path: root/fs/befs
2015-07-04Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull more vfs updates from Al Viro: "Assorted VFS fixes and related cleanups (IMO the most interesting in that part are f_path-related things and Eric's descriptor-related stuff). UFS regression fixes (it got broken last cycle). 9P fixes. fs-cache series, DAX patches, Jan's file_remove_suid() work" [ I'd say this is much more than "fixes and related cleanups". The file_table locking rule change by Eric Dumazet is a rather big and fundamental update even if the patch isn't huge. - Linus ] * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (49 commits) 9p: cope with bogus responses from server in p9_client_{read,write} p9_client_write(): avoid double p9_free_req() 9p: forgetting to cancel request on interrupted zero-copy RPC dax: bdev_direct_access() may sleep block: Add support for DAX reads/writes to block devices dax: Use copy_from_iter_nocache dax: Add block size note to documentation fs/file.c: __fget() and dup2() atomicity rules fs/file.c: don't acquire files->file_lock in fd_install() fs:super:get_anon_bdev: fix race condition could cause dev exceed its upper limitation vfs: avoid creation of inode number 0 in get_next_ino namei: make set_root_rcu() return void make simple_positive() public ufs: use dir_pages instead of ufs_dir_pages() pagemap.h: move dir_pages() over there remove the pointless include of lglock.h fs: cleanup slight list_entry abuse xfs: Correctly lock inode when removing suid and file capabilities fs: Call security_ops->inode_killpriv on truncate fs: Provide function telling whether file_remove_privs() will do anything ...
2015-06-25fs/befs/btree.c: remove unneeded initializationsFabian Frederick
bh, od_sup and this_node are unconditionally initialized in befs_bt_read_super() and befs_btree_find() Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-23fs: cleanup slight list_entry abuseRasmus Villemoes
list_entry is just a wrapper for container_of, but it is arguably wrong (and slightly confusing) to use it when the pointed-to struct member is not a struct list_head. Use container_of directly instead. Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-05-10don't pass nameidata to ->follow_link()Al Viro
its only use is getting passed to nd_jump_link(), which can obtain it from current->nameidata Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-05-10new ->follow_link() and ->put_link() calling conventionsAl Viro
a) instead of storing the symlink body (via nd_set_link()) and returning an opaque pointer later passed to ->put_link(), ->follow_link() _stores_ that opaque pointer (into void * passed by address by caller) and returns the symlink body. Returning ERR_PTR() on error, NULL on jump (procfs magic symlinks) and pointer to symlink body for normal symlinks. Stored pointer is ignored in all cases except the last one. Storing NULL for opaque pointer (or not storing it at all) means no call of ->put_link(). b) the body used to be passed to ->put_link() implicitly (via nameidata). Now only the opaque pointer is. In the cases when we used the symlink body to free stuff, ->follow_link() now should store it as opaque pointer in addition to returning it. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-05-10befs: switch to simple_follow_link()Al Viro
Reviewed-by: Jan Kara <jack@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-04-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull fourth vfs update from Al Viro: "d_inode() annotations from David Howells (sat in for-next since before the beginning of merge window) + four assorted fixes" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: RCU pathwalk breakage when running into a symlink overmounting something fix I_DIO_WAKEUP definition direct-io: only inc/dec inode->i_dio_count for file systems fs/9p: fix readdir() VFS: assorted d_backing_inode() annotations VFS: fs/inode.c helpers: d_inode() annotations VFS: fs/cachefiles: d_backing_inode() annotations VFS: fs library helpers: d_inode() annotations VFS: assorted weird filesystems: d_inode() annotations VFS: normal filesystems (and lustre): d_inode() annotations VFS: security/: d_inode() annotations VFS: security/: d_backing_inode() annotations VFS: net/: d_inode() annotations VFS: net/unix: d_backing_inode() annotations VFS: kernel/: d_inode() annotations VFS: audit: d_backing_inode() annotations VFS: Fix up some ->d_inode accesses in the chelsio driver VFS: Cachefiles should perform fs modifications on the top layer only VFS: AF_UNIX sockets should call mknod on the top layer only
2015-04-17befs: replace typedef befs_inode_info by structureFabian Frederick
See Documentation/CodingStyle Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-17befs: replace typedef befs_sb_info by structureFabian Frederick
See Documenation/CodingStyle Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-17befs: replace typedef befs_mount_options by structureFabian Frederick
2015-04-15VFS: normal filesystems (and lustre): d_inode() annotationsDavid Howells
that's the bulk of filesystem drivers dealing with inodes of their own Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-02-17fs/befs/linuxvfs.c: remove unnecessary castingFabian Frederick
Fix the following coccinelle warning: fs/befs/linuxvfs.c:278:14-36: WARNING: casting value returned by memory allocation function to (struct befs_inode_info *) is useless. [akpm@linux-foundation.org: avoid 80-col ugliness] Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-12-13befs: remove dead codeJan Kara
Coverity id: 1042674 Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-11-19assorted conversions to %p[dD]Al Viro
2014-10-14fs/befs/btree.c: remove typedef befs_btree_nodeHimangi Saraogi
The Linux kernel coding style guidelines suggest not using typedefs for structure types. This patch gets rid of the typedef for befs_btree_node. The following Coccinelle semantic patch detects the case. @tn1@ type td; @@ typedef struct { ... } td; @script:python tf@ td << tn1.td; tdres; @@ coccinelle.tdres = td; @@ type tn1.td; identifier tf.tdres; @@ -typedef struct + tdres { ... } -td ; @@ type tn1.td; identifier tf.tdres; @@ -td + struct tdres Signed-off-by: Himangi Saraogi <himangi774@gmail.com> Acked-by: Julia Lawall <julia.lawall@lip6.fr> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-08fs/befs/linuxvfs.c: check superblock before dump operationFabian Frederick
befs_dump_super_block was called between befs_load_sb and befs_check_sb. It has been reported to crash (5/900) with null block testing. This patch loads, checks and only dump superblock if it's a valid one then brelse bh. (befs_dump_super_block uses disk_sb (bh->b_data) so it seems we need to call it before brelse(bh) but I don't know why befs_check_sb was called after brelse. Another thing I don't understand is why this problem appears now). Signed-off-by: Fabian Frederick <fabf@skynet.be> Reported-by: Fengguang Wu <fengguang.wu@intel.com> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-06Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree changes from Jiri Kosina: "Summer edition of trivial tree updates" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (23 commits) doc: fix two typos in watchdog-api.txt irq-gic: remove file name from heading comment MAINTAINERS: Add miscdevice.h to file list for char/misc drivers. scsi: mvsas: mv_sas.c: Fix for possible null pointer dereference doc: replace "practise" with "practice" in Documentation befs: remove check for CONFIG_BEFS_RW scsi: doc: fix 'SCSI_NCR_SETUP_MASTER_PARITY' drivers/usb/phy/phy.c: remove a leading space mfd: fix comment cpuidle: fix comment doc: hpfall.c: fix missing null-terminate after strncpy call usb: doc: hotplug.txt code typos kbuild: fix comment in Makefile.modinst SH: add proper prompt to SH_MAGIC_PANEL_R2_VERSION ARM: msm: Remove MSM_SCM crypto: Remove MPILIB_EXTRA doc: CN: remove dead link, kerneltrap.org no longer works media: update reference, kerneltrap.org no longer works hexagon: update reference, kerneltrap.org no longer works doc: LSM: update reference, kerneltrap.org no longer works ...
2014-06-19befs: remove check for CONFIG_BEFS_RWPaul Bolle
Befs contains a check for CONFIG_BEFS_RW for over a decade now. The related Kconfig symbol never existed, so this check always evaluated to true. Remove it. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2014-06-06fs/befs: kernel-doc fixesFabian Frederick
Fix some comment errors. Signed-off-by: Fabian Frederick <fabf@skynet.be> Cc: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-06fs/befs/linuxvfs.c: remove positive test on sector_tFabian Frederick
sector_t is unsigned. Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-06fs/befs/btree.c: replace strncpy by strlcpy + coding style fixingFabian Frederick
- strncpy + end of string assignement replaced by strlcpy - Fix endif }; - Fix typo Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-06fs/befs/linuxvfs.c: replace strncpy by strlcpyFabian Frederick
strncpy + end of string assignment replaced by strlcpy Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-04Merge tag 'ext4_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 Pull ext4 updates from Ted Ts'o: "Major changes for 3.14 include support for the newly added ZERO_RANGE and COLLAPSE_RANGE fallocate operations, and scalability improvements in the jbd2 layer and in xattr handling when the extended attributes spill over into an external block. Other than that, the usual clean ups and minor bug fixes" * tag 'ext4_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (42 commits) ext4: fix premature freeing of partial clusters split across leaf blocks ext4: remove unneeded test of ret variable ext4: fix comment typo ext4: make ext4_block_zero_page_range static ext4: atomically set inode->i_flags in ext4_set_inode_flags() ext4: optimize Hurd tests when reading/writing inodes ext4: kill i_version support for Hurd-castrated file systems ext4: each filesystem creates and uses its own mb_cache fs/mbcache.c: doucple the locking of local from global data fs/mbcache.c: change block and index hash chain to hlist_bl_node ext4: Introduce FALLOC_FL_ZERO_RANGE flag for fallocate ext4: refactor ext4_fallocate code ext4: Update inode i_size after the preallocation ext4: fix partial cluster handling for bigalloc file systems ext4: delete path dealloc code in ext4_ext_handle_uninitialized_extents ext4: only call sync_filesystm() when remounting read-only fs: push sync_filesystem() down to the file system's remount_fs() jbd2: improve error messages for inconsistent journal heads jbd2: minimize region locked by j_list_lock in jbd2_journal_forget() jbd2: minimize region locked by j_list_lock in journal_get_create_access() ...
2014-04-03BEFS: logging cleanupFabian Frederick
Summary: - all printk(KERN_foo converted to pr_foo() - add pr_fmt and remove redundant prefixes - convert befs_() to va_format (based on patch by Joe Perches) - remove non standard %Lu - use __func__ for all debugging [akpm@linux-foundation.org: fix printk warnings, reported by Fengguang] Signed-off-by: Fabian Frederick <fabf@skynet.be> Cc: Joe Perches <joe@perches.com> Cc: Fengguang Wu <fengguang.wu@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-03fs/befs/linuxvfs.c: add __init to befs_init_inodecache()Fabian Frederick
init_inodecache is only called by __init init_befs_fs. Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-03befs: replace kmalloc/memset 0 by kzallocFabian Frederick
Use kzalloc for clean fs_info allocation like other filesystems. Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-03-13fs: push sync_filesystem() down to the file system's remount_fs()Theodore Ts'o
Previously, the no-op "mount -o mount /dev/xxx" operation when the file system is already mounted read-write causes an implied, unconditional syncfs(). This seems pretty stupid, and it's certainly documented or guaraunteed to do this, nor is it particularly useful, except in the case where the file system was mounted rw and is getting remounted read-only. However, it's possible that there might be some file systems that are actually depending on this behavior. In most file systems, it's probably fine to only call sync_filesystem() when transitioning from read-write to read-only, and there are some file systems where this is not needed at all (for example, for a pseudo-filesystem or something like romfs). Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: linux-fsdevel@vger.kernel.org Cc: Christoph Hellwig <hch@infradead.org> Cc: Artem Bityutskiy <dedekind1@gmail.com> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Evgeniy Dushistov <dushistov@mail.ru> Cc: Jan Kara <jack@suse.cz> Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: Anders Larsen <al@alarsen.net> Cc: Phillip Lougher <phillip@squashfs.org.uk> Cc: Kees Cook <keescook@chromium.org> Cc: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz> Cc: Petr Vandrovec <petr@vandrovec.name> Cc: xfs@oss.sgi.com Cc: linux-btrfs@vger.kernel.org Cc: linux-cifs@vger.kernel.org Cc: samba-technical@lists.samba.org Cc: codalist@coda.cs.cmu.edu Cc: linux-ext4@vger.kernel.org Cc: linux-f2fs-devel@lists.sourceforge.net Cc: fuse-devel@lists.sourceforge.net Cc: cluster-devel@redhat.com Cc: linux-mtd@lists.infradead.org Cc: jfs-discussion@lists.sourceforge.net Cc: linux-nfs@vger.kernel.org Cc: linux-nilfs@vger.kernel.org Cc: linux-ntfs-dev@lists.sourceforge.net Cc: ocfs2-devel@oss.oracle.com Cc: reiserfs-devel@vger.kernel.org
2014-01-25befs: iget_locked() doesn't return an ERR_PTRRakesh Pandit
Also fix befs_iget return value if iget_locked fails. Signed-off-by: Rakesh Pandit <rakesh@tuxera.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-10-24befs: split symlink iops in two - for short and long symlinks resp.Al Viro
2013-06-29[readdir] convert befsAl Viro
2013-05-31befs_readdir(): do not increment ->f_pos if filldir tells us to stopAl Viro
2013-04-30Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree updates from Jiri Kosina: "Usual stuff, mostly comment fixes, typo fixes, printk fixes and small code cleanups" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (45 commits) mm: Convert print_symbol to %pSR gfs2: Convert print_symbol to %pSR m32r: Convert print_symbol to %pSR iostats.txt: add easy-to-find description for field 6 x86 cmpxchg.h: fix wrong comment treewide: Fix typo in printk and comments doc: devicetree: Fix various typos docbook: fix 8250 naming in device-drivers pata_pdc2027x: Fix compiler warning treewide: Fix typo in printks mei: Fix comments in drivers/misc/mei treewide: Fix typos in kernel messages pm44xx: Fix comment for "CONFIG_CPU_IDLE" doc: Fix typo "CONFIG_CGROUP_CGROUP_MEMCG_SWAP" mmzone: correct "pags" to "pages" in comment. kernel-parameters: remove outdated 'noresidual' parameter Remove spurious _H suffixes from ifdef comments sound: Remove stray pluses from Kconfig file radio-shark: Fix printk "CONFIG_LED_CLASS" doc: put proper reference to CONFIG_MODULE_SIG_ENFORCE ...
2013-03-18fs: befs: remove cast for kmalloc return valueZhang Yanfei
remove cast for kmalloc return value. Signed-off-by: Zhang Yanfei <zhangyanfei@cn.fujitsu.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-03-03fs: Limit sys_mount to only request filesystem modules.Eric W. Biederman
Modify the request_module to prefix the file system type with "fs-" and add aliases to all of the filesystems that can be built as modules to match. A common practice is to build all of the kernel code and leave code that is not commonly needed as modules, with the result that many users are exposed to any bug anywhere in the kernel. Looking for filesystems with a fs- prefix limits the pool of possible modules that can be loaded by mount to just filesystems trivially making things safer with no real cost. Using aliases means user space can control the policy of which filesystem modules are auto-loaded by editing /etc/modprobe.d/*.conf with blacklist and alias directives. Allowing simple, safe, well understood work-arounds to known problematic software. This also addresses a rare but unfortunate problem where the filesystem name is not the same as it's module name and module auto-loading would not work. While writing this patch I saw a handful of such cases. The most significant being autofs that lives in the module autofs4. This is relevant to user namespaces because we can reach the request module in get_fs_type() without having any special permissions, and people get uncomfortable when a user specified string (in this case the filesystem type) goes all of the way to request_module. After having looked at this issue I don't think there is any particular reason to perform any filtering or permission checks beyond making it clear in the module request that we want a filesystem module. The common pattern in the kernel is to call request_module() without regards to the users permissions. In general all a filesystem module does once loaded is call register_filesystem() and go to sleep. Which means there is not much attack surface exposed by loading a filesytem module unless the filesystem is mounted. In a user namespace filesystems are not mounted unless .fs_flags = FS_USERNS_MOUNT, which most filesystems do not set today. Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Acked-by: Kees Cook <keescook@chromium.org> Reported-by: Kees Cook <keescook@google.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2013-02-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs pile (part one) from Al Viro: "Assorted stuff - cleaning namei.c up a bit, fixing ->d_name/->d_parent locking violations, etc. The most visible changes here are death of FS_REVAL_DOT (replaced with "has ->d_weak_revalidate()") and a new helper getting from struct file to inode. Some bits of preparation to xattr method interface changes. Misc patches by various people sent this cycle *and* ocfs2 fixes from several cycles ago that should've been upstream right then. PS: the next vfs pile will be xattr stuff." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (46 commits) saner proc_get_inode() calling conventions proc: avoid extra pde_put() in proc_fill_super() fs: change return values from -EACCES to -EPERM fs/exec.c: make bprm_mm_init() static ocfs2/dlm: use GFP_ATOMIC inside a spin_lock ocfs2: fix possible use-after-free with AIO ocfs2: Fix oops in ocfs2_fast_symlink_readpage() code path get_empty_filp()/alloc_file() leave both ->f_pos and ->f_version zero target: writev() on single-element vector is pointless export kernel_write(), convert open-coded instances fs: encode_fh: return FILEID_INVALID if invalid fid_type kill f_vfsmnt vfs: kill FS_REVAL_DOT by adding a d_weak_revalidate dentry op nfsd: handle vfs_getattr errors in acl protocol switch vfs_getattr() to struct path default SET_PERSONALITY() in linux/elf.h ceph: prepopulate inodes only when request is aborted d_hash_and_lookup(): export, switch open-coded instances 9p: switch v9fs_set_create_acl() to inode+fid, do it before d_instantiate() 9p: split dropping the acls from v9fs_set_create_acl() ...
2013-02-22new helper: file_inode(file)Al Viro
2013-01-21fs/befs: remove depends on CONFIG_EXPERIMENTALKees Cook
The CONFIG_EXPERIMENTAL config item has not carried much meaning for a while now and is almost always enabled by default. As agreed during the Linux kernel summit, remove it from any "depends on" lines in Kconfigs. Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-02Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs update from Al Viro: - big one - consolidation of descriptor-related logics; almost all of that is moved to fs/file.c (BTW, I'm seriously tempted to rename the result to fd.c. As it is, we have a situation when file_table.c is about handling of struct file and file.c is about handling of descriptor tables; the reasons are historical - file_table.c used to be about a static array of struct file we used to have way back). A lot of stray ends got cleaned up and converted to saner primitives, disgusting mess in android/binder.c is still disgusting, but at least doesn't poke so much in descriptor table guts anymore. A bunch of relatively minor races got fixed in process, plus an ext4 struct file leak. - related thing - fget_light() partially unuglified; see fdget() in there (and yes, it generates the code as good as we used to have). - also related - bits of Cyrill's procfs stuff that got entangled into that work; _not_ all of it, just the initial move to fs/proc/fd.c and switch of fdinfo to seq_file. - Alex's fs/coredump.c spiltoff - the same story, had been easier to take that commit than mess with conflicts. The rest is a separate pile, this was just a mechanical code movement. - a few misc patches all over the place. Not all for this cycle, there'll be more (and quite a few currently sit in akpm's tree)." Fix up trivial conflicts in the android binder driver, and some fairly simple conflicts due to two different changes to the sock_alloc_file() interface ("take descriptor handling from sock_alloc_file() to callers" vs "net: Providing protocol type via system.sockprotoname xattr of /proc/PID/fd entries" adding a dentry name to the socket) * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (72 commits) MAX_LFS_FILESIZE should be a loff_t compat: fs: Generic compat_sys_sendfile implementation fs: push rcu_barrier() from deactivate_locked_super() to filesystems btrfs: reada_extent doesn't need kref for refcount coredump: move core dump functionality into its own file coredump: prevent double-free on an error path in core dumper usb/gadget: fix misannotations fcntl: fix misannotations ceph: don't abuse d_delete() on failure exits hypfs: ->d_parent is never NULL or negative vfs: delete surplus inode NULL check switch simple cases of fget_light to fdget new helpers: fdget()/fdput() switch o2hb_region_dev_write() to fget_light() proc_map_files_readdir(): don't bother with grabbing files make get_file() return its argument vhost_set_vring(): turn pollstart/pollstop into bool switch prctl_set_mm_exe_file() to fget_light() switch xfs_find_handle() to fget_light() switch xfs_swapext() to fget_light() ...
2012-10-02fs: push rcu_barrier() from deactivate_locked_super() to filesystemsKirill A. Shutemov
There's no reason to call rcu_barrier() on every deactivate_locked_super(). We only need to make sure that all delayed rcu free inodes are flushed before we destroy related cache. Removing rcu_barrier() from deactivate_locked_super() affects some fast paths. E.g. on my machine exit_group() of a last process in IPC namespace takes 0.07538s. rcu_barrier() takes 0.05188s of that time. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-09-21userns: Convert befs to use kuid/kgid where appropriateEric W. Biederman
Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-07-14stop passing nameidata to ->lookup()Al Viro
Just the flags; only NFS cares even about that, but there are legitimate uses for such argument. And getting rid of that completely would require splitting ->lookup() into a couple of methods (at least), so let's leave that alone for now... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-03-20switch open-coded instances of d_make_root() to new helperAl Viro
2012-01-03vfs: fix the stupidity with i_dentry in inode destructorsAl Viro
Seeing that just about every destructor got that INIT_LIST_HEAD() copied into it, there is no point whatsoever keeping this INIT_LIST_HEAD in inode_init_once(); the cost of taking it into inode_init_always() will be negligible for pipes and sockets and negative for everything else. Not to mention the removal of boilerplate code from ->destroy_inode() instances... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-11-02filesystems: add set_nlink()Miklos Szeredi
Replace remaining direct i_nlink updates with a new set_nlink() updater function. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Tested-by: Toshiyuki Okajima <toshi.okajima@jp.fujitsu.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2011-08-17befs: Validate length of long symbolic links.Timo Warns
Signed-off-by: Timo Warns <warns@pre-sense.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-10block: remove per-queue pluggingJens Axboe
Code has been converted over to the new explicit on-stack plugging, and delay users have been converted to use the new API for that. So lets kill off the old plugging along with aops->sync_page(). Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-01-13befs: don't pass huge structs by valueJesper Juhl
'struct befs_disk_data_stream' is huge (~144 bytes) and it's being passed by value in fs/befs/endian.h::cpu_to_fsrun(). It would be better to pass a pointer. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Cc: Will Dyson <will_dyson@pobox.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-07fs: icache RCU free inodesNick Piggin
RCU free the struct inode. This will allow: - Subsequent store-free path walking patch. The inode must be consulted for permissions when walking, so an RCU inode reference is a must. - sb_inode_list_lock to be moved inside i_lock because sb list walkers who want to take i_lock no longer need to take sb_inode_list_lock to walk the list in the first place. This will simplify and optimize locking. - Could remove some nested trylock loops in dcache code - Could potentially simplify things a bit in VM land. Do not need to take the page lock to follow page->mapping. The downsides of this is the performance cost of using RCU. In a simple creat/unlink microbenchmark, performance drops by about 10% due to inability to reuse cache-hot slab objects. As iterations increase and RCU freeing starts kicking over, this increases to about 20%. In cases where inode lifetimes are longer (ie. many inodes may be allocated during the average life span of a single inode), a lot of this cache reuse is not applicable, so the regression caused by this patch is smaller. The cache-hot regression could largely be avoided by using SLAB_DESTROY_BY_RCU, however this adds some complexity to list walking and store-free path walking, so I prefer to implement this at a later date, if it is shown to be a win in real situations. I haven't found a regression in any non-micro benchmark so I doubt it will be a problem. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2010-10-29new helper: mount_bdev()Al Viro
... and switch of the obvious get_sb_bdev() users to ->mount() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
