path: root/fs/afs/proc.c
2014-02-01afs: proc cells and rootcell are writeablePali Rohár
Both proc files are writeable and used for configuring cells. But there is missing correct mode flag for writeable files. Without this patch both proc files are read only. [ It turns out they aren't really read-only, since root can write to them even if the write bit isn't set due to CAP_DAC_OVERRIDE ] Signed-off-by: Pali Rohár <pali.rohar@gmail.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-25afs: get rid of junk in fs/afs/proc.cAl Viro
kill pointless method instances and don't bother with ->owner - it's ignored for procfs files anyway, make use of remove_proc_subtree() for removal, get rid of cell->proc_dir. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-04-09procfs: new helper - PDE_DATA(inode)Al Viro
The only part of proc_dir_entry the code outside of fs/proc really cares about is PDE(inode)->data. Provide a helper for that; static inline for now, eventually will be moved to fs/proc, along with the knowledge of struct proc_dir_entry layout. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-11AFS: Implement an autocell mount capability [ver #2]wanglei
Implement the ability for the root directory of a mounted AFS filesystem to accept lookups of arbitrary directory names, to interpet the names as the names of cells, to look the cell names up in the DNS for AFSDB records and to mount the root.cell volume of the nominated cell on the pseudo-directory created by lookup. This facility is requested by passing: -o autocell to the mountpoint for which this is desired, usually the /afs mount. To use this facility, a DNS upcall program is required for AFSDB records. This can be obtained from: http://people.redhat.com/~dhowells/afs/dns.afsdb.c It should be compiled with -lresolv and -lkeyutils and installed as, say: /usr/sbin/dns.afsdb Then the following line needs to be added to /sbin/request-key.conf: create dns_resolver afsdb:* * /usr/sbin/dns.afsdb %k This can be tested by mounting AFS, say: insmod dns_resolver.ko insmod af-rxrpc.ko insmod kafs.ko rootcell=grand.central.org mount -t afs "#grand.central.org:root.cell." /afs -o autocell and doing: ls /afs/grand.central.org/ which should show: archive/ cvs/ doc/ local/ project/ service/ software/ user/ www/ if it works. Signed-off-by: Wang Lei <wang840925@gmail.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2009-09-23seq_file: constify seq_operationsJames Morris
Make all seq_operations structs const, to help mitigate against revectoring user-triggerable function pointers. This is derived from the grsecurity patch, although generated from scratch because it's simpler than extracting the changes from there. Signed-off-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Acked-by: Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-31proc 2/2: remove struct proc_dir_entry::ownerAlexey Dobriyan
Setting ->owner as done currently (pde->owner = THIS_MODULE) is racy as correctly noted at bug #12454. Someone can lookup entry with NULL ->owner, thus not pinning enything, and release it later resulting in module refcount underflow. We can keep ->owner and supply it at registration time like ->proc_fops and ->data. But this leaves ->owner as easy-manipulative field (just one C assignment) and somebody will forget to unpin previous/pin current module when switching ->owner. ->proc_fops is declared as "const" which should give some thoughts. ->read_proc/->write_proc were just fixed to not require ->owner for protection. rmmod'ed directories will be empty and return "." and ".." -- no harm. And directories with tricky enough readdir and lookup shouldn't be modular. We definitely don't want such modular code. Removing ->owner will also make PDE smaller. So, let's nuke it. Kudos to Jeff Layton for reminding about this, let's say, oversight. http://bugzilla.kernel.org/show_bug.cgi?id=12454 Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com>
2008-10-31fs: replace NIPQUAD()Harvey Harrison
Using NIPQUAD() with NIPQUAD_FMT, %d.%d.%d.%d or %u.%u.%u.%u can be replaced with %pI4 Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-29afs: use non-racy method for proc entries creationDenis V. Lunev
Use proc_create()/proc_create_data() to make sure that ->proc_fops and ->data be setup before gluing PDE to main tree. Signed-off-by: Denis V. Lunev <den@openvz.org> Acked-by: David Howells <dhowells@redhat.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17fs/afs/: possible cleanupsAdrian Bunk
This patch contains the following possible cleanups: - make the following needlessly global functions static: - rxrpc.c: afs_send_pages() - vlocation.c: afs_vlocation_queue_for_updates() - write.c: afs_writepages_region() - make the following needlessly global variables static: - mntpt.c: afs_mntpt_expiry_timeout - proc.c: afs_vlocation_states[] - server.c: afs_server_timeout - vlocation.c: afs_vlocation_timeout - vlocation.c: afs_vlocation_update_timeout - #if 0 the following unused function: - cell.c: afs_get_cell_maybe() - #if 0 the following unused variables: - callback.c: afs_vnode_update_timeout - cmservice.c: struct afs_cm_workqueue Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16Make AFS use seq_list_xxx helpersPavel Emelianov
These proc files show some header before dumping the list, so the seq_list_start_head() is used. Signed-off-by: Pavel Emelianov <xemul@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-21Detach sched.h from mm.hAlexey Dobriyan
First thing mm.h does is including sched.h solely for can_do_mlock() inline function which has "current" dereference inside. By dealing with can_do_mlock() mm.h can be detached from sched.h which is good. See below, why. This patch a) removes unconditional inclusion of sched.h from mm.h b) makes can_do_mlock() normal function in mm/mlock.c c) exports can_do_mlock() to not break compilation d) adds sched.h inclusions back to files that were getting it indirectly. e) adds less bloated headers to some files (asm/signal.h, jiffies.h) that were getting them indirectly Net result is: a) mm.h users would get less code to open, read, preprocess, parse, ... if they don't need sched.h b) sched.h stops being dependency for significant number of files: on x86_64 allmodconfig touching sched.h results in recompile of 4083 files, after patch it's only 3744 (-8.3%). Cross-compile tested on all arm defconfigs, all mips defconfigs, all powerpc defconfigs, alpha alpha-up arm i386 i386-up i386-defconfig i386-allnoconfig ia64 ia64-up m68k mips parisc parisc-up powerpc powerpc-up s390 s390-up sparc sparc-up sparc64 sparc64-up um-x86_64 x86_64 x86_64-up x86_64-defconfig x86_64-allnoconfig as well as my two usual configs. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-26[AF_RXRPC]: Make the in-kernel AFS filesystem use AF_RXRPC.David Howells
Make the in-kernel AFS filesystem use AF_RXRPC instead of the old RxRPC code. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-26[AFS]: Clean up the AFS sourcesDavid Howells
Clean up the AFS sources. Also remove references to AFS keys. RxRPC keys are used instead. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-29[PATCH] afs: add lock annotations to afs_proc_cell_servers_{start,stop}Josh Triplett
afs_proc_cell_servers_start acquires a lock, and afs_proc_cell_servers_stop releases that lock. Add lock annotations to these two functions so that sparse can check callers for lock pairing, and so that sparse will not complain about these functions since they intentionally use locks in this manner. Signed-off-by: Josh Triplett <josh@freedesktop.org> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] Make most file operations structs in fs/ constArjan van de Ven
This is a conversion to make the various file_operations structs in fs/ const. Basically a regexp job, with a few manual fixups The goal is both to increase correctness (harder to accidentally write to shared datastructures) and reducing the false sharing of cachelines with things that get dirty in .data (while .rodata is nicely read only and thus cache clean) Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
