path: root/fs/befs/super.c
2016-10-08befs: fix style issues in super.cLuis de Bethencourt
Fixing the following checkpatch.pl error: ERROR: "foo * bar" should be "foo *bar" +befs_load_sb(struct super_block *sb, befs_super_block * disk_sb) And the following warnings: WARNING: suspect code indent for conditional statements (8, 12) + if (disk_sb->fs_byte_order == BEFS_BYTEORDER_NATIVE_LE) + befs_sb->byte_order = BEFS_BYTESEX_LE; WARNING: suspect code indent for conditional statements (8, 12) + else if (disk_sb->fs_byte_order == BEFS_BYTEORDER_NATIVE_BE) + befs_sb->byte_order = BEFS_BYTESEX_BE; WARNING: break quoted strings at a space character + befs_error(sb, "blocksize(%u) cannot be larger" + "than system pagesize(%lu)", befs_sb->block_size, WARNING: line over 80 characters + if (befs_sb->log_start != befs_sb->log_end || befs_sb->flags == BEFS_DIRTY) { Signed-off-by: Luis de Bethencourt <luisbg@osg.samsung.com> Signed-off-by: Salah Triki <salah.triki@gmail.com>
2016-10-08befs: fix comment styleLuis de Bethencourt
The description of befs_load_sb was confusing the kernel-doc system since, because it starts with /**, it thinks it will document the function with kernel-doc formatting. Which it isn't. Fix other comment style issues in the file while we are at it. Signed-off-by: Luis de Bethencourt <luisbg@osg.samsung.com> Signed-off-by: Salah Triki <salah.triki@gmail.com>
2016-10-08befs: add check for ag_shift in superblockLuis de Bethencourt
ag_shift and blocks_per_ag contain the same information in different ways, same as block_shift and block_size do. It is worth checking this two are consistent, but since blocks_per_ag isn't documented as mandatory to use some implementations of befs don't enforce this, so making it non-fatal if they don't match and just having it as a warning. Signed-off-by: Luis de Bethencourt <luisbg@osg.samsung.com> Signed-off-by: Salah Triki <salah.triki@gmail.com>
2016-10-08befs: add flags field to validate superblock stateSalah Triki
For validating superblock state, add flags field to befs_sb_info, read the state from the disk and check if it is equal to BEFS_DIRTY. Signed-off-by: Salah Triki <salah.triki@gmail.com> Signed-off-by: Luis de Bethencourt <luisbg@osg.samsung.com>
2016-10-08befs: fix function name in documentationLuis de Bethencourt
Documentation of function befs_load_cb() lists it as load_befs_sb(). Fix the misnomer. Link: http://lkml.kernel.org/r/1465700235-22881-2-git-send-email-luisbg@osg.samsung.com Signed-off-by: Luis de Bethencourt <luisbg@osg.samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2015-04-17befs: replace typedef befs_sb_info by structureFabian Frederick
See Documenation/CodingStyle Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-08befs: fix build on pariscAlexander Beregalov
fs/befs/super.c:85: error: 'PAGE_SIZE' undeclared Signed-off-by: Alexander Beregalov <a.beregalov@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16befs: annotate fs32 on tests for superblock endiannessHarvey Harrison
Does compile-time byteswapping rather than runtime. Noticed by sparse: fs/befs/super.c:29:6: warning: cast to restricted __le32 fs/befs/super.c:29:6: warning: cast from restricted fs32 fs/befs/super.c:31:11: warning: cast to restricted __be32 fs/befs/super.c:31:11: warning: cast from restricted fs32 fs/befs/super.c:31:11: warning: cast to restricted __be32 fs/befs/super.c:31:11: warning: cast from restricted fs32 fs/befs/super.c:31:11: warning: cast to restricted __be32 fs/befs/super.c:31:11: warning: cast from restricted fs32 fs/befs/super.c:31:11: warning: cast to restricted __be32 fs/befs/super.c:31:11: warning: cast from restricted fs32 fs/befs/super.c:31:11: warning: cast to restricted __be32 fs/befs/super.c:31:11: warning: cast from restricted fs32 fs/befs/super.c:31:11: warning: cast to restricted __be32 fs/befs/super.c:31:11: warning: cast from restricted fs32 fs/befs/linuxvfs.c:811:7: warning: cast to restricted __le32 fs/befs/linuxvfs.c:811:7: warning: cast from restricted fs32 fs/befs/linuxvfs.c:812:7: warning: cast to restricted __be32 fs/befs/linuxvfs.c:812:7: warning: cast from restricted fs32 fs/befs/linuxvfs.c:812:7: warning: cast to restricted __be32 fs/befs/linuxvfs.c:812:7: warning: cast from restricted fs32 fs/befs/linuxvfs.c:812:7: warning: cast to restricted __be32 fs/befs/linuxvfs.c:812:7: warning: cast from restricted fs32 fs/befs/linuxvfs.c:812:7: warning: cast to restricted __be32 fs/befs/linuxvfs.c:812:7: warning: cast from restricted fs32 fs/befs/linuxvfs.c:812:7: warning: cast to restricted __be32 fs/befs/linuxvfs.c:812:7: warning: cast from restricted fs32 fs/befs/linuxvfs.c:812:7: warning: cast to restricted __be32 fs/befs/linuxvfs.c:812:7: warning: cast from restricted fs32 Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: "Sergey S. Kostyliov" <rathamahata@php4.ru> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-10[PATCH] befs: prepare to sanitizing headersAl Viro
pulled includes of endian.h from fs/befs/*.c to befs.h Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
