path: root/fs/attr.c
2009-03-26vfs: Use lowercase names of quota functionsJan Kara
Use lowercase names of quota functions instead of old uppercase ones. Signed-off-by: Jan Kara <jack@suse.cz> CC: Alexander Viro <viro@zeniv.linux.org.uk>
2008-11-14CRED: Wrap task credential accesses in the filesystem subsystemDavid Howells
Wrap access to task credentials so that they can be separated more easily from the task_struct during the introduction of COW creds. Change most current->(|e|s|fs)[ug]id to current_(|e|s|fs)[ug]id(). Change some task->e?[ug]id to task_e?[ug]id(). In some places it makes more sense to use RCU directly rather than a convenient wrapper; these will be addressed by later patches. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: James Morris <jmorris@namei.org>
2008-10-23[patch] vfs: make security_inode_setattr() calling consistentMiklos Szeredi
Call security_inode_setattr() consistetly before inode_change_ok(). It doesn't make sense to try to "optimize" the i_op->setattr == NULL case, as most filesystem do define their own setattr function. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2008-07-26[patch 4/4] vfs: immutable inode checking cleanupMiklos Szeredi
Move the immutable and append-only checks from chmod, chown and utimes into notify_change(). Checks for immutable and append-only files are always performed by the VFS and not by the filesystem (see permission() and may_...() in namei.c), so these belong in notify_change(), and not in inode_change_ok(). This should be completely equivalent. CC: Ulrich Drepper <drepper@redhat.com> CC: Michael Kerrisk <mtk.manpages@gmail.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-07-26[patch 1/4] vfs: utimes: move owner check into inode_change_ok()Miklos Szeredi
Add a new ia_valid flag: ATTR_TIMES_SET, to handle the UTIMES_OMIT/UTIMES_NOW and UTIMES_NOW/UTIMES_OMIT cases. In these cases neither ATTR_MTIME_SET nor ATTR_ATIME_SET is in the flags, yet the POSIX draft specifies that permission checking is performed the same way as if one or both of the times was explicitly set to a timestamp. See the path "vfs: utimensat(): fix error checking for {UTIME_NOW,UTIME_OMIT} case" by Michael Kerrisk for the patch introducing this behavior. This is a cleanup, as well as allowing filesystems (NFS/fuse/...) to perform their own permission checking instead of the default. CC: Ulrich Drepper <drepper@redhat.com> CC: Michael Kerrisk <mtk.manpages@gmail.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2007-10-18VFS: make notify_change pass ATTR_KILL_S*ID to setattr operationsJeff Layton
When an unprivileged process attempts to modify a file that has the setuid or setgid bits set, the VFS will attempt to clear these bits. The VFS will set the ATTR_KILL_SUID or ATTR_KILL_SGID bits in the ia_valid mask, and then call notify_change to clear these bits and set the mode accordingly. With a networked filesystem (NFS and CIFS in particular but likely others), the client machine or process may not have credentials that allow for setting the mode. In some situations, this can lead to file corruption, an operation failing outright because the setattr fails, or to races that lead to a mode change being reverted. In this situation, we'd like to just leave the handling of this to the server and ignore these bits. The problem is that by the time the setattr op is called, the VFS has already reinterpreted the ATTR_KILL_* bits into a mode change. The setattr operation has no way to know its intent. The following patch fixes this by making notify_change no longer clear the ATTR_KILL_SUID and ATTR_KILL_SGID bits in the ia_valid before handing it off to the setattr inode op. setattr can then check for the presence of these bits, and if they're set it can assume that the mode change was only for the purposes of clearing these bits. This means that we now have an implicit assumption that notify_change is never called with ATTR_MODE and either ATTR_KILL_S*ID bit set. Nothing currently enforces that, so this patch also adds a BUG() if that occurs. Signed-off-by: Jeff Layton <jlayton@redhat.com> Cc: Michael Halcrow <mhalcrow@us.ibm.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Neil Brown <neilb@suse.de> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Chris Mason <chris.mason@oracle.com> Cc: Jeff Mahoney <jeffm@suse.com> Cc: "Vladimir V. Saveliev" <vs@namesys.com> Cc: Josef 'Jeff' Sipek <jsipek@cs.sunysb.edu> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Steven French <sfrench@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17Implement file posix capabilitiesSerge E. Hallyn
Implement file posix capabilities. This allows programs to be given a subset of root's powers regardless of who runs them, without having to use setuid and giving the binary all of root's powers. This version works with Kaigai Kohei's userspace tools, found at http://www.kaigai.gr.jp/index.php. For more information on how to use this patch, Chris Friedhoff has posted a nice page at http://www.friedhoff.org/fscaps.html. Changelog: Nov 27: Incorporate fixes from Andrew Morton (security-introduce-file-caps-tweaks and security-introduce-file-caps-warning-fix) Fix Kconfig dependency. Fix change signaling behavior when file caps are not compiled in. Nov 13: Integrate comments from Alexey: Remove CONFIG_ ifdef from capability.h, and use %zd for printing a size_t. Nov 13: Fix endianness warnings by sparse as suggested by Alexey Dobriyan. Nov 09: Address warnings of unused variables at cap_bprm_set_security when file capabilities are disabled, and simultaneously clean up the code a little, by pulling the new code into a helper function. Nov 08: For pointers to required userspace tools and how to use them, see http://www.friedhoff.org/fscaps.html. Nov 07: Fix the calculation of the highest bit checked in check_cap_sanity(). Nov 07: Allow file caps to be enabled without CONFIG_SECURITY, since capabilities are the default. Hook cap_task_setscheduler when !CONFIG_SECURITY. Move capable(TASK_KILL) to end of cap_task_kill to reduce audit messages. Nov 05: Add secondary calls in selinux/hooks.c to task_setioprio and task_setscheduler so that selinux and capabilities with file cap support can be stacked. Sep 05: As Seth Arnold points out, uid checks are out of place for capability code. Sep 01: Define task_setscheduler, task_setioprio, cap_task_kill, and task_setnice to make sure a user cannot affect a process in which they called a program with some fscaps. One remaining question is the note under task_setscheduler: are we ok with CAP_SYS_NICE being sufficient to confine a process to a cpuset? It is a semantic change, as without fsccaps, attach_task doesn't allow CAP_SYS_NICE to override the uid equivalence check. But since it uses security_task_setscheduler, which elsewhere is used where CAP_SYS_NICE can be used to override the uid equivalence check, fixing it might be tough. task_setscheduler note: this also controls cpuset:attach_task. Are we ok with CAP_SYS_NICE being used to confine to a cpuset? task_setioprio task_setnice sys_setpriority uses this (through set_one_prio) for another process. Need same checks as setrlimit Aug 21: Updated secureexec implementation to reflect the fact that euid and uid might be the same and nonzero, but the process might still have elevated caps. Aug 15: Handle endianness of xattrs. Enforce capability version match between kernel and disk. Enforce that no bits beyond the known max capability are set, else return -EPERM. With this extra processing, it may be worth reconsidering doing all the work at bprm_set_security rather than d_instantiate. Aug 10: Always call getxattr at bprm_set_security, rather than caching it at d_instantiate. [morgan@kernel.org: file-caps clean up for linux/capability.h] [bunk@kernel.org: unexport cap_inode_killpriv] Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Cc: Stephen Smalley <sds@tycho.nsa.gov> Cc: James Morris <jmorris@namei.org> Cc: Chris Wright <chrisw@sous-sol.org> Cc: Andrew Morgan <morgan@kernel.org> Signed-off-by: Andrew Morgan <morgan@kernel.org> Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17Introduce is_owner_or_cap() to wrap CAP_FOWNER use with fsuid checkSatyam Sharma
Introduce is_owner_or_cap() macro in fs.h, and convert over relevant users to it. This is done because we want to avoid bugs in the future where we check for only effective fsuid of the current task against a file's owning uid, without simultaneously checking for CAP_FOWNER as well, thus violating its semantics. [ XFS uses special macros and structures, and in general looked ... untouchable, so we leave it alone -- but it has been looked over. ] The (current->fsuid != inode->i_uid) check in generic_permission() and exec_permission_lite() is left alone, because those operations are covered by CAP_DAC_OVERRIDE and CAP_DAC_READ_SEARCH. Similarly operations falling under the purview of CAP_CHOWN and CAP_LEASE are also left alone. Signed-off-by: Satyam Sharma <ssatyam@cse.iitk.ac.in> Cc: Al Viro <viro@ftp.linux.org.uk> Acked-by: Serge E. Hallyn <serge@hallyn.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-01-11[PATCH] capable/capability.h (fs/)Randy Dunlap
fs: Use <linux/capability.h> where capable() is used. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Acked-by: Tim Schmielau <tim@physik3.uni-rostock.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-11fs/attr.c: header included twiceNicolas Kaiser
Header included twice. Signed-off-by: Nicolas Kaiser <nikai@nikai.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-01-08[PATCH] Fix some problems with truncate and mtime semantics.NeilBrown
SUS requires that when truncating a file to the size that it currently is: truncate and ftruncate should NOT modify ctime or mtime O_TRUNC SHOULD modify ctime and mtime. Currently mtime and ctime are always modified on most local filesystems (side effect of ->truncate) or never modified (on NFS). With this patch: ATTR_CTIME|ATTR_MTIME are sent with ATTR_SIZE precisely when an update of these times is required whether size changes or not (via a new argument to do_truncate). This allows NFS to do the right thing for O_TRUNC. inode_setattr nolonger forces ATTR_MTIME|ATTR_CTIME when the ATTR_SIZE sets the size to it's current value. This allows local filesystems to do the right thing for f?truncate. Also, the logic in inode_setattr is changed a bit so there are two return points. One returns the error from vmtruncate if it failed, the other returns 0 (there can be no other failure). Finally, if vmtruncate succeeds, and ATTR_SIZE is the only change requested, we now fall-through and mark_inode_dirty. If a filesystem did not have a ->truncate function, then vmtruncate will have changed i_size, without marking the inode as 'dirty', and I think this is wrong. Signed-off-by: Neil Brown <neilb@suse.de> Cc: Christoph Hellwig <hch@lst.de> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] fs/attr.c: remove BUG()Alexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-12[PATCH] inotifyRobert Love
inotify is intended to correct the deficiencies of dnotify, particularly its inability to scale and its terrible user interface: * dnotify requires the opening of one fd per each directory that you intend to watch. This quickly results in too many open files and pins removable media, preventing unmount. * dnotify is directory-based. You only learn about changes to directories. Sure, a change to a file in a directory affects the directory, but you are then forced to keep a cache of stat structures. * dnotify's interface to user-space is awful. Signals? inotify provides a more usable, simple, powerful solution to file change notification: * inotify's interface is a system call that returns a fd, not SIGIO. You get a single fd, which is select()-able. * inotify has an event that says "the filesystem that the item you were watching is on was unmounted." * inotify can watch directories or files. Inotify is currently used by Beagle (a desktop search infrastructure), Gamin (a FAM replacement), and other projects. See Documentation/filesystems/inotify.txt. Signed-off-by: Robert Love <rml@novell.com> Cc: John McCutchan <ttb@tentacle.dhs.org> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
