path: root/fs/affs
2016-06-07affs: fix remount failure when there are no options changedMikulas Patocka
commit 01d6e08711bf90bc4d7ead14a93a0cbd73b1896a upstream. Commit c8f33d0bec99 ("affs: kstrdup() memory handling") checks if the kstrdup function returns NULL due to out-of-memory condition. However, if we are remounting a filesystem with no change to filesystem-specific options, the parameter data is NULL. In this case, kstrdup returns NULL (because it was passed NULL parameter), although no out of memory condition exists. The mount syscall then fails with ENOMEM. This patch fixes the bug. We fail with ENOMEM only if data is non-NULL. The patch also changes the call to replace_mount_options - if we didn't pass any filesystem-specific options, we don't call replace_mount_options (thus we don't erase existing reported options). Fixes: c8f33d0bec99 ("affs: kstrdup() memory handling") Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-09-10fs/affs: make root lookup from blkdev logical sizePranay Kr. Srivastava
This patch resolves https://bugzilla.kernel.org/show_bug.cgi?id=16531. When logical blkdev size > 512 then sector numbers become larger than the device can support. Make affs start lookup based on the device's logical sector size instead of 512. Reported-by: Mark <markk@clara.co.uk> Suggested-by: Mark <markk@clara.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-07-04Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull more vfs updates from Al Viro: "Assorted VFS fixes and related cleanups (IMO the most interesting in that part are f_path-related things and Eric's descriptor-related stuff). UFS regression fixes (it got broken last cycle). 9P fixes. fs-cache series, DAX patches, Jan's file_remove_suid() work" [ I'd say this is much more than "fixes and related cleanups". The file_table locking rule change by Eric Dumazet is a rather big and fundamental update even if the patch isn't huge. - Linus ] * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (49 commits) 9p: cope with bogus responses from server in p9_client_{read,write} p9_client_write(): avoid double p9_free_req() 9p: forgetting to cancel request on interrupted zero-copy RPC dax: bdev_direct_access() may sleep block: Add support for DAX reads/writes to block devices dax: Use copy_from_iter_nocache dax: Add block size note to documentation fs/file.c: __fget() and dup2() atomicity rules fs/file.c: don't acquire files->file_lock in fd_install() fs:super:get_anon_bdev: fix race condition could cause dev exceed its upper limitation vfs: avoid creation of inode number 0 in get_next_ino namei: make set_root_rcu() return void make simple_positive() public ufs: use dir_pages instead of ufs_dir_pages() pagemap.h: move dir_pages() over there remove the pointless include of lglock.h fs: cleanup slight list_entry abuse xfs: Correctly lock inode when removing suid and file capabilities fs: Call security_ops->inode_killpriv on truncate fs: Provide function telling whether file_remove_privs() will do anything ...
2015-06-30fs/affs/symlink.c: remove unneeded err variableFabian Frederick
err is only assigned to -EIO. Return that value at the end of fail context. Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30fs/affs/amigaffs.c: remove unneeded initializationFabian Frederick
bh is initialized unconditionally in affs_remove_link() Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30fs/affs/inode.c: remove unneeded initializationFabian Frederick
bh is initialized unconditionally in affs_add_entry() Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-23fs: cleanup slight list_entry abuseRasmus Villemoes
list_entry is just a wrapper for container_of, but it is arguably wrong (and slightly confusing) to use it when the pointed-to struct member is not a struct list_head. Use container_of directly instead. Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-04-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull fourth vfs update from Al Viro: "d_inode() annotations from David Howells (sat in for-next since before the beginning of merge window) + four assorted fixes" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: RCU pathwalk breakage when running into a symlink overmounting something fix I_DIO_WAKEUP definition direct-io: only inc/dec inode->i_dio_count for file systems fs/9p: fix readdir() VFS: assorted d_backing_inode() annotations VFS: fs/inode.c helpers: d_inode() annotations VFS: fs/cachefiles: d_backing_inode() annotations VFS: fs library helpers: d_inode() annotations VFS: assorted weird filesystems: d_inode() annotations VFS: normal filesystems (and lustre): d_inode() annotations VFS: security/: d_inode() annotations VFS: security/: d_backing_inode() annotations VFS: net/: d_inode() annotations VFS: net/unix: d_backing_inode() annotations VFS: kernel/: d_inode() annotations VFS: audit: d_backing_inode() annotations VFS: Fix up some ->d_inode accesses in the chelsio driver VFS: Cachefiles should perform fs modifications on the top layer only VFS: AF_UNIX sockets should call mknod on the top layer only
2015-04-17Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge third patchbomb from Andrew Morton: - various misc things - a couple of lib/ optimisations - provide DIV_ROUND_CLOSEST_ULL() - checkpatch updates - rtc tree - befs, nilfs2, hfs, hfsplus, fatfs, adfs, affs, bfs - ptrace fixes - fork() fixes - seccomp cleanups - more mmap_sem hold time reductions from Davidlohr * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (138 commits) proc: show locks in /proc/pid/fdinfo/X docs: add missing and new /proc/PID/status file entries, fix typos drivers/rtc/rtc-at91rm9200.c: make IO endian agnostic Documentation/spi/spidev_test.c: fix warning drivers/rtc/rtc-s5m.c: allow usage on device type different than main MFD type .gitignore: ignore *.tar MAINTAINERS: add Mediatek SoC mailing list tomoyo: reduce mmap_sem hold for mm->exe_file powerpc/oprofile: reduce mmap_sem hold for exe_file oprofile: reduce mmap_sem hold for mm->exe_file mips: ip32: add platform data hooks to use DS1685 driver lib/Kconfig: fix up HAVE_ARCH_BITREVERSE help text x86: switch to using asm-generic for seccomp.h sparc: switch to using asm-generic for seccomp.h powerpc: switch to using asm-generic for seccomp.h parisc: switch to using asm-generic for seccomp.h mips: switch to using asm-generic for seccomp.h microblaze: use asm-generic for seccomp.h arm: use asm-generic for seccomp.h seccomp: allow COMPAT sigreturn overrides ...
2015-04-17affs: kstrdup() memory handlingSanidhya Kashyap
There is a possibility of kstrdup() failure upon memory pressure. Therefore, returning ENOMEM even for new_opts. [akpm@linux-foundation.org: cleanup] Signed-off-by: Sanidhya Kashyap <sanidhya.gatech@gmail.com> Cc: Taesoo kim <taesoo@gatech.edu> Cc: Fabian Frederick <fabf@skynet.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-17fs/affs: use affs_test_opt()Fabian Frederick
Replace mount option test by affs_test_opt(). Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-17fs/affs/super.c: use affs_set_opt()Fabian Frederick
Replace direct mount option assignation by affs_set_opt() macro. Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-17fs/affs/affs.h: add mount option manipulation macrosFabian Frederick
Add clear/set/test affs mount option macros. Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-17fs/affs: use AFFS_MOUNT prefix for mount optionsFabian Frederick
Currently, affs still uses direct access on mount_options. This patch prepares to use affs_clear/set/test_opt() like other filesystems. Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-15VFS: normal filesystems (and lustre): d_inode() annotationsDavid Howells
that's the bulk of filesystem drivers dealing with inodes of their own Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-04-11direct_IO: remove rw from a_ops->direct_IO()Omar Sandoval
Now that no one is using rw, remove it completely. Signed-off-by: Omar Sandoval <osandov@osandov.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-04-11direct_IO: use iov_iter_rw() instead of rw everywhereOmar Sandoval
The rw parameter to direct_IO is redundant with iov_iter->type, and treated slightly differently just about everywhere it's used: some users do rw & WRITE, and others do rw == WRITE where they should be doing a bitwise check. Simplify this with the new iov_iter_rw() helper, which always returns either READ or WRITE. Signed-off-by: Omar Sandoval <osandov@osandov.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-04-11Remove rw from {,__,do_}blockdev_direct_IO()Omar Sandoval
Most filesystems call through to these at some point, so we'll start here. Signed-off-by: Omar Sandoval <osandov@osandov.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-04-11make new_sync_{read,write}() staticAl Viro
All places outside of core VFS that checked ->read and ->write for being NULL or called the methods directly are gone now, so NULL {read,write} with non-NULL {read,write}_iter will do the right thing in all cases. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-04-09Merge branch 'iocb' into for-davemAl Viro
trivial conflict in net/socket.c and non-trivial one in crypto - that one had evaded aio_complete() removal. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-03-25fs: move struct kiocb to fs.hChristoph Hellwig
struct kiocb now is a generic I/O container, so move it to fs.h. Also do a #include diet for aio.h while we're at it. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-03-25fs/affs/file.c: unlock/release page on errorTaesoo Kim
When affs_bread_ino() fails, correctly unlock the page and release the page cache with proper error value. All write_end() should unlock/release the page that was locked by write_beg(). Signed-off-by: Taesoo Kim <tsgatesv@gmail.com> Cc: Fabian Frederick <fabf@skynet.be> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-17fs/affs/super.c: fix switch indentationFabian Frederick
Fix checkpatch error: ERROR: switch and case should be at the same indent Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-17fs/affs/inode.c: remove double extern affs_symlink_inode_operationsFabian Frederick
affs_symlink_inode_operations was already declared extern in affs.h Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-17fs/affs/bitmap.c: remove unnecessary returnFabian Frederick
return is not needed at the end of function. Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-17fs/affs/amigaffs.c: remove else after returnFabian Frederick
else is unnecessary after return -ENAMETOOLONG Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-17fs/affs: define AFFSNAMEMAX to replace constant useFabian Frederick
30 was used all over the place to compare name length against AFFS maximum name length. Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-17fs/affs: use unsigned int for string lengthsFabian Frederick
- Some min() were used with different types. - Create a new variable in __affs_hash_dentry() to process affs_check_name()/min() return Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-17fs/affs/super.c: destroy sbi mutex in affs_kill_sb()Fabian Frederick
Call mutex_destroy() on superblock mutex in affs_kill_sb() otherwise mutex debugging code isn't able to detect that mutex is used after being freed. (thanks to Jan Kara for complete definition). Signed-off-by: Fabian Frederick <fabf@skynet.be> Cc: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-17fs/affs/file.c: fix direct IO writes beyond EOFFabian Frederick
Use the same fallback to normal IO in case of write operations beyond EOF as fat direct IO. This patch fixes fsx file -d -Z -r 4096 -w 4096 Report: 129(129 mod 256): TRUNCATE DOWN from 0x3ff01 to 0xb3f6 130(130 mod 256): WRITE 0x22000 thru 0x2dfff (0xc000 bytes) HOLE Thanks to Jan for helping me on this problem. The ideal solution suggested by Jan Kara would be to use cont_write_begin() but affs direct_IO shouldn't be used a lot anyway... Signed-off-by: Fabian Frederick <fabf@skynet.be> Reviewed-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-17fs/affs/file.c: replace if/BUG by BUG_ONFabian Frederick
2015-02-17fs/affs: fix casting in printed messagesGeert Uytterhoeven
- "inode.i_ino" is "unsigned long", - "loff_t" is always "unsigned long long", - "sector_t" should be cast to "unsigned long long" for printing, - "u32" should not be cast to "unsigned int" for printing. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-12-13fs/affs/file.c: remove obsolete pagesize checkFabian Frederick
linux kernel doesn't manage page sizes below 4kb. Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-12-13fs/affs/file.c: add support to O_DIRECTFabian Frederick
Based on ext2_direct_IO Tested with O_DIRECT file open and sysbench/mariadb with 1% written queries improvement (update_non_index test) on a volume created with mkaffs. Signed-off-by: Fabian Frederick <fabf@skynet.be> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-12-13fs/affs/amigaffs.c: use va_format instead of buffer/vnsprintfFabian Frederick
-Remove ErrorBuffer and use %pV -Add __printf to enable argument mistmatch warnings Original patch by Joe Perches. Signed-off-by: Fabian Frederick <fabf@skynet.be> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-12-13fs/affs/file.c: forward declaration clean-upFabian Frederick
-Move file_operations to avoid forward declarations. -Remove unused declarations. Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-11-19assorted conversions to %p[dD]Al Viro
2014-11-03move d_rcu from overlapping d_child to overlapping d_aliasAl Viro
2014-10-14fs/affs: remove redundant sys_tz declarationsFabian Frederick
sys_tz is already declared in include/linux/time.h Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-14fs/affs/file.c: fix shadow warningsFabian Frederick
Four functions declared variables twice resulting in shadow warnings. This patch renames internal variables and adds blank line after declarations. Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-14fs/affs/inode.c: remove unused variableFabian Frederick
head is set to AFFS_HEAD(bh) but never used. Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-14fs/affs/super.c: remove unused variableFabian Frederick
key is set in affs_fill_super but never used. Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs updates from Al Viro: "This the bunch that sat in -next + lock_parent() fix. This is the minimal set; there's more pending stuff. In particular, I really hope to get acct.c fixes merged this cycle - we need that to deal sanely with delayed-mntput stuff. In the next pile, hopefully - that series is fairly short and localized (kernel/acct.c, fs/super.c and fs/namespace.c). In this pile: more iov_iter work. Most of prereqs for ->splice_write with sane locking order are there and Kent's dio rewrite would also fit nicely on top of this pile" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (70 commits) lock_parent: don't step on stale ->d_parent of all-but-freed one kill generic_file_splice_write() ceph: switch to iter_file_splice_write() shmem: switch to iter_file_splice_write() nfs: switch to iter_splice_write_file() fs/splice.c: remove unneeded exports ocfs2: switch to iter_file_splice_write() ->splice_write() via ->write_iter() bio_vec-backed iov_iter optimize copy_page_{to,from}_iter() bury generic_file_aio_{read,write} lustre: get rid of messing with iovecs ceph: switch to ->write_iter() ceph_sync_direct_write: stop poking into iov_iter guts ceph_sync_read: stop poking into iov_iter guts new helper: copy_page_from_iter() fuse: switch to ->write_iter() btrfs: switch to ->write_iter() ocfs2: switch to ->write_iter() xfs: switch to ->write_iter() ...
2014-06-06fs/affs: pr_debug cleanupFabian Frederick
- Remove AFFS: prefix (defined in pr_fmt) - Use __func__ - Separate format/arguments on lines > 80 characters. Signed-off-by: Fabian Frederick <fabf@skynet.be> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-06fs/affs: convert printk to pr_foo()Fabian Frederick
-All printk(KERN_foo converted to pr_foo() -Default printk converted to pr_warn() -Add pr_fmt to affs.h Signed-off-by: Fabian Frederick <fabf@skynet.be> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-06fs/affs/file.c: remove unnecessary function parametersFabian Frederick
- affs_do_readpage_ofs is always called with from = 0 ie reading from page->index - File parameter is never used Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-05-06write_iter variants of {__,}generic_file_aio_write()Al Viro
2014-05-06switch simple generic_file_aio_read() users to ->read_iter()Al Viro
2014-05-06fs/affs/super.c: bugfix / double freeFabian Frederick
Commit 842a859db26b ("affs: use ->kill_sb() to simplify ->put_super() and failure exits of ->mount()") adds .kill_sb which frees sbi but doesn't remove sbi free in case of parse_options error causing double free+random crash. Signed-off-by: Fabian Frederick <fabf@skynet.be> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: <stable@vger.kernel.org> [3.14.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-07affs: add mount option to avoid filename truncatesFabian Frederick
Normal behavior for filenames exceeding specific filesystem limits is to refuse operation. AFFS standard name length being only 30 characters against 255 for usual Linux filesystems, original implementation does filename truncate by default with a define value AFFS_NO_TRUNCATE which can be enabled but needs module compilation. This patch adds 'nofilenametruncate' mount option so that user can easily activate that feature and avoid a lot of problems (eg overwrite files ...) Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
