commit 5998649f779b7148a8a0c10c46cfa99e27d34dfe upstream.
double iput(), leaks...
* Remove smp_lock.h from files which don't need it (including some headers!)
* Add smp_lock.h to files which do need it
* Make smp_lock.h include conditional in hardirq.h
It's needed only for one kernel_locked() usage which is under CONFIG_PREEMPT
This will make hardirq.h inclusion cheaper for every PREEMPT=n config
(which includes allmodconfig/allyesconfig, BTW)
Add a ->sync_fs method for data integrity syncs, and reimplement
->write_super ontop of it.
Move BKL into ->put_super from the only caller. A couple of
filesystems had trivial enough ->put_super (only kfree and NULLing of
s_fs_info + stuff in there) to not get any locking: coda, cramfs, efs,
hugetlbfs, omfs, qnx4, shmem, all others got the full treatment. Most
of them probably don't need it, but I'd rather sort that out individually.
Preferably after all the other BKL pushdowns in that area.
[AV: original used to move lock_super() down as well; these changes are
removed since we don't do lock_super() at all in generic_shutdown_super()
now]
[AV: fuse, btrfs and xfs are known to need no damn BKL, exempt]
We just did a full fs writeout using sync_filesystem before, and if
that's not enough for the filesystem it can perform it's own writeout
in ->put_super, which many filesystems already do.
Move a call to foofs_write_super into every foofs_put_super for now to
guarantee identical behaviour until it's cleaned up by the individual
filesystem maintainers.
Exceptions:
- affs already has identical copy & pasted code at the beginning of
affs_put_super so no need to do it twice.
- xfs does the right thing without it and I have changes pending for
the xfs tree touching this are so I don't really need conflicts
here..
Since all sanity checks rely on the validity of s_start which gets only
checked to be smaller than s_end, we should also check if s_end is sane.
Now we also try to retrieve the last block of the filesystem, which is
computed by s_end. If this fails, something is bogus.
Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de>
Acked-by: Tigran Aivazian <tigran@aivazian.fsnet.co.uk>
bfs_fill_super() already touches all inodes, so we can easily add some
cheap sanity checks and check if the inode start and end blocks are
smaller than the maximum number of blocks, the inode start block lies
behind the end block or the file end offset is behind the end of the
filesystem. Also check if the start of data offset in the super block
fits the filesystem.
The added sanity checks catch softlockup issues early when we try to
sb_bread() lots of blocks in a loop in bfs_readdir() and bfs_find_entry().
In addition an oom issue in bfs_fill_super() is prevented by this when
s_start is corrupted, which influences imap_len and we try to allocate a
huge info->si_imap.
Wrap access to task credentials so that they can be separated more easily from
the task_struct during the introduction of COW creds.
Change most current->(|e|s|fs)[ug]id to current_(|e|s|fs)[ug]id().
Change some task->e?[ug]id to task_e?[ug]id(). In some places it makes more
sense to use RCU directly rather than a convenient wrapper; these will be
addressed by later patches.
Reviewed-by: James Morris <jmorris@namei.org>
Acked-by: Serge Hallyn <serue@us.ibm.com>
Cc: Tigran A. Aivazian <tigran@aivazian.fsnet.co.uk>
Signed-off-by: James Morris <jmorris@namei.org>
With this patch all directory fops instances that have a readdir
that doesn't take the BKL are switched to generic_file_llseek.
This fixes:
[ INFO: possible recursive locking detected ]
2.6.27-rc5-00283-g70bb089 #68
touch/6855 is trying to acquire lock:
(&info->bfs_lock){--..}, at: [<c02262f5>] bfs_delete_inode+0x9e/0x18c
but task is already holding lock:
(&info->bfs_lock){--..}, at: [<c0226c00>] bfs_create+0x45/0x187
2 locks held by touch/6855:
#0: (&type->i_mutex_dir_key#5){--..}, at: [<c018ad13>] do_filp_open+0x10b/0x62f
#1: (&info->bfs_lock){--..}, at: [<c0226c00>] bfs_create+0x45/0x187
stack backtrace:
Pid: 6855, comm: touch Not tainted 2.6.27-rc5-00283-g70bb089 #68
[<c013e769>] validate_chain+0x458/0x9f4
[<c013bece>] ? trace_hardirqs_off+0xb/0xd
[<c013f36b>] __lock_acquire+0x666/0x6e0
[<c013f440>] lock_acquire+0x5b/0x77
[<c02262f5>] ? bfs_delete_inode+0x9e/0x18c
[<c06aab74>] mutex_lock_nested+0xbc/0x234
[<c0226257>] ? bfs_delete_inode+0x0/0x18c
[<c01925e1>] generic_delete_inode+0x94/0xfe
[<c019265d>] generic_drop_inode+0x12/0x12f
[<c0191b7e>] iput+0x4b/0x4e
[<c0226d1e>] bfs_create+0x163/0x187
[<c0188b42>] vfs_create+0xa6/0x114
[<c018adb5>] do_filp_open+0x1ad/0x62f
[<c0107cdc>] ? native_sched_clock+0x82/0x96
[<c06ac309>] ? _spin_unlock+0x27/0x3c
[<c019379e>] ? alloc_fd+0xbf/0xc9
[<c06ae2f4>] ? sub_preempt_count+0x9d/0xab
[<c0180391>] do_sys_open+0x42/0xb8
[<c041d564>] ? trace_hardirqs_on_thunk+0xc/0x10
[<c0180449>] sys_open+0x1e/0x26
[<c01038bd>] sysenter_do_call+0x12/0x31
The problem is that we don't unlock the bfs->lock mutex before calling
iput (we do in the other cases).
Cc: Tigran Aivazian <tigran@aivazian.fsnet.co.uk>
Kmem cache passed to constructor is only needed for constructors that are
themselves multiplexeres. Nobody uses this "feature", nor does anybody uses
passed kmem cache in non-trivial way, so pass only pointer to object.
Non-trivial places are:
arch/powerpc/mm/init_64.c
arch/powerpc/mm/hugetlbpage.c
This is flag day, yes.
Acked-by: Pekka Enberg <penberg@cs.helsinki.fi>
Acked-by: Christoph Lameter <cl@linux-foundation.org>
Cc: Jon Tollefson <kniht@linux.vnet.ibm.com>
Cc: Nick Piggin <nickpiggin@yahoo.com.au>
Cc: Matt Mackall <mpm@selenic.com>
[akpm@linux-foundation.org: fix arch/powerpc/mm/hugetlbpage.c]
[akpm@linux-foundation.org: fix mm/slab.c]
[akpm@linux-foundation.org: fix ubifs]
Replace the BKL-based locking scheme used in the bfs driver by a private
filesystem-wide mutex.
Signed-off-by: Dmitri Vorobiev <dmitri.vorobiev@movial.fi>
Cc: Tigran Aivazian <tigran_aivazian@symantec.com>
This patch makes the following cleanups:
o removing an unused variable from bfs_fill_super();
o removing unneeded blank spaces from pointer
definitions.
__FUNCTION__ is gcc-specific, use __func__
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Stop the BFS filesystem from using iget() and read_inode(). Replace
bfs_read_inode() with bfs_iget(), and call that instead of iget(). bfs_iget()
then uses iget_locked() directly and returns a proper error code instead of an
inode in the event of an error.
bfs_fill_super() returns any error incurred when getting the root inode
instead of EINVAL.
[kamalesh@linux.vnet.ibm.com: build fix]
Acked-by: Christoph Hellwig <hch@lst.de>
Signed-off-by: Kamalesh Babulal <kamalesh@linux.vnet.ibm.com>
BFS_FILEBLOCKS() expects struct bfs_inode * (on-disk data, with little-
endian fields), not struct bfs_inode_info * (in-core stuff, with host-
endian ones).
It's a macro and fields with the right names are present in
bfs_inode_info, so it compiles, but on big-endian host it gives bogus
results.
Introduced in commit f433dc56344cb72cc3de5ba0819021cec3aef807 ("Fixes to
the BFS filesystem driver").
I found a few bugs in the BFS driver. Detailed description of the bugs as
well as the steps to reproduce the errors are given in the kernel bugzilla.
Please follow these links for more information:
http://bugzilla.kernel.org/show_bug.cgi?id=9363
http://bugzilla.kernel.org/show_bug.cgi?id=9364
http://bugzilla.kernel.org/show_bug.cgi?id=9365
http://bugzilla.kernel.org/show_bug.cgi?id=9366
This patch fixes the bugs described above. Besides, the patch introduces
coding style changes to make the BFS driver conform to the requirements
specified for Linux kernel code. Finally, I made a few cosmetic changes
such as removal of trivial debug output.
Also, the patch removes the fields `si_lf_ioff' and `si_lf_sblk' of the
in-core superblock structure. These fields are initialized but never
actually used.
If you are wondering why I need BFS, here is the answer: I am using this
driver in the context of Linux kernel classes I am teaching in the Moscow
State University and in the International Institute of Information
Technology in Pune, India.
Signed-off-by: Dmitri Vorobiev <dmitri.vorobiev@gmail.com>
Cc: Tigran Aivazian <tigran@veritas.com>
Slab constructors currently have a flags parameter that is never used. And
the order of the arguments is opposite to other slab functions. The object
pointer is placed before the kmem_cache pointer.
Convert
ctor(void *object, struct kmem_cache *s, unsigned long flags)
to
ctor(struct kmem_cache *s, void *object)
throughout the kernel
[akpm@linux-foundation.org: coupla fixes]
Signed-off-by: Christoph Lameter <clameter@sgi.com>
Signed-off-by: Nick Piggin <npiggin@suse.de>
Slab destructors were no longer supported after Christoph's
c59def9f222d44bb7e2f0a559f2906191a0862d7 change. They've been
BUGs for both slab and slub, and slob never supported them
either.
This rips out support for the dtor pointer from kmem_cache_create()
completely and fixes up every single callsite in the kernel (there were
about 224, not including the slab allocator definitions themselves,
or the documentation references).
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
They can use generic_file_splice_read() instead. Since sys_sendfile() now
prefers that, there should be no change in behaviour.
SLAB_CTOR_CONSTRUCTOR is always specified. No point in checking it.
Cc: Jens Axboe <jens.axboe@oracle.com>
Cc: Steven French <sfrench@us.ibm.com>
Cc: Michael Halcrow <mhalcrow@us.ibm.com>
Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
Cc: Miklos Szeredi <miklos@szeredi.hu>
Cc: Steven Whitehouse <swhiteho@redhat.com>
Cc: Roman Zippel <zippel@linux-m68k.org>
Cc: Dave Kleikamp <shaggy@austin.ibm.com>
Cc: Trond Myklebust <trond.myklebust@fys.uio.no>
Cc: "J. Bruce Fields" <bfields@fieldses.org>
Cc: Anton Altaparmakov <aia21@cantab.net>
Cc: Mark Fasheh <mark.fasheh@oracle.com>
Cc: Jan Kara <jack@ucw.cz>
Cc: David Chinner <dgc@sgi.com>
I have never seen a use of SLAB_DEBUG_INITIAL. It is only supported by
SLAB.
I think its purpose was to have a callback after an object has been freed
to verify that the state is the constructor state again? The callback is
performed before each freeing of an object.
I would think that it is much easier to check the object state manually
before the free. That also places the check near the code object
manipulation of the object.
Also the SLAB_DEBUG_INITIAL callback is only performed if the kernel was
compiled with SLAB debugging on. If there would be code in a constructor
handling SLAB_DEBUG_INITIAL then it would have to be conditional on
SLAB_DEBUG otherwise it would just be dead code. But there is no such code
in the kernel. I think SLUB_DEBUG_INITIAL is too problematic to make real
use of, difficult to understand and there are easier ways to accomplish the
same effect (i.e. add debug code before kfree).
There is a related flag SLAB_CTOR_VERIFY that is frequently checked to be
clear in fs inode caches. Remove the pointless checks (they would even be
pointless without removeal of SLAB_DEBUG_INITIAL) from the fs constructors.
This is the last slab flag that SLUB did not support. Remove the check for
unimplemented flags from SLUB.
This patch is inspired by Arjan's "Patch series to mark struct
file_operations and struct inode_operations const".
Compile tested with gcc & sparse.
Signed-off-by: Josef 'Jeff' Sipek <jsipek@cs.sunysb.edu>
Many struct inode_operations in the kernel can be "const". Marking them const
moves these to the .rodata section, which avoids false sharing with potential
dirty data. In addition it'll catch accidental writes at compile time to
these shared resources.
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
As Adrian pointed out recently, there were still a couple of places where
I should have fixed my email address.
Signed-off-by: Josef Sipek <jsipek@fsl.cs.sunysb.edu>
Replace all uses of kmem_cache_t with struct kmem_cache.
The patch was generated using the following script:
#!/bin/sh
# Replace one string by another in all the kernel sources.
set -e
for file in `find * -name "*.c" -o -name "*.h"|xargs grep -l $1`; do
quilt add $file
sed -e "1,\$s/$1/$2/g" $file >/tmp/$$
mv /tmp/$$ $file
quilt refresh
done
The script was run like this
sh replace kmem_cache_t "struct kmem_cache"
SLAB_KERNEL is an alias of GFP_KERNEL.
This is mostly included for parity with dec_nlink(), where we will have some
more hooks. This one should stay pretty darn straightforward for now.
Signed-off-by: Dave Hansen <haveblue@us.ibm.com>
When a filesystem decrements i_nlink to zero, it means that a write must be
performed in order to drop the inode from the filesystem.
We're shortly going to have keep filesystems from being remounted r/o between
the time that this i_nlink decrement and that write occurs.
So, add a little helper function to do the decrements. We'll tie into it in a
bit to note when i_nlink hits zero.
This patch cleans up generic_file_*_read/write() interfaces. Christoph
Hellwig gave me the idea for this clean ups.
In a nutshell, all filesystems should set .aio_read/.aio_write methods and use
do_sync_read/ do_sync_write() as their .read/.write methods. This allows us
to cleanup all variants of generic_file_* routines.
Final available interfaces:
generic_file_aio_read() - read handler
generic_file_aio_write() - write handler
generic_file_aio_write_nolock() - no lock write handler
__generic_file_aio_write_nolock() - internal worker routine
Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com>
This eliminates the i_blksize field from struct inode. Filesystems that want
to provide a per-inode st_blksize can do so by providing their own getattr
routine instead of using the generic_fillattr() function.
Note that some filesystems were providing pretty much random (and incorrect)
values for i_blksize.
[bunk@stusta.de: cleanup]
[akpm@osdl.org: generic_fillattr() fix]
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
* Rougly half of callers already do it by not checking return value
* Code in drivers/acpi/osl.c does the following to be sure:
(void)kmem_cache_destroy(cache);
* Those who check it printk something, however, slab_error already printed
the name of failed cache.
* XFS BUGs on failed kmem_cache_destroy which is not the decision
low-level filesystem driver should make. Converted to ignore.
Conversions from kmalloc+memset to kzalloc.
Signed-off-by: Panagiotis Issaris <takis@issaris.org>
Jffs2-bit-acked-by: David Woodhouse <dwmw2@infradead.org>
Same as with already do with the file operations: keep them in .rodata and
prevents people from doing runtime patching.
Give the statfs superblock operation a dentry pointer rather than a superblock
pointer.
This complements the get_sb() patch. That reduced the significance of
sb->s_root, allowing NFS to place a fake root there. However, NFS does
require a dentry to use as a target for the statfs operation. This permits
the root in the vfsmount to be used instead.
linux/mount.h has been added where necessary to make allyesconfig build
successfully.
Interest has also been expressed for use with the FUSE and XFS filesystems.
Acked-by: Al Viro <viro@zeniv.linux.org.uk>
Cc: Nathan Scott <nathans@sgi.com>
Extend the get_sb() filesystem operation to take an extra argument that
permits the VFS to pass in the target vfsmount that defines the mountpoint.
The filesystem is then required to manually set the superblock and root dentry
pointers. For most filesystems, this should be done with simple_set_mnt()
which will set the superblock pointer and then set the root dentry to the
superblock's s_root (as per the old default behaviour).
The get_sb() op now returns an integer as there's now no need to return the
superblock pointer.
This patch permits a superblock to be implicitly shared amongst several mount
points, such as can be done with NFS to avoid potential inode aliasing. In
such a case, simple_set_mnt() would not be called, and instead the mnt_root
and mnt_sb would be set directly.
The patch also makes the following changes:
(*) the get_sb_*() convenience functions in the core kernel now take a vfsmount
pointer argument and return an integer, so most filesystems have to change
very little.
(*) If one of the convenience function is not used, then get_sb() should
normally call simple_set_mnt() to instantiate the vfsmount. This will
always return 0, and so can be tail-called from get_sb().
(*) generic_shutdown_super() now calls shrink_dcache_sb() to clean up the
dcache upon superblock destruction rather than shrink_dcache_anon().
This is required because the superblock may now have multiple trees that
aren't actually bound to s_root, but that still need to be cleaned up. The
currently called functions assume that the whole tree is rooted at s_root,
and that anonymous dentries are not the roots of trees which results in
dentries being left unculled.
However, with the way NFS superblock sharing are currently set to be
implemented, these assumptions are violated: the root of the filesystem is
simply a dummy dentry and inode (the real inode for '/' may well be
inaccessible), and all the vfsmounts are rooted on anonymous[*] dentries
with child trees.
[*] Anonymous until discovered from another tree.
(*) The documentation has been adjusted, including the additional bit of
changing ext2_* into foo_* in the documentation.
[akpm@osdl.org: convert ipath_fs, do other stuff]
Cc: Roland Dreier <rolandd@cisco.com>
This is a conversion to make the various file_operations structs in fs/
const. Basically a regexp job, with a few manual fixups
The goal is both to increase correctness (harder to accidentally write to
shared datastructures) and reducing the false sharing of cachelines with
things that get dirty in .data (while .rodata is nicely read only and thus
cache clean)
Signed-off-by: Arjan van de Ven <arjan@infradead.org>
Rewrap the overly long source code lines resulting from the previous
patch's addition of the slab cache flag SLAB_MEM_SPREAD. This patch
contains only formatting changes, and no function change.
Signed-off-by: Paul Jackson <pj@sgi.com>
Mark file system inode and similar slab caches subject to SLAB_MEM_SPREAD
memory spreading.
If a slab cache is marked SLAB_MEM_SPREAD, then anytime that a task that's
in a cpuset with the 'memory_spread_slab' option enabled goes to allocate
from such a slab cache, the allocations are spread evenly over all the
memory nodes (task->mems_allowed) allowed to that task, instead of favoring
allocation on the node local to the current cpu.
The following inode and similar caches are marked SLAB_MEM_SPREAD:
file cache
fs/adfs/super.c adfs_inode_cache
fs/affs/super.c affs_inode_cache
fs/befs/linuxvfs.c befs_inode_cache
fs/bfs/inode.c bfs_inode_cache
fs/block_dev.c bdev_cache
fs/cifs/cifsfs.c cifs_inode_cache
fs/coda/inode.c coda_inode_cache
fs/dquot.c dquot
fs/efs/super.c efs_inode_cache
fs/ext2/super.c ext2_inode_cache
fs/ext2/xattr.c (fs/mbcache.c) ext2_xattr
fs/ext3/super.c ext3_inode_cache
fs/ext3/xattr.c (fs/mbcache.c) ext3_xattr
fs/fat/cache.c fat_cache
fs/fat/inode.c fat_inode_cache
fs/freevxfs/vxfs_super.c vxfs_inode
fs/hpfs/super.c hpfs_inode_cache
fs/isofs/inode.c isofs_inode_cache
fs/jffs/inode-v23.c jffs_fm
fs/jffs2/super.c jffs2_i
fs/jfs/super.c jfs_ip
fs/minix/inode.c minix_inode_cache
fs/ncpfs/inode.c ncp_inode_cache
fs/nfs/direct.c nfs_direct_cache
fs/nfs/inode.c nfs_inode_cache
fs/ntfs/super.c ntfs_big_inode_cache_name
fs/ntfs/super.c ntfs_inode_cache
fs/ocfs2/dlm/dlmfs.c dlmfs_inode_cache
fs/ocfs2/super.c ocfs2_inode_cache
fs/proc/inode.c proc_inode_cache
fs/qnx4/inode.c qnx4_inode_cache
fs/reiserfs/super.c reiser_inode_cache
fs/romfs/inode.c romfs_inode_cache
fs/smbfs/inode.c smb_inode_cache
fs/sysv/inode.c sysv_inode_cache
fs/udf/super.c udf_inode_cache
fs/ufs/super.c ufs_inode_cache
net/socket.c sock_inode_cache
net/sunrpc/rpc_pipe.c rpc_inode_cache
The choice of which slab caches to so mark was quite simple. I marked
those already marked SLAB_RECLAIM_ACCOUNT, except for fs/xfs, dentry_cache,
inode_cache, and buffer_head, which were marked in a previous patch. Even
though SLAB_RECLAIM_ACCOUNT is for a different purpose, it marks the same
potentially large file system i/o related slab caches as we need for memory
spreading.
Given that the rule now becomes "wherever you would have used a
SLAB_RECLAIM_ACCOUNT slab cache flag before (usually the inode cache), use
the SLAB_MEM_SPREAD flag too", this should be easy enough to maintain.
Future file system writers will just copy one of the existing file system
slab cache setups and tend to get it right without thinking.
bfs_fill_super() walks the inode table to get the bitmap of free inodes
and collect stats. It has no business using iget() for that - it's a
lot of extra work, extra icache pollution and more complex code.
Switched to walking the damn thing directly.
Note: that also allows to kill ->i_dsk_ino in there - separate patch if
Tigran can confirm that this field can be zero only for deleted inodes
(i.e. something that could only be found during that scan and not by
normal lookups).
* Makes BFS code endianness-clean.
* Fixes some signedness warnings.
* Fixes a problem in fs/bfs/inode.c:164 where inodes not synced to disk
don't get fully marked as clean. Here's how to reproduce it:
# mount -o loop -t bfs /bfs.img /mnt
# df -i /mnt
Filesystem Inodes IUsed IFree IUse% Mounted on
/bfs.img 48 1 47 3% /mnt
# df -k /mnt
Filesystem 1K-blocks Used Available Use% Mounted on
/bfs.img 512 5 508 1% /mnt
# cp 60k-archive.zip /mnt/mt.zip
# df -k /mnt
/bfs.img 512 65 447 13% /mnt
# df -i /mnt
/bfs.img 48 2 46 5% /mnt
# rm /mnt/mt.zip
# echo $?
0
[If the unlink happens before the buffers flush, the following happens:]
# df -i /mnt
# df -k /mnt
fs/bfs/bfs.h | 1
Signed-off-by: Andrew Stribblehill <ads@wompom.org>
Cc: <tigran@veritas.com>
Update the file systems in fs/ implementing a delete_inode() callback to
call truncate_inode_pages(). One implementation note: In developing this
patch I put the calls to truncate_inode_pages() at the very top of those
filesystems delete_inode() callbacks in order to retain the previous
behavior. I'm guessing that some of those could probably be optimized.
Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
Acked-by: Christoph Hellwig <hch@infradead.org>
Signed-off-by: Hugh Dickins <hugh@veritas.com>
infrastructure for it.
Let it rip!
