path: root/fs/afs/inode.c
2009-04-03FS-Cache: Make kAFS use FS-CacheDavid Howells
The attached patch makes the kAFS filesystem in fs/afs/ use FS-Cache, and through it any attached caches. The kAFS filesystem will use caching automatically if it's available. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Steve Dickson <steved@redhat.com> Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Tested-by: Daire Byrne <Daire.Byrne@framestore.com>
2008-06-06Fix various old email addresses for dwmw2David Woodhouse
Although if people have questions about ARCnet, perhaps it's _better_ for them to be mailing dwmw2@cam.ac.uk about it... Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07iget: use iget_failed() in AFSDavid Howells
Use iget_failed() in AFS to kill a failed inode. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-28vfs: Add 64 bit i_version supportJean Noel Cordenner
The i_version field of the inode is changed to be a 64-bit counter that is set on every inode creation and that is incremented every time the inode data is modified (similarly to the "ctime" time-stamp). The aim is to fulfill a NFSv4 requirement for rfc3530. This first part concerns the vfs, it converts the 32-bit i_version in the generic inode to a 64-bit, a flag is added in the super block in order to check if the feature is enabled and the i_version is incremented in the vfs. Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: Jean Noel Cordenner <jean-noel.cordenner@bull.net> Signed-off-by: Kalpak Shah <kalpak@clusterfs.com>
2007-05-21Detach sched.h from mm.hAlexey Dobriyan
First thing mm.h does is including sched.h solely for can_do_mlock() inline function which has "current" dereference inside. By dealing with can_do_mlock() mm.h can be detached from sched.h which is good. See below, why. This patch a) removes unconditional inclusion of sched.h from mm.h b) makes can_do_mlock() normal function in mm/mlock.c c) exports can_do_mlock() to not break compilation d) adds sched.h inclusions back to files that were getting it indirectly. e) adds less bloated headers to some files (asm/signal.h, jiffies.h) that were getting them indirectly Net result is: a) mm.h users would get less code to open, read, preprocess, parse, ... if they don't need sched.h b) sched.h stops being dependency for significant number of files: on x86_64 allmodconfig touching sched.h results in recompile of 4083 files, after patch it's only 3744 (-8.3%). Cross-compile tested on all arm defconfigs, all mips defconfigs, all powerpc defconfigs, alpha alpha-up arm i386 i386-up i386-defconfig i386-allnoconfig ia64 ia64-up m68k mips parisc parisc-up powerpc powerpc-up s390 s390-up sparc sparc-up sparc64 sparc64-up um-x86_64 x86_64 x86_64-up x86_64-defconfig x86_64-allnoconfig as well as my two usual configs. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-11AFS: fix a couple of problems with unlinking AFS filesDavid Howells
Fix a couple of problems with unlinking AFS files. (1) The parent directory wasn't being updated properly between unlink() and the following lookup(). It seems that, for some reason, invalidate_remote_inode() wasn't discarding the directory contents correctly, so this patch calls invalidate_inode_pages2() instead on non-regular files. (2) afs_vnode_deleted_remotely() should handle vnodes that don't have a source server recorded without oopsing. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09AFS: implement basic file write supportDavid Howells
Implement support for writing to regular AFS files, including: (1) write (2) truncate (3) fsync, fdatasync (4) chmod, chown, chgrp, utime. AFS writeback attempts to batch writes into as chunks as large as it can manage up to the point that it writes back 65535 pages in one chunk or it meets a locked page. Furthermore, if a page has been written to using a particular key, then should another write to that page use some other key, the first write will be flushed before the second is allowed to take place. If the first write fails due to a security error, then the page will be scrapped and reread before the second write takes place. If a page is dirty and the callback on it is broken by the server, then the dirty data is not discarded (same behaviour as NFS). Shared-writable mappings are not supported by this patch. [akpm@linux-foundation.org: fix a bunch of warnings] Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09AFS: AFS fixupsDavid Howells
Make some miscellaneous changes to the AFS filesystem: (1) Assert RCU barriers on module exit to make sure RCU has finished with callbacks in this module. (2) Correctly handle the AFS server returning a zero-length read. (3) Split out data zapping calls into one function (afs_zap_data). (4) Rename some afs_file_*() functions to afs_*() where they apply to non-regular files too. (5) Be consistent about the presentation of volume ID:vnode ID in debugging output. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-26[AFS]: Fix u64 printing in debug logging.David S. Miller
Need 'unsigned long long' casts to quiet warnings on 64-bit platforms when using %ll on a u64. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-26[AFS]: Add "directory write" support.David Howells
Add support for the create, link, symlink, unlink, mkdir, rmdir and rename VFS operations to the in-kernel AFS filesystem. Also: (1) Fix dentry and inode revalidation. d_revalidate should only look at state of the dentry. Revalidation of the contents of an inode pointed to by a dentry is now separate. (2) Fix afs_lookup() to hash negative dentries as well as positive ones. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-26[AFS]: Add security support.David Howells
Add security support to the AFS filesystem. Kerberos IV tickets are added as RxRPC keys are added to the session keyring with the klog program. open() and other VFS operations then find this ticket with request_key() and either use it immediately (eg: mkdir, unlink) or attach it to a file descriptor (open). Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-26[AF_RXRPC]: Make the in-kernel AFS filesystem use AF_RXRPC.David Howells
Make the in-kernel AFS filesystem use AF_RXRPC instead of the old RxRPC code. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-26[AFS]: Clean up the AFS sourcesDavid Howells
Clean up the AFS sources. Also remove references to AFS keys. RxRPC keys are used instead. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-07[PATCH] afs: use generic_ro_fopsChristoph Hellwig
afs actually had a write method that returned different errors depending on whether some flag was set - better return the standard EINVAL errno. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
