path: root/fs/afs/write.c
2011-07-20fs: push i_mutex and filemap_write_and_wait down into ->fsync() handlersJosef Bacik
Btrfs needs to be able to control how filemap_write_and_wait_range() is called in fsync to make it less of a painful operation, so push down taking i_mutex and the calling of filemap_write_and_wait() down into the ->fsync() handlers. Some file systems can drop taking the i_mutex altogether it seems, like ext3 and ocfs2. For correctness sake I just pushed everything down in all cases to make sure that we keep the current behavior the same for everybody, and then each individual fs maintainer can make up their mind about what to do from there. Thanks, Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-06-16afs: afs_fill_page reads too much, or wrong dataAnton Blanchard
afs_fill_page should read the page that is about to be written but the current implementation has a number of issues. If we aren't extending the file we always read PAGE_CACHE_SIZE at offset 0. If we are extending the file we try to read the entire file. Change afs_fill_page to read PAGE_CACHE_SIZE at the right offset, clamped to i_size. While here, avoid calling afs_fill_page when we are doing a PAGE_CACHE_SIZE write. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-02-25afs: Fix oops in afs_unlink_writebackAnton Blanchard
I'm seeing the following oops when testing afs: Unable to handle kernel paging request for data at address 0x00000008 ... NIP [c0000000003393b0] .afs_unlink_writeback+0x38/0xc0 LR [c00000000033987c] .afs_put_writeback+0x98/0xec Call Trace: [c00000000345f600] [c00000000033987c] .afs_put_writeback+0x98/0xec [c00000000345f690] [c00000000033ae80] .afs_write_begin+0x6a4/0x75c [c00000000345f790] [c00000000012b77c] .generic_file_buffered_write+0x148/0x320 [c00000000345f8d0] [c00000000012e1b8] .__generic_file_aio_write+0x37c/0x3e4 [c00000000345f9d0] [c00000000012e2a8] .generic_file_aio_write+0x88/0xfc [c00000000345fa90] [c0000000003390a8] .afs_file_write+0x10c/0x178 [c00000000345fb40] [c000000000188788] .do_sync_write+0xc4/0x128 [c00000000345fcc0] [c000000000189658] .vfs_write+0xe8/0x1d8 [c00000000345fd70] [c000000000189884] .SyS_write+0x68/0xb0 [c00000000345fe30] [c000000000008564] syscall_exit+0x0/0x40 afs_write_begin hits an error and calls afs_unlink_writeback. In there we do list_del_init on an uninitialised list. The patch below initialises ->link when creating the afs_writeback struct. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26writeback: remove nonblocking/encountered_congestion referencesWu Fengguang
This removes more dead code that was somehow missed by commit 0d99519efef (writeback: remove unused nonblocking and congestion checks). There are no behavior change except for the removal of two entries from one of the ext4 tracing interface. The nonblocking checks in ->writepages are no longer used because the flusher now prefer to block on get_request_wait() than to skip inodes on IO congestion. The latter will lead to more seeky IO. The nonblocking checks in ->writepage are no longer used because it's redundant with the WB_SYNC_NONE check. We no long set ->nonblocking in VM page out and page migration, because a) it's effectively redundant with WB_SYNC_NONE in current code b) it's old semantic of "Don't get stuck on request queues" is mis-behavior: that would skip some dirty inodes on congestion and page out others, which is unfair in terms of LRU age. Inspired by Christoph Hellwig. Thanks! Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Cc: Theodore Ts'o <tytso@mit.edu> Cc: David Howells <dhowells@redhat.com> Cc: Sage Weil <sage@newdream.net> Cc: Steve French <sfrench@samba.org> Cc: Chris Mason <chris.mason@oracle.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-07-06writeback: remove writeback_inodes_wbcChristoph Hellwig
This was just an odd wrapper around writeback_inodes_wb. Removing this also allows to get rid of the bdi member of struct writeback_control which was rather out of place there. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-05-27drop unused dentry argument to ->fsyncChristoph Hellwig
Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-03-05make sure data is on disk before calling ->write_inodeChristoph Hellwig
Similar to the fsync issue fixed a while ago in commit 2daea67e966dc0c42067ebea015ddac6834cef88 we need to write for data to actually hit the disk before writing out the metadata to guarantee data integrity for filesystems that modify the inode in the data I/O completion path. Currently XFS and NFS handle this manually, and AFS has a write_inode method that does nothing but waiting for data, while others are possibly missing out on this. Fortunately this change has a lot less impact than the fsync change as none of the write_inode methods starts data writeout of any form by itself. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-12-10afs: remove manual O_SYNC handlingChristoph Hellwig
generic_file_aio_write already calls into ->fsync to handle O_SYNC/O_DSYNC. Remove the duplicate manual invocation. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2009-12-10vfs: Implement proper O_SYNC semanticsChristoph Hellwig
While Linux provided an O_SYNC flag basically since day 1, it took until Linux 2.4.0-test12pre2 to actually get it implemented for filesystems, since that day we had generic_osync_around with only minor changes and the great "For now, when the user asks for O_SYNC, we'll actually give O_DSYNC" comment. This patch intends to actually give us real O_SYNC semantics in addition to the O_DSYNC semantics. After Jan's O_SYNC patches which are required before this patch it's actually surprisingly simple, we just need to figure out when to set the datasync flag to vfs_fsync_range and when not. This patch renames the existing O_SYNC flag to O_DSYNC while keeping it's numerical value to keep binary compatibility, and adds a new real O_SYNC flag. To guarantee backwards compatiblity it is defined as expanding to both the O_DSYNC and the new additional binary flag (__O_SYNC) to make sure we are backwards-compatible when compiled against the new headers. This also means that all places that don't care about the differences can just check O_DSYNC and get the right behaviour for O_SYNC, too - only places that actuall care need to check __O_SYNC in addition. Drivers and network filesystems have been updated in a fail safe way to always do the full sync magic if O_DSYNC is set. The few places setting O_SYNC for lower layers are kept that way for now to stay failsafe. We enforce that O_DSYNC is set when __O_SYNC is set early in the open path to make sure we always get these sane options. Note that parisc really screwed up their headers as they already define a O_DSYNC that has always been a no-op. We try to repair it by using it for the new O_DSYNC and redefinining O_SYNC to send both the traditional O_SYNC numerical value _and_ the O_DSYNC one. Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Grant Grundler <grundler@parisc-linux.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Ingo Molnar <mingo@elte.hu> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Andreas Dilger <adilger@sun.com> Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com> Acked-by: Kyle McMartin <kyle@mcmartin.ca> Acked-by: Ulrich Drepper <drepper@redhat.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jan Kara <jack@suse.cz>
2009-09-16writeback: get rid of wbc->for_writepagesJens Axboe
It's only set, it's never checked. Kill it. Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-03FS-Cache: Make kAFS use FS-CacheDavid Howells
The attached patch makes the kAFS filesystem in fs/afs/ use FS-Cache, and through it any attached caches. The kAFS filesystem will use caching automatically if it's available. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Steve Dickson <steved@redhat.com> Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Tested-by: Daire Byrne <Daire.Byrne@framestore.com>
2009-01-04fs: symlink write_begin allocation context fixNick Piggin
With the write_begin/write_end aops, page_symlink was broken because it could no longer pass a GFP_NOFS type mask into the point where the allocations happened. They are done in write_begin, which would always assume that the filesystem can be entered from reclaim. This bug could cause filesystem deadlocks. The funny thing with having a gfp_t mask there is that it doesn't really allow the caller to arbitrarily tinker with the context in which it can be called. It couldn't ever be GFP_ATOMIC, for example, because it needs to take the page lock. The only thing any callers care about is __GFP_FS anyway, so turn that into a single flag. Add a new flag for write_begin, AOP_FLAG_NOFS. Filesystems can now act on this flag in their write_begin function. Change __grab_cache_page to accept a nofs argument as well, to honour that flag (while we're there, change the name to grab_cache_page_write_begin which is more instructive and does away with random leading underscores). This is really a more flexible way to go in the end anyway -- if a filesystem happens to want any extra allocations aside from the pagecache ones in ints write_begin function, it may now use GFP_KERNEL (rather than GFP_NOFS) for common case allocations (eg. ocfs2_alloc_write_ctxt, for a random example). [kosaki.motohiro@jp.fujitsu.com: fix ubifs] [kosaki.motohiro@jp.fujitsu.com: fix fuse] Signed-off-by: Nick Piggin <npiggin@suse.de> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: <stable@kernel.org> [2.6.28.x] Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> [ Cleaned up the calling convention: just pass in the AOP flags untouched to the grab_cache_page_write_begin() function. That just simplifies everybody, and may even allow future expansion of the logic. - Linus ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16afs: convert to new aopsNick Piggin
Cannot assume writes will fully complete, so this conversion goes the easy way and always brings the page uptodate before the write. [dhowells@redhat.com: style tweaks] Signed-off-by: Nick Piggin <npiggin@suse.de> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-04mm: rename page trylockNick Piggin
Converting page lock to new locking bitops requires a change of page flag operation naming, so we might as well convert it to something nicer (!TestSetPageLocked_Lock => trylock_page, SetPageLocked => set_page_locked). This also facilitates lockdeping of page lock. Signed-off-by: Nick Piggin <npiggin@suse.de> Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Andrew Morton <akpm@linux-foundation.org> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17Drop some headers from mm.hAlexey Dobriyan
mm.h doesn't use directly anything from mutex.h and backing-dev.h, so remove them and add them back to files which need them. Cross-compile tested on many configs and archs. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17fs/afs/: possible cleanupsAdrian Bunk
This patch contains the following possible cleanups: - make the following needlessly global functions static: - rxrpc.c: afs_send_pages() - vlocation.c: afs_vlocation_queue_for_updates() - write.c: afs_writepages_region() - make the following needlessly global variables static: - mntpt.c: afs_mntpt_expiry_timeout - proc.c: afs_vlocation_states[] - server.c: afs_server_timeout - vlocation.c: afs_vlocation_timeout - vlocation.c: afs_vlocation_update_timeout - #if 0 the following unused function: - cell.c: afs_get_cell_maybe() - #if 0 the following unused variables: - callback.c: afs_vnode_update_timeout - cmservice.c: struct afs_cm_workqueue Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-16AFS: Fix afs_prepare_write()David Howells
afs_prepare_write() should not mark a page up to date if it only partially fills it in, in expectation of the caller filling in the rest prior to calling commit_write(). commit_write(), however, should mark the page up to date. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-11AFS: fix interminable loop in afs_write_back_from_locked_page()David Howells
Following bug was uncovered by compiling with '-W' flag: CC [M] fs/afs/write.o fs/afs/write.c: In function ‘afs_write_back_from_locked_page’: fs/afs/write.c:398: warning: comparison of unsigned expression >= 0 is always true Loop variable 'n' is unsigned, so wraps around happily as far as I can see. Trival fix attached (compile tested only). Signed-off-by: Mika Kukkonen <mikukkon@iki.fi> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-10AFS: further write support fixesDavid Howells
Further fixes for AFS write support: (1) The afs_send_pages() outer loop must do an extra iteration if it ends with 'first == last' because 'last' is inclusive in the page set otherwise it fails to send the last page and complete the RxRPC op under some circumstances. (2) Similarly, the outer loop in afs_pages_written_back() must also do an extra iteration if it ends with 'first == last', otherwise it fails to clear PG_writeback on the last page under some circumstances. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-10AFS: write support fixesDavid Howells
AFS write support fixes: (1) Support large files using the 64-bit file access operations if available on the server. (2) Use kmap_atomic() rather than kmap() in afs_prepare_page(). (3) Don't do stuff in afs_writepage() that's done by the caller. [akpm@linux-foundation.org: fix right shift count >= width of type] Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09AFS: implement basic file write supportDavid Howells
Implement support for writing to regular AFS files, including: (1) write (2) truncate (3) fsync, fdatasync (4) chmod, chown, chgrp, utime. AFS writeback attempts to batch writes into as chunks as large as it can manage up to the point that it writes back 65535 pages in one chunk or it meets a locked page. Furthermore, if a page has been written to using a particular key, then should another write to that page use some other key, the first write will be flushed before the second is allowed to take place. If the first write fails due to a security error, then the page will be scrapped and reread before the second write takes place. If a page is dirty and the callback on it is broken by the server, then the dirty data is not discarded (same behaviour as NFS). Shared-writable mappings are not supported by this patch. [akpm@linux-foundation.org: fix a bunch of warnings] Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
