path: root/fs/Makefile
2006-06-26[PATCH] devfs: Remove devfs from the kernel treeGreg Kroah-Hartman
This is the first patch in a series of patches that removes devfs support from the kernel. This patch removes the core devfs code, and its private header file. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-20[PATCH] inotify (1/5): split kernel API from userspace supportAmy Griffis
The following series of patches introduces a kernel API for inotify, making it possible for kernel modules to benefit from inotify's mechanism for watching inodes. With these patches, inotify will maintain for each caller a list of watches (via an embedded struct inotify_watch), where each inotify_watch is associated with a corresponding struct inode. The caller registers an event handler and specifies for which filesystem events their event handler should be called per inotify_watch. Signed-off-by: Amy Griffis <amy.griffis@hp.com> Acked-by: Robert Love <rml@novell.com> Acked-by: John McCutchan <john@johnmccutchan.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-05-17configfs: Make sure configfs_init() is called before consumers.Joel Becker
configfs_init() needs to be called first to register configfs before anyconsumers try to access it. Move up configfs in fs/Makefile to make sure it is initialized early. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-03-31[PATCH] sys_sync_file_range()Andrew Morton
Remove the recently-added LINUX_FADV_ASYNC_WRITE and LINUX_FADV_WRITE_WAIT fadvise() additions, do it in a new sys_sync_file_range() syscall instead. Reasons: - It's more flexible. Things which would require two or three syscalls with fadvise() can be done in a single syscall. - Using fadvise() in this manner is something not covered by POSIX. The patch wires up the syscall for x86. The sycall is implemented in the new fs/sync.c. The intention is that we can move sys_fsync(), sys_fdatasync() and perhaps sys_sync() into there later. Documentation for the syscall is in fs/sync.c. A test app (sync_file_range.c) is in http://www.zip.com.au/~akpm/linux/patches/stuff/ext3-tools.tar.gz. The available-to-GPL-modules do_sync_file_range() is for knfsd: "A COMMIT can say NFS_DATA_SYNC or NFS_FILE_SYNC. I can skip the ->fsync call for NFS_DATA_SYNC which is hopefully the more common." Note: the `async' writeout mode SYNC_FILE_RANGE_WRITE will turn synchronous if the queue is congested. This is trivial to fix: add a new flag bit, set wbc->nonblocking. But I'm not sure that we want to expose implementation details down to that level. Note: it's notable that we can sync an fd which wasn't opened for writing. Same with fsync() and fdatasync()). Note: the code takes some care to handle attempts to sync file contents outside the 16TB offset on 32-bit machines. It makes such attempts appear to succeed, for best 32-bit/64-bit compatibility. Perhaps it should make such requests fail... Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Michael Kerrisk <mtk-manpages@gmx.net> Cc: Ulrich Drepper <drepper@redhat.com> Cc: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-30[PATCH] Introduce sys_splice() system callJens Axboe
This adds support for the sys_splice system call. Using a pipe as a transport, it can connect to files or sockets (latter as output only). From the splice.c comments: "splice": joining two ropes together by interweaving their strands. This is the "extended pipe" functionality, where a pipe is used as an arbitrary in-memory buffer. Think of a pipe as a small kernel buffer that you can use to transfer data from one end to the other. The traditional unix read/write is extended with a "splice()" operation that transfers data buffers to or from a pipe buffer. Named by Larry McVoy, original implementation from Linus, extended by Jens to support splicing to files and fixing the initial implementation bugs. Signed-off-by: Jens Axboe <axboe@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] relay: migrate from relayfs to a generic relay APIJens Axboe
Original patch from Paul Mundt, sysfs parts removed by me since they were broken. Signed-off-by: Jens Axboe <axboe@suse.de>
2006-01-10[PATCH] sanitize building of fs/compat_ioctl.cChristoph Hellwig
Now that all these entries in the arch ioctl32.c files are gone [1], we can build fs/compat_ioctl.c as a normal object and kill tons of cruft. We need a special do_ioctl32_pointer handler for s390 so the compat_ptr call is done. This is not needed but harmless on all other architectures. Also remove some superflous includes in fs/compat_ioctl.c Tested on ppc64. [1] parisc still had it's PPP handler left, which is not fully correct for ppp and besides that ppp uses the generic SIOCPRIV ioctl so it'd kick in for all netdevice users. We can introduce a proper handler in one of the next patch series by adding a compat_ioctl method to struct net_device but for now let's just kill it - parisc doesn't compile in mainline anyway and I don't want this to block this patchset. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Matthew Wilcox <willy@debian.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] drop-pagecacheAndrew Morton
Add /proc/sys/vm/drop_caches. When written to, this will cause the kernel to discard as much pagecache and/or reclaimable slab objects as it can. THis operation requires root permissions. It won't drop dirty data, so the user should run `sync' first. Caveats: a) Holds inode_lock for exorbitant amounts of time. b) Needs to be taught about NUMA nodes: propagate these all the way through so the discarding can be controlled on a per-node basis. This is a debugging feature: useful for getting consistent results between filesystem benchmarks. We could possibly put it under a config option, but it's less than 300 bytes. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-03[PATCH] OCFS2: The Second Oracle Cluster FilesystemMark Fasheh
Link the code into the kernel build system. OCFS2 is marked as experimental. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com> Signed-off-by: Kurt Hackel <kurt.hackel@oracle.com>
2006-01-03[PATCH] configfs: User-driven configuration filesystemJoel Becker
Configfs, a file system for userspace-driven kernel object configuration. The OCFS2 stack makes extensive use of this for propagation of cluster configuration information into kernel. Signed-off-by: Joel Becker <joel.becker@oracle.com>
2005-11-07[PATCH] beginning of the shared-subtree properRam Pai
A private mount does not forward or receive propagation. This patch provides user the ability to convert any mount to private. Signed-off-by: Ram Pai <linuxram@us.ibm.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] FUSE - MAINTAINERS, Kconfig and Makefile changesMiklos Szeredi
This patch adds FUSE filesystem to MAINTAINERS, fs/Kconfig and fs/Makefile. Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] v9fs: Documentation, Makefiles, ConfigurationEric Van Hensbergen
OVERVIEW V9FS is a distributed file system for Linux which provides an implementation of the Plan 9 resource sharing protocol 9P. It can be used to share all sorts of resources: static files, synthetic file servers (such as /proc or /sys), devices, and application file servers (such as FUSE). BACKGROUND Plan 9 (http://plan9.bell-labs.com/plan9) is a research operating system and associated applications suite developed by the Computing Science Research Center of AT&T Bell Laboratories (now a part of Lucent Technologies), the same group that developed UNIX , C, and C++. Plan 9 was initially released in 1993 to universities, and then made generally available in 1995. Its core operating systems code laid the foundation for the Inferno Operating System released as a product by Lucent Bell-Labs in 1997. The Inferno venture was the only commercial embodiment of Plan 9 and is currently maintained as a product by Vita Nuova (http://www.vitanuova.com). After updated releases in 2000 and 2002, Plan 9 was open-sourced under the OSI approved Lucent Public License in 2003. The Plan 9 project was started by Ken Thompson and Rob Pike in 1985. Their intent was to explore potential solutions to some of the shortcomings of UNIX in the face of the widespread use of high-speed networks to connect machines. In UNIX, networking was an afterthought and UNIX clusters became little more than a network of stand-alone systems. Plan 9 was designed from first principles as a seamless distributed system with integrated secure network resource sharing. Applications and services were architected in such a way as to allow for implicit distribution across a cluster of systems. Configuring an environment to use remote application components or services in place of their local equivalent could be achieved with a few simple command line instructions. For the most part, application implementations operated independent of the location of their actual resources. Commercial operating systems haven't changed much in the 20 years since Plan 9 was conceived. Network and distributed systems support is provided by a patchwork of middle-ware, with an endless number of packages supplying pieces of the puzzle. Matters are complicated by the use of different complicated protocols for individual services, and separate implementations for kernel and application resources. The V9FS project (http://v9fs.sourceforge.net) is an attempt to bring Plan 9's unified approach to resource sharing to Linux and other operating systems via support for the 9P2000 resource sharing protocol. V9FS HISTORY V9FS was originally developed by Ron Minnich and Maya Gokhale at Los Alamos National Labs (LANL) in 1997. In November of 2001, Greg Watson setup a SourceForge project as a public repository for the code which supported the Linux 2.4 kernel. About a year ago, I picked up the initial attempt Ron Minnich had made to provide 2.6 support and got the code integrated into a 2.6.5 kernel. I then went through a line-for-line re-write attempting to clean-up the code while more closely following the Linux Kernel style guidelines. I co-authored a paper with Ron Minnich on the V9FS Linux support including performance comparisons to NFSv3 using Bonnie and PostMark - this paper appeared at the USENIX/FREENIX 2005 conference in April 2005: ( http://www.usenix.org/events/usenix05/tech/freenix/hensbergen.html ). CALL FOR PARTICIPATION/REQUEST FOR COMMENTS Our 2.6 kernel support is stabilizing and we'd like to begin pursuing its integration into the official kernel tree. We would appreciate any review, comments, critiques, and additions from this community and are actively seeking people to join our project and help us produce something that would be acceptable and useful to the Linux community. STATUS The code is reasonably stable, although there are no doubt corner cases our regression tests haven't discovered yet. It is in regular use by several of the developers and has been tested on x86 and PowerPC (32-bit and 64-bit) in both small and large (LANL cluster) deployments. Our current regression tests include fsx, bonnie, and postmark. It was our intention to keep things as simple as possible for this release -- trying to focus on correctness within the core of the protocol support versus a rich set of features. For example: a more complete security model and cache layer are in the road map, but excluded from this release. Additionally, we have removed support for mmap operations at Al Viro's request. PERFORMANCE Detailed performance numbers and analysis are included in the FREENIX paper, but we show comparable performance to NFSv3 for large file operations based on the Bonnie benchmark, and superior performance for many small file operations based on the PostMark benchmark. Somewhat preliminary graphs (from the FREENIX paper) are available (http://v9fs.sourceforge.net/perf/index.html). RESOURCES The source code is available in a few different forms: tarballs: http://v9fs.sf.net CVSweb: http://cvs.sourceforge.net/viewcvs.py/v9fs/linux-9p/ CVS: :pserver:anonymous@cvs.sourceforge.net:/cvsroot/v9fs/linux-9p Git: rsync://v9fs.graverobber.org/v9fs (webgit: http://v9fs.graverobber.org) 9P: tcp!v9fs.graverobber.org!6564 The user-level server is available from either the Plan 9 distribution or from http://v9fs.sf.net Other support applications are still being developed, but preliminary version can be downloaded from sourceforge. Documentation on the protocol has historically been the Plan 9 Man pages (http://plan9.bell-labs.com/sys/man/5/INDEX.html), but there is an effort under way to write a more complete Internet-Draft style specification (http://v9fs.sf.net/rfc). There are a couple of mailing lists supporting v9fs, but the most used is v9fs-developer@lists.sourceforge.net -- please direct/cc your comments there so the other v9fs contibutors can participate in the conversation. There is also an IRC channel: irc://freenode.net/#v9fs This part of the patch contains Documentation, Makefiles, and configuration file changes. Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] relayfsTom Zanussi
Here's the latest version of relayfs, against linux-2.6.11-mm2. I'm hoping you'll consider putting this version back into your tree - the previous rounds of comment seem to have shaken out all the API issues and the number of comments on the code itself have also steadily dwindled. This patch is essentially the same as the relayfs redux part 5 patch, with some minor changes based on reviewer comments. Thanks again to Pekka Enberg for those. The patch size without documentation is now a little smaller at just over 40k. Here's a detailed list of the changes: - removed the attribute_flags in relay open and changed it to a boolean specifying either overwrite or no-overwrite mode, and removed everything referencing the attribute flags. - added a check for NULL names in relayfs_create_entry() - got rid of the unnecessary multiple labels in relay_create_buf() - some minor simplification of relay_alloc_buf() which got rid of a couple params - updated the Documentation In addition, this version (through code contained in the relay-apps tarball linked to below, not as part of the relayfs patch) tries to make it as easy as possible to create the cooperating kernel/user pieces of a typical and common type of logging application, one where kernel logging is kicked off when a user space data collection app starts and stops when the collection app exits, with the data being automatically logged to disk in between. To create this type of application, you basically just include a header file (relay-app.h, included in the relay-apps tarball) in your kernel module, define a couple of callbacks and call an initialization function, and on the user side call a single function that sets up and continuously monitors the buffers, and writes data to files as it becomes available. Channels are created when the collection app is started and destroyed when it exits, not when the kernel module is inserted, so different channel buffer sizes can be specified for each separate run via command-line options. See the README in the relay-apps tarball for details. Also included in the relay-apps tarball are a couple examples demonstrating how you can use this to create quick and dirty kernel logging/debugging applications. They are: - tprintk, short for 'tee printk', which temporarily puts a kprobe on printk() and writes a duplicate stream of printk output to a relayfs channel. This could be used anywhere there's printk() debugging code in the kernel which you'd like to exercise, but would rather not have your system logs cluttered with debugging junk. You'd probably want to kill klogd while you do this, otherwise there wouldn't be much point (since putting a kprobe on printk() doesn't change the output of printk()). I've used this method to temporarily divert the packet logging output of the iptables LOG target from the system logs to relayfs files instead, for instance. - klog, which just provides a printk-like formatted logging function on top of relayfs. Again, you can use this to keep stuff out of your system logs if used in place of printk. The example applications can be found here: http://prdownloads.sourceforge.net/dprobes/relay-apps.tar.gz?download From: Christoph Hellwig <hch@lst.de> avoid lookup_hash usage in relayfs Signed-off-by: Tom Zanussi <zanussi@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-12[PATCH] inotifyRobert Love
inotify is intended to correct the deficiencies of dnotify, particularly its inability to scale and its terrible user interface: * dnotify requires the opening of one fd per each directory that you intend to watch. This quickly results in too many open files and pins removable media, preventing unmount. * dnotify is directory-based. You only learn about changes to directories. Sure, a change to a file in a directory affects the directory, but you are then forced to keep a cache of stat structures. * dnotify's interface to user-space is awful. Signals? inotify provides a more usable, simple, powerful solution to file change notification: * inotify's interface is a system call that returns a fd, not SIGIO. You get a single fd, which is select()-able. * inotify has an event that says "the filesystem that the item you were watching is on was unmounted." * inotify can watch directories or files. Inotify is currently used by Beagle (a desktop search infrastructure), Gamin (a FAM replacement), and other projects. See Documentation/filesystems/inotify.txt. Signed-off-by: Robert Love <rml@novell.com> Cc: John McCutchan <ttb@tentacle.dhs.org> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-27[PATCH] Update cfq io scheduler to time sliced designJens Axboe
This updates the CFQ io scheduler to the new time sliced design (cfq v3). It provides full process fairness, while giving excellent aggregate system throughput even for many competing processes. It supports io priorities, either inherited from the cpu nice value or set directly with the ioprio_get/set syscalls. The latter closely mimic set/getpriority. This import is based on my latest from -mm. Signed-off-by: Jens Axboe <axboe@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-22[PATCH] NFSD: Add server support for NFSv3 ACLs.Andreas Gruenbacher
This adds functions for encoding and decoding POSIX ACLs for the NFSACL protocol extension, and the GETACL and SETACL RPCs. The implementation is compatible with NFSACL in Solaris. Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Acked-by: Olaf Kirch <okir@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
