path: root/fs/bfs/inode.c
2011-01-07fs: icache RCU free inodesNick Piggin
RCU free the struct inode. This will allow: - Subsequent store-free path walking patch. The inode must be consulted for permissions when walking, so an RCU inode reference is a must. - sb_inode_list_lock to be moved inside i_lock because sb list walkers who want to take i_lock no longer need to take sb_inode_list_lock to walk the list in the first place. This will simplify and optimize locking. - Could remove some nested trylock loops in dcache code - Could potentially simplify things a bit in VM land. Do not need to take the page lock to follow page->mapping. The downsides of this is the performance cost of using RCU. In a simple creat/unlink microbenchmark, performance drops by about 10% due to inability to reuse cache-hot slab objects. As iterations increase and RCU freeing starts kicking over, this increases to about 20%. In cases where inode lifetimes are longer (ie. many inodes may be allocated during the average life span of a single inode), a lot of this cache reuse is not applicable, so the regression caused by this patch is smaller. The cache-hot regression could largely be avoided by using SLAB_DESTROY_BY_RCU, however this adds some complexity to list walking and store-free path walking, so I prefer to implement this at a later date, if it is shown to be a win in real situations. I haven't found a regression in any non-micro benchmark so I doubt it will be a problem. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2010-10-29new helper: mount_bdev()Al Viro
... and switch of the obvious get_sb_bdev() users to ->mount() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-04BKL: Remove BKL from BFSJan Blunck
The BKL is only used in put_super and fill_super that are both protected by the superblocks s_umount rw_semaphore. Therefore it is safe to remove the BKL entirely. Signed-off-by: Jan Blunck <jblunck@infradead.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2010-10-04BKL: Explicitly add BKL around get_sb/fill_superJan Blunck
This patch is a preparation necessary to remove the BKL from do_new_mount(). It explicitly adds calls to lock_kernel()/unlock_kernel() around get_sb/fill_super operations for filesystems that still uses the BKL. I've read through all the code formerly covered by the BKL inside do_kern_mount() and have satisfied myself that it doesn't need the BKL any more. do_kern_mount() is already called without the BKL when mounting the rootfs and in nfsctl. do_kern_mount() calls vfs_kern_mount(), which is called from various places without BKL: simple_pin_fs(), nfs_do_clone_mount() through nfs_follow_mountpoint(), afs_mntpt_do_automount() through afs_mntpt_follow_link(). Both later functions are actually the filesystems follow_link inode operation. vfs_kern_mount() is calling the specified get_sb function and lets the filesystem do its job by calling the given fill_super function. Therefore I think it is safe to push down the BKL from the VFS to the low-level filesystems get_sb/fill_super operation. [arnd: do not add the BKL to those file systems that already don't use it elsewhere] Signed-off-by: Jan Blunck <jblunck@infradead.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Christoph Hellwig <hch@infradead.org>
2010-08-09BFS: clean up the superblock usageArtem Bityutskiy
BFS is a very simple FS and its superblocks contains only static information and is never changed. However, the BFS code for some misterious reasons marked its buffer head as dirty from time to time, but nothing in that buffer was ever changed. This patch removes all the BFS superblock manipulation, simply because it is not needed. It removes: 1. The si_sbh filed from 'struct bfs_sb_info' because it is not needed. We only need to read the SB once on mount to get the start of data blocks and the FS size. After this, we can forget about the SB. 2. All instances of 'mark_buffer_dirty(sbh)' for BFS SB because it is never changed. 3. The '->sync_fs()' method because there is nothing to sync (inodes are synched by VFS). 4. The '->write_super()' method, again, because the SB is never changed. Tested-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09switch bfs to ->evict_inode(), clean upAl Viro
2010-03-05pass writeback_control to ->write_inodeChristoph Hellwig
This gives the filesystem more information about the writeback that is happening. Trond requested this for the NFS unstable write handling, and other filesystems might benefit from this too by beeing able to distinguish between the different callers in more detail. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-01-26Fix failure exits in bfs_fill_super()Al Viro
double iput(), leaks... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-11bfs: add ->sync_fsChristoph Hellwig
Add a ->sync_fs method for data integrity syncs, and reimplement ->write_super ontop of it. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-11repair bfs_write_inode(), switch bfs to simple_fsync()Al Viro
2009-06-11push BKL down into ->put_superChristoph Hellwig
Move BKL into ->put_super from the only caller. A couple of filesystems had trivial enough ->put_super (only kfree and NULLing of s_fs_info + stuff in there) to not get any locking: coda, cramfs, efs, hugetlbfs, omfs, qnx4, shmem, all others got the full treatment. Most of them probably don't need it, but I'd rather sort that out individually. Preferably after all the other BKL pushdowns in that area. [AV: original used to move lock_super() down as well; these changes are removed since we don't do lock_super() at all in generic_shutdown_super() now] [AV: fuse, btrfs and xfs are known to need no damn BKL, exempt] Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-11remove ->write_super call in generic_shutdown_superChristoph Hellwig
We just did a full fs writeout using sync_filesystem before, and if that's not enough for the filesystem it can perform it's own writeout in ->put_super, which many filesystems already do. Move a call to foofs_write_super into every foofs_put_super for now to guarantee identical behaviour until it's cleaned up by the individual filesystem maintainers. Exceptions: - affs already has identical copy & pasted code at the beginning of affs_put_super so no need to do it twice. - xfs does the right thing without it and I have changes pending for the xfs tree touching this are so I don't really need conflicts here.. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-01-06bfs: check that filesystem fits on the blockdeviceEric Sesterhenn
Since all sanity checks rely on the validity of s_start which gets only checked to be smaller than s_end, we should also check if s_end is sane. Now we also try to retrieve the last block of the filesystem, which is computed by s_end. If this fails, something is bogus. Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Acked-by: Tigran Aivazian <tigran@aivazian.fsnet.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06bfs: add some basic sanity checksEric Sesterhenn
bfs_fill_super() already touches all inodes, so we can easily add some cheap sanity checks and check if the inode start and end blocks are smaller than the maximum number of blocks, the inode start block lies behind the end block or the file end offset is behind the end of the filesystem. Also check if the start of data offset in the super block fits the filesystem. The added sanity checks catch softlockup issues early when we try to sb_bread() lots of blocks in a loop in bfs_readdir() and bfs_find_entry(). In addition an oom issue in bfs_fill_super() is prevented by this when s_start is corrupted, which influences imap_len and we try to allocate a huge info->si_imap. Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Acked-by: Tigran Aivazian <tigran@aivazian.fsnet.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26SL*B: drop kmem cache argument from constructorAlexey Dobriyan
Kmem cache passed to constructor is only needed for constructors that are themselves multiplexeres. Nobody uses this "feature", nor does anybody uses passed kmem cache in non-trivial way, so pass only pointer to object. Non-trivial places are: arch/powerpc/mm/init_64.c arch/powerpc/mm/hugetlbpage.c This is flag day, yes. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Acked-by: Christoph Lameter <cl@linux-foundation.org> Cc: Jon Tollefson <kniht@linux.vnet.ibm.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Matt Mackall <mpm@selenic.com> [akpm@linux-foundation.org: fix arch/powerpc/mm/hugetlbpage.c] [akpm@linux-foundation.org: fix mm/slab.c] [akpm@linux-foundation.org: fix ubifs] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26bfs: kill BKLDmitri Vorobiev
Replace the BKL-based locking scheme used in the bfs driver by a private filesystem-wide mutex. Signed-off-by: Dmitri Vorobiev <dmitri.vorobiev@movial.fi> Cc: Tigran Aivazian <tigran_aivazian@symantec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26bfs: assorted cleanupsDmitri Vorobiev
This patch makes the following cleanups: o removing an unused variable from bfs_fill_super(); o removing unneeded blank spaces from pointer definitions. Signed-off-by: Dmitri Vorobiev <dmitri.vorobiev@movial.fi> Cc: Tigran Aivazian <tigran_aivazian@symantec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07iget: stop BFS from using iget() and read_inode()David Howells
Stop the BFS filesystem from using iget() and read_inode(). Replace bfs_read_inode() with bfs_iget(), and call that instead of iget(). bfs_iget() then uses iget_locked() directly and returns a proper error code instead of an inode in the event of an error. bfs_fill_super() returns any error incurred when getting the root inode instead of EINVAL. [kamalesh@linux.vnet.ibm.com: build fix] Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Kamalesh Babulal <kamalesh@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-12-05regression: bfs endianness bugAl Viro
BFS_FILEBLOCKS() expects struct bfs_inode * (on-disk data, with little- endian fields), not struct bfs_inode_info * (in-core stuff, with host- endian ones). It's a macro and fields with the right names are present in bfs_inode_info, so it compiles, but on big-endian host it gives bogus results. Introduced in commit f433dc56344cb72cc3de5ba0819021cec3aef807 ("Fixes to the BFS filesystem driver"). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-11-14Fixes to the BFS filesystem driverDmitri Vorobiev
I found a few bugs in the BFS driver. Detailed description of the bugs as well as the steps to reproduce the errors are given in the kernel bugzilla. Please follow these links for more information: http://bugzilla.kernel.org/show_bug.cgi?id=9363 http://bugzilla.kernel.org/show_bug.cgi?id=9364 http://bugzilla.kernel.org/show_bug.cgi?id=9365 http://bugzilla.kernel.org/show_bug.cgi?id=9366 This patch fixes the bugs described above. Besides, the patch introduces coding style changes to make the BFS driver conform to the requirements specified for Linux kernel code. Finally, I made a few cosmetic changes such as removal of trivial debug output. Also, the patch removes the fields `si_lf_ioff' and `si_lf_sblk' of the in-core superblock structure. These fields are initialized but never actually used. If you are wondering why I need BFS, here is the answer: I am using this driver in the context of Linux kernel classes I am teaching in the Moscow State University and in the International Institute of Information Technology in Pune, India. Signed-off-by: Dmitri Vorobiev <dmitri.vorobiev@gmail.com> Cc: Tigran Aivazian <tigran@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17Slab API: remove useless ctor parameter and reorder parametersChristoph Lameter
Slab constructors currently have a flags parameter that is never used. And the order of the arguments is opposite to other slab functions. The object pointer is placed before the kmem_cache pointer. Convert ctor(void *object, struct kmem_cache *s, unsigned long flags) to ctor(struct kmem_cache *s, void *object) throughout the kernel [akpm@linux-foundation.org: coupla fixes] Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-13[PATCH] update Tigran's email addressesTigran Aivazian
As Adrian pointed out recently, there were still a couple of places where I should have fixed my email address. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] Really ignore kmem_cache_destroy return valueAlexey Dobriyan
* Rougly half of callers already do it by not checking return value * Code in drivers/acpi/osl.c does the following to be sure: (void)kmem_cache_destroy(cache); * Those who check it printk something, however, slab_error already printed the name of failed cache. * XFS BUGs on failed kmem_cache_destroy which is not the decision low-level filesystem driver should make. Converted to ignore. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] fs: Conversions from kmalloc+memset to k(z|c)allocPanagiotis Issaris
Conversions from kmalloc+memset to kzalloc. Signed-off-by: Panagiotis Issaris <takis@issaris.org> Jffs2-bit-acked-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] VFS: Permit filesystem to perform statfs with a known root dentryDavid Howells
Give the statfs superblock operation a dentry pointer rather than a superblock pointer. This complements the get_sb() patch. That reduced the significance of sb->s_root, allowing NFS to place a fake root there. However, NFS does require a dentry to use as a target for the statfs operation. This permits the root in the vfsmount to be used instead. linux/mount.h has been added where necessary to make allyesconfig build successfully. Interest has also been expressed for use with the FUSE and XFS filesystems. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Nathan Scott <nathans@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] VFS: Permit filesystem to override root dentry on mountDavid Howells
Extend the get_sb() filesystem operation to take an extra argument that permits the VFS to pass in the target vfsmount that defines the mountpoint. The filesystem is then required to manually set the superblock and root dentry pointers. For most filesystems, this should be done with simple_set_mnt() which will set the superblock pointer and then set the root dentry to the superblock's s_root (as per the old default behaviour). The get_sb() op now returns an integer as there's now no need to return the superblock pointer. This patch permits a superblock to be implicitly shared amongst several mount points, such as can be done with NFS to avoid potential inode aliasing. In such a case, simple_set_mnt() would not be called, and instead the mnt_root and mnt_sb would be set directly. The patch also makes the following changes: (*) the get_sb_*() convenience functions in the core kernel now take a vfsmount pointer argument and return an integer, so most filesystems have to change very little. (*) If one of the convenience function is not used, then get_sb() should normally call simple_set_mnt() to instantiate the vfsmount. This will always return 0, and so can be tail-called from get_sb(). (*) generic_shutdown_super() now calls shrink_dcache_sb() to clean up the dcache upon superblock destruction rather than shrink_dcache_anon(). This is required because the superblock may now have multiple trees that aren't actually bound to s_root, but that still need to be cleaned up. The currently called functions assume that the whole tree is rooted at s_root, and that anonymous dentries are not the roots of trees which results in dentries being left unculled. However, with the way NFS superblock sharing are currently set to be implemented, these assumptions are violated: the root of the filesystem is simply a dummy dentry and inode (the real inode for '/' may well be inaccessible), and all the vfsmounts are rooted on anonymous[*] dentries with child trees. [*] Anonymous until discovered from another tree. (*) The documentation has been adjusted, including the additional bit of changing ext2_* into foo_* in the documentation. [akpm@osdl.org: convert ipath_fs, do other stuff] Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Nathan Scott <nathans@sgi.com> Cc: Roland Dreier <rolandd@cisco.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] cpuset memory spread: slab cache formatPaul Jackson
Rewrap the overly long source code lines resulting from the previous patch's addition of the slab cache flag SLAB_MEM_SPREAD. This patch contains only formatting changes, and no function change. Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] cpuset memory spread: slab cache filesystemsPaul Jackson
Mark file system inode and similar slab caches subject to SLAB_MEM_SPREAD memory spreading. If a slab cache is marked SLAB_MEM_SPREAD, then anytime that a task that's in a cpuset with the 'memory_spread_slab' option enabled goes to allocate from such a slab cache, the allocations are spread evenly over all the memory nodes (task->mems_allowed) allowed to that task, instead of favoring allocation on the node local to the current cpu. The following inode and similar caches are marked SLAB_MEM_SPREAD: file cache ==== ===== fs/adfs/super.c adfs_inode_cache fs/affs/super.c affs_inode_cache fs/befs/linuxvfs.c befs_inode_cache fs/bfs/inode.c bfs_inode_cache fs/block_dev.c bdev_cache fs/cifs/cifsfs.c cifs_inode_cache fs/coda/inode.c coda_inode_cache fs/dquot.c dquot fs/efs/super.c efs_inode_cache fs/ext2/super.c ext2_inode_cache fs/ext2/xattr.c (fs/mbcache.c) ext2_xattr fs/ext3/super.c ext3_inode_cache fs/ext3/xattr.c (fs/mbcache.c) ext3_xattr fs/fat/cache.c fat_cache fs/fat/inode.c fat_inode_cache fs/freevxfs/vxfs_super.c vxfs_inode fs/hpfs/super.c hpfs_inode_cache fs/isofs/inode.c isofs_inode_cache fs/jffs/inode-v23.c jffs_fm fs/jffs2/super.c jffs2_i fs/jfs/super.c jfs_ip fs/minix/inode.c minix_inode_cache fs/ncpfs/inode.c ncp_inode_cache fs/nfs/direct.c nfs_direct_cache fs/nfs/inode.c nfs_inode_cache fs/ntfs/super.c ntfs_big_inode_cache_name fs/ntfs/super.c ntfs_inode_cache fs/ocfs2/dlm/dlmfs.c dlmfs_inode_cache fs/ocfs2/super.c ocfs2_inode_cache fs/proc/inode.c proc_inode_cache fs/qnx4/inode.c qnx4_inode_cache fs/reiserfs/super.c reiser_inode_cache fs/romfs/inode.c romfs_inode_cache fs/smbfs/inode.c smb_inode_cache fs/sysv/inode.c sysv_inode_cache fs/udf/super.c udf_inode_cache fs/ufs/super.c ufs_inode_cache net/socket.c sock_inode_cache net/sunrpc/rpc_pipe.c rpc_inode_cache The choice of which slab caches to so mark was quite simple. I marked those already marked SLAB_RECLAIM_ACCOUNT, except for fs/xfs, dentry_cache, inode_cache, and buffer_head, which were marked in a previous patch. Even though SLAB_RECLAIM_ACCOUNT is for a different purpose, it marks the same potentially large file system i/o related slab caches as we need for memory spreading. Given that the rule now becomes "wherever you would have used a SLAB_RECLAIM_ACCOUNT slab cache flag before (usually the inode cache), use the SLAB_MEM_SPREAD flag too", this should be easy enough to maintain. Future file system writers will just copy one of the existing file system slab cache setups and tend to get it right without thinking. Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-04[PATCH] bfs iget() abusesAl Viro
bfs_fill_super() walks the inode table to get the bitmap of free inodes and collect stats. It has no business using iget() for that - it's a lot of extra work, extra icache pollution and more complex code. Switched to walking the damn thing directly. Note: that also allows to kill ->i_dsk_ino in there - separate patch if Tigran can confirm that this field can be zero only for deleted inodes (i.e. something that could only be found during that scan and not by normal lookups). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-04[PATCH] bfs endianness annotationsAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] bfs: fix endianness, signedness; add trivial bugfixAndrew Stribblehill
* Makes BFS code endianness-clean. * Fixes some signedness warnings. * Fixes a problem in fs/bfs/inode.c:164 where inodes not synced to disk don't get fully marked as clean. Here's how to reproduce it: # mount -o loop -t bfs /bfs.img /mnt # df -i /mnt Filesystem Inodes IUsed IFree IUse% Mounted on /bfs.img 48 1 47 3% /mnt # df -k /mnt Filesystem 1K-blocks Used Available Use% Mounted on /bfs.img 512 5 508 1% /mnt # cp 60k-archive.zip /mnt/mt.zip # df -k /mnt Filesystem 1K-blocks Used Available Use% Mounted on /bfs.img 512 65 447 13% /mnt # df -i /mnt Filesystem Inodes IUsed IFree IUse% Mounted on /bfs.img 48 2 46 5% /mnt # rm /mnt/mt.zip # echo $? 0 [If the unlink happens before the buffers flush, the following happens:] # df -i /mnt Filesystem Inodes IUsed IFree IUse% Mounted on /bfs.img 48 2 46 5% /mnt # df -k /mnt Filesystem 1K-blocks Used Available Use% Mounted on /bfs.img 512 65 447 13% /mnt fs/bfs/bfs.h | 1 Signed-off-by: Andrew Stribblehill <ads@wompom.org> Cc: <tigran@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] update filesystems for new delete_inode behaviorMark Fasheh
Update the file systems in fs/ implementing a delete_inode() callback to call truncate_inode_pages(). One implementation note: In developing this patch I put the calls to truncate_inode_pages() at the very top of those filesystems delete_inode() callbacks in order to retain the previous behavior. I'm guessing that some of those could probably be optimized. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com> Acked-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
