path: root/fs/binfmt_elf_fdpic.c
2006-01-10[PATCH] fs/binfmt_elf: Remove unneeded kmalloc() return value castsJesper Juhl
Remove unneeded casts of kmalloc() return value in binfmt_elf. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] kfree cleanup: fsJesper Juhl
This is the fs/ part of the big kfree cleanup patch. Remove pointless checks for NULL prior to calling kfree() in fs/. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29[PATCH] mm: mm_init set_mm_countersHugh Dickins
How is anon_rss initialized? In dup_mmap, and by mm_alloc's memset; but that's not so good if an mm_counter_t is a special type. And how is rss initialized? By set_mm_counter, all over the place. Come on, we just need to initialize them both at once by set_mm_counter in mm_init (which follows the memcpy when forking). Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
