path: root/fs/affs
2018-05-30affs_lookup(): close a race with affs_remove_link()Al Viro
commit 30da870ce4a4e007c901858a96e9e394a1daa74a upstream. we unlock the directory hash too early - if we are looking at secondary link and primary (in another directory) gets removed just as we unlock, we could have the old primary moved in place of the secondary, leaving us to look into freed entry (and leaving our dentry with ->d_fsdata pointing to a freed entry). Cc: stable@vger.kernel.org # 2.4.4+ Acked-by: David Sterba <dsterba@suse.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-10Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull more vfs updates from Al Viro: ">rename2() work from Miklos + current_time() from Deepa" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: fs: Replace current_fs_time() with current_time() fs: Replace CURRENT_TIME_SEC with current_time() for inode timestamps fs: Replace CURRENT_TIME with current_time() for inode timestamps fs: proc: Delete inode time initializations in proc_alloc_inode() vfs: Add current_time() api vfs: add note about i_op->rename changes to porting fs: rename "rename2" i_op to "rename" vfs: remove unused i_op->rename fs: make remaining filesystems use .rename2 libfs: support RENAME_NOREPLACE in simple_rename() fs: support RENAME_NOREPLACE for local filesystems ncpfs: fix unused variable warning
2016-10-10Merge remote-tracking branch 'ovl/rename2' into for-linusAl Viro
2016-09-27fs: Replace CURRENT_TIME_SEC with current_time() for inode timestampsDeepa Dinamani
CURRENT_TIME_SEC is not y2038 safe. current_time() will be transitioned to use 64 bit time along with vfs in a separate patch. There is no plan to transistion CURRENT_TIME_SEC to use y2038 safe time interfaces. current_time() will also be extended to use superblock range checking parameters when range checking is introduced. This works because alloc_super() fills in the the s_time_gran in super block to NSEC_PER_SEC. Signed-off-by: Deepa Dinamani <deepa.kernel@gmail.com> Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-09-27fs: rename "rename2" i_op to "rename"Miklos Szeredi
Generated patch: sed -i "s/\.rename2\t/\.rename\t\t/" `git grep -wl rename2` sed -i "s/\brename2\b/rename/g" `git grep -wl rename2` Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
2016-09-27fs: support RENAME_NOREPLACE for local filesystemsMiklos Szeredi
This is trivial to do: - add flags argument to foo_rename() - check if flags doesn't have any other than RENAME_NOREPLACE - assign foo_rename() to .rename2 instead of .rename Filesystems converted: affs, bfs, exofs, ext2, hfs, hfsplus, jffs2, jfs, logfs, minix, msdos, nilfs2, omfs, reiserfs, sysvfs, ubifs, udf, ufs, vfat. Signed-off-by: Miklos Szeredi <mszeredi@redhat.com> Acked-by: Boaz Harrosh <ooo@electrozaur.com> Acked-by: Richard Weinberger <richard@nod.at> Acked-by: Bob Copeland <me@bobcopeland.com> Acked-by: Jan Kara <jack@suse.cz> Cc: Theodore Ts'o <tytso@mit.edu> Cc: Jaegeuk Kim <jaegeuk@kernel.org> Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: Mikulas Patocka <mpatocka@redhat.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Dave Kleikamp <shaggy@kernel.org> Cc: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Cc: Christoph Hellwig <hch@infradead.org>
2016-09-22fs: Give dentry to inode_change_ok() instead of inodeJan Kara
inode_change_ok() will be resposible for clearing capabilities and IMA extended attributes and as such will need dentry. Give it as an argument to inode_change_ok() instead of an inode. Also rename inode_change_ok() to setattr_prepare() to better relect that it does also some modifications in addition to checks. Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2016-07-31get rid of 'parent' argument of ->d_compare()Al Viro
2016-07-29affs ->d_compare(): don't bother with ->d_inodeAl Viro
Use ->d_sb directly. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-06-10vfs: make the string hashes salt the hashLinus Torvalds
We always mixed in the parent pointer into the dentry name hash, but we did it late at lookup time. It turns out that we can simplify that lookup-time action by salting the hash with the parent pointer early instead of late. A few other users of our string hashes also wanted to mix in their own pointers into the hash, and those are updated to use the same mechanism. Hash users that don't have any particular initial salt can just use the NULL pointer as a no-salt. Cc: Vegard Nossum <vegard.nossum@oracle.com> Cc: George Spelvin <linux@sciencehorizons.net> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-28affs: fix remount failure when there are no options changedMikulas Patocka
Commit c8f33d0bec99 ("affs: kstrdup() memory handling") checks if the kstrdup function returns NULL due to out-of-memory condition. However, if we are remounting a filesystem with no change to filesystem-specific options, the parameter data is NULL. In this case, kstrdup returns NULL (because it was passed NULL parameter), although no out of memory condition exists. The mount syscall then fails with ENOMEM. This patch fixes the bug. We fail with ENOMEM only if data is non-NULL. The patch also changes the call to replace_mount_options - if we didn't pass any filesystem-specific options, we don't call replace_mount_options (thus we don't erase existing reported options). Fixes: c8f33d0bec99 ("affs: kstrdup() memory handling") Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Cc: stable@vger.kernel.org # v4.1+ Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-17Merge branch 'work.preadv2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs cleanups from Al Viro: "More cleanups from Christoph" * 'work.preadv2' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: nfsd: use RWF_SYNC fs: add RWF_DSYNC aand RWF_SYNC ceph: use generic_write_sync fs: simplify the generic_write_sync prototype fs: add IOCB_SYNC and IOCB_DSYNC direct-io: remove the offset argument to dio_complete direct-io: eliminate the offset argument to ->direct_IO xfs: eliminate the pos variable in xfs_file_dio_aio_write filemap: remove the pos argument to generic_file_direct_write filemap: remove pos variables in generic_file_read_iter
2016-05-02simple local filesystems: switch to ->iterate_shared()Al Viro
no changes needed (XFS isn't simple, but it has the same parallelism in the interesting parts exercised from CXFS). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-05-01direct-io: eliminate the offset argument to ->direct_IOChristoph Hellwig
Including blkdev_direct_IO and dax_do_io. It has to be ki_pos to actually work, so eliminate the superflous argument. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-04-04mm, fs: get rid of PAGE_CACHE_* and page_cache_{get,release} macrosKirill A. Shutemov
PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} macros were introduced *long* time ago with promise that one day it will be possible to implement page cache with bigger chunks than PAGE_SIZE. This promise never materialized. And unlikely will. We have many places where PAGE_CACHE_SIZE assumed to be equal to PAGE_SIZE. And it's constant source of confusion on whether PAGE_CACHE_* or PAGE_* constant should be used in a particular case, especially on the border between fs and mm. Global switching to PAGE_CACHE_SIZE != PAGE_SIZE would cause to much breakage to be doable. Let's stop pretending that pages in page cache are special. They are not. The changes are pretty straight-forward: - <foo> << (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> <foo>; - <foo> >> (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> <foo>; - PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} -> PAGE_{SIZE,SHIFT,MASK,ALIGN}; - page_cache_get() -> get_page(); - page_cache_release() -> put_page(); This patch contains automated changes generated with coccinelle using script below. For some reason, coccinelle doesn't patch header files. I've called spatch for them manually. The only adjustment after coccinelle is revert of changes to PAGE_CAHCE_ALIGN definition: we are going to drop it later. There are few places in the code where coccinelle didn't reach. I'll fix them manually in a separate patch. Comments and documentation also will be addressed with the separate patch. virtual patch @@ expression E; @@ - E << (PAGE_CACHE_SHIFT - PAGE_SHIFT) + E @@ expression E; @@ - E >> (PAGE_CACHE_SHIFT - PAGE_SHIFT) + E @@ @@ - PAGE_CACHE_SHIFT + PAGE_SHIFT @@ @@ - PAGE_CACHE_SIZE + PAGE_SIZE @@ @@ - PAGE_CACHE_MASK + PAGE_MASK @@ expression E; @@ - PAGE_CACHE_ALIGN(E) + PAGE_ALIGN(E) @@ expression E; @@ - page_cache_get(E) + get_page(E) @@ expression E; @@ - page_cache_release(E) + put_page(E) Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Acked-by: Michal Hocko <mhocko@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-02-20affs_do_readpage_ofs(): just use kmap_atomic() around memcpy()Al Viro
It forgets kunmap() on a failure exit, but there's really no point keeping the page kmapped at all - after all, what we are doing is a bunch of memcpy() into the parts of page, so kmap_atomic()/kunmap_atomic() just around those memcpy() is enough. Spotted-by: Insu Yun <wuninsu@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-01-22wrappers for ->i_mutex accessAl Viro
parallel to mutex_{lock,unlock,trylock,is_locked,lock_nested}, inode_foo(inode) being mutex_foo(&inode->i_mutex). Please, use those for access to ->i_mutex; over the coming cycle ->i_mutex will become rwsem, with ->lookup() done with it held only shared. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-01-14kmemcg: account certain kmem allocations to memcgVladimir Davydov
Mark those kmem allocations that are known to be easily triggered from userspace as __GFP_ACCOUNT/SLAB_ACCOUNT, which makes them accounted to memcg. For the list, see below: - threadinfo - task_struct - task_delay_info - pid - cred - mm_struct - vm_area_struct and vm_region (nommu) - anon_vma and anon_vma_chain - signal_struct - sighand_struct - fs_struct - files_struct - fdtable and fdtable->full_fds_bits - dentry and external_name - inode for all filesystems. This is the most tedious part, because most filesystems overwrite the alloc_inode method. The list is far from complete, so feel free to add more objects. Nevertheless, it should be close to "account everything" approach and keep most workloads within bounds. Malevolent users will be able to breach the limit, but this was possible even with the former "account everything" approach (simply because it did not account everything in fact). [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Vladimir Davydov <vdavydov@virtuozzo.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Tejun Heo <tj@kernel.org> Cc: Greg Thelen <gthelen@google.com> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-12Merge branch 'work.misc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull misc vfs updates from Al Viro: "All kinds of stuff. That probably should've been 5 or 6 separate branches, but by the time I'd realized how large and mixed that bag had become it had been too close to -final to play with rebasing. Some fs/namei.c cleanups there, memdup_user_nul() introduction and switching open-coded instances, burying long-dead code, whack-a-mole of various kinds, several new helpers for ->llseek(), assorted cleanups and fixes from various people, etc. One piece probably deserves special mention - Neil's lookup_one_len_unlocked(). Similar to lookup_one_len(), but gets called without ->i_mutex and tries to avoid ever taking it. That, of course, means that it's not useful for any directory modifications, but things like getting inode attributes in nfds readdirplus are fine with that. I really should've asked for moratorium on lookup-related changes this cycle, but since I hadn't done that early enough... I *am* asking for that for the coming cycle, though - I'm going to try and get conversion of i_mutex to rwsem with ->lookup() done under lock taken shared. There will be a patch closer to the end of the window, along the lines of the one Linus had posted last May - mechanical conversion of ->i_mutex accesses to inode_lock()/inode_unlock()/inode_trylock()/ inode_is_locked()/inode_lock_nested(). To quote Linus back then: ----- | This is an automated patch using | | sed 's/mutex_lock(&\(.*\)->i_mutex)/inode_lock(\1)/' | sed 's/mutex_unlock(&\(.*\)->i_mutex)/inode_unlock(\1)/' | sed 's/mutex_lock_nested(&\(.*\)->i_mutex,[ ]*I_MUTEX_\([A-Z0-9_]*\))/inode_lock_nested(\1, I_MUTEX_\2)/' | sed 's/mutex_is_locked(&\(.*\)->i_mutex)/inode_is_locked(\1)/' | sed 's/mutex_trylock(&\(.*\)->i_mutex)/inode_trylock(\1)/' | | with a very few manual fixups ----- I'm going to send that once the ->i_mutex-affecting stuff in -next gets mostly merged (or when Linus says he's about to stop taking merges)" * 'work.misc' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (63 commits) nfsd: don't hold i_mutex over userspace upcalls fs:affs:Replace time_t with time64_t fs/9p: use fscache mutex rather than spinlock proc: add a reschedule point in proc_readfd_common() logfs: constify logfs_block_ops structures fcntl: allow to set O_DIRECT flag on pipe fs: __generic_file_splice_read retry lookup on AOP_TRUNCATED_PAGE fs: xattr: Use kvfree() [s390] page_to_phys() always returns a multiple of PAGE_SIZE nbd: use ->compat_ioctl() fs: use block_device name vsprintf helper lib/vsprintf: add %*pg format specifier fs: use gendisk->disk_name where possible poll: plug an unused argument to do_poll amdkfd: don't open-code memdup_user() cdrom: don't open-code memdup_user() rsxx: don't open-code memdup_user() mtip32xx: don't open-code memdup_user() [um] mconsole: don't open-code memdup_user_nul() [um] hostaudio: don't open-code memdup_user() ...
2016-01-09fs:affs:Replace time_t with time64_tDengChao
The affs code uses "time_t" and "get_seconds()". This will cause problems on 32-bit architectures in 2038 when time_t overflows. This patch replaces them with "time64_t" and "ktime_get_real_seconds()". This patch introduces expensive 64-bit divsion in "secs_to_datestamp()", considering this function is not called so often, the cost should be acceptable. Reviewed-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: DengChao <chao.deng@linaro.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-12-30switch ->get_link() to delayed_call, kill ->put_link()Al Viro
2015-12-08replace ->follow_link() with new method that could stay in RCU modeAl Viro
new method: ->get_link(); replacement of ->follow_link(). The differences are: * inode and dentry are passed separately * might be called both in RCU and non-RCU mode; the former is indicated by passing it a NULL dentry. * when called that way it isn't allowed to block and should return ERR_PTR(-ECHILD) if it needs to be called in non-RCU mode. It's a flagday change - the old method is gone, all in-tree instances converted. Conversion isn't hard; said that, so far very few instances do not immediately bail out when called in RCU mode. That'll change in the next commits. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-12-08don't put symlink bodies in pagecache into highmemAl Viro
kmap() in page_follow_link_light() needed to go - allowing to hold an arbitrary number of kmaps for long is a great way to deadlocking the system. new helper (inode_nohighmem(inode)) needs to be used for pagecache symlinks inodes; done for all in-tree cases. page_follow_link_light() instrumented to yell about anything missed. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-09-10fs/affs: make root lookup from blkdev logical sizePranay Kr. Srivastava
This patch resolves https://bugzilla.kernel.org/show_bug.cgi?id=16531. When logical blkdev size > 512 then sector numbers become larger than the device can support. Make affs start lookup based on the device's logical sector size instead of 512. Reported-by: Mark <markk@clara.co.uk> Suggested-by: Mark <markk@clara.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-07-04Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull more vfs updates from Al Viro: "Assorted VFS fixes and related cleanups (IMO the most interesting in that part are f_path-related things and Eric's descriptor-related stuff). UFS regression fixes (it got broken last cycle). 9P fixes. fs-cache series, DAX patches, Jan's file_remove_suid() work" [ I'd say this is much more than "fixes and related cleanups". The file_table locking rule change by Eric Dumazet is a rather big and fundamental update even if the patch isn't huge. - Linus ] * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (49 commits) 9p: cope with bogus responses from server in p9_client_{read,write} p9_client_write(): avoid double p9_free_req() 9p: forgetting to cancel request on interrupted zero-copy RPC dax: bdev_direct_access() may sleep block: Add support for DAX reads/writes to block devices dax: Use copy_from_iter_nocache dax: Add block size note to documentation fs/file.c: __fget() and dup2() atomicity rules fs/file.c: don't acquire files->file_lock in fd_install() fs:super:get_anon_bdev: fix race condition could cause dev exceed its upper limitation vfs: avoid creation of inode number 0 in get_next_ino namei: make set_root_rcu() return void make simple_positive() public ufs: use dir_pages instead of ufs_dir_pages() pagemap.h: move dir_pages() over there remove the pointless include of lglock.h fs: cleanup slight list_entry abuse xfs: Correctly lock inode when removing suid and file capabilities fs: Call security_ops->inode_killpriv on truncate fs: Provide function telling whether file_remove_privs() will do anything ...
2015-06-30fs/affs/symlink.c: remove unneeded err variableFabian Frederick
err is only assigned to -EIO. Return that value at the end of fail context. Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30fs/affs/amigaffs.c: remove unneeded initializationFabian Frederick
bh is initialized unconditionally in affs_remove_link() Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-30fs/affs/inode.c: remove unneeded initializationFabian Frederick
bh is initialized unconditionally in affs_add_entry() Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-23fs: cleanup slight list_entry abuseRasmus Villemoes
list_entry is just a wrapper for container_of, but it is arguably wrong (and slightly confusing) to use it when the pointed-to struct member is not a struct list_head. Use container_of directly instead. Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-04-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull fourth vfs update from Al Viro: "d_inode() annotations from David Howells (sat in for-next since before the beginning of merge window) + four assorted fixes" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: RCU pathwalk breakage when running into a symlink overmounting something fix I_DIO_WAKEUP definition direct-io: only inc/dec inode->i_dio_count for file systems fs/9p: fix readdir() VFS: assorted d_backing_inode() annotations VFS: fs/inode.c helpers: d_inode() annotations VFS: fs/cachefiles: d_backing_inode() annotations VFS: fs library helpers: d_inode() annotations VFS: assorted weird filesystems: d_inode() annotations VFS: normal filesystems (and lustre): d_inode() annotations VFS: security/: d_inode() annotations VFS: security/: d_backing_inode() annotations VFS: net/: d_inode() annotations VFS: net/unix: d_backing_inode() annotations VFS: kernel/: d_inode() annotations VFS: audit: d_backing_inode() annotations VFS: Fix up some ->d_inode accesses in the chelsio driver VFS: Cachefiles should perform fs modifications on the top layer only VFS: AF_UNIX sockets should call mknod on the top layer only
2015-04-17Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge third patchbomb from Andrew Morton: - various misc things - a couple of lib/ optimisations - provide DIV_ROUND_CLOSEST_ULL() - checkpatch updates - rtc tree - befs, nilfs2, hfs, hfsplus, fatfs, adfs, affs, bfs - ptrace fixes - fork() fixes - seccomp cleanups - more mmap_sem hold time reductions from Davidlohr * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (138 commits) proc: show locks in /proc/pid/fdinfo/X docs: add missing and new /proc/PID/status file entries, fix typos drivers/rtc/rtc-at91rm9200.c: make IO endian agnostic Documentation/spi/spidev_test.c: fix warning drivers/rtc/rtc-s5m.c: allow usage on device type different than main MFD type .gitignore: ignore *.tar MAINTAINERS: add Mediatek SoC mailing list tomoyo: reduce mmap_sem hold for mm->exe_file powerpc/oprofile: reduce mmap_sem hold for exe_file oprofile: reduce mmap_sem hold for mm->exe_file mips: ip32: add platform data hooks to use DS1685 driver lib/Kconfig: fix up HAVE_ARCH_BITREVERSE help text x86: switch to using asm-generic for seccomp.h sparc: switch to using asm-generic for seccomp.h powerpc: switch to using asm-generic for seccomp.h parisc: switch to using asm-generic for seccomp.h mips: switch to using asm-generic for seccomp.h microblaze: use asm-generic for seccomp.h arm: use asm-generic for seccomp.h seccomp: allow COMPAT sigreturn overrides ...
2015-04-17affs: kstrdup() memory handlingSanidhya Kashyap
There is a possibility of kstrdup() failure upon memory pressure. Therefore, returning ENOMEM even for new_opts. [akpm@linux-foundation.org: cleanup] Signed-off-by: Sanidhya Kashyap <sanidhya.gatech@gmail.com> Cc: Taesoo kim <taesoo@gatech.edu> Cc: Fabian Frederick <fabf@skynet.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-17fs/affs: use affs_test_opt()Fabian Frederick
Replace mount option test by affs_test_opt(). Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-17fs/affs/super.c: use affs_set_opt()Fabian Frederick
Replace direct mount option assignation by affs_set_opt() macro. Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-17fs/affs/affs.h: add mount option manipulation macrosFabian Frederick
Add clear/set/test affs mount option macros. Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-17fs/affs: use AFFS_MOUNT prefix for mount optionsFabian Frederick
Currently, affs still uses direct access on mount_options. This patch prepares to use affs_clear/set/test_opt() like other filesystems. Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-15VFS: normal filesystems (and lustre): d_inode() annotationsDavid Howells
that's the bulk of filesystem drivers dealing with inodes of their own Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-04-11direct_IO: remove rw from a_ops->direct_IO()Omar Sandoval
Now that no one is using rw, remove it completely. Signed-off-by: Omar Sandoval <osandov@osandov.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-04-11direct_IO: use iov_iter_rw() instead of rw everywhereOmar Sandoval
The rw parameter to direct_IO is redundant with iov_iter->type, and treated slightly differently just about everywhere it's used: some users do rw & WRITE, and others do rw == WRITE where they should be doing a bitwise check. Simplify this with the new iov_iter_rw() helper, which always returns either READ or WRITE. Signed-off-by: Omar Sandoval <osandov@osandov.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-04-11Remove rw from {,__,do_}blockdev_direct_IO()Omar Sandoval
Most filesystems call through to these at some point, so we'll start here. Signed-off-by: Omar Sandoval <osandov@osandov.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-04-11make new_sync_{read,write}() staticAl Viro
All places outside of core VFS that checked ->read and ->write for being NULL or called the methods directly are gone now, so NULL {read,write} with non-NULL {read,write}_iter will do the right thing in all cases. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-04-09Merge branch 'iocb' into for-davemAl Viro
trivial conflict in net/socket.c and non-trivial one in crypto - that one had evaded aio_complete() removal. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-03-25fs: move struct kiocb to fs.hChristoph Hellwig
struct kiocb now is a generic I/O container, so move it to fs.h. Also do a #include diet for aio.h while we're at it. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-03-25fs/affs/file.c: unlock/release page on errorTaesoo Kim
When affs_bread_ino() fails, correctly unlock the page and release the page cache with proper error value. All write_end() should unlock/release the page that was locked by write_beg(). Signed-off-by: Taesoo Kim <tsgatesv@gmail.com> Cc: Fabian Frederick <fabf@skynet.be> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-17fs/affs/super.c: fix switch indentationFabian Frederick
Fix checkpatch error: ERROR: switch and case should be at the same indent Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-17fs/affs/inode.c: remove double extern affs_symlink_inode_operationsFabian Frederick
affs_symlink_inode_operations was already declared extern in affs.h Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-17fs/affs/bitmap.c: remove unnecessary returnFabian Frederick
return is not needed at the end of function. Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-17fs/affs/amigaffs.c: remove else after returnFabian Frederick
else is unnecessary after return -ENAMETOOLONG Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-17fs/affs: define AFFSNAMEMAX to replace constant useFabian Frederick
30 was used all over the place to compare name length against AFFS maximum name length. Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-17fs/affs: use unsigned int for string lengthsFabian Frederick
- Some min() were used with different types. - Create a new variable in __affs_hash_dentry() to process affs_check_name()/min() return Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
