucho@ionkov.net> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-08-309p: potential ERR_PTR() dereferenceDan Carpenter
p9_client_walk() can return error values if we run out of space or there is a problem with the network. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-08-11v9fs: fixup for inode_setattr being removedStephen Rothwell
Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-10Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (96 commits) no need for list_for_each_entry_safe()/resetting with superblock list Fix sget() race with failing mount vfs: don't hold s_umount over close_bdev_exclusive() call sysv: do not mark superblock dirty on remount sysv: do not mark superblock dirty on mount btrfs: remove junk sb_dirt change BFS: clean up the superblock usage AFFS: wait for sb synchronization when needed AFFS: clean up dirty flag usage cifs: truncate fallout mbcache: fix shrinker function return value mbcache: Remove unused features add f_flags to struct statfs(64) pass a struct path to vfs_statfs update VFS documentation for method changes. All filesystems that need invalidate_inode_buffers() are doing that explicitly convert remaining ->clear_inode() to ->evict_inode() Make ->drop_inode() just return whether inode needs to be dropped fs/inode.c:clear_inode() is gone fs/inode.c:evict() doesn't care about delete vs. non-delete paths now ... Fix up trivial conflicts in fs/nilfs2/super.c
2010-08-09convert remaining ->clear_inode() to ->evict_inode()Al Viro
2010-08-09remove inode_setattrChristoph Hellwig
Replace inode_setattr with opencoded variants of it in all callers. This moves the remaining call to vmtruncate into the filesystem methods where it can be replaced with the proper truncate sequence. In a few cases it was obvious that we would never end up calling vmtruncate so it was left out in the opencoded variant: spufs: explicitly checks for ATTR_SIZE earlier btrfs,hugetlbfs,logfs,dlmfs: explicitly clears ATTR_SIZE earlier ufs: contains an opencoded simple_seattr + truncate that sets the filesize just above In addition to that ncpfs called inode_setattr with handcrafted iattrs, which allowed to trim down the opencoded variant. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-029p: fix sparse warnings in new xattr codeEric Van Hensbergen
fixes: CHECK fs/9p/xattr.c fs/9p/xattr.c:73:6: warning: Using plain integer as NULL pointer fs/9p/xattr.c:135:6: warning: Using plain integer as NULL pointer Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-08-02fs/9p: remove sparse warning in vfs_inodeEric Van Hensbergen
make v9fs_dentry_from_dir_inode static Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-08-02fs/9p: Prevent parallel rename when doing fid_lookupAneesh Kumar K.V
During fid lookup we need to make sure that the dentry->d_parent doesn't change so that we can safely walk the parent dentries. To ensure that we need to prevent cross directory rename during fid_lookup. Add a per superblock rename_sem rw_semaphore to prevent parallel fid lookup and rename. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-08-02fs/9p: Add support user. xattrAneesh Kumar K.V
2010-08-029p: Implement LOPENM. Mohan Kumar
Implement 9p2000.L version of open(LOPEN) interface in 9p client. For LOPEN, no need to convert the flags to and from 9p mode to VFS mode. Synopsis: size[4] Tlopen tag[2] fid[4] mode[4] size[4] Rlopen tag[2] qid[13] iounit[4] [Fix mode bit format - jvrao@linux.vnet.ibm.com] Signed-off-by: M. Mohan Kumar <mohan@in.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbegren <ericvh@gmail.com>
2010-08-02fs/9p: This patch implements TLCREATE for 9p2000.L protocol.Venkateswararao Jujjuri (JV)
SYNOPSIS size[4] Tlcreate tag[2] fid[4] name[s] flags[4] mode[4] gid[4] size[4] Rlcreate tag[2] qid[13] iounit[4] DESCRIPTION The Tlreate request asks the file server to create a new regular file with the name supplied, in the directory (dir) represented by fid. The mode argument specifies the permissions to use. New file is created with the uid if the fid and with supplied gid. The flags argument represent Linux access mode flags with which the caller is requesting to open the file with. Protocol allows all the Linux access modes but it is upto the server to allow/disallow any of these acess modes. If the server doesn't support any of the access mode, it is expected to return error. Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-08-029p: Implement TMKDIRM. Mohan Kumar
Implement TMKDIR as part of 2000.L Work Synopsis size[4] Tmkdir tag[2] fid[4] name[s] mode[4] gid[4] size[4] Rmkdir tag[2] qid[13] Description mkdir asks the file server to create a directory with given name, mode and gid. The qid for the new directory is returned with the mkdir reply message. Note: 72 is selected as the opcode for TMKDIR from the reserved list. Signed-off-by: M. Mohan Kumar <mohan@in.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-08-029p: Implement TMKNODM. Mohan Kumar
Synopsis size[4] Tmknod tag[2] fid[4] name[s] mode[4] major[4] minor[4] gid[4] size[4] Rmknod tag[2] qid[13] Description mknod asks the file server to create a device node with given major and minor number, mode and gid. The qid for the new device node is returned with the mknod reply message. [sripathik@in.ibm.com: Fix error handling code] Signed-off-by: M. Mohan Kumar <mohan@in.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-08-029p: Define and implement TSYMLINK for 9P2000.LVenkateswararao Jujjuri (JV)
Create a symbolic link SYNOPSIS size[4] Tsymlink tag[2] fid[4] name[s] symtgt[s] gid[4] size[4] Rsymlink tag[2] qid[13] DESCRIPTION Create a symbolic link named 'name' pointing to 'symtgt'. gid represents the effective group id of the caller. The permissions of a symbolic link are irrelevant hence it is omitted from the protocol. Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Reviewed-by: Sripathi Kodi <sripathik@in.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-08-029p: Define and implement TLINK for 9P2000.LEric Van Hensbergen
This patch adds a helper function to get the dentry from inode and uses it in creating a Hardlink SYNOPSIS size[4] Tlink tag[2] dfid[4] oldfid[4] newpath[s] size[4] Rlink tag[2] DESCRIPTION Create a link 'newpath' in directory pointed by dfid linking to oldfid path. [sripathik@in.ibm.com : p9_client_link should not free req structure if p9_client_rpc has returned an error.] Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-08-029p: Implement client side of setattr for 9P2000.L protocol.Sripathi Kodi
SYNOPSIS size[4] Tsetattr tag[2] attr[n] size[4] Rsetattr tag[2] DESCRIPTION The setattr command changes some of the file status information. attr resembles the iattr structure used in Linux kernel. It specifies which status parameter is to be changed and to what value. It is laid out as follows: valid[4] specifies which status information is to be changed. Possible values are: ATTR_MODE (1 << 0) ATTR_UID (1 << 1) ATTR_GID (1 << 2) ATTR_SIZE (1 << 3) ATTR_ATIME (1 << 4) ATTR_MTIME (1 << 5) ATTR_ATIME_SET (1 << 7) ATTR_MTIME_SET (1 << 8) The last two bits represent whether the time information is being sent by the client's user space. In the absense of these bits the server always uses server's time. mode[4] File permission bits uid[4] Owner id of file gid[4] Group id of the file size[8] File size atime_sec[8] Time of last file access, seconds atime_nsec[8] Time of last file access, nanoseconds mtime_sec[8] Time of last file modification, seconds mtime_nsec[8] Time of last file modification, nanoseconds Explanation of the patches: -------------------------- *) The kernel just copies relevent contents of iattr structure to p9_iattr_dotl structure and passes it down to the client. The only check it has is calling inode_change_ok() *) The p9_iattr_dotl structure does not have ctime and ia_file parameters because I don't think these are needed in our case. The client user space can request updating just ctime by calling chown(fd, -1, -1). This is handled on server side without a need for putting ctime on the wire. *) The server currently supports changing mode, time, ownership and size of the file. *) 9P RFC says "Either all the changes in wstat request happen, or none of them does: if the request succeeds, all changes were made; if it fails, none were." I have not done anything to implement this specifically because I don't see a reason. Signed-off-by: Sripathi Kodi <sripathik@in.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-08-029p: getattr client implementation for 9P2000.L protocol.Sripathi Kodi
SYNOPSIS size[4] Tgetattr tag[2] fid[4] request_mask[8] size[4] Rgetattr tag[2] lstat[n] DESCRIPTION The getattr transaction inquires about the file identified by fid. request_mask is a bit mask that specifies which fields of the stat structure is the client interested in. The reply will contain a machine-independent directory entry, laid out as follows: st_result_mask[8] Bit mask that indicates which fields in the stat structure have been populated by the server qid.type[1] the type of the file (directory, etc.), represented as a bit vector corresponding to the high 8 bits of the file's mode word. qid.vers[4] version number for given path qid.path[8] the file server's unique identification for the file st_mode[4] Permission and flags st_uid[4] User id of owner st_gid[4] Group ID of owner st_nlink[8] Number of hard links st_rdev[8] Device ID (if special file) st_size[8] Size, in bytes st_blksize[8] Block size for file system IO st_blocks[8] Number of file system blocks allocated st_atime_sec[8] Time of last access, seconds st_atime_nsec[8] Time of last access, nanoseconds st_mtime_sec[8] Time of last modification, seconds st_mtime_nsec[8] Time of last modification, nanoseconds st_ctime_sec[8] Time of last status change, seconds st_ctime_nsec[8] Time of last status change, nanoseconds st_btime_sec[8] Time of creation (birth) of file, seconds st_btime_nsec[8] Time of creation (birth) of file, nanoseconds st_gen[8] Inode generation st_data_version[8] Data version number request_mask and result_mask bit masks contain the following bits #define P9_STATS_MODE 0x00000001ULL #define P9_STATS_NLINK 0x00000002ULL #define P9_STATS_UID 0x00000004ULL #define P9_STATS_GID 0x00000008ULL #define P9_STATS_RDEV 0x00000010ULL #define P9_STATS_ATIME 0x00000020ULL #define P9_STATS_MTIME 0x00000040ULL #define P9_STATS_CTIME 0x00000080ULL #define P9_STATS_INO 0x00000100ULL #define P9_STATS_SIZE 0x00000200ULL #define P9_STATS_BLOCKS 0x00000400ULL #define P9_STATS_BTIME 0x00000800ULL #define P9_STATS_GEN 0x00001000ULL #define P9_STATS_DATA_VERSION 0x00002000ULL #define P9_STATS_BASIC 0x000007ffULL #define P9_STATS_ALL 0x00003fffULL This patch implements the client side of getattr implementation for 9P2000.L. It introduces a new structure p9_stat_dotl for getting Linux stat information along with QID. The data layout is similar to stat structure in Linux user space with the following major differences: inode (st_ino) is not part of data. Instead qid is. device (st_dev) is not part of data because this doesn't make sense on the client. All time variables are 64 bit wide on the wire. The kernel seems to use 32 bit variables for these variables. However, some of the architectures have used 64 bit variables and glibc exposes 64 bit variables to user space on some architectures. Hence to be on the safer side we have made these 64 bit in the protocol. Refer to the comments in include/asm-generic/stat.h There are some additional fields: st_btime_sec, st_btime_nsec, st_gen, st_data_version apart from the bitmask, st_result_mask. The bit mask is filled by the server to indicate which stat fields have been populated by the server. Currently there is no clean way for the server to obtain these additional fields, so it sends back just the basic fields. Signed-off-by: Sripathi Kodi <sripathik@in.ibm.com> Signed-off-by: Eric Van Hensbegren <ericvh@gmail.com>
2010-08-02fs/9p: Pass the correct user credentials during attachAneesh Kumar K.V
We need to make sure we pass the right uid value during attach. dotl is similar to dotu in this regard. Without this mapped security model on dotl doesn't work Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-08-029p: readdir implementation for 9p2000.LSripathi Kodi
This patch implements the kernel part of readdir() implementation for 9p2000.L Change from V3: Instead of inode, server now sends qids for each dirent SYNOPSIS size[4] Treaddir tag[2] fid[4] offset[8] count[4] size[4] Rreaddir tag[2] count[4] data[count] DESCRIPTION The readdir request asks the server to read the directory specified by 'fid' at an offset specified by 'offset' and return as many dirent structures as possible that fit into count bytes. Each dirent structure is laid out as follows. qid.type[1] the type of the file (directory, etc.), represented as a bit vector corresponding to the high 8 bits of the file's mode word. qid.vers[4] version number for given path qid.path[8] the file server's unique identification for the file offset[8] offset into the next dirent. type[1] type of this directory entry. name[256] name of this directory entry. This patch adds v9fs_dir_readdir_dotl() as the readdir() call for 9p2000.L. This function sends P9_TREADDIR command to the server. In response the server sends a buffer filled with dirent structures. This is different from the existing v9fs_dir_readdir() call which receives stat structures from the server. This results in significant speedup of readdir() on large directories. For example, doing 'ls >/dev/null' on a directory with 10000 files on my laptop takes 1.088 seconds with the existing code, but only takes 0.339 seconds with the new readdir. Signed-off-by: Sripathi Kodi <sripathik@in.ibm.com> Reviewed-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-08-029p: Make use of iounit for read/writeM. Mohan Kumar
Change the v9fs_file_readn function to limit the maximum transfer size based on the iounit or msize. Also remove the redundant check for limiting the transfer size in v9fs_file_write. This check is done by p9_client_write. Signed-off-by: M. Mohan Kumar <mohan@in.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-07-279p: Pass the correct end of buffer to p9stat_readLatchesar Ionkov
Pass the correct end of the buffer to p9stat_read. Signed-off-by: Latchesar Ionkov <lucho@ionkov.net> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
