path: root/fs/autofs4/inode.c
2008-02-08mount options: fix autofs4Miklos Szeredi
Add uid= and gid= options to /proc/mounts for autofs4 filesystems. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Acked-by: Ian Kent <raven@themaw.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19pid namespaces: round up the APIPavel Emelianov
The set of functions process_session, task_session, process_group and task_pgrp is confusing, as the names can be mixed with each other when looking at the code for a long time. The proposals are to * equip the functions that return the integer with _nr suffix to represent that fact, * and to make all functions work with task (not process) by making the common prefix of the same name. For monotony the routines signal_session() and set_signal_session() are replaced with task_session_nr() and set_task_session(), especially since they are only used with the explicit task->signal dereference. Signed-off-by: Pavel Emelianov <xemul@openvz.org> Acked-by: Serge E. Hallyn <serue@us.ibm.com> Cc: Kirill Korotaev <dev@openvz.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17fs/autofs4/inode.c: kmalloc + memset conversion to kzallocMariusz Kozlowski
fs/autofs4/inode.c | 10467 -> 10435 (-32 bytes) fs/autofs4/inode.o | 98576 -> 98552 (-24 bytes) Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl> Acked-by: Ian Kent <raven@themaw.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-11Fix some coding-style errors in autofsSukadev Bhattiprolu
Fix coding style errors (extra spaces, long lines) in autofs and autofs4 files being modified for container/pidspace issues. Signed-off-by: Sukadev Bhattiprolu <sukadev@us.ibm.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: Serge Hallyn <serue@us.ibm.com> Cc: <containers@lists.osdl.org> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Ian Kent <raven@themaw.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-20[PATCH] autofs4: fix another race between mount and expireIan Kent
Jeff Moyer has identified a race between mount and expire. What happens is that during an expire the situation can arise that a directory is removed and another lookup is done before the expire issues a completion status to the kernel module. In this case, since the the lookup gets a new dentry, it doesn't know that there is an expire in progress and when it posts its mount request, matches the existing expire request and waits for its completion. ENOENT is then returned to user space from lookup (as the dentry passed in is now unhashed) without having performed the mount request. The solution used here is to keep track of dentrys in this unhashed state and reuse them, if possible, in order to preserve the flags. Additionally, this infrastructure will provide the framework for the reintroduction of caching of mount fails removed earlier in development. Signed-off-by: Ian Kent <raven@themaw.net> Acked-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-13[PATCH] getting rid of all casts of k[cmz]alloc() callsRobert P. J. Day
Run this: #!/bin/sh for f in $(grep -Erl "\([^\)]*\) *k[cmz]alloc" *) ; do echo "De-casting $f..." perl -pi -e "s/ ?= ?\([^\)]*\) *(k[cmz]alloc) *\(/ = \1\(/" $f done And then go through and reinstate those cases where code is casting pointers to non-pointers. And then drop a few hunks which conflicted with outstanding work. Cc: Russell King <rmk@arm.linux.org.uk>, Ian Molton <spyro@f2s.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Greg KH <greg@kroah.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Paul Fulghum <paulkf@microgate.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Karsten Keil <kkeil@suse.de> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: Jeff Garzik <jeff@garzik.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Ian Kent <raven@themaw.net> Cc: Steven French <sfrench@us.ibm.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Neil Brown <neilb@cse.unsw.edu.au> Cc: Jaroslav Kysela <perex@suse.cz> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] autofs: fix error code path in autofs_fill_sb()Jiri Kosina
When kernel is compiled with old version of autofs (CONFIG_AUTOFS_FS), and new (observed at least with 5.x.x) automount deamon is started, kernel correctly reports incompatible version of kernel and userland daemon, but then screws things up instead of correct handling of the error: autofs: kernel does not match daemon version ===================================== [ BUG: bad unlock balance detected! ] ------------------------------------- automount/4199 is trying to release lock (&type->s_umount_key) at: [<c0163b9e>] get_sb_nodev+0x76/0xa4 but there are no more locks to release! other info that might help us debug this: no locks held by automount/4199. stack backtrace: [<c0103b15>] dump_trace+0x68/0x1b2 [<c0103c77>] show_trace_log_lvl+0x18/0x2c [<c01041db>] show_trace+0xf/0x11 [<c010424d>] dump_stack+0x12/0x14 [<c012e02c>] print_unlock_inbalance_bug+0xe7/0xf3 [<c012fd4f>] lock_release+0x8d/0x164 [<c012b452>] up_write+0x14/0x27 [<c0163b9e>] get_sb_nodev+0x76/0xa4 [<c0163689>] vfs_kern_mount+0x83/0xf6 [<c016373e>] do_kern_mount+0x2d/0x3e [<c017513f>] do_mount+0x607/0x67a [<c0175224>] sys_mount+0x72/0xa4 [<c0102b96>] sysenter_past_esp+0x5f/0x99 DWARF2 unwinder stuck at sysenter_past_esp+0x5f/0x99 Leftover inexact backtrace: ======================= and then deadlock comes. The problem: autofs_fill_super() returns EINVAL to get_sb_nodev(), but before that, it calls kill_anon_super() to destroy the superblock which won't be needed. This is however way too soon to call kill_anon_super(), because get_sb_nodev() has to perform its own cleanup of the superblock first (deactivate_super(), etc.). The correct time to call kill_anon_super() is in the autofs_kill_sb() callback, which is called by deactivate_super() at proper time, when the superblock is ready to be killed. I can see the same faulty codepath also in autofs4. This patch solves issues in both filesystems in a same way - it postpones the kill_anon_super() until the proper time is signalized by deactivate_super() calling the kill_sb() callback. [raven@themaw.net: update comment] Signed-off-by: Jiri Kosina <jkosina@suse.cz> Acked-by: Ian Kent <raven@themaw.net> Cc: <stable@kernel.org> Signed-off-by: Ian Kent <raven@themaw.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-14[PATCH] autofs4: panic after mount failIan Kent
Resolve the panic on failed mount of an autofs filesystem originally reported by Mao Bibo. It addresses two issues that happen after the mount fail. The first a NULL pointer reference to a field (pipe) in the autofs superblock info structure and second the lack of super block cleanup by the autofs and autofs4 modules. Signed-off-by: Ian Kent <raven@themaw.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] AUTOFS: Make sure all dentries refs are released before calling ↵David Howells
kill_anon_super() Make sure all dentries refs are released before calling kill_anon_super() so that the assumption that generic_shutdown_super() can completely destroy the dentry tree for there will be no external references holds true. What was being done in the put_super() superblock op, is now done in the kill_sb() filesystem op instead, prior to calling kill_anon_super(). This makes the struct autofs_sb_info::root member variable redundant (since sb->s_root is still available), and so that is removed. The calls to shrink_dcache_sb() are also removed since they're also redundant as shrink_dcache_for_umount() will now be called after the cleanup routine. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Ian Kent <raven@themaw.net> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-24Move several *_SUPER_MAGIC symbols to include/linux/magic.h.Jeff Garzik
Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-03-28[PATCH] autofs4: proper prototype for autofs4_dentry_release()Adrian Bunk
Add a proper prototype for autofs4_dentry_release() to autofs_i.h. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] Remove redundant check from autofs4_put_superDave Jones
We have to have a valid sbi here, or we'd have oopsed already. (There's a dereference of sbi->catatonic a few lines above) Coverity #740 Signed-off-by: Dave Jones <davej@redhat.com> Cc: Ian Kent <raven@themaw.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] autofs4: change AUTOFS_TYP_* AUTOFS_TYPE_*Ian Kent
2006-03-27[PATCH] autofs4: add v5 follow_link mount trigger methodIan Kent
This patch adds a follow_link inode method for the root of an autofs direct mount trigger. It also adds the corresponding mount options and updates the show_mount method. Signed-off-by: Ian Kent <raven@themaw.net> Cc: Al Viro <viro@ftp.linux.org.uk> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] autofs4: add a show mount options for proc filesystemIan Kent
Add show_options method to display autofs4 mount options in the proc filesystem. Signed-off-by: Ian Kent <raven@themaw.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] autofs4: fix false negative return from expireIan Kent
Fix the case where an expire returns busy on a tree mount when it is in fact not busy. This case was overlooked when the patch to prevent the expiring away of "scaffolding" directories for tree mounts was applied. The problem arises when a tree of mounts is a member of a map with other keys. The current logic will not expire the tree if any other mount in the map is busy. The solution is to maintain a "minimum" use count for each autofs dentry and compare this to the actual dentry usage count during expire. Signed-off-by: Ian Kent <raven@themaw.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] sem2mutex: autofs4 wq_semIngo Molnar
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Ingo Molnar <mingo@elte.hu> Acked-by: Ian Kent <raven@themaw.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] shrink dentry structEric Dumazet
Some long time ago, dentry struct was carefully tuned so that on 32 bits UP, sizeof(struct dentry) was exactly 128, ie a power of 2, and a multiple of memory cache lines. Then RCU was added and dentry struct enlarged by two pointers, with nice results for SMP, but not so good on UP, because breaking the above tuning (128 + 8 = 136 bytes) This patch reverts this unwanted side effect, by using an union (d_u), where d_rcu and d_child are placed so that these two fields can share their memory needs. At the time d_free() is called (and d_rcu is really used), d_child is known to be empty and not touched by the dentry freeing. Lockless lookups only access d_name, d_parent, d_lock, d_op, d_flags (so the previous content of d_child is not needed if said dentry was unhashed but still accessed by a CPU because of RCU constraints) As dentry cache easily contains millions of entries, a size reduction is worth the extra complexity of the ugly C union. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Cc: Dipankar Sarma <dipankar@in.ibm.com> Cc: Maneesh Soni <maneesh@in.ibm.com> Cc: Miklos Szeredi <miklos@szeredi.hu> Cc: "Paul E. McKenney" <paulmck@us.ibm.com> Cc: Ian Kent <raven@themaw.net> Cc: Paul Jackson <pj@sgi.com> Cc: Al Viro <viro@ftp.linux.org.uk> Cc: Christoph Hellwig <hch@lst.de> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Neil Brown <neilb@cse.unsw.edu.au> Cc: James Morris <jmorris@namei.org> Cc: Stephen Smalley <sds@epoch.ncsc.mil> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] kfree cleanup: fsJesper Juhl
This is the fs/ part of the big kfree cleanup patch. Remove pointless checks for NULL prior to calling kfree() in fs/. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-27[PATCH] autofs4: fix infamous "Busy inodes after umount ..." messageIan Kent
If the automount daemon receives a signal which causes it to sumarily terminate the autofs4 module leaks dentries. The same problem exists with detached mount requests without the warning. This patch cleans these dentries at umount. Signed-off-by: Ian Kent <raven@themaw.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] autofs4: tree race fixIan Kent
For tree mount maps, a call to chdir or chroot, to a directory above the moint point directories at a certain time during the expire results in the expire incorrectly thinking the tree is not busy. This patch adds a check to see if the filesystem above the tree mount points is busy and also locks the filesystem during the tree mount expire to prevent the race. Signed-off-by: Ian Kent <raven@themaw.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
