path: root/fs/bfs
2008-09-13bfs: fix Lockdep warningEric Sesterhenn
This fixes: ============================================= [ INFO: possible recursive locking detected ] 2.6.27-rc5-00283-g70bb089 #68 --------------------------------------------- touch/6855 is trying to acquire lock: (&info->bfs_lock){--..}, at: [<c02262f5>] bfs_delete_inode+0x9e/0x18c but task is already holding lock: (&info->bfs_lock){--..}, at: [<c0226c00>] bfs_create+0x45/0x187 other info that might help us debug this: 2 locks held by touch/6855: #0: (&type->i_mutex_dir_key#5){--..}, at: [<c018ad13>] do_filp_open+0x10b/0x62f #1: (&info->bfs_lock){--..}, at: [<c0226c00>] bfs_create+0x45/0x187 stack backtrace: Pid: 6855, comm: touch Not tainted 2.6.27-rc5-00283-g70bb089 #68 [<c013e769>] validate_chain+0x458/0x9f4 [<c013bece>] ? trace_hardirqs_off+0xb/0xd [<c013f36b>] __lock_acquire+0x666/0x6e0 [<c013f440>] lock_acquire+0x5b/0x77 [<c02262f5>] ? bfs_delete_inode+0x9e/0x18c [<c06aab74>] mutex_lock_nested+0xbc/0x234 [<c02262f5>] ? bfs_delete_inode+0x9e/0x18c [<c02262f5>] ? bfs_delete_inode+0x9e/0x18c [<c02262f5>] bfs_delete_inode+0x9e/0x18c [<c0226257>] ? bfs_delete_inode+0x0/0x18c [<c01925e1>] generic_delete_inode+0x94/0xfe [<c019265d>] generic_drop_inode+0x12/0x12f [<c0191b7e>] iput+0x4b/0x4e [<c0226d1e>] bfs_create+0x163/0x187 [<c0188b42>] vfs_create+0xa6/0x114 [<c018adb5>] do_filp_open+0x1ad/0x62f [<c0107cdc>] ? native_sched_clock+0x82/0x96 [<c06ac309>] ? _spin_unlock+0x27/0x3c [<c019379e>] ? alloc_fd+0xbf/0xc9 [<c06ae2f4>] ? sub_preempt_count+0x9d/0xab [<c019379e>] ? alloc_fd+0xbf/0xc9 [<c0180391>] do_sys_open+0x42/0xb8 [<c041d564>] ? trace_hardirqs_on_thunk+0xc/0x10 [<c0180449>] sys_open+0x1e/0x26 [<c01038bd>] sysenter_do_call+0x12/0x31 ======================= The problem is that we don't unlock the bfs->lock mutex before calling iput (we do in the other cases). Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Cc: Tigran Aivazian <tigran@aivazian.fsnet.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26SL*B: drop kmem cache argument from constructorAlexey Dobriyan
Kmem cache passed to constructor is only needed for constructors that are themselves multiplexeres. Nobody uses this "feature", nor does anybody uses passed kmem cache in non-trivial way, so pass only pointer to object. Non-trivial places are: arch/powerpc/mm/init_64.c arch/powerpc/mm/hugetlbpage.c This is flag day, yes. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Acked-by: Christoph Lameter <cl@linux-foundation.org> Cc: Jon Tollefson <kniht@linux.vnet.ibm.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Matt Mackall <mpm@selenic.com> [akpm@linux-foundation.org: fix arch/powerpc/mm/hugetlbpage.c] [akpm@linux-foundation.org: fix mm/slab.c] [akpm@linux-foundation.org: fix ubifs] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26bfs: kill BKLDmitri Vorobiev
Replace the BKL-based locking scheme used in the bfs driver by a private filesystem-wide mutex. Signed-off-by: Dmitri Vorobiev <dmitri.vorobiev@movial.fi> Cc: Tigran Aivazian <tigran_aivazian@symantec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26bfs: assorted cleanupsDmitri Vorobiev
This patch makes the following cleanups: o removing an unused variable from bfs_fill_super(); o removing unneeded blank spaces from pointer definitions. Signed-off-by: Dmitri Vorobiev <dmitri.vorobiev@movial.fi> Cc: Tigran Aivazian <tigran_aivazian@symantec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30fs: replace remaining __FUNCTION__ occurrencesHarvey Harrison
2008-02-07iget: stop BFS from using iget() and read_inode()David Howells
Stop the BFS filesystem from using iget() and read_inode(). Replace bfs_read_inode() with bfs_iget(), and call that instead of iget(). bfs_iget() then uses iget_locked() directly and returns a proper error code instead of an inode in the event of an error. bfs_fill_super() returns any error incurred when getting the root inode instead of EINVAL. [kamalesh@linux.vnet.ibm.com: build fix] Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Kamalesh Babulal <kamalesh@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-12-05regression: bfs endianness bugAl Viro
BFS_FILEBLOCKS() expects struct bfs_inode * (on-disk data, with little- endian fields), not struct bfs_inode_info * (in-core stuff, with host- endian ones). It's a macro and fields with the right names are present in bfs_inode_info, so it compiles, but on big-endian host it gives bogus results. Introduced in commit f433dc56344cb72cc3de5ba0819021cec3aef807 ("Fixes to the BFS filesystem driver"). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-11-14Fixes to the BFS filesystem driverDmitri Vorobiev
I found a few bugs in the BFS driver. Detailed description of the bugs as well as the steps to reproduce the errors are given in the kernel bugzilla. Please follow these links for more information: http://bugzilla.kernel.org/show_bug.cgi?id=9363 http://bugzilla.kernel.org/show_bug.cgi?id=9364 http://bugzilla.kernel.org/show_bug.cgi?id=9365 http://bugzilla.kernel.org/show_bug.cgi?id=9366 This patch fixes the bugs described above. Besides, the patch introduces coding style changes to make the BFS driver conform to the requirements specified for Linux kernel code. Finally, I made a few cosmetic changes such as removal of trivial debug output. Also, the patch removes the fields `si_lf_ioff' and `si_lf_sblk' of the in-core superblock structure. These fields are initialized but never actually used. If you are wondering why I need BFS, here is the answer: I am using this driver in the context of Linux kernel classes I am teaching in the Moscow State University and in the International Institute of Information Technology in Pune, India. Signed-off-by: Dmitri Vorobiev <dmitri.vorobiev@gmail.com> Cc: Tigran Aivazian <tigran@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17Slab API: remove useless ctor parameter and reorder parametersChristoph Lameter
Slab constructors currently have a flags parameter that is never used. And the order of the arguments is opposite to other slab functions. The object pointer is placed before the kmem_cache pointer. Convert ctor(void *object, struct kmem_cache *s, unsigned long flags) to ctor(struct kmem_cache *s, void *object) throughout the kernel [akpm@linux-foundation.org: coupla fixes] Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16bfs: convert to new aopsNick Piggin
Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Tigran Aivazian <tigran@aivazian.fsnet.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-10sendfile: remove .sendfile from filesystems that use generic_file_sendfile()Jens Axboe
They can use generic_file_splice_read() instead. Since sys_sendfile() now prefers that, there should be no change in behaviour. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2006-12-13[PATCH] update Tigran's email addressesTigran Aivazian
As Adrian pointed out recently, there were still a couple of places where I should have fixed my email address. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] struct path: convert bfsJosef Sipek
2006-10-01[PATCH] r/o bind mount prepwork: inc_nlink() helperDave Hansen
This is mostly included for parity with dec_nlink(), where we will have some more hooks. This one should stay pretty darn straightforward for now. Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Acked-by: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] r/o bind mounts: unlink: monitor i_nlinkDave Hansen
When a filesystem decrements i_nlink to zero, it means that a write must be performed in order to drop the inode from the filesystem. We're shortly going to have keep filesystems from being remounted r/o between the time that this i_nlink decrement and that write occurs. So, add a little helper function to do the decrements. We'll tie into it in a bit to note when i_nlink hits zero. Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Acked-by: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] Streamline generic_file_* interfaces and filemap cleanupsBadari Pulavarty
This patch cleans up generic_file_*_read/write() interfaces. Christoph Hellwig gave me the idea for this clean ups. In a nutshell, all filesystems should set .aio_read/.aio_write methods and use do_sync_read/ do_sync_write() as their .read/.write methods. This allows us to cleanup all variants of generic_file_* routines. Final available interfaces: generic_file_aio_read() - read handler generic_file_aio_write() - write handler generic_file_aio_write_nolock() - no lock write handler __generic_file_aio_write_nolock() - internal worker routine Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] Really ignore kmem_cache_destroy return valueAlexey Dobriyan
* Rougly half of callers already do it by not checking return value * Code in drivers/acpi/osl.c does the following to be sure: (void)kmem_cache_destroy(cache); * Those who check it printk something, however, slab_error already printed the name of failed cache. * XFS BUGs on failed kmem_cache_destroy which is not the decision low-level filesystem driver should make. Converted to ignore. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] fs: Conversions from kmalloc+memset to k(z|c)allocPanagiotis Issaris
Conversions from kmalloc+memset to kzalloc. Signed-off-by: Panagiotis Issaris <takis@issaris.org> Jffs2-bit-acked-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-28[PATCH] mark address_space_operations constChristoph Hellwig
Same as with already do with the file operations: keep them in .rodata and prevents people from doing runtime patching. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Steven French <sfrench@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] VFS: Permit filesystem to perform statfs with a known root dentryDavid Howells
Give the statfs superblock operation a dentry pointer rather than a superblock pointer. This complements the get_sb() patch. That reduced the significance of sb->s_root, allowing NFS to place a fake root there. However, NFS does require a dentry to use as a target for the statfs operation. This permits the root in the vfsmount to be used instead. linux/mount.h has been added where necessary to make allyesconfig build successfully. Interest has also been expressed for use with the FUSE and XFS filesystems. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Nathan Scott <nathans@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] VFS: Permit filesystem to override root dentry on mountDavid Howells
Extend the get_sb() filesystem operation to take an extra argument that permits the VFS to pass in the target vfsmount that defines the mountpoint. The filesystem is then required to manually set the superblock and root dentry pointers. For most filesystems, this should be done with simple_set_mnt() which will set the superblock pointer and then set the root dentry to the superblock's s_root (as per the old default behaviour). The get_sb() op now returns an integer as there's now no need to return the superblock pointer. This patch permits a superblock to be implicitly shared amongst several mount points, such as can be done with NFS to avoid potential inode aliasing. In such a case, simple_set_mnt() would not be called, and instead the mnt_root and mnt_sb would be set directly. The patch also makes the following changes: (*) the get_sb_*() convenience functions in the core kernel now take a vfsmount pointer argument and return an integer, so most filesystems have to change very little. (*) If one of the convenience function is not used, then get_sb() should normally call simple_set_mnt() to instantiate the vfsmount. This will always return 0, and so can be tail-called from get_sb(). (*) generic_shutdown_super() now calls shrink_dcache_sb() to clean up the dcache upon superblock destruction rather than shrink_dcache_anon(). This is required because the superblock may now have multiple trees that aren't actually bound to s_root, but that still need to be cleaned up. The currently called functions assume that the whole tree is rooted at s_root, and that anonymous dentries are not the roots of trees which results in dentries being left unculled. However, with the way NFS superblock sharing are currently set to be implemented, these assumptions are violated: the root of the filesystem is simply a dummy dentry and inode (the real inode for '/' may well be inaccessible), and all the vfsmounts are rooted on anonymous[*] dentries with child trees. [*] Anonymous until discovered from another tree. (*) The documentation has been adjusted, including the additional bit of changing ext2_* into foo_* in the documentation. [akpm@osdl.org: convert ipath_fs, do other stuff] Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Nathan Scott <nathans@sgi.com> Cc: Roland Dreier <rolandd@cisco.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] Make most file operations structs in fs/ constArjan van de Ven
This is a conversion to make the various file_operations structs in fs/ const. Basically a regexp job, with a few manual fixups The goal is both to increase correctness (harder to accidentally write to shared datastructures) and reducing the false sharing of cachelines with things that get dirty in .data (while .rodata is nicely read only and thus cache clean) Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] cpuset memory spread: slab cache formatPaul Jackson
Rewrap the overly long source code lines resulting from the previous patch's addition of the slab cache flag SLAB_MEM_SPREAD. This patch contains only formatting changes, and no function change. Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] cpuset memory spread: slab cache filesystemsPaul Jackson
Mark file system inode and similar slab caches subject to SLAB_MEM_SPREAD memory spreading. If a slab cache is marked SLAB_MEM_SPREAD, then anytime that a task that's in a cpuset with the 'memory_spread_slab' option enabled goes to allocate from such a slab cache, the allocations are spread evenly over all the memory nodes (task->mems_allowed) allowed to that task, instead of favoring allocation on the node local to the current cpu. The following inode and similar caches are marked SLAB_MEM_SPREAD: file cache ==== ===== fs/adfs/super.c adfs_inode_cache fs/affs/super.c affs_inode_cache fs/befs/linuxvfs.c befs_inode_cache fs/bfs/inode.c bfs_inode_cache fs/block_dev.c bdev_cache fs/cifs/cifsfs.c cifs_inode_cache fs/coda/inode.c coda_inode_cache fs/dquot.c dquot fs/efs/super.c efs_inode_cache fs/ext2/super.c ext2_inode_cache fs/ext2/xattr.c (fs/mbcache.c) ext2_xattr fs/ext3/super.c ext3_inode_cache fs/ext3/xattr.c (fs/mbcache.c) ext3_xattr fs/fat/cache.c fat_cache fs/fat/inode.c fat_inode_cache fs/freevxfs/vxfs_super.c vxfs_inode fs/hpfs/super.c hpfs_inode_cache fs/isofs/inode.c isofs_inode_cache fs/jffs/inode-v23.c jffs_fm fs/jffs2/super.c jffs2_i fs/jfs/super.c jfs_ip fs/minix/inode.c minix_inode_cache fs/ncpfs/inode.c ncp_inode_cache fs/nfs/direct.c nfs_direct_cache fs/nfs/inode.c nfs_inode_cache fs/ntfs/super.c ntfs_big_inode_cache_name fs/ntfs/super.c ntfs_inode_cache fs/ocfs2/dlm/dlmfs.c dlmfs_inode_cache fs/ocfs2/super.c ocfs2_inode_cache fs/proc/inode.c proc_inode_cache fs/qnx4/inode.c qnx4_inode_cache fs/reiserfs/super.c reiser_inode_cache fs/romfs/inode.c romfs_inode_cache fs/smbfs/inode.c smb_inode_cache fs/sysv/inode.c sysv_inode_cache fs/udf/super.c udf_inode_cache fs/ufs/super.c ufs_inode_cache net/socket.c sock_inode_cache net/sunrpc/rpc_pipe.c rpc_inode_cache The choice of which slab caches to so mark was quite simple. I marked those already marked SLAB_RECLAIM_ACCOUNT, except for fs/xfs, dentry_cache, inode_cache, and buffer_head, which were marked in a previous patch. Even though SLAB_RECLAIM_ACCOUNT is for a different purpose, it marks the same potentially large file system i/o related slab caches as we need for memory spreading. Given that the rule now becomes "wherever you would have used a SLAB_RECLAIM_ACCOUNT slab cache flag before (usually the inode cache), use the SLAB_MEM_SPREAD flag too", this should be easy enough to maintain. Future file system writers will just copy one of the existing file system slab cache setups and tend to get it right without thinking. Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-04[PATCH] bfs iget() abusesAl Viro
bfs_fill_super() walks the inode table to get the bitmap of free inodes and collect stats. It has no business using iget() for that - it's a lot of extra work, extra icache pollution and more complex code. Switched to walking the damn thing directly. Note: that also allows to kill ->i_dsk_ino in there - separate patch if Tigran can confirm that this field can be zero only for deleted inodes (i.e. something that could only be found during that scan and not by normal lookups). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-04[PATCH] bfs endianness annotationsAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] bfs: fix endianness, signedness; add trivial bugfixAndrew Stribblehill
* Makes BFS code endianness-clean. * Fixes some signedness warnings. * Fixes a problem in fs/bfs/inode.c:164 where inodes not synced to disk don't get fully marked as clean. Here's how to reproduce it: # mount -o loop -t bfs /bfs.img /mnt # df -i /mnt Filesystem Inodes IUsed IFree IUse% Mounted on /bfs.img 48 1 47 3% /mnt # df -k /mnt Filesystem 1K-blocks Used Available Use% Mounted on /bfs.img 512 5 508 1% /mnt # cp 60k-archive.zip /mnt/mt.zip # df -k /mnt Filesystem 1K-blocks Used Available Use% Mounted on /bfs.img 512 65 447 13% /mnt # df -i /mnt Filesystem Inodes IUsed IFree IUse% Mounted on /bfs.img 48 2 46 5% /mnt # rm /mnt/mt.zip # echo $? 0 [If the unlink happens before the buffers flush, the following happens:] # df -i /mnt Filesystem Inodes IUsed IFree IUse% Mounted on /bfs.img 48 2 46 5% /mnt # df -k /mnt Filesystem 1K-blocks Used Available Use% Mounted on /bfs.img 512 65 447 13% /mnt fs/bfs/bfs.h | 1 Signed-off-by: Andrew Stribblehill <ads@wompom.org> Cc: <tigran@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] update filesystems for new delete_inode behaviorMark Fasheh
Update the file systems in fs/ implementing a delete_inode() callback to call truncate_inode_pages(). One implementation note: In developing this patch I put the calls to truncate_inode_pages() at the very top of those filesystems delete_inode() callbacks in order to retain the previous behavior. I'm guessing that some of those could probably be optimized. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com> Acked-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
