path: root/fs/afs
2006-12-08[PATCH] rename struct namespace to struct mnt_namespaceKirill Korotaev
Rename 'struct namespace' to 'struct mnt_namespace' to avoid confusion with other namespaces being developped for the containers : pid, uts, ipc, etc. 'namespace' variables and attributes are also renamed to 'mnt_ns' Signed-off-by: Kirill Korotaev <dev@sw.ru> Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] struct path: convert afsJosef Sipek
2006-12-07[PATCH] affs: replace kmalloc+memset with kzallocYan Burman
Replace kmalloc+memset with kzalloc Signed-off-by: Yan Burman <burman.yan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] Add include/linux/freezer.h and move definitions from sched.hNigel Cunningham
Move process freezing functions from include/linux/sched.h to freezer.h, so that modifications to the freezer or the kernel configuration don't require recompiling just about everything. [akpm@osdl.org: fix ueagle driver] Signed-off-by: Nigel Cunningham <nigel@suspend2.net> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] fs/*: use BUILD_BUG_ONAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: David Howells <dhowells@redhat.com> Cc: Mark Fasheh <mark.fasheh@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03[PATCH] VFS: Make filldir_t and struct kstat deal in 64-bit inode numbersDavid Howells
These patches make the kernel pass 64-bit inode numbers internally when communicating to userspace, even on a 32-bit system. They are required because some filesystems have intrinsic 64-bit inode numbers: NFS3+ and XFS for example. The 64-bit inode numbers are then propagated to userspace automatically where the arch supports it. Problems have been seen with userspace (eg: ld.so) using the 64-bit inode number returned by stat64() or getdents64() to differentiate files, and failing because the 64-bit inode number space was compressed to 32-bits, and so overlaps occur. This patch: Make filldir_t take a 64-bit inode number and struct kstat carry a 64-bit inode number so that 64-bit inode numbers can be passed back to userspace. The stat functions then returns the full 64-bit inode number where available and where possible. If it is not possible to represent the inode number supplied by the filesystem in the field provided by userspace, then error EOVERFLOW will be issued. Similarly, the getdents/readdir functions now pass the full 64-bit inode number to userspace where possible, returning EOVERFLOW instead when a directory entry is encountered that can't be properly represented. Note that this means that some inodes will not be stat'able on a 32-bit system with old libraries where they were before - but it does mean that there will be no ambiguity over what a 32-bit inode number refers to. Note similarly that directory scans may be cut short with an error on a 32-bit system with old libraries where the scan would work before for the same reasons. It is judged unlikely that this situation will occur because modern glibc uses 64-bit capable versions of stat and getdents class functions exclusively, and that older systems are unlikely to encounter unrepresentable inode numbers anyway. [akpm: alpha build fix] Signed-off-by: David Howells <dhowells@redhat.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-30[PATCH] BLOCK: Remove no-longer necessary linux/buffer_head.h inclusions ↵David Howells
[try #6] Remove inclusions of linux/buffer_head.h that are no longer necessary due to the transfer of a number of things out of there. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2006-09-30[PATCH] BLOCK: Don't call block_sync_page() from AFS [try #6]David Howells
The AFS filesystem no longer needs to override its sync_page() op. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2006-09-29[PATCH] afs: add lock annotations to afs_proc_cell_servers_{start,stop}Josh Triplett
afs_proc_cell_servers_start acquires a lock, and afs_proc_cell_servers_stop releases that lock. Add lock annotations to these two functions so that sparse can check callers for lock pairing, and so that sparse will not complain about these functions since they intentionally use locks in this manner. Signed-off-by: Josh Triplett <josh@freedesktop.org> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] fs: Conversions from kmalloc+memset to k(z|c)allocPanagiotis Issaris
Conversions from kmalloc+memset to kzalloc. Signed-off-by: Panagiotis Issaris <takis@issaris.org> Jffs2-bit-acked-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-28[PATCH] mark address_space_operations constChristoph Hellwig
Same as with already do with the file operations: keep them in .rodata and prevents people from doing runtime patching. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Steven French <sfrench@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] fs: use list_move()Akinobu Mita
This patch converts the combination of list_del(A) and list_add(A, B) to list_move(A, B) under fs/. Cc: Ian Kent <raven@themaw.net> Acked-by: Joel Becker <joel.becker@oracle.com> Cc: Neil Brown <neilb@cse.unsw.edu.au> Cc: Hans Reiser <reiserfs-dev@namesys.com> Cc: Urban Widmark <urban@teststation.com> Acked-by: David Howells <dhowells@redhat.com> Acked-by: Mark Fasheh <mark.fasheh@oracle.com> Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-24Merge branch 'master' of /home/trondmy/kernel/linux-2.6/Trond Myklebust
Conflicts: fs/nfs/inode.c fs/super.c Fix conflicts between patch 'NFS: Split fs/nfs/inode.c' and patch 'VFS: Permit filesystem to override root dentry on mount'
2006-06-23[PATCH] read_mapping_page for address spacePekka Enberg
Add read_mapping_page() which is used for callers that pass mapping->a_ops->readpage as the filler for read_cache_page. This removes some duplication from filesystem code. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] VFS: Permit filesystem to override root dentry on mountDavid Howells
Extend the get_sb() filesystem operation to take an extra argument that permits the VFS to pass in the target vfsmount that defines the mountpoint. The filesystem is then required to manually set the superblock and root dentry pointers. For most filesystems, this should be done with simple_set_mnt() which will set the superblock pointer and then set the root dentry to the superblock's s_root (as per the old default behaviour). The get_sb() op now returns an integer as there's now no need to return the superblock pointer. This patch permits a superblock to be implicitly shared amongst several mount points, such as can be done with NFS to avoid potential inode aliasing. In such a case, simple_set_mnt() would not be called, and instead the mnt_root and mnt_sb would be set directly. The patch also makes the following changes: (*) the get_sb_*() convenience functions in the core kernel now take a vfsmount pointer argument and return an integer, so most filesystems have to change very little. (*) If one of the convenience function is not used, then get_sb() should normally call simple_set_mnt() to instantiate the vfsmount. This will always return 0, and so can be tail-called from get_sb(). (*) generic_shutdown_super() now calls shrink_dcache_sb() to clean up the dcache upon superblock destruction rather than shrink_dcache_anon(). This is required because the superblock may now have multiple trees that aren't actually bound to s_root, but that still need to be cleaned up. The currently called functions assume that the whole tree is rooted at s_root, and that anonymous dentries are not the roots of trees which results in dentries being left unculled. However, with the way NFS superblock sharing are currently set to be implemented, these assumptions are violated: the root of the filesystem is simply a dummy dentry and inode (the real inode for '/' may well be inaccessible), and all the vfsmounts are rooted on anonymous[*] dentries with child trees. [*] Anonymous until discovered from another tree. (*) The documentation has been adjusted, including the additional bit of changing ext2_* into foo_* in the documentation. [akpm@osdl.org: convert ipath_fs, do other stuff] Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Nathan Scott <nathans@sgi.com> Cc: Roland Dreier <rolandd@cisco.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-09VFS: Unexport do_kern_mount() and clean up simple_pin_fs()Trond Myklebust
Replace all module uses with the new vfs_kern_mount() interface, and fix up simple_pin_fs(). Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-03-28[PATCH] Make most file operations structs in fs/ constArjan van de Ven
This is a conversion to make the various file_operations structs in fs/ const. Basically a regexp job, with a few manual fixups The goal is both to increase correctness (harder to accidentally write to shared datastructures) and reducing the false sharing of cachelines with things that get dirty in .data (while .rodata is nicely read only and thus cache clean) Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] Make address_space_operations->invalidatepage return voidNeilBrown
The return value of this function is never used, so let's be honest and declare it as void. Some places where invalidatepage returned 0, I have inserted comments suggesting a BUG_ON. [akpm@osdl.org: JBD BUG fix] [akpm@osdl.org: rework for git-nfs] [akpm@osdl.org: don't go BUG in block_invalidate_page()] Signed-off-by: Neil Brown <neilb@suse.de> Acked-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] fs: Use ARRAY_SIZE macroTobias Klauser
Use ARRAY_SIZE macro instead of sizeof(x)/sizeof(x[0]) and remove a duplicate of ARRAY_SIZE. Some trailing whitespaces are also deleted. Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch> Cc: David Howells <dhowells@redhat.com> Cc: Dave Kleikamp <shaggy@austin.ibm.com> Acked-by: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Neil Brown <neilb@cse.unsw.edu.au> Cc: Chris Mason <mason@suse.com> Cc: Jeff Mahoney <jeffm@suse.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Nathan Scott <nathans@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] vfs: MS_VERBOSE should be MS_SILENTTheodore Ts'o
The meaning of MS_VERBOSE is backwards; if the bit is set, it really means, "don't be verbose". This is confusing and counter-intuitive. In addition, there is also no way to set the MS_VERBOSE flag in the mount(8) program in util-linux, but interesting, it does define options which would do the right thing if MS_SILENT were defined, which unfortunately we do not: #ifdef MS_SILENT { "quiet", 0, 0, MS_SILENT }, /* be quiet */ { "loud", 0, 1, MS_SILENT }, /* print out messages. */ #endif So the obvious fix is to deprecate the use of MS_VERBOSE and replace it with MS_SILENT. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-11add loglevel to printk in fs/afs/cmservice.cJesper Juhl
This is a small patch that adds loglevel to a printk in fs/afs/cmservice.c Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-01-08[PATCH] afs: remove unnecessary __attribute__((packed))Jan Blunck
Remove the unnecessary __attribute__((packed)) since the enum itself is packed and not the location of it in the structure. Signed-off-by: Jan Blunck <jblunck@suse.de> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] fix possible PAGE_CACHE_SHIFT overflowsAndrew Morton
We've had two instances recently of overflows when doing 64_bit_value = (32_bit_value << PAGE_CACHE_SHIFT) I did a tree-wide grep of `<<.*PAGE_CACHE_SHIFT' and this is the result. - afs_rxfs_fetch_descriptor.offset is of type off_t, which seems broken. - jfs and jffs are limited to 4GB anyway. - reiserfs map_block_for_writepage() takes an unsigned long for the block - it should take sector_t. (It'll fail for huge filesystems with blocksize<PAGE_CACHE_SIZE) - cramfs_read() needs to use sector_t (I think cramsfs is busted on large filesystems anyway) - affs is limited in file size anyway. - I generally didn't fix 32-bit overflows in directory operations. - arm's __flush_dcache_page() is peculiar. What if the page lies beyond 4G? - gss_wrap_req_priv() needs checking (snd_buf->page_base) Cc: Oleg Drokin <green@linuxhacker.ru> Cc: David Howells <dhowells@redhat.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: <reiserfs-dev@namesys.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Anton Altaparmakov <aia21@cantab.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: <linux-fsdevel@vger.kernel.org> Cc: Miklos Szeredi <miklos@szeredi.hu> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-08fs/afs/callback.c should #include "cmservice.h"Adrian Bunk
Every file should include the headers containing the prototypes for it's global functions. Signed-off-by: Adrian Bunk <bunk@stusta.de>
2005-11-07[PATCH] kfree cleanup: fsJesper Juhl
This is the fs/ part of the big kfree cleanup patch. Remove pointless checks for NULL prior to calling kfree() in fs/. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] afs: use generic_ro_fopsChristoph Hellwig
afs actually had a write method that returned different errors depending on whether some flag was set - better return the standard EINVAL errno. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29[PATCH] mm: split page table lockHugh Dickins
Christoph Lameter demonstrated very poor scalability on the SGI 512-way, with a many-threaded application which concurrently initializes different parts of a large anonymous area. This patch corrects that, by using a separate spinlock per page table page, to guard the page table entries in that page, instead of using the mm's single page_table_lock. (But even then, page_table_lock is still used to guard page table allocation, and anon_vma allocation.) In this implementation, the spinlock is tucked inside the struct page of the page table page: with a BUILD_BUG_ON in case it overflows - which it would in the case of 32-bit PA-RISC with spinlock debugging enabled. Splitting the lock is not quite for free: another cacheline access. Ideally, I suppose we would use split ptlock only for multi-threaded processes on multi-cpu machines; but deciding that dynamically would have its own costs. So for now enable it by config, at some number of cpus - since the Kconfig language doesn't support inequalities, let preprocessor compare that with NR_CPUS. But I don't think it's worth being user-configurable: for good testing of both split and unsplit configs, split now at 4 cpus, and perhaps change that to 8 later. There is a benefit even for singly threaded processes: kswapd can be attacking one part of the mm while another part is busy faulting. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-28[PATCH] gfp_t: fs/*Al Viro
- ->releasepage() annotated (s/int/gfp_t), instances updated - missing gfp_t in fs/* added - fixed misannotation from the original sweep caught by bitwise checks: XFS used __nocast both for gfp_t and for flags used by XFS allocator. The latter left with unsigned int __nocast; we might want to add a different type for those but for now let's leave them alone. That, BTW, is a case when __nocast use had been actively confusing - it had been used in the same code for two different and similar types, with no way to catch misuses. Switch of gfp_t to bitwise had caught that immediately... One tricky bit is left alone to be dealt with later - mapping->flags is a mix of gfp_t and error indications. Left alone for now. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-19[PATCH] Fix up symlink function pointersAl Viro
This fixes up the symlink functions for the calling convention change: * afs, autofs4, befs, devfs, freevxfs, jffs2, jfs, ncpfs, procfs, smbfs, sysvfs, ufs, xfs - prototype change for ->follow_link() * befs, smbfs, xfs - same for ->put_link() Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] Cleanup patch for process freezingChristoph Lameter
1. Establish a simple API for process freezing defined in linux/include/sched.h: frozen(process) Check for frozen process freezing(process) Check if a process is being frozen freeze(process) Tell a process to freeze (go to refrigerator) thaw_process(process) Restart process frozen_process(process) Process is frozen now 2. Remove all references to PF_FREEZE and PF_FROZEN from all kernel sources except sched.h 3. Fix numerous locations where try_to_freeze is manually done by a driver 4. Remove the argument that is no longer necessary from two function calls. 5. Some whitespace cleanup 6. Clear potential race in refrigerator (provides an open window of PF_FREEZE cleared before setting PF_FROZEN, recalc_sigpending does not check PF_FROZEN). This patch does not address the problem of freeze_processes() violating the rule that a task may only modify its own flags by setting PF_FREEZE. This is not clean in an SMP environment. freeze(process) is therefore not SMP safe! Signed-off-by: Christoph Lameter <christoph@lameter.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] Exterminate PAGE_BUGMatt Mackall
Remove PAGE_BUG - repalce it with BUG and BUG_ON. Signed-off-by: Matt Mackall <mpm@selenic.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
