Change-Id: Ib3b69ffc5ac3e07c9cc44cc49e9142088eec477e
vfs_create() ignores everything outside of 16bit subset of its
mode argument; switching it to umode_t is obviously equivalent
and it's the only caller of the method
vfs_mkdir() gets int, but immediately drops everything that might not
fit into umode_t and that's the only caller of ->mkdir()...
Btrfs needs to be able to control how filemap_write_and_wait_range() is called
in fsync to make it less of a painful operation, so push down taking i_mutex and
the calling of filemap_write_and_wait() down into the ->fsync() handlers. Some
file systems can drop taking the i_mutex altogether it seems, like ext3 and
ocfs2. For correctness sake I just pushed everything down in all cases to make
sure that we keep the current behavior the same for everybody, and then each
individual fs maintainer can make up their mind about what to do from there.
Thanks,
Acked-by: Jan Kara <jack@suse.cz>
Signed-off-by: Josef Bacik <josef@redhat.com>
not used by the instances anymore.
return -EIO; is *not* a blocking operation, thank you very much.
Nick, what the hell have you been smoking?
Signed-off-by: Nick Piggin <npiggin@kernel.dk>
The last user is gone, so we can safely remove this
Cc: John Kacur <jkacur@redhat.com>
Cc: Al Viro <viro@ZenIV.linux.org.uk>
Remove the hopelessly misguided ->dir_notify(). The only instance (cifs)
has been broken by design from the very beginning; the objects it creates
are never destroyed, keep references to struct file they can outlive, nothing
that could possibly evict them exists on close(2) path *and* no locking
whatsoever is done to prevent races with close(), should the previous, er,
deficiencies someday be dealt with.
* kill nameidata * argument; map the 3 bits in ->flags anybody cares
about to new MAY_... ones and pass with the mask.
* kill redundant gfs2_iop_permission()
* sanitize ecryptfs_permission()
* fix remaining places where ->permission() instances might barf on new
MAY_... found in mask.
The obvious next target in that direction is permission(9)
folded fix for nfs_permission() breakage from Miklos Szeredi <mszeredi@suse.cz>
Introduce a function to register failure in an inode construction path. This
includes marking the inode under construction as bad, unlocking it and
releasing it.
Acked-by: Christoph Hellwig <hch@lst.de>
do_sendfile() prefers splice over sendfile, so it should not trigger
(directly, at least).
Remove includes of <linux/smp_lock.h> where it is not used/needed.
Suggested by Al Viro.
Builds cleanly on x86_64, i386, alpha, ia64, powerpc, sparc,
sparc64, and arm (all 59 defconfigs).
Many struct inode_operations in the kernel can be "const". Marking them const
moves these to the .rodata section, which avoids false sharing with potential
dirty data. In addition it'll catch accidental writes at compile time to
these shared resources.
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
CVE-2006-5753 is for a case where an inode can be marked bad, switching
the ops to bad_inode_ops, which are all connected as:
static int return_EIO(void)
return -EIO;
#define EIO_ERROR ((void *) (return_EIO))
static struct inode_operations bad_inode_ops =
.create = bad_inode_create
...etc...
The problem here is that the void cast causes return types to not be
promoted, and for ops such as listxattr which expect more than 32 bits of
return value, the 32-bit -EIO is interpreted as a large positive 64-bit
number, i.e. 0x00000000fffffffa instead of 0xfffffffa.
This goes particularly badly when the return value is taken as a number of
bytes to copy into, say, a user's buffer for example...
I originally had coded up the fix by creating a return_EIO_<TYPE> macro
for each return type, like this:
static int return_EIO_int(void)
return -EIO;
#define EIO_ERROR_INT ((void *) (return_EIO_int))
.create = EIO_ERROR_INT,
...etc...
but Al felt that it was probably better to create an EIO-returner for each
actual op signature. Since so few ops share a signature, I just went ahead
& created an EIO function for each individual file & inode op that returns
a value.
Signed-off-by: Eric Sandeen <sandeen@redhat.com>
This patch removes readv() and writev() methods and replaces them with
aio_read()/aio_write() methods.
Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com>
This is a conversion to make the various file_operations structs in fs/
const. Basically a regexp job, with a few manual fixups
The goal is both to increase correctness (harder to accidentally write to
shared datastructures) and reducing the false sharing of cachelines with
things that get dirty in .data (while .rodata is nicely read only and thus
cache clean)
Signed-off-by: Arjan van de Ven <arjan@infradead.org>
This patch makes some needlessly global identifiers static.
Acked-by: Arjan van de Ven <arjanv@infradead.org>
Acked-by: Trond Myklebust <trond.myklebust@fys.uio.no>
infrastructure for it.
Let it rip!
