path: root/fs/Kconfig
2015-04-10f2fs: relocate Kconfig from misc filesystemsJaegeuk Kim
The f2fs has been shipped on many smartphone devices during a couple of years. So, it is worth to relocate Kconfig into main page from misc filesystems for developers to choose it more easily. Signed-off-by: Jaegeuk Kim <jaegeuk@kernel.org>
2015-02-16dax: does not work correctly with virtual aliasing cachesMatthew Wilcox
The DAX code accesses the underlying storage through the kernel's linear mapping, which may not be cache-coherent with user mappings on ARM, MIPS or SPARC. Temporarily disable the DAX code until this problem is resolved. The original XIP code also had this problem, but it was never noticed. Signed-off-by: Matthew Wilcox <matthew.r.wilcox@intel.com> Cc: Andreas Dilger <andreas.dilger@intel.com> Cc: Boaz Harrosh <boaz@plexistor.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Dave Chinner <david@fromorbit.com> Cc: Jan Kara <jack@suse.cz> Cc: Jens Axboe <axboe@kernel.dk> Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Cc: Randy Dunlap <rdunlap@infradead.org> Cc: Ross Zwisler <ross.zwisler@linux.intel.com> Cc: Theodore Ts'o <tytso@mit.edu> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-16vfs,ext2: remove CONFIG_EXT2_FS_XIP and rename CONFIG_FS_XIP to CONFIG_FS_DAXMatthew Wilcox
The fewer Kconfig options we have the better. Use the generic CONFIG_FS_DAX to enable XIP support in ext2 as well as in the core. Signed-off-by: Matthew Wilcox <matthew.r.wilcox@intel.com> Cc: Andreas Dilger <andreas.dilger@intel.com> Cc: Boaz Harrosh <boaz@plexistor.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Dave Chinner <david@fromorbit.com> Cc: Jan Kara <jack@suse.cz> Cc: Jens Axboe <axboe@kernel.dk> Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Cc: Randy Dunlap <rdunlap@infradead.org> Cc: Ross Zwisler <ross.zwisler@linux.intel.com> Cc: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-01-05fs: Make efivarfs a pseudo filesystem, built by default with EFILeif Lindholm
efivars is currently enabled under MISC_FILESYSTEMS, which is decribed as "such as filesystems that came from other operating systems". In reality, it is a pseudo filesystem, providing access to the kernel UEFI variable interface. Since this is the preferred interface for accessing UEFI variables, over the legacy efivars interface, also build it by default as a module if CONFIG_EFI. Signed-off-by: Leif Lindholm <leif.lindholm@linaro.org> Signed-off-by: Matt Fleming <matt.fleming@intel.com>
2014-10-24overlay filesystemMiklos Szeredi
Overlayfs allows one, usually read-write, directory tree to be overlaid onto another, read-only directory tree. All modifications go to the upper, writable layer. This type of mechanism is most often used for live CDs but there's a wide variety of other uses. The implementation differs from other "union filesystem" implementations in that after a file is opened all operations go directly to the underlying, lower or upper, filesystems. This simplifies the implementation and allows native performance in these cases. The dentry tree is duplicated from the underlying filesystems, this enables fast cached lookups without adding special support into the VFS. This uses slightly more memory than union mounts, but dentries are relatively small. Currently inodes are duplicated as well, but it is a possible optimization to share inodes for non-directories. Opening non directories results in the open forwarded to the underlying filesystem. This makes the behavior very similar to union mounts (with the same limitations vs. fchmod/fchown on O_RDONLY file descriptors). Usage: mount -t overlayfs overlayfs -olowerdir=/lower,upperdir=/upper/upper,workdir=/upper/work /overlay The following cotributions have been folded into this patch: Neil Brown <neilb@suse.de>: - minimal remount support - use correct seek function for directories - initialise is_real before use - rename ovl_fill_cache to ovl_dir_read Felix Fietkau <nbd@openwrt.org>: - fix a deadlock in ovl_dir_read_merged - fix a deadlock in ovl_remove_whiteouts Erez Zadok <ezk@fsl.cs.sunysb.edu> - fix cleanup after WARN_ON Sedat Dilek <sedat.dilek@googlemail.com> - fix up permission to confirm to new API Robin Dong <hao.bigrat@gmail.com> - fix possible leak in ovl_new_inode - create new inode in ovl_link Andy Whitcroft <apw@canonical.com> - switch to __inode_permission() - copy up i_uid/i_gid from the underlying inode AV: - ovl_copy_up_locked() - dput(ERR_PTR(...)) on two failure exits - ovl_clear_empty() - one failure exit forgetting to do unlock_rename(), lack of check for udir being the parent of upper, dropping and regaining the lock on udir (which would require _another_ check for parent being right). - bogus d_drop() in copyup and rename [fix from your mail] - copyup/remove and copyup/rename races [fix from your mail] - ovl_dir_fsync() leaving ERR_PTR() in ->realfile - ovl_entry_free() is pointless - it's just a kfree_rcu() - fold ovl_do_lookup() into ovl_lookup() - manually assigning ->d_op is wrong. Just use ->s_d_op. [patches picked from Miklos]: * copyup/remove and copyup/rename races * bogus d_drop() in copyup and rename Also thanks to the following people for testing and reporting bugs: Jordi Pujol <jordipujolp@gmail.com> Andy Whitcroft <apw@canonical.com> Michal Suchanek <hramrach@centrum.cz> Felix Fietkau <nbd@openwrt.org> Erez Zadok <ezk@fsl.cs.sunysb.edu> Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2014-09-17lockd: move lockd's grace period handling into its own moduleJeff Layton
Currently, all of the grace period handling is part of lockd. Eventually though we'd like to be able to build v4-only servers, at which point we'll need to put all of this elsewhere. Move the code itself into fs/nfs_common and have it build a grace.ko module. Then, rejigger the Kconfig options so that both nfsd and lockd enable it automatically. Signed-off-by: Jeff Layton <jlayton@primarydata.com>
2014-02-07kernfs: add CONFIG_KERNFSTejun Heo
As sysfs was kernfs's only user, kernfs has been piggybacking on CONFIG_SYSFS; however, kernfs is scheduled to grow a new user very soon. Introduce a separate config option CONFIG_KERNFS which is to be selected by kernfs users. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: linux-fsdevel@vger.kernel.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-26fs: remove generic_aclChristoph Hellwig
And instead convert tmpfs to use the new generic ACL code, with two stub methods provided for in-memory filesystems. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-04-17efivarfs: Move to fs/efivarfsMatt Fleming
Now that efivarfs uses the efivar API, move it out of efivars.c and into fs/efivarfs where it belongs. This move will eventually allow us to enable the efivarfs code without having to also enable CONFIG_EFI_VARS built, and vice versa. Furthermore, things like, mount -t efivarfs none /sys/firmware/efi/efivars will now work if efivarfs is built as a module without requiring the use of MODULE_ALIAS(), which would have been necessary when the efivarfs code was part of efivars.c. Cc: Matthew Garrett <matthew.garrett@nebula.com> Cc: Jeremy Kerr <jk@ozlabs.org> Reviewed-by: Tom Gundersen <teg@jklm.no> Tested-by: Tom Gundersen <teg@jklm.no> Signed-off-by: Matt Fleming <matt.fleming@intel.com>
2013-01-17fuse: Move CUSE Kconfig entry from fs/Kconfig into fs/fuse/KconfigRobert P. J. Day
Given that CUSE depends on FUSE, it only makes sense to move its Kconfig entry into the FUSE Kconfig file. Also, add a few grammatical and semantic touchups. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2012-12-20Merge tag 'for-3.8-merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jaegeuk/f2fs Pull new F2FS filesystem from Jaegeuk Kim: "Introduce a new file system, Flash-Friendly File System (F2FS), to Linux 3.8. Highlights: - Add initial f2fs source codes - Fix an endian conversion bug - Fix build failures on random configs - Fix the power-off-recovery routine - Minor cleanup, coding style, and typos patches" From the Kconfig help text: F2FS is based on Log-structured File System (LFS), which supports versatile "flash-friendly" features. The design has been focused on addressing the fundamental issues in LFS, which are snowball effect of wandering tree and high cleaning overhead. Since flash-based storages show different characteristics according to the internal geometry or flash memory management schemes aka FTL, F2FS and tools support various parameters not only for configuring on-disk layout, but also for selecting allocation and cleaning algorithms. and there's an article by Neil Brown about it on lwn.net: http://lwn.net/Articles/518988/ * tag 'for-3.8-merge' of git://git.kernel.org/pub/scm/linux/kernel/git/jaegeuk/f2fs: (36 commits) f2fs: fix tracking parent inode number f2fs: cleanup the f2fs_bio_alloc routine f2fs: introduce accessor to retrieve number of dentry slots f2fs: remove redundant call to f2fs_put_page in delete entry f2fs: make use of GFP_F2FS_ZERO for setting gfp_mask f2fs: rewrite f2fs_bio_alloc to make it simpler f2fs: fix a typo in f2fs documentation f2fs: remove unused variable f2fs: move error condition for mkdir at proper place f2fs: remove unneeded initialization f2fs: check read only condition before beginning write out f2fs: remove unneeded memset from init_once f2fs: show error in case of invalid mount arguments f2fs: fix the compiler warning for uninitialized use of variable f2fs: resolve build failures f2fs: adjust kernel coding style f2fs: fix endian conversion bugs reported by sparse f2fs: remove unneeded version.h header file from f2fs.h f2fs: update the f2fs document f2fs: update Kconfig and Makefile ...
2012-12-11f2fs: update Kconfig and MakefileJaegeuk Kim
This adds Makefile and Kconfig for f2fs, and updates Makefile and Kconfig files in the fs directory. Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
2012-12-10ext4: Remove CONFIG_EXT4_FS_XATTRTao Ma
Ted has sent out a RFC about removing this feature. Eric and Jan confirmed that both RedHat and SUSE enable this feature in all their product. David also said that "As far as I know, it's enabled in all Android kernels that use ext4." So it seems OK for us. And what's more, as inline data depends its implementation on xattr, and to be frank, I don't run any test again inline data enabled while xattr disabled. So I think we should add inline data and remove this config option in the same release. [ The savings if you disable CONFIG_EXT4_FS_XATTR is only 27k, which isn't much in the grand scheme of things. Since no one seems to be testing this configuration except for some automated compile farms, on balance we are better removing this config option, and so that it is effectively always enabled. -- tytso ] Cc: David Brown <davidb@codeaurora.org> Cc: Eric Sandeen <sandeen@redhat.com> Reviewed-by: Jan Kara <jack@suse.cz> Signed-off-by: Tao Ma <boyu.mt@taobao.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2012-03-21Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs pile 1 from Al Viro: "This is _not_ all; in particular, Miklos' and Jan's stuff is not there yet." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (64 commits) ext4: initialization of ext4_li_mtx needs to be done earlier debugfs-related mode_t whack-a-mole hfsplus: add an ioctl to bless files hfsplus: change finder_info to u32 hfsplus: initialise userflags qnx4: new helper - try_extent() qnx4: get rid of qnx4_bread/qnx4_getblk take removal of PF_FORKNOEXEC to flush_old_exec() trim includes in inode.c um: uml_dup_mmap() relies on ->mmap_sem being held, but activate_mm() doesn't hold it um: embed ->stub_pages[] into mmu_context gadgetfs: list_for_each_safe() misuse ocfs2: fix leaks on failure exits in module_init ecryptfs: make register_filesystem() the last potential failure exit ntfs: forgets to unregister sysctls on register_filesystem() failure logfs: missing cleanup on register_filesystem() failure jfs: mising cleanup on register_filesystem() failure make configfs_pin_fs() return root dentry on success configfs: configfs_create_dir() has parent dentry in dentry->d_parent configfs: sanitize configfs_create() ...
2012-03-20fs: initial qnx6fs additionKai Bankett
Adds support for qnx6fs readonly support to the linux kernel. * Mount option The option mmi_fs can be used to mount Harman Becker/Audi MMI 3G HDD qnx6fs filesystems. * Documentation A high level filesystem stucture description can be found in the Documentation/filesystems directory. (qnx6.txt) * Additional features - Active (stable) superblock selection - Superblock checksum check (enforced) - Supports mount of qnx6 filesystems with to host different endianess - Automatic endianess detection - Longfilename support (with non-enfocing crc check) - All blocksizes (512, 1024, 2048 and 4096 supported) Signed-off-by: Kai Bankett <chaosman@ontika.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-03-08vfs: use 'unsigned long' accesses for dcache name comparison and hashingLinus Torvalds
Ok, this is hacky, and only works on little-endian machines with goo unaligned handling. And even then only with CONFIG_DEBUG_PAGEALLOC disabled, since it can access up to 7 bytes after the pathname. But it runs like a bat out of hell. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-09Merge branch 'for-linus' of git://git.open-osd.org/linux-open-osdLinus Torvalds
* 'for-linus' of git://git.open-osd.org/linux-open-osd: ore: Must support none-PAGE-aligned IO ore: fix BUG_ON, too few sgs when reading ore: Fix crash in case of an IO error. ore: FIX breakage when MISC_FILESYSTEMS is not set
2012-01-06ore: FIX breakage when MISC_FILESYSTEMS is not setBoaz Harrosh
As Reported by Randy Dunlap When MISC_FILESYSTEMS is not enabled and NFS4.1 is: fs/built-in.o: In function `objio_alloc_io_state': objio_osd.c:(.text+0xcb525): undefined reference to `ore_get_rw_state' fs/built-in.o: In function `_write_done': objio_osd.c:(.text+0xcb58d): undefined reference to `ore_check_io' fs/built-in.o: In function `_read_done': ... When MISC_FILESYSTEMS, which is more of a GUI thing then anything else, is not selected. exofs/Kconfig is never examined during Kconfig, and it can not do it's magic stuff to automatically select everything needed. We must split exofs/Kconfig in two. The ore one is always included. And the exofs one is left in it's old place in the menu. [Needed for the 3.2.0 Kernel] CC: Stable Tree <stable@kernel.org> Reported-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
2012-01-03move fs/partitions to block/Al Viro
2011-10-31tmpfs: add "tmpfs" to the Kconfig prompt to make it obvious.Robert P. J. Day
Add the leading word "tmpfs" to the Kconfig string to make it blindingly obvious that this selection refers to tmpfs. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Acked-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-03tmpfs: expand "help" to explain value of TMPFS_POSIX_ACLRobert P. J. Day
Expand the fs/Kconfig "help" info to clarify why it's a bad idea to deselect the TMPFS_POSIX_ACL config variable. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Acked-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (25 commits) cifs: remove unnecessary dentry_unhash on rmdir/rename_dir ocfs2: remove unnecessary dentry_unhash on rmdir/rename_dir exofs: remove unnecessary dentry_unhash on rmdir/rename_dir nfs: remove unnecessary dentry_unhash on rmdir/rename_dir ext2: remove unnecessary dentry_unhash on rmdir/rename_dir ext3: remove unnecessary dentry_unhash on rmdir/rename_dir ext4: remove unnecessary dentry_unhash on rmdir/rename_dir btrfs: remove unnecessary dentry_unhash in rmdir/rename_dir ceph: remove unnecessary dentry_unhash calls vfs: clean up vfs_rename_other vfs: clean up vfs_rename_dir vfs: clean up vfs_rmdir vfs: fix vfs_rename_dir for FS_RENAME_DOES_D_MOVE filesystems libfs: drop unneeded dentry_unhash vfs: update dentry_unhash() comment vfs: push dentry_unhash on rename_dir into file systems vfs: push dentry_unhash on rmdir into file systems vfs: remove dget() from dentry_unhash() vfs: dentry_unhash immediately prior to rmdir vfs: Block mmapped writes while the fs is frozen ...
2011-05-26exportfs: reallow building as a moduleJonas Gorski
Commit 990d6c2d7aee921e3bce22b2d6a750fd552262be ("vfs: Add name to file handle conversion support") changed EXPORTFS to be a bool. This was needed for earlier revisions of the original patch, but the actual commit put the code needing it into its own file that only gets compiled when FHANDLE is selected which in turn selects EXPORTFS. So EXPORTFS can be safely compiled as a module when not selecting FHANDLE. Signed-off-by: Jonas Gorski <jonas.gorski@gmail.com> Acked-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-05-25tmpfs: fix XATTR N overriding POSIX_ACL YEric Paris
Choosing TMPFS_XATTR default N was switching off TMPFS_POSIX_ACL, even if it had been Y in oldconfig; and Linus reports that PulseAudio goes subtly wrong unless it can use ACLs on /dev/shm. Make TMPFS_POSIX_ACL select TMPFS_XATTR (and depend upon TMPFS), and move the TMPFS_POSIX_ACL entry before the TMPFS_XATTR entry, to avoid asking unnecessary questions then ignoring their answers. Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25tmpfs: implement generic xattr supportEric Paris
Implement generic xattrs for tmpfs filesystems. The Feodra project, while trying to replace suid apps with file capabilities, realized that tmpfs, which is used on the build systems, does not support file capabilities and thus cannot be used to build packages which use file capabilities. Xattrs are also needed for overlayfs. The xattr interface is a bit odd. If a filesystem does not implement any {get,set,list}xattr functions the VFS will call into some random LSM hooks and the running LSM can then implement some method for handling xattrs. SELinux for example provides a method to support security.selinux but no other security.* xattrs. As it stands today when one enables CONFIG_TMPFS_POSIX_ACL tmpfs will have xattr handler routines specifically to handle acls. Because of this tmpfs would loose the VFS/LSM helpers to support the running LSM. To make up for that tmpfs had stub functions that did nothing but call into the LSM hooks which implement the helpers. This new patch does not use the LSM fallback functions and instead just implements a native get/set/list xattr feature for the full security.* and trusted.* namespace like a normal filesystem. This means that tmpfs can now support both security.selinux and security.capability, which was not previously possible. The basic implementation is that I attach a: struct shmem_xattr { struct list_head list; /* anchored by shmem_inode_info->xattr_list */ char *name; size_t size; char value[0]; }; Into the struct shmem_inode_info for each xattr that is set. This implementation could easily support the user.* namespace as well, except some care needs to be taken to prevent large amounts of unswappable memory being allocated for unprivileged users. [mszeredi@suse.cz: new config option, suport trusted.*, support symlinks] Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Acked-by: Serge Hallyn <serge.hallyn@ubuntu.com> Tested-by: Serge Hallyn <serge.hallyn@ubuntu.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Acked-by: Hugh Dickins <hughd@google.com> Tested-by: Jordi Pujol <jordipujolp@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-16Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6: [IA64] tioca: Fix assignment from incompatible pointer warnings [IA64] mca.c: Fix cast from integer to pointer warning [IA64] setup.c Typo fix "Architechtuallly" [IA64] Add CONFIG_MISC_DEVICES=y to configs that need it. [IA64] disable interrupts at end of ia64_mca_cpe_int_handler() [IA64] Add DMA_ERROR_CODE define. pstore: fix build warning for unused return value from sysfs_create_file pstore: X86 platform interface using ACPI/APEI/ERST pstore: new filesystem interface to platform persistent storage
2011-03-16Pull pstorev4 into release branchTony Luck
2011-03-15vfs: Add name to file handle conversion supportAneesh Kumar K.V
The syscall also return mount id which can be used to lookup file system specific information such as uuid in /proc/<pid>/mountinfo Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-01-20kconfig: rename CONFIG_EMBEDDED to CONFIG_EXPERTDavid Rientjes
The meaning of CONFIG_EMBEDDED has long since been obsoleted; the option is used to configure any non-standard kernel with a much larger scope than only small devices. This patch renames the option to CONFIG_EXPERT in init/Kconfig and fixes references to the option throughout the kernel. A new CONFIG_EMBEDDED option is added that automatically selects CONFIG_EXPERT when enabled and can be used in the future to isolate options that should only be considered for embedded systems (RISC architectures, SLOB, etc). Calling the option "EXPERT" more accurately represents its intention: only expert users who understand the impact of the configuration changes they are making should enable it. Reviewed-by: Ingo Molnar <mingo@elte.hu> Acked-by: David Woodhouse <david.woodhouse@intel.com> Signed-off-by: David Rientjes <rientjes@google.com> Cc: Greg KH <gregkh@suse.de> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jens Axboe <axboe@kernel.dk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Robin Holt <holt@sgi.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-17fs: FS_POSIX_ACL does not depend on BLOCKRandy Dunlap
- Fix a kconfig unmet dependency warning. - Remove the comment that identifies which filesystems use POSIX ACL utility routines. - Move the FS_POSIX_ACL symbol outside of the BLOCK symbol if/endif block because its functions do not depend on BLOCK and some of the filesystems that use it do not depend on BLOCK. warning: (GENERIC_ACL && JFFS2_FS_POSIX_ACL && NFSD_V4 && NFS_ACL_SUPPORT && 9P_FS_POSIX_ACL) selects FS_POSIX_ACL which has unmet direct dependencies (BLOCK) Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-12-28pstore: new filesystem interface to platform persistent storageTony Luck
Some platforms have a small amount of non-volatile storage that can be used to store information useful to diagnose the cause of a system crash. This is the generic part of a file system interface that presents information from the crash as a series of files in /dev/pstore. Once the information has been seen, the underlying storage is freed by deleting the files. Signed-off-by: Tony Luck <tony.luck@intel.com>
2010-10-28Merge 'staging-next' to Linus's treeGreg Kroah-Hartman
This merges the staging-next tree to Linus's tree and resolves some conflicts that were present due to changes in other trees that were affected by files here. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-27Merge branch 'flock' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bklLinus Torvalds
* 'flock' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl: locks: turn lock_flocks into a spinlock fasync: re-organize fasync entry insertion to allow it under a spinlock locks/nfsd: allocate file lock outside of spinlock lockd: fix nlmsvc_notify_blocked locking lockd: push lock_flocks down
2010-10-27locks: turn lock_flocks into a spinlockArnd Bergmann
Nothing depends on lock_flocks using the BKL any more, so we can do the switch over to a private spinlock. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2010-10-26fs: move exportfs since it is not a networking filesystemRandy Dunlap
Move the EXPORTFS kconfig symbol out of the NETWORK_FILESYSTEMS block since it provides a library function that can be (and is) used by other (non-network) filesystems. This also eliminates a kconfig dependency warning: warning: (XFS_FS && BLOCK || NFSD && NETWORK_FILESYSTEMS && INET && FILE_LOCKING && BKL) selects EXPORTFS which has unmet direct dependencies (NETWORK_FILESYSTEMS) Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Dave Chinner <david@fromorbit.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Alex Elder <aelder@sgi.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-21BKL: introduce CONFIG_BKL.Arnd Bergmann
With all the patches we have queued in the BKL removal tree, only a few dozen modules are left that actually rely on the BKL, and even there are lots of low-hanging fruit. We need to decide what to do about them, this patch illustrates one of the options: Every user of the BKL is marked as 'depends on BKL' in Kconfig, and the CONFIG_BKL becomes a user-visible option. If it gets disabled, no BKL using module can be built any more and the BKL code itself is compiled out. The one exception is file locking, which is practically always enabled and does a 'select BKL' instead. This effectively forces CONFIG_BKL to be enabled until we have solved the fs/lockd mess and can apply the patch that removes the BKL from fs/locks.c. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2010-10-05smbfs: move to drivers/stagingArnd Bergmann
smbfs has been scheduled for removal in 2.6.27, so maybe we can now move it to drivers/staging on the way out. smbfs still uses the big kernel lock and nobody is going to fix that, so we should be getting rid of it soon. This removes the 32 bit compat mount and ioctl handling code, which is implemented in common fs code, and moves all smbfs related files into drivers/staging/smbfs. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-05autofs3: move to drivers/stagingArnd Bergmann
Nobody appears to be interested in fixing autofs3 bugs any more and it uses the BKL, which is going away. Move this to staging for retirement. Unless someone complains until 2.6.38, we can remove it for good. The include/linux/auto_fs.h header file is still used by autofs4, so it remains in place. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Ian Kent <raven@themaw.net> Cc: autofs@linux.kernel.org Cc: "H. Peter Anvin" <hpa@zytor.com> Acked-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-07-20fs/Kconfig: Fix typo Userpace -> UserspaceStephen Boyd
Signed-off-by: Stephen Boyd <bebarino@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-03-19Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: (205 commits) ceph: update for write_inode API change ceph: reset osd after relevant messages timed out ceph: fix flush_dirty_caps race with caps migration ceph: include migrating caps in issued set ceph: fix osdmap decoding when pools include (removed) snaps ceph: return EBADF if waiting for caps on closed file ceph: set osd request message front length correctly ceph: reset front len on return to msgpool; BUG on mismatched front iov ceph: fix snaptrace decoding on cap migration between mds ceph: use single osd op reply msg ceph: reset bits on connection close ceph: remove bogus mds forward warning ceph: remove fragile __map_osds optimization ceph: fix connection fault STANDBY check ceph: invalidate_authorizer without con->mutex held ceph: don't clobber write return value when using O_SYNC ceph: fix client_request_forward decoding ceph: drop messages on unregistered mds sessions; cleanup ceph: fix comments, locking in destroy_inode ceph: move dereference after NULL test ... Fix trivial conflicts in Documentation/ioctl/ioctl-number.txt
2009-11-20[LogFS] add new flash file systemJoern Engel
This is a new flash file system. See Documentation/filesystems/logfs.txt Signed-off-by: Joern Engel <joern@logfs.org>
2009-10-30powerpc: Cleanup Kconfig selection of hugetlbfs supportBenjamin Herrenschmidt
2009-10-29Merge branch 'sh/for-2.6.32' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6 * 'sh/for-2.6.32' of git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: sh: Fix hugetlbfs dependencies for SH-3 && MMU configurations. sh: Document uImage.bin target in archhelp. sh: add uImage.bin target sh: rsk7203 CONFIG_MTD=n fix sh: Check for return_to_handler when unwinding the stack sh: Build fix: define more __movmem* symbols sh: __irq_entry annotate do_IRQ(). Fix up sh/powerpc conflicts in fs/Kconfig
2009-10-27powerpc: Limit hugetlbfs support to PPC64 Book-3S machinesKumar Gala
Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-10-27sh: Fix hugetlbfs dependencies for SH-3 && MMU configurations.Paul Mundt
The hugetlb dependencies presently depend on SUPERH && MMU while the hugetlb page size definitions depend on CPU_SH4 or CPU_SH5. This unfortunately allows SH-3 + MMU configurations to enable hugetlbfs without a corresponding HPAGE_SHIFT definition, resulting in the build blowing up. As SH-3 doesn't support variable page sizes, we tighten up the dependenies a bit to prevent hugetlbfs from being enabled. These days we also have a shiny new SYS_SUPPORTS_HUGETLBFS, so switch to using that rather than adding to the list of corner cases in fs/Kconfig. Reported-by: Kristoffer Ericson <kristoffer.ericson@gmail.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-10-06ceph: Kconfig, MakefileSage Weil
Kconfig options and Makefile. Signed-off-by: Sage Weil <sage@newdream.net>
2009-09-22tmpfs: depend on shmemHugh Dickins
CONFIG_SHMEM off gives you (ramfs masquerading as) tmpfs, even when CONFIG_TMPFS is off: that's a little anomalous, and I'd intended to make more sense of it by removing CONFIG_TMPFS altogether, always enabling its code when CONFIG_SHMEM; but so many defconfigs have CONFIG_SHMEM on CONFIG_TMPFS off that we'd better leave that as is. But there is no point in asking for CONFIG_TMPFS if CONFIG_SHMEM is off: make TMPFS depend on SHMEM, which also prevents TMPFS_POSIX_ACL shmem_acl.o being pointlessly built into the kernel when SHMEM is off. And a selfish change, to prevent the world from being rebuilt when I switch between CONFIG_SHMEM on and off: the only CONFIG_SHMEM in the header files is mm.h shmem_lock() - give that a shmem.c stub instead. Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Acked-by: Matt Mackall <mpm@selenic.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-14fs/Kconfig: move nilfs2 outside misc filesystemsRyusuke Konishi
Some people asked me questions like the following: On Wed, 15 Jul 2009 13:11:21 +0200, Leon Woestenberg wrote: > just wondering, any reasons why NILFS2 is one of the miscellaneous > filesystems and, for example, btrfs, is not in Kconfig? Actually, nilfs is NOT a filesystem came from other operating systems, but a filesystem created purely for Linux. Nor is it a flash filesystem but that for generic block devices. So, this moves nilfs outside the misc category as I responded in LKML "Re: Why does NILFS2 hide under Miscellaneous filesystems?" (Message-Id: <20090716.002526.93465395.ryusuke@osrg.net>). Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2009-07-14fs/Kconfig: move nilfs2 outRyusuke Konishi
fs/Kconfig file was split into individual fs/*/Kconfig files before nilfs was merged. I've found the current config entry of nilfs is tainting the work. Sorry, I didn't notice. This fixes the violation. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Cc: Alexey Dobriyan <adobriyan@gmail.com>
2009-06-22Merge branch 'for-2.6.31' of git://fieldses.org/git/linux-nfsdLinus Torvalds
* 'for-2.6.31' of git://fieldses.org/git/linux-nfsd: (60 commits) SUNRPC: Fix the TCP server's send buffer accounting nfsd41: Backchannel: minorversion support for the back channel nfsd41: Backchannel: cleanup nfs4.0 callback encode routines nfsd41: Remove ip address collision detection case nfsd: optimise the starting of zero threads when none are running. nfsd: don't take nfsd_mutex twice when setting number of threads. nfsd41: sanity check client drc maxreqs nfsd41: move channel attributes from nfsd4_session to a nfsd4_channel_attr struct NFS: kill off complicated macro 'PROC' sunrpc: potential memory leak in function rdma_read_xdr nfsd: minor nfsd_vfs_write cleanup nfsd: Pull write-gathering code out of nfsd_vfs_write nfsd: track last inode only in use_wgather case sunrpc: align cache_clean work's timer nfsd: Use write gathering only with NFSv2 NFSv4: kill off complicated macro 'PROC' NFSv4: do exact check about attribute specified knfsd: remove unreported filehandle stats counters knfsd: fix reply cache memory corruption knfsd: reply cache cleanups ...
