commit 835f252c6debd204fcd607c79975089b1ecd3472 upstream.
https://bugzilla.kernel.org/show_bug.cgi?id=86831
Markus reported that when shutting down mysqld (with AIO support,
on a ext3 formatted Harddrive) leads to a negative number of dirty pages
(underrun to the counter). The negative number results in a drastic reduction
of the write performance because the page cache is not used, because the kernel
thinks it is still 2 ^ 32 dirty pages open.
Add a warn trace in __dec_zone_state will catch this easily:
static inline void __dec_zone_state(struct zone *zone, enum
zone_stat_item item)
atomic_long_dec(&zone->vm_stat[item]);
+ WARN_ON_ONCE(item == NR_FILE_DIRTY &&
atomic_long_read(&zone->vm_stat[item]) < 0);
atomic_long_dec(&vm_stat[item]);
[ 21.341632] ------------[ cut here ]------------
[ 21.346294] WARNING: CPU: 0 PID: 309 at include/linux/vmstat.h:242
cancel_dirty_page+0x164/0x224()
[ 21.355296] Modules linked in: wutbox_cp sata_mv
[ 21.359968] CPU: 0 PID: 309 Comm: kworker/0:1 Not tainted 3.14.21-WuT #80
[ 21.366793] Workqueue: events free_ioctx
[ 21.370760] [<c0016a64>] (unwind_backtrace) from [<c0012f88>]
(show_stack+0x20/0x24)
[ 21.378562] [<c0012f88>] (show_stack) from [<c03f8ccc>]
(dump_stack+0x24/0x28)
[ 21.385840] [<c03f8ccc>] (dump_stack) from [<c0023ae4>]
(warn_slowpath_common+0x84/0x9c)
[ 21.393976] [<c0023ae4>] (warn_slowpath_common) from [<c0023bb8>]
(warn_slowpath_null+0x2c/0x34)
[ 21.402800] [<c0023bb8>] (warn_slowpath_null) from [<c00c0688>]
(cancel_dirty_page+0x164/0x224)
[ 21.411524] [<c00c0688>] (cancel_dirty_page) from [<c00c080c>]
(truncate_inode_page+0x8c/0x158)
[ 21.420272] [<c00c080c>] (truncate_inode_page) from [<c00c0a94>]
(truncate_inode_pages_range+0x11c/0x53c)
[ 21.429890] [<c00c0a94>] (truncate_inode_pages_range) from
[<c00c0f6c>] (truncate_pagecache+0x88/0xac)
[ 21.439252] [<c00c0f6c>] (truncate_pagecache) from [<c00c0fec>]
(truncate_setsize+0x5c/0x74)
[ 21.447731] [<c00c0fec>] (truncate_setsize) from [<c013b3a8>]
(put_aio_ring_file.isra.14+0x34/0x90)
[ 21.456826] [<c013b3a8>] (put_aio_ring_file.isra.14) from
[<c013b424>] (aio_free_ring+0x20/0xcc)
[ 21.465660] [<c013b424>] (aio_free_ring) from [<c013b4f4>]
(free_ioctx+0x24/0x44)
[ 21.473190] [<c013b4f4>] (free_ioctx) from [<c003d8d8>]
(process_one_work+0x134/0x47c)
[ 21.481132] [<c003d8d8>] (process_one_work) from [<c003e988>]
(worker_thread+0x130/0x414)
[ 21.489350] [<c003e988>] (worker_thread) from [<c00448ac>]
(kthread+0xd4/0xec)
[ 21.496621] [<c00448ac>] (kthread) from [<c000ec18>]
(ret_from_fork+0x14/0x20)
[ 21.503884] ---[ end trace 79c4bf42c038c9a1 ]---
The cause is that we set the aio ring file pages as *DIRTY* via SetPageDirty
(bypasses the VFS dirty pages increment) when init, and aio fs uses
*default_backing_dev_info* as the backing dev, which does not disable
the dirty pages accounting capability.
So truncating aio ring file will contribute to accounting dirty pages (VFS
dirty pages decrement), then error occurs.
The original goal is keeping these pages in memory (can not be reclaimed
or swapped) in life-time via marking it dirty. But thinking more, we have
already pinned pages via elevating the page's refcount, which can already
achieve the goal, so the SetPageDirty seems unnecessary.
In order to fix the issue, using the __set_page_dirty_no_writeback instead
of the nop .set_page_dirty, and dropped the SetPageDirty (don't manually
set the dirty flags, don't disable set_page_dirty(), rely on default behaviour).
With the above change, the dirty pages accounting can work well. But as we
known, aio fs is an anonymous one, which should never cause any real write-back,
we can ignore the dirty pages (write back) accounting by disabling the dirty
pages (write back) accounting capability. So we introduce an aio private
backing dev info (disabled the ACCT_DIRTY/WRITEBACK/ACCT_WB capabilities) to
replace the default one.
Reported-by: Markus Königshaus <m.koenigshaus@wut.de>
Signed-off-by: Gu Zheng <guz.fnst@cn.fujitsu.com>
Acked-by: Andrew Morton <akpm@linux-foundation.org>
Signed-off-by: Benjamin LaHaise <bcrl@kvack.org>
commit 6098b45b32e6baeacc04790773ced9340601d511 upstream.
It seems that exit_aio() also needs to wait for all iocbs to complete (like
io_destroy), but we missed the wait step in current implemention, so fix
it in the same way as we did in io_destroy.
[bwh: Backported to 3.16: adjust context]
commit 2ff396be602f10b5eab8e73b24f20348fa2de159 upstream.
We ran into a case on ppc64 running mariadb where io_getevents would
return zeroed out I/O events. After adding instrumentation, it became
clear that there was some missing synchronization between reading the
tail pointer and the events themselves. This small patch fixes the
problem in testing.
Thanks to Zach for helping to look into this, and suggesting the fix.
Signed-off-by: Jeff Moyer <jmoyer@redhat.com>
commit d856f32a86b2b015ab180ab7a55e455ed8d3ccc5 upstream.
As reported by Dan Aloni, commit f8567a3845ac ("aio: fix aio request
leak when events are reaped by userspace") introduces a regression when
user code attempts to perform io_submit() with more events than are
available in the ring buffer. Reverting that commit would reintroduce a
regression when user space event reaping is used.
Fixing this bug is a bit more involved than the previous attempts to fix
this regression. Since we do not have a single point at which we can
count events as being reaped by user space and io_getevents(), we have
to track event completion by looking at the number of events left in the
event ring. So long as there are as many events in the ring buffer as
there have been completion events generate, we cannot call
put_reqs_available(). The code to check for this is now placed in
refill_reqs_available().
A test program from Dan and modified by me for verifying this bug is available
at http://www.kvack.org/~bcrl/20140824-aio_bug.c .
Reported-by: Dan Aloni <dan@kernelim.com>
Acked-by: Dan Aloni <dan@kernelim.com>
Cc: Kent Overstreet <kmo@daterainc.com>
Cc: Mateusz Guzik <mguzik@redhat.com>
Cc: Petr Matousek <pmatouse@redhat.com>
commit 263782c1c95bbddbb022dc092fd89a36bb8d5577 upstream.
As of commit f8567a3845ac05bb28f3c1b478ef752762bd39ef it is now possible to
have put_reqs_available() called from irq context. While put_reqs_available()
is per cpu, it did not protect itself from interrupts on the same CPU. This
lead to aio_complete() corrupting the available io requests count when run
under a heavy O_DIRECT workloads as reported by Robert Elliott. Fix this by
disabling irq updates around the per cpu batch updates of reqs_available.
Many thanks to Robert and folks for testing and tracking this down.
Reported-by: Robert Elliot <Elliott@hp.com>
Tested-by: Robert Elliot <Elliott@hp.com>
Cc: Jens Axboe <axboe@kernel.dk>, Christoph Hellwig <hch@infradead.org>
commit e02ba72aabfade4c9cd6e3263e9b57bf890ad25c upstream.
deletes aio context and all resources related to. It makes sense that
no IO operations connected to the context should be running after the context
is destroyed. As we removed io_context we have no chance to
get requests status or call io_getevents().
man page for io_destroy says that this function may block until
all context's requests are completed. Before kernel 3.11 io_destroy()
blocked indeed, but since aio refactoring in 3.11 it is not true anymore.
Here is a pseudo-code that shows a testcase for a race condition discovered
in 3.11:
initialize io_context
io_submit(read to buffer)
io_destroy()
// context is destroyed so we can free the resources
free(buffers);
// if the buffer is allocated by some other user he'll be surprised
// to learn that the buffer still filled by an outstanding operation
// from the destroyed io_context
The fix is straight-forward - add a completion struct and wait on it
in io_destroy, complete() should be called when number of in-fligh requests
reaches zero.
If two or more io_destroy() called for the same context simultaneously then
only the first one waits for IO completion, other calls behaviour is undefined.
Tested: ran http://pastebin.com/LrPsQ4RL testcase for several hours and
do not see the race condition anymore.
Signed-off-by: Anatol Pomozov <anatol.pomozov@gmail.com>
Cc: Jan Kara <jack@suse.cz>
commit edfbbf388f293d70bf4b7c0bc38774d05e6f711a upstream.
A kernel memory disclosure was introduced in aio_read_events_ring() in v3.10
by commit a31ad380bed817aa25f8830ad23e1a0480fef797. The changes made to
aio_read_events_ring() failed to correctly limit the index into
ctx->ring_pages[], allowing an attacked to cause the subsequent kmap() of
an arbitrary page with a copy_to_user() to copy the contents into userspace.
This vulnerability has been assigned CVE-2014-0206. Thanks to Mateusz and
Petr for disclosing this issue.
This patch applies to v3.12+. A separate backport is needed for 3.10/3.11.
Cc: Jeff Moyer <jmoyer@redhat.com>
commit f8567a3845ac05bb28f3c1b478ef752762bd39ef upstream.
The aio cleanups and optimizations by kmo that were merged into the 3.10
tree added a regression for userspace event reaping. Specifically, the
reference counts are not decremented if the event is reaped in userspace,
leading to the application being unable to submit further aio requests.
This patch applies to 3.12+. A separate backport is required for 3.10/3.11.
This issue was uncovered as part of CVE-2014-0206.
commit 754320d6e166d3a12cb4810a452bde00afbd4e9a upstream.
iovec should be reclaimed whenever caller of rw_copy_check_uvector() returns,
but it doesn't hold when failure happens right after aio_setup_vectored_rw().
Fix that in a such way to avoid hairy goto.
Signed-off-by: Leon Yu <chianglungyu@gmail.com>
commit fa8a53c39f3fdde98c9eace6a9b412143f0f6ed6 upstream.
As reported by Tang Chen, Gu Zheng and Yasuaki Isimatsu, the following issues
exist in the aio ring page migration support.
As a result, for example, we have the following problem:
thread 1 | thread 2
aio_migratepage() |
|-> take ctx->completion_lock |
|-> migrate_page_copy(new, old) |
| *NOW*, ctx->ring_pages[idx] == old |
| |-> ring = kmap_atomic(ctx->ring_pages[0])
| |-> ring->head = head; *HERE, write to the old ring page*
| |-> kunmap_atomic(ring);
|-> ctx->ring_pages[idx] = new |
| *BUT NOW*, the content of |
| ring_pages[idx] is old. |
|-> release ctx->completion_lock |
As above, the new ring page will not be updated.
Fix this issue, as well as prevent races in aio_ring_setup() by holding
the ring_lock mutex during kioctx setup and page migration. This avoids
the overhead of taking another spinlock in aio_read_events_ring() as Tang's
and Gu's original fix did, pushing the overhead into the migration code.
Note that to handle the nesting of ring_lock inside of mmap_sem, the
migratepage operation uses mutex_trylock(). Page migration is not a 100%
critical operation in this case, so the ocassional failure can be
tolerated. This issue was reported by Sasha Levin.
Based on feedback from Linus, avoid the extra taking of ctx->completion_lock.
Instead, make page migration fully serialised by mapping->private_lock, and
have aio_free_ring() simply disconnect the kioctx from the mapping by calling
put_aio_ring_file() before touching ctx->ring_pages[]. This simplifies the
error handling logic in aio_migratepage(), and should improve robustness.
v4: always do mutex_unlock() in cases when kioctx setup fails.
Reported-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
Reported-by: Sasha Levin <sasha.levin@oracle.com>
Cc: Tang Chen <tangchen@cn.fujitsu.com>
Cc: Gu Zheng <guz.fnst@cn.fujitsu.com>
Pull AIO leak fixes from Ben LaHaise:
"I've put these two patches plus Linus's change through a round of
tests, and it passes millions of iterations of the aio numa
migratepage test, as well as a number of repetitions of a few simple
read and write tests.
The first patch fixes the memory leak Kent introduced, while the
second patch makes aio_migratepage() much more paranoid and robust"
* git://git.kvack.org/~bcrl/aio-next:
aio/migratepages: make aio migrate pages sane
aio: fix kioctx leak introduced by "aio: Fix a trinity splat"
Since commit 36bc08cc01709 ("fs/aio: Add support to aio ring pages
migration") the aio ring setup code has used a special per-ring backing
inode for the page allocations, rather than just using random anonymous
pages.
However, rather than remembering the pages as it allocated them, it
would allocate the pages, insert them into the file mapping (dirty, so
that they couldn't be free'd), and then forget about them. And then to
look them up again, it would mmap the mapping, and then use
"get_user_pages()" to get back an array of the pages we just created.
Now, not only is that incredibly inefficient, it also leaked all the
pages if the mmap failed (which could happen due to excessive number of
mappings, for example).
So clean it all up, making it much more straightforward. Also remove
some left-overs of the previous (broken) mm_populate() usage that was
removed in commit d6c355c7dabc ("aio: fix race in ring buffer page
lookup introduced by page migration support") but left the pointless and
now misleading MAP_POPULATE flag around.
Tested-and-acked-by: Benjamin LaHaise <bcrl@kvack.org>
The arbitrary restriction on page counts offered by the core
migrate_page_move_mapping() code results in rather suspicious looking
fiddling with page reference counts in the aio_migratepage() operation.
To fix this, make migrate_page_move_mapping() take an extra_count parameter
that allows aio to tell the code about its own reference count on the page
being migrated.
While cleaning up aio_migratepage(), make it validate that the old page
being passed in is actually what aio_migratepage() expects to prevent
misbehaviour in the case of races.
e34ecee2ae791df674dfb466ce40692ca6218e43 reworked the percpu reference
counting to correct a bug trinity found. Unfortunately, the change lead
to kioctxes being leaked because there was no final reference count to
put. Add that reference count back in to fix things.
Cc: stable@vger.kernel.org
Pull aio fix from Benjamin LaHaise:
"AIO fix from Gu Zheng that fixes a GPF that Dave Jones uncovered with
trinity"
aio: clean up aio ring in the fail path
Clean up the aio ring file in the fail path of aio_setup_ring
and ioctx_alloc. And maybe it can fix the GPF issue reported by
Dave Jones:
https://lkml.org/lkml/2013/11/25/898
Pull aio fixes from Benjamin LaHaise.
aio: nullify aio->ring_pages after freeing it
aio: prevent double free in ioctx_alloc
After freeing ring_pages we leave it as is causing a dangling pointer. This
has already caused an issue so to help catching any issues in the future
NULL it out.
ioctx_alloc() calls aio_setup_ring() to allocate a ring. If aio_setup_ring()
fails to do so it would call aio_free_ring() before returning, but
ioctx_alloc() would call aio_free_ring() again causing a double free of
the ring.
This is easily reproducible from userspace.
alloc_anon_inode() returns an ERR_PTR(), it doesn't return NULL.
Fixes: 71ad7490c1f3 ('rework aio migrate pages to use aio fs')
Don't abuse anon_inodes.c to host private files needed by aio;
we can bloody well declare a mini-fs of our own instead of
patching up what anon_inodes can create for us.
Tested-by: Benjamin LaHaise <bcrl@kvack.org>
Acked-by: Benjamin LaHaise <bcrl@kvack.org>
aio kiocb refcounting was broken - it was relying on keeping track of
the number of available ring buffer entries, which it needs to do
anyways; then at shutdown time it'd wait for completions to be delivered
until the # of available ring buffer entries equalled what it was
initialized to.
Problem with that is that the ring buffer is mapped writable into
userspace, so userspace could futz with the head and tail pointers to
cause the kernel to see extra completions, and cause free_ioctx() to
return while there were still outstanding kiocbs. Which would be bad.
Fix is just to directly refcount the kiocbs - which is more
straightforward, and with the new percpu refcounting code doesn't cost
us any cacheline bouncing which was the whole point of the original
scheme.
Also clean up ioctx_alloc()'s error path and fix a bug where it wasn't
subtracting from aio_nr if ioctx_add_table() failed.
Signed-off-by: Kent Overstreet <kmo@daterainc.com>
Dmitry Vyukov managed to trigger a case where aio_migratepage can cause a
use-after-free during teardown of the aio ring buffer's mapping. This turns
out to be caused by access to the ioctx's ring_pages via the migratepage
operation which was not being protected by any locks during ioctx freeing.
Use the address_space's private_lock to protect use and updates of the mapping's
private_data, and make ioctx teardown unlink the ioctx from the address space.
Tested-by: Dmitry Vyukov <dvyukov@google.com>
Patch "aio: fix rcu sparse warnings introduced by ioctx table lookup patch"
(77d30b14d24e557f89c41980011d72428514d729 in linux-next.git) introduced a
couple of new rcu_dereference calls which are not protected by rcu_read_lock
and result in following warnings during syscall fuzzing(trinity):
[ 471.646379] ===============================
[ 471.649727] [ INFO: suspicious RCU usage. ]
[ 471.653919] 3.11.0-next-20130906+ #496 Not tainted
[ 471.657792] -------------------------------
[ 471.661235] fs/aio.c:503 suspicious rcu_dereference_check() usage!
[ 471.665968]
[ 471.665968] other info that might help us debug this:
[ 471.665968]
[ 471.672141]
[ 471.672141] rcu_scheduler_active = 1, debug_locks = 1
[ 471.677549] 1 lock held by trinity-child0/3774:
[ 471.681675] #0: (&(&mm->ioctx_lock)->rlock){+.+...}, at: [<c119ba1a>] SyS_io_setup+0x63a/0xc70
[ 471.688721]
[ 471.688721] stack backtrace:
[ 471.692488] CPU: 1 PID: 3774 Comm: trinity-child0 Not tainted 3.11.0-next-20130906+ #496
[ 471.698437] Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011
[ 471.703151] 00000000 00000000 c58bbf30 c18a814b de2234c0 c58bbf58 c10a4ec6 c1b0d824
[ 471.709544] c1b0f60e 00000001 00000001 c1af61b0 00000000 cb670ac0 c3aca000 c58bbfac
[ 471.716251] c119bc7c 00000002 00000001 00000000 c119b8dd 00000000 c10cf684 c58bbfb4
[ 471.722902] Call Trace:
[ 471.724859] [<c18a814b>] dump_stack+0x4b/0x66
[ 471.728772] [<c10a4ec6>] lockdep_rcu_suspicious+0xc6/0x100
[ 471.733716] [<c119bc7c>] SyS_io_setup+0x89c/0xc70
[ 471.737806] [<c119b8dd>] ? SyS_io_setup+0x4fd/0xc70
[ 471.741689] [<c10cf684>] ? __audit_syscall_entry+0x94/0xe0
[ 471.746080] [<c18b1fcc>] syscall_call+0x7/0xb
[ 471.749723] [<c1080000>] ? task_fork_fair+0x240/0x260
Signed-off-by: Artem Savkov <artem.savkov@gmail.com>
Reviewed-by: Gu Zheng <guz.fnst@cn.fujitsu.com>
Prior to the introduction of page migration support in "fs/aio: Add support
to aio ring pages migration" / 36bc08cc01709b4a9bb563b35aa530241ddc63e3,
mapping of the ring buffer pages was done via get_user_pages() while
retaining mmap_sem held for write. This avoided possible races with userland
racing an munmap() or mremap(). The page migration patch, however, switched
to using mm_populate() to prime the page mapping. mm_populate() cannot be
called with mmap_sem held.
Instead of dropping the mmap_sem, revert to the old behaviour and simply
drop the use of mm_populate() since get_user_pages() will cause the pages to
get mapped anyways. Thanks to Al Viro for spotting this issue.
Sseveral sparse warnings were caused by missing rcu_dereference() annotations
for dereferencing mm->ioctx_table. Thankfully, none of those were actual bugs
as the deref was protected by a spin lock in all instances.
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
The commit 36bc08cc0170 ("fs/aio: Add support to aio ring pages migration")
added some debugging code that is not required and resulted in a build error
when 98474236f72e ("vfs: make the dentry cache use the lockref infrastructure")
was added to the tree. The code is not required, so just delete it.
Another shortcoming of the table lookup patch was revealed where the pointer
was not being tested before being dereferenced. Verify this to avoid the
NULL pointer dereference.
lookup v3"
In the patch "aio: convert the ioctx list to table lookup v3", incorrect
handling in the ioctx_alloc() error path was introduced that lead to an
ioctx being added via ioctx_add_table() while freed when the ioctx_alloc()
call returned -EAGAIN due to hitting the aio_max_nr limit. Fix this by
only calling ioctx_add_table() as the last step in ioctx_alloc().
Also, several unnecessary rcu_dereference() calls were added that lead to
RCU warnings where the system was already protected by a spin lock for
accessing mm->ioctx_table.
In the event that an overflow/underflow occurs while calculating req_batch,
clamp the minimum at 1 request instead of doing a BUG_ON().
On Wed, Jun 12, 2013 at 11:14:40AM -0700, Kent Overstreet wrote:
> On Mon, Apr 15, 2013 at 02:40:55PM +0300, Octavian Purdila wrote:
> > When using a large number of threads performing AIO operations the
> > IOCTX list may get a significant number of entries which will cause
> > significant overhead. For example, when running this fio script:
> > rw=randrw; size=256k ;directory=/mnt/fio; ioengine=libaio; iodepth=1
> > blocksize=1024; numjobs=512; thread; loops=100
> > on an EXT2 filesystem mounted on top of a ramdisk we can observe up to
> > 30% CPU time spent by lookup_ioctx:
> > 32.51% [guest.kernel] [g] lookup_ioctx
> > 9.19% [guest.kernel] [g] __lock_acquire.isra.28
> > 4.40% [guest.kernel] [g] lock_release
> > 4.19% [guest.kernel] [g] sched_clock_local
> > 3.86% [guest.kernel] [g] local_clock
> > 3.68% [guest.kernel] [g] native_sched_clock
> > 3.08% [guest.kernel] [g] sched_clock_cpu
> > 2.64% [guest.kernel] [g] lock_release_holdtime.part.11
> > 2.60% [guest.kernel] [g] memcpy
> > 2.33% [guest.kernel] [g] lock_acquired
> > 2.25% [guest.kernel] [g] lock_acquire
> > 1.84% [guest.kernel] [g] do_io_submit
> > This patchs converts the ioctx list to a radix tree. For a performance
> > comparison the above FIO script was run on a 2 sockets 8 core
> > machine. This are the results (average and %rsd of 10 runs) for the
> > original list based implementation and for the radix tree based
> > implementation:
> > cores 1 2 4 8 16 32
> > list 109376 ms 69119 ms 35682 ms 22671 ms 19724 ms 16408 ms
> > %rsd 0.69% 1.15% 1.17% 1.21% 1.71% 1.43%
> > radix 73651 ms 41748 ms 23028 ms 16766 ms 15232 ms 13787 ms
> > %rsd 1.19% 0.98% 0.69% 1.13% 0.72% 0.75%
> > % of radix
> > relative 66.12% 65.59% 66.63% 72.31% 77.26% 83.66%
> > to list
> > To consider the impact of the patch on the typical case of having
> > only one ctx per process the following FIO script was run:
> > rw=randrw; size=100m ;directory=/mnt/fio; ioengine=libaio; iodepth=1
> > blocksize=1024; numjobs=1; thread; loops=100
> > on the same system and the results are the following:
> > list 58892 ms
> > %rsd 0.91%
> > radix 59404 ms
> > %rsd 0.81%
> > % of radix
> > relative 100.87%
> > to list
> So, I was just doing some benchmarking/profiling to get ready to send
> out the aio patches I've got for 3.11 - and it looks like your patch is
> causing a ~1.5% throughput regression in my testing :/
... <snip>
I've got an alternate approach for fixing this wart in lookup_ioctx()...
Instead of using an rbtree, just use the reserved id in the ring buffer
header to index an array pointing the ioctx. It's not finished yet, and
it needs to be tidied up, but is most of the way there.
-ben
"Thought is the essence of where you are now."
kmo> And, a rework of Ben's code, but this was entirely his idea
kmo> -Kent
bcrl> And fix the code to use the right mm_struct in kill_ioctx(), actually
free memory.
With the changes to use percpu counters for aio event ring size calculation,
existing increases to aio_max_nr are now insufficient to allow for the
allocation of enough events. Double the value used for aio_max_nr to account
for the doubling introduced by the percpu slack.
sock_aio_dtor() is dead code - and stuff that does need to do cleanup
can simply do it before calling aio_complete().
Signed-off-by: Kent Overstreet <koverstreet@google.com>
Cc: Zach Brown <zab@redhat.com>
Cc: Felipe Balbi <balbi@ti.com>
Cc: Mark Fasheh <mfasheh@suse.com>
Cc: Asai Thambi S P <asamymuthupa@micron.com>
Cc: Selvan Mani <smani@micron.com>
Cc: Sam Bradshaw <sbradshaw@micron.com>
Cc: Benjamin LaHaise <bcrl@kvack.org>
Cc: Theodore Ts'o <tytso@mit.edu>
The kiocb refcount is only needed for cancellation - to ensure a kiocb
isn't freed while a ki_cancel callback is running. But if we restrict
ki_cancel callbacks to not block (which they currently don't), we can
simply drop the refcount.
The old aio retry infrastucture needed to save the various arguments to
to aio operations. But with the retry infrastructure gone, we can trim
struct kiocb quite a bit.
This code doesn't serve any purpose anymore, since the aio retry
infrastructure has been removed.
This change should be safe because aio_read/write are also used for
synchronous IO, and called from do_sync_read()/do_sync_write() - and
there's no looping done in the sync case (the read and write syscalls).
aio_complete() (arguably) needs to keep its own trusted copy of the tail
pointer, but io_getevents() doesn't have to use it - it's already using
the head pointer from the ring buffer.
So convert it to use the tail from the ring buffer so it touches fewer
cachelines and doesn't contend with the cacheline aio_complete() needs.
Originally, io_event() was documented to return the io_event if
cancellation succeeded - the io_event wouldn't be delivered via the ring
buffer like it normally would.
But this isn't what the implementation was actually doing; the only
driver implementing cancellation, the usb gadget code, never returned an
io_event in its cancel function. And aio_complete() was recently changed
to no longer suppress event delivery if the kiocb had been cancelled.
This gets rid of the unused io_event argument to kiocb_cancel() and
kiocb->ki_cancel(), and changes io_cancel() to return -EINPROGRESS if
kiocb->ki_cancel() returned success.
Also tweak the refcounting in kiocb_cancel() to make more sense.
This just converts the ioctx refcount to the new generic dynamic percpu
refcount code.
Reviewed-by: "Theodore Ts'o" <tytso@mit.edu>
See the previous patch ("aio: reqs_active -> reqs_available") for why we
want to do this - this basically implements a per cpu allocator for
reqs_available that doesn't actually allocate anything.
Note that we need to increase the size of the ringbuffer we allocate,
since a single thread won't necessarily be able to use all the
reqs_available slots - some (up to about half) might be on other per cpu
lists, unavailable for the current thread.
We size the ringbuffer based on the nr_events userspace passed to
io_setup(), so this is a slight behaviour change - but nr_events wasn't
being used as a hard limit before, it was being rounded up to the next
page before so this doesn't change the actual semantics.
The number of outstanding kiocbs is one of the few shared things left that
has to be touched for every kiocb - it'd be nice to make it percpu.
We can make it per cpu by treating it like an allocation problem: we have
a maximum number of kiocbs that can be outstanding (i.e. slots) - then we
just allocate and free slots, and we know how to write per cpu allocators.
So as prep work for that, we convert reqs_active to reqs_available.
When "fs/aio: Add support to aio ring pages migration" was applied, it
broke the build when CONFIG_MIGRATION was disabled. Wrap the migration
code with a test for CONFIG_MIGRATION to fix this and save a few bytes
when migration is disabled.
As the aio job will pin the ring pages, that will lead to mem migrated
failed. In order to fix this problem we use an anon inode to manage the aio ring
pages, and setup the migratepage callback in the anon inode's address space, so
that when mem migrating the aio ring pages will be moved to other mem node safely.
ctx->ctx_lock should be ctx->completion_lock.
Signed-off-by: Tang Chen <tangchen@cn.fujitsu.com>
There was a regression introduced by 36f5588905c1 ("aio: refcounting
cleanup"), reported by Jens Axboe - the refcounting cleanup switched to
using RCU in the shutdown path, but the synchronize_rcu() was done in
the context of the io_destroy() syscall greatly increasing the time it
could block.
This patch switches it to call_rcu() and makes shutdown asynchronous
(more asynchronous than it was originally; before the refcount changes
io_destroy() would still wait on pending kiocbs).
Note that there's a global quota on the max outstanding kiocbs, and that
quota must be manipulated synchronously; otherwise io_setup() could
return -EAGAIN when there isn't quota available, and userspace won't
have any way of waiting until shutdown of the old kioctxs has finished
(besides busy looping).
So we release our quota before kioctx shutdown has finished, which
should be fine since the quota never corresponded to anything real
anyways.
Reported-by: Jens Axboe <axboe@kernel.dk>
Tested-by: Jens Axboe <axboe@kernel.dk>
The recent changes overhauling fs/aio.c introduced a bug that results in
the kioctx not being freed when outstanding kiocbs are cancelled at
exit_aio() time. Specifically, a kiocb that is cancelled has its
completion events discarded by batch_complete_aio(), which then fails to
wake up the process stuck in free_ioctx(). Fix this by modifying the
wait_event() condition in free_ioctx() appropriately.
This patch was tested with the cancel operation in the thread based code
posted yesterday.
[akpm@linux-foundation.org: fix build]
Cc: Kent Overstreet <koverstreet@google.com>
Cc: Josh Boyer <jwboyer@redhat.com>
In reviewing man pages, I noticed that io_getevents is documented to
update the timeout that gets passed into the library call. This doesn't
happen in kernel space or in the library (even though it's documented to
do so in both places). Unless there is objection, I'd like to fix the
comments/docs to match the code (I will also update the man page upon
consensus).
Acked-by: Cyril Hrubis <chrubis@suse.cz>
Acked-by: Michael Kerrisk <mtk.manpages@gmail.com>
Thanks to Zach Brown's work to rip out the retry infrastructure, we don't
need this anymore - ki_retry was only called right after the kiocb was
initialized.
This also refactors and trims some duplicated code, as well as cleaning up
the refcounting/error handling a bit.
[akpm@linux-foundation.org: use fmode_t in aio_run_iocb()]
[akpm@linux-foundation.org: fix file_start_write/file_end_write tests]
ki_key wasn't actually used for anything previously - it was always 0.
Drop it to trim struct kiocb a bit.
