path: root/fs/binfmt_elf.c
2011-04-14brk: COMPAT_BRK: fix detection of randomized brkJiri Kosina
5520e89 ("brk: fix min_brk lower bound computation for COMPAT_BRK") tried to get the whole logic of brk randomization for legacy (libc5-based) applications finally right. It turns out that the way to detect whether brk has actually been randomized in the end or not introduced by that patch still doesn't work for those binaries, as reported by Geert: : /sbin/init from my old m68k ramdisk exists prematurely. : : Before the patch: : : | brk(0x80005c8e) = 0x80006000 : : After the patch: : : | brk(0x80005c8e) = 0x80005c8e : : Old libc5 considers brk() to have failed if the return value is not : identical to the requested value. I don't like it, but currently see no better option than a bit flag in task_struct to catch the CONFIG_COMPAT_BRK && randomize_va_space == 2 case. Signed-off-by: Jiri Kosina <jkosina@suse.cz> Tested-by: Geert Uytterhoeven <geert@linux-m68k.org> Reported-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: deal with races in /proc/*/{syscall,stack,personality} proc: enable writing to /proc/pid/mem proc: make check_mem_permission() return an mm_struct on success proc: hold cred_guard_mutex in check_mem_permission() proc: disable mem_write after exec mm: implement access_remote_vm mm: factor out main logic of access_process_vm mm: use mm_struct to resolve gate vma's in __get_user_pages mm: arch: rename in_gate_area_no_task to in_gate_area_no_mm mm: arch: make in_gate_area take an mm_struct instead of a task_struct mm: arch: make get_gate_vma take an mm_struct instead of a task_struct x86: mark associated mm when running a task in 32 bit compatibility mode x86: add context tag to mark mm when running a task in 32-bit compatibility mode auxv: require the target to be tracable (or yourself) close race in /proc/*/environ report errors in /proc/*/*map* sanely pagemap: close races with suid execve make sessionid permissions in /proc/*/task/* match those in /proc/* fix leaks in path_lookupat() Fix up trivial conflicts in fs/proc/base.c
2011-03-23mm: arch: make get_gate_vma take an mm_struct instead of a task_structStephen Wilson
Morally, the presence of a gate vma is more an attribute of a particular mm than a particular task. Moreover, dropping the dependency on task_struct will help make both existing and future operations on mm's more flexible and convenient. Signed-off-by: Stephen Wilson <wilsons@start.ca> Reviewed-by: Michel Lespinasse <walken@google.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-22binfmt_elf: quiet GCC-4.6 'set but not used' warning in load_elf_binary()David Daney
With GCC-4.6 we get warnings about things being 'set but not used'. In load_elf_binary() this can happen with reloc_func_desc if ELF_PLAT_INIT is defined, but doesn't use the reloc_func_desc argument. Quiet the warning/error by marking reloc_func_desc as __maybe_unused. Signed-off-by: David Daney <ddaney@caviumnetworks.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13binfmt_elf: cleanupsMikael Pettersson
This cleans up a few bits in binfmt_elf.c and binfmts.h: - the hasvdso field in struct linux_binfmt is unused, so remove it and the only initialization of it - the elf_map CPP symbol is not defined anywhere in the kernel, so remove an unnecessary #ifndef elf_map - reduce excessive indentation in elf_format's initializer - add missing spaces, remove extraneous spaces No functional changes, but tested on x86 (32 and 64 bit), powerpc (32 and 64 bit), sparc64, arm, and alpha. Signed-off-by: Mikael Pettersson <mikpe@it.uu.se> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-08ARM: 6342/1: fix ASLR of PIE executablesNicolas Pitre
Since commits 990cb8acf2 and cc92c28b2d, it is possible to have full address space layout randomization (ASLR) on ARM. Except that one small change was missing for ASLR of PIE executables. Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-03-06coredump: pass mm->flags as a coredump parameter for consistencyMasami Hiramatsu
Pass mm->flags as a coredump parameter for consistency. --- 1787 if (mm->core_state || !get_dumpable(mm)) { <- (1) 1788 up_write(&mm->mmap_sem); 1789 put_cred(cred); 1790 goto fail; 1791 } 1792 [...] 1798 if (get_dumpable(mm) == 2) { /* Setuid core dump mode */ <-(2) 1799 flag = O_EXCL; /* Stop rewrite attacks */ 1800 cred->fsuid = 0; /* Dump root private */ 1801 } --- Since dumpable bits are not protected by lock, there is a chance to change these bits between (1) and (2). To solve this issue, this patch copies mm->flags to coredump_params.mm_flags at the beginning of do_coredump() and uses it instead of get_dumpable() while dumping core. This copy is also passed to binfmt->core_dump, since elf*_core_dump() uses dump_filter bits in mm->flags. [akpm@linux-foundation.org: fix merge] Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Acked-by: Roland McGrath <roland@redhat.com> Cc: Hidehiro Kawai <hidehiro.kawai.ez@hitachi.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06elf coredump: add extended numbering supportDaisuke HATAYAMA
The current ELF dumper implementation can produce broken corefiles if program headers exceed 65535. This number is determined by the number of vmas which the process have. In particular, some extreme programs may use more than 65535 vmas. (If you google max_map_count, you can find some users facing this problem.) This kind of program never be able to generate correct coredumps. This patch implements ``extended numbering'' that uses sh_info field of the first section header instead of e_phnum field in order to represent upto 4294967295 vmas. This is supported by AMD64-ABI(http://www.x86-64.org/documentation.html) and Solaris(http://docs.sun.com/app/docs/doc/817-1984/). Of course, we are preparing patches for gdb and binutils. Signed-off-by: Daisuke HATAYAMA <d.hatayama@jp.fujitsu.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Jeff Dike <jdike@addtoit.com> Cc: David Howells <dhowells@redhat.com> Cc: Greg Ungerer <gerg@snapgear.com> Cc: Roland McGrath <roland@redhat.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Andi Kleen <andi@firstfloor.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06elf coredump: make offset calculation process and writing process explicitDaisuke HATAYAMA
By the next patch, elf_core_dump() and elf_fdpic_core_dump() will support extended numbering and so will produce the corefiles with section header table in a special case. The problem is the process of writing a file header offset of the section header table into e_shoff field of the ELF header. ELF header is positioned at the beginning of the corefile, while section header at the end. So, we need to take which of the following ways: 1. Seek backward to retry writing operation for ELF header after writing process for a whole part 2. Make offset calculation process and writing process totally sequential The clause 1. is not always possible: one cannot assume that file system supports seek function. Consider the no_llseek case. Therefore, this patch adopts the clause 2. Signed-off-by: Daisuke HATAYAMA <d.hatayama@jp.fujitsu.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Jeff Dike <jdike@addtoit.com> Cc: David Howells <dhowells@redhat.com> Cc: Greg Ungerer <gerg@snapgear.com> Cc: Roland McGrath <roland@redhat.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Andi Kleen <andi@firstfloor.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06elf coredump: replace ELF_CORE_EXTRA_* macros by functionsDaisuke HATAYAMA
elf_core_dump() and elf_fdpic_core_dump() use #ifdef and the corresponding macro for hiding _multiline_ logics in functions. This patch removes #ifdef and replaces ELF_CORE_EXTRA_* by corresponding functions. For architectures not implemeonting ELF_CORE_EXTRA_*, we use weak functions in order to reduce a range of modification. This cleanup is for my next patches, but I think this cleanup itself is worth doing regardless of my firnal purpose. Signed-off-by: Daisuke HATAYAMA <d.hatayama@jp.fujitsu.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Jeff Dike <jdike@addtoit.com> Cc: David Howells <dhowells@redhat.com> Cc: Greg Ungerer <gerg@snapgear.com> Cc: Roland McGrath <roland@redhat.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Andi Kleen <andi@firstfloor.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06coredump: move dump_write() and dump_seek() into a header fileDaisuke HATAYAMA
My next patch will replace ELF_CORE_EXTRA_* macros by functions, putting them into other newly created *.c files. Then, each files will contain dump_write(), where each pair of binfmt_*.c and elfcore.c should be the same. So, this patch moves them into a header file with dump_seek(). Also, the patch deletes confusing DUMP_WRITE macros in each files. Signed-off-by: Daisuke HATAYAMA <d.hatayama@jp.fujitsu.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Jeff Dike <jdike@addtoit.com> Cc: David Howells <dhowells@redhat.com> Cc: Greg Ungerer <gerg@snapgear.com> Cc: Roland McGrath <roland@redhat.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Andi Kleen <andi@firstfloor.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-01-29Split 'flush_old_exec' into two functionsLinus Torvalds
'flush_old_exec()' is the point of no return when doing an execve(), and it is pretty badly misnamed. It doesn't just flush the old executable environment, it also starts up the new one. Which is very inconvenient for things like setting up the new personality, because we want the new personality to affect the starting of the new environment, but at the same time we do _not_ want the new personality to take effect if flushing the old one fails. As a result, the x86-64 '32-bit' personality is actually done using this insane "I'm going to change the ABI, but I haven't done it yet" bit (TIF_ABI_PENDING), with SET_PERSONALITY() not actually setting the personality, but just the "pending" bit, so that "flush_thread()" can do the actual personality magic. This patch in no way changes any of that insanity, but it does split the 'flush_old_exec()' function up into a preparatory part that can fail (still called flush_old_exec()), and a new part that will actually set up the new exec environment (setup_new_exec()). All callers are changed to trivially comply with the new world order. Signed-off-by: H. Peter Anvin <hpa@zytor.com> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-17mm: introduce coredump parameter structureMasami Hiramatsu
Introduce coredump parameter data structure (struct coredump_params) to simplify binfmt->core_dump() arguments. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Suggested-by: Ingo Molnar <mingo@elte.hu> Cc: Hidehiro Kawai <hidehiro.kawai.ez@hitachi.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Roland McGrath <roland@redhat.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-16elf: kill USE_ELF_CORE_DUMPChristoph Hellwig
Currently all architectures but microblaze unconditionally define USE_ELF_CORE_DUMP. The microblaze omission seems like an error to me, so let's kill this ifdef and make sure we are the same everywhere. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: <linux-arch@vger.kernel.org> Cc: Michal Simek <michal.simek@petalogix.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-04tree-wide: fix assorted typos all over the placeAndré Goddard Rosa
That is "success", "unknown", "through", "performance", "[re|un]mapping" , "access", "default", "reasonable", "[con]currently", "temperature" , "channel", "[un]used", "application", "example","hierarchy", "therefore" , "[over|under]flow", "contiguous", "threshold", "enough" and others. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-09-24elf: clean up fill_note_info()Amerigo Wang
Introduce a helper function elf_note_info_init() to help fill_note_info() to do initializations, also fix the potential memory leaks. [akpm@linux-foundation.org: remove NUM_NOTES] Signed-off-by: WANG Cong <amwang@redhat.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: David Howells <dhowells@redhat.com> Cc: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22mm: add get_dump_pageHugh Dickins
In preparation for the next patch, add a simple get_dump_page(addr) interface for the CONFIG_ELF_CORE dumpers to use, instead of calling get_user_pages() directly. They're not interested in errors: they just want to use holes as much as possible, to save space and make sure that the data is aligned where the headers said it would be. Oh, and don't use that horrid DUMP_SEEK(off) macro! Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Acked-by: Rik van Riel <riel@redhat.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Nick Piggin <npiggin@suse.de> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Minchan Kim <minchan.kim@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-09binfmt_elf: fix PT_INTERP bss handlingRoland McGrath
In fs/binfmt_elf.c, load_elf_interp() calls padzero() for .bss even if the PT_LOAD has no PROT_WRITE and no .bss. This generates EFAULT. Here is a small test case. (Yes, there are other, useful PT_INTERP which have only .text and no .data/.bss.) ----- ptinterp.S _start: .globl _start nop int3 ----- $ gcc -m32 -nostartfiles -nostdlib -o ptinterp ptinterp.S $ gcc -m32 -Wl,--dynamic-linker=ptinterp -o hello hello.c $ ./hello Segmentation fault # during execve() itself After applying the patch: $ ./hello Trace trap # user-mode execution after execve() finishes If the ELF headers are actually self-inconsistent, then dying is fine. But having no PROT_WRITE segment is perfectly normal and correct if there is no segment with p_memsz > p_filesz (i.e. bss). John Reiser suggested checking for PROT_WRITE in the bss logic. I think it makes most sense to simply apply the bss logic only when there is bss. This patch looks less trivial than it is due to some reindentation. It just moves the "if (last_bss > elf_bss) {" test up to include the partial-page bss logic as well as the more-pages bss logic. Reported-by: John Reiser <jreiser@bitwagon.com> Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-01elf: fix one check-after-useAmerigo Wang
Check before use it. Signed-off-by: WANG Cong <amwang@redhat.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: David Howells <dhowells@redhat.com> Acked-by: Roland McGrath <roland@redhat.com> Acked-by: James Morris <jmorris@namei.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-30elf: limit max map count to safe valueKAMEZAWA Hiroyuki
With ELF, at generating coredump, some more headers other than used vmas are added. When max_map_count == 65536, a core generated by following kinds of code can be unreadable because the number of ELF's program header is written in 16bit in Ehdr (please see elf.h) and the number overflows. == ... = mmap(); (munmap, mprotect, etc...) if (failed) abort(); == This can happen in mmap/munmap/mprotect/etc...which calls split_vma(). I think 65536 is not safe as _default_ and reduce it to 65530 is good for avoiding unexpected corrupted core. Anyway, max_map_count can be enlarged by sysctl if a user is brave.. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Jakub Jelinek <jakub@redhat.com> Acked-by: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-18elf_core_dump: use rcu_read_lock() to access ->real_parentOleg Nesterov
In theory it is not safe to dereference ->parent/real_parent without tasklist or rcu lock, we can race with re-parenting. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Roland McGrath <roland@redhat.com> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-31Trim includes in binfmt_elfAl Viro
2009-03-31Don't mess with descriptor table in load_elf_binary()Al Viro
... since we don't tell anyone which descriptor does the file get. We used to, but only in case of ELF binary with a.out loader and that stuff has been gone for a while. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-02-06elf core dump: fix get_user useRoland McGrath
The elf_core_dump() code does its work with set_fs(KERNEL_DS) in force, so vma_dump_size() needs to switch back with set_fs(USER_DS) to safely use get_user() for a normal user-space address. Checking for VM_READ optimizes out the case where get_user() would fail anyway. The vm_file check here was already superfluous given the control flow earlier in the function, so that is a cleanup/optimization unrelated to other changes but an obvious and trivial one. Reported-by: Gerald Schaefer <gerald.schaefer@de.ibm.com> Signed-off-by: Roland McGrath <roland@redhat.com>
2009-01-08ELF: implement AT_RANDOM for glibc PRNG seedingKees Cook
While discussing[1] the need for glibc to have access to random bytes during program load, it seems that an earlier attempt to implement AT_RANDOM got stalled. This implements a random 16 byte string, available to every ELF program via a new auxv AT_RANDOM vector. [1] http://sourceware.org/ml/libc-alpha/2008-10/msg00006.html Ulrich said: glibc needs right after startup a bit of random data for internal protections (stack canary etc). What is now in upstream glibc is that we always unconditionally open /dev/urandom, read some data, and use it. For every process startup. That's slow. ... The solution is to provide a limited amount of random data to the starting process in the aux vector. I suggested 16 bytes and this is what the patch implements. If we need only 16 bytes or less we use the data directly. If we need more we'll use the 16 bytes to see a PRNG. This avoids the costly /dev/urandom use and it allows the kernel to use the most adequate source of random data for this purpose. It might not be the same pool as that for /dev/urandom. Concerns were expressed about the depletion of the randomness pool. But this patch doesn't make the situation worse, it doesn't deplete entropy more than happens now. Signed-off-by: Kees Cook <kees.cook@canonical.com> Cc: Jakub Jelinek <jakub@redhat.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Ulrich Drepper <drepper@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-12-28Merge branch 'for-linus' of git://git390.osdl.marist.edu/pub/scm/linux-2.6Linus Torvalds
* 'for-linus' of git://git390.osdl.marist.edu/pub/scm/linux-2.6: (85 commits) [S390] provide documentation for hvc_iucv kernel parameter. [S390] convert ctcm printks to dev_xxx and pr_xxx macros. [S390] convert zfcp printks to pr_xxx macros. [S390] convert vmlogrdr printks to pr_xxx macros. [S390] convert zfcp dumper printks to pr_xxx macros. [S390] convert cpu related printks to pr_xxx macros. [S390] convert qeth printks to dev_xxx and pr_xxx macros. [S390] convert sclp printks to pr_xxx macros. [S390] convert iucv printks to dev_xxx and pr_xxx macros. [S390] convert ap_bus printks to pr_xxx macros. [S390] convert dcssblk and extmem printks messages to pr_xxx macros. [S390] convert monwriter printks to pr_xxx macros. [S390] convert s390 debug feature printks to pr_xxx macros. [S390] convert monreader printks to pr_xxx macros. [S390] convert appldata printks to pr_xxx macros. [S390] convert setup printks to pr_xxx macros. [S390] convert hypfs printks to pr_xxx macros. [S390] convert time printks to pr_xxx macros. [S390] convert cpacf printks to pr_xxx macros. [S390] convert cio printks to pr_xxx macros. ...
2008-12-25[S390] arch_setup_additional_pages argumentsMartin Schwidefsky
arch_setup_additional_pages currently gets two arguments, the binary format descripton and an indication if the process uses an executable stack or not. The second argument is not used by anybody, it could be removed without replacement. What actually does make sense is to pass an indication if the process uses the elf interpreter or not. The glibc code will not use anything from the vdso if the process does not use the dynamic linker, so for statically linked binaries the architecture backend can choose not to map the vdso. Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-11-14CRED: Make execve() take advantage of copy-on-write credentialsDavid Howells
Make execve() take advantage of copy-on-write credentials, allowing it to set up the credentials in advance, and then commit the whole lot after the point of no return. This patch and the preceding patches have been tested with the LTP SELinux testsuite. This patch makes several logical sets of alteration: (1) execve(). The credential bits from struct linux_binprm are, for the most part, replaced with a single credentials pointer (bprm->cred). This means that all the creds can be calculated in advance and then applied at the point of no return with no possibility of failure. I would like to replace bprm->cap_effective with: cap_isclear(bprm->cap_effective) but this seems impossible due to special behaviour for processes of pid 1 (they always retain their parent's capability masks where normally they'd be changed - see cap_bprm_set_creds()). The following sequence of events now happens: (a) At the start of do_execve, the current task's cred_exec_mutex is locked to prevent PTRACE_ATTACH from obsoleting the calculation of creds that we make. (a) prepare_exec_creds() is then called to make a copy of the current task's credentials and prepare it. This copy is then assigned to bprm->cred. This renders security_bprm_alloc() and security_bprm_free() unnecessary, and so they've been removed. (b) The determination of unsafe execution is now performed immediately after (a) rather than later on in the code. The result is stored in bprm->unsafe for future reference. (c) prepare_binprm() is called, possibly multiple times. (i) This applies the result of set[ug]id binaries to the new creds attached to bprm->cred. Personality bit clearance is recorded, but now deferred on the basis that the exec procedure may yet fail. (ii) This then calls the new security_bprm_set_creds(). This should calculate the new LSM and capability credentials into *bprm->cred. This folds together security_bprm_set() and parts of security_bprm_apply_creds() (these two have been removed). Anything that might fail must be done at this point. (iii) bprm->cred_prepared is set to 1. bprm->cred_prepared is 0 on the first pass of the security calculations, and 1 on all subsequent passes. This allows SELinux in (ii) to base its calculations only on the initial script and not on the interpreter. (d) flush_old_exec() is called to commit the task to execution. This performs the following steps with regard to credentials: (i) Clear pdeath_signal and set dumpable on certain circumstances that may not be covered by commit_creds(). (ii) Clear any bits in current->personality that were deferred from (c.i). (e) install_exec_creds() [compute_creds() as was] is called to install the new credentials. This performs the following steps with regard to credentials: (i) Calls security_bprm_committing_creds() to apply any security requirements, such as flushing unauthorised files in SELinux, that must be done before the credentials are changed. This is made up of bits of security_bprm_apply_creds() and security_bprm_post_apply_creds(), both of which have been removed. This function is not allowed to fail; anything that might fail must have been done in (c.ii). (ii) Calls commit_creds() to apply the new credentials in a single assignment (more or less). Possibly pdeath_signal and dumpable should be part of struct creds. (iii) Unlocks the task's cred_replace_mutex, thus allowing PTRACE_ATTACH to take place. (iv) Clears The bprm->cred pointer as the credentials it was holding are now immutable. (v) Calls security_bprm_committed_creds() to apply any security alterations that must be done after the creds have been changed. SELinux uses this to flush signals and signal handlers. (f) If an error occurs before (d.i), bprm_free() will call abort_creds() to destroy the proposed new credentials and will then unlock cred_replace_mutex. No changes to the credentials will have been made. (2) LSM interface. A number of functions have been changed, added or removed: (*) security_bprm_alloc(), ->bprm_alloc_security() (*) security_bprm_free(), ->bprm_free_security() Removed in favour of preparing new credentials and modifying those. (*) security_bprm_apply_creds(), ->bprm_apply_creds() (*) security_bprm_post_apply_creds(), ->bprm_post_apply_creds() Removed; split between security_bprm_set_creds(), security_bprm_committing_creds() and security_bprm_committed_creds(). (*) security_bprm_set(), ->bprm_set_security() Removed; folded into security_bprm_set_creds(). (*) security_bprm_set_creds(), ->bprm_set_creds() New. The new credentials in bprm->creds should be checked and set up as appropriate. bprm->cred_prepared is 0 on the first call, 1 on the second and subsequent calls. (*) security_bprm_committing_creds(), ->bprm_committing_creds() (*) security_bprm_committed_creds(), ->bprm_committed_creds() New. Apply the security effects of the new credentials. This includes closing unauthorised files in SELinux. This function may not fail. When the former is called, the creds haven't yet been applied to the process; when the latter is called, they have. The former may access bprm->cred, the latter may not. (3) SELinux. SELinux has a number of changes, in addition to those to support the LSM interface changes mentioned above: (a) The bprm_security_struct struct has been removed in favour of using the credentials-under-construction approach. (c) flush_unauthorized_files() now takes a cred pointer and passes it on to inode_has_perm(), file_has_perm() and dentry_open(). Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-11-14CRED: Use RCU to access another task's creds and to release a task's own credsDavid Howells
Use RCU to access another task's creds and to release a task's own creds. This means that it will be possible for the credentials of a task to be replaced without another task (a) requiring a full lock to read them, and (b) seeing deallocated memory. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-11-14CRED: Wrap current->cred and a few other accessorsDavid Howells
Wrap current->cred and a few other accessors to hide their actual implementation. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-11-14CRED: Separate task security context from task_structDavid Howells
Separate the task security context from task_struct. At this point, the security data is temporarily embedded in the task_struct with two pointers pointing to it. Note that the Alpha arch is altered as it refers to (E)UID and (E)GID in entry.S via asm-offsets. With comment fixes Signed-off-by: Marc Dionne <marc.c.dionne@gmail.com> Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-10-20Merge branch 'v28-timers-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'v28-timers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (36 commits) fix documentation of sysrq-q really Fix documentation of sysrq-q timer_list: add base address to clock base timer_list: print cpu number of clockevents device timer_list: print real timer address NOHZ: restart tick device from irq_enter() NOHZ: split tick_nohz_restart_sched_tick() NOHZ: unify the nohz function calls in irq_enter() timers: fix itimer/many thread hang, fix timers: fix itimer/many thread hang, v3 ntp: improve adjtimex frequency rounding timekeeping: fix rounding problem during clock update ntp: let update_persistent_clock() sleep hrtimer: reorder struct hrtimer to save 8 bytes on 64bit builds posix-timers: lock_timer: make it readable posix-timers: lock_timer: kill the bogus ->it_id check posix-timers: kill ->it_sigev_signo and ->it_sigev_value posix-timers: sys_timer_create: cleanup the error handling posix-timers: move the initialization of timer->sigq from send to create path posix-timers: sys_timer_create: simplify and s/tasklist/rcu/ ... Fix trivial conflicts due to sysrq-q description clahes in Documentation/sysrq.txt and drivers/char/sysrq.c
2008-10-20coredump_filter: add hugepage dumpingKOSAKI Motohiro
Presently hugepage's vma has a VM_RESERVED flag in order not to be swapped. But a VM_RESERVED vma isn't core dumped because this flag is often used for some kernel vmas (e.g. vmalloc, sound related). Thus hugepages are never dumped and it can't be debugged easily. Many developers want hugepages to be included into core-dump. However, We can't read generic VM_RESERVED area because this area is often IO mapping area. then these area reading may change device state. it is definitly undesiable side-effect. So adding a hugepage specific bit to the coredump filter is better. It will be able to hugepage core dumping and doesn't cause any side-effect to any i/o devices. In additional, libhugetlb use hugetlb private mapping pages as anonymous page. Then, hugepage private mapping pages should be core dumped by default. Then, /proc/[pid]/core_dump_filter has two new bits. - bit 5 mean hugetlb private mapping pages are dumped or not. (default: yes) - bit 6 mean hugetlb shared mapping pages are dumped or not. (default: no) I tested by following method. % ulimit -c unlimited % ./crash_hugepage 50 % ./crash_hugepage 50 -p % ls -lh % gdb ./crash_hugepage core % % echo 0x43 > /proc/self/coredump_filter % ./crash_hugepage 50 % ./crash_hugepage 50 -p % ls -lh % gdb ./crash_hugepage core #include <stdlib.h> #include <stdio.h> #include <unistd.h> #include <sys/mman.h> #include <string.h> #include "hugetlbfs.h" int main(int argc, char** argv){ char* p; int ch; int mmap_flags = MAP_SHARED; int fd; int nr_pages; while((ch = getopt(argc, argv, "p")) != -1) { switch (ch) { case 'p': mmap_flags &= ~MAP_SHARED; mmap_flags |= MAP_PRIVATE; break; default: /* nothing*/ break; } } argc -= optind; argv += optind; if (argc == 0){ printf("need # of pages\n"); exit(1); } nr_pages = atoi(argv[0]); if (nr_pages < 2) { printf("nr_pages must >2\n"); exit(1); } fd = hugetlbfs_unlinked_fd(); p = mmap(NULL, nr_pages * gethugepagesize(), PROT_READ|PROT_WRITE, mmap_flags, fd, 0); sleep(2); *(p + gethugepagesize()) = 1; /* COW */ sleep(2); /* crash! */ *(int*)0 = 1; return 0; } Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reviewed-by: Kawai Hidehiro <hidehiro.kawai.ez@hitachi.com> Cc: Hugh Dickins <hugh@veritas.com> Cc: William Irwin <wli@holomorphy.com> Cc: Adam Litke <agl@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20Merge branches 'timers/clocksource', 'timers/hrtimers', 'timers/nohz', ↵Thomas Gleixner
'timers/ntp', 'timers/posixtimers' and 'timers/debug' into v28-timers-for-linus
2008-10-16[PATCH] remove unused ibcs2/PER_SVR4 in SET_PERSONALITYMartin Schwidefsky
The SET_PERSONALITY macro is always called with a second argument of 0. Remove the ibcs argument and the various tests to set the PER_SVR4 personality. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-09-14timers: fix itimer/many thread hangFrank Mayhar
Overview This patch reworks the handling of POSIX CPU timers, including the ITIMER_PROF, ITIMER_VIRT timers and rlimit handling. It was put together with the help of Roland McGrath, the owner and original writer of this code. The problem we ran into, and the reason for this rework, has to do with using a profiling timer in a process with a large number of threads. It appears that the performance of the old implementation of run_posix_cpu_timers() was at least O(n*3) (where "n" is the number of threads in a process) or worse. Everything is fine with an increasing number of threads until the time taken for that routine to run becomes the same as or greater than the tick time, at which point things degrade rather quickly. This patch fixes bug 9906, "Weird hang with NPTL and SIGPROF." Code Changes This rework corrects the implementation of run_posix_cpu_timers() to make it run in constant time for a particular machine. (Performance may vary between one machine and another depending upon whether the kernel is built as single- or multiprocessor and, in the latter case, depending upon the number of running processors.) To do this, at each tick we now update fields in signal_struct as well as task_struct. The run_posix_cpu_timers() function uses those fields to make its decisions. We define a new structure, "task_cputime," to contain user, system and scheduler times and use these in appropriate places: struct task_cputime { cputime_t utime; cputime_t stime; unsigned long long sum_exec_runtime; }; This is included in the structure "thread_group_cputime," which is a new substructure of signal_struct and which varies for uniprocessor versus multiprocessor kernels. For uniprocessor kernels, it uses "task_cputime" as a simple substructure, while for multiprocessor kernels it is a pointer: struct thread_group_cputime { struct task_cputime totals; }; struct thread_group_cputime { struct task_cputime *totals; }; We also add a new task_cputime substructure directly to signal_struct, to cache the earliest expiration of process-wide timers, and task_cputime also replaces the it_*_expires fields of task_struct (used for earliest expiration of thread timers). The "thread_group_cputime" structure contains process-wide timers that are updated via account_user_time() and friends. In the non-SMP case the structure is a simple aggregator; unfortunately in the SMP case that simplicity was not achievable due to cache-line contention between CPUs (in one measured case performance was actually _worse_ on a 16-cpu system than the same test on a 4-cpu system, due to this contention). For SMP, the thread_group_cputime counters are maintained as a per-cpu structure allocated using alloc_percpu(). The timer functions update only the timer field in the structure corresponding to the running CPU, obtained using per_cpu_ptr(). We define a set of inline functions in sched.h that we use to maintain the thread_group_cputime structure and hide the differences between UP and SMP implementations from the rest of the kernel. The thread_group_cputime_init() function initializes the thread_group_cputime structure for the given task. The thread_group_cputime_alloc() is a no-op for UP; for SMP it calls the out-of-line function thread_group_cputime_alloc_smp() to allocate and fill in the per-cpu structures and fields. The thread_group_cputime_free() function, also a no-op for UP, in SMP frees the per-cpu structures. The thread_group_cputime_clone_thread() function (also a UP no-op) for SMP calls thread_group_cputime_alloc() if the per-cpu structures haven't yet been allocated. The thread_group_cputime() function fills the task_cputime structure it is passed with the contents of the thread_group_cputime fields; in UP it's that simple but in SMP it must also safely check that tsk->signal is non-NULL (if it is it just uses the appropriate fields of task_struct) and, if so, sums the per-cpu values for each online CPU. Finally, the three functions account_group_user_time(), account_group_system_time() and account_group_exec_runtime() are used by timer functions to update the respective fields of the thread_group_cputime structure. Non-SMP operation is trivial and will not be mentioned further. The per-cpu structure is always allocated when a task creates its first new thread, via a call to thread_group_cputime_clone_thread() from copy_signal(). It is freed at process exit via a call to thread_group_cputime_free() from cleanup_signal(). All functions that formerly summed utime/stime/sum_sched_runtime values from from all threads in the thread group now use thread_group_cputime() to snapshot the values in the thread_group_cputime structure or the values in the task structure itself if the per-cpu structure hasn't been allocated. Finally, the code in kernel/posix-cpu-timers.c has changed quite a bit. The run_posix_cpu_timers() function has been split into a fast path and a slow path; the former safely checks whether there are any expired thread timers and, if not, just returns, while the slow path does the heavy lifting. With the dedicated thread group fields, timers are no longer "rebalanced" and the process_timer_rebalance() function and related code has gone away. All summing loops are gone and all code that used them now uses the thread_group_cputime() inline. When process-wide timers are set, the new task_cputime structure in signal_struct is used to cache the earliest expiration; this is checked in the fast path. Performance The fix appears not to add significant overhead to existing operations. It generally performs the same as the current code except in two cases, one in which it performs slightly worse (Case 5 below) and one in which it performs very significantly better (Case 2 below). Overall it's a wash except in those two cases. I've since done somewhat more involved testing on a dual-core Opteron system. Case 1: With no itimer running, for a test with 100,000 threads, the fixed kernel took 1428.5 seconds, 513 seconds more than the unfixed system, all of which was spent in the system. There were twice as many voluntary context switches with the fix as without it. Case 2: With an itimer running at .01 second ticks and 4000 threads (the most an unmodified kernel can handle), the fixed kernel ran the test in eight percent of the time (5.8 seconds as opposed to 70 seconds) and had better tick accuracy (.012 seconds per tick as opposed to .023 seconds per tick). Case 3: A 4000-thread test with an initial timer tick of .01 second and an interval of 10,000 seconds (i.e. a timer that ticks only once) had very nearly the same performance in both cases: 6.3 seconds elapsed for the fixed kernel versus 5.5 seconds for the unfixed kernel. With fewer threads (eight in these tests), the Case 1 test ran in essentially the same time on both the modified and unmodified kernels (5.2 seconds versus 5.8 seconds). The Case 2 test ran in about the same time as well, 5.9 seconds versus 5.4 seconds but again with much better tick accuracy, .013 seconds per tick versus .025 seconds per tick for the unmodified kernel. Since the fix affected the rlimit code, I also tested soft and hard CPU limits. Case 4: With a hard CPU limit of 20 seconds and eight threads (and an itimer running), the modified kernel was very slightly favored in that while it killed the process in 19.997 seconds of CPU time (5.002 seconds of wall time), only .003 seconds of that was system time, the rest was user time. The unmodified kernel killed the process in 20.001 seconds of CPU (5.014 seconds of wall time) of which .016 seconds was system time. Really, though, the results were too close to call. The results were essentially the same with no itimer running. Case 5: With a soft limit of 20 seconds and a hard limit of 2000 seconds (where the hard limit would never be reached) and an itimer running, the modified kernel exhibited worse tick accuracy than the unmodified kernel: .050 seconds/tick versus .028 seconds/tick. Otherwise, performance was almost indistinguishable. With no itimer running this test exhibited virtually identical behavior and times in both cases. In times past I did some limited performance testing. those results are below. On a four-cpu Opteron system without this fix, a sixteen-thread test executed in 3569.991 seconds, of which user was 3568.435s and system was 1.556s. On the same system with the fix, user and elapsed time were about the same, but system time dropped to 0.007 seconds. Performance with eight, four and one thread were comparable. Interestingly, the timer ticks with the fix seemed more accurate: The sixteen-thread test with the fix received 149543 ticks for 0.024 seconds per tick, while the same test without the fix received 58720 for 0.061 seconds per tick. Both cases were configured for an interval of 0.01 seconds. Again, the other tests were comparable. Each thread in this test computed the primes up to 25,000,000. I also did a test with a large number of threads, 100,000 threads, which is impossible without the fix. In this case each thread computed the primes only up to 10,000 (to make the runtime manageable). System time dominated, at 1546.968 seconds out of a total 2176.906 seconds (giving a user time of 629.938s). It received 147651 ticks for 0.015 seconds per tick, still quite accurate. There is obviously no comparable test without the fix. Signed-off-by: Frank Mayhar <fmayhar@google.com> Cc: Roland McGrath <roland@redhat.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-26tracehook: execRoland McGrath
This moves all the ptrace hooks related to exec into tracehook.h inlines. This also lifts the calls for tracing out of the binfmt load_binary hooks into search_binary_handler() after it calls into the binfmt module. This change has no effect, since all the binfmt modules' load_binary functions did the call at the end on success, and now search_binary_handler() does it immediately after return if successful. We consolidate the repeated code, and binfmt modules no longer need to import ptrace_notify(). Signed-off-by: Roland McGrath <roland@redhat.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Reviewed-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (34 commits) powerpc: Wireup new syscalls Move update_mmu_cache() declaration from tlbflush.h to pgtable.h powerpc/pseries: Remove kmalloc call in handling writes to lparcfg powerpc/pseries: Update arch vector to indicate support for CMO ibmvfc: Add support for collaborative memory overcommit ibmvscsi: driver enablement for CMO ibmveth: enable driver for CMO ibmveth: Automatically enable larger rx buffer pools for larger mtu powerpc/pseries: Verify CMO memory entitlement updates with virtual I/O powerpc/pseries: vio bus support for CMO powerpc/pseries: iommu enablement for CMO powerpc/pseries: Add CMO paging statistics powerpc/pseries: Add collaborative memory manager powerpc/pseries: Utilities to set firmware page state powerpc/pseries: Enable CMO feature during platform setup powerpc/pseries: Split retrieval of processor entitlement data into a helper routine powerpc/pseries: Add memory entitlement capabilities to /proc/ppc64/lparcfg powerpc/pseries: Split processor entitlement retrieval and gathering to helper routines powerpc/pseries: Remove extraneous error reporting for hcall failures in lparcfg powerpc: Fix compile error with binutils 2.15 ... Fixed up conflict in arch/powerpc/platforms/52xx/Kconfig manually.
2008-07-25coredump: elf_core_dump: use core_state->dumper listOleg Nesterov
Kill the nasty rcu_read_lock() + do_each_thread() loop, use the list encoded in mm->core_state instead, s/GFP_ATOMIC/GFP_KERNEL/. This patch allows futher cleanups in binfmt_elf.c, in particular we can kill the parallel info->threads list. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Acked-by: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25coredump: elf_core_dump: skip kernel threadsOleg Nesterov
linux_binfmt->core_dump() runs before the process does exit_aio(), this means that we can hit the kernel thread which shares the same ->mm. Afaics, nothing really bad can happen, but perhaps it makes sense to fix this minor bug. It is sad we have to iterate over all threads in system and use GFP_ATOMIC. Hopefully we can kill theses ugly do_each_thread()s, but this needs some nontrivial changes in mm_struct and do_coredump. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25ELF loader support for auxvec base platform stringNathan Lynch
Some IBM POWER-based platforms have the ability to run in a mode which mostly appears to the OS as a different processor from the actual hardware. For example, a Power6 system may appear to be a Power5+, which makes the AT_PLATFORM value "power5+". This means that programs are restricted to the ISA supported by Power5+; Power6-specific instructions are treated as illegal. However, some applications (virtual machines, optimized libraries) can benefit from knowledge of the underlying CPU model. A new aux vector entry, AT_BASE_PLATFORM, will denote the actual hardware. For example, on a Power6 system in Power5+ compatibility mode, AT_PLATFORM will be "power5+" and AT_BASE_PLATFORM will be "power6". The idea is that AT_PLATFORM indicates the instruction set supported, while AT_BASE_PLATFORM indicates the underlying microarchitecture. If the architecture has defined ELF_BASE_PLATFORM, copy that value to the user stack in the same manner as ELF_PLATFORM. Signed-off-by: Nathan Lynch <ntl@pobox.com> Acked-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2008-07-22execve filename: document and export via auxiliary vectorJohn Reiser
The Linux kernel puts the filename argument of execve() into the new address space. Many developers are surprised to learn this. Those who know and could use it, object "But it's not documented." Those who want to use it dislike the expression (char *)(1+ strlen(env[-1+ n_env]) + env[-1+ n_env]) because it requires locating the last original environment variable, and assumes that the filename follows the characters. This patch documents the insertion of the filename, and makes it easier to find by adding a new tag AT_EXECFN in the ElfXX_auxv_t; see <elf.h>. In many cases readlink("/proc/self/exe",) gives the same answer. But if all the original pages get unmapped, then the kernel erases the symlink for /proc/self/exe. This can happen when a program decompressor does a good job of cleaning up after uncompressing directly to memory, so that the address space of the target program looks the same as if compression had never happened. One example is http://upx.sourceforge.net . One notable use of the underlying concept (what path containED the executable) is glibc expanding $ORIGIN in DT_RUNPATH. In practice for the near term, it may be a good idea for user-mode code to use both /proc/self/exe and AT_EXECFN as fall-back methods for each other. /proc/self/exe can fail due to unmapping, AT_EXECFN can fail because it won't be present on non-new systems. The auxvec or {AT_EXECFN}.d_val also can get overwritten, although in nearly all cases this would be the result of a bug. The runtime cost is one NEW_AUX_ENT using two words of stack space. The underlying value is maintained already as bprm->exec; setup_arg_pages() in fs/exec.c slides it for stack_shift, etc. Signed-off-by: John Reiser <jreiser@BitWagon.com> Cc: Roland McGrath <roland@redhat.com> Cc: Jakub Jelinek <jakub@redhat.com> Cc: Ulrich Drepper <drepper@redhat.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-16Remove last traces of a.out support from ELF loader.David Woodhouse
In commit d20894a23708c2af75966534f8e4dedb46d48db2 ("Remove a.out interpreter support in ELF loader"), Andi removed support for a.out interpreters from the ELF loader, which was only ever needed for the transition from a.out to ELF. This removes the last traces of that support, in particular the inclusion of <linux/a.out.h>. Signed-off-by: David Woodhouse <dwmw2@infradead.org> Acked-by: Peter Korsgaard <jacmet@sunsite.dk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-16[Patch] fs/binfmt_elf.c: fix wrong return valuesWANG Cong
create_elf_tables() returns 0 on success. But when strnlen_user() "fails", it returns 0 directly. So this is wrong. Signed-off-by: WANG Cong <wangcong@zeuux.org> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-05-16[Patch] fs/binfmt_elf.c: fix a wrong freeWANG Cong
In kmalloc failing path, we shouldn't free pointers in 'info', because the struct 'info' is uninitilized when kmalloc is called. And when kmalloc returns NULL, it's needless to kfree it. Signed-off-by: WANG Cong <wangcong@zeuux.org> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Reviewed-by: Pekka Enberg <penberg@cs.helsinki.fi> -- Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-04-29elf: fix shadowed variables in fs/binfmt_elf.cWANG Cong
Fix these sparse warings: fs/binfmt_elf.c:1749:29: warning: symbol 'tmp' shadows an earlier one fs/binfmt_elf.c:1734:28: originally declared here fs/binfmt_elf.c:2009:26: warning: symbol 'vma' shadows an earlier one fs/binfmt_elf.c:1892:24: originally declared here [akpm@linux-foundation.org: chose better variable name] Signed-off-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29BINFMT: fill_elf_header cleanup - use straight memset firstCyrill Gorcunov
This patch does simplify fill_elf_header function by setting to zero the whole elf header first. So we fillup the fields we really need only. before: text data bss dec hex filename 11735 80 0 11815 2e27 fs/binfmt_elf.o after: text data bss dec hex filename 11710 80 0 11790 2e0e fs/binfmt_elf.o viola, 25 bytes of text is freed Signed-off-by: Cyrill Gorcunov <gorcunov@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-25[PATCH] sanitize handling of shared descriptor tables in failing execve()Al Viro
* unshare_files() can fail; doing it after irreversible actions is wrong and de_thread() is certainly irreversible. * since we do it unconditionally anyway, we might as well do it in do_execve() and save ourselves the PITA in binfmt handlers, etc. * while we are at it, binfmt_som actually leaked files_struct on failure. As a side benefit, unshare_files(), put_files_struct() and reset_files_struct() become unexported. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-03-04core dump: user_regset writebackRoland McGrath
This makes the user_regset-based core dump code call user_regset writeback hooks when available. This is necessary groundwork to allow IA64 to set CORE_DUMP_USE_REGSET. Cc: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Roland McGrath <roland@redhat.com> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08Remove a.out interpreter support in ELF loaderAndi Kleen
Following the deprecation schedule the a.out ELF interpreter support is removed now with this patch. a.out ELF interpreters were an transition feature for moving a.out systems to ELF, but they're unlikely to be still needed. Pure a.out systems will still work of course. This allows to simplify the hairy ELF loader. Signed-off-by: Andi Kleen <ak@suse.de> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
