Remove v9fs_vfs_readlink_dotl function and use generic_readlink. Update
v9fs_vfs_follow_link_dotl function to accommodate this change
Signed-off-by: M. Mohan Kumar <mohan@in.ibm.com>
Reported-by: Dr. David Alan Gilbert <linux@treblig.org>
Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com>
Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Source Code Reorganization
Make the 9P_FS kconfig options subordinate to the 9P_FS kconfig symbol
in the menu presentation instead of them all being at the same level.
If we don't have default ACL, then trying to remove
default acl on a file should return 0.
dcache_inode_lock can be replaced with per-inode locking. Use existing
inode->i_lock for this. This is slightly non-trivial because we sometimes
need to find the inode from the dentry, which requires d_inode to be
stabilised (either with refcount or d_lock).
Signed-off-by: Nick Piggin <npiggin@kernel.dk>
Reduce some branches and memory accesses in dcache lookup by adding dentry
flags to indicate common d_ops are set, rather than having to check them.
This saves a pointer memory access (dentry->d_op) in common path lookup
situations, and saves another pointer load and branch in cases where we
have d_op but not the particular operation.
Patched with:
git grep -E '[.>]([[:space:]])*d_op([[:space:]])*=' | xargs sed -e 's/\([^\t ]*\)->d_op = \(.*\);/d_set_d_op(\1, \2);/' -e 's/\([^\t ]*\)\.d_op = \(.*\);/d_set_d_op(\&\1, \2);/' -i
RCU free the struct inode. This will allow:
- Subsequent store-free path walking patch. The inode must be consulted for
permissions when walking, so an RCU inode reference is a must.
- sb_inode_list_lock to be moved inside i_lock because sb list walkers who want
to take i_lock no longer need to take sb_inode_list_lock to walk the list in
the first place. This will simplify and optimize locking.
- Could remove some nested trylock loops in dcache code
- Could potentially simplify things a bit in VM land. Do not need to take the
page lock to follow page->mapping.
The downsides of this is the performance cost of using RCU. In a simple
creat/unlink microbenchmark, performance drops by about 10% due to inability to
reuse cache-hot slab objects. As iterations increase and RCU freeing starts
kicking over, this increases to about 20%.
In cases where inode lifetimes are longer (ie. many inodes may be allocated
during the average life span of a single inode), a lot of this cache reuse is
not applicable, so the regression caused by this patch is smaller.
The cache-hot regression could largely be avoided by using SLAB_DESTROY_BY_RCU,
however this adds some complexity to list walking and store-free path walking,
so I prefer to implement this at a later date, if it is shown to be a win in
real situations. I haven't found a regression in any non-micro benchmark so I
doubt it will be a problem.
dcache_lock no longer protects anything. remove it.
Add a new lock, dcache_inode_lock, to protect the inode's i_dentry list
from concurrent modification. d_alias is also protected by d_lock.
Change d_delete from a dentry deletion notification to a dentry caching
advise, more like ->drop_inode. Require it to be constant and idempotent,
and not take d_lock. This is how all existing filesystems use the callback
anyway.
This makes fine grained dentry locking of dput and dentry lru scanning
much simpler.
SYNOPSIS
size[4] Tfsync tag[2] fid[4] datasync[4]
size[4] Rfsync tag[2]
DESCRIPTION
The Tfsync transaction transfers ("flushes") all modified in-core data of
file identified by fid to the disk device (or other permanent storage
device) where that file resides.
If datasync flag is specified data will be fleshed but does not flush
modified metadata unless that metadata is needed in order to allow a
subsequent data retrieval to be correctly handled.
We need to do O_LARGEFILE check even in case of 9p. Use the
generic_file_open helper
Make sure we drop inode reference in the error path
A create without LOOKUP_OPEN flag set is due to mknod of regular
files. Use mknod 9P operation for the same
Synopsis
size[4] TReadlink tag[2] fid[4]
size[4] RReadlink tag[2] target[s]
Description
Readlink is used to return the contents of the symoblic link
referred by fid. Contents of symboic link is returned as a
response.
target[s] - Contents of the symbolic link referred by fid.
Reviewed-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Use V9FS_MAGIC as the file system type while filling kernel statfs
strucutre instead of using host file system magic number. Also move
the definition of V9FS_MAGIC from v9fs.h to standard magic.h file.
Synopsis
size[4] TGetlock tag[2] fid[4] getlock[n]
size[4] RGetlock tag[2] getlock[n]
Description
TGetlock is used to test for the existence of byte range posix locks on a file
identified by given fid. The reply contains getlock structure. If the lock could
be placed it returns F_UNLCK in type field of getlock structure. Otherwise it
returns the details of the conflicting locks in the getlock structure
getlock structure:
type[1] - Type of lock: F_RDLCK, F_WRLCK
start[8] - Starting offset for lock
length[8] - Number of bytes to check for the lock
If length is 0, check for lock in all bytes starting at the location
'start' through to the end of file
pid[4] - PID of the process that wants to take lock/owns the task
in case of reply
client[4] - Client id of the system that owns the process which
has the conflicting lock
Synopsis
size[4] TLock tag[2] fid[4] flock[n]
size[4] RLock tag[2] status[1]
Description
Tlock is used to acquire/release byte range posix locks on a file
identified by given fid. The reply contains status of the lock request
flock structure:
type[1] - Type of lock: F_RDLCK, F_WRLCK, F_UNLCK
flags[4] - Flags could be either of
P9_LOCK_FLAGS_BLOCK - Blocked lock request, if there is a
conflicting lock exists, wait for that lock to be released.
P9_LOCK_FLAGS_RECLAIM - Reclaim lock request, used when client is
trying to reclaim a lock after a server restrart (due to crash)
length[8] - Number of bytes to lock
If length is 0, lock all bytes starting at the location 'start'
client_id[4] - Unique client id
status[1] - Status of the lock request, can be
P9_LOCK_SUCCESS(0), P9_LOCK_BLOCKED(1), P9_LOCK_ERROR(2) or
P9_LOCK_GRACE(3)
P9_LOCK_SUCCESS - Request was successful
P9_LOCK_BLOCKED - A conflicting lock is held by another process
P9_LOCK_ERROR - Error while processing the lock request
P9_LOCK_GRACE - Server is in grace period, it can't accept new lock
requests in this period (except locks with
P9_LOCK_FLAGS_RECLAIM flag set)
SYNOPSIS
DESCRIPTION
Inherit default ACL on create
We need update the acl value on chmod
This patch also update mode bits, as a normal file system.
I am not sure wether we should do that, considering that
a setxattr on the server will again update the ACL/mode value
This patch implement fetching POSIX ACL from the server
The ACL value is fetched as a part of inode initialization
from the server and the permission checking function use the
cached value of the ACL
the same calculation is done in p9_client_write
Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com>
The presence of v9fs_direct_IO() in the address space ops vector
allowes open() O_DIRECT flags which would have failed otherwise.
In the non-cached mode, we shunt off direct read and write requests before
the VFS gets them, so this method should never be called.
Direct IO is not 'yet' supported in the cached mode. Hence when
this routine is called through generic_file_aio_read(), the read/write fails
with an error.
The current implementation of 9p client mkdir function does not
set the S_ISGID mode bit for the directory being created if the
parent directory has this bit set. This patch fixes this problem
so that the newly created directory inherits the gid from parent
directory and not from the process creating this directory, when
the S_ISGID bit is set in parent directory.
Signed-off-by: Harsh Prateek Bora <harsh@linux.vnet.ibm.com>
A patch was accepted recently for sending correct buffer size to p9stat_read.
We need a similar patch in v9fs_dir_readdir_dotl to send correct end of buffer
to p9dirent_read.
Signed-off-by: Sripathi Kodi <sripathik@in.ibm.com>
Current 9p client file write code does not check for RLIMIT_FSIZE resource.
This bug was found by running LTP test case for setrlimit. This bug is fixed
by calling generic_write_checks before sending the write request to the
server.
Without this patch: the write function is allowed to write above the
RLIMIT_FSIZE set by user.
With this patch: the write function checks for RLIMIT_SIZE and writes upto
the size limit.
git_t is unsigned an can never be less than zero.
Clones an existing reference to inode; caller must already hold one.
We should not use dotlversion for the dotu inode operations
We should use the cached dentry operation only if caching mode is enabled
NULL fid should be handled in cases where we endup calling v9fs_dir_release()
before even we instantiate the fid in filp.
This was introduced by 7cadb63d58a932041afa3f957d5cbb6ce69dcee5
Four memory leak fixes in the 9P code.
Signed-off-by: Latchesar Ionkov <lucho@ionkov.net>
p9_client_walk() can return error values if we run out of space or there
is a problem with the network.
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (96 commits)
no need for list_for_each_entry_safe()/resetting with superblock list
Fix sget() race with failing mount
vfs: don't hold s_umount over close_bdev_exclusive() call
sysv: do not mark superblock dirty on remount
sysv: do not mark superblock dirty on mount
btrfs: remove junk sb_dirt change
BFS: clean up the superblock usage
AFFS: wait for sb synchronization when needed
AFFS: clean up dirty flag usage
cifs: truncate fallout
mbcache: fix shrinker function return value
mbcache: Remove unused features
add f_flags to struct statfs(64)
pass a struct path to vfs_statfs
update VFS documentation for method changes.
All filesystems that need invalidate_inode_buffers() are doing that explicitly
convert remaining ->clear_inode() to ->evict_inode()
Make ->drop_inode() just return whether inode needs to be dropped
fs/inode.c:clear_inode() is gone
fs/inode.c:evict() doesn't care about delete vs. non-delete paths now
Fix up trivial conflicts in fs/nilfs2/super.c
Replace inode_setattr with opencoded variants of it in all callers. This
moves the remaining call to vmtruncate into the filesystem methods where it
can be replaced with the proper truncate sequence.
In a few cases it was obvious that we would never end up calling vmtruncate
so it was left out in the opencoded variant:
spufs: explicitly checks for ATTR_SIZE earlier
btrfs,hugetlbfs,logfs,dlmfs: explicitly clears ATTR_SIZE earlier
ufs: contains an opencoded simple_seattr + truncate that sets the filesize just above
In addition to that ncpfs called inode_setattr with handcrafted iattrs,
which allowed to trim down the opencoded variant.
fixes:
CHECK fs/9p/xattr.c
fs/9p/xattr.c:73:6: warning: Using plain integer as NULL pointer
fs/9p/xattr.c:135:6: warning: Using plain integer as NULL pointer
make v9fs_dentry_from_dir_inode static
During fid lookup we need to make sure that the dentry->d_parent doesn't
change so that we can safely walk the parent dentries. To ensure that
we need to prevent cross directory rename during fid_lookup. Add a
per superblock rename_sem rw_semaphore to prevent parallel fid lookup and
rename.
