path: root/fs/affs
2012-07-30affs: use memweight()Akinobu Mita
Use memweight() to count the total number of bits set in memory area. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-14don't pass nameidata to ->create()Al Viro
boolean "does it have to be exclusive?" flag is passed instead; Local filesystem should just ignore it - the object is guaranteed not to be there yet. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-14stop passing nameidata to ->lookup()Al Viro
Just the flags; only NFS cares even about that, but there are legitimate uses for such argument. And getting rid of that completely would require splitting ->lookup() into a couple of methods (at least), so let's leave that alone for now... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-14vfs: switch i_dentry/d_alias to hlistAl Viro
2012-07-14affs: unobfuscate affs_fix_dcache()Al Viro
and add a comment on what it's doing Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-14affs: get rid of open-coded list_for_each_entry()Al Viro
2012-07-14affs: get rid of affs_sync_superArtem Bityutskiy
This patch makes affs stop using the VFS '->write_super()' method along with the 's_dirt' superblock flag, because they are on their way out. The whole "superblock write-out" VFS infrastructure is served by the 'sync_supers()' kernel thread, which wakes up every 5 (by default) seconds and writes out all dirty superblocks using the '->write_super()' call-back. But the problem with this thread is that it wastes power by waking up the system every 5 seconds, even if there are no diry superblocks, or there are no client file-systems which would need this (e.g., btrfs does not use '->write_super()'). So we want to kill it completely and thus, we need to make file-systems to stop using the '->write_super()' VFS service, and then remove it together with the kernel thread. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-14affs: introduce VFS superblock object back-referenceArtem Bityutskiy
Add an 'sb' VFS superblock back-reference to the 'struct affs_sb_info' data structure - we will need to find the VFS superblock from a 'struct affs_sb_info' object in the next patch, so this change is jut a preparation. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-14affs: stop using lock_superArtem Bityutskiy
The VFS's 'lock_super()' and 'unlock_super()' calls are deprecated and unwanted and just wait for a brave knight who'd kill them. This patch makes AFFS stop using them and use the buffer-head's own lock instead. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-14affs: re-structure superblock locking a bitArtem Bityutskiy
AFFS wants to serialize the superblock (the root block in AFFS terms) updates and uses 'lock_super()/unlock_super()' for these purposes. This patch pushes the locking down to the 'affs_commit_super()' from the callers. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-14affs: remove useless superblock writeout on remountArtem Bityutskiy
We do not need to write out the superblock from '->remount_fs()' because VFS has already called '->sync_fs()' by this time and the superblock has already been written out. Thus, remove the 'affs_write_super()' infocation from 'affs_remount()'. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-14affs: remove useless superblock writeout on unmountArtem Bityutskiy
We do not need to write out the superblock from '->put_super()' because VFS has already called '->sync_fs()' by this time and the superblock has already been written out. Thus, remove the 'affs_commit_super()' infocation from 'affs_put_super()'. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-14affs: stop setting bm_flagsArtem Bityutskiy
AFFS stores values '1' and '2' in 'bm_flags', and I fail to see any logic when it prefers one or another. AFFS writes '1' only from '->put_super()', while '->sync_fs()' and '->write_super()' store value '2'. So on the first glance, it looks like we want to have '1' if we unmount. However, this does not really happen in these cases: 1. superblock is written via 'write_super()' then we unmount; 2. we re-mount R/O, then unmount. which are quite typical. I could not find good documentation describing this field, except of one random piece of documentation in the internet which says that -1 means that the root block is valid, which is not consistent with what we have in the Linux AFFS driver. Jan Kara commented on this: "I have some vague recollection that on Amiga boolean was usually encoded as: 0 == false, ~0 == -1 == true. But it has been ages..." Thus, my conclusion is that value of '1' is as good as value of '2' and we can just always use '2'. An Jan Kara suggested to go further: "generally bm_flags handling looks strange. If they are 0, we mount fs read only and thus cannot change them. If they are != 0, we write 2 there. So IMHO if you just removed bm_flags setting, nothing will really happen." So this patch removes the bm_flags setting completely. This makes the "clean" argument of the 'affs_commit_super()' function unneeded, so it is also removed. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-05-29affs: bury unused macrosAl Viro
... unused since 2.4.4. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-05-06vfs: Rename end_writeback() to clear_inode()Jan Kara
After we moved inode_sync_wait() from end_writeback() it doesn't make sense to call the function end_writeback() anymore. Rename it to clear_inode() which well says what the function really does - set I_CLEAR flag. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Fengguang Wu <fengguang.wu@intel.com>
2012-03-20switch open-coded instances of d_make_root() to new helperAl Viro
2012-01-03affs: propagate umode_tAl Viro
2012-01-03switch ->create() to umode_tAl Viro
vfs_create() ignores everything outside of 16bit subset of its mode argument; switching it to umode_t is obviously equivalent and it's the only caller of the method Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-01-03switch vfs_mkdir() and ->mkdir() to umode_tAl Viro
vfs_mkdir() gets int, but immediately drops everything that might not fit into umode_t and that's the only caller of ->mkdir()... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-01-03vfs: fix the stupidity with i_dentry in inode destructorsAl Viro
Seeing that just about every destructor got that INIT_LIST_HEAD() copied into it, there is no point whatsoever keeping this INIT_LIST_HEAD in inode_init_once(); the cost of taking it into inode_init_always() will be negligible for pipes and sockets and negative for everything else. Not to mention the removal of boilerplate code from ->destroy_inode() instances... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-11-02filesystems: add set_nlink()Miklos Szeredi
Replace remaining direct i_nlink updates with a new set_nlink() updater function. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Tested-by: Toshiyuki Okajima <toshi.okajima@jp.fujitsu.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2011-11-02filesystems: add missing nlink wrappersMiklos Szeredi
Replace direct i_nlink updates with the respective updater function (inc_nlink, drop_nlink, clear_nlink, inode_dec_link_count). Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2011-07-20fs: push i_mutex and filemap_write_and_wait down into ->fsync() handlersJosef Bacik
Btrfs needs to be able to control how filemap_write_and_wait_range() is called in fsync to make it less of a painful operation, so push down taking i_mutex and the calling of filemap_write_and_wait() down into the ->fsync() handlers. Some file systems can drop taking the i_mutex altogether it seems, like ext3 and ocfs2. For correctness sake I just pushed everything down in all cases to make sure that we keep the current behavior the same for everybody, and then each individual fs maintainer can make up their mind about what to do from there. Thanks, Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-05-28affs: remove unnecessary dentry_unhash on rmdir, dir renameSage Weil
affs has no problems with references to unlinked directories. Signed-off-by: Sage Weil <sage@newdream.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-05-26vfs: push dentry_unhash on rename_dir into file systemsSage Weil
Only a few file systems need this. Start by pushing it down into each rename method (except gfs2 and xfs) so that it can be dealt with on a per-fs basis. Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Sage Weil <sage@newdream.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-05-26vfs: push dentry_unhash on rmdir into file systemsSage Weil
Only a few file systems need this. Start by pushing it down into each fs rmdir method (except gfs2 and xfs) so it can be dealt with on a per-fs basis. This does not change behavior for any in-tree file systems. Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Sage Weil <sage@newdream.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-24Merge branch 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-block: (65 commits) Documentation/iostats.txt: bit-size reference etc. cfq-iosched: removing unnecessary think time checking cfq-iosched: Don't clear queue stats when preempt. blk-throttle: Reset group slice when limits are changed blk-cgroup: Only give unaccounted_time under debug cfq-iosched: Don't set active queue in preempt block: fix non-atomic access to genhd inflight structures block: attempt to merge with existing requests on plug flush block: NULL dereference on error path in __blkdev_get() cfq-iosched: Don't update group weights when on service tree fs: assign sb->s_bdi to default_backing_dev_info if the bdi is going away block: Require subsystems to explicitly allocate bio_set integrity mempool jbd2: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging jbd: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging fs: make fsync_buffers_list() plug mm: make generic_writepages() use plugging blk-cgroup: Add unaccounted time to timeslice_used. block: fixup plugging stubs for !CONFIG_BLOCK block: remove obsolete comments for blkdev_issue_zeroout. blktrace: Use rq->cmd_flags directly in blk_add_trace_rq. ... Fix up conflicts in fs/{aio.c,super.c}
2011-03-17fs: change to new flag variablematt mooney
Replace EXTRA_CFLAGS with ccflags-y. And change ntfs-objs to ntfs-y for cleaner conditional inclusion. Signed-off-by: matt mooney <mfm@muteddisk.com> Acked-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-03-10block: remove per-queue pluggingJens Axboe
Code has been converted over to the new explicit on-stack plugging, and delay users have been converted to use the new API for that. So lets kill off the old plugging along with aops->sync_page(). Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-01-12switch affsAl Viro
either d_op instance would work for root, actually... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-01-07fs: dcache per-inode inode alias lockingNick Piggin
dcache_inode_lock can be replaced with per-inode locking. Use existing inode->i_lock for this. This is slightly non-trivial because we sometimes need to find the inode from the dentry, which requires d_inode to be stabilised (either with refcount or d_lock). Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: dcache reduce branches in lookup pathNick Piggin
Reduce some branches and memory accesses in dcache lookup by adding dentry flags to indicate common d_ops are set, rather than having to check them. This saves a pointer memory access (dentry->d_op) in common path lookup situations, and saves another pointer load and branch in cases where we have d_op but not the particular operation. Patched with: git grep -E '[.>]([[:space:]])*d_op([[:space:]])*=' | xargs sed -e 's/\([^\t ]*\)->d_op = \(.*\);/d_set_d_op(\1, \2);/' -e 's/\([^\t ]*\)\.d_op = \(.*\);/d_set_d_op(\&\1, \2);/' -i Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: icache RCU free inodesNick Piggin
RCU free the struct inode. This will allow: - Subsequent store-free path walking patch. The inode must be consulted for permissions when walking, so an RCU inode reference is a must. - sb_inode_list_lock to be moved inside i_lock because sb list walkers who want to take i_lock no longer need to take sb_inode_list_lock to walk the list in the first place. This will simplify and optimize locking. - Could remove some nested trylock loops in dcache code - Could potentially simplify things a bit in VM land. Do not need to take the page lock to follow page->mapping. The downsides of this is the performance cost of using RCU. In a simple creat/unlink microbenchmark, performance drops by about 10% due to inability to reuse cache-hot slab objects. As iterations increase and RCU freeing starts kicking over, this increases to about 20%. In cases where inode lifetimes are longer (ie. many inodes may be allocated during the average life span of a single inode), a lot of this cache reuse is not applicable, so the regression caused by this patch is smaller. The cache-hot regression could largely be avoided by using SLAB_DESTROY_BY_RCU, however this adds some complexity to list walking and store-free path walking, so I prefer to implement this at a later date, if it is shown to be a win in real situations. I haven't found a regression in any non-micro benchmark so I doubt it will be a problem. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: dcache remove dcache_lockNick Piggin
dcache_lock no longer protects anything. remove it. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: scale inode alias listNick Piggin
Add a new lock, dcache_inode_lock, to protect the inode's i_dentry list from concurrent modification. d_alias is also protected by d_lock. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: change d_hash for rcu-walkNick Piggin
Change d_hash so it may be called from lock-free RCU lookups. See similar patch for d_compare for details. For in-tree filesystems, this is just a mechanical change. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: change d_compare for rcu-walkNick Piggin
Change d_compare so it may be called from lock-free RCU lookups. This does put significant restrictions on what may be done from the callback, however there don't seem to have been any problems with in-tree fses. If some strange use case pops up that _really_ cannot cope with the rcu-walk rules, we can just add new rcu-unaware callbacks, which would cause name lookup to drop out of rcu-walk mode. For in-tree filesystems, this is just a mechanical change. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2010-10-29new helper: mount_bdev()Al Viro
... and switch of the obvious get_sb_bdev() users to ->mount() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-25new helper: ihold()Al Viro
Clones an existing reference to inode; caller must already hold one. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-25affs: testing the wrong variableDan Carpenter
The intent was to verify that bh = affs_bread_ino(...) returned a valid pointer. We checked "ext_bh" earlier in the function and it's valid here. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-22Merge branch 'vfs' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bklLinus Torvalds
* 'vfs' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl: (30 commits) BKL: remove BKL from freevxfs BKL: remove BKL from qnx4 autofs4: Only declare function when CONFIG_COMPAT is defined autofs: Only declare function when CONFIG_COMPAT is defined ncpfs: Lock socket in ncpfs while setting its callbacks fs/locks.c: prepare for BKL removal BKL: Remove BKL from ncpfs BKL: Remove BKL from OCFS2 BKL: Remove BKL from squashfs BKL: Remove BKL from jffs2 BKL: Remove BKL from ecryptfs BKL: Remove BKL from afs BKL: Remove BKL from USB gadgetfs BKL: Remove BKL from autofs4 BKL: Remove BKL from isofs BKL: Remove BKL from fat BKL: Remove BKL from ext2 filesystem BKL: Remove BKL from do_new_mount() BKL: Remove BKL from cgroup BKL: Remove BKL from NTFS ...
2010-10-12affs: Use sema_init instead of init_MUTEXThomas Gleixner
Get rid of init_MUTE() and use sema_init() instead. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Christoph Hellwig <hch@infradead.org> Cc: Al Viro <viro@zeniv.linux.org.uk> LKML-Reference: <20100907125056.511395595@linutronix.de>
2010-10-04BKL: Remove BKL from Amiga FFSJan Blunck
The BKL is only used in put_super, fill_super and remount_fs that are all three protected by the superblocks s_umount rw_semaphore. Therefore it is safe to remove the BKL entirely. Signed-off-by: Jan Blunck <jblunck@infradead.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2010-10-04BKL: Explicitly add BKL around get_sb/fill_superJan Blunck
This patch is a preparation necessary to remove the BKL from do_new_mount(). It explicitly adds calls to lock_kernel()/unlock_kernel() around get_sb/fill_super operations for filesystems that still uses the BKL. I've read through all the code formerly covered by the BKL inside do_kern_mount() and have satisfied myself that it doesn't need the BKL any more. do_kern_mount() is already called without the BKL when mounting the rootfs and in nfsctl. do_kern_mount() calls vfs_kern_mount(), which is called from various places without BKL: simple_pin_fs(), nfs_do_clone_mount() through nfs_follow_mountpoint(), afs_mntpt_do_automount() through afs_mntpt_follow_link(). Both later functions are actually the filesystems follow_link inode operation. vfs_kern_mount() is calling the specified get_sb function and lets the filesystem do its job by calling the given fill_super function. Therefore I think it is safe to push down the BKL from the VFS to the low-level filesystems get_sb/fill_super operation. [arnd: do not add the BKL to those file systems that already don't use it elsewhere] Signed-off-by: Jan Blunck <jblunck@infradead.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Christoph Hellwig <hch@infradead.org>
2010-08-09AFFS: wait for sb synchronization when neededArtem Bityutskiy
AFFS does not ever wait for superblock synchronization in ->put_super(), ->write_super, and ->sync_fs(). However, it should wait for synchronization in ->put_super() because it is about to be unmounted, in ->write_super() because this is periodic SB synchronization performed from a separate kernel thread, and in ->sync_fs() it should respect the 'wait' flag. This patch fixes the situation. Also, in ->put_super(), do not write the SB if it is not dirty. Tested-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09AFFS: clean up dirty flag usageArtem Bityutskiy
In 'affs_write_super()': remove ancient and wrong commented code, remove unneeded 'clean' variable, so the function becomes a bit cleaner and simpler. In 'affs_remount(): remove unnecessary SB dirty flag changes. Tested-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09switch affs to ->evict_inode()Al Viro
2010-08-09remove inode_setattrChristoph Hellwig
Replace inode_setattr with opencoded variants of it in all callers. This moves the remaining call to vmtruncate into the filesystem methods where it can be replaced with the proper truncate sequence. In a few cases it was obvious that we would never end up calling vmtruncate so it was left out in the opencoded variant: spufs: explicitly checks for ATTR_SIZE earlier btrfs,hugetlbfs,logfs,dlmfs: explicitly clears ATTR_SIZE earlier ufs: contains an opencoded simple_seattr + truncate that sets the filesize just above In addition to that ncpfs called inode_setattr with handcrafted iattrs, which allowed to trim down the opencoded variant. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09get rid of cont_write_begin_newtruncChristoph Hellwig
Move the call to vmtruncate to get rid of accessive blocks to the callers in preparation of the new truncate sequence and rename the non-truncating version to cont_write_begin. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-27drop unused dentry argument to ->fsyncChristoph Hellwig
