path: root/fs/binfmt_elf.c
2015-05-28fs/binfmt_elf.c:load_elf_binary(): return -EINVAL on zero-length mappingsAndrew Morton
load_elf_binary() returns `retval', not `error'. Fixes: a87938b2e246b81b4fb ("fs/binfmt_elf.c: fix bug in loading of PIE binaries") Reported-by: James Hogan <james.hogan@imgtec.com> Cc: Michael Davidson <md@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-14mm: fold arch_randomize_brk into ARCH_HAS_ELF_RANDOMIZEKees Cook
The arch_randomize_brk() function is used on several architectures, even those that don't support ET_DYN ASLR. To avoid bulky extern/#define tricks, consolidate the support under CONFIG_ARCH_HAS_ELF_RANDOMIZE for the architectures that support it, while still handling CONFIG_COMPAT_BRK. Signed-off-by: Kees Cook <keescook@chromium.org> Cc: Hector Marco-Gisbert <hecmargi@upv.es> Cc: Russell King <linux@arm.linux.org.uk> Reviewed-by: Ingo Molnar <mingo@kernel.org> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Andy Lutomirski <luto@amacapital.net> Cc: "David A. Long" <dave.long@linaro.org> Cc: Andrey Ryabinin <a.ryabinin@samsung.com> Cc: Arun Chandran <achandran@mvista.com> Cc: Yann Droneaud <ydroneaud@opteya.com> Cc: Min-Hua Chen <orca.chen@gmail.com> Cc: Paul Burton <paul.burton@imgtec.com> Cc: Alex Smith <alex@alex-smith.me.uk> Cc: Markos Chandras <markos.chandras@imgtec.com> Cc: Vineeth Vijayan <vvijayan@mvista.com> Cc: Jeff Bailey <jeffbailey@google.com> Cc: Michael Holzheu <holzheu@linux.vnet.ibm.com> Cc: Ben Hutchings <ben@decadent.org.uk> Cc: Behan Webster <behanw@converseincode.com> Cc: Ismael Ripoll <iripoll@upv.es> Cc: Jan-Simon Mller <dl9pf@gmx.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-14mm: split ET_DYN ASLR from mmap ASLRKees Cook
This fixes the "offset2lib" weakness in ASLR for arm, arm64, mips, powerpc, and x86. The problem is that if there is a leak of ASLR from the executable (ET_DYN), it means a leak of shared library offset as well (mmap), and vice versa. Further details and a PoC of this attack is available here: http://cybersecurity.upv.es/attacks/offset2lib/offset2lib.html With this patch, a PIE linked executable (ET_DYN) has its own ASLR region: $ ./show_mmaps_pie 54859ccd6000-54859ccd7000 r-xp ... /tmp/show_mmaps_pie 54859ced6000-54859ced7000 r--p ... /tmp/show_mmaps_pie 54859ced7000-54859ced8000 rw-p ... /tmp/show_mmaps_pie 7f75be764000-7f75be91f000 r-xp ... /lib/x86_64-linux-gnu/libc.so.6 7f75be91f000-7f75beb1f000 ---p ... /lib/x86_64-linux-gnu/libc.so.6 7f75beb1f000-7f75beb23000 r--p ... /lib/x86_64-linux-gnu/libc.so.6 7f75beb23000-7f75beb25000 rw-p ... /lib/x86_64-linux-gnu/libc.so.6 7f75beb25000-7f75beb2a000 rw-p ... 7f75beb2a000-7f75beb4d000 r-xp ... /lib64/ld-linux-x86-64.so.2 7f75bed45000-7f75bed46000 rw-p ... 7f75bed46000-7f75bed47000 r-xp ... 7f75bed47000-7f75bed4c000 rw-p ... 7f75bed4c000-7f75bed4d000 r--p ... /lib64/ld-linux-x86-64.so.2 7f75bed4d000-7f75bed4e000 rw-p ... /lib64/ld-linux-x86-64.so.2 7f75bed4e000-7f75bed4f000 rw-p ... 7fffb3741000-7fffb3762000 rw-p ... [stack] 7fffb377b000-7fffb377d000 r--p ... [vvar] 7fffb377d000-7fffb377f000 r-xp ... [vdso] The change is to add a call the newly created arch_mmap_rnd() into the ELF loader for handling ET_DYN ASLR in a separate region from mmap ASLR, as was already done on s390. Removes CONFIG_BINFMT_ELF_RANDOMIZE_PIE, which is no longer needed. Signed-off-by: Kees Cook <keescook@chromium.org> Reported-by: Hector Marco-Gisbert <hecmargi@upv.es> Cc: Russell King <linux@arm.linux.org.uk> Reviewed-by: Ingo Molnar <mingo@kernel.org> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Andy Lutomirski <luto@amacapital.net> Cc: "David A. Long" <dave.long@linaro.org> Cc: Andrey Ryabinin <a.ryabinin@samsung.com> Cc: Arun Chandran <achandran@mvista.com> Cc: Yann Droneaud <ydroneaud@opteya.com> Cc: Min-Hua Chen <orca.chen@gmail.com> Cc: Paul Burton <paul.burton@imgtec.com> Cc: Alex Smith <alex@alex-smith.me.uk> Cc: Markos Chandras <markos.chandras@imgtec.com> Cc: Vineeth Vijayan <vvijayan@mvista.com> Cc: Jeff Bailey <jeffbailey@google.com> Cc: Michael Holzheu <holzheu@linux.vnet.ibm.com> Cc: Ben Hutchings <ben@decadent.org.uk> Cc: Behan Webster <behanw@converseincode.com> Cc: Ismael Ripoll <iripoll@upv.es> Cc: Jan-Simon Mller <dl9pf@gmx.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-14fs/binfmt_elf.c: fix bug in loading of PIE binariesMichael Davidson
With CONFIG_ARCH_BINFMT_ELF_RANDOMIZE_PIE enabled, and a normal top-down address allocation strategy, load_elf_binary() will attempt to map a PIE binary into an address range immediately below mm->mmap_base. Unfortunately, load_elf_ binary() does not take account of the need to allocate sufficient space for the entire binary which means that, while the first PT_LOAD segment is mapped below mm->mmap_base, the subsequent PT_LOAD segment(s) end up being mapped above mm->mmap_base into the are that is supposed to be the "gap" between the stack and the binary. Since the size of the "gap" on x86_64 is only guaranteed to be 128MB this means that binaries with large data segments > 128MB can end up mapping part of their data segment over their stack resulting in corruption of the stack (and the data segment once the binary starts to run). Any PIE binary with a data segment > 128MB is vulnerable to this although address randomization means that the actual gap between the stack and the end of the binary is normally greater than 128MB. The larger the data segment of the binary the higher the probability of failure. Fix this by calculating the total size of the binary in the same way as load_elf_interp(). Signed-off-by: Michael Davidson <md@google.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Kees Cook <keescook@chromium.org> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-19x86, mm/ASLR: Fix stack randomization on 64-bit systemsHector Marco-Gisbert
The issue is that the stack for processes is not properly randomized on 64 bit architectures due to an integer overflow. The affected function is randomize_stack_top() in file "fs/binfmt_elf.c": static unsigned long randomize_stack_top(unsigned long stack_top) { unsigned int random_variable = 0; if ((current->flags & PF_RANDOMIZE) && !(current->personality & ADDR_NO_RANDOMIZE)) { random_variable = get_random_int() & STACK_RND_MASK; random_variable <<= PAGE_SHIFT; } return PAGE_ALIGN(stack_top) + random_variable; return PAGE_ALIGN(stack_top) - random_variable; } Note that, it declares the "random_variable" variable as "unsigned int". Since the result of the shifting operation between STACK_RND_MASK (which is 0x3fffff on x86_64, 22 bits) and PAGE_SHIFT (which is 12 on x86_64): random_variable <<= PAGE_SHIFT; then the two leftmost bits are dropped when storing the result in the "random_variable". This variable shall be at least 34 bits long to hold the (22+12) result. These two dropped bits have an impact on the entropy of process stack. Concretely, the total stack entropy is reduced by four: from 2^28 to 2^30 (One fourth of expected entropy). This patch restores back the entropy by correcting the types involved in the operations in the functions randomize_stack_top() and stack_maxrandom_size(). The successful fix can be tested with: $ for i in `seq 1 10`; do cat /proc/self/maps | grep stack; done 7ffeda566000-7ffeda587000 rw-p 00000000 00:00 0 [stack] 7fff5a332000-7fff5a353000 rw-p 00000000 00:00 0 [stack] 7ffcdb7a1000-7ffcdb7c2000 rw-p 00000000 00:00 0 [stack] 7ffd5e2c4000-7ffd5e2e5000 rw-p 00000000 00:00 0 [stack] ... Once corrected, the leading bytes should be between 7ffc and 7fff, rather than always being 7fff. Signed-off-by: Hector Marco-Gisbert <hecmargi@upv.es> Signed-off-by: Ismael Ripoll <iripoll@upv.es> [ Rebased, fixed 80 char bugs, cleaned up commit message, added test example and CVE ] Signed-off-by: Kees Cook <keescook@chromium.org> Cc: <stable@vger.kernel.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Fixes: CVE-2015-1593 Link: http://lkml.kernel.org/r/20150214173350.GA18393@www.outflux.net Signed-off-by: Borislav Petkov <bp@suse.de>
2014-12-11Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
Pull MIPS updates from Ralf Baechle: "This is an unusually large pull request for MIPS - in parts because lots of patches missed the 3.18 deadline but primarily because some folks opened the flood gates. - Retire the MIPS-specific phys_t with the generic phys_addr_t. - Improvments for the backtrace code used by oprofile. - Better backtraces on SMP systems. - Cleanups for the Octeon platform code. - Cleanups and fixes for the Loongson platform code. - Cleanups and fixes to the firmware library. - Switch ATH79 platform to use the firmware library. - Grand overhault to the SEAD3 and Malta interrupt code. - Move the GIC interrupt code to drivers/irqchip - Lots of GIC cleanups and updates to the GIC code to use modern IRQ infrastructures and features of the kernel. - OF documentation updates for the GIC bindings - Move GIC clocksource driver to drivers/clocksource - Merge GIC clocksource driver with clockevent driver. - Further updates to bring the GIC clocksource driver up to date. - R3000 TLB code cleanups - Improvments to the Loongson 3 platform code. - Convert pr_warning to pr_warn. - Merge a bunch of small lantiq and ralink fixes that have been staged/lingering inside the openwrt tree for a while. - Update archhelp for IP22/IP32 - Fix a number of issues for Loongson 1B. - New clocksource and clockevent driver for Loongson 1B. - Further work on clk handling for Loongson 1B. - Platform work for Broadcom BMIPS. - Error handling cleanups for TurboChannel. - Fixes and optimization to the microMIPS support. - Option to disable the FTLB. - Dump more relevant information on machine check exception - Change binfmt to allow arch to examine PT_*PROC headers - Support for new style FPU register model in O32 - VDSO randomization. - BCM47xx cleanups - BCM47xx reimplement the way the kernel accesses NVRAM information. - Random cleanups - Add support for ATH25 platforms - Remove pointless locking code in some PCI platforms. - Some improvments to EVA support - Minor Alchemy cleanup" * 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (185 commits) MIPS: Add MFHC0 and MTHC0 instructions to uasm. MIPS: Cosmetic cleanups of page table headers. MIPS: Add CP0 macros for extended EntryLo registers MIPS: Remove now unused definition of phys_t. MIPS: Replace use of phys_t with phys_addr_t. MIPS: Replace MIPS-specific 64BIT_PHYS_ADDR with generic PHYS_ADDR_T_64BIT PCMCIA: Alchemy Don't select 64BIT_PHYS_ADDR in Kconfig. MIPS: lib: memset: Clean up some MIPS{EL,EB} ifdefery MIPS: iomap: Use __mem_{read,write}{b,w,l} for MMIO MIPS: <asm/types.h> fix indentation. MAINTAINERS: Add entry for BMIPS multiplatform kernel MIPS: Enable VDSO randomization MIPS: Remove a temporary hack for debugging cache flushes in SMTC configuration MIPS: Remove declaration of obsolete arch_init_clk_ops() MIPS: atomic.h: Reformat to fit in 79 columns MIPS: Apply `.insn' to fixup labels throughout MIPS: Fix microMIPS LL/SC immediate offsets MIPS: Kconfig: Only allow 32-bit microMIPS builds MIPS: signal.c: Fix an invalid cast in ISA mode bit handling MIPS: mm: Only build one microassembler that is suitable ...
2014-12-10fs/binfmt_elf.c: fix internal inconsistency relating to vma dump sizeJungseung Lee
vma_dump_size() has been used several times on actual dumper and it is supposed to return the same value for the same vma. But vma_dump_size() could return different values for same vma. The known problem case is concurrent shared memory removal. If a vma is used for a shared memory and that shared memory is removed between writing program header and dumping vma memory, this will result in a dump file which is internally consistent. To fix the problem, we set baseline to get dump size and store the size into vma_filesz and always use the same vma dump size which is stored in vma_filsz. The consistnecy with reality is not actually guranteed, but it's tolerable since that is fully consistent with base line. Signed-off-by: Jungseung Lee <js07.lee@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-11-24binfmt_elf: allow arch code to examine PT_LOPROC ... PT_HIPROC headersPaul Burton
MIPS is introducing new variants of its O32 ABI which differ in their handling of floating point, in order to enable a gradual transition towards a world where mips32 binaries can take advantage of new hardware features only available when configured for certain FP modes. In order to do this ELF binaries are being augmented with a new section that indicates, amongst other things, the FP mode requirements of the binary. The presence & location of such a section is indicated by a program header in the PT_LOPROC ... PT_HIPROC range. In order to allow the MIPS architecture code to examine the program header & section in question, pass all program headers in this range to an architecture-specific arch_elf_pt_proc function. This function may return an error if the header is deemed invalid or unsuitable for the system, in which case that error will be returned from load_elf_binary and upwards through the execve syscall. A means is required for the architecture code to make a decision once it is known that all such headers have been seen, but before it is too late to return from an execve syscall. For this purpose the arch_check_elf function is added, and called once, after all PT_LOPROC to PT_HIPROC headers have been passed to arch_elf_pt_proc but before the code which invoked execve has been lost. This enables the architecture code to make a decision based upon all the headers present in an ELF binary and its interpreter, as is required to forbid conflicting FP ABI requirements between an ELF & its interpreter. In order to allow data to be stored throughout the calls to the above functions, struct arch_elf_state is introduced. Finally a variant of the SET_PERSONALITY macro is introduced which accepts a pointer to the struct arch_elf_state, allowing it to act based upon state observed from the architecture specific program headers. Signed-off-by: Paul Burton <paul.burton@imgtec.com> Cc: linux-mips@linux-mips.org Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: linux-fsdevel@vger.kernel.org Cc: linux-kernel@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/7679/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-11-24binfmt_elf: load interpreter program headers earlierPaul Burton
Load the program headers of an ELF interpreter early enough in load_elf_binary that they can be examined before it's too late to return an error from an exec syscall. This patch does not perform any such checking, it merely lays the groundwork for a further patch to do so. No functional change is intended. Signed-off-by: Paul Burton <paul.burton@imgtec.com> Cc: linux-mips@linux-mips.org Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: linux-fsdevel@vger.kernel.org Cc: linux-kernel@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/7675/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-11-24binfmt_elf: Hoist ELF program header loading to a functionPaul Burton
load_elf_binary & load_elf_interp both load program headers from an ELF executable in the same way, duplicating the code. This patch introduces a helper function (load_elf_phdrs) which performs this common task & calls it from both load_elf_binary & load_elf_interp. In addition to reducing code duplication, this is part of preparing to load the ELF interpreter headers earlier such that they can be examined before it's too late to return an error from an exec syscall. Signed-off-by: Paul Burton <paul.burton@imgtec.com> Cc: linux-mips@linux-mips.org Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: linux-fsdevel@vger.kernel.org Cc: linux-kernel@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/7676/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-10-09handle suicide on late failure exits in execve() in search_binary_handler()Al Viro
... rather than doing that in the guts of ->load_binary(). [updated to fix the bug spotted by Shentino - for SIGSEGV we really need something stronger than send_sig_info(); again, better do that in one place] Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-06-05Merge branch 'x86/vdso' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip into next Pull x86 cdso updates from Peter Anvin: "Vdso cleanups and improvements largely from Andy Lutomirski. This makes the vdso a lot less ''special''" * 'x86/vdso' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/vdso, build: Make LE access macros clearer, host-safe x86/vdso, build: Fix cross-compilation from big-endian architectures x86/vdso, build: When vdso2c fails, unlink the output x86, vdso: Fix an OOPS accessing the HPET mapping w/o an HPET x86, mm: Replace arch_vma_name with vm_ops->name for vsyscalls x86, mm: Improve _install_special_mapping and fix x86 vdso naming mm, fs: Add vm_ops->name as an alternative to arch_vma_name x86, vdso: Fix an OOPS accessing the HPET mapping w/o an HPET x86, vdso: Remove vestiges of VDSO_PRELINK and some outdated comments x86, vdso: Move the vvar and hpet mappings next to the 64-bit vDSO x86, vdso: Move the 32-bit vdso special pages after the text x86, vdso: Reimplement vdso.so preparation in build-time C x86, vdso: Move syscall and sysenter setup into kernel/cpu/common.c x86, vdso: Clean up 32-bit vs 64-bit vdso params x86, mm: Ensure correct alignment of the fixmap
2014-06-04fs/binfmt_elf.c: fix bool assignementsFabian Frederick
Fix coccinelle warnings. Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-05-20mm, fs: Add vm_ops->name as an alternative to arch_vma_nameAndy Lutomirski
arch_vma_name sucks. It's a silly hack, and it's annoying to implement correctly. In fact, AFAICS, even the straightforward x86 implementation is incorrect (I suspect that it breaks if the vdso mapping is split or gets remapped). This adds a new vm_ops->name operation that can replace it. The followup patches will remove all uses of arch_vma_name on x86, fixing a couple of annoyances in the process. Signed-off-by: Andy Lutomirski <luto@amacapital.net> Link: http://lkml.kernel.org/r/2eee21791bb36a0a408c5c2bdb382a9e6a41ca4a.1400538962.git.luto@amacapital.net Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2014-04-07exec: kill the unnecessary mm->def_flags setting in load_elf_binary()Alex Thorlton
load_elf_binary() sets current->mm->def_flags = def_flags and def_flags is always zero. Not only this looks strange, this is unnecessary because mm_init() has already set ->def_flags = 0. Signed-off-by: Alex Thorlton <athorlton@sgi.com> Suggested-by: Oleg Nesterov <oleg@redhat.com> Cc: Gerald Schaefer <gerald.schaefer@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Christian Borntraeger <borntraeger@de.ibm.com> Cc: Paolo Bonzini <pbonzini@redhat.com> Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com> Cc: Mel Gorman <mgorman@suse.de> Acked-by: Rik van Riel <riel@redhat.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: David Rientjes <rientjes@google.com> Cc: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-03fs, kernel: permit disabling the uselib syscallJosh Triplett
uselib hasn't been used since libc5; glibc does not use it. Support turning it off. When disabled, also omit the load_elf_library implementation from binfmt_elf.c, which only uselib invokes. bloat-o-meter: add/remove: 0/4 grow/shrink: 0/1 up/down: 0/-785 (-785) function old new delta padzero 39 36 -3 uselib_flags 20 - -20 sys_uselib 168 - -168 SyS_uselib 168 - -168 load_elf_library 426 - -426 The new CONFIG_USELIB defaults to `y'. Signed-off-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23fs: binfmt_elf: remove unused defines INTERPRETER_NONE and INTERPRETER_ELFTodor Minchev
These two defines are unused since the removal of the a.out interpreter support in the ELF loader in kernel 2.6.25 Signed-off-by: Todor Minchev <todor@minchev.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-09elf{,_fdpic} coredump: get rid of pointless if (siginfo->si_signo)Al Viro
we can't get to do_coredump() if that condition isn't satisfied... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-11-09constify do_coredump() argumentAl Viro
2013-11-09constify copy_siginfo_to_user{,32}()Al Viro
2013-11-09new helper: dump_align()Al Viro
dump_skip to given alignment... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-11-09dump_skip(): dump_seek() replacement taking coredump_paramsAl Viro
2013-11-09binfmt_elf: count notes towards coredump limitAl Viro
2013-11-09switch elf_coredump_extra_notes_write() to dump_emit()Al Viro
2013-11-09binfmt_elf: convert writing actual dump pages to dump_emit()Al Viro
2013-11-09switch elf_core_write_extra_data() to dump_emit()Al Viro
2013-11-09switch elf_core_write_extra_phdrs() to dump_emit()Al Viro
2013-11-09new helper: dump_emit()Al Viro
dump_write() analog, takes core_dump_params instead of file, keeps track of the amount written in cprm->written and checks for cprm->limit. Start using it in binfmt_elf.c... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-10-24file->f_op is never NULL...Al Viro
2013-09-30fs/binfmt_elf.c: prevent a coredump with a large vm_map_count from OopsingDan Aloni
A high setting of max_map_count, and a process core-dumping with a large enough vm_map_count could result in an NT_FILE note not being written, and the kernel crashing immediately later because it has assumed otherwise. Reproduction of the oops-causing bug described here: https://lkml.org/lkml/2013/8/30/50 Rge ussue originated in commit 2aa362c49c31 ("coredump: extend core dump note section to contain file names of mapped file") from Oct 4, 2012. This patch make that section optional in that case. fill_files_note() should signify the error, and also let the info struct in elf_core_dump() be zero-initialized so that we can check for the optionally written note. [akpm@linux-foundation.org: avoid abusing E2BIG, remove a couple of not-really-needed local variables] [akpm@linux-foundation.org: fix sparse warning] Signed-off-by: Dan Aloni <alonid@stratoscale.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Denys Vlasenko <vda.linux@googlemail.com> Reported-by: Martin MOKREJS <mmokrejs@gmail.com> Tested-by: Martin MOKREJS <mmokrejs@gmail.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-10mm: remove free_area_cacheMichel Lespinasse
Since all architectures have been converted to use vm_unmapped_area(), there is no remaining use for the free_area_cache. Signed-off-by: Michel Lespinasse <walken@google.com> Acked-by: Rik van Riel <riel@redhat.com> Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Howells <dhowells@redhat.com> Cc: Helge Deller <deller@gmx.de> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Matt Turner <mattst88@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Richard Henderson <rth@twiddle.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-02Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc Pull powerpc update from Benjamin Herrenschmidt: "The main highlights this time around are: - A pile of addition POWER8 bits and nits, such as updated performance counter support (Michael Ellerman), new branch history buffer support (Anshuman Khandual), base support for the new PCI host bridge when not using the hypervisor (Gavin Shan) and other random related bits and fixes from various contributors. - Some rework of our page table format by Aneesh Kumar which fixes a thing or two and paves the way for THP support. THP itself will not make it this time around however. - More Freescale updates, including Altivec support on the new e6500 cores, new PCI controller support, and a pile of new boards support and updates. - The usual batch of trivial cleanups & fixes" * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (156 commits) powerpc: Fix build error for book3e powerpc: Context switch the new EBB SPRs powerpc: Turn on the EBB H/FSCR bits powerpc: Replace CPU_FTR_BCTAR with CPU_FTR_ARCH_207S powerpc: Setup BHRB instructions facility in HFSCR for POWER8 powerpc: Fix interrupt range check on debug exception powerpc: Update tlbie/tlbiel as per ISA doc powerpc: Print page size info during boot powerpc: print both base and actual page size on hash failure powerpc: Fix hpte_decode to use the correct decoding for page sizes powerpc: Decode the pte-lp-encoding bits correctly. powerpc: Use encode avpn where we need only avpn values powerpc: Reduce PTE table memory wastage powerpc: Move the pte free routines from common header powerpc: Reduce the PTE_INDEX_SIZE powerpc: Switch 16GB and 16MB explicit hugepages to a different page table format powerpc: New hugepage directory format powerpc: Don't truncate pgd_index wrongly powerpc: Don't hard code the size of pte page powerpc: Save DAR and DSISR in pt_regs on MCE ...
2013-04-30coredump: factor out the setting of PF_DUMPCOREOleg Nesterov
Cleanup. Every linux_binfmt->core_dump() sets PF_DUMPCORE, move this into zap_threads() called by do_coredump(). Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Mandeep Singh Baines <msb@chromium.org> Cc: Neil Horman <nhorman@redhat.com> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30binfmt_elf: PIE: make PF_RANDOMIZE check comment more accurateJiri Kosina
The comment I originally added in commit a3defbe5c337 ("binfmt_elf: fix PIE execution with randomization disabled") is not really 100% accurate -- sysctl is not the only way how PF_RANDOMIZE could be forcibly unset in runtime. Another option of course is direct modification of personality flags (i.e. running through setarch wrapper). Make the comment more explicit and accurate. Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-26powerpc: Add HWCAP2 aux entryMichael Neuling
We are currently out of free bits in AT_HWCAP. With POWER8, we have several hardware features that we need to advertise. Tested on POWER and x86. Signed-off-by: Michael Neuling <michael@neuling.org> Signed-off-by: Nishanth Aravamudan <nacc@linux.vnet.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-04-17fs/binfmt_elf.c: fix hugetlb memory check in vma_dump_size()Naoya Horiguchi
Documentation/filesystems/proc.txt says about coredump_filter bitmask, Note bit 0-4 doesn't effect any hugetlb memory. hugetlb memory are only effected by bit 5-6. However current code can go into the subsequent flag checks of bit 0-4 for vma(VM_HUGETLB). So this patch inserts 'return' and makes it work as written in the document. Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Reviewed-by: Rik van Riel <riel@redhat.com> Acked-by: Michal Hocko <mhocko@suse.cz> Reviewed-by: HATAYAMA Daisuke <d.hatayama@jp.fujitsu.com> Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: David Rientjes <rientjes@google.com> Cc: <stable@vger.kernel.org> [3.7+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-03-03Merge tag 'metag-v3.9-rc1-v4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jhogan/metag Pull new ImgTec Meta architecture from James Hogan: "This adds core architecture support for Imagination's Meta processor cores, followed by some later miscellaneous arch/metag cleanups and fixes which I kept separate to ease review: - Support for basic Meta 1 (ATP) and Meta 2 (HTP) core architecture - A few fixes all over, particularly for symbol prefixes - A few privilege protection fixes - Several cleanups (setup.c includes, split out a lot of metag_ksyms.c) - Fix some missing exports - Convert hugetlb to use vm_unmapped_area() - Copy device tree to non-init memory - Provide dma_get_sgtable()" * tag 'metag-v3.9-rc1-v4' of git://git.kernel.org/pub/scm/linux/kernel/git/jhogan/metag: (61 commits) metag: Provide dma_get_sgtable() metag: prom.h: remove declaration of metag_dt_memblock_reserve() metag: copy devicetree to non-init memory metag: cleanup metag_ksyms.c includes metag: move mm/init.c exports out of metag_ksyms.c metag: move usercopy.c exports out of metag_ksyms.c metag: move setup.c exports out of metag_ksyms.c metag: move kick.c exports out of metag_ksyms.c metag: move traps.c exports out of metag_ksyms.c metag: move irq enable out of irqflags.h on SMP genksyms: fix metag symbol prefix on crc symbols metag: hugetlb: convert to vm_unmapped_area() metag: export clear_page and copy_page metag: export metag_code_cache_flush_all metag: protect more non-MMU memory regions metag: make TXPRIVEXT bits explicit metag: kernel/setup.c: sort includes perf: Enable building perf tools for Meta metag: add boot time LNKGET/LNKSET check metag: add __init to metag_cache_probe() ...
2013-03-02Revert some of "binfmt_elf: cleanups"James Hogan
The commit "binfmt_elf: cleanups" (f670d0ecda73b7438eec9ed108680bc5f5362ad8) removed an ifndef elf_map but this breaks compilation for metag which does define elf_map. This adds the ifndef back in as it was before, but does not affect the other cleanups made by that patch. Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: linux-fsdevel@vger.kernel.org Acked-by: Mikael Pettersson <mikpe@it.uu.se>
2013-02-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs pile (part one) from Al Viro: "Assorted stuff - cleaning namei.c up a bit, fixing ->d_name/->d_parent locking violations, etc. The most visible changes here are death of FS_REVAL_DOT (replaced with "has ->d_weak_revalidate()") and a new helper getting from struct file to inode. Some bits of preparation to xattr method interface changes. Misc patches by various people sent this cycle *and* ocfs2 fixes from several cycles ago that should've been upstream right then. PS: the next vfs pile will be xattr stuff." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (46 commits) saner proc_get_inode() calling conventions proc: avoid extra pde_put() in proc_fill_super() fs: change return values from -EACCES to -EPERM fs/exec.c: make bprm_mm_init() static ocfs2/dlm: use GFP_ATOMIC inside a spin_lock ocfs2: fix possible use-after-free with AIO ocfs2: Fix oops in ocfs2_fast_symlink_readpage() code path get_empty_filp()/alloc_file() leave both ->f_pos and ->f_version zero target: writev() on single-element vector is pointless export kernel_write(), convert open-coded instances fs: encode_fh: return FILEID_INVALID if invalid fid_type kill f_vfsmnt vfs: kill FS_REVAL_DOT by adding a d_weak_revalidate dentry op nfsd: handle vfs_getattr errors in acl protocol switch vfs_getattr() to struct path default SET_PERSONALITY() in linux/elf.h ceph: prepopulate inodes only when request is aborted d_hash_and_lookup(): export, switch open-coded instances 9p: switch v9fs_set_create_acl() to inode+fid, do it before d_instantiate() 9p: split dropping the acls from v9fs_set_create_acl() ...
2013-02-22new helper: file_inode(file)Al Viro
2013-02-21binfmt_elf: remove unused argument in fill_elf_headerZhang Yanfei
In fill_elf_header(), elf->e_ident[EI_OSABI] is always set to ELF_OSABI, so remove the unused argument 'osabi'. Signed-off-by: Zhang Yanfei <zhangyanfei@cn.fujitsu.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-01-27cputime: Use accessors to read task cputime statsFrederic Weisbecker
This is in preparation for the full dynticks feature. While remotely reading the cputime of a task running in a full dynticks CPU, we'll need to do some extra-computation. This way we can account the time it spent tickless in userspace since its last cputime snapshot. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Li Zhong <zhong@linux.vnet.ibm.com> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Thomas Gleixner <tglx@linutronix.de>
2012-12-17binfmt_elf: fix corner case kfree of uninitialized dataAlan Cox
If elf_core_dump() is called and fill_note_info() fails in the kmalloc() then it returns 0 but has not yet initialised all the needed fields. As a result we do a kfree(randomness) after correctly skipping the thread data. [akpm@linux-foundation.org: checkpatch fixes] Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-11-28get rid of pt_regs argument of ->load_binary()Al Viro
2012-10-10Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal Pull generic execve() changes from Al Viro: "This introduces the generic kernel_thread() and kernel_execve() functions, and switches x86, arm, alpha, um and s390 over to them." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: (26 commits) s390: convert to generic kernel_execve() s390: switch to generic kernel_thread() s390: fold kernel_thread_helper() into ret_from_fork() s390: fold execve_tail() into start_thread(), convert to generic sys_execve() um: switch to generic kernel_thread() x86, um/x86: switch to generic sys_execve and kernel_execve x86: split ret_from_fork alpha: introduce ret_from_kernel_execve(), switch to generic kernel_execve() alpha: switch to generic kernel_thread() alpha: switch to generic sys_execve() arm: get rid of execve wrapper, switch to generic execve() implementation arm: optimized current_pt_regs() arm: introduce ret_from_kernel_execve(), switch to generic kernel_execve() arm: split ret_from_fork, simplify kernel_thread() [based on patch by rmk] generic sys_execve() generic kernel_execve() new helper: current_pt_regs() preparation for generic kernel_thread() um: kill thread->forking um: let signal_delivered() do SIGTRAP on singlestepping into handler ...
2012-10-09mm: kill vma flag VM_RESERVED and mm->reserved_vm counterKonstantin Khlebnikov
A long time ago, in v2.4, VM_RESERVED kept swapout process off VMA, currently it lost original meaning but still has some effects: | effect | alternative flags -+------------------------+--------------------------------------------- 1| account as reserved_vm | VM_IO 2| skip in core dump | VM_IO, VM_DONTDUMP 3| do not merge or expand | VM_IO, VM_DONTEXPAND, VM_HUGETLB, VM_PFNMAP 4| do not mlock | VM_IO, VM_DONTEXPAND, VM_HUGETLB, VM_PFNMAP This patch removes reserved_vm counter from mm_struct. Seems like nobody cares about it, it does not exported into userspace directly, it only reduces total_vm showed in proc. Thus VM_RESERVED can be replaced with VM_IO or pair VM_DONTEXPAND | VM_DONTDUMP. remap_pfn_range() and io_remap_pfn_range() set VM_IO|VM_DONTEXPAND|VM_DONTDUMP. remap_vmalloc_range() set VM_DONTEXPAND | VM_DONTDUMP. [akpm@linux-foundation.org: drivers/vfio/pci/vfio_pci.c fixup] Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Carsten Otte <cotte@de.ibm.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Eric Paris <eparis@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Hugh Dickins <hughd@google.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: James Morris <james.l.morris@oracle.com> Cc: Jason Baron <jbaron@redhat.com> Cc: Kentaro Takeda <takedakn@nttdata.co.jp> Cc: Matt Helsley <matthltc@us.ibm.com> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Robert Richter <robert.richter@amd.com> Cc: Suresh Siddha <suresh.b.siddha@intel.com> Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Cc: Venkatesh Pallipadi <venki@google.com> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09mm: prepare VM_DONTDUMP for using in driversKonstantin Khlebnikov
Rename VM_NODUMP into VM_DONTDUMP: this name matches other negative flags: VM_DONTEXPAND, VM_DONTCOPY. Currently this flag used only for sys_madvise. The next patch will use it for replacing the outdated flag VM_RESERVED. Also forbid madvise(MADV_DODUMP) for special kernel mappings VM_SPECIAL (VM_IO | VM_DONTEXPAND | VM_RESERVED | VM_PFNMAP) Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Carsten Otte <cotte@de.ibm.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Eric Paris <eparis@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Hugh Dickins <hughd@google.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: James Morris <james.l.morris@oracle.com> Cc: Jason Baron <jbaron@redhat.com> Cc: Kentaro Takeda <takedakn@nttdata.co.jp> Cc: Matt Helsley <matthltc@us.ibm.com> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Robert Richter <robert.richter@amd.com> Cc: Suresh Siddha <suresh.b.siddha@intel.com> Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Cc: Venkatesh Pallipadi <venki@google.com> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-06coredump: extend core dump note section to contain file names of mapped filesDenys Vlasenko
This note has the following format: long count -- how many files are mapped long page_size -- units for file_ofs array of [COUNT] elements of long start long end long file_ofs followed by COUNT filenames in ASCII: "FILE1" NUL "FILE2" NUL... Signed-off-by: Denys Vlasenko <vda.linux@googlemail.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Amerigo Wang <amwang@redhat.com> Cc: "Jonathan M. Foote" <jmfoote@cert.org> Cc: Roland McGrath <roland@hack.frob.com> Cc: Pedro Alves <palves@redhat.com> Cc: Fengguang Wu <fengguang.wu@intel.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-06coredump: add a new elf note with siginfo of the signalDenys Vlasenko
Existing PRSTATUS note contains only si_signo, si_code, si_errno fields from the siginfo of the signal which caused core to be dumped. There are tools which try to analyze crashes for possible security implications, and they want to use, among other data, si_addr field from the SIGSEGV. This patch adds a new elf note, NT_SIGINFO, which contains the complete siginfo_t of the signal which killed the process. Signed-off-by: Denys Vlasenko <vda.linux@googlemail.com> Reviewed-by: Oleg Nesterov <oleg@redhat.com> Cc: Amerigo Wang <amwang@redhat.com> Cc: "Jonathan M. Foote" <jmfoote@cert.org> Cc: Roland McGrath <roland@hack.frob.com> Cc: Pedro Alves <palves@redhat.com> Cc: Fengguang Wu <fengguang.wu@intel.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-06coredump: pass siginfo_t* to do_coredump() and below, not merely signrDenys Vlasenko
This is a preparatory patch for the introduction of NT_SIGINFO elf note. With this patch we pass "siginfo_t *siginfo" instead of "int signr" to do_coredump() and put it into coredump_params. It will be used by the next patch. Most changes are simple s/signr/siginfo->si_signo/. Signed-off-by: Denys Vlasenko <vda.linux@googlemail.com> Reviewed-by: Oleg Nesterov <oleg@redhat.com> Cc: Amerigo Wang <amwang@redhat.com> Cc: "Jonathan M. Foote" <jmfoote@cert.org> Cc: Roland McGrath <roland@hack.frob.com> Cc: Pedro Alves <palves@redhat.com> Cc: Fengguang Wu <fengguang.wu@intel.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
