[ Upstream commit c87a37ebd40b889178664c2c09cc187334146292 ]
Currently on mmap cache policy, we always attach writeback_fid
whether mmap type is SHARED or PRIVATE. However, in the use case
of kata-container which combines 9p(Guest OS) with overlayfs(Host OS),
this behavior will trigger overlayfs' copy-up when excute command
inside container.
Link: http://lkml.kernel.org/r/20190820100325.10313-1-cgxu519@zoho.com.cn
Signed-off-by: Chengguang Xu <cgxu519@zoho.com.cn>
Signed-off-by: Dominique Martinet <dominique.martinet@cea.fr>
[ Upstream commit f053cbd4366051d7eb6ba1b8d529d20f719c2963 ]
Fix the callback 9p passes to read_cache_page to actually have the
proper type expected. Casting around function pointers can easily
hide typing bugs, and defeats control flow protection.
Link: http://lkml.kernel.org/r/20190520055731.24538-5-hch@lst.de
Cc: Sami Tolvanen <samitolvanen@google.com>
Cc: Nick Desaulniers <ndesaulniers@google.com>
[ Upstream commit e02a53d92e197706cad1627bd84705d4aa20a145 ]
iattr is passed to v9fs_vfs_setattr_dotl which does send various
values from iattr over the wire, even if it tells the server to
only look at iattr.ia_valid fields this could leak some stack data.
Link: http://lkml.kernel.org/r/1536339057-21974-2-git-send-email-asmadeus@codewreck.org
Addresses-Coverity-ID: 1195601 ("Uninitalized scalar variable")
[ Upstream commit 5e172f75e51e3de1b4274146d9b990f803cb5c2a ]
The default P9_LOCK_TIMEOUT can be too long for some users exporting
a local file system to a guest VM (30s), make this configurable at
mount time.
Link: http://lkml.kernel.org/r/1536295827-3181-1-git-send-email-asmadeus@codewreck.org
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=195727
Signed-off-by: Dinu-Razvan Chis-Serban <justcsdr@gmail.com>
[ Upstream commit 2803cf4379ed252894f046cb8812a48db35294e3 ]
v9fs_dir_readdir() could deadloop if a struct was sent with a size set
to -2
Link: http://lkml.kernel.org/r/1536134432-11997-1-git-send-email-asmadeus@codewreck.org
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=88021
Signed-off-by: Gertjan Halkes <gertjan@google.com>
commit 5e3cc1ee1405a7eb3487ed24f786dec01b4cbe1f upstream.
Use inode->i_lock to protect i_size_write(), else i_size_read() in
generic_fillattr() may loop infinitely in read_seqcount_begin() when
multiple processes invoke v9fs_vfs_getattr() or v9fs_vfs_getattr_dotl()
simultaneously under 32-bit SMP environment, and a soft lockup will be
triggered as show below:
watchdog: BUG: soft lockup - CPU#5 stuck for 22s! [stat:2217]
Modules linked in:
CPU: 5 PID: 2217 Comm: stat Not tainted 5.0.0-rc1-00005-g7f702faf5a9e #4
Hardware name: Generic DT based system
PC is at generic_fillattr+0x104/0x108
LR is at 0xec497f00
pc : [<802b8898>] lr : [<ec497f00>] psr: 200c0013
sp : ec497e20 ip : ed608030 fp : ec497e3c
r10: 00000000 r9 : ec497f00 r8 : ed608030
r7 : ec497ebc r6 : ec497f00 r5 : ee5c1550 r4 : ee005780
r3 : 0000052d r2 : 00000000 r1 : ec497f00 r0 : ed608030
Flags: nzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment none
Control: 10c5387d Table: ac48006a DAC: 00000051
Backtrace:
[<8010d974>] (dump_backtrace) from [<8010dc88>] (show_stack+0x20/0x24)
[<8010dc68>] (show_stack) from [<80a1d194>] (dump_stack+0xb0/0xdc)
[<80a1d0e4>] (dump_stack) from [<80109f34>] (show_regs+0x1c/0x20)
[<80109f18>] (show_regs) from [<801d0a80>] (watchdog_timer_fn+0x280/0x2f8)
[<801d0800>] (watchdog_timer_fn) from [<80198658>] (__hrtimer_run_queues+0x18c/0x380)
[<801984cc>] (__hrtimer_run_queues) from [<80198e60>] (hrtimer_run_queues+0xb8/0xf0)
[<80198da8>] (hrtimer_run_queues) from [<801973e8>] (run_local_timers+0x28/0x64)
[<801973c0>] (run_local_timers) from [<80197460>] (update_process_times+0x3c/0x6c)
[<80197424>] (update_process_times) from [<801ab2b8>] (tick_nohz_handler+0xe0/0x1bc)
[<801ab1d8>] (tick_nohz_handler) from [<80843050>] (arch_timer_handler_virt+0x38/0x48)
[<80843018>] (arch_timer_handler_virt) from [<80180a64>] (handle_percpu_devid_irq+0x8c/0x240)
[<801809d8>] (handle_percpu_devid_irq) from [<8017ac20>] (generic_handle_irq+0x34/0x44)
[<8017abec>] (generic_handle_irq) from [<8017b344>] (__handle_domain_irq+0x6c/0xc4)
[<8017b2d8>] (__handle_domain_irq) from [<801022e0>] (gic_handle_irq+0x4c/0x88)
[<80102294>] (gic_handle_irq) from [<80101a30>] (__irq_svc+0x70/0x98)
[<802b8794>] (generic_fillattr) from [<8056b284>] (v9fs_vfs_getattr_dotl+0x74/0xa4)
[<8056b210>] (v9fs_vfs_getattr_dotl) from [<802b8904>] (vfs_getattr_nosec+0x68/0x7c)
[<802b889c>] (vfs_getattr_nosec) from [<802b895c>] (vfs_getattr+0x44/0x48)
[<802b8918>] (vfs_getattr) from [<802b8a74>] (vfs_statx+0x9c/0xec)
[<802b89d8>] (vfs_statx) from [<802b9428>] (sys_lstat64+0x48/0x78)
[<802b93e0>] (sys_lstat64) from [<80101000>] (ret_fast_syscall+0x0/0x28)
[dominique.martinet@cea.fr: updated comment to not refer to a function
in another subsystem]
Link: http://lkml.kernel.org/r/20190124063514.8571-2-houtao1@huawei.com
Cc: stable@vger.kernel.org
Fixes: 7549ae3e81cc ("9p: Use the i_size_[read, write]() macros instead of using inode->i_size directly.")
Reported-by: Xing Gaopeng <xingaopeng@huawei.com>
Signed-off-by: Hou Tao <houtao1@huawei.com>
commit 81c99089bce693b94b775b6eb888115d2d540086 upstream.
p9stat_read will call p9stat_free on error, we should only free the
struct content on success.
There also is no need to "p9stat_init" st as the read function will
zero the whole struct for us anyway, so clean up the code a bit while
we are here.
Link: http://lkml.kernel.org/r/1535410108-20650-1-git-send-email-asmadeus@codewreck.org
Reported-by: syzbot+d4252148d198410b864f@syzkaller.appspotmail.com
[ Upstream commit b4dc44b3cac9e8327e0655f530ed0c46f2e6214c ]
the 9p client code overwrites our glock.client_id pointing to a static
buffer by an allocated string holding the network provided value which
we do not care about; free and reset the value as appropriate.
This is almost identical to the leak in v9fs_file_getlock() fixed by
Al Viro in commit ce85dd58ad5a6 ("9p: we are leaking glock.client_id
in v9fs_file_getlock()"), which was returned as an error by a coverity
false positive -- while we are here attempt to make the code slightly
more robust to future change of the net/9p/client code and hopefully
more clear to coverity that there is no problem.
Link: http://lkml.kernel.org/r/1536339057-21974-5-git-send-email-asmadeus@codewreck.org
commit 3111784bee81591ea2815011688d28b65df03627 upstream.
In my testing, v9fs_fid_xattr_set will return successfully even if the
backend ext4 filesystem has no space to store xattr key-value. That will
cause inconsistent behavior between front end and back end. The reason is
that lsetxattr will be triggered by p9_client_clunk, and unfortunately we
did not catch the error. This patch will catch the error to notify upper
caller.
p9_client_clunk (in 9p)
p9_client_rpc(clnt, P9_TCLUNK, "d", fid->fid);
v9fs_clunk (in qemu)
put_fid
free_fid
v9fs_xattr_fid_clunk
v9fs_co_lsetxattr
s->ops->lsetxattr
ext4_xattr_user_set (in host ext4 filesystem)
Link: http://lkml.kernel.org/r/5B57EACC.2060900@huawei.com
Signed-off-by: Jun Piao <piaojun@huawei.com>
Cc: Eric Van Hensbergen <ericvh@gmail.com>
Cc: Ron Minnich <rminnich@sandia.gov>
Cc: Latchesar Ionkov <lucho@ionkov.net>
commit 8ee031631546cf2f7859cc69593bd60bbdd70b46 upstream.
Commit fd2421f54423 ("fs/9p: When doing inode lookup compare qid details
and inode mode bits.") transformed v9fs_qid_iget() to use iget5_locked()
instead of iget_locked(). However, the test() callback is not checking
fid.path at all, which means that a lookup in the inode cache can now
accidentally locate a completely wrong inode from the same inode hash
bucket if the other fields (qid.type and qid.version) match.
Fixes: fd2421f54423 ("fs/9p: When doing inode lookup compare qid details and inode mode bits.")
Reviewed-by: Latchesar Ionkov <lucho@ionkov.net>
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
Commit 77469c3f570 prevented setting the page as uptodate when we wrote
the right amount of data, fix that.
Fixes: 77469c3f570 ("9p: saner ->write_end() on failing copy into non-uptodate page")
Reviewed-by: Jan Kara <jack@suse.com>
Signed-off-by: Alexander Levin <alexander.levin@verizon.com>
Merge updates from Andrew Morton:
- various misc bits
- DAX updates
- OCFS2
- most of MM
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (119 commits)
mm,fork: introduce MADV_WIPEONFORK
x86,mpx: make mpx depend on x86-64 to free up VMA flag
mm: add /proc/pid/smaps_rollup
mm: hugetlb: clear target sub-page last when clearing huge page
mm: oom: let oom_reap_task and exit_mmap run concurrently
swap: choose swap device according to numa node
mm: replace TIF_MEMDIE checks by tsk_is_oom_victim
mm, oom: do not rely on TIF_MEMDIE for memory reserves access
z3fold: use per-cpu unbuddied lists
mm, swap: don't use VMA based swap readahead if HDD is used as swap
mm, swap: add sysfs interface for VMA based swap readahead
mm, swap: VMA based swap readahead
mm, swap: fix swap readahead marking
mm, swap: add swap readahead hit statistics
mm/vmalloc.c: don't reinvent the wheel but use existing llist API
mm/vmstat.c: fix wrong comment
selftests/memfd: add memfd_create hugetlbfs selftest
mm/shmem: add hugetlbfs support to memfd_create()
mm, devm_memremap_pages: use multi-order radix for ZONE_DEVICE lookups
mm/vmalloc.c: halve the number of comparisons performed in pcpu_get_vm_areas()
Patch series "Ranged pagevec lookup", v2.
In this series I make pagevec_lookup() update the index (to be
consistent with pagevec_lookup_tag() and also as a preparation for
ranged lookups), provide ranged variant of pagevec_lookup() and use it
in places where it makes sense. This not only removes some common code
but is also a measurable performance win for some use cases (see patch
4/10) where radix tree is sparse and searching & grabing of a page after
the end of the range has measurable overhead.
This patch (of 10):
The callback doesn't ever get called. Remove it.
Link: http://lkml.kernel.org/r/20170726114704.7626-2-jack@suse.cz
git://git.kernel.org/pub/scm/linux/kernel/git/jlayton/linux
Pull writeback error handling updates from Jeff Layton:
"This pile continues the work from last cycle on better tracking
writeback errors. In v4.13 we added some basic errseq_t infrastructure
and converted a few filesystems to use it.
This set continues refining that infrastructure, adds documentation,
and converts most of the other filesystems to use it. The main
exception at this point is the NFS client"
* tag 'wberr-v4.14-1' of git://git.kernel.org/pub/scm/linux/kernel/git/jlayton/linux:
ecryptfs: convert to file_write_and_wait in ->fsync
mm: remove optimizations based on i_size in mapping writeback waits
fs: convert a pile of fsync routines to errseq_t based reporting
gfs2: convert to errseq_t based writeback error reporting for fsync
fs: convert sync_file_range to use errseq_t based error-tracking
mm: add file_fdatawait_range and file_write_and_wait
fuse: convert to errseq_t based error tracking for fsync
mm: consolidate dax / non-dax checks for writeback
Documentation: add some docs for errseq_t
errseq: rename __errseq_set to errseq_set
This patch converts most of the in-kernel filesystems that do writeback
out of the pagecache to report errors using the errseq_t-based
infrastructure that was recently added. This allows them to report
errors once for each open file description.
Most filesystems have a fairly straightforward fsync operation. They
call filemap_write_and_wait_range to write back all of the data and
wait on it, and then (sometimes) sync out the metadata.
For those filesystems this is a straightforward conversion from calling
filemap_write_and_wait_range in their fsync operation to calling
file_write_and_wait_range.
Acked-by: Jan Kara <jack@suse.cz>
Acked-by: Dave Kleikamp <dave.kleikamp@oracle.com>
Signed-off-by: Jeff Layton <jlayton@redhat.com>
Since commit c69899a17ca4 "NFSv4: Update of VFS byte range lock must be
atomic with the stateid update", NFSv4 has been inserting locks in rpciod
worker context. The result is that the file_lock's fl_nspid is the
kworker's pid instead of the original userspace pid.
The fl_nspid is only used to represent the namespaced virtual pid number
when displaying locks or returning from F_GETLK. There's no reason to set
it for every inserted lock, since we can usually just look it up from
fl_pid. So, instead of looking up and holding struct pid for every lock,
let's just look up the virtual pid number from fl_pid when it is needed.
That means we can remove fl_nspid entirely.
The translaton and presentation of fl_pid should handle the following four
cases:
1 - F_GETLK on a remote file with a remote lock:
In this case, the filesystem should determine the l_pid to return here.
Filesystems should indicate that the fl_pid represents a non-local pid
value that should not be translated by returning an fl_pid <= 0.
2 - F_GETLK on a local file with a remote lock:
This should be the l_pid of the lock manager process, and translated.
3 - F_GETLK on a remote file with a local lock, and
4 - F_GETLK on a local file with a local lock:
These should be the translated l_pid of the local locking process.
Fuse was already doing the correct thing by translating the pid into the
caller's namespace. With this change we must update fuse to translate
to init's pid namespace, so that the locks API can then translate from
init's pid namespace into the pid namespace of the caller.
With this change, the locks API will expect that if a filesystem returns
a remote pid as opposed to a local pid for F_GETLK, that remote pid will
be <= 0. This signifies that the pid is remote, and the locks API will
forego translating that pid into the pid namespace of the local calling
process.
Finally, we convert remote filesystems to present remote pids using
negative numbers. Have lustre, 9p, ceph, cifs, and dlm negate the remote
pid returned for F_GETLK lock requests.
Since local pids will never be larger than PID_MAX_LIMIT (which is
currently defined as <= 4 million), but pid_t is an unsigned int, we
should have plenty of room to represent remote pids with negative
numbers if we assume that remote pid numbers are similarly limited.
If this is not the case, then we run the risk of having a remote pid
returned for which there is also a corresponding local pid. This is a
problem we have now, but this patch should reduce the chances of that
occurring, while also returning those remote pid numbers, for whatever
that may be worth.
Signed-off-by: Benjamin Coddington <bcodding@redhat.com>
Implement the show_options superblock op for 9p as part of a bid to get
rid of s_options and generic_show_options() to make it easier to implement
a context-based mount where the mount options can be passed individually
over a file descriptor.
cc: Eric Van Hensbergen <ericvh@gmail.com>
cc: Ron Minnich <rminnich@sandia.gov>
cc: Latchesar Ionkov <lucho@ionkov.net>
cc: v9fs-developer@lists.sourceforge.net
Allocate struct backing_dev_info separately instead of embedding it
inside session. This unifies handling of bdi among users.
CC: Eric Van Hensbergen <ericvh@gmail.com>
CC: Ron Minnich <rminnich@sandia.gov>
CC: Latchesar Ionkov <lucho@ionkov.net>
CC: v9fs-developer@lists.sourceforge.net
Signed-off-by: Jens Axboe <axboe@fb.com>
Pull misc final vfs updates from Al Viro:
"A few unrelated patches that got beating in -next.
Everything else will have to go into the next window ;-/"
* 'work.misc' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
hfs: fix hfs_readdir()
selftest for default_file_splice_read() infoleak
9p: constify ->d_name handling
Pull vfs 'statx()' update from Al Viro.
This adds the new extended stat() interface that internally subsumes our
previous stat interfaces, and allows user mode to specify in more detail
what kind of information it wants.
It also allows for some explicit synchronization information to be
passed to the filesystem, which can be relevant for network filesystems:
is the cached value ok, or do you need open/close consistency, or what?
From David Howells.
Andreas Dilger points out that the first version of the extended statx
interface was posted June 29, 2010:
https://www.spinics.net/lists/linux-fsdevel/msg33831.html
* 'rebased-statx' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
statx: Add a system call to make enhanced file info available
Add a system call to make extended file information available, including
file creation and some attribute flags where available through the
underlying filesystem.
The getattr inode operation is altered to take two additional arguments: a
u32 request_mask and an unsigned int flags that indicate the
synchronisation mode. This change is propagated to the vfs_getattr*()
function.
Functions like vfs_stat() are now inline wrappers around new functions
vfs_statx() and vfs_statx_fd() to reduce stack usage.
OVERVIEW
The idea was initially proposed as a set of xattrs that could be retrieved
with getxattr(), but the general preference proved to be for a new syscall
with an extended stat structure.
A number of requests were gathered for features to be included. The
following have been included:
(1) Make the fields a consistent size on all arches and make them large.
(2) Spare space, request flags and information flags are provided for
future expansion.
(3) Better support for the y2038 problem [Arnd Bergmann] (tv_sec is an
__s64).
(4) Creation time: The SMB protocol carries the creation time, which could
be exported by Samba, which will in turn help CIFS make use of
FS-Cache as that can be used for coherency data (stx_btime).
This is also specified in NFSv4 as a recommended attribute and could
be exported by NFSD [Steve French].
(5) Lightweight stat: Ask for just those details of interest, and allow a
netfs (such as NFS) to approximate anything not of interest, possibly
without going to the server [Trond Myklebust, Ulrich Drepper, Andreas
Dilger] (AT_STATX_DONT_SYNC).
(6) Heavyweight stat: Force a netfs to go to the server, even if it thinks
its cached attributes are up to date [Trond Myklebust]
(AT_STATX_FORCE_SYNC).
And the following have been left out for future extension:
(7) Data version number: Could be used by userspace NFS servers [Aneesh
Kumar].
Can also be used to modify fill_post_wcc() in NFSD which retrieves
i_version directly, but has just called vfs_getattr(). It could get
it from the kstat struct if it used vfs_xgetattr() instead.
(There's disagreement on the exact semantics of a single field, since
not all filesystems do this the same way).
(8) BSD stat compatibility: Including more fields from the BSD stat such
as creation time (st_btime) and inode generation number (st_gen)
[Jeremy Allison, Bernd Schubert].
(9) Inode generation number: Useful for FUSE and userspace NFS servers
[Bernd Schubert].
(This was asked for but later deemed unnecessary with the
open-by-handle capability available and caused disagreement as to
whether it's a security hole or not).
(10) Extra coherency data may be useful in making backups [Andreas Dilger].
(No particular data were offered, but things like last backup
timestamp, the data version number and the DOS archive bit would come
into this category).
(11) Allow the filesystem to indicate what it can/cannot provide: A
filesystem can now say it doesn't support a standard stat feature if
that isn't available, so if, for instance, inode numbers or UIDs don't
exist or are fabricated locally...
(This requires a separate system call - I have an fsinfo() call idea
for this).
(12) Store a 16-byte volume ID in the superblock that can be returned in
struct xstat [Steve French].
(Deferred to fsinfo).
(13) Include granularity fields in the time data to indicate the
granularity of each of the times (NFSv4 time_delta) [Steve French].
(14) FS_IOC_GETFLAGS value. These could be translated to BSD's st_flags.
Note that the Linux IOC flags are a mess and filesystems such as Ext4
define flags that aren't in linux/fs.h, so translation in the kernel
may be a necessity (or, possibly, we provide the filesystem type too).
(Some attributes are made available in stx_attributes, but the general
feeling was that the IOC flags were to ext[234]-specific and shouldn't
be exposed through statx this way).
(15) Mask of features available on file (eg: ACLs, seclabel) [Brad Boyer,
Michael Kerrisk].
(Deferred, probably to fsinfo. Finding out if there's an ACL or
seclabal might require extra filesystem operations).
(16) Femtosecond-resolution timestamps [Dave Chinner].
(A __reserved field has been left in the statx_timestamp struct for
this - if there proves to be a need).
(17) A set multiple attributes syscall to go with this.
NEW SYSTEM CALL
The new system call is:
int ret = statx(int dfd,
const char *filename,
unsigned int flags,
unsigned int mask,
struct statx *buffer);
The dfd, filename and flags parameters indicate the file to query, in a
similar way to fstatat(). There is no equivalent of lstat() as that can be
emulated with statx() by passing AT_SYMLINK_NOFOLLOW in flags. There is
also no equivalent of fstat() as that can be emulated by passing a NULL
filename to statx() with the fd of interest in dfd.
Whether or not statx() synchronises the attributes with the backing store
can be controlled by OR'ing a value into the flags argument (this typically
only affects network filesystems):
(1) AT_STATX_SYNC_AS_STAT tells statx() to behave as stat() does in this
respect.
(2) AT_STATX_FORCE_SYNC will require a network filesystem to synchronise
its attributes with the server - which might require data writeback to
occur to get the timestamps correct.
(3) AT_STATX_DONT_SYNC will suppress synchronisation with the server in a
network filesystem. The resulting values should be considered
approximate.
mask is a bitmask indicating the fields in struct statx that are of
interest to the caller. The user should set this to STATX_BASIC_STATS to
get the basic set returned by stat(). It should be noted that asking for
more information may entail extra I/O operations.
buffer points to the destination for the data. This must be 256 bytes in
size.
MAIN ATTRIBUTES RECORD
The following structures are defined in which to return the main attribute
set:
struct statx_timestamp {
__s64 tv_sec;
__s32 tv_nsec;
__s32 __reserved;
struct statx {
__u32 stx_mask;
__u32 stx_blksize;
__u64 stx_attributes;
__u32 stx_nlink;
__u32 stx_uid;
__u32 stx_gid;
__u16 stx_mode;
__u16 __spare0[1];
__u64 stx_ino;
__u64 stx_size;
__u64 stx_blocks;
__u64 __spare1[1];
struct statx_timestamp stx_atime;
struct statx_timestamp stx_btime;
struct statx_timestamp stx_ctime;
struct statx_timestamp stx_mtime;
__u32 stx_rdev_major;
__u32 stx_rdev_minor;
__u32 stx_dev_major;
__u32 stx_dev_minor;
__u64 __spare2[14];
The defined bits in request_mask and stx_mask are:
STATX_TYPE Want/got stx_mode & S_IFMT
STATX_MODE Want/got stx_mode & ~S_IFMT
STATX_NLINK Want/got stx_nlink
STATX_UID Want/got stx_uid
STATX_GID Want/got stx_gid
STATX_ATIME Want/got stx_atime{,_ns}
STATX_MTIME Want/got stx_mtime{,_ns}
STATX_CTIME Want/got stx_ctime{,_ns}
STATX_INO Want/got stx_ino
STATX_SIZE Want/got stx_size
STATX_BLOCKS Want/got stx_blocks
STATX_BASIC_STATS [The stuff in the normal stat struct]
STATX_BTIME Want/got stx_btime{,_ns}
STATX_ALL [All currently available stuff]
stx_btime is the file creation time, stx_mask is a bitmask indicating the
data provided and __spares*[] are where as-yet undefined fields can be
placed.
Time fields are structures with separate seconds and nanoseconds fields
plus a reserved field in case we want to add even finer resolution. Note
that times will be negative if before 1970; in such a case, the nanosecond
fields will also be negative if not zero.
The bits defined in the stx_attributes field convey information about a
file, how it is accessed, where it is and what it does. The following
attributes map to FS_*_FL flags and are the same numerical value:
STATX_ATTR_COMPRESSED File is compressed by the fs
STATX_ATTR_IMMUTABLE File is marked immutable
STATX_ATTR_APPEND File is append-only
STATX_ATTR_NODUMP File is not to be dumped
STATX_ATTR_ENCRYPTED File requires key to decrypt in fs
Within the kernel, the supported flags are listed by:
KSTAT_ATTR_FS_IOC_FLAGS
[Are any other IOC flags of sufficient general interest to be exposed
through this interface?]
New flags include:
STATX_ATTR_AUTOMOUNT Object is an automount trigger
These are for the use of GUI tools that might want to mark files specially,
depending on what they are.
Fields in struct statx come in a number of classes:
(0) stx_dev_*, stx_blksize.
These are local system information and are always available.
(1) stx_mode, stx_nlinks, stx_uid, stx_gid, stx_[amc]time, stx_ino,
stx_size, stx_blocks.
These will be returned whether the caller asks for them or not. The
corresponding bits in stx_mask will be set to indicate whether they
actually have valid values.
If the caller didn't ask for them, then they may be approximated. For
example, NFS won't waste any time updating them from the server,
unless as a byproduct of updating something requested.
If the values don't actually exist for the underlying object (such as
UID or GID on a DOS file), then the bit won't be set in the stx_mask,
even if the caller asked for the value. In such a case, the returned
value will be a fabrication.
Note that there are instances where the type might not be valid, for
instance Windows reparse points.
(2) stx_rdev_*.
This will be set only if stx_mode indicates we're looking at a
blockdev or a chardev, otherwise will be 0.
(3) stx_btime.
Similar to (1), except this will be set to 0 if it doesn't exist.
TESTING
The following test program can be used to test the statx system call:
samples/statx/test-statx.c
Just compile and run, passing it paths to the files you want to examine.
The file is built automatically if CONFIG_SAMPLES is enabled.
Here's some example output. Firstly, an NFS directory that crosses to
another FSID. Note that the AUTOMOUNT attribute is set because transiting
this directory will cause d_automount to be invoked by the VFS.
[root@andromeda ~]# /tmp/test-statx -A /warthog/data
statx(/warthog/data) = 0
results=7ff
Size: 4096 Blocks: 8 IO Block: 1048576 directory
Device: 00:26 Inode: 1703937 Links: 125
Access: (3777/drwxrwxrwx) Uid: 0 Gid: 4041
Access: 2016-11-24 09:02:12.219699527+0000
Modify: 2016-11-17 10:44:36.225653653+0000
Change: 2016-11-17 10:44:36.225653653+0000
Attributes: 0000000000001000 (-------- -------- -------- -------- -------- -------- ---m---- --------)
Secondly, the result of automounting on that directory.
[root@andromeda ~]# /tmp/test-statx /warthog/data
results=7ff
Device: 00:27 Inode: 2 Links: 125
Add #include <linux/cred.h> dependencies to all .c files rely on sched.h
doing that for them.
Note that even if the count where we need to add extra headers seems high,
it's still a net win, because <linux/sched.h> is included in over
2,200 files ...
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
->fault(), ->page_mkwrite(), and ->pfn_mkwrite() calls do not need to
take a vma and vmf parameter when the vma already resides in vmf.
Remove the vma parameter to simplify things.
[arnd@arndb.de: fix ARM build]
Link: http://lkml.kernel.org/r/20170125223558.1451224-1-arnd@arndb.de
Link: http://lkml.kernel.org/r/148521301778.19116.10840599906674778980.stgit@djiang5-desk3.ch.intel.com
Signed-off-by: Dave Jiang <dave.jiang@intel.com>
Reviewed-by: Ross Zwisler <ross.zwisler@linux.intel.com>
Cc: Theodore Ts'o <tytso@mit.edu>
Cc: Darrick J. Wong <darrick.wong@oracle.com>
Cc: Matthew Wilcox <mawilcox@microsoft.com>
Cc: Jan Kara <jack@suse.com>
Cc: Dan Williams <dan.j.williams@intel.com>
posix_acl_update_mode() could possibly clear 'acl', if so we leak the
memory pointed by 'acl'. Save this pointer before calling
posix_acl_update_mode() and release the memory if 'acl' really gets
cleared.
Link: http://lkml.kernel.org/r/1486678332-2430-1-git-send-email-xiyou.wangcong@gmail.com
Reported-by: Mark Salyzyn <salyzyn@android.com>
Reviewed-by: Greg Kurz <groug@kaod.org>
This was entirely automated, using the script by Al:
PATT='^[[:blank:]]*#[[:blank:]]*include[[:blank:]]*<asm/uaccess.h>'
sed -i -e "s!$PATT!#include <linux/uaccess.h>!" \
$(git grep -l "$PATT"|grep -v ^include/linux/uaccess.h)
to do the replacement at the end of the merge window.
Requested-by: Al Viro <viro@zeniv.linux.org.uk>
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/vfs
Pull partial readlink cleanups from Miklos Szeredi.
This is the uncontroversial part of the readlink cleanup patch-set that
simplifies the default readlink handling.
Miklos and Al are still discussing the rest of the series.
* git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/vfs:
vfs: make generic_readlink() static
vfs: remove ".readlink = generic_readlink" assignments
vfs: default to generic_readlink()
vfs: replace calling i_op->readlink with vfs_readlink()
proc/self: use generic_readlink
ecryptfs: use vfs_get_link()
bad_inode: add missing i_op initializers
Pull more vfs updates from Al Viro:
"In this pile:
- autofs-namespace series
- dedupe stuff
- more struct path constification"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (40 commits)
ocfs2: implement the VFS clone_range, copy_range, and dedupe_range features
ocfs2: charge quota for reflinked blocks
ocfs2: fix bad pointer cast
ocfs2: always unlock when completing dio writes
ocfs2: don't eat io errors during _dio_end_io_write
ocfs2: budget for extent tree splits when adding refcount flag
ocfs2: prohibit refcounted swapfiles
ocfs2: add newlines to some error messages
ocfs2: convert inode refcount test to a helper
simple_write_end(): don't zero in short copy into uptodate
exofs: don't mess with simple_write_{begin,end}
fix gfs2_stuffed_write_end() on short copies
fix ceph_write_end()
nfs_write_end(): fix handling of short copies
vfs: refactor clone/dedupe_file_range common functions
fs: try to clone files first in vfs_copy_file_range
vfs: misc struct path constification
namespace.c: constify struct path passed to a bunch of primitives
quota: constify struct path in quota_on
If we had a short copy into an uptodate page, there's no reason
whatsoever to zero anything; OTOH, if that page had _not_ been
uptodate, we must have been trying to overwrite it completely
and got a short copy. In that case, overwriting the end with
zeroes, marking uptodate and sending to server is just plain
wrong. Just unlock, keep it non-uptodate and return 0.
If .readlink == NULL implies generic_readlink().
Generated by:
to_del="\.readlink.*=.*generic_readlink"
for i in `git grep -l $to_del`; do sed -i "/$to_del"/d $i; done
Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
Nothing in fs.h should require blk_types.h to be included.
">rename2() work from Miklos + current_time() from Deepa"
fs: Replace current_fs_time() with current_time()
fs: Replace CURRENT_TIME_SEC with current_time() for inode timestamps
fs: Replace CURRENT_TIME with current_time() for inode timestamps
fs: proc: Delete inode time initializations in proc_alloc_inode()
vfs: Add current_time() api
vfs: add note about i_op->rename changes to porting
fs: rename "rename2" i_op to "rename"
vfs: remove unused i_op->rename
fs: make remaining filesystems use .rename2
libfs: support RENAME_NOREPLACE in simple_rename()
fs: support RENAME_NOREPLACE for local filesystems
ncpfs: fix unused variable warning
Pull vfs xattr updates from Al Viro:
"xattr stuff from Andreas
This completes the switch to xattr_handler ->get()/->set() from
->getxattr/->setxattr/->removexattr"
* 'work.xattr' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
vfs: Remove {get,set,remove}xattr inode operations
xattr: Stop calling {get,set,remove}xattr inode operations
vfs: Check for the IOP_XATTR flag in listxattr
xattr: Add __vfs_{get,set,remove}xattr helpers
libfs: Use IOP_XATTR flag for empty directory handling
vfs: Use IOP_XATTR flag for bad-inode handling
vfs: Add IOP_XATTR inode operations flag
vfs: Move xattr_resolve_name to the front of fs/xattr.c
ecryptfs: Switch to generic xattr handlers
sockfs: Get rid of getxattr iop
sockfs: getxattr: Fail with -EOPNOTSUPP for invalid attribute names
kernfs: Switch to generic xattr handlers
hfs: Switch to generic xattr handlers
jffs2: Remove jffs2_{get,set,remove}xattr macros
xattr: Remove unnecessary NULL attribute name check
These inode operations are no longer used; remove them.
Signed-off-by: Andreas Gruenbacher <agruenba@redhat.com>
CURRENT_TIME macro is not appropriate for filesystems as it
doesn't use the right granularity for filesystem timestamps.
Use current_time() instead.
CURRENT_TIME is also not y2038 safe.
This is also in preparation for the patch that transitions
vfs timestamps to use 64 bit time and hence make them
y2038 safe. As part of the effort current_time() will be
extended to do range checks. Hence, it is necessary for all
file system timestamps to use current_time(). Also,
current_time() will be transitioned along with vfs to be
y2038 safe.
Note that whenever a single call to current_time() is used
to change timestamps in different inodes, it is because they
share the same time granularity.
Signed-off-by: Deepa Dinamani <deepa.kernel@gmail.com>
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
Acked-by: Felipe Balbi <balbi@kernel.org>
Acked-by: Steven Whitehouse <swhiteho@redhat.com>
Acked-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
Acked-by: David Sterba <dsterba@suse.com>
Generated patch:
sed -i "s/\.rename2\t/\.rename\t\t/" `git grep -wl rename2`
sed -i "s/\brename2\b/rename/g" `git grep -wl rename2`
This is trivial to do:
- add flags argument to foo_rename()
- check if flags is zero
- assign foo_rename() to .rename2 instead of .rename
This doesn't mean it's impossible to support RENAME_NOREPLACE for these
filesystems, but it is not trivial, like for local filesystems.
RENAME_NOREPLACE must guarantee atomicity (i.e. it shouldn't be possible
for a file to be created on one host while it is overwritten by rename on
another host).
Filesystems converted:
9p, afs, ceph, coda, ecryptfs, kernfs, lustre, ncpfs, nfs, ocfs2, orangefs.
After this, we can get rid of the duplicate interfaces for rename.
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Acked-by: David Howells <dhowells@redhat.com> [AFS]
Acked-by: Mike Marshall <hubcap@omnibond.com>
Cc: Ilya Dryomov <idryomov@gmail.com>
Cc: Jan Harkes <jaharkes@cs.cmu.edu>
Cc: Tyler Hicks <tyhicks@canonical.com>
Cc: Oleg Drokin <oleg.drokin@intel.com>
Cc: Trond Myklebust <trond.myklebust@primarydata.com>
Cc: Mark Fasheh <mfasheh@suse.com>
inode_change_ok() will be resposible for clearing capabilities and IMA
extended attributes and as such will need dentry. Give it as an argument
to inode_change_ok() instead of an inode. Also rename inode_change_ok()
to setattr_prepare() to better relect that it does also some
modifications in addition to checks.
When file permissions are modified via chmod(2) and the user is not in
the owning group or capable of CAP_FSETID, the setgid bit is cleared in
inode_change_ok(). Setting a POSIX ACL via setxattr(2) sets the file
permissions as well as the new ACL, but doesn't clear the setgid bit in
a similar way; this allows to bypass the check in chmod(2). Fix that.
References: CVE-2016-7097
Reviewed-by: Jeff Layton <jlayton@redhat.com>
"Assorted cleanups and fixes.
In the "trivial API change" department - ->d_compare() losing 'parent'
argument"
* 'for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
cachefiles: Fix race between inactivating and culling a cache object
9p: use clone_fid()
9p: fix braino introduced in "9p: new helper - v9fs_parent_fid()"
vfs: make dentry_needs_remove_privs() internal
vfs: remove file_needs_remove_privs()
vfs: fix deadlock in file_remove_privs() on overlayfs
get rid of 'parent' argument of ->d_compare()
cifs, msdos, vfat, hfs+: don't bother with parent in ->d_compare()
affs ->d_compare(): don't bother with ->d_inode
fold _d_rehash() and __d_rehash() together
fold dentry_rcuwalk_invalidate() into its only remaining caller
in a bunch of places it cleans the things up
In v9fs_vfs_rename() we need to clone the parents' fids, not just
find them.
Spotted-by: Johannes Berg <johannes@sipsolutions.net>
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace
Pull userns vfs updates from Eric Biederman:
"This tree contains some very long awaited work on generalizing the
user namespace support for mounting filesystems to include filesystems
with a backing store. The real world target is fuse but the goal is
to update the vfs to allow any filesystem to be supported. This
patchset is based on a lot of code review and testing to approach that
goal.
While looking at what is needed to support the fuse filesystem it
became clear that there were things like xattrs for security modules
that needed special treatment. That the resolution of those concerns
would not be fuse specific. That sorting out these general issues
made most sense at the generic level, where the right people could be
drawn into the conversation, and the issues could be solved for
everyone.
At a high level what this patchset does a couple of simple things:
- Add a user namespace owner (s_user_ns) to struct super_block.
- Teach the vfs to handle filesystem uids and gids not mapping into
to kuids and kgids and being reported as INVALID_UID and
INVALID_GID in vfs data structures.
By assigning a user namespace owner filesystems that are mounted with
only user namespace privilege can be detected. This allows security
modules and the like to know which mounts may not be trusted. This
also allows the set of uids and gids that are communicated to the
filesystem to be capped at the set of kuids and kgids that are in the
owning user namespace of the filesystem.
One of the crazier corner casees this handles is the case of inodes
whose i_uid or i_gid are not mapped into the vfs. Most of the code
simply doesn't care but it is easy to confuse the inode writeback path
so no operation that could cause an inode write-back is permitted for
such inodes (aka only reads are allowed).
This set of changes starts out by cleaning up the code paths involved
in user namespace permirted mounts. Then when things are clean enough
adds code that cleanly sets s_user_ns. Then additional restrictions
are added that are possible now that the filesystem superblock
contains owner information.
These changes should not affect anyone in practice, but there are some
parts of these restrictions that are changes in behavior.
- Andy's restriction on suid executables that does not honor the
suid bit when the path is from another mount namespace (think
/proc/[pid]/fd/) or when the filesystem was mounted by a less
privileged user.
- The replacement of the user namespace implicit setting of MNT_NODEV
with implicitly setting SB_I_NODEV on the filesystem superblock
instead.
Using SB_I_NODEV is a stronger form that happens to make this state
user invisible. The user visibility can be managed but it caused
problems when it was introduced from applications reasonably
expecting mount flags to be what they were set to.
There is a little bit of work remaining before it is safe to support
mounting filesystems with backing store in user namespaces, beyond
what is in this set of changes.
- Verifying the mounter has permission to read/write the block device
during mount.
- Teaching the integrity modules IMA and EVM to handle filesystems
mounted with only user namespace root and to reduce trust in their
security xattrs accordingly.
- Capturing the mounters credentials and using that for permission
checks in d_automount and the like. (Given that overlayfs already
does this, and we need the work in d_automount it make sense to
generalize this case).
Furthermore there are a few changes that are on the wishlist:
- Get all filesystems supporting posix acls using the generic posix
acls so that posix_acl_fix_xattr_from_user and
posix_acl_fix_xattr_to_user may be removed. [Maintainability]
- Reducing the permission checks in places such as remount to allow
the superblock owner to perform them.
- Allowing the superblock owner to chown files with unmapped uids and
gids to something that is mapped so the files may be treated
normally.
I am not considering even obvious relaxations of permission checks
until it is clear there are no more corner cases that need to be
locked down and handled generically.
Many thanks to Seth Forshee who kept this code alive, and putting up
with me rewriting substantial portions of what he did to handle more
corner cases, and for his diligent testing and reviewing of my
changes"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: (30 commits)
fs: Call d_automount with the filesystems creds
fs: Update i_[ug]id_(read|write) to translate relative to s_user_ns
evm: Translate user/group ids relative to s_user_ns when computing HMAC
dquot: For now explicitly don't support filesystems outside of init_user_ns
quota: Handle quota data stored in s_user_ns in quota_setxquota
quota: Ensure qids map to the filesystem
vfs: Don't create inodes with a uid or gid unknown to the vfs
vfs: Don't modify inodes with a uid or gid unknown to the vfs
cred: Reject inodes with invalid ids in set_create_file_as()
fs: Check for invalid i_uid in may_follow_link()
vfs: Verify acls are valid within superblock's s_user_ns.
userns: Handle -1 in k[ug]id_has_mapping when !CONFIG_USER_NS
fs: Refuse uid/gid changes which don't map into s_user_ns
selinux: Add support for unprivileged mounts from user namespaces
Smack: Handle labels consistently in untrusted mounts
Smack: Add support for unprivileged mounts from user namespaces
fs: Treat foreign mounts as nosuid
fs: Limit file caps to the user namespace of the super block
userns: Remove the now unnecessary FS_USERNS_DEV_MOUNT flag
userns: Remove implicit MNT_NODEV fragility.
Pull vfs updates from Al Viro:
Probably the most interesting part long-term is ->d_init() - that will
have a bunch of followups in (at least) ceph and lustre, but we'll
need to sort the barrier-related rules before it can get used for
really non-trivial stuff.
Another fun thing is the merge of ->d_iput() callers (dentry_iput()
and dentry_unlink_inode()) and a bunch of ->d_compare() ones (all
except the one in __d_lookup_lru())"
* 'work.misc' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (26 commits)
fs/dcache.c: avoid soft-lockup in dput()
vfs: new d_init method
vfs: Update lookup_dcache() comment
bdev: get rid of ->bd_inodes
Remove last traces of ->sync_page
new helper: d_same_name()
dentry_cmp(): use lockless_dereference() instead of smp_read_barrier_depends()
vfs: clean up documentation
vfs: document ->d_real()
vfs: merge .d_select_inode() into .d_real()
unify dentry_iput() and dentry_unlink_inode()
binfmt_misc: ->s_root is not going anywhere
drop redundant ->owner initializations
ufs: get rid of redundant checks
orangefs: constify inode_operations
missed comment updates from ->direct_IO() prototype change
file_inode(f)->i_mapping is f->f_mapping
trim fsnotify hooks a bit
debugfs: ->d_parent is never NULL or negative
->atomic_open() can be given an in-lookup dentry *or* a negative one
found in dcache. Use d_in_lookup() to tell one from another, rather
than d_unhashed().
v9fs may be used as lower layer of overlayfs and accessing f_path.dentry
can lead to a crash. In this case it's a NULL pointer dereference in
p9_fid_create().
Fix by replacing direct access of file->f_path.dentry with the
file_dentry() accessor, which will always return a native object.
Reported-by: Alessio Igor Bogani <alessioigorbogani@gmail.com>
Tested-by: Alessio Igor Bogani <alessioigorbogani@gmail.com>
Fixes: 4bacc9c9234c ("overlayfs: Make f_path always point to the overlay and f_inode to the underlay")
Cc: <stable@vger.kernel.org>
Update posix_acl_valid to verify that an acl is within a user namespace.
Update the callers of posix_acl_valid to pass in an appropriate
user namespace. For posix_acl_xattr_set and v9fs_xattr_set_acl pass in
inode->i_sb->s_user_ns to posix_acl_valid. For md_unpack_acl pass in
&init_user_ns as no inode or superblock is in sight.
Acked-by: Seth Forshee <seth.forshee@canonical.com>
