path: root/fs/binfmt_elf.c
2013-10-13fs/binfmt_elf.c: prevent a coredump with a large vm_map_count from OopsingDan Aloni
commit 72023656961b8c81a168a7a6762d589339d0d7ec upstream. A high setting of max_map_count, and a process core-dumping with a large enough vm_map_count could result in an NT_FILE note not being written, and the kernel crashing immediately later because it has assumed otherwise. Reproduction of the oops-causing bug described here: https://lkml.org/lkml/2013/8/30/50 Rge ussue originated in commit 2aa362c49c31 ("coredump: extend core dump note section to contain file names of mapped file") from Oct 4, 2012. This patch make that section optional in that case. fill_files_note() should signify the error, and also let the info struct in elf_core_dump() be zero-initialized so that we can check for the optionally written note. [akpm@linux-foundation.org: avoid abusing E2BIG, remove a couple of not-really-needed local variables] [akpm@linux-foundation.org: fix sparse warning] Signed-off-by: Dan Aloni <alonid@stratoscale.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Denys Vlasenko <vda.linux@googlemail.com> Reported-by: Martin MOKREJS <mmokrejs@gmail.com> Tested-by: Martin MOKREJS <mmokrejs@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-02Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc Pull powerpc update from Benjamin Herrenschmidt: "The main highlights this time around are: - A pile of addition POWER8 bits and nits, such as updated performance counter support (Michael Ellerman), new branch history buffer support (Anshuman Khandual), base support for the new PCI host bridge when not using the hypervisor (Gavin Shan) and other random related bits and fixes from various contributors. - Some rework of our page table format by Aneesh Kumar which fixes a thing or two and paves the way for THP support. THP itself will not make it this time around however. - More Freescale updates, including Altivec support on the new e6500 cores, new PCI controller support, and a pile of new boards support and updates. - The usual batch of trivial cleanups & fixes" * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (156 commits) powerpc: Fix build error for book3e powerpc: Context switch the new EBB SPRs powerpc: Turn on the EBB H/FSCR bits powerpc: Replace CPU_FTR_BCTAR with CPU_FTR_ARCH_207S powerpc: Setup BHRB instructions facility in HFSCR for POWER8 powerpc: Fix interrupt range check on debug exception powerpc: Update tlbie/tlbiel as per ISA doc powerpc: Print page size info during boot powerpc: print both base and actual page size on hash failure powerpc: Fix hpte_decode to use the correct decoding for page sizes powerpc: Decode the pte-lp-encoding bits correctly. powerpc: Use encode avpn where we need only avpn values powerpc: Reduce PTE table memory wastage powerpc: Move the pte free routines from common header powerpc: Reduce the PTE_INDEX_SIZE powerpc: Switch 16GB and 16MB explicit hugepages to a different page table format powerpc: New hugepage directory format powerpc: Don't truncate pgd_index wrongly powerpc: Don't hard code the size of pte page powerpc: Save DAR and DSISR in pt_regs on MCE ...
2013-04-30coredump: factor out the setting of PF_DUMPCOREOleg Nesterov
Cleanup. Every linux_binfmt->core_dump() sets PF_DUMPCORE, move this into zap_threads() called by do_coredump(). Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Mandeep Singh Baines <msb@chromium.org> Cc: Neil Horman <nhorman@redhat.com> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30binfmt_elf: PIE: make PF_RANDOMIZE check comment more accurateJiri Kosina
The comment I originally added in commit a3defbe5c337 ("binfmt_elf: fix PIE execution with randomization disabled") is not really 100% accurate -- sysctl is not the only way how PF_RANDOMIZE could be forcibly unset in runtime. Another option of course is direct modification of personality flags (i.e. running through setarch wrapper). Make the comment more explicit and accurate. Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-26powerpc: Add HWCAP2 aux entryMichael Neuling
We are currently out of free bits in AT_HWCAP. With POWER8, we have several hardware features that we need to advertise. Tested on POWER and x86. Signed-off-by: Michael Neuling <michael@neuling.org> Signed-off-by: Nishanth Aravamudan <nacc@linux.vnet.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-04-17fs/binfmt_elf.c: fix hugetlb memory check in vma_dump_size()Naoya Horiguchi
Documentation/filesystems/proc.txt says about coredump_filter bitmask, Note bit 0-4 doesn't effect any hugetlb memory. hugetlb memory are only effected by bit 5-6. However current code can go into the subsequent flag checks of bit 0-4 for vma(VM_HUGETLB). So this patch inserts 'return' and makes it work as written in the document. Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Reviewed-by: Rik van Riel <riel@redhat.com> Acked-by: Michal Hocko <mhocko@suse.cz> Reviewed-by: HATAYAMA Daisuke <d.hatayama@jp.fujitsu.com> Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: David Rientjes <rientjes@google.com> Cc: <stable@vger.kernel.org> [3.7+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-03-03Merge tag 'metag-v3.9-rc1-v4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jhogan/metag Pull new ImgTec Meta architecture from James Hogan: "This adds core architecture support for Imagination's Meta processor cores, followed by some later miscellaneous arch/metag cleanups and fixes which I kept separate to ease review: - Support for basic Meta 1 (ATP) and Meta 2 (HTP) core architecture - A few fixes all over, particularly for symbol prefixes - A few privilege protection fixes - Several cleanups (setup.c includes, split out a lot of metag_ksyms.c) - Fix some missing exports - Convert hugetlb to use vm_unmapped_area() - Copy device tree to non-init memory - Provide dma_get_sgtable()" * tag 'metag-v3.9-rc1-v4' of git://git.kernel.org/pub/scm/linux/kernel/git/jhogan/metag: (61 commits) metag: Provide dma_get_sgtable() metag: prom.h: remove declaration of metag_dt_memblock_reserve() metag: copy devicetree to non-init memory metag: cleanup metag_ksyms.c includes metag: move mm/init.c exports out of metag_ksyms.c metag: move usercopy.c exports out of metag_ksyms.c metag: move setup.c exports out of metag_ksyms.c metag: move kick.c exports out of metag_ksyms.c metag: move traps.c exports out of metag_ksyms.c metag: move irq enable out of irqflags.h on SMP genksyms: fix metag symbol prefix on crc symbols metag: hugetlb: convert to vm_unmapped_area() metag: export clear_page and copy_page metag: export metag_code_cache_flush_all metag: protect more non-MMU memory regions metag: make TXPRIVEXT bits explicit metag: kernel/setup.c: sort includes perf: Enable building perf tools for Meta metag: add boot time LNKGET/LNKSET check metag: add __init to metag_cache_probe() ...
2013-03-02Revert some of "binfmt_elf: cleanups"James Hogan
The commit "binfmt_elf: cleanups" (f670d0ecda73b7438eec9ed108680bc5f5362ad8) removed an ifndef elf_map but this breaks compilation for metag which does define elf_map. This adds the ifndef back in as it was before, but does not affect the other cleanups made by that patch. Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: linux-fsdevel@vger.kernel.org Acked-by: Mikael Pettersson <mikpe@it.uu.se>
2013-02-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs pile (part one) from Al Viro: "Assorted stuff - cleaning namei.c up a bit, fixing ->d_name/->d_parent locking violations, etc. The most visible changes here are death of FS_REVAL_DOT (replaced with "has ->d_weak_revalidate()") and a new helper getting from struct file to inode. Some bits of preparation to xattr method interface changes. Misc patches by various people sent this cycle *and* ocfs2 fixes from several cycles ago that should've been upstream right then. PS: the next vfs pile will be xattr stuff." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (46 commits) saner proc_get_inode() calling conventions proc: avoid extra pde_put() in proc_fill_super() fs: change return values from -EACCES to -EPERM fs/exec.c: make bprm_mm_init() static ocfs2/dlm: use GFP_ATOMIC inside a spin_lock ocfs2: fix possible use-after-free with AIO ocfs2: Fix oops in ocfs2_fast_symlink_readpage() code path get_empty_filp()/alloc_file() leave both ->f_pos and ->f_version zero target: writev() on single-element vector is pointless export kernel_write(), convert open-coded instances fs: encode_fh: return FILEID_INVALID if invalid fid_type kill f_vfsmnt vfs: kill FS_REVAL_DOT by adding a d_weak_revalidate dentry op nfsd: handle vfs_getattr errors in acl protocol switch vfs_getattr() to struct path default SET_PERSONALITY() in linux/elf.h ceph: prepopulate inodes only when request is aborted d_hash_and_lookup(): export, switch open-coded instances 9p: switch v9fs_set_create_acl() to inode+fid, do it before d_instantiate() 9p: split dropping the acls from v9fs_set_create_acl() ...
2013-02-22new helper: file_inode(file)Al Viro
2013-02-21binfmt_elf: remove unused argument in fill_elf_headerZhang Yanfei
In fill_elf_header(), elf->e_ident[EI_OSABI] is always set to ELF_OSABI, so remove the unused argument 'osabi'. Signed-off-by: Zhang Yanfei <zhangyanfei@cn.fujitsu.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-01-27cputime: Use accessors to read task cputime statsFrederic Weisbecker
This is in preparation for the full dynticks feature. While remotely reading the cputime of a task running in a full dynticks CPU, we'll need to do some extra-computation. This way we can account the time it spent tickless in userspace since its last cputime snapshot. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Li Zhong <zhong@linux.vnet.ibm.com> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Thomas Gleixner <tglx@linutronix.de>
2012-12-17binfmt_elf: fix corner case kfree of uninitialized dataAlan Cox
If elf_core_dump() is called and fill_note_info() fails in the kmalloc() then it returns 0 but has not yet initialised all the needed fields. As a result we do a kfree(randomness) after correctly skipping the thread data. [akpm@linux-foundation.org: checkpatch fixes] Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-11-28get rid of pt_regs argument of ->load_binary()Al Viro
2012-10-10Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal Pull generic execve() changes from Al Viro: "This introduces the generic kernel_thread() and kernel_execve() functions, and switches x86, arm, alpha, um and s390 over to them." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: (26 commits) s390: convert to generic kernel_execve() s390: switch to generic kernel_thread() s390: fold kernel_thread_helper() into ret_from_fork() s390: fold execve_tail() into start_thread(), convert to generic sys_execve() um: switch to generic kernel_thread() x86, um/x86: switch to generic sys_execve and kernel_execve x86: split ret_from_fork alpha: introduce ret_from_kernel_execve(), switch to generic kernel_execve() alpha: switch to generic kernel_thread() alpha: switch to generic sys_execve() arm: get rid of execve wrapper, switch to generic execve() implementation arm: optimized current_pt_regs() arm: introduce ret_from_kernel_execve(), switch to generic kernel_execve() arm: split ret_from_fork, simplify kernel_thread() [based on patch by rmk] generic sys_execve() generic kernel_execve() new helper: current_pt_regs() preparation for generic kernel_thread() um: kill thread->forking um: let signal_delivered() do SIGTRAP on singlestepping into handler ...
2012-10-09mm: kill vma flag VM_RESERVED and mm->reserved_vm counterKonstantin Khlebnikov
A long time ago, in v2.4, VM_RESERVED kept swapout process off VMA, currently it lost original meaning but still has some effects: | effect | alternative flags -+------------------------+--------------------------------------------- 1| account as reserved_vm | VM_IO 2| skip in core dump | VM_IO, VM_DONTDUMP 3| do not merge or expand | VM_IO, VM_DONTEXPAND, VM_HUGETLB, VM_PFNMAP 4| do not mlock | VM_IO, VM_DONTEXPAND, VM_HUGETLB, VM_PFNMAP This patch removes reserved_vm counter from mm_struct. Seems like nobody cares about it, it does not exported into userspace directly, it only reduces total_vm showed in proc. Thus VM_RESERVED can be replaced with VM_IO or pair VM_DONTEXPAND | VM_DONTDUMP. remap_pfn_range() and io_remap_pfn_range() set VM_IO|VM_DONTEXPAND|VM_DONTDUMP. remap_vmalloc_range() set VM_DONTEXPAND | VM_DONTDUMP. [akpm@linux-foundation.org: drivers/vfio/pci/vfio_pci.c fixup] Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Carsten Otte <cotte@de.ibm.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Eric Paris <eparis@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Hugh Dickins <hughd@google.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: James Morris <james.l.morris@oracle.com> Cc: Jason Baron <jbaron@redhat.com> Cc: Kentaro Takeda <takedakn@nttdata.co.jp> Cc: Matt Helsley <matthltc@us.ibm.com> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Robert Richter <robert.richter@amd.com> Cc: Suresh Siddha <suresh.b.siddha@intel.com> Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Cc: Venkatesh Pallipadi <venki@google.com> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09mm: prepare VM_DONTDUMP for using in driversKonstantin Khlebnikov
Rename VM_NODUMP into VM_DONTDUMP: this name matches other negative flags: VM_DONTEXPAND, VM_DONTCOPY. Currently this flag used only for sys_madvise. The next patch will use it for replacing the outdated flag VM_RESERVED. Also forbid madvise(MADV_DODUMP) for special kernel mappings VM_SPECIAL (VM_IO | VM_DONTEXPAND | VM_RESERVED | VM_PFNMAP) Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Carsten Otte <cotte@de.ibm.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Eric Paris <eparis@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Hugh Dickins <hughd@google.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: James Morris <james.l.morris@oracle.com> Cc: Jason Baron <jbaron@redhat.com> Cc: Kentaro Takeda <takedakn@nttdata.co.jp> Cc: Matt Helsley <matthltc@us.ibm.com> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Robert Richter <robert.richter@amd.com> Cc: Suresh Siddha <suresh.b.siddha@intel.com> Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Cc: Venkatesh Pallipadi <venki@google.com> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-06coredump: extend core dump note section to contain file names of mapped filesDenys Vlasenko
This note has the following format: long count -- how many files are mapped long page_size -- units for file_ofs array of [COUNT] elements of long start long end long file_ofs followed by COUNT filenames in ASCII: "FILE1" NUL "FILE2" NUL... Signed-off-by: Denys Vlasenko <vda.linux@googlemail.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Amerigo Wang <amwang@redhat.com> Cc: "Jonathan M. Foote" <jmfoote@cert.org> Cc: Roland McGrath <roland@hack.frob.com> Cc: Pedro Alves <palves@redhat.com> Cc: Fengguang Wu <fengguang.wu@intel.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-06coredump: add a new elf note with siginfo of the signalDenys Vlasenko
Existing PRSTATUS note contains only si_signo, si_code, si_errno fields from the siginfo of the signal which caused core to be dumped. There are tools which try to analyze crashes for possible security implications, and they want to use, among other data, si_addr field from the SIGSEGV. This patch adds a new elf note, NT_SIGINFO, which contains the complete siginfo_t of the signal which killed the process. Signed-off-by: Denys Vlasenko <vda.linux@googlemail.com> Reviewed-by: Oleg Nesterov <oleg@redhat.com> Cc: Amerigo Wang <amwang@redhat.com> Cc: "Jonathan M. Foote" <jmfoote@cert.org> Cc: Roland McGrath <roland@hack.frob.com> Cc: Pedro Alves <palves@redhat.com> Cc: Fengguang Wu <fengguang.wu@intel.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-06coredump: pass siginfo_t* to do_coredump() and below, not merely signrDenys Vlasenko
This is a preparatory patch for the introduction of NT_SIGINFO elf note. With this patch we pass "siginfo_t *siginfo" instead of "int signr" to do_coredump() and put it into coredump_params. It will be used by the next patch. Most changes are simple s/signr/siginfo->si_signo/. Signed-off-by: Denys Vlasenko <vda.linux@googlemail.com> Reviewed-by: Oleg Nesterov <oleg@redhat.com> Cc: Amerigo Wang <amwang@redhat.com> Cc: "Jonathan M. Foote" <jmfoote@cert.org> Cc: Roland McGrath <roland@hack.frob.com> Cc: Pedro Alves <palves@redhat.com> Cc: Fengguang Wu <fengguang.wu@intel.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-06binfmt_elf: Uninitialized variableAlan Cox
load_elf_interp() has interp_map_addr carefully described as "uninitialized_var" and marked so as to avoid a warning. However if you trace the code it is passed into load_elf_interp and then this value is checked against NULL. As this return value isn't used this is actually safe but it freaks various analysis tools that see un-initialized memory addresses being read before their value is ever defined. Set it to NULL as a matter of programming good taste if nothing else Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-09-26coredump: prevent double-free on an error path in core dumperDenys Vlasenko
In !CORE_DUMP_USE_REGSET case, if elf_note_info_init fails to allocate memory for info->fields, it frees already allocated stuff and returns error to its caller, fill_note_info. Which in turn returns error to its caller, elf_core_dump. Which jumps to cleanup label and calls free_note_info, which will happily try to free all info->fields again. BOOM. This is the fix. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Denys Vlasenko <vda.linux@googlemail.com> Cc: Venu Byravarasu <vbyravarasu@nvidia.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2012-09-20the only place that needs to include asm/exec.h is linux/binfmts.hAl Viro
2012-05-30binfmt_elf: switch elf_map() to vm_mmap/vm_munmapAl Viro
No reason to hold ->mmap_sem over the sequence Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-05-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace Pull user namespace enhancements from Eric Biederman: "This is a course correction for the user namespace, so that we can reach an inexpensive, maintainable, and reasonably complete implementation. Highlights: - Config guards make it impossible to enable the user namespace and code that has not been converted to be user namespace safe. - Use of the new kuid_t type ensures the if you somehow get past the config guards the kernel will encounter type errors if you enable user namespaces and attempt to compile in code whose permission checks have not been updated to be user namespace safe. - All uids from child user namespaces are mapped into the initial user namespace before they are processed. Removing the need to add an additional check to see if the user namespace of the compared uids remains the same. - With the user namespaces compiled out the performance is as good or better than it is today. - For most operations absolutely nothing changes performance or operationally with the user namespace enabled. - The worst case performance I could come up with was timing 1 billion cache cold stat operations with the user namespace code enabled. This went from 156s to 164s on my laptop (or 156ns to 164ns per stat operation). - (uid_t)-1 and (gid_t)-1 are reserved as an internal error value. Most uid/gid setting system calls treat these value specially anyway so attempting to use -1 as a uid would likely cause entertaining failures in userspace. - If setuid is called with a uid that can not be mapped setuid fails. I have looked at sendmail, login, ssh and every other program I could think of that would call setuid and they all check for and handle the case where setuid fails. - If stat or a similar system call is called from a context in which we can not map a uid we lie and return overflowuid. The LFS experience suggests not lying and returning an error code might be better, but the historical precedent with uids is different and I can not think of anything that would break by lying about a uid we can't map. - Capabilities are localized to the current user namespace making it safe to give the initial user in a user namespace all capabilities. My git tree covers all of the modifications needed to convert the core kernel and enough changes to make a system bootable to runlevel 1." Fix up trivial conflicts due to nearby independent changes in fs/stat.c * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: (46 commits) userns: Silence silly gcc warning. cred: use correct cred accessor with regards to rcu read lock userns: Convert the move_pages, and migrate_pages permission checks to use uid_eq userns: Convert cgroup permission checks to use uid_eq userns: Convert tmpfs to use kuid and kgid where appropriate userns: Convert sysfs to use kgid/kuid where appropriate userns: Convert sysctl permission checks to use kuid and kgids. userns: Convert proc to use kuid/kgid where appropriate userns: Convert ext4 to user kuid/kgid where appropriate userns: Convert ext3 to use kuid/kgid where appropriate userns: Convert ext2 to use kuid/kgid where appropriate. userns: Convert devpts to use kuid/kgid where appropriate userns: Convert binary formats to use kuid/kgid where appropriate userns: Add negative depends on entries to avoid building code that is userns unsafe userns: signal remove unnecessary map_cred_ns userns: Teach inode_capable to understand inodes whose uids map to other namespaces. userns: Fail exec for suid and sgid binaries with ids outside our user namespace. userns: Convert stat to return values mapped from kuids and kgids userns: Convert user specfied uids and gids in chown into kuids and kgid userns: Use uid_eq gid_eq helpers when comparing kuids and kgids in the vfs ...
2012-05-15userns: Convert binary formats to use kuid/kgid where appropriateEric W. Biederman
Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-04-20VM: add "vm_mmap()" helper functionLinus Torvalds
This continues the theme started with vm_brk() and vm_munmap(): vm_mmap() does the same thing as do_mmap(), but additionally does the required VM locking. This uninlines (and rewrites it to be clearer) do_mmap(), which sadly duplicates it in mm/mmap.c and mm/nommu.c. But that way we don't have to export our internal do_mmap_pgoff() function. Some day we hopefully don't have to export do_mmap() either, if all modular users can become the simpler vm_mmap() instead. We're actually very close to that already, with the notable exception of the (broken) use in i810, and a couple of stragglers in binfmt_elf. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-04-20VM: add "vm_brk()" helper functionLinus Torvalds
It does the same thing as "do_brk()", except it handles the VM locking too. It turns out that all external callers want that anyway, so we can make do_brk() static to just mm/mmap.c while at it. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-29Merge branch 'x86-x32-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x32 support for x86-64 from Ingo Molnar: "This tree introduces the X32 binary format and execution mode for x86: 32-bit data space binaries using 64-bit instructions and 64-bit kernel syscalls. This allows applications whose working set fits into a 32 bits address space to make use of 64-bit instructions while using a 32-bit address space with shorter pointers, more compressed data structures, etc." Fix up trivial context conflicts in arch/x86/{Kconfig,vdso/vma.c} * 'x86-x32-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (71 commits) x32: Fix alignment fail in struct compat_siginfo x32: Fix stupid ia32/x32 inversion in the siginfo format x32: Add ptrace for x32 x32: Switch to a 64-bit clock_t x32: Provide separate is_ia32_task() and is_x32_task() predicates x86, mtrr: Use explicit sizing and padding for the 64-bit ioctls x86/x32: Fix the binutils auto-detect x32: Warn and disable rather than error if binutils too old x32: Only clear TIF_X32 flag once x32: Make sure TS_COMPAT is cleared for x32 tasks fs: Remove missed ->fds_bits from cessation use of fd_set structs internally fs: Fix close_on_exec pointer in alloc_fdtable x32: Drop non-__vdso weak symbols from the x32 VDSO x32: Fix coding style violations in the x32 VDSO code x32: Add x32 VDSO support x32: Allow x32 to be configured x32: If configured, add x32 system calls to system call tables x32: Handle process creation x32: Signal-related system calls x86: Add #ifdef CONFIG_COMPAT to <asm/sys_ia32.h> ...
2012-03-28Merge tag 'split-asm_system_h-for-linus-20120328' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system Pull "Disintegrate and delete asm/system.h" from David Howells: "Here are a bunch of patches to disintegrate asm/system.h into a set of separate bits to relieve the problem of circular inclusion dependencies. I've built all the working defconfigs from all the arches that I can and made sure that they don't break. The reason for these patches is that I recently encountered a circular dependency problem that came about when I produced some patches to optimise get_order() by rewriting it to use ilog2(). This uses bitops - and on the SH arch asm/bitops.h drags in asm-generic/get_order.h by a circuituous route involving asm/system.h. The main difficulty seems to be asm/system.h. It holds a number of low level bits with no/few dependencies that are commonly used (eg. memory barriers) and a number of bits with more dependencies that aren't used in many places (eg. switch_to()). These patches break asm/system.h up into the following core pieces: (1) asm/barrier.h Move memory barriers here. This already done for MIPS and Alpha. (2) asm/switch_to.h Move switch_to() and related stuff here. (3) asm/exec.h Move arch_align_stack() here. Other process execution related bits could perhaps go here from asm/processor.h. (4) asm/cmpxchg.h Move xchg() and cmpxchg() here as they're full word atomic ops and frequently used by atomic_xchg() and atomic_cmpxchg(). (5) asm/bug.h Move die() and related bits. (6) asm/auxvec.h Move AT_VECTOR_SIZE_ARCH here. Other arch headers are created as needed on a per-arch basis." Fixed up some conflicts from other header file cleanups and moving code around that has happened in the meantime, so David's testing is somewhat weakened by that. We'll find out anything that got broken and fix it.. * tag 'split-asm_system_h-for-linus-20120328' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system: (38 commits) Delete all instances of asm/system.h Remove all #inclusions of asm/system.h Add #includes needed to permit the removal of asm/system.h Move all declarations of free_initmem() to linux/mm.h Disintegrate asm/system.h for OpenRISC Split arch_align_stack() out from asm-generic/system.h Split the switch_to() wrapper out of asm-generic/system.h Move the asm-generic/system.h xchg() implementation to asm-generic/cmpxchg.h Create asm-generic/barrier.h Make asm-generic/cmpxchg.h #include asm-generic/cmpxchg-local.h Disintegrate asm/system.h for Xtensa Disintegrate asm/system.h for Unicore32 [based on ver #3, changed by gxt] Disintegrate asm/system.h for Tile Disintegrate asm/system.h for Sparc Disintegrate asm/system.h for SH Disintegrate asm/system.h for Score Disintegrate asm/system.h for S390 Disintegrate asm/system.h for PowerPC Disintegrate asm/system.h for PA-RISC Disintegrate asm/system.h for MN10300 ...
2012-03-28Add #includes needed to permit the removal of asm/system.hDavid Howells
asm/system.h is a cause of circular dependency problems because it contains commonly used primitive stuff like barrier definitions and uncommonly used stuff like switch_to() that might require MMU definitions. asm/system.h has been disintegrated by this point on all arches into the following common segments: (1) asm/barrier.h Moved memory barrier definitions here. (2) asm/cmpxchg.h Moved xchg() and cmpxchg() here. #included in asm/atomic.h. (3) asm/bug.h Moved die() and similar here. (4) asm/exec.h Moved arch_align_stack() here. (5) asm/elf.h Moved AT_VECTOR_SIZE_ARCH here. (6) asm/switch_to.h Moved switch_to() here. Signed-off-by: David Howells <dhowells@redhat.com>
2012-03-23coredump: add VM_NODUMP, MADV_NODUMP, MADV_CLEAR_NODUMPJason Baron
Since we no longer need the VM_ALWAYSDUMP flag, let's use the freed bit for 'VM_NODUMP' flag. The idea is is to add a new madvise() flag: MADV_DONTDUMP, which can be set by applications to specifically request memory regions which should not dump core. The specific application I have in mind is qemu: we can add a flag there that wouldn't dump all of guest memory when qemu dumps core. This flag might also be useful for security sensitive apps that want to absolutely make sure that parts of memory are not dumped. To clear the flag use: MADV_DODUMP. [akpm@linux-foundation.org: s/MADV_NODUMP/MADV_DONTDUMP/, s/MADV_CLEAR_NODUMP/MADV_DODUMP/, per Roland] [akpm@linux-foundation.org: fix up the architectures which broke] Signed-off-by: Jason Baron <jbaron@redhat.com> Acked-by: Roland McGrath <roland@hack.frob.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Avi Kivity <avi@redhat.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Matt Turner <mattst88@gmail.com> Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Cc: Helge Deller <deller@gmx.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-23coredump: remove VM_ALWAYSDUMP flagJason Baron
The motivation for this patchset was that I was looking at a way for a qemu-kvm process, to exclude the guest memory from its core dump, which can be quite large. There are already a number of filter flags in /proc/<pid>/coredump_filter, however, these allow one to specify 'types' of kernel memory, not specific address ranges (which is needed in this case). Since there are no more vma flags available, the first patch eliminates the need for the 'VM_ALWAYSDUMP' flag. The flag is used internally by the kernel to mark vdso and vsyscall pages. However, it is simple enough to check if a vma covers a vdso or vsyscall page without the need for this flag. The second patch then replaces the 'VM_ALWAYSDUMP' flag with a new 'VM_NODUMP' flag, which can be set by userspace using new madvise flags: 'MADV_DONTDUMP', and unset via 'MADV_DODUMP'. The core dump filters continue to work the same as before unless 'MADV_DONTDUMP' is set on the region. The qemu code which implements this features is at: http://people.redhat.com/~jbaron/qemu-dump/qemu-dump.patch In my testing the qemu core dump shrunk from 383MB -> 13MB with this patch. I also believe that the 'MADV_DONTDUMP' flag might be useful for security sensitive apps, which might want to select which areas are dumped. This patch: The VM_ALWAYSDUMP flag is currently used by the coredump code to indicate that a vma is part of a vsyscall or vdso section. However, we can determine if a vma is in one these sections by checking it against the gate_vma and checking for a non-NULL return value from arch_vma_name(). Thus, freeing a valuable vma bit. Signed-off-by: Jason Baron <jbaron@redhat.com> Acked-by: Roland McGrath <roland@hack.frob.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Avi Kivity <avi@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-20take removal of PF_FORKNOEXEC to flush_old_exec()Al Viro
2012-03-20__register_binfmt() made voidAl Viro
Just don't pass NULL to it - nobody does, anyway. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-03-02regset: Prevent null pointer reference on readonly regsetsH. Peter Anvin
The regset common infrastructure assumed that regsets would always have .get and .set methods, but not necessarily .active methods. Unfortunately people have since written regsets without .set methods. Rather than putting in stub functions everywhere, handle regsets with null .get or .set methods explicitly. Signed-off-by: H. Peter Anvin <hpa@zytor.com> Reviewed-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Roland McGrath <roland@hack.frob.com> Cc: <stable@vger.kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-02-20elf: Allow core dump-related fields to be overriddenH. J. Lu
Allow some core dump-related fields to be overridden. This allows core dumps to work correctly for x32. Signed-off-by: H. Peter Anvin <hpa@zytor.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Roland McGrath <roland@redhat.com> Cc: Oleg Nesterov <oleg@redhat.com>
2012-01-10fs: binfmt_elf: create Kconfig variable for PIE randomizationDavid Daney
Randomization of PIE load address is hard coded in binfmt_elf.c for X86 and ARM. Create a new Kconfig variable (CONFIG_ARCH_BINFMT_ELF_RANDOMIZE_PIE) for this and use it instead. Thus architecture specific policy is pushed out of the generic binfmt_elf.c and into the architecture Kconfig files. X86 and ARM Kconfigs are modified to select the new variable so there is no change in behavior. A follow on patch will select it for MIPS too. Signed-off-by: David Daney <david.daney@cavium.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Acked-by: H. Peter Anvin <hpa@zytor.com> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-11-02binfmt_elf: fix PIE execution with randomization disabledJiri Kosina
The case of address space randomization being disabled in runtime through randomize_va_space sysctl is not treated properly in load_elf_binary(), resulting in SIGKILL coming at exec() time for certain PIE-linked binaries in case the randomization has been disabled at runtime prior to calling exec(). Handle the randomize_va_space == 0 case the same way as if we were not supporting .text randomization at all. Based on original patch by H.J. Lu and Josh Boyer. Signed-off-by: Jiri Kosina <jkosina@suse.cz> Cc: Ingo Molnar <mingo@elte.hu> Cc: Russell King <rmk@arm.linux.org.uk> Cc: H.J. Lu <hongjiu.lu@intel.com> Cc: <stable@kernel.org> Tested-by: Josh Boyer <jwboyer@redhat.com> Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-20consolidate BINPRM_FLAGS_ENFORCE_NONDUMP handlingAl Viro
new helper: would_dump(bprm, file). Checks if we are allowed to read the file and if we are not - sets ENFORCE_NODUMP. Exported, used in places that previously open-coded the same logics. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-04-14brk: COMPAT_BRK: fix detection of randomized brkJiri Kosina
5520e89 ("brk: fix min_brk lower bound computation for COMPAT_BRK") tried to get the whole logic of brk randomization for legacy (libc5-based) applications finally right. It turns out that the way to detect whether brk has actually been randomized in the end or not introduced by that patch still doesn't work for those binaries, as reported by Geert: : /sbin/init from my old m68k ramdisk exists prematurely. : : Before the patch: : : | brk(0x80005c8e) = 0x80006000 : : After the patch: : : | brk(0x80005c8e) = 0x80005c8e : : Old libc5 considers brk() to have failed if the return value is not : identical to the requested value. I don't like it, but currently see no better option than a bit flag in task_struct to catch the CONFIG_COMPAT_BRK && randomize_va_space == 2 case. Signed-off-by: Jiri Kosina <jkosina@suse.cz> Tested-by: Geert Uytterhoeven <geert@linux-m68k.org> Reported-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: deal with races in /proc/*/{syscall,stack,personality} proc: enable writing to /proc/pid/mem proc: make check_mem_permission() return an mm_struct on success proc: hold cred_guard_mutex in check_mem_permission() proc: disable mem_write after exec mm: implement access_remote_vm mm: factor out main logic of access_process_vm mm: use mm_struct to resolve gate vma's in __get_user_pages mm: arch: rename in_gate_area_no_task to in_gate_area_no_mm mm: arch: make in_gate_area take an mm_struct instead of a task_struct mm: arch: make get_gate_vma take an mm_struct instead of a task_struct x86: mark associated mm when running a task in 32 bit compatibility mode x86: add context tag to mark mm when running a task in 32-bit compatibility mode auxv: require the target to be tracable (or yourself) close race in /proc/*/environ report errors in /proc/*/*map* sanely pagemap: close races with suid execve make sessionid permissions in /proc/*/task/* match those in /proc/* fix leaks in path_lookupat() Fix up trivial conflicts in fs/proc/base.c
2011-03-23mm: arch: make get_gate_vma take an mm_struct instead of a task_structStephen Wilson
Morally, the presence of a gate vma is more an attribute of a particular mm than a particular task. Moreover, dropping the dependency on task_struct will help make both existing and future operations on mm's more flexible and convenient. Signed-off-by: Stephen Wilson <wilsons@start.ca> Reviewed-by: Michel Lespinasse <walken@google.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-22binfmt_elf: quiet GCC-4.6 'set but not used' warning in load_elf_binary()David Daney
With GCC-4.6 we get warnings about things being 'set but not used'. In load_elf_binary() this can happen with reloc_func_desc if ELF_PLAT_INIT is defined, but doesn't use the reloc_func_desc argument. Quiet the warning/error by marking reloc_func_desc as __maybe_unused. Signed-off-by: David Daney <ddaney@caviumnetworks.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13binfmt_elf: cleanupsMikael Pettersson
This cleans up a few bits in binfmt_elf.c and binfmts.h: - the hasvdso field in struct linux_binfmt is unused, so remove it and the only initialization of it - the elf_map CPP symbol is not defined anywhere in the kernel, so remove an unnecessary #ifndef elf_map - reduce excessive indentation in elf_format's initializer - add missing spaces, remove extraneous spaces No functional changes, but tested on x86 (32 and 64 bit), powerpc (32 and 64 bit), sparc64, arm, and alpha. Signed-off-by: Mikael Pettersson <mikpe@it.uu.se> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-08ARM: 6342/1: fix ASLR of PIE executablesNicolas Pitre
Since commits 990cb8acf2 and cc92c28b2d, it is possible to have full address space layout randomization (ASLR) on ARM. Except that one small change was missing for ASLR of PIE executables. Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-03-06coredump: pass mm->flags as a coredump parameter for consistencyMasami Hiramatsu
Pass mm->flags as a coredump parameter for consistency. --- 1787 if (mm->core_state || !get_dumpable(mm)) { <- (1) 1788 up_write(&mm->mmap_sem); 1789 put_cred(cred); 1790 goto fail; 1791 } 1792 [...] 1798 if (get_dumpable(mm) == 2) { /* Setuid core dump mode */ <-(2) 1799 flag = O_EXCL; /* Stop rewrite attacks */ 1800 cred->fsuid = 0; /* Dump root private */ 1801 } --- Since dumpable bits are not protected by lock, there is a chance to change these bits between (1) and (2). To solve this issue, this patch copies mm->flags to coredump_params.mm_flags at the beginning of do_coredump() and uses it instead of get_dumpable() while dumping core. This copy is also passed to binfmt->core_dump, since elf*_core_dump() uses dump_filter bits in mm->flags. [akpm@linux-foundation.org: fix merge] Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Acked-by: Roland McGrath <roland@redhat.com> Cc: Hidehiro Kawai <hidehiro.kawai.ez@hitachi.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06elf coredump: add extended numbering supportDaisuke HATAYAMA
The current ELF dumper implementation can produce broken corefiles if program headers exceed 65535. This number is determined by the number of vmas which the process have. In particular, some extreme programs may use more than 65535 vmas. (If you google max_map_count, you can find some users facing this problem.) This kind of program never be able to generate correct coredumps. This patch implements ``extended numbering'' that uses sh_info field of the first section header instead of e_phnum field in order to represent upto 4294967295 vmas. This is supported by AMD64-ABI(http://www.x86-64.org/documentation.html) and Solaris(http://docs.sun.com/app/docs/doc/817-1984/). Of course, we are preparing patches for gdb and binutils. Signed-off-by: Daisuke HATAYAMA <d.hatayama@jp.fujitsu.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Jeff Dike <jdike@addtoit.com> Cc: David Howells <dhowells@redhat.com> Cc: Greg Ungerer <gerg@snapgear.com> Cc: Roland McGrath <roland@redhat.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Andi Kleen <andi@firstfloor.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06elf coredump: make offset calculation process and writing process explicitDaisuke HATAYAMA
By the next patch, elf_core_dump() and elf_fdpic_core_dump() will support extended numbering and so will produce the corefiles with section header table in a special case. The problem is the process of writing a file header offset of the section header table into e_shoff field of the ELF header. ELF header is positioned at the beginning of the corefile, while section header at the end. So, we need to take which of the following ways: 1. Seek backward to retry writing operation for ELF header after writing process for a whole part 2. Make offset calculation process and writing process totally sequential The clause 1. is not always possible: one cannot assume that file system supports seek function. Consider the no_llseek case. Therefore, this patch adopts the clause 2. Signed-off-by: Daisuke HATAYAMA <d.hatayama@jp.fujitsu.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Jeff Dike <jdike@addtoit.com> Cc: David Howells <dhowells@redhat.com> Cc: Greg Ungerer <gerg@snapgear.com> Cc: Roland McGrath <roland@redhat.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Andi Kleen <andi@firstfloor.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06elf coredump: replace ELF_CORE_EXTRA_* macros by functionsDaisuke HATAYAMA
elf_core_dump() and elf_fdpic_core_dump() use #ifdef and the corresponding macro for hiding _multiline_ logics in functions. This patch removes #ifdef and replaces ELF_CORE_EXTRA_* by corresponding functions. For architectures not implemeonting ELF_CORE_EXTRA_*, we use weak functions in order to reduce a range of modification. This cleanup is for my next patches, but I think this cleanup itself is worth doing regardless of my firnal purpose. Signed-off-by: Daisuke HATAYAMA <d.hatayama@jp.fujitsu.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Jeff Dike <jdike@addtoit.com> Cc: David Howells <dhowells@redhat.com> Cc: Greg Ungerer <gerg@snapgear.com> Cc: Roland McGrath <roland@redhat.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Andi Kleen <andi@firstfloor.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
